RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
include
grlib
occan.h
1
7
8
* COPYRIGHT (c) 2007.
9
* Cobham Gaisler AB.
10
11
* The license and distribution terms for this file may be
12
* found in the file LICENSE in this distribution or at
13
* http://www.rtems.org/license/LICENSE.
14
15
16
#ifndef __OCCAN_DRIVER_H__
17
#define __OCCAN_DRIVER_H__
18
19
#ifdef __cplusplus
20
extern
"C"
21
#endif
22
23
/* CAN MESSAGE */
24
typedef
struct
25
char
extended;
/* 1= Extended Frame (29-bit id), 0= STD Frame (11-bit id) */
26
char
rtr;
/* RTR - Remote Transmission Request */
27
char
sshot;
/* single shot */
28
unsigned
char
len;
29
unsigned
char
data[8];
30
unsigned
int
id;
31
CANMsg
32
33
typedef
struct
34
/* tx/rx stats */
35
unsigned
int
rx_msgs;
36
unsigned
int
tx_msgs;
37
38
/* Error Interrupt counters */
39
unsigned
int
err_warn;
40
unsigned
int
err_dovr;
41
unsigned
int
err_errp;
42
unsigned
int
err_arb;
43
unsigned
int
err_bus;
44
45
/**** BUS ERRORS (err_arb) ****/
46
47
/* ALC 4-0 */
48
unsigned
int
err_arb_bitnum[32];
/* At what bit arbitration is lost */
49
50
51
52
/**** BUS ERRORS (err_bus) ****/
53
54
/* ECC 7-6 */
55
unsigned
int
err_bus_bit;
/* Bit error */
56
unsigned
int
err_bus_form;
/* Form Error */
57
unsigned
int
err_bus_stuff;
/* Stuff Error */
58
unsigned
int
err_bus_other;
/* Other Error */
59
60
/* ECC 5 */
61
unsigned
int
err_bus_rx;
/* Errors during Reception */
62
unsigned
int
err_bus_tx;
/* Errors during Transmission */
63
64
/* ECC 4:0 */
65
unsigned
int
err_bus_segs[32];
/* Segment (Where in frame error occured)
66
* See OCCAN_SEG_* defines for indexes
67
68
69
70
71
72
/* total number of interrupts */
73
unsigned
int
ints;
74
75
/* software monitoring hw errors */
76
unsigned
int
tx_buf_error;
77
78
/* Software fifo overrun */
79
unsigned
int
rx_sw_dovr;
80
81
occan_stats
82
83
/* indexes into occan_stats.err_bus_segs[index] */
84
#define OCCAN_SEG_ID28 0x02
/* ID field bit 28:21 */
85
#define OCCAN_SEG_ID20 0x06
/* ID field bit 20:18 */
86
#define OCCAN_SEG_ID17 0x07
/* ID field bit 17:13 */
87
#define OCCAN_SEG_ID12 0x0f
/* ID field bit 12:5 */
88
#define OCCAN_SEG_ID4 0x0e
/* ID field bit 4:0 */
89
90
#define OCCAN_SEG_START 0x03
/* Start of Frame */
91
#define OCCAN_SEG_SRTR 0x04
/* Bit SRTR */
92
#define OCCAN_SEG_IDE 0x05
/* Bit IDE */
93
#define OCCAN_SEG_RTR 0x0c
/* Bit RTR */
94
#define OCCAN_SEG_RSV0 0x09
/* Reserved bit 0 */
95
#define OCCAN_SEG_RSV1 0x0d
/* Reserved bit 1 */
96
97
#define OCCAN_SEG_DLEN 0x0b
/* Data Length code */
98
#define OCCAN_SEG_DFIELD 0x0a
/* Data Field */
99
100
#define OCCAN_SEG_CRC_SEQ 0x08
/* CRC Sequence */
101
#define OCCAN_SEG_CRC_DELIM 0x18
/* CRC Delimiter */
102
103
#define OCCAN_SEG_ACK_SLOT 0x19
/* Acknowledge slot */
104
#define OCCAN_SEG_ACK_DELIM 0x1b
/* Acknowledge delimiter */
105
#define OCCAN_SEG_EOF 0x1a
/* End Of Frame */
106
#define OCCAN_SEG_INTERMISSION 0x12
/* Intermission */
107
#define OCCAN_SEG_ACT_ERR 0x11
/* Active error flag */
108
#define OCCAN_SEG_PASS_ERR 0x16
/* Passive error flag */
109
#define OCCAN_SEG_DOMINANT 0x13
/* Tolerate dominant bits */
110
#define OCCAN_SEG_EDELIM 0x17
/* Error delimiter */
111
#define OCCAN_SEG_OVERLOAD 0x1c
/* overload flag */
112
113
114
#define CANMSG_OPT_RTR 0x40
/* RTR Frame */
115
#define CANMSG_OPT_EXTENDED 0x80
/* Exteneded frame */
116
#define CANMSG_OPT_SSHOT 0x01
/* Single Shot, no retry */
117
118
#define OCCAN_IOC_START 1
119
#define OCCAN_IOC_STOP 2
120
121
#define OCCAN_IOC_GET_CONF 3
122
#define OCCAN_IOC_GET_STATS 4
123
#define OCCAN_IOC_GET_STATUS 5
124
125
#define OCCAN_IOC_SET_SPEED 6
126
#define OCCAN_IOC_SPEED_AUTO 7
127
#define OCCAN_IOC_SET_LINK 8
128
#define OCCAN_IOC_SET_FILTER 9
129
#define OCCAN_IOC_SET_BLK_MODE 10
130
#define OCCAN_IOC_SET_BUFLEN 11
131
#define OCCAN_IOC_SET_BTRS 12
132
133
134
struct
occan_afilter
135
unsigned
char
code
[4];
136
unsigned
char
mask[4];
137
int
single_mode;
138
139
140
#define OCCAN_STATUS_RESET 0x01
141
#define OCCAN_STATUS_OVERRUN 0x02
142
#define OCCAN_STATUS_WARN 0x04
143
#define OCCAN_STATUS_ERR_PASSIVE 0x08
144
#define OCCAN_STATUS_ERR_BUSOFF 0x10
145
#define OCCAN_STATUS_QUEUE_ERROR 0x80
146
147
#define OCCAN_BLK_MODE_RX 0x1
148
#define OCCAN_BLK_MODE_TX 0x2
149
150
void
occan_register_drv (
void
151
152
153
#define OCCAN_SPEED_500K 500000
154
#define OCCAN_SPEED_250K 250000
155
#define OCCAN_SPEED_125K 125000
156
#define OCCAN_SPEED_75K 75000
157
#define OCCAN_SPEED_50K 50000
158
#define OCCAN_SPEED_25K 25000
159
#define OCCAN_SPEED_10K 10000
160
161
#ifdef __cplusplus
162
163
#endif
164
165
#endif
occan_stats
Definition:
occan.h:33
CANMsg
Definition:
grcan.h:101
occan_afilter
Definition:
occan.h:134
code
Definition:
inftrees.h:24
