RTEMS  5.1
qoriq.h
1
9 /*
10  * Copyright (c) 2010-2015 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_POWERPC_QORIQ_QORIQ_H
24 #define LIBBSP_POWERPC_QORIQ_QORIQ_H
25
26 #include <bsp.h>
27 #include <bsp/tsec.h>
28 #include <bsp/utility.h>
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif /* __cplusplus */
33
34 #define QORIQ_FILL(a, b, s) uint8_t reserved_ ## b [b - a - sizeof(s)]
35 #define QORIQ_RESERVE(a, b) uint8_t reserved_ ## b [b - a]
36
37 typedef struct {
38  uint32_t reg;
39  QORIQ_FILL(0x00000, 0x00010, uint32_t);
41
42 typedef struct {
43  uint32_t ccr;
44  QORIQ_FILL(0x00000, 0x00010, uint32_t);
45  uint32_t bcr;
46  QORIQ_FILL(0x00010, 0x00020, uint32_t);
47  uint32_t vpr;
48  QORIQ_FILL(0x00020, 0x00030, uint32_t);
49  uint32_t dr;
50  QORIQ_FILL(0x00030, 0x00040, uint32_t);
52
53 #define GTCCR_TOG BSP_BBIT32(0)
54 #define GTCCR_COUNT_GET(reg) BSP_BFLD32GET(reg, 1, 31)
55
56 #define GTBCR_CI BSP_BBIT32(0)
57 #define GTBCR_COUNT(val) BSP_BFLD32(val, 1, 31)
58 #define GTBCR_COUNT_GET(reg) BSP_BFLD32GET(reg, 1, 31)
59 #define GTBCR_COUNT_SET(reg, val) BSP_BFLD32SET(reg, val, 1, 31)
60
61 typedef struct {
62  uint32_t misc;
63  QORIQ_FILL(0x00000, 0x00010, uint32_t);
64  uint32_t internal [2];
65  QORIQ_FILL(0x00010, 0x00020, uint32_t [2]);
67
68 typedef struct {
69  uint32_t vpr;
70  QORIQ_FILL(0x00000, 0x00010, uint32_t);
71  uint32_t dr;
72  QORIQ_FILL(0x00010, 0x00020, uint32_t);
74
75 typedef struct {
76  QORIQ_RESERVE(0x00000, 0x00040);
77  qoriq_pic_reg ipidr [4];
78  uint32_t ctpr;
79  QORIQ_FILL(0x00080, 0x00090, uint32_t);
80  uint32_t whoami;
81  QORIQ_FILL(0x00090, 0x000a0, uint32_t);
82  uint32_t iack;
83  QORIQ_FILL(0x000a0, 0x000b0, uint32_t);
84  uint32_t eoi;
85  QORIQ_FILL(0x000b0, 0x01000, uint32_t);
87
88 typedef struct {
89  uint32_t brr1;
90  QORIQ_FILL(0x00000, 0x00010, uint32_t);
91  uint32_t brr2;
92  QORIQ_FILL(0x00010, 0x00040, uint32_t);
93  qoriq_pic_reg ipidr [4];
94  uint32_t ctpr;
95  QORIQ_FILL(0x00080, 0x00090, uint32_t);
96  uint32_t whoami;
97  QORIQ_FILL(0x00090, 0x000a0, uint32_t);
98  uint32_t iack;
99  QORIQ_FILL(0x000a0, 0x000b0, uint32_t);
100  uint32_t eoi;
101  QORIQ_FILL(0x000b0, 0x01000, uint32_t);
102  uint32_t frr;
103  QORIQ_FILL(0x01000, 0x01020, uint32_t);
104  uint32_t gcr;
105  QORIQ_FILL(0x01020, 0x01080, uint32_t);
106  uint32_t vir;
107  QORIQ_FILL(0x01080, 0x01090, uint32_t);
108  uint32_t pir;
109  QORIQ_FILL(0x01090, 0x010a0, uint32_t);
110  qoriq_pic_reg ipivpr [4];
111  uint32_t svr;
112  QORIQ_FILL(0x010e0, 0x010f0, uint32_t);
113  uint32_t tfrra;
114  QORIQ_FILL(0x010f0, 0x01100, uint32_t);
115  qoriq_pic_global_timer gta [4];
116  QORIQ_RESERVE(0x01200, 0x01300);
117  uint32_t tcra;
118  QORIQ_FILL(0x01300, 0x01308, uint32_t);
119  uint32_t erqsr;
120  QORIQ_FILL(0x01308, 0x01310, uint32_t);
121  qoriq_pic_bit_field irqsr;
122  qoriq_pic_bit_field cisr;
123  qoriq_pic_bit_field pm [4];
124  QORIQ_RESERVE(0x013d0, 0x01400);
125  qoriq_pic_reg msgr03 [4];
126  QORIQ_RESERVE(0x01440, 0x01500);
127  uint32_t mer03;
128  QORIQ_FILL(0x01500, 0x01510, uint32_t);
129  uint32_t msr03;
130  QORIQ_FILL(0x01510, 0x01600, uint32_t);
131  qoriq_pic_reg msir [8];
132  QORIQ_RESERVE(0x01680, 0x01720);
133  uint32_t msisr;
134  QORIQ_FILL(0x01720, 0x01740, uint32_t);
135  uint32_t msiir;
136  QORIQ_FILL(0x01740, 0x020f0, uint32_t);
137  uint32_t tfrrb;
138  QORIQ_FILL(0x020f0, 0x02100, uint32_t);
139  qoriq_pic_global_timer gtb [4];
140  QORIQ_RESERVE(0x02200, 0x02300);
141  uint32_t tcrb;
142  QORIQ_FILL(0x02300, 0x02400, uint32_t);
143  qoriq_pic_reg msgr47 [4];
144  QORIQ_RESERVE(0x02440, 0x02500);
145  uint32_t mer47;
146  QORIQ_FILL(0x02500, 0x02510, uint32_t);
147  uint32_t msr47;
148  QORIQ_FILL(0x02510, 0x10000, uint32_t);
149  qoriq_pic_src_cfg ei [12];
150  QORIQ_RESERVE(0x10180, 0x10200);
151  qoriq_pic_src_cfg ii_0 [160];
152  qoriq_pic_src_cfg mi [8];
153  QORIQ_RESERVE(0x11700, 0x11c00);
154  qoriq_pic_src_cfg msi [8];
155  QORIQ_RESERVE(0x11d00, 0x13000);
156  qoriq_pic_src_cfg ii_1 [96];
157  QORIQ_RESERVE(0x13c00, 0x20000);
158  qoriq_pic_per_cpu per_cpu [2];
159 } qoriq_pic;
160
161 #define GTTCR_ROVR(val) BSP_BFLD32(val, 5, 7)
162 #define GTTCR_ROVR_GET(reg) BSP_BFLD32GET(reg, 5, 7)
163 #define GTTCR_ROVR_SET(reg, val) BSP_BFLD32SET(reg, val, 5, 7)
164 #define GTTCR_RTM BSP_BBIT32(15)
165 #define GTTCR_CLKR(val) BSP_BFLD32(val, 22, 23)
166 #define GTTCR_CLKR_GET(reg) BSP_BFLD32GET(reg, 22, 23)
167 #define GTTCR_CLKR_SET(reg, val) BSP_BFLD32SET(reg, val, 22, 23)
168 #define GTTCR_CASC(val) BSP_BFLD32(val, 29, 31)
169 #define GTTCR_CASC_GET(reg) BSP_BFLD32GET(reg, 29, 31)
170 #define GTTCR_CASC_SET(reg, val) BSP_BFLD32SET(reg, val, 29, 31)
171
172 typedef struct {
173 } qoriq_uart;
174
175 typedef struct {
176  uint32_t gpdir;
177  uint32_t gpodr;
178  uint32_t gpdat;
179  uint32_t gpier;
180  uint32_t gpimr;
181  uint32_t gpicr;
182  uint32_t gpibe;
183  QORIQ_RESERVE(0x001c, 0x1000);
184 } qoriq_gpio;
185
186 typedef struct {
187  QORIQ_RESERVE(0x000, 0x100);
188  uint16_t caplength;
189  uint16_t hciversion;
190  uint32_t hcsparams;
191  uint32_t hccparams;
192  QORIQ_RESERVE(0x10c, 0x120);
193  uint32_t dciversion;
194  uint32_t dccparams;
195  QORIQ_RESERVE(0x128, 0x140);
196  uint32_t usbcmd;
197  uint32_t usbsts;
198  uint32_t usbintr;
199  uint32_t frindex;
200  QORIQ_RESERVE(0x150, 0x154);
201  union {
202  uint32_t periodiclistbase;
203  uint32_t deviceaddr;
204  } perbase_devaddr;
205  union {
206  uint32_t asynclistaddr;
207  uint32_t addr;
208  } async_addr;
209  QORIQ_RESERVE(0x15c, 0x160);
210  uint32_t burstsize;
211  uint32_t txfilltuning;
212  QORIQ_RESERVE(0x168, 0x170);
213  uint32_t viewport;
214  QORIQ_RESERVE(0x174, 0x180);
215  uint32_t configflag;
216  uint32_t portsc1;
217  QORIQ_RESERVE(0x188, 0x1a8);
218  uint32_t usbmode;
219  uint32_t endptsetupstat;
220  uint32_t endpointprime;
221  uint32_t endptflush;
222  uint32_t endptstatus;
223  uint32_t endptcomplete;
224  uint32_t endptctrl[6];
225  QORIQ_RESERVE(0x1d8, 0x400);
226  uint32_t snoop1;
227  uint32_t snoop2;
228  uint32_t age_cnt_thresh;
229  uint32_t pri_ctrl;
230  uint32_t si_ctrl;
231  QORIQ_RESERVE(0x414, 0x500);
232  uint32_t control;
233 } qoriq_usb;
234
235 typedef struct {
236  uint32_t dsaddr;
237  uint32_t blkattr;
238  uint32_t cmdarg;
239  uint32_t xfertyp;
240  uint32_t cmdrsp0;
241  uint32_t cmdrsp1;
242  uint32_t cmdrsp2;
243  uint32_t cmdrsp3;
244  uint32_t datport;
245  uint32_t prsstat;
246  uint32_t proctl;
247  uint32_t sysctl;
248  uint32_t irqstat;
249  uint32_t irqstaten;
250  uint32_t irqsigen;
251  uint32_t autoc12err;
252  uint32_t hostcapblt;
253  uint32_t wml;
254  QORIQ_FILL(0x00044, 0x00050, uint32_t);
255  uint32_t fevt;
256  QORIQ_FILL(0x00050, 0x000fc, uint32_t);
257  uint32_t hostver;
258  QORIQ_FILL(0x000fc, 0x0040c, uint32_t);
259  uint32_t dcr;
260 } qoriq_esdhc;
261
262 #if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
263
264 typedef struct {
265  uint32_t ccsrbarh;
266  uint32_t ccsrbarl;
267  uint32_t ccsrar;
268  uint32_t altcbarh;
269  uint32_t altcbarl;
270  uint32_t altcar;
271  uint32_t bstrh;
272  uint32_t bstrl;
273  uint32_t bstar;
274 } qoriq_lcc;
275
276 #define LCC_BSTAR_EN BSP_BBIT32(0)
277
278 typedef struct {
279  uint32_t lawbarh;
280  uint32_t lawbarl;
281  uint32_t lawar;
282  uint32_t reserved_0xc;
283 } qoriq_law;
284
285 typedef struct {
286  uint32_t reserved_0x0[640];
287  uint32_t qmbm_warmrst;
288 } qoriq_dcfg;
289
290 typedef struct {
291  QORIQ_RESERVE(0x0000, 0x1000);
292 } qoriq_bman;
293
294 typedef struct {
295  QORIQ_RESERVE(0x0000, 0x1000);
296 } qoriq_qman;
297
298 typedef struct {
299  QORIQ_RESERVE(0x000000, 0x100000);
300 } qoriq_fman;
301
302 typedef struct qoriq_ccsr {
303  qoriq_lcc lcc;
304  QORIQ_FILL(0x000000, 0x000c00, qoriq_lcc);
305  qoriq_law law [32];
306  QORIQ_FILL(0x000c00, 0x001000, qoriq_law [32]);
307  QORIQ_RESERVE(0x001000, 0x040000);
308  qoriq_pic pic;
309  QORIQ_FILL(0x040000, 0x070000, qoriq_pic);
310  QORIQ_RESERVE(0x070000, 0x0e0000);
311  qoriq_dcfg dcfg;
312  QORIQ_FILL(0x0e0000, 0x0e1000, qoriq_dcfg);
313  QORIQ_RESERVE(0x0e1000, 0x114000);
314  qoriq_esdhc esdhc;
315  QORIQ_FILL(0x114000, 0x115000, qoriq_esdhc);
316  QORIQ_RESERVE(0x115000, 0x11c500);
317  qoriq_uart uart_0;
318  QORIQ_FILL(0x11c500, 0x11c600, qoriq_uart);
319  qoriq_uart uart_1;
320  QORIQ_FILL(0x11c600, 0x11d500, qoriq_uart);
321  qoriq_uart uart_2;
322  QORIQ_FILL(0x11d500, 0x11d600, qoriq_uart);
323  qoriq_uart uart_3;
324  QORIQ_FILL(0x11d600, 0x11e000, qoriq_uart);
325  QORIQ_RESERVE(0x11e000, 0x130000);
326  qoriq_gpio gpio[4];
327  QORIQ_RESERVE(0x134000, 0x210000);
328  qoriq_usb usb_1;
329  QORIQ_FILL(0x210000, 0x211000, qoriq_usb);
330  QORIQ_RESERVE(0x211000, 0x318000);
331  qoriq_qman qman;
332  QORIQ_RESERVE(0x319000, 0x31a000);
333  qoriq_bman bman;
334  QORIQ_RESERVE(0x31b000, 0x400000);
335  qoriq_fman fman[2];
336  QORIQ_RESERVE(0x600000, 0x2000000);
337 } qoriq_ccsr;
338
339 #else /* QORIQ_CHIP_VARIANT */
340
341 typedef struct {
342  uint32_t ccsrbar;
343  uint32_t reserved_0;
344  uint32_t altcbar;
345  uint32_t reserved_1;
346  uint32_t altcar;
347  uint32_t reserved_2 [3];
348  uint32_t bptr;
349 } qoriq_lcc;
350
351 #define CCSRBAR_BASE_ADDR(val) BSP_BFLD32(val, 8, 23)
352 #define CCSRBAR_BASE_ADDR_GET(reg) BSP_BFLD32GET(reg, 8, 23)
353 #define CCSRBAR_BASE_ADDR_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 23)
354
355 #define ALTCBAR_BASE_ADDR(val) BSP_BFLD32(val, 8, 23)
356 #define ALTCBAR_BASE_ADDR_GET(reg) BSP_BFLD32GET(reg, 8, 23)
357 #define ALTCBAR_BASE_ADDR_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 23)
358
359 #define ALTCAR_EN BSP_BBIT32(0)
360 #define ALTCAR_TRGT_ID(val) BSP_BFLD32(val, 8, 11)
361 #define ALTCAR_TRGT_ID_GET(reg) BSP_BFLD32GET(reg, 8, 11)
362 #define ALTCAR_TRGT_ID_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 11)
363
364 #define BPTR_EN BSP_BBIT32(0)
365 #define BPTR_BOOT_PAGE(val) BSP_BFLD32(val, 8, 31)
366 #define BPTR_BOOT_PAGE_GET(reg) BSP_BFLD32GET(reg, 8, 31)
367 #define BPTR_BOOT_PAGE_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 31)
368
369 typedef struct {
370  uint32_t bar;
371  uint32_t reserved_0;
372  uint32_t ar;
373  uint32_t reserved_1 [5];
374 } qoriq_law;
375
376 #define LAWBAR_BASE_ADDR(val) BSP_BFLD32(val, 8, 31)
377 #define LAWBAR_BASE_ADDR_GET(reg) BSP_BFLD32GET(reg, 8, 31)
378 #define LAWBAR_BASE_ADDR_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 31)
379
380 #define LAWAR_EN BSP_BBIT32(0)
381 #define LAWAR_TRGT(val) BSP_BFLD32(val, 8, 11)
382 #define LAWAR_TRGT_GET(reg) BSP_BFLD32GET(reg, 8, 11)
383 #define LAWAR_TRGT_SET(reg, val) BSP_BFLD32SET(reg, val, 8, 11)
384 #define LAWAR_SIZE(val) BSP_BFLD32(val, 26, 31)
385 #define LAWAR_SIZE_GET(reg) BSP_BFLD32GET(reg, 26, 31)
386 #define LAWAR_SIZE_SET(reg, val) BSP_BFLD32SET(reg, val, 26, 31)
387
388 typedef struct {
389 } qoriq_ecm;
390
391 typedef struct {
393
394 typedef struct {
395 } qoriq_i2c;
396
397 typedef struct {
399
400 typedef struct {
401 } qoriq_spi;
402
403 typedef struct {
405
406 typedef struct {
407 } qoriq_tdm;
408
409 typedef struct {
411
412 typedef struct {
413 } qoriq_dma;
414
415 typedef struct {
416 } qoriq_tdm_dma;
417
418 typedef struct {
419 } qoriq_sec;
420
421 typedef struct {
423
424 typedef struct {
426
427 typedef struct {
429
430 typedef struct {
432
433 typedef struct {
434 } qoriq_serdes;
435
436 typedef struct {
438
439 typedef struct qoriq_ccsr {
440  qoriq_lcc lcc;
441  QORIQ_FILL(0x00000, 0x00c08, qoriq_lcc);
442  qoriq_law law [12];
443  QORIQ_FILL(0x00c08, 0x01000, qoriq_law [12]);
444  qoriq_ecm ecm;
445  QORIQ_FILL(0x01000, 0x02000, qoriq_ecm);
446  qoriq_ddr_controller ddr_controller;
447  QORIQ_FILL(0x02000, 0x03000, qoriq_ddr_controller);
448  qoriq_i2c i2c;
449  QORIQ_FILL(0x03000, 0x04000, qoriq_i2c);
450  QORIQ_RESERVE(0x04000, 0x04500);
451  qoriq_uart uart_0;
452  QORIQ_FILL(0x04500, 0x04600, qoriq_uart);
453  qoriq_uart uart_1;
454  QORIQ_FILL(0x04600, 0x04700, qoriq_uart);
455  QORIQ_RESERVE(0x04700, 0x05000);
456  qoriq_local_bus local_bus;
457  QORIQ_FILL(0x05000, 0x06000, qoriq_local_bus);
458  qoriq_spi spi;
459  QORIQ_FILL(0x06000, 0x07000, qoriq_spi);
460  QORIQ_RESERVE(0x07000, 0x08000);
461  qoriq_pci_express pci_express_3;
462  QORIQ_FILL(0x08000, 0x09000, qoriq_pci_express);
463  qoriq_pci_express pci_express_2;
464  QORIQ_FILL(0x09000, 0x0a000, qoriq_pci_express);
465  qoriq_pci_express pci_express_1;
466  QORIQ_FILL(0x0a000, 0x0b000, qoriq_pci_express);
467  QORIQ_RESERVE(0x0b000, 0x0c000);
468  qoriq_dma dma_2;
469  QORIQ_FILL(0x0c000, 0x0d000, qoriq_dma);
470  QORIQ_RESERVE(0x0d000, 0x0f000);
471  qoriq_gpio gpio;
472  QORIQ_RESERVE(0x10000, 0x16000);
473  qoriq_tdm tdm;
474  QORIQ_FILL(0x16000, 0x17000, qoriq_tdm);
475  QORIQ_RESERVE(0x17000, 0x20000);
476  qoriq_l2_cache l2_cache;
477  QORIQ_FILL(0x20000, 0x21000, qoriq_l2_cache);
478  qoriq_dma dma_1;
479  QORIQ_FILL(0x21000, 0x22000, qoriq_dma);
480  qoriq_usb usb_1;
481  QORIQ_FILL(0x22000, 0x23000, qoriq_usb);
482  qoriq_usb usb_2;
483  QORIQ_FILL(0x23000, 0x24000, qoriq_usb);
484  tsec_registers tsec_1;
485  QORIQ_FILL(0x24000, 0x25000, tsec_registers);
486  tsec_registers tsec_2;
487  QORIQ_FILL(0x25000, 0x26000, tsec_registers);
488  tsec_registers tsec_3;
489  QORIQ_FILL(0x26000, 0x27000, tsec_registers);
490  QORIQ_RESERVE(0x27000, 0x2c000);
491  qoriq_tdm_dma tdm_dma;
492  QORIQ_FILL(0x2c000, 0x2d000, qoriq_tdm_dma);
493  QORIQ_RESERVE(0x2d000, 0x2e000);
494  qoriq_esdhc esdhc;
495  QORIQ_FILL(0x2e000, 0x2f000, qoriq_esdhc);
496  QORIQ_RESERVE(0x2f000, 0x30000);
497  qoriq_sec sec;
498  QORIQ_FILL(0x30000, 0x31000, qoriq_sec);
499  QORIQ_RESERVE(0x31000, 0x40000);
500  qoriq_pic pic;
501  QORIQ_FILL(0x40000, 0x80000, qoriq_pic);
502  QORIQ_RESERVE(0x80000, 0xb0000);
503  tsec_registers tsec_1_group_0;
504  QORIQ_FILL(0xb0000, 0xb1000, tsec_registers);
505  tsec_registers tsec_2_group_0;
506  QORIQ_FILL(0xb1000, 0xb2000, tsec_registers);
507  tsec_registers tsec_3_group_0;
508  QORIQ_FILL(0xb2000, 0xb3000, tsec_registers);
509  QORIQ_RESERVE(0xb3000, 0xb4000);
510  tsec_registers tsec_1_group_1;
511  QORIQ_FILL(0xb4000, 0xb5000, tsec_registers);
512  tsec_registers tsec_2_group_1;
513  QORIQ_FILL(0xb5000, 0xb6000, tsec_registers);
514  tsec_registers tsec_3_group_1;
515  QORIQ_FILL(0xb6000, 0xb7000, tsec_registers);
516  QORIQ_RESERVE(0xb7000, 0xc0000);
517  qoriq_serial_rapid_io serial_rapid_io;
518  QORIQ_FILL(0xc0000, 0xe0000, qoriq_serial_rapid_io);
519  qoriq_global_utilities global_utilities;
520  QORIQ_FILL(0xe0000, 0xe1000, qoriq_global_utilities);
521  qoriq_performance_monitor performance_monitor;
522  QORIQ_FILL(0xe1000, 0xe2000, qoriq_performance_monitor);
523  qoriq_debug_watchpoint debug_watchpoint;
524  QORIQ_FILL(0xe2000, 0xe3000, qoriq_debug_watchpoint);
525  qoriq_serdes serdes;
526  QORIQ_FILL(0xe3000, 0xe4000, qoriq_serdes);
527  QORIQ_RESERVE(0xe4000, 0xf0000);
528  qoriq_boot_rom boot_rom;
529  QORIQ_FILL(0xf0000, 0x100000, qoriq_boot_rom);
530 } qoriq_ccsr;
531
532 #endif /* QORIQ_CHIP_VARIANT */
533
534 extern volatile qoriq_ccsr qoriq;
535
536 #if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
537 extern uint8_t qoriq_bman_portal[2][16777216];
538 extern uint8_t qoriq_qman_portal[2][16777216];
539
540 void qoriq_clear_ce_portal(void *base, size_t size);
541 void qoriq_clear_ci_portal(void *base, size_t size);
542 #endif
543
544 static inline void qoriq_reset_qman_and_bman(void)
545 {
546 #if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
547  qoriq.dcfg.qmbm_warmrst = 0x3;
548
549  while ((qoriq.dcfg.qmbm_warmrst & 0x3) != 0) {
550  /* Wait for reset done */
551  }
552 #endif
553 }
554
555 #ifdef __cplusplus
556 }
557 #endif /* __cplusplus */
558
559 #endif /* LIBBSP_POWERPC_QORIQ_QORIQ_H */
Definition: qoriq.h:418
Definition: qoriq.h:409
Definition: qoriq.h:175
Definition: qoriq.h:391
Definition: qoriq.h:186
Definition: 8xx_immap.h:216
Definition: qoriq.h:88
Definition: qoriq.h:415
Definition: qoriq.h:341
Definition: qoriq.h:37
Definition: qoriq.h:388
Definition: qoriq.h:403
Definition: qoriq.h:427
Definition: qoriq.h:412
Definition: qoriq.h:75
Utility macros.
Definition: qoriq.h:394
Definition: qoriq.h:424
Definition: tsec.h:89
Definition: intercom.c:74
Definition: qoriq.h:61
Definition: qoriq.h:235
Definition: qoriq.h:406
Definition: qoriq.h:433
Definition: qoriq.h:68
Definition: qoriq.h:369
Definition: qoriq.h:439
Definition: qoriq.h:172
Definition: qoriq.h:400
Definition: qoriq.h:436
Definition: qoriq.h:397
Definition: qoriq.h:430
unsigned size
Definition: tte.h:74
Definition: qoriq.h:421
