RTEMS  5.1
ofw.h
1 /*
2  * Copyright (c) 2005 Martin Decky
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  *
9  * - Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * - Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  * - The name of the author may not be used to endorse or promote products
15  * derived from this software without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20  * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22  * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26  * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27  */
28
29 #ifndef BOOT_OFW_H_
30 #define BOOT_OFW_H_
31
32 #include <boot/types.h>
33 #include <stdarg.h>
34
35 #define MEMMAP_MAX_RECORDS 32
36 #define MAX_OFW_ARGS 12
37
38 #define OFW_TREE_PATH_MAX_LEN 256
39 #define OFW_TREE_PROPERTY_MAX_NAMELEN 32
40 #define OFW_TREE_PROPERTY_MAX_VALUELEN 64
41
42 typedef unative_t ofw_arg_t;
43 typedef unsigned int ihandle;
44 typedef unsigned int phandle;
45
49 typedef struct {
50  ofw_arg_t service;
51  ofw_arg_t nargs;
52  ofw_arg_t nret;
53  ofw_arg_t args[MAX_OFW_ARGS];
54 } ofw_args_t;
55
56 typedef struct {
57  void *start;
58  uint32_t size;
59 } memzone_t;
60
61 typedef struct {
62  uint32_t total;
63  uint32_t count;
64  memzone_t zones[MEMMAP_MAX_RECORDS];
65 } memmap_t;
66
67 typedef struct {
68  uint32_t info;
69  uint32_t addr_hi;
70  uint32_t addr_lo;
71 } pci_addr_t;
72
73 typedef struct {
74  pci_addr_t addr;
75  uint32_t size_hi;
76  uint32_t size_lo;
77 } pci_reg_t;
78
79 extern uintptr_t ofw_cif;
80
81 extern phandle ofw_chosen;
82 extern ihandle ofw_stdout;
83 extern phandle ofw_root;
84 extern ihandle ofw_mmu;
85 extern phandle ofw_memory;
86
87 extern void ofw_init(void);
88
89 extern void ofw_write(const char *str, const int len);
90
91 extern int ofw_get_property(const phandle device, const char *name, void *buf, const int buflen);
92 extern int ofw_get_proplen(const phandle device, const char *name);
93 extern int ofw_next_property(const phandle device, char *previous, char *buf);
94
95 extern phandle ofw_get_child_node(const phandle node);
96 extern phandle ofw_get_peer_node(const phandle node);
97 extern phandle ofw_find_device(const char *name);
98
99 extern int ofw_package_to_path(const phandle device, char *buf, const int buflen);
100
101 extern int ofw(ofw_args_t *arg);
102 extern unsigned long ofw_call(const char *service, const int nargs, const int nret, ofw_arg_t *rets, ...);
103 extern void ofw_write(const char *str, const int len);
104 extern void ofw_read(void *str, const int len);
105 extern unsigned int ofw_get_address_cells(const phandle device);
106 extern unsigned int ofw_get_size_cells(const phandle device);
107 extern void *ofw_translate(const void *virt);
108 extern int ofw_translate_failed(ofw_arg_t flag);
109 extern void *ofw_claim_virt(const void *virt, const unsigned int len);
110 extern void *ofw_claim_phys(const void *virt, const unsigned int len);
111 extern void *ofw_claim_phys_any(const unsigned int len, const unsigned int alignment);
112 extern int ofw_map(const void *phys, const void *virt, const unsigned int size, const int mode);
113 extern int ofw_memmap(memmap_t *map);
114 extern void ofw_setup_screens(void);
115 extern void ofw_quiesce(void);
116
117 #endif
ofw_arg_t nret
Definition: ofw.h:52
ofw_arg_t nargs
Definition: ofw.h:51
Definition: ofw.h:49
Definition: rtemscompat1.h:15
Definition: boot.h:67
Definition: ofw.h:67
ofw_arg_t service
Definition: ofw.h:50
Definition: boot.h:72
Definition: mm.c:60
unsigned size
Definition: tte.h:74
Definition: ofw.h:73
