RTEMS  5.1
raspberrypi.h
1
9 /*
10  * Copyright (c) 2014-2015 Andre Marques <andre.lousa.marques at gmail.com>
11  * Copyright (c) 2013 Alan Cudmore.
12  * Copyright (c) 2015 Yang Qiao
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  *
17  * http://www.rtems.org/license/LICENSE
18  *
19  */
20
21 #ifndef LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H
22 #define LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H
23
24 #include <bspopts.h>
25 #include <stdint.h>
26 #include <bsp/utility.h>
27
44 #define BCM2835_REG(x) (*(volatile uint32_t *)(x))
45 #define BCM2835_BIT(n) (1 << (n))
46
55 #if (BSP_IS_RPI2 == 1)
56  #define RPI_PERIPHERAL_BASE 0x3F000000
57  #define BASE_OFFSET 0X3F000000
58 #else
59  #define RPI_PERIPHERAL_BASE 0x20000000
60  #define BASE_OFFSET 0X5E000000
61 #endif
62
63 #define RPI_PERIPHERAL_SIZE 0x01000000
64
71 #define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
72
81 #define BCM2835_CLOCK_FREQ 250000000
82
83 #define BCM2835_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400)
84
85 #define BCM2835_TIMER_LOD (BCM2835_TIMER_BASE + 0x00)
86 #define BCM2835_TIMER_VAL (BCM2835_TIMER_BASE + 0x04)
87 #define BCM2835_TIMER_CTL (BCM2835_TIMER_BASE + 0x08)
88 #define BCM2835_TIMER_CLI (BCM2835_TIMER_BASE + 0x0C)
89 #define BCM2835_TIMER_RIS (BCM2835_TIMER_BASE + 0x10)
90 #define BCM2835_TIMER_MIS (BCM2835_TIMER_BASE + 0x14)
91 #define BCM2835_TIMER_RLD (BCM2835_TIMER_BASE + 0x18)
92 #define BCM2835_TIMER_DIV (BCM2835_TIMER_BASE + 0x1C)
93 #define BCM2835_TIMER_CNT (BCM2835_TIMER_BASE + 0x20)
94
95 #define BCM2835_TIMER_PRESCALE 0xF9
96
105 #define BCM2835_PM_PASSWD_MAGIC 0x5a000000
106
107 #define BCM2835_PM_BASE (RPI_PERIPHERAL_BASE + 0x100000)
108
109 #define BCM2835_PM_GNRIC (BCM2835_PM_BASE + 0x00)
110 #define BCM2835_PM_GNRIC_POWUP 0x00000001
111 #define BCM2835_PM_GNRIC_POWOK 0x00000002
112 #define BCM2835_PM_GNRIC_ISPOW 0x00000004
113 #define BCM2835_PM_GNRIC_MEMREP 0x00000008
114 #define BCM2835_PM_GNRIC_MRDONE 0x00000010
115 #define BCM2835_PM_GNRIC_ISFUNC 0x00000020
116 #define BCM2835_PM_GNRIC_RSTN 0x00000fc0
117 #define BCM2835_PM_GNRIC_ENAB 0x00001000
118 #define BCM2835_PM_GNRIC_CFG 0x007f0000
119
120 #define BCM2835_PM_AUDIO (BCM2835_PM_BASE + 0x04)
121 #define BCM2835_PM_AUDIO_APSM 0x000fffff
122 #define BCM2835_PM_AUDIO_CTRLEN 0x00100000
123 #define BCM2835_PM_AUDIO_RSTN 0x00200000
124
125 #define BCM2835_PM_STATUS (BCM2835_PM_BASE + 0x18)
126
127 #define BCM2835_PM_RSTC (BCM2835_PM_BASE + 0x1c)
128 #define BCM2835_PM_RSTC_DRCFG 0x00000003
129 #define BCM2835_PM_RSTC_WRCFG 0x00000030
130 #define BCM2835_PM_RSTC_WRCFG_FULL 0x00000020
131 #define BCM2835_PM_RSTC_SRCFG 0x00000300
132 #define BCM2835_PM_RSTC_QRCFG 0x00003000
133 #define BCM2835_PM_RSTC_FRCFG 0x00030000
134 #define BCM2835_PM_RSTC_HRCFG 0x00300000
135
136 #define BCM2835_PM_RSTS (BCM2835_PM_BASE + 0x20)
137 #define BCM2835_PM_RSTS_HADDRQ 0x00000001
138 #define BCM2835_PM_RSTS_HADDRF 0x00000002
139 #define BCM2835_PM_RSTS_HADDRH 0x00000004
140 #define BCM2835_PM_RSTS_HADWRQ 0x00000010
141 #define BCM2835_PM_RSTS_HADWRF 0x00000020
142 #define BCM2835_PM_RSTS_HADWRH 0x00000040
143 #define BCM2835_PM_RSTS_HADSRQ 0x00000100
144 #define BCM2835_PM_RSTS_HADSRF 0x00000200
145 #define BCM2835_PM_RSTS_HADSRH 0x00000400
146 #define BCM2835_PM_RSTS_HADPOR 0x00001000
147
148 #define BCM2835_PM_WDOG (BCM2835_PM_BASE + 0x24)
149
158 #define BCM2835_GPIO_REGS_BASE (RPI_PERIPHERAL_BASE + 0x200000)
159
160 #define BCM2835_GPIO_GPFSEL1 (BCM2835_GPIO_REGS_BASE + 0x04)
161 #define BCM2835_GPIO_GPSET0 (BCM2835_GPIO_REGS_BASE + 0x1C)
162 #define BCM2835_GPIO_GPCLR0 (BCM2835_GPIO_REGS_BASE + 0x28)
163 #define BCM2835_GPIO_GPLEV0 (BCM2835_GPIO_REGS_BASE + 0x34)
164 #define BCM2835_GPIO_GPEDS0 (BCM2835_GPIO_REGS_BASE + 0x40)
165 #define BCM2835_GPIO_GPREN0 (BCM2835_GPIO_REGS_BASE + 0x4C)
166 #define BCM2835_GPIO_GPFEN0 (BCM2835_GPIO_REGS_BASE + 0x58)
167 #define BCM2835_GPIO_GPHEN0 (BCM2835_GPIO_REGS_BASE + 0x64)
168 #define BCM2835_GPIO_GPLEN0 (BCM2835_GPIO_REGS_BASE + 0x70)
169 #define BCM2835_GPIO_GPAREN0 (BCM2835_GPIO_REGS_BASE + 0x7C)
170 #define BCM2835_GPIO_GPAFEN0 (BCM2835_GPIO_REGS_BASE + 0x88)
171 #define BCM2835_GPIO_GPPUD (BCM2835_GPIO_REGS_BASE + 0x94)
172 #define BCM2835_GPIO_GPPUDCLK0 (BCM2835_GPIO_REGS_BASE + 0x98)
173
182 #define BCM2835_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000)
183
184 #define AUX_ENABLES (BCM2835_AUX_BASE + 0x04)
185 #define AUX_MU_IO_REG (BCM2835_AUX_BASE + 0x40)
186 #define AUX_MU_IER_REG (BCM2835_AUX_BASE + 0x44)
187 #define AUX_MU_IIR_REG (BCM2835_AUX_BASE + 0x48)
188 #define AUX_MU_LCR_REG (BCM2835_AUX_BASE + 0x4C)
189 #define AUX_MU_MCR_REG (BCM2835_AUX_BASE + 0x50)
190 #define AUX_MU_LSR_REG (BCM2835_AUX_BASE + 0x54)
191 #define AUX_MU_MSR_REG (BCM2835_AUX_BASE + 0x58)
192 #define AUX_MU_SCRATCH (BCM2835_AUX_BASE + 0x5C)
193 #define AUX_MU_CNTL_REG (BCM2835_AUX_BASE + 0x60)
194 #define AUX_MU_STAT_REG (BCM2835_AUX_BASE + 0x64)
195 #define AUX_MU_BAUD_REG (BCM2835_AUX_BASE + 0x68)
196
207 #define BCM2835_I2C_BASE (RPI_PERIPHERAL_BASE + 0x804000)
208
209 #define BCM2835_I2C_C (BCM2835_I2C_BASE + 0x00)
210 #define BCM2835_I2C_S (BCM2835_I2C_BASE + 0x04)
211 #define BCM2835_I2C_DLEN (BCM2835_I2C_BASE + 0x08)
212 #define BCM2835_I2C_A (BCM2835_I2C_BASE + 0x0C)
213 #define BCM2835_I2C_FIFO (BCM2835_I2C_BASE + 0x10)
214 #define BCM2835_I2C_DIV (BCM2835_I2C_BASE + 0x14)
215 #define BCM2835_I2C_DEL (BCM2835_I2C_BASE + 0x18)
216 #define BCM2835_I2C_CLKT (BCM2835_I2C_BASE + 0x1C)
217
226 #define BCM2835_SPI_BASE (RPI_PERIPHERAL_BASE + 0x204000)
227
228 #define BCM2835_SPI_CS (BCM2835_SPI_BASE + 0x00)
229 #define BCM2835_SPI_FIFO (BCM2835_SPI_BASE + 0x04)
230 #define BCM2835_SPI_CLK (BCM2835_SPI_BASE + 0x08)
231 #define BCM2835_SPI_DLEN (BCM2835_SPI_BASE + 0x0C)
232 #define BCM2835_SPI_LTOH (BCM2835_SPI_BASE + 0x10)
233 #define BCM2835_SPI_DC (BCM2835_SPI_BASE + 0x14)
234
243 #define BCM2835_I2C_SPI_BASE (RPI_PERIPHERAL_BASE + 0x214000)
244
245 #define BCM2835_I2C_SPI_DR (BCM2835_I2C_SPI_BASE + 0x00)
246 #define BCM2835_I2C_SPI_RSR (BCM2835_I2C_SPI_BASE + 0x04)
247 #define BCM2835_I2C_SPI_SLV (BCM2835_I2C_SPI_BASE + 0x08)
248 #define BCM2835_I2C_SPI_CR (BCM2835_I2C_SPI_BASE + 0x0C)
249 #define BCM2835_I2C_SPI_FR (BCM2835_I2C_SPI_BASE + 0x10)
250 #define BCM2835_I2C_SPI_IFLS (BCM2835_I2C_SPI_BASE + 0x14)
251 #define BCM2835_I2C_SPI_IMSC (BCM2835_I2C_SPI_BASE + 0x18)
252 #define BCM2835_I2C_SPI_RIS (BCM2835_I2C_SPI_BASE + 0x1C)
253 #define BCM2835_I2C_SPI_MIS (BCM2835_I2C_SPI_BASE + 0x20)
254 #define BCM2835_I2C_SPI_ICR (BCM2835_I2C_SPI_BASE + 0x24)
255 #define BCM2835_I2C_SPI_DMACR (BCM2835_I2C_SPI_BASE + 0x28)
256 #define BCM2835_I2C_SPI_TDR (BCM2835_I2C_SPI_BASE + 0x2C)
257 #define BCM2835_I2C_SPI_GPUSTAT (BCM2835_I2C_SPI_BASE + 0x30)
258 #define BCM2835_I2C_SPI_HCTRL (BCM2835_I2C_SPI_BASE + 0x34)
259
268 #define BCM2835_BASE_INTC (RPI_PERIPHERAL_BASE + 0xB200)
269
270 #define BCM2835_IRQ_BASIC (BCM2835_BASE_INTC + 0x00)
271 #define BCM2835_IRQ_PENDING1 (BCM2835_BASE_INTC + 0x04)
272 #define BCM2835_IRQ_PENDING2 (BCM2835_BASE_INTC + 0x08)
273 #define BCM2835_IRQ_FIQ_CTRL (BCM2835_BASE_INTC + 0x0C)
274 #define BCM2835_IRQ_ENABLE1 (BCM2835_BASE_INTC + 0x10)
275 #define BCM2835_IRQ_ENABLE2 (BCM2835_BASE_INTC + 0x14)
276 #define BCM2835_IRQ_ENABLE_BASIC (BCM2835_BASE_INTC + 0x18)
277 #define BCM2835_IRQ_DISABLE1 (BCM2835_BASE_INTC + 0x1C)
278 #define BCM2835_IRQ_DISABLE2 (BCM2835_BASE_INTC + 0x20)
279 #define BCM2835_IRQ_DISABLE_BASIC (BCM2835_BASE_INTC + 0x24)
280
294 #define BCM2835_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000)
295
296 #define BCM2835_GPU_TIMER_CS (BCM2835_GPU_TIMER_BASE + 0x00)
297 #define BCM2835_GPU_TIMER_CS_M0 0x00000001
298 #define BCM2835_GPU_TIMER_CS_M1 0x00000002
299 #define BCM2835_GPU_TIMER_CS_M2 0x00000004
300 #define BCM2835_GPU_TIMER_CS_M3 0x00000008
301 #define BCM2835_GPU_TIMER_CLO (BCM2835_GPU_TIMER_BASE + 0x04)
302 #define BCM2835_GPU_TIMER_CHI (BCM2835_GPU_TIMER_BASE + 0x08)
303 #define BCM2835_GPU_TIMER_C0 (BCM2835_GPU_TIMER_BASE + 0x0C)
304 #define BCM2835_GPU_TIMER_C1 (BCM2835_GPU_TIMER_BASE + 0x10)
305 #define BCM2835_GPU_TIMER_C2 (BCM2835_GPU_TIMER_BASE + 0x14)
306 #define BCM2835_GPU_TIMER_C3 (BCM2835_GPU_TIMER_BASE + 0x18)
307
321 #define BCM2835_EMMC_BASE (RPI_PERIPHERAL_BASE + 0x300000)
322
331 #define BCM2835_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
332
333 #define BCM2835_MBOX_PEEK (BCM2835_MBOX_BASE+0x10)
334 #define BCM2835_MBOX_READ (BCM2835_MBOX_BASE+0x00)
335 #define BCM2835_MBOX_WRITE (BCM2835_MBOX_BASE+0x20)
336 #define BCM2835_MBOX_STATUS (BCM2835_MBOX_BASE+0x18)
337 #define BCM2835_MBOX_SENDER (BCM2835_MBOX_BASE+0x14)
338 #define BCM2835_MBOX_CONFIG (BCM2835_MBOX_BASE+0x1C)
339
340 #define BCM2835_MBOX_FULL 0x80000000
341 #define BCM2835_MBOX_EMPTY 0x40000000
342
351 /* Power Manager channel */
352 #define BCM2835_MBOX_CHANNEL_PM 0
353 /* Framebuffer channel */
354 #define BCM2835_MBOX_CHANNEL_FB 1
355  /* Virtual UART channel */
356 #define BCM2835_MBOX_CHANNEL_VUART 2
357  /* VCHIQ channel */
358 #define BCM2835_MBOX_CHANNEL_VCHIQ 3
359  /* LEDs channel */
360 #define BCM2835_MBOX_CHANNEL_LED 4
361  /* Button channel */
362 #define BCM2835_MBOX_CHANNEL_BUTTON 5
363  /* Touch screen channel */
364 #define BCM2835_MBOX_CHANNEL_TOUCHS 6
365 /* Property tags (ARM <-> VC) channel */
366 #define BCM2835_MBOX_CHANNEL_PROP_AVC 8
367  /* Property tags (VC <-> ARM) channel */
368 #define BCM2835_MBOX_CHANNEL_PROP_VCA 9
369
378 #define BCM2835_USB_BASE (RPI_PERIPHERAL_BASE + 0x980000) /* DTC_OTG USB controller */
379
388 #define BCM2836_CORE_LOCAL_PERIPH_BASE 0x40000000
389 #define BCM2836_CORE_LOCAL_PERIPH_SIZE 0x00040000
390
399 #define BCM2836_MAILBOX_0_WRITE_SET_BASE 0x40000080
400 #define BCM2836_MAILBOX_1_WRITE_SET_BASE 0x40000084
401 #define BCM2836_MAILBOX_2_WRITE_SET_BASE 0x40000088
402 #define BCM2836_MAILBOX_3_WRITE_SET_BASE 0x4000008C
403 #define BCM2836_MAILBOX_0_READ_CLEAR_BASE 0x400000C0
404 #define BCM2836_MAILBOX_1_READ_CLEAR_BASE 0x400000C4
405 #define BCM2836_MAILBOX_2_READ_CLEAR_BASE 0x400000C8
406 #define BCM2836_MAILBOX_3_READ_CLEAR_BASE 0x400000CC
407
416 #define BCM2836_CORE_TIMER_CTRL 0x40000000
417
418 #define BCM2836_CORE_TIMER_CTRL_APB_CLK 0x00000100
419 #define BCM2836_CORE_TIMER_CTRL_INC_2 0x00000200
420
421 #define BCM2836_CORE_TIMER_PRESCALER 0x40000008
422
423 #define BCM2836_CORE_TIMER_LS32 0x4000001C
424 #define BCM2836_CORE_TIMER_MS32 0x40000020
425
434 #define BCM2836_LOCAL_TIMER_CTRL 0x40000034
435
436 #define BCM2836_LOCAL_TIMER_CTRL_IRQ_FLAG 0x80000000
437 #define BCM2836_LOCAL_TIMER_CTRL_IRQ_EN 0x20000000
438 #define BCM2836_LOCAL_TIMER_CTRL_TIMER_EN 0x10000000
439 #define BCM2836_LOCAL_TIMER_RELOAD 0x0FFFFFFF
440
441 #define BCM2836_LOCAL_TIMER_IRQ_RELOAD 0x40000038
442
443 #define BCM2836_LOCAL_TIMER_IRQ_CLEAR 0x80000000
444 #define BCM2836_LOCAL_TIMER_RELOAD_NOW 0x40000000
445
446 #define BCM2836_LOCAL_TIMER_IRQ_ROUTING 0x40000024
447 #define BCM2836_LOCAL_TIMER_ROU_CORE0_IRQ 0x00
448 #define BCM2836_LOCAL_TIMER_ROU_CORE1_IRQ 0x01
449 #define BCM2836_LOCAL_TIMER_ROU_CORE2_IRQ 0x02
450 #define BCM2836_LOCAL_TIMER_ROU_CORE3_IRQ 0x03
451 #define BCM2836_LOCAL_TIMER_ROU_CORE0_FIQ 0x04
452 #define BCM2836_LOCAL_TIMER_ROU_CORE1_FIQ 0x05
453 #define BCM2836_LOCAL_TIMER_ROU_CORE2_FIQ 0x06
454 #define BCM2836_LOCAL_TIMER_ROU_CORE3_FIQ 0x07
455
464 #define BCM2836_GPU_IRQ_ROUTING 0x4000000C
465
466 #define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE0 0x00000000
467 #define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE1 0x00000001
468 #define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE2 0x00000002
469 #define BCM2836_GPU_IRQ_ROU_GPU_IRQ_CORE4 0x00000003
470
471 #define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE0 0x00000000
472 #define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE1 0x00000004
473 #define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE2 0x00000008
474 #define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE4 0x0000000C
475
476 #define BCM2836_GPU_IRQ_ROU_GPU_FIQ_CORE4 0x0000000C
477
478
487 /* Timers interrupt control registers */
488 #define BCM2836_CORE0_TIMER_IRQ_CTRL_BASE 0x40000040
489 #define BCM2836_CORE1_TIMER_IRQ_CTRL_BASE 0x40000044
490 #define BCM2836_CORE2_TIMER_IRQ_CTRL_BASE 0x40000048
491 #define BCM2836_CORE3_TIMER_IRQ_CTRL_BASE 0x4000004C
492
493 #define BCM2836_CORE_TIMER_IRQ_CTRL(cpuidx) \
494  (BCM2836_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
495
496 /*
497  * Where to route timer interrupt to, IRQ/FIQ
498  * Setting both the IRQ and FIQ bit gives an FIQ
499  */
500 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_IRQ 0x01
501 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_IRQ 0x02
502 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_IRQ 0x04
503 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_IRQ 0x08
504 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER0_FIQ 0x10
505 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER1_FIQ 0x20
506 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER2_FIQ 0x40
507 #define BCM2836_CORE_TIMER_IRQ_CTRL_TIMER3_FIQ 0x80
508
509 /* CPU mailbox registers */
510 #define BCM2836_MAILBOX_IRQ_CTRL_BASE 0x40000050
511 #define BCM2836_MAILBOX_IRQ_CTRL(cpuidx) \
512  (BCM2836_MAILBOX_IRQ_CTRL_BASE + 0x4 * (cpuidx))
513 /*
514  * Where to route mailbox interrupt to, IRQ/FIQ
515  * Setting both the IRQ and FIQ bit gives an FIQ
516  */
517 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_IRQ 0x01
518 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_IRQ 0x02
519 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_IRQ 0x04
520 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_IRQ 0x08
521 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX0_FIQ 0x10
522 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX1_FIQ 0x20
523 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX2_FIQ 0x40
524 #define BCM2836_MAILBOX_IRQ_CTRL_MBOX3_FIQ 0x80
525
526 #define BCM2836_IRQ_SOURCE_REG_BASE 0x40000060
527 #define BCM2836_IRQ_SOURCE_REG(cpuidx) \
528  (BCM2836_IRQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
529
530 #define BCM2836_FIQ_SOURCE_REG_BASE 0x40000070
531 #define BCM2836_FIQ_SOURCE_REG(cpuidx) \
532  (BCM2836_FIQ_SOURCE_REG_BASE + 0x4 * (cpuidx))
533
534 #define BCM2836_IRQ_SOURCE_TIMER0 0x00000001
535 #define BCM2836_IRQ_SOURCE_TIMER1 0x00000002
536 #define BCM2836_IRQ_SOURCE_TIMER2 0x00000004
537 #define BCM2836_IRQ_SOURCE_TIMER3 0x00000008
538 #define BCM2836_IRQ_SOURCE_MBOX0 0x00000010
539 #define BCM2836_IRQ_SOURCE_MBOX1 0x00000020
540 #define BCM2836_IRQ_SOURCE_MBOX2 0x00000040
541 #define BCM2836_IRQ_SOURCE_MBOX3 0x00000080
542 #define BCM2836_IRQ_SOURCE_GPU 0x00000100
543 #define BCM2836_IRQ_SOURCE_PMU 0x00000200
544 #define BCM2836_IRQ_SOURCE_LOCAL_TIMER 0x00000800
545
548 #endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
Utility macros.
