RTEMS  5.1
mmu.h
1 #ifndef RTEMS_VIRTEX4_MMU_H
2 #define RTEMS_VIRTEX4_MMU_H
3
10 /*
11  * Authorship
12  * ----------
13  * This software was created by
14  * Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
15  * Stanford Linear Accelerator Center, Stanford University.
16  * and was transcribed for the PPC 405 by
17  * R. Claus <claus@slac.stanford.edu>, 2012,
18  * Stanford Linear Accelerator Center, Stanford University,
19  *
20  * Acknowledgement of sponsorship
21  * ------------------------------
22  * This software was produced by
23  * the Stanford Linear Accelerator Center, Stanford University,
24  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
25  *
26  * Government disclaimer of liability
27  * ----------------------------------
28  * Neither the United States nor the United States Department of Energy,
29  * nor any of their employees, makes any warranty, express or implied, or
30  * assumes any legal liability or responsibility for the accuracy,
31  * completeness, or usefulness of any data, apparatus, product, or process
32  * disclosed, or represents that its use would not infringe privately owned
33  * rights.
34  *
35  * Stanford disclaimer of liability
36  * --------------------------------
37  * Stanford University makes no representations or warranties, express or
38  * implied, nor assumes any liability for the use of this software.
39  *
40  * Stanford disclaimer of copyright
41  * --------------------------------
42  * Stanford University, owner of the copyright, hereby disclaims its
43  * copyright and all other rights in this software. Hence, anyone may
44  * freely use it for any purpose without restriction.
45  *
46  * Maintenance of notices
47  * ----------------------
48  * In the interest of clarity regarding the origin and status of this
49  * SLAC software, this and all the preceding Stanford University notices
50  * are to remain affixed to any copy or derivative of this software made
51  * or distributed by the recipient and are to be affixed to any copy of
52  * software made or distributed by the recipient that contains a copy or
53  * derivative of this software.
54  *
55  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
56  */
57
58 #include <rtems.h>
59 #include <inttypes.h>
60 #include <stdio.h>
61
62 #ifdef __cplusplus
63 extern "C" {
64 #endif
65
76 /* Some routines require or return a index 'key'.
77  */
78 typedef int bsp_tlb_idx_t;
79
80 /* Cache the relevant TLB entries so that we can make sure the user cannot
81  * create conflicting (overlapping) entries. Keep them public for informational
82  * purposes.
83  */
84 typedef struct {
85  struct {
86  uint32_t pad:24;
87  uint32_t tid:8;
88  } id;
89  struct {
90  uint32_t epn:22;
91  uint32_t size:3;
92  uint32_t v:1;
93  uint32_t att:2;
94  uint32_t pad:4;
95  } hi;
96  struct {
97  uint32_t rpn:22;
98  uint32_t perm:6;
99  uint32_t wimg:4;
100  } lo;
102
103 #define NTLBS 64
104
105 extern bsp_tlb_entry_t* bsp_mmu_cache;
106
107
108 // These constants will have to be shifted right by 20 bits before
109 // being inserted the high word of the TLB.
110
111 #define MMU_M_SIZE_1K (0x00000000U)
112 #define MMU_M_SIZE_4K (0x08000000U)
113 #define MMU_M_SIZE_16K (0x10000000U)
114 #define MMU_M_SIZE_64K (0x18000000U)
115 #define MMU_M_SIZE_256K (0x20000000U)
116 #define MMU_M_SIZE_1M (0x28000000U)
117 #define MMU_M_SIZE_4M (0x30000000U)
118 #define MMU_M_SIZE_16M (0x38000000U)
119 #define MMU_M_SIZE_MIN (MMU_M_SIZE_1K)
120 #define MMU_M_SIZE_MAX (MMU_M_SIZE_16M)
121 #define MMU_M_SIZE (0x38000000U)
122 #define MMU_V_SIZE (27)
123
124 #define MMU_M_ATTR_LITTLE_ENDIAN (0x02000000U)
125 #define MMU_M_ATTR_USER0 (0x01000000U)
126 #define MMU_M_ATTR (0x03000000U)
127 #define MMU_V_ATTR (24)
128
129 // These constants have the same bit positions they'll occupy
130 // in low word of the TLB.
131
132 #define MMU_M_PERM_EXEC (0x00000200U)
133 #define MMU_M_PERM_DATA_WRITE (0x00000100U)
134 #define MMU_M_PERM_ZONE_SELECT (0x000000f0U)
135 #define MMU_M_PERM (0x000003f0U)
136 #define MMU_V_PERM (4)
137
138 #define MMU_M_PROP_WRITE_THROUGH (0x00000008U)
139 #define MMU_M_PROP_UNCACHED (0x00000004U)
140 #define MMU_M_PROP_MEM_COHERENT (0x00000002U)
141 #define MMU_M_PROP_GUARDED (0x00000001U)
142 #define MMU_M_PROP (0x0000000fU)
143 #define MMU_V_PROP (0)
144
145
146 /*
147  * Dump (cleartext) content info from cached TLB entries
148  * to a file (stdout if f==NULL).
149  */
150 void
151 bsp_mmu_dump_cache(FILE *f);
152
153 /* Read a TLB entry from the hardware and store the settings in the
154  * bsp_mmu_cache[] structure.
155  *
156  * The routine can perform this operation quietly or
157  * print information to a file.
158  *
159  * 'key': TLB entry index.
160  * 'quiet': perform operation silently (no info printed) if nonzero.
161  * 'f': open FILE where to print information. May be NULL, in
162  * which case 'stdout' is used.
163  *
164  * RETURNS:
165  * 0: success; TLB entry is VALID
166  * +1: success but TLB entry is INVALID
167  * < 0: error (-1: invalid argument)
168  * (-2: driver not initialized)
169  */
170 int
171 bsp_mmu_update(bsp_tlb_idx_t key, bool quiet, FILE *f);
172
173 /* Initialize cache. Should be done only once although this is not enforced.
174  *
175  * RETURNS: zero on success, nonzero on error; in this case the driver will
176  * refuse to change TLB entries (other than disabling them).
177  */
178 int
179 bsp_mmu_initialize(void);
180
181 /* Find first free TLB entry by examining all entries' valid bit. The first
182  * entry without the valid bit set is returned.
183  *
184  * RETURNS: A free TLB entry number. -1 if no entry can be found.
185  */
186 bsp_tlb_idx_t
187 bsp_mmu_find_first_free(void);
188
189 /* Write a TLB entry (can also be used to disable an entry).
190  *
191  * The routine checks against the cached data in bsp_mmu_cache[]
192  * to prevent the user from generating overlapping entries.
193  *
194  * 'idx': TLB entry # to manipulate
195  * 'ea': Effective address (must be page aligned)
196  * 'pa': Physical address (must be page aligned)
197  * 'sz': Page size selector; page size is 1024 * 2^(2*sz) bytes.
198  * 'sz' may also be one of the following:
199  * - page size in bytes ( >= 1024 ); the selector
200  * value is then computed by this routine.
201  * However, 'sz' must be a valid page size
202  * or -1 will be returned.
203  * - a value < 0 to invalidate/disable the
204  * TLB entry.
205  * 'flgs': Page's little-endian & user-defined flags, permissions and attributes
206  * 'tid': Translation ID
207  *
208  * RETURNS: 0 on success, nonzero on error:
209  *
210  * >0: requested mapping would overlap with
211  * existing mapping in another entry. Return
212  * value gives conflicting entry + 1; i.e.,
213  * if a value of 4 is returned then the request
214  * conflicts with existing mapping in entry 3.
215  * -1: invalid argument
216  * -3: driver not initialized (or initialization failed).
217  * <0: other error
218  */
219 bsp_tlb_idx_t
220 bsp_mmu_write(bsp_tlb_idx_t idx, uint32_t ea, uint32_t pa, uint sz,
221  uint32_t flgs, uint32_t tid);
222
223 /* Check if a ea/tid/sz mapping overlaps with an existing entry.
224  *
225  * 'ea': The Effective Address to match against
226  * 'sz': The 'logarithmic' size selector; the page size
227  * is 1024*2^(2*sz).
228  * 'tid': The TID to match against
229  *
230  * RETURNS:
231  * >= 0: index of TLB entry that already provides a mapping
232  * which overlaps within the ea range.
233  * -1: SUCCESS (no conflicting entry found)
234  * <=-2: ERROR (invalid input)
235  */
236 bsp_tlb_idx_t
237 bsp_mmu_match(uint32_t ea, int sz, uint32_t tid);
238
239 /* Find TLB index that maps 'ea/tid' combination
240  *
241  * 'ea': Effective address to match against
242  * 'tid': The TID to match against
243  *
244  * RETURNS: index 'key'; i.e., the index number.
245  *
246  * On error (no mapping) -1 is returned.
247  */
248 bsp_tlb_idx_t
249 bsp_mmu_find(uint32_t ea, uint32_t tid);
250
251 /* Mark TLB entry as invalid ('disabled').
252  *
253  * 'key': TLB entry index.
254  *
255  * RETURNS: zero on success, nonzero on error (TLB unchanged).
256  *
257  * NOTE: If a TLB entry is disabled the associated
258  * entry in bsp_mmu_cache[] is also marked as disabled.
259  */
260 int
261 bsp_mmu_invalidate(bsp_tlb_idx_t key);
262
265 #ifdef __cplusplus
266 };
267 #endif
268
269 #endif
uint32_t perm
Definition: mmu.h:98
uint32_t att
Definition: mmu.h:93
Definition: mmu.h:84
Provide printf() PRIxxx Constante Beyond Standards.
uint32_t v
Definition: mmu.h:92
uint32_t wimg
Definition: mmu.h:99
uint32_t pad
Definition: mmu.h:86
uint32_t size
Definition: mmu.h:91
