RTEMS  5.1
ns16550.h
1
6 /*
7  * COPYRIGHT (c) 1998 by Radstone Technology
8  *
9  * THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
10  * KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
11  * IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
12  * AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
13  *
14  * You are hereby granted permission to use, copy, modify, and distribute
15  * this file, provided that this notice, plus the above copyright notice
16  * and disclaimer, appears in all copies. Radstone Technology will provide
17  * no support for this code.
18  *
19  * COPYRIGHT (c) 1989-2012.
20  * On-Line Applications Research Corporation (OAR).
21  *
22  * The license and distribution terms for this file may be
23  * found in the file LICENSE in this distribution or at
24  * http://www.rtems.org/license/LICENSE.
25  */
26
27 #ifndef _NS16550_H_
28 #define _NS16550_H_
29
30 #include <rtems/termiostypes.h>
31 #include <libchip/serial.h>
32
33 #ifdef __cplusplus
34 extern "C" {
35 #endif
36
37 /*
38  * Driver function table
39  */
40
41 extern const console_fns ns16550_fns;
42 extern const console_fns ns16550_fns_polled;
43
44 /*
45  * Flow control function tables
46  */
47
48 extern const console_flow ns16550_flow_RTSCTS;
49 extern const console_flow ns16550_flow_DTRCTS;
50
51 /*
52  * Helpers for printk
53  */
54 void ns16550_outch_polled(console_tbl *c, char out);
55 int ns16550_inch_polled(console_tbl *c);
56
57 /* Alternative NS16550 driver using the Termios device context */
58
59 typedef uint8_t (*ns16550_get_reg)(uintptr_t port, uint8_t reg);
60
61 typedef void (*ns16550_set_reg)(uintptr_t port, uint8_t reg, uint8_t value);
62
63 typedef struct ns16550_context ns16550_context;
64
65 typedef uint32_t (*ns16550_calculate_baud_divisor)(ns16550_context *ctx, uint32_t baud);
66
69  ns16550_get_reg get_reg;
70  ns16550_set_reg set_reg;
71  uintptr_t port;
73  uint32_t clock;
74  uint32_t initial_baud;
75  bool has_fractional_divider_register;
76  bool has_precision_clock_synthesizer;
77  uint8_t modem_control;
78  uint8_t line_control;
79  uint32_t baud_divisor;
80  size_t out_total;
81  size_t out_remaining;
82  size_t out_current;
83  const char *out_buf;
84  rtems_termios_tty *tty;
85  ns16550_calculate_baud_divisor calculate_baud_divisor;
86 };
87
88 extern const rtems_termios_device_handler ns16550_handler_interrupt;
89 extern const rtems_termios_device_handler ns16550_handler_polled;
90 extern const rtems_termios_device_handler ns16550_handler_task;
91
92 extern const rtems_termios_device_flow ns16550_flow_rtscts;
93 extern const rtems_termios_device_flow ns16550_flow_dtrcts;
94
96
97 int ns16550_polled_getchar(rtems_termios_device_context *base);
98
99 bool ns16550_probe(rtems_termios_device_context *base);
100
101 #ifdef __cplusplus
102 }
103 #endif
104
105 #endif /* _NS16550_H_ */
Polled write for NS16550.
Definition: ns16550.c:348
Termios device context.
Definition: termiostypes.h:75
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: serial.h:94
Definition: serial.h:117
Definition: termiostypes.h:283
The generic libchip serial driver interface.
void ns16550_polled_putchar(rtems_termios_device_context *base, char out)
Definition: ns16550-context.c:500
Definition: serial.h:76
Termios device flow control handler.
Definition: termiostypes.h:248
Definition: ns16550.h:67
Termios device handler.
Definition: termiostypes.h:141
