RTEMS  5.1
os-rtems.h
1 /*
2  * JFFS2 -- Journalling Flash File System, Version 2.
3  *
4  * Copyright © 2002-2003 Free Software Foundation, Inc.
5  * Copyright © 2013 embedded brains GmbH <rtems@embedded-brains.de>
6  *
7  * Created by David Woodhouse <dwmw2@cambridge.redhat.com>
8  *
9  * Port to the RTEMS by embedded brains GmbH.
10  *
11  * For licensing information, see the file 'LICENCE' in this directory.
12  *
13  * $Id: os-ecos.h,v 1.24 2005/02/09 09:23:55 pavlov Exp $
14  *
15  */
16
17 #ifndef __JFFS2_OS_RTEMS_H__
18 #define __JFFS2_OS_RTEMS_H__
19
20 #include <asm/atomic.h>
21 #include <asm/bug.h>
22 #include <linux/compiler.h>
23 #include <linux/list.h>
24 #include <linux/pagemap.h>
25 #include <linux/stat.h>
26 #include <linux/types.h>
27 #include <sys/uio.h>
28 #include <dirent.h>
29 #include <errno.h>
30 #include <fcntl.h>
31 #include <string.h>
32 #include <time.h>
33
34 #include <rtems/jffs2.h>
35 #include <rtems/thread.h>
36
37 #define CONFIG_JFFS2_RTIME
38
39 #define CONFIG_JFFS2_ZLIB
40
41 struct _inode;
42 struct super_block;
43
44 static inline unsigned int full_name_hash(const void *salt, const unsigned char * name, size_t len) {
45
46  uint32_t hash = 0;
47  (void)salt;
48  while (len--) {
49  hash = (hash << 4) | (hash >> 28);
50  hash ^= *(name++);
51  }
52  return hash;
53 }
54
55 /* NAND flash not currently supported on RTEMS */
56 #define jffs2_can_mark_obsolete(c) (1)
57
58 #define JFFS2_INODE_INFO(i) (&(i)->jffs2_i)
59 #define OFNI_EDONI_2SFFJ(f) ((struct _inode *) ( ((char *)f) - ((char *)(&((struct _inode *)NULL)->jffs2_i)) ) )
60
61 #define ITIME(sec) (sec)
62 #define I_SEC(tv) (tv)
63
64 #define JFFS2_F_I_SIZE(f) (OFNI_EDONI_2SFFJ(f)->i_size)
65 #define JFFS2_F_I_MODE(f) (OFNI_EDONI_2SFFJ(f)->i_mode)
66 #define JFFS2_F_I_UID(f) (OFNI_EDONI_2SFFJ(f)->i_uid)
67 #define JFFS2_F_I_GID(f) (OFNI_EDONI_2SFFJ(f)->i_gid)
68 #define JFFS2_F_I_CTIME(f) (OFNI_EDONI_2SFFJ(f)->i_ctime)
69 #define JFFS2_F_I_MTIME(f) (OFNI_EDONI_2SFFJ(f)->i_mtime)
70 #define JFFS2_F_I_ATIME(f) (OFNI_EDONI_2SFFJ(f)->i_atime)
71
72 #define get_seconds() time(NULL)
73
74 struct _inode {
75  cyg_uint32 i_ino;
76
77  int i_count;
78  mode_t i_mode;
79  nlink_t i_nlink; // Could we dispense with this?
80  uid_t i_uid;
81  gid_t i_gid;
82  time_t i_atime;
83  time_t i_mtime;
84  time_t i_ctime;
85 // union {
86  unsigned short i_rdev; // For devices only
87  struct _inode * i_parent; // For directories only
88  off_t i_size; // For files only
89 // };
90  struct super_block * i_sb;
91  struct jffs2_full_dirent * i_fd;
92
93  struct jffs2_inode_info jffs2_i;
94
95  struct _inode * i_cache_prev; // We need doubly-linked?
96  struct _inode * i_cache_next;
97 };
98
99 #define JFFS2_SB_INFO(sb) (&(sb)->jffs2_sb)
100 #define OFNI_BS_2SFFJ(c) ((struct super_block *) ( ((char *)c) - ((char *)(&((struct super_block *)NULL)->jffs2_sb)) ) )
101
102 struct super_block {
103  struct jffs2_sb_info jffs2_sb;
104  struct _inode * s_root;
105  rtems_jffs2_flash_control *s_flash_control;
106  rtems_jffs2_compressor_control *s_compressor_control;
107  bool s_is_readonly;
108  unsigned char s_gc_buffer[PAGE_CACHE_SIZE]; // Avoids malloc when user may be under memory pressure
109  rtems_recursive_mutex s_mutex;
110  char s_name_buf[JFFS2_MAX_NAME_LEN];
111 };
112
113 #define sleep_on_spinunlock(wq, sl) spin_unlock(sl)
114 #define EBADFD 32767
115
116 static inline bool jffs2_is_readonly(struct jffs2_sb_info *c)
117 {
118  struct super_block *sb = OFNI_BS_2SFFJ(c);
119
120  return sb->s_is_readonly;
121 }
122
123 static inline void jffs2_garbage_collect_trigger(struct jffs2_sb_info *c)
124 {
125  const struct super_block *sb = OFNI_BS_2SFFJ(c);
126  rtems_jffs2_flash_control *fc = sb->s_flash_control;
127
128  if (fc->trigger_garbage_collection != NULL) {
129  (*fc->trigger_garbage_collection)(fc);
130  }
131 }
132
133 /* fs-rtems.c */
134 struct _inode *jffs2_new_inode (struct _inode *dir_i, int mode, struct jffs2_raw_inode *ri);
135 struct _inode *jffs2_iget(struct super_block *sb, cyg_uint32 ino);
136 void jffs2_iput(struct _inode * i);
137 void jffs2_gc_release_inode(struct jffs2_sb_info *c, struct jffs2_inode_info *f);
138 struct jffs2_inode_info *jffs2_gc_fetch_inode(struct jffs2_sb_info *c, int inum, int nlink);
139 unsigned char *jffs2_gc_fetch_page(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
140  unsigned long offset, unsigned long *priv);
141 void jffs2_gc_release_page(struct jffs2_sb_info *c, unsigned char *pg, unsigned long *priv);
142
143 /* Avoid polluting RTEMS namespace with names not starting in jffs2_ */
144 #define os_to_jffs2_mode(x) jffs2_from_os_mode(x)
145 static inline uint32_t jffs2_from_os_mode(uint32_t osmode)
146 {
147  return osmode & (S_IFMT | S_IRWXU | S_IRWXG | S_IRWXO);
148 }
149
150 static inline uint32_t jffs2_to_os_mode (uint32_t jmode)
151 {
152  return jmode & (S_IFMT | S_IRWXU | S_IRWXG | S_IRWXO);
153 }
154
155
156 /* flashio.c */
157 int jffs2_flash_read(struct jffs2_sb_info *c, cyg_uint32 read_buffer_offset,
158  const size_t size, size_t * return_size, unsigned char * write_buffer);
159 int jffs2_flash_write(struct jffs2_sb_info *c, cyg_uint32 write_buffer_offset,
160  const size_t size, size_t * return_size, unsigned char * read_buffer);
161 int jffs2_flash_direct_writev(struct jffs2_sb_info *c, const struct iovec *vecs,
162  unsigned long count, loff_t to, size_t *retlen);
163 int jffs2_flash_erase(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
164
165 // dir-rtems.c
166 struct _inode *jffs2_lookup(struct _inode *dir_i, const unsigned char *name, size_t namelen);
167 int jffs2_create(struct _inode *dir_i, const char *d_name, size_t d_namelen, int mode);
168 int jffs2_mknod(struct _inode *dir_i, const unsigned char *d_name, size_t d_namelen, int mode, const unsigned char *data, size_t datalen);
169 int jffs2_link (struct _inode *old_d_inode, struct _inode *dir_i, const unsigned char *d_name, size_t d_namelen);
170 int jffs2_unlink(struct _inode *dir_i, struct _inode *d_inode, const unsigned char *d_name, size_t d_namelen);
171 int jffs2_rmdir (struct _inode *dir_i, struct _inode *d_inode, const unsigned char *d_name, size_t d_namelen);
172 int jffs2_rename (struct _inode *old_dir_i, struct _inode *d_inode, const unsigned char *old_d_name, size_t old_d_namelen,
173  struct _inode *new_dir_i, const unsigned char *new_d_name, size_t new_d_namelen);
174
175 /* erase.c */
176 static inline void jffs2_erase_pending_trigger(struct jffs2_sb_info *c)
177 { }
178
179 #ifndef CONFIG_JFFS2_FS_WRITEBUFFER
180 #define SECTOR_ADDR(x) ( ((unsigned long)(x) & ~(c->sector_size-1)) )
181 #define jffs2_can_mark_obsolete(c) (1)
182 #define jffs2_is_writebuffered(c) (0)
183 #define jffs2_cleanmarker_oob(c) (0)
184 #define jffs2_write_nand_cleanmarker(c,jeb) (-EIO)
185
186 #define jffs2_flush_wbuf_pad(c) (c=c)
187 #define jffs2_flush_wbuf_gc(c, i) ({ (void)(c), (void) i, 0; })
188 #define jffs2_nand_read_failcnt(c,jeb) do { ; } while(0)
189 #define jffs2_write_nand_badblock(c,jeb,p) (0)
190 #define jffs2_flash_setup(c) (0)
191 #define jffs2_nand_flash_cleanup(c) do {} while(0)
192 #define jffs2_wbuf_dirty(c) (0)
193 #define jffs2_flash_writev(a,b,c,d,e,f) jffs2_flash_direct_writev(a,b,c,d,e)
194 #define jffs2_wbuf_timeout NULL
195 #define jffs2_wbuf_process NULL
196 #define jffs2_nor_ecc(c) (0)
197 #else
198 #error no nand yet
199 #endif
200
201 #ifndef BUG_ON
202 #define BUG_ON(x) do { if (unlikely(x)) BUG(); } while(0)
203 #endif
204
205 #define __init
206
207 #endif /* __JFFS2_OS_RTEMS_H__ */
Definition: nodelist.h:277
Definition: os-rtems.h:102
rtems_jffs2_trigger_garbage_collection trigger_garbage_collection
Trigger garbage collection operation.
Definition: jffs2.h:300
Definition: nodelist.h:251
Definition: os-rtems.h:74
Definition: jffs2.h:140
Definition: jffs2_fs_sb.h:48
Definition: jffs2_fs_i.h:20
JFFS2 compressor control.
Definition: jffs2.h:367
unsigned size
Definition: tte.h:74
JFFS2 flash device control.
Definition: jffs2.h:249
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
