RTEMS  5.1
mvme16x_hw.h
1
9 /* mvme16x_hw.h
10  *
11  * This include file contains all MVME16x board IO definitions
12  * and was derived by combining the common items in the
13  * mvme162 and mvme167 BSPs.
14  *
15  * COPYRIGHT (c) 1989-2000.
16  * On-Line Applications Research Corporation (OAR).
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef __MVME16xHW_h
24 #define __MVME16xHW_h
25
26 #include <bsp.h>
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif
31
40 struct rtems_bsdnet_ifconfig;
41 int uti596_attach(struct rtems_bsdnet_ifconfig * pConfig, int attaching );
42 #define RTEMS_BSP_NETWORK_DRIVER_NAME "uti1"
43 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH uti596_attach
44
45 /*
46  * This is NOT the base address of local RAM!
47  * This is the base local address of the VMEbus short I/O space. A local
48  * access to this space results in a A16 VMEbus I/O cycle. This base address
49  * is NOT configurable on the MVME167, although the types of VMEbus short I/O
50  * cycles generated when a cycle in the local 0xFFFF0000-0xFFFFFFFF address
51  * range is generated is under control of bits 8-15 of LCSR 0xFFF4002C. The
52  * GCSRs of other boards are accessible only through the VMEbus short I/O
53  * space. See pages 2-45 and 2-7.
54  */
55 #define BOARD_BASE_ADDRESS 0xFFFF0000
56
57 /*
58  * This address must be added to the BOARD_BASE_ADDRESS to access the GCSR of
59  * other MVMEs in the group, i.e. it represents the offset of the GCSRs in the
60  * VMEbus short I/O space. It also should represent the group address of this
61  * MVME167! The group address is configurable, and must match the address
62  * programmed into the MVME167 through the 167Bug monitor. 0xCC is the address
63  * recommended by Motorola. It is arbitrary.
64  * See pages 2-42 and 2-97 to 2-104.
65  */
66 #define GROUP_BASE_ADDRESS 0x0000CC00
67
68 /*
69  * Representation of the VMEchip2 LCSR.
70  * Could be made more detailed.
71  */
72
73 typedef volatile struct {
74  unsigned long slave_adr[2];
75  unsigned long slave_trn[2];
76  unsigned long slave_ctl;
77  unsigned long mastr_adr[4];
78  unsigned long mastr_trn;
79  unsigned long mastr_att;
80  unsigned long mastr_ctl;
81  unsigned long dma_ctl_1;
82  unsigned long dma_ctl_2;
83  unsigned long dma_loc_cnt;
84  unsigned long dma_vme_cnt;
85  unsigned long dma_byte_cnt;
86  unsigned long dma_adr_cnt;
87  unsigned long dma_status;
88  unsigned long to_ctl;
89  unsigned long timer_cmp_1;
90  unsigned long timer_cnt_1;
91  unsigned long timer_cmp_2;
92  unsigned long timer_cnt_2;
93  unsigned long board_ctl;
94  unsigned long prescaler_cnt;
95  unsigned long intr_stat;
96  unsigned long intr_ena;
97  unsigned long intr_soft_set;
98  unsigned long intr_clear;
99  unsigned long intr_level[4];
100  unsigned long vector_base;
101 } lcsr_regs;
102
103 /*
104  * Base address of VMEchip2 LCSR
105  * Not configurable on the MVME167.
106  * XXX what about 162?
107  */
108 #define lcsr ((lcsr_regs * const) 0xFFF40000)
109
110 /*
111  * Vector numbers for the interrupts from the VMEchip2. Use the values
112  * "recommended" by Motorola.
113  * See pages 2-70 to 2-92, and table 2-3.
114  */
115
116 /* MIEN (Master Interrupt Enable) bit in LCSR 0xFFF40088. */
117 #define MASK_INT 0x00800000
118
119 /* The content of VBR0 corresponds to "X" in table 2-3 */
120 #define VBR0 0x6
121
122 /* The content of VBR1 corresponds to "Y" in table 2-3 */
123 #define VBR1 0x7
124
125 /*
126  * Representation of the PCCchip2
127  */
128 typedef volatile struct pccchip2_regs_ {
129  unsigned char chip_id; /* 0xFFF42000 */
130  unsigned char chip_revision; /* 0xFFF42001 */
131  unsigned char gen_control; /* 0xFFF42002 */
132  unsigned char vector_base; /* 0xFFF42003 */
133  unsigned long timer_cmp_1; /* 0xFFF42004 */
134  unsigned long timer_cnt_1; /* 0xFFF42008 */
135  unsigned long timer_cmp_2; /* 0xFFF4200C */
136  unsigned long timer_cnt_2; /* 0xFFF42010 */
137  unsigned char LSB_prescaler_count;/* 0xFFF42014 */
138  unsigned char prescaler_clock_adjust; /* 0xFFF42015 */
139  unsigned char timer_ctl_2; /* 0xFFF42016 */
140  unsigned char timer_ctl_1; /* 0xFFF42017 */
141  unsigned char gpi_int_ctl; /* 0xFFF42018 */
142  unsigned char gpio_ctl; /* 0xFFF42019 */
143  unsigned char timer_int_ctl_2; /* 0xFFF4201A */
144  unsigned char timer_int_ctl_1; /* 0xFFF4201B */
145  unsigned char SCC_error; /* 0xFFF4201C */
146  unsigned char SCC_modem_int_ctl; /* 0xFFF4201D */
147  unsigned char SCC_tx_int_ctl; /* 0xFFF4201E */
148  unsigned char SCC_rx_int_ctl; /* 0xFFF4201F */
149  unsigned char reserved1[3];
150  unsigned char modem_piack; /* 0xFFF42023 */
151  unsigned char reserved2;
152  unsigned char tx_piack; /* 0xFFF42025 */
153  unsigned char reserved3;
154  unsigned char rx_piack; /* 0xFFF42027 */
155  unsigned char LANC_error; /* 0xFFF42028 */
156  unsigned char reserved4;
157  unsigned char LANC_int_ctl; /* 0xFFF4202A */
158  unsigned char LANC_berr_ctl; /* 0xFFF4202B */
159  unsigned char SCSI_error; /* 0xFFF4202C */
160  unsigned char reserved5[2];
161  unsigned char SCSI_int_ctl; /* 0xFFF4202F */
162  unsigned char print_ack_int_ctl; /* 0xFFF42030 */
163  unsigned char print_fault_int_ctl;/* 0xFFF42031 */
164  unsigned char print_sel_int_ctl; /* 0xFFF42032 */
165  unsigned char print_pe_int_ctl; /* 0xFFF42033 */
166  unsigned char print_busy_int_ctl; /* 0xFFF42034 */
167  unsigned char reserved6;
168  unsigned char print_input_status; /* 0xFFF42036 */
169  unsigned char print_ctl; /* 0xFFF42037 */
170  unsigned char chip_speed; /* 0xFFF42038 */
171  unsigned char reserved7;
172  unsigned char print_data; /* 0xFFF4203A */
173  unsigned char reserved8[3];
174  unsigned char int_level; /* 0xFFF4203E */
175  unsigned char int_mask; /* 0xFFF4203F */
176 } pccchip2_regs;
177
178 /*
179  * Base address of the PCCchip2.
180  * This is not configurable in the MVME167.
181  */
182 #define pccchip2 ((pccchip2_regs * const) 0xFFF42000)
183
184 /*
185  * On the MVME162, we have the mcchip and the pccchip2 on
186  * the 167. They are similar but different enough where
187  * we have to reconcile them later.
188  */
189
190 /*
191  * Vector numbers for the interrupts from the PCCchip2. Use the values
192  * "recommended" by Motorola.
193  * See page 3-15.
194  */
195 #define PCCCHIP2_VBR 0x5
196
197 /*
198  * The following registers are located in the VMEbus short
199  * IO space and respond to address modifier codes $29 and $2D.
200  * On FORCE CPU use address gcsr_vme and device /dev/vme16d32.
201  */
202
203 typedef volatile struct {
204  unsigned char chip_revision;
205  unsigned char chip_id;
206  unsigned char lmsig;
207  unsigned char board_scr;
208  unsigned short gpr[6];
209 } gcsr_regs;
210
211 #define gcsr_vme ((gcsr_regs * const) (GROUP_BASE_ADDRESS + BOARD_BASE_ADDRESS))
212 #define gcsr ((gcsr_regs * const) 0xFFF40100)
213
214 /*
215  * Representation of 82596CA LAN controller: Memory Map
216  */
217 typedef volatile struct i82596_regs_ {
218  unsigned short port_lower; /* 0xFFF46000 */
219  unsigned short port_upper; /* 0xFFF46002 */
220  unsigned long chan_attn; /* 0xFFF46004 */
221 } i82596_regs;
222
223 /*
224  * Base address of the 82596.
225  */
226
227 #define i82596 ((i82596_regs * const) 0xFFF46000)
228
229 /*
230  * Representation of initialization data in NVRAM
231  */
232
233 #if defined(mvme167)
234 typedef volatile struct nvram_config_ {
235  unsigned char cache_mode; /* 0xFFFC0000 */
236  unsigned char console_mode; /* 0xFFFC0001 */
237  unsigned char console_printk_port; /* 0xFFFC0002 */
238  unsigned char pad1; /* 0xFFFC0003 */
239  unsigned long ipaddr; /* 0xFFFC0004 */
240  unsigned long netmask; /* 0xFFFC0008 */
241  unsigned char enaddr[6]; /* 0xFFFC000C */
242  unsigned short processor_id; /* 0xFFFC0012 */
243  unsigned long rma_start; /* 0xFFFC0014 */
244  unsigned long vma_start; /* 0xFFFC0018 */
245  unsigned long ramsize; /* 0xFFFC001C */
246 } nvram_config;
247
248 /*
249  * Pointer to the base of User Area NVRAM
250  */
251
252 #define nvram ((nvram_config * const) 0xFFFC0000)
253
254 #endif
255
256 /*
257  * Flag to indicate if J1-4 is on (and parameters should be
258  * sought in User Area NVRAM)
259  *
260  * NOTE: If NVRAM has bad settings, the you want to disable this
261  * on the MVME167.
262  */
263 #if defined(mvme167)
264  #define NVRAM_CONFIGURE \
265  ( !( ( (unsigned char)(lcsr->vector_base & 0xFF) ) & 0x10 ) )
266 #else
267  #define NVRAM_CONFIGURE 0
268 #endif
269
270 #ifdef __cplusplus
271 }
272 #endif
273
274 #endif
Definition: mvme16x_hw.h:203
Definition: mvme16x_hw.h:217
Definition: mvme16x_hw.h:73
Definition: mvme16x_hw.h:128
