RTEMS  5.1
mpu.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef _MPU_H_
31 #define _MPU_H_
32 #ifdef __rtems__
33 #include <bsp.h>
34 #endif /* __rtems__ */
35
36 /*----------------------------------------------------------------------------
37  * Definitions
38  *----------------------------------------------------------------------------*/
39 #define ARM_MODE_USR 0x10
40
41 #define PRIVILEGE_MODE 0
42 #define USER_MODE 1
43
44 #define MPU_DEFAULT_ITCM_REGION (1)
45 #define MPU_DEFAULT_IFLASH_REGION (2)
46 #define MPU_DEFAULT_DTCM_REGION (3)
47 #define MPU_DEFAULT_SRAM_REGION_1 (4)
48 #define MPU_DEFAULT_SRAM_REGION_2 (5)
49 #define MPU_PERIPHERALS_REGION (6)
50 #define MPU_EXT_EBI_REGION (7)
51 #define MPU_DEFAULT_SDRAM_REGION (8)
52 #define MPU_QSPIMEM_REGION (9)
53 #define MPU_USBHSRAM_REGION (10)
54 #if defined MPU_HAS_NOCACHE_REGION
55  #define MPU_NOCACHE_SRAM_REGION (11)
56 #endif
57 #define MPU_SYSTEM_REGION (12)
58 #ifdef __rtems__
59 /* Reserve the region with highest priority for user applications */
60 #define MPU_USER_DEFINED_REGION (15)
61 #endif /* __rtems__ */
62
63 #define MPU_REGION_VALID (0x10)
64 #define MPU_REGION_ENABLE (0x01)
65 #define MPU_REGION_DISABLE (0x0)
66
67 #define MPU_ENABLE (0x1 << MPU_CTRL_ENABLE_Pos)
68 #define MPU_HFNMIENA (0x1 << MPU_CTRL_HFNMIENA_Pos)
69 #define MPU_PRIVDEFENA (0x1 << MPU_CTRL_PRIVDEFENA_Pos)
70
71
72 #define MPU_REGION_BUFFERABLE (0x01 << MPU_RASR_B_Pos)
73 #define MPU_REGION_CACHEABLE (0x01 << MPU_RASR_C_Pos)
74 #define MPU_REGION_SHAREABLE (0x01 << MPU_RASR_S_Pos)
75
76 #define MPU_REGION_EXECUTE_NEVER (0x01 << MPU_RASR_XN_Pos)
77
78 #define MPU_AP_NO_ACCESS (0x00 << MPU_RASR_AP_Pos)
79 #define MPU_AP_PRIVILEGED_READ_WRITE (0x01 << MPU_RASR_AP_Pos)
80 #define MPU_AP_UNPRIVILEGED_READONLY (0x02 << MPU_RASR_AP_Pos)
81 #define MPU_AP_FULL_ACCESS (0x03 << MPU_RASR_AP_Pos)
82 #define MPU_AP_RES (0x04 << MPU_RASR_AP_Pos)
83 #define MPU_AP_PRIVILEGED_READONLY (0x05 << MPU_RASR_AP_Pos)
84 #define MPU_AP_READONLY (0x06 << MPU_RASR_AP_Pos)
85 #define MPU_AP_READONLY2 (0x07 << MPU_RASR_AP_Pos)
86
87 #define MPU_TEX_B000 (0x01 << MPU_RASR_TEX_Pos)
88 #define MPU_TEX_B001 (0x01 << MPU_RASR_TEX_Pos)
89 #define MPU_TEX_B010 (0x01 << MPU_RASR_TEX_Pos)
90 #define MPU_TEX_B011 (0x01 << MPU_RASR_TEX_Pos)
91 #define MPU_TEX_B100 (0x01 << MPU_RASR_TEX_Pos)
92 #define MPU_TEX_B101 (0x01 << MPU_RASR_TEX_Pos)
93 #define MPU_TEX_B110 (0x01 << MPU_RASR_TEX_Pos)
94 #define MPU_TEX_B111 (0x01 << MPU_RASR_TEX_Pos)
95
96 /* Default memory map
97  Address range Memory region Memory type Shareability Cache policy
98  0x00000000- 0x1FFFFFFF Code Normal Non-shareable WT
99  0x20000000- 0x3FFFFFFF SRAM Normal Non-shareable WBWA
100  0x40000000- 0x5FFFFFFF Peripheral Device Non-shareable -
101  0x60000000- 0x7FFFFFFF RAM Normal Non-shareable WBWA
102  0x80000000- 0x9FFFFFFF RAM Normal Non-shareable WT
103  0xA0000000- 0xBFFFFFFF Device Device Shareable
104  0xC0000000- 0xDFFFFFFF Device Device Non Shareable
105  0xE0000000- 0xFFFFFFFF System - -
106  */
107
108 /********* IFLASH memory macros *********************/
109 #ifdef __rtems__
110 #define ITCM_START_ADDRESS ((uintptr_t) atsam_memory_itcm_begin)
111 #define ITCM_END_ADDRESS ((uintptr_t) atsam_memory_itcm_end - 1)
112 #define IFLASH_START_ADDRESS ((uintptr_t) atsam_memory_intflash_begin)
113 #define IFLASH_END_ADDRESS ((uintptr_t) atsam_memory_intflash_end - 1)
114 #else /* !__rtems__ */
115 #define ITCM_START_ADDRESS 0x00000000UL
116 #define ITCM_END_ADDRESS 0x003FFFFFUL
117 #define IFLASH_START_ADDRESS 0x00400000UL
118 #define IFLASH_END_ADDRESS 0x005FFFFFUL
119 #endif /* __rtems__ */
120
121
122 #define IFLASH_PRIVILEGE_START_ADDRESS (IFLASH_START_ADDRESS)
123 #define IFLASH_PRIVILEGE_END_ADDRESS (IFLASH_START_ADDRESS + 0xFFF)
124
125 #define IFLASH_UNPRIVILEGE_START_ADDRESS (IFLASH_PRIVILEGE_END_ADDRESS + 1)
126 #define IFLASH_UNPRIVILEGE_END_ADDRESS (IFLASH_END_ADDRESS)
127
128 /**************** DTCM *******************************/
129 #ifdef __rtems__
130 #define DTCM_START_ADDRESS ((uintptr_t) atsam_memory_dtcm_begin)
131 #define DTCM_END_ADDRESS ((uintptr_t) atsam_memory_dtcm_end - 1)
132 #else /* !__rtems__ */
133 #define DTCM_START_ADDRESS 0x20000000UL
134 #define DTCM_END_ADDRESS 0x203FFFFFUL
135 #endif /* __rtems__ */
136
137
138 /******* SRAM memory macros ***************************/
139
140 #ifdef __rtems__
141 #define SRAM_START_ADDRESS ((uintptr_t) atsam_memory_intsram_begin)
142 #define SRAM_END_ADDRESS ((uintptr_t) atsam_memory_intsram_end - 1)
143 #else /* !__rtems__ */
144 #define SRAM_START_ADDRESS 0x20400000UL
145 #define SRAM_END_ADDRESS 0x2045FFFFUL
146 #endif /* __rtems__ */
147
148 #ifndef __rtems__
149 #if defined MPU_HAS_NOCACHE_REGION
150  #define NOCACHE_SRAM_REGION_SIZE 0x1000
151 #endif
152 #endif /* __rtems__ */
153
154 /* Regions should be a 2^(N+1) where 4 < N < 31 */
155 #ifdef __rtems__
156 #define SRAM_FIRST_START_ADDRESS ((uintptr_t) atsam_memory_intsram_begin)
157 #define SRAM_FIRST_END_ADDRESS ((uintptr_t) atsam_memory_intsram_end - 1)
158 #else /* !__rtems__ */
159 #define SRAM_FIRST_START_ADDRESS (SRAM_START_ADDRESS)
160 #define SRAM_FIRST_END_ADDRESS (SRAM_FIRST_START_ADDRESS + 0x3FFFF) // (2^18) 256 KB
161 #endif /* __rtems__ */
162
163 #if defined MPU_HAS_NOCACHE_REGION
164 #ifdef __rtems__
165  #define SRAM_NOCACHE_START_ADDRESS ((uintptr_t) atsam_memory_nocache_begin)
166  #define SRAM_NOCACHE_END_ADDRESS ((uintptr_t) atsam_memory_nocache_end - 1)
167  #define NOCACHE_SRAM_REGION_SIZE (SRAM_NOCACHE_END_ADDRESS - SRAM_NOCACHE_START_ADDRESS)
168 #else /* !__rtems__ */
169  #define SRAM_SECOND_START_ADDRESS (SRAM_FIRST_END_ADDRESS+1)
170  #define SRAM_SECOND_END_ADDRESS (SRAM_END_ADDRESS - NOCACHE_SRAM_REGION_SIZE) // (2^17) 128 - 0x1000 KB
171  #define SRAM_NOCACHE_START_ADDRESS (SRAM_SECOND_END_ADDRESS + 1)
172  #define SRAM_NOCACHE_END_ADDRESS (SRAM_END_ADDRESS)
173 #endif /* __rtems__ */
174 #else
175 #ifndef __rtems__
176  #define SRAM_SECOND_START_ADDRESS (SRAM_FIRST_END_ADDRESS + 1)
177  #define SRAM_SECOND_END_ADDRESS (SRAM_END_ADDRESS) // (2^17) 128 KB
178 #endif /* __rtems__ */
179 #endif
180 /************** Peripherals memory region macros ********/
181 #define PERIPHERALS_START_ADDRESS 0x40000000UL
182 #define PERIPHERALS_END_ADDRESS 0x5FFFFFFFUL
183 #ifdef __rtems__
184 #define SYSTEM_START_ADDRESS 0xE0000000UL
185 #define SYSTEM_END_ADDRESS 0xFFFFFFFFUL
186 #endif /* __rtems__ */
187
188 /******* Ext EBI memory macros ***************************/
189 #define EXT_EBI_START_ADDRESS 0x60000000UL
190 #define EXT_EBI_END_ADDRESS 0x6FFFFFFFUL
191
192 /******* Ext-SRAM memory macros ***************************/
193 #ifdef __rtems__
194 #define SDRAM_START_ADDRESS ((uintptr_t) atsam_memory_sdram_begin)
195 #define SDRAM_END_ADDRESS ((uintptr_t) atsam_memory_sdram_end - 1)
196 #else /* !__rtems__ */
197 #define SDRAM_START_ADDRESS 0x70000000UL
198 #define SDRAM_END_ADDRESS 0x7FFFFFFFUL
199 #endif /* __rtems__ */
200
201 /******* QSPI macros ***************************/
202 #ifdef __rtems__
203 #define QSPI_START_ADDRESS ((uintptr_t) atsam_memory_qspiflash_begin)
204 #define QSPI_END_ADDRESS ((uintptr_t) atsam_memory_qspiflash_end - 1)
205 #else /* !__rtems__ */
206 #define QSPI_START_ADDRESS 0x80000000UL
207 #define QSPI_END_ADDRESS 0x9FFFFFFFUL
208 #endif /* __rtems__ */
209
210 /************** USBHS_RAM region macros ******************/
211 #define USBHSRAM_START_ADDRESS 0xA0100000UL
212 #define USBHSRAM_END_ADDRESS 0xA01FFFFFUL
213
214 /*----------------------------------------------------------------------------
215  * Export functions
216  *----------------------------------------------------------------------------*/
217 void MPU_Enable(uint32_t dwMPUEnable);
218 void MPU_SetRegion(uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr);
219 void MPU_SetRegionNum(uint32_t dwRegionNum);
220 void MPU_DisableRegion(void);
221 uint32_t MPU_CalMPURegionSize(uint32_t dwActualSizeInBytes);
222 void MPU_UpdateRegions(uint32_t dwRegionNum, uint32_t dwRegionBaseAddr,
223  uint32_t dwRegionAttr);
224
225 #endif /* #ifndef _MMU_ */
226
Set active memory region.
Definition: mpu.c:88
Disable the current active region.
Definition: mpu.c:96
Calculate region size for the RASR.
Definition: mpu.c:117
void MPU_UpdateRegions(uint32_t dwRegionNum, uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr)
Update MPU regions.
Definition: mpu.c:140
Setup a memory region.
Definition: mpu.c:107
Enables the MPU module.
Definition: mpu.c:78
