RTEMS  5.1
reg_ccmsr.h
1 /* The header file is generated by make_header.py from CCMSR.json */
2 /* Current script's version can be found at: */
3 /* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5 /*
6  * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7  *
8  * Czech Technical University in Prague
9  * Zikova 1903/4
10  * 166 36 Praha 6
11  * Czech Republic
12  *
13  * All rights reserved.
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions are met:
17  *
18  * 1. Redistributions of source code must retain the above copyright notice, this
19  * list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright notice,
21  * this list of conditions and the following disclaimer in the documentation
22  * and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28  * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29  * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30  * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31  * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34  *
35  * The views and conclusions contained in the software and documentation are those
36  * of the authors and should not be interpreted as representing official policies,
37  * either expressed or implied, of the FreeBSD Project.
38 */
39 #ifndef LIBBSP_ARM_TMS570_CCMSR
40 #define LIBBSP_ARM_TMS570_CCMSR
41
42 #include <bsp/utility.h>
43
44 typedef struct{
45  uint32_t CCMSR; /*CCM-R4F Status Register*/
46  uint32_t CCMKEYR; /*CCM-R4F Key Register*/
48
49
50 /*---------------------TMS570_CCMSR_CCMSR---------------------*/
51 /* field: CMPE - Compare Error */
52 #define TMS570_CCMSR_CCMSR_CMPE BSP_BIT32(16)
53
54 /* field: STC - Self-test Complete */
55 #define TMS570_CCMSR_CCMSR_STC BSP_BIT32(8)
56
57 /* field: STET - Self-test Error Type */
58 #define TMS570_CCMSR_CCMSR_STET BSP_BIT32(1)
59
60 /* field: STE - Self-test Error */
61 #define TMS570_CCMSR_CCMSR_STE BSP_BIT32(0)
62
63
64 /*--------------------TMS570_CCMSR_CCMKEYR--------------------*/
65 /* field: MKEY - Mode Key */
66 #define TMS570_CCMSR_CCMKEYR_MKEY(val) BSP_FLD32(val,0, 3)
67 #define TMS570_CCMSR_CCMKEYR_MKEY_GET(reg) BSP_FLD32GET(reg,0, 3)
68 #define TMS570_CCMSR_CCMKEYR_MKEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
69
70
71
72 #endif /* LIBBSP_ARM_TMS570_CCMSR */
Definition: reg_ccmsr.h:44
Utility macros.
