RTEMS
5.1
Definition of the interface between stub and gdb. More...
struct | rtems_gdb_stub_thread_info |
#define | QM_MAX_THREADS (20) |
Max number of threads in qM response. | |
#define | MEMOPT_READABLE 1 |
#define | MEMOPT_WRITEABLE 2 |
#define | NUM_MEMSEGS 10 |
MIPS registers | |
Numbered in the order in which gdb expects to see them. | |
#define | ZERO 0 |
#define | AT 1 |
#define | V0 2 |
#define | V1 3 |
#define | A0 4 |
#define | A1 5 |
#define | A2 6 |
#define | A3 7 |
#define | T0 8 |
#define | T1 9 |
#define | T2 10 |
#define | T3 11 |
#define | T4 12 |
#define | T5 13 |
#define | T6 14 |
#define | T7 15 |
#define | S0 16 |
#define | S1 17 |
#define | S2 18 |
#define | S3 19 |
#define | S4 20 |
#define | S5 21 |
#define | S6 22 |
#define | S7 23 |
#define | T8 24 |
#define | T9 25 |
#define | K0 26 |
#define | K1 27 |
#define | GP 28 |
#define | SP 29 |
#define | S8 30 |
#define | RA 31 |
#define | SR 32 |
#define | LO 33 |
#define | HI 34 |
#define | BAD_VA 35 |
#define | CAUSE 36 |
#define | PC 37 |
#define | F0 38 |
#define | F1 39 |
#define | F2 40 |
#define | F3 41 |
#define | F4 42 |
#define | F5 43 |
#define | F6 44 |
#define | F7 45 |
#define | F8 46 |
#define | F9 47 |
#define | F10 48 |
#define | F11 49 |
#define | F12 50 |
#define | F13 51 |
#define | F14 52 |
#define | F15 53 |
#define | F16 54 |
#define | F17 55 |
#define | F18 56 |
#define | F19 57 |
#define | F20 58 |
#define | F21 59 |
#define | F22 60 |
#define | F23 61 |
#define | F24 62 |
#define | F25 63 |
#define | F26 64 |
#define | F27 65 |
#define | F28 66 |
#define | F29 67 |
#define | F30 68 |
#define | F31 69 |
#define | FCSR 70 |
#define | FIRR 71 |
#define | NUM_REGS 72 |
void | mips_gdb_stub_install (int enableThreads) |
int | gdbstub_add_memsegment (unsigned, unsigned, int) |
Prototypes | |
int | parse_zbreak (const char *in, int *type, unsigned char **addr, int *len) |
char * | mem2hstr (char *buf, const unsigned char *mem, int count) |
int | hstr2mem (unsigned char *mem, const char *buf, int count) |
void | set_mem_err (void) |
unsigned char | get_byte (const unsigned char *ptr) |
void | set_byte (unsigned char *ptr, int val) |
char * | thread2vhstr (char *buf, int thread) |
char * | thread2fhstr (char *buf, int thread) |
const char * | fhstr2thread (const char *buf, int *thread) |
const char * | vhstr2thread (const char *buf, int *thread) |
char * | int2fhstr (char *buf, int val) |
char * | int2vhstr (char *buf, int vali) |
const char * | fhstr2int (const char *buf, int *ival) |
const char * | vhstr2int (const char *buf, int *ival) |
int | hstr2byte (const char *buf, int *bval) |
int | hstr2nibble (const char *buf, int *nibble) |
Thread_Control * | rtems_gdb_index_to_stub_id (int) |
int | rtems_gdb_stub_thread_support_ok (void) |
int | rtems_gdb_stub_get_current_thread (void) |
int | rtems_gdb_stub_get_next_thread (int) |
int | rtems_gdb_stub_get_offsets (unsigned char **text_addr, unsigned char **data_addr, unsigned char **bss_addr) |
int | rtems_gdb_stub_get_thread_regs (int thread, unsigned int *registers) |
int | rtems_gdb_stub_set_thread_regs (int thread, unsigned int *registers) |
void | rtems_gdb_process_query (char *inbuffer, char *outbuffer, int do_threads, int thread) |
