RTEMS  5.1
mscan_int.h
1 /*===============================================================*\
2 | Project: RTEMS generic MPC5200 BSP |
3 +-----------------------------------------------------------------+
4 | Partially based on the code references which are named below. |
5 | Adaptions, modifications, enhancements and any recent parts of |
6 | the code are: |
7 | Copyright (c) 2005 |
8 | Embedded Brains GmbH |
9 | Obere Lagerstr. 30 |
10 | D-82178 Puchheim |
11 | Germany |
12 | rtems@embedded-brains.de |
13 +-----------------------------------------------------------------+
14 | The license and distribution terms for this file may be |
15 | found in the file LICENSE in this distribution or at |
16 | |
17 | http://www.rtems.org/license/LICENSE. |
18 | |
19 +-----------------------------------------------------------------+
20 | this file has to be included by the m driver |
21 \*===============================================================*/
22 #ifndef __MSCAN_INT_H__
23 #define __MSCAN_INT_H__
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
29 #include <bsp/mscan-base.h>
30
31 #include <bsp/mscan.h>
32
33 #define MSCAN_RX_BUFF_NUM 4
34 #define MSCAN_TX_BUFF_NUM 3
35
36 #define MSCAN_NON_INITIALIZED_MODE 0
37 #define MSCAN_INITIALIZED_MODE 1
38 #define MSCAN_INIT_NORMAL_MODE 2
39 #define MSCAN_NORMAL_MODE 4
40 #define MSCAN_SLEEP_MODE 8
41
42 #define MSCAN_RX_BUFF_NOACTIVE (0 << 4)
43 #define MSCAN_RX_BUFF_EMPTY (1 << 6)
44 #define MSCAN_RX_BUFF_FULL (1 << 5)
45 #define MSCAN_RX_BUFF_OVERRUN ((MSCAN_RX_BUFF_EMPTY) | (MSCAN_RX_BUFF_FULL))
46 #define MSCAN_RX_BUFF_BUSY (1 << 4)
47
48 #define MSCAN_MBUFF_MASK 0x07
49
50 #define MSCAN_TX_BUFF0 (1 << 0)
51 #define MSCAN_TX_BUFF1 (1 << 1)
52 #define MSCAN_TX_BUFF2 (1 << 2)
53
54 #define MSCAN_IDE (1 << 0)
55 #define MSCAN_RTR (1 << 1)
56 #define MSCAN_READ_RXBUFF_0 (1 << 2)
57 #define MSCAN_READ_RXBUFF_1 (1 << 2)
58 #define MSCAN_READ_RXBUFF_2 (1 << 2)
59 #define MSCAN_READ_RXBUFF_3 (1 << 2)
60
61 #define MSCAN_STATE_OK 0
62 #define MSCAN_STATE_ERR 1
63 #define MSCAN_STATE_WRN 2
64 #define MSCAN_STATE_BUSOFF 3
65
66 #define TX_MBUF_SEL(buf_no) (1 << (buf_no))
67 #define TX_DATA_LEN(len) ((len) & 0x0F)
68
69 #define TX_MBUF_EMPTY(val) (1 << (val))
70
71 #define ID_RTR (1 << 4)
72
73 #define SET_IDR0(u16) ((uint8_t)((u16) >> 3))
74 #define SET_IDR1(u16) (MSCAN_MESS_ID_HAS_RTR(u16) ? ((uint8_t)(((u16) & 0x0007) << 5))|((uint8_t)(ID_RTR)) : ((uint8_t)(((u16) & 0x0007) << 5)))
75
76 #define SET_IDR2(u16) SET_IDR0(u16)
77 #define SET_IDR3(u16) SET_IDR1(u16)
78
79 #define SET_IDR4(u16) SET_IDR0(u16)
80 #define SET_IDR5(u16) SET_IDR1(u16)
81
82 #define SET_IDR6(u16) SET_IDR0(u16)
83 #define SET_IDR7(u16) SET_IDR1(u16)
84
85 #define GET_IDR0(u16) ((uint16_t) ((u16) << 3))
86 #define GET_IDR1(u16) ((((u16)&(ID_RTR))==(ID_RTR)) ? (uint16_t) ((((u16) >> 5)&0x0007)|MSCAN_MESS_ID_RTR) : (uint16_t)(((u16) >> 5)&0x0007))
87
88 #define GET_IDR2(u16) GET_IDR0(u16)
89 #define GET_IDR3(u16) GET_IDR1(u16)
90
91 #define GET_IDR4(u16) GET_IDR0(u16)
92 #define GET_IDR5(u16) GET_IDR1(u16)
93
94 #define GET_IDR6(u16) GET_IDR0(u16)
95 #define GET_IDR7(u16) GET_IDR1(u16)
96
97 #define SET_IDMR0(u16) ((uint8_t)((u16) >> 3))
98 #define SET_IDMR1(u16) (MSCAN_MESS_ID_HAS_RTR(u16) ? ((uint8_t) (((((u16) & 0x0007) << 5)|((uint8_t)(ID_RTR)))|0x0007)) : ((uint8_t)((((u16) & 0x0007) << 5))|0x0007))
99
100 #define SET_IDMR2(u16) SET_IDMR0(u16)
101 #define SET_IDMR3(u16) SET_IDMR1(u16)
102
103 #define SET_IDMR4(u16) SET_IDMR0(u16)
104 #define SET_IDMR5(u16) SET_IDMR1(u16)
105
106 #define SET_IDMR6(u16) SET_IDMR0(u16)
107 #define SET_IDMR7(u16) SET_IDMR1(u16)
108
109 #define GET_IDMR0(u16) ((uint16_t)((u16) << 3))
110 #define GET_IDMR1(u16) ((((u16)&(ID_RTR))==(ID_RTR)) ? (uint16_t) ((((u16) >> 5)&0x0007)|MSCAN_MESS_ID_RTR) : (uint16_t)(((u16) >> 5)&0x0007))
111
112 #define GET_IDMR2(u16) GET_IDMR0(u16)
113 #define GET_IDMR3(u16) GET_IDMR1(u16)
114
115 #define GET_IDMR4(u16) GET_IDMR0(u16)
116 #define GET_IDMR5(u16) GET_IDMR1(u16)
117
118 #define GET_IDMR6(u16) GET_IDMR0(u16)
119 #define GET_IDMR7(u16) GET_IDMR1(u16)
120
121 #define NO_OF_MSCAN_RX_BUFF 20
122 #define MSCAN_MESSAGE_SIZE(size) (((size)%CPU_ALIGNMENT) ? (((size) + CPU_ALIGNMENT)-((size) + CPU_ALIGNMENT)%CPU_ALIGNMENT) : (size))
123
124 #define TX_BUFFER_0 0
125 #define TX_BUFFER_1 1
126 #define TX_BUFFER_2 2
127
128 #define RX_BUFFER_0 0
129 #define RX_BUFFER_1 1
130 #define RX_BUFFER_2 2
131 #define RX_BUFFER_3 3
132
133 #define NO_OF_MSCAN_TX_BUFF 20
134 #define RING_BUFFER_EMPTY(rbuff) ((((rbuff)->head) == ((rbuff)->tail)) ? TRUE : FALSE)
135 #define RING_BUFFER_FULL(rbuff) ((((rbuff)->head) == ((rbuff)->tail)) ? TRUE : FALSE)
136
137
138 typedef struct _mscan_handle
139  {
140  uint8_t mscan_channel;
141  void (*toucan_callback)(int16_t);
142  } mscan_handle;
143
144 struct ring_buf
145  {
146  struct can_message * volatile buf_ptr;
147  struct can_message * volatile head_ptr;
148  struct can_message * volatile tail_ptr;
149  };
150
152  {
153  struct can_message can_rx_message[MSCAN_RX_BUFF_NUM];
154  };
155
157  {
158  mscan *regs;
159  uint32_t int_rx_err;
160  rtems_id rx_qid;
161  uint32_t rx_qname;
162  rtems_id tx_rb_sid;
163  uint32_t tx_rb_sname;
164  uint8_t id_extended;
165  uint8_t mode;
166  uint8_t tx_buf_no;
167  struct ring_buf tx_ring_buf;
168  };
169
170 extern void CanInterrupt_A(int16_t);
171 extern void CanInterrupt_B(int16_t);
172
173 /*MSCAN driver internal functions */
174 void mscan_hardware_initialize(rtems_device_major_number, uint32_t, void *);
175 void mpc5200_mscan_wait_sync(mscan *);
176 void mpc5200_mscan_perform_init_mode_settings(mscan *);
177 void mpc5200_mscan_perform_normal_mode_settings(mscan *);
178 rtems_status_code mpc5200_mscan_set_mode(rtems_device_minor_number, uint8_t);
179 rtems_status_code mscan_channel_initialize(rtems_device_major_number, rtems_device_minor_number);
180
181 #ifdef __cplusplus
182 }
183 #endif
184
185 #endif /* __MSCAN_H__ */
Definition: mscan_int.h:151
Definition: mscan_int.h:138
Definition: mscan_int.h:144
rtems_status_code
Classic API Status.
Definition: status.h:43
A CAN message represented of both forms.
Definition: can.h:66
Definition: mscan_int.h:156
MSCAN register definitions and support functions.
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
struct mpc5200_mscan mscan
MSCAN registers.
Definition: mscan-base.h:242
