RTEMS  5.1
uart.h
1
2 /*
3  * This software is Copyright (C) 1998 by T.sqware - all rights limited
4  * It is provided in to the public domain "as is", can be freely modified
5  * as far as this copyight notice is kept unchanged, but does not imply
6  * an endorsement by T.sqware of the product in which it is included.
7  */
8
9 #ifndef _BSPUART_H
10 #define _BSPUART_H
11
12 #include <bsp/irq.h>
13
14 #include <sys/ioctl.h>
15 #include <rtems/libio.h>
16
17 void BSP_uart_init(int uart, int baud, int hwFlow);
18 void BSP_uart_set_baud(int uart, int baud);
19 void BSP_uart_intr_ctrl(int uart, int cmd);
20 void BSP_uart_throttle(int uart);
21 void BSP_uart_unthrottle(int uart);
22 int BSP_uart_polled_status(int uart);
23 void BSP_uart_polled_write(int uart, int val);
24 int BSP_uart_polled_read(int uart);
25 void BSP_uart_termios_set(int uart, void *ttyp);
26 ssize_t BSP_uart_termios_write_com(int minor, const char *buf, size_t len);
27 int BSP_uart_termios_read_com (int minor);
28 void BSP_uart_termios_isr_com1(void *unused);
29 void BSP_uart_termios_isr_com2(void *unused);
30 void BSP_uart_dbgisr_com1(void);
31 void BSP_uart_dbgisr_com2(void);
32 int BSP_uart_install_isr(int uart, rtems_irq_hdl handler);
33 int BSP_uart_remove_isr(int uart, rtems_irq_hdl handler);
34 ssize_t BSP_uart_termios_write_polled(int minor, const char *buf, size_t len);
35 int BSP_uart_get_break_cb(int uart, rtems_libio_ioctl_args_t *arg);
36 int BSP_uart_set_break_cb(int uart, rtems_libio_ioctl_args_t *arg);
37
38 extern unsigned BSP_poll_char_via_serial(void);
39 extern void BSP_output_char_via_serial(const char val);
40 extern int BSPConsolePort;
41 extern int BSPBaseBaud;
42
43 /* Special IOCTLS to install a lowlevel 'BREAK' handler */
44
45 /* pass a BSP_UartBreakCb pointer to ioctl when retrieving
46  * or installing break callback
47  */
48 typedef void (*BSP_UartBreakCbProc)(
49  int uartMinor,
50  unsigned uartRBRLSRStatus,
51  void *termiosPrivatePtr,
52  void *private
53 );
54
55 typedef struct BSP_UartBreakCbRec_ {
56  BSP_UartBreakCbProc handler; /* NOTE: handler runs in INTERRUPT CONTEXT */
57  void *private; /* closure pointer which is passed to the callback */
59
60 #define BIOCGETBREAKCB _IOR('b',1,sizeof(BSP_UartBreakCbRec))
61 #define BIOCSETBREAKCB _IOW('b',2,sizeof(BSP_UartBreakCbRec))
62
63 /*
64  * Command values for BSP_uart_intr_ctrl(),
65  * values are strange in order to catch errors
66  * with assert
67  */
68 #define BSP_UART_INTR_CTRL_DISABLE (0)
69 #define BSP_UART_INTR_CTRL_GDB (0xaa) /* RX only */
70 #define BSP_UART_INTR_CTRL_ENABLE (0xbb) /* Normal operations */
71 #define BSP_UART_INTR_CTRL_TERMIOS (0xcc) /* RX & line status */
72
73 /* Return values for uart_polled_status() */
74 #define BSP_UART_STATUS_ERROR (-1) /* No character */
75 #define BSP_UART_STATUS_NOCHAR (0) /* No character */
76 #define BSP_UART_STATUS_CHAR (1) /* Character present */
77 #define BSP_UART_STATUS_BREAK (2) /* Break point is detected */
78
79 /* PC UART definitions */
80 #define BSP_UART_COM1 (0)
81 #define BSP_UART_COM2 (1)
82
83 /*
84  * Offsets from base
85  */
86
87 /* DLAB 0 */
88 #define RBR (0) /* Rx Buffer Register (read) */
89 #define THR (0) /* Tx Buffer Register (write) */
90 #define IER (1) /* Interrupt Enable Register */
91
92 /* DLAB X */
93 #define IIR (2) /* Interrupt Ident Register (read) */
94 #define FCR (2) /* FIFO Control Register (write) */
95 #define LCR (3) /* Line Control Register */
96 #define MCR (4) /* Modem Control Register */
97 #define LSR (5) /* Line Status Register */
98 #define MSR (6) /* Modem Status Register */
99 #define SCR (7) /* Scratch register */
100
101 /* DLAB 1 */
102 #define DLL (0) /* Divisor Latch, LSB */
103 #define DLM (1) /* Divisor Latch, MSB */
104 #define AFR (2) /* Alternate Function register */
105
106 /*
107  * Interrupt source definition via IIR
108  */
109 #define MODEM_STATUS 0
110 #define NO_MORE_INTR 1
111 #define TRANSMITTER_HODING_REGISTER_EMPTY 2
112 #define RECEIVER_DATA_AVAIL 4
113 #define RECEIVER_ERROR 6
114 #define CHARACTER_TIMEOUT_INDICATION 12
115
116 /*
117  * Bits definition of IER
118  */
119 #define RECEIVE_ENABLE 0x1
120 #define TRANSMIT_ENABLE 0x2
121 #define RECEIVER_LINE_ST_ENABLE 0x4
122 #define MODEM_ENABLE 0x8
123 #define INTERRUPT_DISABLE 0x0
124
125 /*
126  * Bits definition of the Line Status Register (LSR)
127  */
128 #define DR 0x01 /* Data Ready */
129 #define OE 0x02 /* Overrun Error */
130 #define PE 0x04 /* Parity Error */
131 #define FE 0x08 /* Framing Error */
132 #define BI 0x10 /* Break Interrupt */
133 #define THRE 0x20 /* Transmitter Holding Register Empty */
134 #define TEMT 0x40 /* Transmitter Empty */
135 #define ERFIFO 0x80 /* Error receive Fifo */
136
137 /*
138  * Bits definition of the MODEM Control Register (MCR)
139  */
140 #define DTR 0x01 /* Data Terminal Ready */
141 #define RTS 0x02 /* Request To Send */
142 #define OUT_1 0x04 /* Output 1, (reserved on COMPAQ I/O Board) */
143 #define OUT_2 0x08 /* Output 2, Enable Asynchronous Port Interrupts */
144 #define LB 0x10 /* Enable Internal Loop Back */
145
146 /*
147  * Bits definition of the Line Control Register (LCR)
148  */
149 #define CHR_5_BITS 0
150 #define CHR_6_BITS 1
151 #define CHR_7_BITS 2
152 #define CHR_8_BITS 3
153
154 #define WL 0x03 /* Word length mask */
155 #define STB 0x04 /* 1 Stop Bit, otherwise 2 Stop Bits */
156 #define PEN 0x08 /* Parity Enabled */
157 #define EPS 0x10 /* Even Parity Select, otherwise Odd */
158 #define SP 0x20 /* Stick Parity */
159 #define BCB 0x40 /* Break Control Bit */
160 #define DLAB 0x80 /* Enable Divisor Latch Access */
161
162 /*
163  * Bits definition of the MODEM Status Register (MSR)
164  */
165 #define DCTS 0x01 /* Delta Clear To Send */
166 #define DDSR 0x02 /* Delta Data Set Ready */
167 #define TERI 0x04 /* Trailing Edge Ring Indicator */
168 #define DDCD 0x08 /* Delta Carrier Detect Indicator */
169 #define CTS 0x10 /* Clear To Send (when loop back is active) */
170 #define DSR 0x20 /* Data Set Ready (when loop back is active) */
171 #define RI 0x40 /* Ring Indicator (when loop back is active) */
172 #define DCD 0x80 /* Data Carrier Detect (when loop back is active) */
173
174 /*
175  * Bits definition of the FIFO Control Register : WD16C552 or NS16550
176  */
177
178 #define FIFO_CTRL 0x01 /* Set to 1 permit access to other bits */
179 #define FIFO_EN 0x01 /* Enable the FIFO */
180 #define XMIT_RESET 0x02 /* Transmit FIFO Reset */
181 #define RCV_RESET 0x04 /* Receive FIFO Reset */
182 #define FCR3 0x08 /* do not understand manual! */
183
184 #define RECEIVE_FIFO_TRIGGER1 0x00 /* trigger RX interrupt after 1 byte */
185 #define RECEIVE_FIFO_TRIGGER4 0x40 /* trigger RX interrupt after 4 bytes */
186 #define RECEIVE_FIFO_TRIGGER8 0x80 /* trigger RX interrupt after 8 bytes */
187 #define RECEIVE_FIFO_TRIGGER12 0xc0 /* trigger RX interrupt after 12 bytes */
188 #define TRIG_LEVEL 0xc0 /* Mask for the trigger level */
189
190 #endif /* _BSPUART_H */
Basic IO API.
Parameter block for ioctl.
Definition: libio.h:1355
Definition: uart.h:55
