RTEMS  5.1
recordclient.h
1 /*
2  * SPDX-License-Identifier: BSD-2-Clause
3  *
4  * Copyright (C) 2018, 2019 embedded brains GmbH
5  *
6  * Redistribution and use in source and binary forms, with or without
7  * modification, are permitted provided that the following conditions
8  * are met:
9  * 1. Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * 2. Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  *
15  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25  * POSSIBILITY OF SUCH DAMAGE.
26  */
27
28 /*
29  * This file must be compatible to general purpose POSIX system, e.g. Linux,
30  * FreeBSD. It may be used for utility programs.
31  */
32
33 #ifndef _RTEMS_RECORDCLIENT_H
34 #define _RTEMS_RECORDCLIENT_H
35
36 #include "recorddata.h"
37
38 #include <stdbool.h>
39 #include <stddef.h>
40
41 #ifdef __cplusplus
42 extern "C" {
43 #endif /* __cplusplus */
44
51 #define RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT 32
52
53 typedef enum {
54  RTEMS_RECORD_CLIENT_SUCCESS,
55  RTEMS_RECORD_CLIENT_ERROR_INVALID_MAGIC,
56  RTEMS_RECORD_CLIENT_ERROR_UNKNOWN_FORMAT,
57  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_VERSION,
58  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU,
59  RTEMS_RECORD_CLIENT_ERROR_UNSUPPORTED_CPU_MAX,
60  RTEMS_RECORD_CLIENT_ERROR_DOUBLE_CPU_MAX,
61  RTEMS_RECORD_CLIENT_ERROR_DOUBLE_PER_CPU_COUNT,
62  RTEMS_RECORD_CLIENT_ERROR_NO_CPU_MAX,
63  RTEMS_RECORD_CLIENT_ERROR_NO_MEMORY,
64  RTEMS_RECORD_CLIENT_ERROR_PER_CPU_ITEMS_OVERFLOW
65 } rtems_record_client_status;
66
67 typedef rtems_record_client_status ( *rtems_record_client_handler )(
68  uint64_t bt,
69  uint32_t cpu,
70  rtems_record_event event,
71  uint64_t data,
72  void *arg
73 );
74
75 typedef struct {
79  struct {
80  uint64_t bt;
81  uint32_t time_at_bt;
82  uint32_t time_last;
83  uint32_t time_accumulated;
84  } uptime;
85
91  uint32_t tail[ 2 ];
92
98  uint32_t head[ 2 ];
99
107
111  uint32_t overflow;
112
117  bool hold_back;
118
131  rtems_record_item_64 *items;
132
136  size_t item_index;
138
140  uint64_t to_bt_scaler;
141  rtems_record_client_per_cpu per_cpu[ RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT ];
142  uint32_t cpu;
143  uint32_t cpu_count;
144  uint32_t count;
145  union {
146  rtems_record_item_32 format_32;
147  rtems_record_item_64 format_64;
148  } item;
149  size_t todo;
150  void *pos;
151  rtems_record_client_status ( *consume )(
153  const void *,
154  size_t
155  );
156  rtems_record_client_handler handler;
157  void *handler_arg;
158  size_t data_size;
159  uint32_t header[ 2 ];
160  rtems_record_client_status status;
162
175  rtems_record_client_handler handler,
176  void *arg
177 );
178
186 rtems_record_client_status rtems_record_client_run(
188  const void *buf,
189  size_t n
190 );
191
202 );
203
204 static inline void rtems_record_client_set_handler(
206  rtems_record_client_handler handler
207 )
208 {
209  ctx->handler = handler;
210 }
211
212 static inline uint64_t rtems_record_client_bintime_to_nanoseconds(
213  uint64_t bt
214 )
215 {
216  uint64_t ns_per_sec;
217  uint64_t nanoseconds;
218
219  ns_per_sec = 1000000000ULL;
220  nanoseconds = ns_per_sec * ( (uint32_t) ( bt >> 32 ) );
221  nanoseconds += ( ns_per_sec * (uint32_t) bt ) >> 32;
222
223  return nanoseconds;
224 }
225
226 static inline void rtems_record_client_bintime_to_seconds_and_nanoseconds(
227  uint64_t bt,
228  uint32_t *seconds,
229  uint32_t *nanoseconds
230 )
231 {
232  uint64_t ns_per_sec;
233
234  ns_per_sec = 1000000000ULL;
235  *seconds = (uint32_t) ( bt >> 32 );
236  *nanoseconds = (uint32_t) ( ( ns_per_sec * (uint32_t) bt ) >> 32 );
237 }
238
241 #ifdef __cplusplus
242 }
243 #endif /* __cplusplus */
244
245 #endif /* _RTEMS_RECORDCLIENT_H */
size_t item_index
The index for the next hold back item.
Definition: recordclient.h:136
void rtems_record_client_init(rtems_record_client_context *ctx, rtems_record_client_handler handler, void *arg)
Initializes a record client.
Definition: record-client.c:688
rtems_record_client_status rtems_record_client_run(rtems_record_client_context *ctx, const void *buf, size_t n)
Runs the record client to consume new stream data.
Definition: record-client.c:703
rtems_record_event
The record events.
Definition: recorddata.h:90
size_t tail_head_index
The index of the tail and head members.
Definition: recordclient.h:106
uint32_t overflow
Count of lost items due to ring buffer overflows.
Definition: recordclient.h:111
Definition: recordclient.h:139
Definition: recordclient.h:75
The 32-bit format record item.
Definition: recorddata.h:1183
bool hold_back
If true, then hold back items for overflow or initial ramp up processing.
Definition: recordclient.h:117
void rtems_record_client_destroy(rtems_record_client_context *ctx)
Drains all internal buffers and frees the allocated resources.
Definition: record-client.c:712
