RTEMS  5.1
mscan.h
1 /*===============================================================*\
2 | Project: RTEMS generic MPC5200 BSP |
3 +-----------------------------------------------------------------+
4 | Partially based on the code references which are named below. |
5 | Adaptions, modifications, enhancements and any recent parts of |
6 | the code are: |
7 | Copyright (c) 2005 |
8 | Embedded Brains GmbH |
9 | Obere Lagerstr. 30 |
10 | D-82178 Puchheim |
11 | Germany |
12 | rtems@embedded-brains.de |
13 +-----------------------------------------------------------------+
14 | The license and distribution terms for this file may be |
15 | found in the file LICENSE in this distribution or at |
16 | |
17 | http://www.rtems.org/license/LICENSE. |
18 | |
19 +-----------------------------------------------------------------+
20 | this file has to be included by application when using mscan |
21 \*===============================================================*/
22 #ifndef __MSCAN_H__
23 #define __MSCAN_H__
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
29 #define MSCAN_A_DEV_NAME "/dev/mscana"
30 #define MSCAN_B_DEV_NAME "/dev/mscanb"
31 #define MSCAN_0_DEV_NAME "/dev/mscan0"
32 #define MSCAN_1_DEV_NAME "/dev/mscan1"
33 #define MSCAN_A 0
34 #define MSCAN_B 1
35
36 #define MSCAN_MAX_DATA_BYTES 8
37
38 #define MSCAN_MESS_ID_RTR (1 << 15)
39 #define MSCAN_MESS_ID_RTR_MASK (1 << 15)
40 #define MSCAN_MESS_ID_ID_MASK ((1 << 11)-1)
41 #define MSCAN_MESS_ID_HAS_RTR(id) (((id)&MSCAN_MESS_ID_RTR_MASK)==MSCAN_MESS_ID_RTR)
42
43 #define MSCAN_SET_RX_ID 1
44 #define MSCAN_GET_RX_ID 2
45 #define MSCAN_SET_RX_ID_MASK 3
46 #define MSCAN_GET_RX_ID_MASK 4
47 #define MSCAN_SET_TX_ID 5
48 #define MSCAN_GET_TX_ID 6
49 #define TOUCAN_MSCAN_INIT 7
50 #define MSCAN_SET_BAUDRATE 8
51 #define SET_TX_BUF_NO 9
52
53 struct can_message
54  {
55  /* uint16_t mess_len; */
56  uint16_t mess_id;
57  uint16_t mess_time_stamp;
58  uint8_t mess_data[MSCAN_MAX_DATA_BYTES];
59  uint8_t mess_len;
60  uint8_t mess_rtr;
61  uint32_t toucan_tx_idx;
62  };
63
65  {
66  struct can_message *rx_mess;
67  uint32_t rx_timeout;
68  uint8_t rx_flags;
69  };
70
72  {
73  struct can_message *tx_mess;
74  uint32_t tx_idx;
75  };
76
78  {
79  uint32_t ctrl_id;
80  uint32_t ctrl_id_mask;
81  uint8_t ctrl_reg_no;
82  uint8_t ctrl_tx_buf_no;
83  uint32_t ctrl_can_bitrate;
84  void (*toucan_cb_fnc)(int16_t);
85  };
86
87
88 rtems_device_driver mscan_initialize( rtems_device_major_number,
89  rtems_device_minor_number,
90  void *
91  );
92
93 rtems_device_driver mscan_open( rtems_device_major_number,
94  rtems_device_minor_number,
95  void *
96  );
97
98 rtems_device_driver mscan_close( rtems_device_major_number,
99  rtems_device_minor_number,
100  void *
101  );
102
103 rtems_device_driver mscan_read( rtems_device_major_number,
104  rtems_device_minor_number,
105  void *
106  );
107
108 rtems_device_driver mscan_write( rtems_device_major_number,
109  rtems_device_minor_number,
110  void *
111  );
112
113 rtems_device_driver mscan_control( rtems_device_major_number,
114  rtems_device_minor_number,
115  void *
116  );
117
118
119 #define MSCAN_DRIVER_TABLE_ENTRY \
120  { mscan_initialize, mscan_open, mscan_close, \
121  mscan_read, mscan_write, mscan_control }
122
123 #ifdef __cplusplus
124 }
125 #endif
126
127 #endif /* __MSCAN_H__ */
Definition: mscan.h:77
rtems_status_code
Classic API Status.
Definition: status.h:43
A CAN message represented of both forms.
Definition: can.h:66
Definition: mscan.h:71
Definition: mscan.h:64
