RTEMS  5.1
system_conf.h
1
9 /* system_conf.h
10  * Global System conf
11  *
12  * Milkymist port of RTEMS
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  *
18  * COPYRIGHT (c) 2010, 2011 Sebastien Bourdeauducq
19  */
20
21 #ifndef __SYSTEM_CONFIG_H_
22 #define __SYSTEM_CONFIG_H_
23
24 #define UART_BAUD_RATE (115200)
25
26 /* Clock frequency */
27 #define MM_FREQUENCY (0xe0001074)
28
29 /* FML bridge */
30 #define FMLBRG_FLUSH_BASE (0xc8000000)
31 #define FMLBRG_LINE_LENGTH (32)
32 #define FMLBRG_LINE_COUNT (512)
33
34 /* UART */
35 #define MM_UART_RXTX (0xe0000000)
36 #define MM_UART_DIV (0xe0000004)
37 #define MM_UART_STAT (0xe0000008)
38 #define MM_UART_CTRL (0xe000000c)
39
40 #define UART_STAT_THRE (0x1)
41 #define UART_STAT_RX_EVT (0x2)
42 #define UART_STAT_TX_EVT (0x4)
43
44 #define UART_CTRL_RX_INT (0x1)
45 #define UART_CTRL_TX_INT (0x2)
46 #define UART_CTRL_THRU (0x4)
47
48 /* Timers */
49 #define MM_TIMER1_COMPARE (0xe0001024)
50 #define MM_TIMER1_COUNTER (0xe0001028)
51 #define MM_TIMER1_CONTROL (0xe0001020)
52
53 #define MM_TIMER0_COMPARE (0xe0001014)
54 #define MM_TIMER0_COUNTER (0xe0001018)
55 #define MM_TIMER0_CONTROL (0xe0001010)
56
57 #define TIMER_ENABLE (0x01)
58 #define TIMER_AUTORESTART (0x02)
59
60 /* GPIO */
61 #define MM_GPIO_IN (0xe0001000)
62 #define MM_GPIO_OUT (0xe0001004)
63 #define MM_GPIO_INTEN (0xe0001008)
64
65 #define GPIO_BTN1 (0x00000001)
66 #define GPIO_BTN2 (0x00000002)
67 #define GPIO_BTN3 (0x00000004)
68 #define GPIO_PCBREV0 (0x00000008)
69 #define GPIO_PCBREV1 (0x00000010)
70 #define GPIO_PCBREV2 (0x00000020)
71 #define GPIO_PCBREV3 (0x00000040)
72 #define GPIO_LED1 (0x00000001)
73 #define GPIO_LED2 (0x00000002)
74
75 /* System ID and reset */
76 #define MM_SYSTEM_ID (0xe000107c)
77
78 /* ICAP */
79 #define MM_ICAP (0xe0001040)
80
81 #define ICAP_READY (0x01)
82 #define ICAP_CE (0x10000)
83 #define ICAP_WRITE (0x20000)
84
85 /* VGA */
86 #define MM_VGA_RESET (0xe0003000)
87
88 #define MM_VGA_HRES (0xe0003004)
89 #define MM_VGA_HSYNC_START (0xe0003008)
90 #define MM_VGA_HSYNC_END (0xe000300C)
91 #define MM_VGA_HSCAN (0xe0003010)
92
93 #define MM_VGA_VRES (0xe0003014)
94 #define MM_VGA_VSYNC_START (0xe0003018)
95 #define MM_VGA_VSYNC_END (0xe000301C)
96 #define MM_VGA_VSCAN (0xe0003020)
97
98 #define MM_VGA_BASEADDRESS (0xe0003024)
99 #define MM_VGA_BASEADDRESS_ACT (0xe0003028)
100
101 #define MM_VGA_BURST_COUNT (0xe000302C)
102
103 #define MM_VGA_DDC (0xe0003030)
104
105 #define MM_VGA_CLKSEL (0xe0003034)
106
107 #define VGA_RESET (0x01)
108 #define VGA_DDC_SDAIN (0x1)
109 #define VGA_DDC_SDAOUT (0x2)
110 #define VGA_DDC_SDAOE (0x4)
111 #define VGA_DDC_SDC (0x8)
112
113 /* Ethernet */
114 #define MM_MINIMAC_SETUP (0xe0008000)
115 #define MM_MINIMAC_MDIO (0xe0008004)
116
117 #define MM_MINIMAC_STATE0 (0xe0008008)
118 #define MM_MINIMAC_COUNT0 (0xe000800C)
119 #define MM_MINIMAC_STATE1 (0xe0008010)
120 #define MM_MINIMAC_COUNT1 (0xe0008014)
121
122 #define MM_MINIMAC_TXCOUNT (0xe0008018)
123
124 #define MINIMAC_RX0_BASE (0xb0000000)
125 #define MINIMAC_RX1_BASE (0xb0000800)
126 #define MINIMAC_TX_BASE (0xb0001000)
127
128 #define MINIMAC_SETUP_PHYRST (0x1)
129
130 #define MINIMAC_STATE_EMPTY (0x0)
131 #define MINIMAC_STATE_LOADED (0x1)
132 #define MINIMAC_STATE_PENDING (0x2)
133
134 /* AC97 */
135 #define MM_AC97_CRCTL (0xe0005000)
136
137 #define AC97_CRCTL_RQEN (0x01)
138 #define AC97_CRCTL_WRITE (0x02)
139
140 #define MM_AC97_CRADDR (0xe0005004)
141 #define MM_AC97_CRDATAOUT (0xe0005008)
142 #define MM_AC97_CRDATAIN (0xe000500C)
143
144 #define MM_AC97_DCTL (0xe0005010)
145 #define MM_AC97_DADDRESS (0xe0005014)
146 #define MM_AC97_DREMAINING (0xe0005018)
147
148 #define MM_AC97_UCTL (0xe0005020)
149 #define MM_AC97_UADDRESS (0xe0005024)
150 #define MM_AC97_UREMAINING (0xe0005028)
151
152 #define AC97_SCTL_EN (0x01)
153
154 #define AC97_MAX_DMASIZE (0x3fffc)
155
156 /* SoftUSB */
157 #define MM_SOFTUSB_CONTROL (0xe000f000)
158
159 #define SOFTUSB_CONTROL_RESET (0x1)
160
161 #define MM_SOFTUSB_PMEM_BASE (0xa0000000)
162 #define MM_SOFTUSB_DMEM_BASE (0xa0020000)
163
164 #define SOFTUSB_PMEM_SIZE (1 << 13)
165 #define SOFTUSB_DMEM_SIZE (1 << 13)
166
167 /* PFPU */
168 #define MM_PFPU_CTL (0xe0006000)
169 #define PFPU_CTL_START (0x01)
170 #define PFPU_CTL_BUSY (0x01)
171
172 #define MM_PFPU_MESHBASE (0xe0006004)
173 #define MM_PFPU_HMESHLAST (0xe0006008)
174 #define MM_PFPU_VMESHLAST (0xe000600C)
175
176 #define MM_PFPU_CODEPAGE (0xe0006010)
177
178 #define MM_PFPU_DREGBASE (0xe0006400)
179 #define MM_PFPU_CODEBASE (0xe0006800)
180
181 #define PFPU_PAGESIZE (512)
182 #define PFPU_SPREG_COUNT (2)
183 #define PFPU_REG_X (0)
184 #define PFPU_REG_Y (1)
185
186 /* TMU */
187 #define MM_TMU_CTL (0xe0007000)
188 #define TMU_CTL_START (0x01)
189 #define TMU_CTL_BUSY (0x01)
190 #define TMU_CTL_CHROMAKEY (0x02)
191
192 #define MM_TMU_HMESHLAST (0xe0007004)
193 #define MM_TMU_VMESHLAST (0xe0007008)
194 #define MM_TMU_BRIGHTNESS (0xe000700C)
195 #define MM_TMU_CHROMAKEY (0xe0007010)
196
197 #define MM_TMU_VERTICESADR (0xe0007014)
198 #define MM_TMU_TEXFBUF (0xe0007018)
199 #define MM_TMU_TEXHRES (0xe000701C)
200 #define MM_TMU_TEXVRES (0xe0007020)
201 #define MM_TMU_TEXHMASK (0xe0007024)
202 #define MM_TMU_TEXVMASK (0xe0007028)
203
204 #define MM_TMU_DSTFBUF (0xe000702C)
205 #define MM_TMU_DSTHRES (0xe0007030)
206 #define MM_TMU_DSTVRES (0xe0007034)
207 #define MM_TMU_DSTHOFFSET (0xe0007038)
208 #define MM_TMU_DSTVOFFSET (0xe000703C)
209 #define MM_TMU_DSTSQUAREW (0xe0007040)
210 #define MM_TMU_DSTSQUAREH (0xe0007044)
211
212 #define MM_TMU_ALPHA (0xe0007048)
213
214 /* Memory card */
215 #define MM_MEMCARD_CLK2XDIV (0xe0004000)
216
217 #define MM_MEMCARD_ENABLE (0xe0004004)
218
219 #define MEMCARD_ENABLE_CMD_TX (0x1)
220 #define MEMCARD_ENABLE_CMD_RX (0x2)
221 #define MEMCARD_ENABLE_DAT_TX (0x4)
222 #define MEMCARD_ENABLE_DAT_RX (0x8)
223
224 #define MM_MEMCARD_PENDING (0xe0004008)
225
226 #define MEMCARD_PENDING_CMD_TX (0x1)
227 #define MEMCARD_PENDING_CMD_RX (0x2)
228 #define MEMCARD_PENDING_DAT_TX (0x4)
229 #define MEMCARD_PENDING_DAT_RX (0x8)
230
231 #define MM_MEMCARD_START (0xe000400c)
232
233 #define MEMCARD_START_CMD_RX (0x1)
234 #define MEMCARD_START_DAT_RX (0x2)
235
236 #define MM_MEMCARD_CMD (0xe0004010)
237 #define MM_MEMCARD_DAT (0xe0004014)
238
239 /* DMX */
240 #define MM_DMX_TX(x) (0xe000c000+4*(x))
241 #define MM_DMX_THRU (0xe000c800)
242 #define MM_DMX_RX(x) (0xe000d000+4*(x))
243
244 /* MIDI */
245 #define MM_MIDI_RXTX (0xe000b000)
246 #define MM_MIDI_DIV (0xe000b004)
247 #define MM_MIDI_STAT (0xe000b008)
248 #define MM_MIDI_CTRL (0xe000b00c)
249
250 #define MIDI_STAT_THRE (0x1)
251 #define MIDI_STAT_RX_EVT (0x2)
252 #define MIDI_STAT_TX_EVT (0x4)
253
254 #define MIDI_CTRL_RX_INT (0x1)
255 #define MIDI_CTRL_TX_INT (0x2)
256 #define MIDI_CTRL_THRU (0x4)
257
258 /* IR */
259 #define MM_IR_RX (0xe000e000)
260
261 /* Video input */
262 #define MM_BT656_I2C (0xe000a000)
263 #define MM_BT656_FILTERSTATUS (0xe000a004)
264 #define MM_BT656_BASE (0xe000a008)
265 #define MM_BT656_MAXBURSTS (0xe000a00c)
266 #define MM_BT656_DONEBURSTS (0xe000a010)
267
268 #define BT656_I2C_SDAIN (0x1)
269 #define BT656_I2C_SDAOUT (0x2)
270 #define BT656_I2C_SDAOE (0x4)
271 #define BT656_I2C_SDC (0x8)
272
273 #define BT656_FILTER_FIELD1 (0x1)
274 #define BT656_FILTER_FIELD2 (0x2)
275 #define BT656_FILTER_INFRAME (0x4)
276
277 /* Interrupts */
278 #define MM_IRQ_UART (0)
279 #define MM_IRQ_GPIO (1)
280 #define MM_IRQ_TIMER0 (2)
281 #define MM_IRQ_TIMER1 (3)
282 #define MM_IRQ_AC97CRREQUEST (4)
283 #define MM_IRQ_AC97CRREPLY (5)
284 #define MM_IRQ_AC97DMAR (6)
285 #define MM_IRQ_AC97DMAW (7)
286 #define MM_IRQ_PFPU (8)
287 #define MM_IRQ_TMU (9)
288 #define MM_IRQ_ETHRX (10)
289 #define MM_IRQ_ETHTX (11)
290 #define MM_IRQ_VIDEOIN (12)
291 #define MM_IRQ_MIDI (13)
292 #define MM_IRQ_IR (14)
293 #define MM_IRQ_USB (15)
294
295 /* Flash layout */
296 #define FLASH_BASE (0x80000000)
297
298 #define FLASH_OFFSET_STANDBY_BITSTREAM (0x80000000)
299
300 #define FLASH_OFFSET_RESCUE_BITSTREAM (0x800A0000)
301 #define FLASH_OFFSET_RESCUE_BIOS (0x80220000)
302 #define FLASH_OFFSET_MAC_ADDRESS (0x802200E0)
303 #define FLASH_OFFSET_RESCUE_SPLASH (0x80240000)
304 #define FLASH_OFFSET_RESCUE_APP (0x802E0000)
305
306 #define FLASH_OFFSET_REGULAR_BITSTREAM (0x806E0000)
307 #define FLASH_OFFSET_REGULAR_BIOS (0x80860000)
308 #define FLASH_OFFSET_REGULAR_SPLASH (0x80880000)
309 #define FLASH_OFFSET_REGULAR_APP (0x80920000)
310
311 /* MMIO */
312 #define MM_READ(reg) (*((volatile unsigned int *)(reg)))
313 #define MM_WRITE(reg, val) *((volatile unsigned int *)(reg)) = val
314
315 /* Flash partitions */
316
317 #define FLASH_SECTOR_SIZE (128*1024)
318
319 #define FLASH_PARTITION_COUNT (5)
320
321 #define FLASH_PARTITIONS { \
322  { .start_address = 0x806E0000, .length = 0x0180000 }, \
323  { .start_address = 0x80860000, .length = 0x0020000 }, \
324  { .start_address = 0x80880000, .length = 0x00A0000 }, \
325  { .start_address = 0x80920000, .length = 0x0400000 }, \
326  { .start_address = 0x80D20000, .length = 0x12E0000 }, \
327 }
328
329 #endif /* __SYSTEM_CONFIG_H_ */
