RTEMS  5.1
mips.h
1
14 /*
15  * COPYRIGHT (c) 1989-2001.
16  * On-Line Applications Research Corporation (OAR).
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef _RTEMS_SCORE_MIPS_H
24 #define _RTEMS_SCORE_MIPS_H
25
34 #ifdef __cplusplus
35 extern "C" {
36 #endif
37
38 #ifndef ASM
39 #include <rtems/mips/idtcpu.h>
40 #endif
41
42 /*
43  * SR bits that enable/disable interrupts
44  *
45  * NOTE: XXX what about SR_ERL?
46  */
47
48 #if (__mips == 3) || (__mips == 32)
49 #ifdef ASM
50 #define SR_INTERRUPT_ENABLE_BITS 0x01
51 #else
52 #define SR_INTERRUPT_ENABLE_BITS SR_IE
53 #endif
54
55 #elif __mips == 1
56 #define SR_INTERRUPT_ENABLE_BITS SR_IEC
57
58 #else
59 #error "mips interrupt enable bits: unknown architecture level!"
60 #endif
61
62 /*
63  * This file contains the information required to build
64  * RTEMS for a particular member of the "no cpu"
65  * family when executing in protected mode. It does
66  * this by setting variables to indicate which implementation
67  * dependent features are present in a particular member
68  * of the family.
69  */
70
71 #if defined(__mips_soft_float)
72 #define MIPS_HAS_FPU 0
73 #else
74 #define MIPS_HAS_FPU 1
75 #endif
76
77
78 #if (__mips == 1)
79 #define CPU_MODEL_NAME "ISA Level 1 or 2"
80 #elif (__mips == 3) || (__mips == 32)
81 #if defined(__mips64)
82 #define CPU_MODEL_NAME "ISA Level 4"
83 #else
84 #define CPU_MODEL_NAME "ISA Level 3"
85 #endif
86 #else
87 #error "Unknown MIPS ISA level"
88 #endif
89
90 /*
91  * Define the name of the CPU family.
92  */
93
94 #define CPU_NAME "MIPS"
95
96 /*
97  * RTEMS Vector numbers for exception conditions. This is a direct
98  * map to the causes.
99  */
100
101 #define MIPS_EXCEPTION_BASE 0
102
103 #define MIPS_EXCEPTION_INT MIPS_EXCEPTION_BASE+0
104 #define MIPS_EXCEPTION_MOD MIPS_EXCEPTION_BASE+1
105 #define MIPS_EXCEPTION_TLBL MIPS_EXCEPTION_BASE+2
106 #define MIPS_EXCEPTION_TLBS MIPS_EXCEPTION_BASE+3
107 #define MIPS_EXCEPTION_ADEL MIPS_EXCEPTION_BASE+4
108 #define MIPS_EXCEPTION_ADES MIPS_EXCEPTION_BASE+5
109 #define MIPS_EXCEPTION_IBE MIPS_EXCEPTION_BASE+6
110 #define MIPS_EXCEPTION_DBE MIPS_EXCEPTION_BASE+7
111 #define MIPS_EXCEPTION_SYSCALL MIPS_EXCEPTION_BASE+8
112 #define MIPS_EXCEPTION_BREAK MIPS_EXCEPTION_BASE+9
113 #define MIPS_EXCEPTION_RI MIPS_EXCEPTION_BASE+10
114 #define MIPS_EXCEPTION_CPU MIPS_EXCEPTION_BASE+11
115 #define MIPS_EXCEPTION_OVERFLOW MIPS_EXCEPTION_BASE+12
116 #define MIPS_EXCEPTION_TRAP MIPS_EXCEPTION_BASE+13
117 #define MIPS_EXCEPTION_VCEI MIPS_EXCEPTION_BASE+14
118 /* FPE only on mips2 and higher */
119 #define MIPS_EXCEPTION_FPE MIPS_EXCEPTION_BASE+15
120 #define MIPS_EXCEPTION_C2E MIPS_EXCEPTION_BASE+16
121 /* 17-22 reserved */
122 #define MIPS_EXCEPTION_WATCH MIPS_EXCEPTION_BASE+23
123 /* 24-30 reserved */
124 #define MIPS_EXCEPTION_VCED MIPS_EXCEPTION_BASE+31
125
126 #define MIPS_INTERRUPT_BASE MIPS_EXCEPTION_BASE+32
127
128 /*
129  * Some macros to access registers
130  */
131
132 #define mips_get_sr( _x ) \
133  do { \
134  __asm__ volatile( "mfc0 %0, $12; nop" : "=r" (_x) : ); \
135  } while (0)
136
137 #define mips_set_sr( _x ) \
138  do { \
139  unsigned int __x = (_x); \
140  __asm__ volatile( "mtc0 %0, $12; nop" : : "r" (__x) ); \
141  } while (0)
142
143
144 /*
145  * Access the Cause register
146  */
147
148 #define mips_get_cause( _x ) \
149  do { \
150  __asm__ volatile( "mfc0 %0, $13; nop" : "=r" (_x) : ); \
151  } while (0)
152
153
154 #define mips_set_cause( _x ) \
155  do { \
156  unsigned int __x = (_x); \
157  __asm__ volatile( "mtc0 %0, $13; nop" : : "r" (__x) ); \
158  } while (0)
159
160
161
162
163 /*
164  * Access the Debug Cache Invalidate Control register
165  */
166
167 #define mips_get_dcic( _x ) \
168  do { \
169  __asm__ volatile( "mfc0 %0, $7; nop" : "=r" (_x) : ); \
170  } while (0)
171
172
173 #define mips_set_dcic( _x ) \
174  do { \
175  unsigned int __x = (_x); \
176  __asm__ volatile( "mtc0 %0, $7; nop" : : "r" (__x) ); \
177  } while (0)
178
179
180
181
182 /*
183  * Access the Breakpoint Program Counter & Mask registers
184  * (_x for BPC, _y for mask)
185  */
186
187 #define mips_get_bpcrm( _x, _y ) \
188  do { \
189  __asm__ volatile( "mfc0 %0, $3; nop" : "=r" (_x) : ); \
190  __asm__ volatile( "mfc0 %0, $11; nop" : "=r" (_y) : ); \
191  } while (0)
192
193
194 #define mips_set_bpcrm( _x, _y ) \
195  do { \
196  unsigned int __x = (_x); \
197  unsigned int __y = (_y); \
198  __asm__ volatile( "mtc0 %0, $11; nop" : : "r" (__y) ); \
199  __asm__ volatile( "mtc0 %0, $3; nop" : : "r" (__x) ); \
200  } while (0)
201
202
203
204
205
206
207 /*
208  * Access the Breakpoint Data Address & Mask registers
209  * (_x for BDA, _y for mask)
210  */
211
212 #define mips_get_bdarm( _x, _y ) \
213  do { \
214  __asm__ volatile( "mfc0 %0, $5; nop" : "=r" (_x) : ); \
215  __asm__ volatile( "mfc0 %0, $9; nop" : "=r" (_y) : ); \
216  } while (0)
217
218
219 #define mips_set_bdarm( _x, _y ) \
220  do { \
221  unsigned int __x = (_x); \
222  unsigned int __y = (_y); \
223  __asm__ volatile( "mtc0 %0, $9; nop" : : "r" (__y) ); \
224  __asm__ volatile( "mtc0 %0, $5; nop" : : "r" (__x) ); \
225  } while (0)
226
227
228
229
230
231
232
233 /*
234  * Access FCR31
235  */
236
237 #if ( MIPS_HAS_FPU == 1 )
238
239 #define mips_get_fcr31( _x ) \
240  do { \
241  __asm__ volatile( "cfc1 %0, $31; nop" : "=r" (_x) : ); \
242  } while(0)
243
244
245 #define mips_set_fcr31( _x ) \
246  do { \
247  unsigned int __x = (_x); \
248  __asm__ volatile( "ctc1 %0, $31; nop" : : "r" (__x) ); \
249  } while(0)
250
251 #else
252
253 #define mips_get_fcr31( _x )
254 #define mips_set_fcr31( _x )
255
256 #endif
257
258 /*
259  * Manipulate interrupt mask
260  *
261  * mips_unmask_interrupt( _mask)
262  * enables interrupts - mask is positioned so it only needs to be or'ed
263  * into the status reg. This also does some other things !!!! Caution
264  * should be used if invoking this while in the middle of a debugging
265  * session where the client may have nested interrupts.
266  *
267  * mips_mask_interrupt( _mask )
268  * disable the interrupt - mask is the complement of the bits to be
269  * cleared - i.e. to clear ext int 5 the mask would be - 0xffff7fff
270  *
271  *
272  * NOTE: mips_mask_interrupt() used to be disable_int().
273  * mips_unmask_interrupt() used to be enable_int().
274  *
275  */
276
277 #define mips_enable_in_interrupt_mask( _mask ) \
278  do { \
279  unsigned int _sr; \
280  mips_get_sr( _sr ); \
281  _sr |= (_mask); \
282  mips_set_sr( _sr ); \
283  } while (0)
284
285 #define mips_disable_in_interrupt_mask( _mask ) \
286  do { \
287  unsigned int _sr; \
288  mips_get_sr( _sr ); \
289  _sr &= ~(_mask); \
290  mips_set_sr( _sr ); \
291  } while (0)
292
293 #ifdef __cplusplus
294 }
295 #endif
296
298 #endif /* _RTEMS_SCORE_MIPS_H */
299 /* end of include file */
CPU Related Definitions.
