RTEMS  5.1
memscrub.h
1 /* MEMSCRUB driver interface
2  *
3  * COPYRIGHT (c) 2017.
4  * Cobham Gaisler AB.
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef __MEMSCRUB_H__
12 #define __MEMSCRUB_H__
13
14 #include <stdint.h>
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19
20 #define MEMSCRUB_ERR_OK 0
21 #define MEMSCRUB_ERR_EINVAL -1
22 #define MEMSCRUB_ERR_ERROR -2
23
24 extern void memscrub_register_drv(void);
25
26 /*
27  * MEMORYSCRUBBER CONFIG register fields
28  */
29 #define CONFIG_DELAY_BIT 8
30 #define CONFIG_IRQD_BIT 7
31 #define CONFIG_SERA_BIT 5
32 #define CONFIG_LOOP_BIT 4
33 #define CONFIG_MODE_BIT 2
34 #define CONFIG_ES_BIT 1
35 #define CONFIG_SCEN_BIT 0
36
37 #define CONFIG_DELAY (0xff << CONFIG_DELAY_BIT)
38 #define CONFIG_IRQD (0x1 << CONFIG_IRQD_BIT)
39 #define CONFIG_SERA (0x1 << CONFIG_SERA_BIT)
40 #define CONFIG_LOOP (0x1 << CONFIG_LOOP_BIT)
41 #define CONFIG_MODE (0x3 << CONFIG_MODE_BIT)
42 #define CONFIG_ES (0x1 << CONFIG_ES_BIT)
43 #define CONFIG_SCEN (0x1 << CONFIG_SCEN_BIT)
44 #define CONFIG_MODE_SCRUB (0x0 << CONFIG_MODE_BIT)
45 #define CONFIG_MODE_REGEN (0x1 << CONFIG_MODE_BIT)
46 #define CONFIG_MODE_INIT (0x2 << CONFIG_MODE_BIT)
47
48 #define MEMSCRUB_OPTIONS_INTERRUPTDONE_ENABLE CONFIG_IRQD
49 #define MEMSCRUB_OPTIONS_INTERRUPTDONE_DISABLE 0
50 #define MEMSCRUB_OPTIONS_EXTERNALSTART_ENABLE CONFIG_ES
51 #define MEMSCRUB_OPTIONS_EXTERNALSTART_DISABLE 0
52 #define MEMSCRUB_OPTIONS_LOOPMODE_ENABLE CONFIG_LOOP
53 #define MEMSCRUB_OPTIONS_LOOPMODE_DISABLE 0
54 #define MEMSCRUB_OPTIONS_SECONDARY_MEMRANGE_ENABLE CONFIG_SERA
55 #define MEMSCRUB_OPTIONS_SECONDARY_MEMRANGE_DISABLE 0
56
57 /* Scrubbing modes */
58 extern int memscrub_init_start(uint32_t value, uint8_t delay, int options);
59 extern int memscrub_scrub_start(uint8_t delay, int options);
60 extern int memscrub_regen_start(uint8_t delay, int options);
61 extern int memscrub_stop(void);
62 extern int memscrub_active(void);
63
64 /* Set/get memory ranges */
65 extern int memscrub_range_set(uint32_t start, uint32_t end);
66 extern int memscrub_range_get(uint32_t * start, uint32_t * end);
67 extern int memscrub_secondary_range_set(uint32_t start, uint32_t end);
68 extern int memscrub_secondary_range_get(uint32_t * start, uint32_t * end);
69
70 /* Interrupts */
71 /* MEMSCRUB Interrupts */
72 /* Function Interrupt-Code ISR callback prototype.
73  * arg - Custom arg provided by user
74  * access - AHB Access that failed
75  * ahbstatus - AHB status register of the MEMSCRUB core
76  * status - status register of the MEMSCRUB core
77  */
78 typedef void (*memscrub_isr_t)(void *arg, uint32_t ahbaccess,
79  uint32_t ahbstatus, uint32_t scrubstatus);
80 extern int memscrub_isr_register(memscrub_isr_t isr, void * data);
81 extern int memscrub_isr_unregister(void);
82
83 extern int memscrub_error_status(uint32_t *ahbaccess, uint32_t *ahbstatus,
84  uint32_t *scrubstatus);
85
86 /* Set the different error thresholds. */
87
88 /*
89  * MEMORYSCRUBBER AHBS register fields
90  */
91 #define AHBS_CECNT_BIT 22
92 #define AHBS_UECNT_BIT 14
93 #define AHBS_DONE_BIT 13
94 #define AHBS_SEC_BIT 11
95 #define AHBS_SBC_BIT 10
96 #define AHBS_CE_BIT 9
97 #define AHBS_NE_BIT 8
98 #define AHBS_HW_BIT 7
99 #define AHBS_HM_BIT 3
100 #define AHBS_HS_BIT 0
101
102 #define AHBS_CECNT (0x3ff << AHBS_CECNT_BIT)
103 #define AHBS_UECNT (0xff << AHBS_UECNT_BIT)
104 #define AHBS_DONE (1 << AHBS_DONE_BIT)
105 #define AHBS_SEC (1 << AHBS_SEC_BIT)
106 #define AHBS_SBC (1 << AHBS_SBC_BIT)
107 #define AHBS_CE (1 << AHBS_CE_BIT)
108 #define AHBS_NE (1 << AHBS_NE_BIT)
109 #define AHBS_HW (1 << AHBS_HW_BIT)
110 #define AHBS_HM (0xf << AHBS_HM_BIT)
111 #define AHBS_HS (0x7 << AHBS_HS_BIT)
112
113 /*
114  * MEMORYSCRUBBER STAT register fields
115  */
116 #define STAT_RUNCOUNT_BIT 22
117 #define STAT_BLKCOUNT_BIT 14
118 #define STAT_DONE_BIT 13
119 #define STAT_BURSTLEN_BIT 1
120 #define STAT_ACTIVE_BIT 0
121
122 #define STAT_RUNCOUNT (0x3ff << STAT_RUNCOUNT_BIT)
123 #define STAT_BLKCOUNT (0xff << STAT_BLKCOUNT_BIT)
124 #define STAT_DONE (0x1 << STAT_DONE_BIT)
125 #define STAT_BURSTLEN (0xf << STAT_BURSTLEN_BIT)
126 #define STAT_ACTIVE (0x1 << STAT_ACTIVE_BIT)
127
128 /*
129  * MEMORYSCRUBBER AHBERC register fields
130  */
131 #define AHBERC_CECNTT_BIT 22
132 #define AHBERC_UECNTT_BIT 14
133 #define AHBERC_CECTE_BIT 1
134 #define AHBERC_UECTE_BIT 0
135
136 #define AHBERC_CECNTT (0x3ff << AHBERC_CECNTT_BIT)
137 #define AHBERC_UECNTT (0xff << AHBERC_UECNTT_BIT)
138 #define AHBERC_CECTE (0x1 << AHBERC_CECTE_BIT)
139 #define AHBERC_UECTE (0x1 << AHBERC_UECTE_BIT)
140
141 /*
142  * MEMORYSCRUBBER ETHRES register fields
143  */
144 #define ETHRES_RECT_BIT 22
145 #define ETHRES_BECT_BIT 14
146 #define ETHRES_RECTE_BIT 1
147 #define ETHRES_BECTE_BIT 0
148
149 #define ETHRES_RECT (0x3ff << ETHRES_RECT_BIT)
150 #define ETHRES_BECT (0xff << ETHRES_BECT_BIT)
151 #define ETHRES_RECTE (0x1 << ETHRES_RECTE_BIT)
152 #define ETHRES_BECTE (0x1 << ETHRES_BECTE_BIT)
153
154 #define MEMSCRUB_OPTIONS_AHBERROR_CORTHRES_ENABLE AHBERC_CECTE
155 #define MEMSCRUB_OPTIONS_AHBERROR_CORTHRES_DISABLE 0
156 #define MEMSCRUB_OPTIONS_AHBERROR_UNCORTHRES_ENABLE AHBERC_UECTE
157 #define MEMSCRUB_OPTIONS_AHBERROR_UNCORTHRES_DISABLE 0
158 #define MEMSCRUB_OPTIONS_SCRUBERROR_RUNTHRES_ENABLE ETHRES_RECTE
159 #define MEMSCRUB_OPTIONS_SCRUBERROR_RUNTHRES_DISABLE 0
160 #define MEMSCRUB_OPTIONS_SCRUBERROR_BLOCKTHRES_ENABLE ETHRES_BECTE
161 #define MEMSCRUB_OPTIONS_SCRUBERROR_BLOCKTHRES_DISABLE 0
162 extern int memscrub_ahberror_setup(int uethres, int cethres, int options);
163 extern int memscrub_scruberror_setup(int blkthres, int runthres,
164  int options);
165
166 extern int memscrub_scrub_position(uint32_t * position);
167
168 #ifdef __cplusplus
169 }
170 #endif
171
172 #endif
