RTEMS  5.1
clockdrv.c File Reference
#include <bsp/irq.h>
#include <bsp.h>
#include "../../../shared/dev/clock/clockimpl.h"
#define CLOCK_DRIVER_USE_FAST_IDLE   1
#define CLOCK_VECTOR   TX3904_IRQ_TMR0
#define CLICKS   5000
#define Clock_driver_support_install_isr(_new)   rtems_interrupt_handler_install( CLOCK_VECTOR, "clock", 0, _new, NULL )
#define Clock_driver_support_initialize_hardware()
#define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
Instantiate the clock driver shell.
The TX3904 simulator in gdb counts instructions.
◆ Clock_driver_support_initialize_hardware
#define Clock_driver_support_initialize_hardware (   void)
Value:
do { \
uint32_t _clicks = CLICKS; \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CCDR, 0x3 ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CPRA, _clicks ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TISR, 0x00 ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_ITMR, 0x8001 ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TCR, 0xC0 ); \
*((volatile uint32_t*) 0xFFFFC01C) = 0x00000700; \
} while(0)
