RTEMS  5.1
open_eth.h
1 /* Opencores ethernet MAC driver */
2 /* adapted from linux driver by Jiri Gaisler */
3
4 #ifndef _OPEN_ETH_
5 #define _OPEN_ETH_
6
7
8 /* Configuration Information */
9
10 typedef struct {
11  void *base_address;
12  uint32_t vector;
13  uint32_t txd_count;
14  uint32_t rxd_count;
15  uint32_t en100MHz;
17
18
19 /* Ethernet buffer descriptor */
20
21 typedef struct _oeth_rxtxdesc {
22  volatile uint32_t len_status; /* Length and status */
23  volatile uint32_t *addr; /* Buffer pointer */
25
26 /* Ethernet configuration registers */
27
28 typedef struct _oeth_regs {
29  volatile uint32_t moder; /* Mode Register */
30  volatile uint32_t int_src; /* Interrupt Source Register */
31  volatile uint32_t int_mask; /* Interrupt Mask Register */
32  volatile uint32_t ipgt; /* Back to Bak Inter Packet Gap Register */
33  volatile uint32_t ipgr1; /* Non Back to Back Inter Packet Gap Register 1 */
34  volatile uint32_t ipgr2; /* Non Back to Back Inter Packet Gap Register 2 */
35  volatile uint32_t packet_len; /* Packet Length Register (min. and max.) */
36  volatile uint32_t collconf; /* Collision and Retry Configuration Register */
37  volatile uint32_t tx_bd_num; /* Transmit Buffer Descriptor Number Register */
38  volatile uint32_t ctrlmoder; /* Control Module Mode Register */
39  volatile uint32_t miimoder; /* MII Mode Register */
40  volatile uint32_t miicommand; /* MII Command Register */
41  volatile uint32_t miiaddress; /* MII Address Register */
42  volatile uint32_t miitx_data; /* MII Transmit Data Register */
43  volatile uint32_t miirx_data; /* MII Receive Data Register */
44  volatile uint32_t miistatus; /* MII Status Register */
45  volatile uint32_t mac_addr0; /* MAC Individual Address Register 0 */
46  volatile uint32_t mac_addr1; /* MAC Individual Address Register 1 */
47  volatile uint32_t hash_addr0; /* Hash Register 0 */
48  volatile uint32_t hash_addr1; /* Hash Register 1 */
49  volatile uint32_t txctrl; /* Transmitter control register */
50  uint32_t empty[235]; /* Unused space */
51  oeth_rxtxdesc xd[128]; /* TX & RX descriptors */
52 } oeth_regs;
53
54 #define OETH_TOTAL_BD 128
55 #define OETH_MAXBUF_LEN 0x610
56
57 /* Tx BD */
58 #define OETH_TX_BD_READY 0x8000 /* Tx BD Ready */
59 #define OETH_TX_BD_IRQ 0x4000 /* Tx BD IRQ Enable */
60 #define OETH_TX_BD_WRAP 0x2000 /* Tx BD Wrap (last BD) */
61 #define OETH_TX_BD_PAD 0x1000 /* Tx BD Pad Enable */
62 #define OETH_TX_BD_CRC 0x0800 /* Tx BD CRC Enable */
63
64 #define OETH_TX_BD_UNDERRUN 0x0100 /* Tx BD Underrun Status */
65 #define OETH_TX_BD_RETRY 0x00F0 /* Tx BD Retry Status */
66 #define OETH_TX_BD_RETLIM 0x0008 /* Tx BD Retransmission Limit Status */
67 #define OETH_TX_BD_LATECOL 0x0004 /* Tx BD Late Collision Status */
68 #define OETH_TX_BD_DEFER 0x0002 /* Tx BD Defer Status */
69 #define OETH_TX_BD_CARRIER 0x0001 /* Tx BD Carrier Sense Lost Status */
70 #define OETH_TX_BD_STATS (OETH_TX_BD_UNDERRUN | \
71  OETH_TX_BD_RETRY | \
72  OETH_TX_BD_RETLIM | \
73  OETH_TX_BD_LATECOL | \
74  OETH_TX_BD_DEFER | \
75  OETH_TX_BD_CARRIER)
76
77 /* Rx BD */
78 #define OETH_RX_BD_EMPTY 0x8000 /* Rx BD Empty */
79 #define OETH_RX_BD_IRQ 0x4000 /* Rx BD IRQ Enable */
80 #define OETH_RX_BD_WRAP 0x2000 /* Rx BD Wrap (last BD) */
81
82 #define OETH_RX_BD_MISS 0x0080 /* Rx BD Miss Status */
83 #define OETH_RX_BD_OVERRUN 0x0040 /* Rx BD Overrun Status */
84 #define OETH_RX_BD_INVSIMB 0x0020 /* Rx BD Invalid Symbol Status */
85 #define OETH_RX_BD_DRIBBLE 0x0010 /* Rx BD Dribble Nibble Status */
86 #define OETH_RX_BD_TOOLONG 0x0008 /* Rx BD Too Long Status */
87 #define OETH_RX_BD_SHORT 0x0004 /* Rx BD Too Short Frame Status */
88 #define OETH_RX_BD_CRCERR 0x0002 /* Rx BD CRC Error Status */
89 #define OETH_RX_BD_LATECOL 0x0001 /* Rx BD Late Collision Status */
90 #define OETH_RX_BD_STATS (OETH_RX_BD_MISS | \
91  OETH_RX_BD_OVERRUN | \
92  OETH_RX_BD_INVSIMB | \
93  OETH_RX_BD_DRIBBLE | \
94  OETH_RX_BD_TOOLONG | \
95  OETH_RX_BD_SHORT | \
96  OETH_RX_BD_CRCERR | \
97  OETH_RX_BD_LATECOL)
98
99 /* MODER Register */
100 #define OETH_MODER_RXEN 0x00000001 /* Receive Enable */
101 #define OETH_MODER_TXEN 0x00000002 /* Transmit Enable */
102 #define OETH_MODER_NOPRE 0x00000004 /* No Preamble */
103 #define OETH_MODER_BRO 0x00000008 /* Reject Broadcast */
104 #define OETH_MODER_IAM 0x00000010 /* Use Individual Hash */
105 #define OETH_MODER_PRO 0x00000020 /* Promiscuous (receive all) */
106 #define OETH_MODER_IFG 0x00000040 /* Min. IFG not required */
107 #define OETH_MODER_LOOPBCK 0x00000080 /* Loop Back */
108 #define OETH_MODER_NOBCKOF 0x00000100 /* No Backoff */
109 #define OETH_MODER_EXDFREN 0x00000200 /* Excess Defer */
110 #define OETH_MODER_FULLD 0x00000400 /* Full Duplex */
111 #define OETH_MODER_RST 0x00000800 /* Reset MAC */
112 #define OETH_MODER_DLYCRCEN 0x00001000 /* Delayed CRC Enable */
113 #define OETH_MODER_CRCEN 0x00002000 /* CRC Enable */
114 #define OETH_MODER_HUGEN 0x00004000 /* Huge Enable */
115 #define OETH_MODER_PAD 0x00008000 /* Pad Enable */
116 #define OETH_MODER_RECSMALL 0x00010000 /* Receive Small */
117
118 /* Interrupt Source Register */
119 #define OETH_INT_TXB 0x00000001 /* Transmit Buffer IRQ */
120 #define OETH_INT_TXE 0x00000002 /* Transmit Error IRQ */
121 #define OETH_INT_RXF 0x00000004 /* Receive Frame IRQ */
122 #define OETH_INT_RXE 0x00000008 /* Receive Error IRQ */
123 #define OETH_INT_BUSY 0x00000010 /* Busy IRQ */
124 #define OETH_INT_TXC 0x00000020 /* Transmit Control Frame IRQ */
125 #define OETH_INT_RXC 0x00000040 /* Received Control Frame IRQ */
126
127 /* Interrupt Mask Register */
128 #define OETH_INT_MASK_TXB 0x00000001 /* Transmit Buffer IRQ Mask */
129 #define OETH_INT_MASK_TXE 0x00000002 /* Transmit Error IRQ Mask */
130 #define OETH_INT_MASK_RXF 0x00000004 /* Receive Frame IRQ Mask */
131 #define OETH_INT_MASK_RXE 0x00000008 /* Receive Error IRQ Mask */
132 #define OETH_INT_MASK_BUSY 0x00000010 /* Busy IRQ Mask */
133 #define OETH_INT_MASK_TXC 0x00000020 /* Transmit Control Frame IRQ Mask */
134 #define OETH_INT_MASK_RXC 0x00000040 /* Received Control Frame IRQ Mask */
135
136 /* Control Module Mode Register */
137 #define OETH_CTRLMODER_PASSALL 0x00000001 /* Pass Control Frames */
138 #define OETH_CTRLMODER_RXFLOW 0x00000002 /* Receive Control Flow Enable */
139 #define OETH_CTRLMODER_TXFLOW 0x00000004 /* Transmit Control Flow Enable */
140
141 /* MII Mode Register */
142 #define OETH_MIIMODER_CLKDIV 0x000000FF /* Clock Divider */
143 #define OETH_MIIMODER_NOPRE 0x00000100 /* No Preamble */
144 #define OETH_MIIMODER_RST 0x00000200 /* MIIM Reset */
145
146 /* MII Command Register */
147 #define OETH_MIICOMMAND_SCANSTAT 0x00000001 /* Scan Status */
148 #define OETH_MIICOMMAND_RSTAT 0x00000002 /* Read Status */
149 #define OETH_MIICOMMAND_WCTRLDATA 0x00000004 /* Write Control Data */
150
151 /* MII Address Register */
152 #define OETH_MIIADDRESS_FIAD 0x0000001F /* PHY Address */
153 #define OETH_MIIADDRESS_RGAD 0x00001F00 /* RGAD Address */
154
155 /* MII Status Register */
156 #define OETH_MIISTATUS_LINKFAIL 0x00000001 /* Link Fail */
157 #define OETH_MIISTATUS_BUSY 0x00000002 /* MII Busy */
158 #define OETH_MIISTATUS_NVALID 0x00000004 /* Data in MII Status Register is invalid */
159
160 /* Attatch routine */
161
162 int rtems_open_eth_driver_attach (
163  struct rtems_bsdnet_ifconfig *config,
165 );
166
167 /*
168 #ifdef CPU_U32_FIX
169 void ipalign(struct mbuf *m);
170 #endif
171
172 */
173 #endif /* _OPEN_ETH_ */
Definition: deflate.c:115
Definition: open_eth.h:21
Definition: open_eth.h:28
Definition: open_eth.h:10
