RTEMS
5.1
Go to the documentation of this file. 36 #ifndef _RTEMS_CONFDEFS_OBSOLETE_H 37 #define _RTEMS_CONFDEFS_OBSOLETE_H 39 #ifndef __CONFIGURATION_TEMPLATE_h 40 #error "Do not include this file directly, use <rtems/confdefs.h> instead" 60 #ifdef CONFIGURE_BDBUF_BUFFER_SIZE 61 #error "The CONFIGURE_BDBUF_BUFFER_SIZE configuration option is obsolete since RTEMS 4.10.0" 64 #ifdef CONFIGURE_BDBUF_BUFFER_COUNT 65 #error "The CONFIGURE_BDBUF_BUFFER_COUNT configuration option is obsolete since RTEMS 4.10.0" 68 #ifdef CONFIGURE_MAXIMUM_DEVICES 69 #warning "The CONFIGURE_MAXIMUM_DEVICES configuration option is obsolete since RTEMS 5.1" 72 #ifdef CONFIGURE_ENABLE_GO 73 #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1" 76 #ifdef CONFIGURE_GNAT_RTEMS 77 #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1" 80 #ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE 81 #error "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1" 84 #ifdef CONFIGURE_HAS_OWN_BDBUF_TABLE 85 #error "The CONFIGURE_HAS_BDBUF_TABLE configuration option is obsolete since RTEMS 4.10.0" 88 #ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE 89 #error "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1" 92 #ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE 93 #error "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1" 96 #ifdef CONFIGURE_HAS_OWN_INIT_TABLE 97 #error "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1" 100 #ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE 101 #error "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1" 104 #ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE 105 #error "The CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE configuration option is obsolete since RTEMS 5.1" 108 #ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 109 #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1" 110 #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 113 #ifdef CONFIGURE_MAXIMUM_ADA_TASKS 114 #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1" 117 #ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 118 #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1" 121 #ifdef CONFIGURE_MAXIMUM_FIFOS 122 #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead" 123 #if CONFIGURE_MAXIMUM_FIFOS > 0 124 #define CONFIGURE_IMFS_ENABLE_MKFIFO 128 #ifdef CONFIGURE_MAXIMUM_GOROUTINES 129 #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1" 132 #ifdef CONFIGURE_MAXIMUM_GO_CHANNELS 133 #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1" 136 #ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES 137 #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1" 140 #ifdef CONFIGURE_MAXIMUM_PIPES 141 #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead" 142 #if CONFIGURE_MAXIMUM_PIPES > 0 143 #define CONFIGURE_IMFS_ENABLE_MKFIFO 147 #ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS 148 #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1" 151 #ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 152 #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1" 155 #ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS 156 #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1" 159 #ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES 160 #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1" 163 #ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS 164 #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1" 167 #ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS 168 #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1" 171 #ifdef CONFIGURE_MAXIMUM_PTYS 172 #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1" 175 #ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS 176 #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1" 179 #ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE 180 #error "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1" 183 #ifdef CONFIGURE_SCHEDULER_CONTEXT 184 #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1" 185 #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT 188 #ifdef CONFIGURE_SCHEDULER_CONTROLS 189 #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1" 190 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS 193 #ifdef CONFIGURE_SMP_APPLICATION 194 #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1" 197 #ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS 198 #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1" 199 #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS 202 #ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS 203 #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1" 204 #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS 207 #ifdef CONFIGURE_TERMIOS_DISABLED 208 #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1" 211 #ifdef CONFIGURE_TEST_NEEDS_CLOCK_DRIVER 212 #error "The CONFIGURE_TEST_NEEDS_CLOCK_DRIVER configuration option is obsolete since at least RTEMS 4.5.0" 215 #ifdef CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER 216 #error "The CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER configuration option is obsolete at least RTEMS 4.5.0" 219 #ifdef CONFIGURE_TEST_NEEDS_RTC_DRIVER 220 #error "The CONFIGURE_TEST_NEEDS_RTC_DRIVER configuration option is obsolete at least RTEMS 4.5.0" 223 #ifdef CONFIGURE_TEST_NEEDS_STUB_DRIVER 224 #error "The CONFIGURE_TEST_NEEDS_STUB_DRIVER configuration option is obsolete at least RTEMS 4.5.0" 227 #ifdef CONFIGURE_TEST_NEEDS_TIMER_DRIVER 228 #error "The CONFIGURE_TEST_NEEDS_TIMER_DRIVER configuration option is obsolete at least RTEMS 4.5.0" 231 #ifdef STACK_CHECKER_ON 232 #warning "STACK_CHECKER_ON has been renamed to CONFIGURE_STACK_CHECKER_ENABLED since RTEMS 4.10.0" 233 #define CONFIGURE_STACK_CHECKER_ENABLED
