RTEMS  5.1
nodelist.h
1 /*
2  * JFFS2 -- Journalling Flash File System, Version 2.
3  *
4  * Copyright © 2001-2007 Red Hat, Inc.
5  *
6  * Created by David Woodhouse <dwmw2@infradead.org>
7  *
8  * For licensing information, see the file 'LICENCE' in this directory.
9  *
10  */
11
12 #ifndef __JFFS2_NODELIST_H__
13 #define __JFFS2_NODELIST_H__
14
15 #include <linux/fs.h>
16 #include <linux/types.h>
17 #include <linux/jffs2.h>
18 #include "jffs2_fs_sb.h"
19 #include "jffs2_fs_i.h"
20 #include "xattr.h"
21 #include "acl.h"
22 #include "summary.h"
23
24 #ifdef __rtems__
25 #include "os-rtems.h"
26 #else
27 #include "os-linux.h"
28 #endif
29
30 #define JFFS2_NATIVE_ENDIAN
31
32 /* Note we handle mode bits conversion from JFFS2 (i.e. Linux) to/from
33  whatever OS we're actually running on here too. */
34
35 #if defined(JFFS2_NATIVE_ENDIAN)
36 #define cpu_to_je16(x) ((jint16_t){x})
37 #define cpu_to_je32(x) ((jint32_t){x})
38 #define cpu_to_jemode(x) ((jmode_t){os_to_jffs2_mode(x)})
39
40 #define constant_cpu_to_je16(x) ((jint16_t){x})
41 #define constant_cpu_to_je32(x) ((jint32_t){x})
42
43 #define je16_to_cpu(x) ((x).v16)
44 #define je32_to_cpu(x) ((x).v32)
45 #define jemode_to_cpu(x) (jffs2_to_os_mode((x).m))
46 #elif defined(JFFS2_BIG_ENDIAN)
47 #define cpu_to_je16(x) ((jint16_t){cpu_to_be16(x)})
48 #define cpu_to_je32(x) ((jint32_t){cpu_to_be32(x)})
49 #define cpu_to_jemode(x) ((jmode_t){cpu_to_be32(os_to_jffs2_mode(x))})
50
51 #define constant_cpu_to_je16(x) ((jint16_t){__constant_cpu_to_be16(x)})
52 #define constant_cpu_to_je32(x) ((jint32_t){__constant_cpu_to_be32(x)})
53
54 #define je16_to_cpu(x) (be16_to_cpu(x.v16))
55 #define je32_to_cpu(x) (be32_to_cpu(x.v32))
56 #define jemode_to_cpu(x) (be32_to_cpu(jffs2_to_os_mode((x).m)))
57 #elif defined(JFFS2_LITTLE_ENDIAN)
58 #define cpu_to_je16(x) ((jint16_t){cpu_to_le16(x)})
59 #define cpu_to_je32(x) ((jint32_t){cpu_to_le32(x)})
60 #define cpu_to_jemode(x) ((jmode_t){cpu_to_le32(os_to_jffs2_mode(x))})
61
62 #define constant_cpu_to_je16(x) ((jint16_t){__constant_cpu_to_le16(x)})
63 #define constant_cpu_to_je32(x) ((jint32_t){__constant_cpu_to_le32(x)})
64
65 #define je16_to_cpu(x) (le16_to_cpu(x.v16))
66 #define je32_to_cpu(x) (le32_to_cpu(x.v32))
67 #define jemode_to_cpu(x) (le32_to_cpu(jffs2_to_os_mode((x).m)))
68 #else
69 #error wibble
70 #endif
71
72 /* The minimal node header size */
73 #define JFFS2_MIN_NODE_HEADER sizeof(struct jffs2_raw_dirent)
74
75 /*
76  This is all we need to keep in-core for each raw node during normal
77  operation. As and when we do read_inode on a particular inode, we can
78  scan the nodes which are listed for it and build up a proper map of
79  which nodes are currently valid. JFFSv1 always used to keep that whole
80  map in core for each inode.
81 */
83 {
84  struct jffs2_raw_node_ref *next_in_ino; /* Points to the next raw_node_ref
85  for this object. If this _is_ the last, it points to the inode_cache,
86  xattr_ref or xattr_datum instead. The common part of those structures
87  has NULL in the first word. See jffs2_raw_ref_to_ic() below */
88  uint32_t flash_offset;
89 #undef TEST_TOTLEN
90 #ifdef TEST_TOTLEN
91  uint32_t __totlen; /* This may die; use ref_totlen(c, jeb, ) below */
92 #endif
93 };
94
95 #define REF_LINK_NODE ((int32_t)-1)
96 #define REF_EMPTY_NODE ((int32_t)-2)
97
98 /* Use blocks of about 256 bytes */
99 #define REFS_PER_BLOCK ((255/sizeof(struct jffs2_raw_node_ref))-1)
100
101 static inline struct jffs2_raw_node_ref *ref_next(struct jffs2_raw_node_ref *ref)
102 {
103  ref++;
104
105  /* Link to another block of refs */
106  if (ref->flash_offset == REF_LINK_NODE) {
107  ref = ref->next_in_ino;
108  if (!ref)
109  return ref;
110  }
111
112  /* End of chain */
113  if (ref->flash_offset == REF_EMPTY_NODE)
114  return NULL;
115
116  return ref;
117 }
118
119 static inline struct jffs2_inode_cache *jffs2_raw_ref_to_ic(struct jffs2_raw_node_ref *raw)
120 {
121  while(raw->next_in_ino)
122  raw = raw->next_in_ino;
123
124  /* NB. This can be a jffs2_xattr_datum or jffs2_xattr_ref and
125  not actually a jffs2_inode_cache. Check ->class */
126  return ((struct jffs2_inode_cache *)raw);
127 }
128
129  /* flash_offset & 3 always has to be zero, because nodes are
130  always aligned at 4 bytes. So we have a couple of extra bits
131  to play with, which indicate the node's status; see below: */
132 #define REF_UNCHECKED 0 /* We haven't yet checked the CRC or built its inode */
133 #define REF_OBSOLETE 1 /* Obsolete, can be completely ignored */
134 #define REF_PRISTINE 2 /* Completely clean. GC without looking */
135 #define REF_NORMAL 3 /* Possibly overlapped. Read the page and write again on GC */
136 #define ref_flags(ref) ((ref)->flash_offset & 3)
137 #define ref_offset(ref) ((ref)->flash_offset & ~3)
138 #define ref_obsolete(ref) (((ref)->flash_offset & 3) == REF_OBSOLETE)
139 #define mark_ref_normal(ref) do { (ref)->flash_offset = ref_offset(ref) | REF_NORMAL; } while(0)
140
141 /* Dirent nodes should be REF_PRISTINE only if they are not a deletion
142  dirent. Deletion dirents should be REF_NORMAL so that GC gets to
143  throw them away when appropriate */
144 #define dirent_node_state(rd) ( (je32_to_cpu((rd)->ino)?REF_PRISTINE:REF_NORMAL) )
145
146 /* NB: REF_PRISTINE for an inode-less node (ref->next_in_ino == NULL) indicates
147  it is an unknown node of type JFFS2_NODETYPE_RWCOMPAT_COPY, so it'll get
148  copied. If you need to do anything different to GC inode-less nodes, then
149  you need to modify gc.c accordingly. */
150
151 /* For each inode in the filesystem, we need to keep a record of
152  nlink, because it would be a PITA to scan the whole directory tree
153  at read_inode() time to calculate it, and to keep sufficient information
154  in the raw_node_ref (basically both parent and child inode number for
155  dirent nodes) would take more space than this does. We also keep
156  a pointer to the first physical node which is part of this inode, too.
157 */
159  /* First part of structure is shared with other objects which
160  can terminate the raw node refs' next_in_ino list -- which
161  currently struct jffs2_xattr_datum and struct jffs2_xattr_ref. */
162
163  struct jffs2_full_dirent *scan_dents; /* Used during scan to hold
164  temporary lists of dirents, and later must be set to
165  NULL to mark the end of the raw_node_ref->next_in_ino
166  chain. */
167  struct jffs2_raw_node_ref *nodes;
168  uint8_t class; /* It's used for identification */
169
170  /* end of shared structure */
171
172  uint8_t flags;
173  uint16_t state;
174  uint32_t ino;
175  struct jffs2_inode_cache *next;
176 #ifdef CONFIG_JFFS2_FS_XATTR
177  struct jffs2_xattr_ref *xref;
178 #endif
179  uint32_t pino_nlink; /* Directories store parent inode
180  here; other inodes store nlink.
181  Zero always means that it's
182  completely unlinked. */
183 };
184
185 /* Inode states for 'state' above. We need the 'GC' state to prevent
186  someone from doing a read_inode() while we're moving a 'REF_PRISTINE'
187  node without going through all the iget() nonsense */
188 #define INO_STATE_UNCHECKED 0 /* CRC checks not yet done */
189 #define INO_STATE_CHECKING 1 /* CRC checks in progress */
190 #define INO_STATE_PRESENT 2 /* In core */
191 #define INO_STATE_CHECKEDABSENT 3 /* Checked, cleared again */
192 #define INO_STATE_GC 4 /* GCing a 'pristine' node */
193 #define INO_STATE_READING 5 /* In read_inode() */
194 #define INO_STATE_CLEARING 6 /* In clear_inode() */
195
196 #define INO_FLAGS_XATTR_CHECKED 0x01 /* has no duplicate xattr_ref */
197 #define INO_FLAGS_IS_DIR 0x02 /* is a directory */
198
199 #define RAWNODE_CLASS_INODE_CACHE 0
200 #define RAWNODE_CLASS_XATTR_DATUM 1
201 #define RAWNODE_CLASS_XATTR_REF 2
202
203 #define INOCACHE_HASHSIZE_MIN 128
204 #define INOCACHE_HASHSIZE_MAX 1024
205
206 #define write_ofs(c) ((c)->nextblock->offset + (c)->sector_size - (c)->nextblock->free_size)
207
208 /*
209  Larger representation of a raw node, kept in-core only when the
210  struct inode for this particular ino is instantiated.
211 */
212
214 {
215  struct jffs2_raw_node_ref *raw;
216  uint32_t ofs; /* The offset to which the data of this node belongs */
217  uint32_t size;
218  uint32_t frags; /* Number of fragments which currently refer
219  to this node. When this reaches zero,
220  the node is obsolete. */
221 };
222
223 /*
224  Even larger representation of a raw node, kept in-core only while
225  we're actually building up the original map of which nodes go where,
226  in read_inode()
227 */
229 {
230  struct rb_node rb;
231  struct jffs2_full_dnode *fn;
232  uint32_t version;
233  uint32_t data_crc;
234  uint32_t partial_crc;
235  uint32_t csize;
236  uint16_t overlapped;
237 };
238
239 /* Temporary data structure used during readinode. */
241 {
242  struct rb_root tn_root;
243  struct jffs2_tmp_dnode_info *mdata_tn;
244  uint32_t highest_version;
245  uint32_t latest_mctime;
246  uint32_t mctime_ver;
247  struct jffs2_full_dirent *fds;
248  struct jffs2_raw_node_ref *latest_ref;
249 };
250
252 {
253  union {
254  struct jffs2_raw_node_ref *raw;
255  struct jffs2_inode_cache *ic; /* Just during part of build */
256  };
257  struct jffs2_full_dirent *next;
258  uint32_t version;
259  uint32_t ino; /* == zero for unlink */
260  unsigned int nhash;
261  unsigned char type;
262  unsigned char name[0];
263 };
264
265 /*
266  Fragments - used to build a map of which raw node to obtain
267  data from for each part of the ino
268 */
270 {
271  struct rb_node rb;
272  struct jffs2_full_dnode *node; /* NULL for holes */
273  uint32_t size;
274  uint32_t ofs; /* The offset to which this fragment belongs */
275 };
276
278 {
279  struct list_head list;
280  int bad_count;
281  uint32_t offset; /* of this block in the MTD */
282
283  uint32_t unchecked_size;
284  uint32_t used_size;
285  uint32_t dirty_size;
286  uint32_t wasted_size;
287  uint32_t free_size; /* Note that sector_size - free_size
288  is the address of the first free space */
289  uint32_t allocated_refs;
290  struct jffs2_raw_node_ref *first_node;
291  struct jffs2_raw_node_ref *last_node;
292
293  struct jffs2_raw_node_ref *gc_node; /* Next node to be garbage collected */
294 };
295
296 static inline int jffs2_blocks_use_vmalloc(struct jffs2_sb_info *c)
297 {
298  return ((c->flash_size / c->sector_size) * sizeof (struct jffs2_eraseblock)) > (128L * 1024L);
299 }
300
301 #define ref_totlen(a, b, c) __jffs2_ref_totlen((a), (b), (c))
302
303 #define ALLOC_NORMAL 0 /* Normal allocation */
304 #define ALLOC_DELETION 1 /* Deletion node. Best to allow it */
305 #define ALLOC_GC 2 /* Space requested for GC. Give it or die */
306 #define ALLOC_NORETRY 3 /* For jffs2_write_dnode: On failure, return -EAGAIN instead of retrying */
307
308 /* How much dirty space before it goes on the very_dirty_list */
309 #define VERYDIRTY(c, size) ((size) >= ((c)->sector_size / 2))
310
311 /* check if dirty space is more than 255 Byte */
312 #define ISDIRTY(size) ((size) > sizeof (struct jffs2_raw_inode) + JFFS2_MIN_DATA_LEN)
313
314 #define PAD(x) (((x)+3)&~3)
315
316 #ifndef __rtems__
317 static inline int jffs2_encode_dev(union jffs2_device_node *jdev, dev_t rdev)
318 {
319  if (old_valid_dev(rdev)) {
320  jdev->old_id = cpu_to_je16(old_encode_dev(rdev));
321  return sizeof(jdev->old_id);
322  } else {
323  jdev->new_id = cpu_to_je32(new_encode_dev(rdev));
324  return sizeof(jdev->new_id);
325  }
326 }
327 #endif /* __rtems__ */
328
329 static inline struct jffs2_node_frag *frag_first(struct rb_root *root)
330 {
331  struct rb_node *node = rb_first(root);
332
333  if (!node)
334  return NULL;
335
336  return rb_entry(node, struct jffs2_node_frag, rb);
337 }
338
339 static inline struct jffs2_node_frag *frag_last(struct rb_root *root)
340 {
341  struct rb_node *node = rb_last(root);
342
343  if (!node)
344  return NULL;
345
346  return rb_entry(node, struct jffs2_node_frag, rb);
347 }
348
349 #define frag_next(frag) rb_entry(rb_next(&(frag)->rb), struct jffs2_node_frag, rb)
350 #define frag_prev(frag) rb_entry(rb_prev(&(frag)->rb), struct jffs2_node_frag, rb)
351 #define frag_parent(frag) rb_entry(rb_parent(&(frag)->rb), struct jffs2_node_frag, rb)
352 #define frag_left(frag) rb_entry((frag)->rb.rb_left, struct jffs2_node_frag, rb)
353 #define frag_right(frag) rb_entry((frag)->rb.rb_right, struct jffs2_node_frag, rb)
354 #define frag_erase(frag, list) rb_erase(&frag->rb, list);
355
356 #define tn_next(tn) rb_entry(rb_next(&(tn)->rb), struct jffs2_tmp_dnode_info, rb)
357 #define tn_prev(tn) rb_entry(rb_prev(&(tn)->rb), struct jffs2_tmp_dnode_info, rb)
358 #define tn_parent(tn) rb_entry(rb_parent(&(tn)->rb), struct jffs2_tmp_dnode_info, rb)
359 #define tn_left(tn) rb_entry((tn)->rb.rb_left, struct jffs2_tmp_dnode_info, rb)
360 #define tn_right(tn) rb_entry((tn)->rb.rb_right, struct jffs2_tmp_dnode_info, rb)
361 #define tn_erase(tn, list) rb_erase(&tn->rb, list);
362 #define tn_last(list) rb_entry(rb_last(list), struct jffs2_tmp_dnode_info, rb)
363 #define tn_first(list) rb_entry(rb_first(list), struct jffs2_tmp_dnode_info, rb)
364
365 /* nodelist.c */
366 void jffs2_add_fd_to_list(struct jffs2_sb_info *c, struct jffs2_full_dirent *new, struct jffs2_full_dirent **list);
367 void jffs2_set_inocache_state(struct jffs2_sb_info *c, struct jffs2_inode_cache *ic, int state);
368 struct jffs2_inode_cache *jffs2_get_ino_cache(struct jffs2_sb_info *c, uint32_t ino);
369 void jffs2_add_ino_cache (struct jffs2_sb_info *c, struct jffs2_inode_cache *new);
370 void jffs2_del_ino_cache(struct jffs2_sb_info *c, struct jffs2_inode_cache *old);
371 void jffs2_free_ino_caches(struct jffs2_sb_info *c);
372 void jffs2_free_raw_node_refs(struct jffs2_sb_info *c);
373 struct jffs2_node_frag *jffs2_lookup_node_frag(struct rb_root *fragtree, uint32_t offset);
374 void jffs2_kill_fragtree(struct rb_root *root, struct jffs2_sb_info *c_delete);
375 int jffs2_add_full_dnode_to_inode(struct jffs2_sb_info *c, struct jffs2_inode_info *f, struct jffs2_full_dnode *fn);
376 uint32_t jffs2_truncate_fragtree (struct jffs2_sb_info *c, struct rb_root *list, uint32_t size);
377 struct jffs2_raw_node_ref *jffs2_link_node_ref(struct jffs2_sb_info *c,
378  struct jffs2_eraseblock *jeb,
379  uint32_t ofs, uint32_t len,
380  struct jffs2_inode_cache *ic);
381 extern uint32_t __jffs2_ref_totlen(struct jffs2_sb_info *c,
382  struct jffs2_eraseblock *jeb,
383  struct jffs2_raw_node_ref *ref);
384
385 /* nodemgmt.c */
386 int jffs2_thread_should_wake(struct jffs2_sb_info *c);
387 int jffs2_reserve_space(struct jffs2_sb_info *c, uint32_t minsize,
388  uint32_t *len, int prio, uint32_t sumsize);
389 int jffs2_reserve_space_gc(struct jffs2_sb_info *c, uint32_t minsize,
390  uint32_t *len, uint32_t sumsize);
391 struct jffs2_raw_node_ref *jffs2_add_physical_node_ref(struct jffs2_sb_info *c,
392  uint32_t ofs, uint32_t len,
393  struct jffs2_inode_cache *ic);
394 void jffs2_complete_reservation(struct jffs2_sb_info *c);
395 void jffs2_mark_node_obsolete(struct jffs2_sb_info *c, struct jffs2_raw_node_ref *raw);
396
397 /* write.c */
398 int jffs2_do_new_inode(struct jffs2_sb_info *c, struct jffs2_inode_info *f, uint32_t mode, struct jffs2_raw_inode *ri);
399
400 struct jffs2_full_dnode *jffs2_write_dnode(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
401  struct jffs2_raw_inode *ri, const unsigned char *data,
402  uint32_t datalen, int alloc_mode);
403 struct jffs2_full_dirent *jffs2_write_dirent(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
404  struct jffs2_raw_dirent *rd, const unsigned char *name,
405  uint32_t namelen, int alloc_mode);
406 int jffs2_write_inode_range(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
407  struct jffs2_raw_inode *ri, unsigned char *buf,
408  uint32_t offset, uint32_t writelen, uint32_t *retlen);
409 int jffs2_do_create(struct jffs2_sb_info *c, struct jffs2_inode_info *dir_f, struct jffs2_inode_info *f,
410  struct jffs2_raw_inode *ri, const struct qstr *qstr);
411 int jffs2_do_unlink(struct jffs2_sb_info *c, struct jffs2_inode_info *dir_f, const char *name,
412  int namelen, struct jffs2_inode_info *dead_f, uint32_t time);
413 int jffs2_do_link(struct jffs2_sb_info *c, struct jffs2_inode_info *dir_f, uint32_t ino,
414  uint8_t type, const char *name, int namelen, uint32_t time);
415
416
417 /* readinode.c */
418 int jffs2_do_read_inode(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
419  uint32_t ino, struct jffs2_raw_inode *latest_node);
420 int jffs2_do_crccheck_inode(struct jffs2_sb_info *c, struct jffs2_inode_cache *ic);
421 void jffs2_do_clear_inode(struct jffs2_sb_info *c, struct jffs2_inode_info *f);
422
423 /* malloc.c */
424 int jffs2_create_slab_caches(void);
425 void jffs2_destroy_slab_caches(void);
426
427 struct jffs2_full_dirent *jffs2_alloc_full_dirent(int namesize);
428 void jffs2_free_full_dirent(struct jffs2_full_dirent *);
429 struct jffs2_full_dnode *jffs2_alloc_full_dnode(void);
430 void jffs2_free_full_dnode(struct jffs2_full_dnode *);
431 struct jffs2_raw_dirent *jffs2_alloc_raw_dirent(void);
432 void jffs2_free_raw_dirent(struct jffs2_raw_dirent *);
433 struct jffs2_raw_inode *jffs2_alloc_raw_inode(void);
434 void jffs2_free_raw_inode(struct jffs2_raw_inode *);
435 struct jffs2_tmp_dnode_info *jffs2_alloc_tmp_dnode_info(void);
436 void jffs2_free_tmp_dnode_info(struct jffs2_tmp_dnode_info *);
437 int jffs2_prealloc_raw_node_refs(struct jffs2_sb_info *c,
438  struct jffs2_eraseblock *jeb, int nr);
439 void jffs2_free_refblock(struct jffs2_raw_node_ref *);
440 struct jffs2_node_frag *jffs2_alloc_node_frag(void);
441 void jffs2_free_node_frag(struct jffs2_node_frag *);
442 struct jffs2_inode_cache *jffs2_alloc_inode_cache(void);
443 void jffs2_free_inode_cache(struct jffs2_inode_cache *);
444 #ifdef CONFIG_JFFS2_FS_XATTR
445 struct jffs2_xattr_datum *jffs2_alloc_xattr_datum(void);
446 void jffs2_free_xattr_datum(struct jffs2_xattr_datum *);
447 struct jffs2_xattr_ref *jffs2_alloc_xattr_ref(void);
448 void jffs2_free_xattr_ref(struct jffs2_xattr_ref *);
449 #endif
450
451 /* gc.c */
452 int jffs2_garbage_collect_pass(struct jffs2_sb_info *c);
453
454 /* read.c */
455 int jffs2_read_dnode(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
456  struct jffs2_full_dnode *fd, unsigned char *buf,
457  int ofs, int len);
458 int jffs2_read_inode_range(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
459  unsigned char *buf, uint32_t offset, uint32_t len);
460 char *jffs2_getlink(struct jffs2_sb_info *c, struct jffs2_inode_info *f);
461
462 /* scan.c */
463 int jffs2_scan_medium(struct jffs2_sb_info *c);
464 void jffs2_rotate_lists(struct jffs2_sb_info *c);
465 struct jffs2_inode_cache *jffs2_scan_make_ino_cache(struct jffs2_sb_info *c, uint32_t ino);
466 int jffs2_scan_classify_jeb(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
467 int jffs2_scan_dirty_space(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb, uint32_t size);
468
469 /* build.c */
470 int jffs2_do_mount_fs(struct jffs2_sb_info *c);
471
472 /* erase.c */
473 int jffs2_erase_pending_blocks(struct jffs2_sb_info *c, int count);
474 void jffs2_free_jeb_node_refs(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
475
476 #ifdef CONFIG_JFFS2_FS_WRITEBUFFER
477 /* wbuf.c */
478 int jffs2_flush_wbuf_gc(struct jffs2_sb_info *c, uint32_t ino);
479 int jffs2_flush_wbuf_pad(struct jffs2_sb_info *c);
480 int jffs2_check_nand_cleanmarker(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
481 int jffs2_write_nand_cleanmarker(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
482 #endif
483
484 #include "debug.h"
485
486 #endif /* __JFFS2_NODELIST_H__ */
Definition: nodelist.h:82
Definition: xattr.h:23
Definition: nodelist.h:158
Definition: nodelist.h:277
Definition: rbtree.h:48
Definition: list.h:57
Definition: jffs2.h:116
Definition: nodelist.h:213
Definition: nodelist.h:251
Definition: nodelist.h:269
Definition: jffs2.h:218
Definition: jffs2.h:140
Definition: jffs2_fs_sb.h:48
Definition: jffs2_fs_i.h:20
unsigned size
Definition: tte.h:74
Definition: nodelist.h:240
Definition: xattr.h:45
Definition: nodelist.h:228
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Definition: types.h:19
