RTEMS  5.1
mmu_405.h
1 #ifndef _mmu_405_h
2 #define _mmu_405_h
3
4 /*
5  Simple interface to the PowerPC 405 MMU
6
7  The intention here is just to allow the MMU to be used to define cacheability and
8  read/write/execute permissions in a simple enough way to fit entirely into the
9  64-entry TLB cache.
10
11  This code does not do address relocation and does not generate any MMU-related interrupts.
12
13  The process ID support is there for a possible future extension where RTEMS supports
14  setting the process ID on task switches, which allows per-process stack protection
15
16  This code will call fatal_error() if your add_space() calls overrun the 64 entries
17
18  Michael Hamel ADInstruments 2008
19
20 */
21
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif
26
27 #include "stdint.h"
28
29 enum {
30  kAllProcessIDs = 0
31 };
32
33 typedef enum MMUAccessType {
34  executable,
35  readOnlyData,
36  readOnlyNoCache,
37  readWriteData,
38  readWriteNoCache,
39  readWriteExecutable
40 } MMUAccessType;
41
42 /* Initialise and clear the MMU */
43 void mmu_initialise(void);
44
45 /* Turn on/off data access translation */
46 bool mmu_enable_data(bool enable);
47
48 /* Turn on instruction translation */
49 bool mmu_enable_code(bool enable);
50
51 /* Define properties for an area of memory (must be 1K-aligned) */
52 void mmu_add_space(uint32_t startAddr, uint32_t endAddr, MMUAccessType permissions, uint8_t processID);
53
54 /* Delete a memory property definition */
55 void mmu_remove_space(uint32_t startAddr, uint32_t endAddr);
56
57 /* Return number of TLB entries out of total in use */
58 int mmu_get_tlb_count(void);
59
60 /* Allocate a new process ID and return it */
61 uint8_t mmu_new_processID(void);
62
63 /* Free a process ID that has been in use */
64 void mmu_free_processID(uint8_t freeThis);
65
66 /* Return the current process ID */
67 uint8_t mmu_current_processID(void);
68
69 /* Change the process ID to ID and return the old value */
70 uint8_t mmu_set_processID(uint8_t toID);
71
72
73 #ifdef __cplusplus
74 }
75 #endif
76
77 #endif //_mmu_405.h
