RTEMS  5.1
clockdrv.c File Reference
#include <bsp/irq.h>
#include <bsp.h>
#include "../../../shared/dev/clock/clockimpl.h"
#define CLOCK_VECTOR   TX4925_IRQ_TMR0
#define TX4925_TIMER_INTERVAL_MODE   1
#define TX4925_TIMER_PULSE_MODE   2
#define TX4925_TIMER_MODE   TX4925_TIMER_INTERVAL_MODE
#define TX4925_TIMER_INTERRUPT_FLAG   TIIS
#define Clock_driver_support_initialize_hardware()   Initialize_timer0_in_interval_mode()
#define Clock_driver_support_install_isr(_new)   rtems_interrupt_handler_install( CLOCK_VECTOR, "clock", 0, _new, NULL )
#define Clock_driver_support_at_tick()
#define Initialize_timer0_in_interval_mode()
#define Initialize_timer0_in_pulse_mode()
#define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
Instantiate the clock driver shell.
◆ Clock_driver_support_at_tick
#define Clock_driver_support_at_tick ( )
Value:
do { \
uint32_t interrupt_flag; \
do { \
int loop_count; \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_TISR, 0x0 ); /* Clear timer 0 interrupt */ \
loop_count = 0; \
do { /* Wait until interrupt flag is cleared (this prevents re-entering interrupt) */ \
/* Read back interrupt status register and isolate interval timer flag */ \
interrupt_flag = TX4925_REG_READ( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_TISR ) & TX4925_TIMER_INTERRUPT_FLAG; \
} while (interrupt_flag && (++loop_count < 10)); /* Loop while timer interrupt bit is set, or loop count is lees than 10 */ \
} while(interrupt_flag); \
} while(0)
◆ Initialize_timer0_in_interval_mode
#define Initialize_timer0_in_interval_mode ( )
Value:
do { \
uint32_t temp; \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_TCR, 0x0 ); /* Disable timer */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_CCDR, 0x0 ); /* Set register for divide by 2 clock */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_ITMR, TIMER_CLEAR_ENABLE_MASK ); /* Set interval timer mode register */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_CPRA, 0x30d40 ); /* Set tmier period ,10.0 msec (20 MHz timer clock) */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_TCR, 0xC0 ); /* Enable timer in interval mode */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_IRQCTL_DM0, 0x0 ); /* Set interrupt controller detection mode */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_IRQCTL_LVL2, 0x1000000 ); /* Set interrupt controller level */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_IRQCTL_MSK, 0x0 ); /* Set interrupt controller mask */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_IRQCTL_DEN, 0x1 ); /* Enable interrupts from controller */ \
temp = TX4925_REG_READ( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_ITMR ); /* Enable interval timer interrupts */ \
temp |= TIMER_INT_ENABLE_MASK; \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_ITMR, temp ); \
} while(0)
◆ Initialize_timer0_in_pulse_mode
#define Initialize_timer0_in_pulse_mode ( )
Value:
do { \
uint32_t temp; \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_PGMR, FFI ); /* Set pulse generator mode register */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_CPRA, 0x3e8 ); /* Set pulse high duration ,0.05 msec (20 MHz timer clock) */ \
/* TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_CPRB, 0x1388 ); */ /* Set pulse total period, 0.25 msec (20 MHz timer clock) */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_CPRB, 0x30d40 ); /* Set pulse total period, 10 msec (20 MHz timer clock) */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_TCR, 0xC1 ); /* Enable timer in pulse generator mode */ \
/* Enable timer 0 output pulses on PIO20 */ \
temp = TX4925_REG_READ( TX4925_REG_BASE, TX4925_CFG_PCFG ); \
temp = (temp & ~ SELCHI) | SELTMR0; /* Enable timer 0 pulses on PIO20 */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_CFG_PCFG, temp ); \
temp = TX4925_REG_READ( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_PGMR ); /* Enable pulse generator interrupt */ \
temp |= TPIBE; /* Only want interrupts on B compare (where clock count is cleared) */ \
TX4925_REG_WRITE( TX4925_REG_BASE, TX4925_TIMER0_BASE + TX4925_TIMER_PGMR, temp ); \
} while(0)
