RTEMS  5.1
openpic.h
1 /*
2  * openpic.h -- OpenPIC definitions
3  *
4  * Copyright (C) 1997 Geert Uytterhoeven
5  *
6  * This file is based on the following documentation:
7  *
8  * The Open Programmable Interrupt Controller (PIC)
9  * Register Interface Specification Revision 1.2
10  *
11  * Issue Date: October 1995
12  *
13  * Issued jointly by Advanced Micro Devices and Cyrix Corporation
14  *
15  * AMD is a registered trademark of Advanced Micro Devices, Inc.
16  * Copyright (C) 1995, Advanced Micro Devices, Inc. and Cyrix, Inc.
17  * All Rights Reserved.
18  *
19  * To receive a copy of this documentation, send an email to openpic@amd.com.
20  *
21  * This file is subject to the terms and conditions of the GNU General Public
22  * License. See the file COPYING in the main directory of this archive
23  * for more details.
24  *
25  * Modified to compile in RTEMS development environment
26  * by Eric Valette
27  *
28  * Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
29  *
30  * The license and distribution terms for this file may be
31  * found in the file LICENSE in this distribution or at
32  * http://www.rtems.org/license/LICENSE.
33  */
34
35 #ifndef _RTEMS_OPENPIC_H
36 #define _RTEMS_OPENPIC_H
37
38  /*
39  * OpenPIC supports up to 2048 interrupt sources and up to 32 processors
40  */
41 #define OPENPIC_MAX_SOURCES 2048
42 #define OPENPIC_MAX_PROCESSORS 32
43
44 #define OPENPIC_NUM_TIMERS 4
45 #define OPENPIC_NUM_IPI 4
46 #define OPENPIC_NUM_PRI 16
47 #define OPENPIC_NUM_VECTORS 256
48
49  /*
50  * Vector numbers
51  */
52
53 #define OPENPIC_VEC_SOURCE 0x10 /* and up */
54 #define OPENPIC_VEC_TIMER 0x40 /* and up */
55 #define OPENPIC_VEC_IPI 0x50 /* and up */
56 #define OPENPIC_VEC_SPURIOUS 99
57
58  /*
59  * OpenPIC Registers are 32 bits and aligned on 128 bit boundaries
60  */
61
62 typedef struct _OpenPIC_Reg {
63  unsigned int Reg; /* Little endian! */
64  char Pad[0xc];
65 } OpenPIC_Reg;
66
67  /*
68  * Per Processor Registers
69  */
70
71 typedef struct _OpenPIC_Processor {
72  /*
73  * Private Shadow Registers (for SLiC backwards compatibility)
74  */
75  unsigned int IPI0_Dispatch_Shadow; /* Write Only */
76  char Pad1[0x4];
77  unsigned int IPI0_Vector_Priority_Shadow; /* Read/Write */
78  char Pad2[0x34];
79  /*
80  * Interprocessor Interrupt Command Ports
81  */
82  OpenPIC_Reg _IPI_Dispatch[OPENPIC_NUM_IPI]; /* Write Only */
83  /*
84  * Current Task Priority Register
85  */
86  OpenPIC_Reg _Current_Task_Priority; /* Read/Write */
87  char Pad3[0x10];
88  /*
89  * Interrupt Acknowledge Register
90  */
91  OpenPIC_Reg _Interrupt_Acknowledge; /* Read Only */
92  /*
93  * End of Interrupt (EOI) Register
94  */
95  OpenPIC_Reg _EOI; /* Read/Write */
96  char Pad5[0xf40];
98
99  /*
100  * Timer Registers
101  */
102
103 typedef struct _OpenPIC_Timer {
104  OpenPIC_Reg _Current_Count; /* Read Only */
105  OpenPIC_Reg _Base_Count; /* Read/Write */
106  OpenPIC_Reg _Vector_Priority; /* Read/Write */
107  OpenPIC_Reg _Destination; /* Read/Write */
108 } OpenPIC_Timer;
109
110  /*
111  * Global Registers
112  */
113
114 typedef struct _OpenPIC_Global {
115  /*
116  * Feature Reporting Registers
117  */
118  OpenPIC_Reg _Feature_Reporting0; /* Read Only */
119  OpenPIC_Reg _Feature_Reporting1; /* Future Expansion */
120  /*
121  * Global Configuration Registers
122  */
123  OpenPIC_Reg _Global_Configuration0; /* Read/Write */
124  OpenPIC_Reg _Global_Configuration1; /* Future Expansion */
125  /*
126  * Vendor Specific Registers
127  */
128  OpenPIC_Reg _Vendor_Specific[4];
129  /*
130  * Vendor Identification Register
131  */
132  OpenPIC_Reg _Vendor_Identification; /* Read Only */
133  /*
134  * Processor Initialization Register
135  */
136  OpenPIC_Reg _Processor_Initialization; /* Read/Write */
137  /*
138  * IPI Vector/Priority Registers
139  */
140  OpenPIC_Reg _IPI_Vector_Priority[OPENPIC_NUM_IPI]; /* Read/Write */
141  /*
142  * Spurious Vector Register
143  */
144  OpenPIC_Reg _Spurious_Vector; /* Read/Write */
145  /*
146  * Global Timer Registers
147  */
148  OpenPIC_Reg _Timer_Frequency; /* Read/Write */
149  OpenPIC_Timer Timer[OPENPIC_NUM_TIMERS];
150  char Pad1[0xee00];
152
153  /*
154  * Interrupt Source Registers
155  */
156
157 typedef struct _OpenPIC_Source {
158  OpenPIC_Reg _Vector_Priority; /* Read/Write */
159  OpenPIC_Reg _Destination; /* Read/Write */
161
162  /*
163  * OpenPIC Register Map
164  */
165
166 struct OpenPIC {
167  char Pad1[0x1000];
168  /*
169  * Global Registers
170  */
171  OpenPIC_Global Global;
172  /*
173  * Interrupt Source Configuration Registers
174  */
175  OpenPIC_Source Source[OPENPIC_MAX_SOURCES];
176  /*
177  * Per Processor Registers
178  */
179  OpenPIC_Processor Processor[OPENPIC_MAX_PROCESSORS];
180 };
181
182 extern volatile struct OpenPIC *OpenPIC;
183
184  /*
185  * Current Task Priority Register
186  */
187
188 #define OPENPIC_CURRENT_TASK_PRIORITY_MASK 0x0000000f
189
190  /*
191  * Who Am I Register
192  */
193
194 #define OPENPIC_WHO_AM_I_ID_MASK 0x0000001f
195
196  /*
197  * Feature Reporting Register 0
198  */
199
200 #define OPENPIC_FEATURE_LAST_SOURCE_MASK 0x07ff0000
201 #define OPENPIC_FEATURE_LAST_SOURCE_SHIFT 16
202 #define OPENPIC_FEATURE_LAST_PROCESSOR_MASK 0x00001f00
203 #define OPENPIC_FEATURE_LAST_PROCESSOR_SHIFT 8
204 #define OPENPIC_FEATURE_VERSION_MASK 0x000000ff
205
206  /*
207  * Global Configuration Register 0
208  */
209
210 #define OPENPIC_CONFIG_RESET 0x80000000
211 #define OPENPIC_CONFIG_8259_PASSTHROUGH_DISABLE 0x20000000
212 #define OPENPIC_CONFIG_BASE_MASK 0x000fffff
213
214  /*
215  * Vendor Identification Register
216  */
217
218 #define OPENPIC_VENDOR_ID_STEPPING_MASK 0x00ff0000
219 #define OPENPIC_VENDOR_ID_STEPPING_SHIFT 16
220 #define OPENPIC_VENDOR_ID_DEVICE_ID_MASK 0x0000ff00
221 #define OPENPIC_VENDOR_ID_DEVICE_ID_SHIFT 8
222 #define OPENPIC_VENDOR_ID_VENDOR_ID_MASK 0x000000ff
223
224  /*
225  * Vector/Priority Registers
226  */
227
228 #define OPENPIC_MASK 0x80000000
229 #define OPENPIC_ACTIVITY 0x40000000 /* Read Only */
230 #define OPENPIC_PRIORITY_MASK 0x000f0000
231 #define OPENPIC_PRIORITY_SHIFT 16
232 #define OPENPIC_VECTOR_MASK 0x000000ff
233
234  /*
235  * Interrupt Source Registers
236  */
237
238 #define OPENPIC_SENSE_POLARITY 0x00800000 /* Undoc'd */
239 #define OPENPIC_SENSE_LEVEL 0x00400000
240
241  /*
242  * Timer Registers
243  */
244
245 #define OPENPIC_COUNT_MASK 0x7fffffff
246 #define OPENPIC_TIMER_TOGGLE 0x80000000
247 #define OPENPIC_TIMER_COUNT_INHIBIT 0x80000000
248
249  /*
250  * Aliases to make life simpler
251  */
252
253 /* Per Processor Registers */
254 #define IPI_Dispatch(i) _IPI_Dispatch[i].Reg
255 #define Current_Task_Priority _Current_Task_Priority.Reg
256 #define Interrupt_Acknowledge _Interrupt_Acknowledge.Reg
257 #define EOI _EOI.Reg
258
259 /* Global Registers */
260 #define Feature_Reporting0 _Feature_Reporting0.Reg
261 #define Feature_Reporting1 _Feature_Reporting1.Reg
262 #define Global_Configuration0 _Global_Configuration0.Reg
263 #define Global_Configuration1 _Global_Configuration1.Reg
264 #define Vendor_Specific(i) _Vendor_Specific[i].Reg
265 #define Vendor_Identification _Vendor_Identification.Reg
266 #define Processor_Initialization _Processor_Initialization.Reg
267 #define IPI_Vector_Priority(i) _IPI_Vector_Priority[i].Reg
268 #define Spurious_Vector _Spurious_Vector.Reg
269 #define Timer_Frequency _Timer_Frequency.Reg
270
271 /* Timer Registers */
272 #define Current_Count _Current_Count.Reg
273 #define Base_Count _Base_Count.Reg
274 #define Vector_Priority _Vector_Priority.Reg
275 #define Destination _Destination.Reg
276
277 /* Interrupt Source Registers */
278 #define Vector_Priority _Vector_Priority.Reg
279 #define Destination _Destination.Reg
280
281  /*
282  * Vendor and Device IDs
283  */
284
285 #define OPENPIC_VENDOR_ID_APPLE 0x14
286 #define OPENPIC_DEVICE_ID_APPLE_HYDRA 0x46
287
288  /*
289  * OpenPIC Operations
290  */
291
292 /*
293  * Handle EPIC differences. Unfortunately, I don't know of an easy
294  * way to tell an EPIC from a normal PIC at run-time. Therefore,
295  * the BSP must enable a few quirks if it knows that an EPIC is being
296  * used:
297  * - If the BSP uses the serial interrupt mode / 'multiplexer' then
298  * EOI must be delayed by at least 16 SRAM_CLK cycles to avoid
299  * spurious interrupts.
300  * It is the BSP's responsibility to set up an appropriate delay
301  * (in timebase-clock cycles) at init time using
302  * 'openpic_set_eoi_delay()'. This is ONLY necessary when using
303  * an EPIC in serial mode.
304  * - The EPIC sources start at an offset of 16 in the register
305  * map, i.e., on an EPIC you'd say Sources[ x + 16 ] where
306  * on a PIC you would say Sources[ x ].
307  * Again, the BSP can set an offset that is used by the
308  * calls dealing with 'Interrupt Sources'
309  * openpic_enable_irq()
310  * openpic_disable_irq()
311  * openpic_initirq()
312  * openpic_mapirq()
313  * openpic_set_sense()
314  * openpic_get_source_priority()
315  * openpic_set_source_priority()
316  * the desired source offset parameter is passed to openpic_init().
317  *
318  * The routine 'openpic_set_eoi_delay()' returns the previous/old
319  * value of the delay parameter.
320  */
321 extern unsigned openpic_set_eoi_delay(unsigned tb_cycles);
322
323
324 /* Global Operations */
325
326 /* num_sources: number of sources to use; if zero this value
327  * is read from the device, if nonzero the value read from
328  * the device is overridden.
329  * 'polarities' and 'senses' are arrays defining the desired
330  * polarities (active hi [nonzero]/lo [zero]) and
331  * senses (level [nonzero]/edge [zero]).
332  * Either of the two array pointers may be NULL resulting
333  * in the driver choosing default values of: 'active low'
334  * and 'level sensitive', respectively.
335  * NOTE: if you do pass arrays then their size must either
336  * match the number of sources read from the device or
337  * that value must be overridden by specifying
338  * a non-zero 'num_sources' parameter.
339  *
340  * Nonzero 'epic_freq' activates the EOI delay if the EPIC is
341  * configured in serial mode (driver assumes firmware performs initial
342  * EPIC setup). The BSP must pass the clock frequency of the EPIC
343  * serial interface here.
344  */
345 extern void openpic_init(int main_pic, unsigned char *polarities, unsigned char *senses, int num_sources, int source_offset, unsigned long epic_freq);
346
347 extern void openpic_reset(void);
348 extern void openpic_enable_8259_pass_through(void);
349 extern void openpic_disable_8259_pass_through(void);
350 extern unsigned int openpic_irq(unsigned int cpu);
351 extern void openpic_eoi(unsigned int cpu);
352 extern unsigned int openpic_get_priority(unsigned int cpu);
353 extern void openpic_set_priority(unsigned int cpu, unsigned int pri);
354 extern unsigned int openpic_get_spurious(void);
355 extern void openpic_set_spurious(unsigned int vector);
356 extern void openpic_init_processor(unsigned int cpumask);
357
358 /* Interprocessor Interrupts */
359 extern void openpic_initipi(unsigned int ipi, unsigned int pri, unsigned int vector);
360 extern void openpic_cause_IPI(unsigned int cpu, unsigned int ipi, unsigned int cpumask);
361
362 /* Timer Interrupts */
363 extern void openpic_inittimer(unsigned int timer, unsigned int pri, unsigned int vector);
364 extern void openpic_settimer(unsigned int timer, unsigned int base_count, int irq_enable);
365 extern unsigned int openpic_gettimer(unsigned int timer);
366 extern void openpic_maptimer(unsigned int timer, unsigned int cpumask);
367
368 /* Interrupt Sources */
369 extern void openpic_enable_irq(unsigned int irq);
370 extern int openpic_disable_irq(unsigned int irq);
371 extern void openpic_initirq(unsigned int irq, unsigned int pri, unsigned int vector, int polarity,
372  int is_level);
373 extern void openpic_mapirq(unsigned int irq, unsigned int cpumask);
374 extern void openpic_set_sense(unsigned int irq, int sense);
375 extern unsigned int openpic_get_source_priority(unsigned int irq);
376 extern void openpic_set_source_priority(unsigned int irq, unsigned int pri);
377
378 #endif /* RTEMS_OPENPIC_H */
Definition: openpic.h:157
Definition: openpic.h:166
Definition: openpic.h:62
Definition: openpic.h:71
Definition: openpic.h:114
Definition: openpic.h:103
