RTEMS  5.1
VMEConfig.h
1 #ifndef RTEMS_BSP_VME_CONFIG_H
2 #define RTEMS_BSP_VME_CONFIG_H
3 /* VMEConfig.h, S. Kate Feng modified it for MVME5500 3/04
4  *
5  * May 2011 : Use the VME shared IRQ handlers.
6  *
7  * It seems that the implementation of VMEUNIVERSE_IRQ_MGR_FLAG_PW_WORKAROUND
8  * is not fully developed. The UNIV_REGOFF_VCSR_BS is defined for VME64
9  * specification, which does not apply to a VME32 crate. In order to avoid
10  * spurious VME interrupts, a better and more universal solution is
11  * to flush the vmeUniverse FIFO by reading a register back within the
12  * users' Interrupt Service Routine (ISR) before returning.
13  *
14  * Some devices might require the ISR to issue an interrupt status READ
15  * after its IRQ is cleared, but before its corresponding interrupt
16  * is enabled again.
17  *
18  */
19
20 /*
21  * Prototypes
22  */
23 int BSP_VMEInit(void);
24 int BSP_VMEIrqMgrInstall(void);
25
26 /* BSP specific address space configuration parameters */
27
28 /*
29  * The BSP maps VME address ranges into
30  * one BAT.
31  * NOTE: the BSP (startup/bspstart.c) uses
32  * hardcoded window lengths that match this
33  * layout:
34  */
35 #define _VME_A32_WIN0_ON_PCI 0x90000000
36 /* If _VME_CSR_ON_PCI is defined then the A32 window is reduced to accommodate
37  * CSR for space.
38  */
39 #define _VME_CSR_ON_PCI 0x9e000000
40 #define _VME_A24_ON_PCI 0x9f000000
41 #define _VME_A16_ON_PCI 0x9fff0000
42
43 /* Reuse BAT 0 for VME */
44 #define BSP_VME_BAT_IDX 0
45
46 /* start of the A32 window on the VME bus
47  * TODO: this should perhaps be a configuration option
48  */
49 #define _VME_A32_WIN0_ON_VME 0x20000000
50
51 /* if _VME_DRAM_OFFSET is defined, the BSP
52  * will map our RAM onto the VME bus, starting
53  * at _VME_DRAM_OFFSET
54  */
55 #define _VME_DRAM_OFFSET 0x90000000
56
57 #define BSP_VME_UNIVERSE_INSTALL_IRQ_MGR(err) \
58  do { \
59  err = vmeUniverseInstallIrqMgrAlt(VMEUNIVERSE_IRQ_MGR_FLAG_SHARED, \
60  0, BSP_GPP_VME_VLINT0, \
61  1, BSP_GPP_VME_VLINT1, \
62  2, BSP_GPP_VME_VLINT2, \
63  3, BSP_GPP_VME_VLINT3, \
64  -1 /* terminate list */); \
65  } while (0)
66
67 #endif
