RTEMS  5.1
mcf548x.h
1 /*===============================================================*\
2 | Project: RTEMS generic mcf548x BSP |
3 +-----------------------------------------------------------------+
4 | File: mcf548x.h |
5 +-----------------------------------------------------------------+
6 | The file contains all register an bit definitions of the |
7 | generic MCF548x BSP. |
8 +-----------------------------------------------------------------+
9 | Copyright (c) 2007 |
10 | Embedded Brains GmbH |
11 | Obere Lagerstr. 30 |
12 | D-82178 Puchheim |
13 | Germany |
14 | rtems@embedded-brains.de |
15 +-----------------------------------------------------------------+
16 | |
17 | Parts of the code has been derived from the "dBUG source code" |
18 | package Freescale is providing for M548X EVBs. The usage of |
19 | the modified or unmodified code and it's integration into the |
20 | generic mcf548x BSP has been done according to the Freescale |
21 | license terms. |
22 | |
23 | The Freescale license terms can be reviewed in the file |
24 | |
25 | Freescale_license.txt |
26 | |
27 +-----------------------------------------------------------------+
28 | |
29 | The generic mcf548x BSP has been developed on the basic |
30 | structures and modules of the av5282 BSP. |
31 | |
32 +-----------------------------------------------------------------+
33 | |
34 | The license and distribution terms for this file may be |
35 | found in the file LICENSE in this distribution or at |
36 | |
37 | http://www.rtems.org/license/LICENSE. |
38 | |
39 +-----------------------------------------------------------------+
40 | |
41 | date history ID |
42 | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
43 | 12.11.07 1.0 ras |
44 | |
45 \*===============================================================*/
46
47 #ifndef __MCF548X_H__
48 #define __MCF548X_H__
49
50 #include <stdint.h>
51
52 /*********************************************************************/
53 extern char __MBAR[];
54
55 /*********************************************************************
56 *
57 * Cache Control Register (CACR)
58 *
59 *********************************************************************/
60
61 /* Bit definitions and macros for MCF548X_CACR */
62 #define MCF548X_CACR_DEC (0x80000000)
63 #define MCF548X_CACR_DW (0x40000000)
64 #define MCF548X_CACR_DESB (0x20000000)
65 #define MCF548X_CACR_DDPI (0x10000000)
66 #define MCF548X_CACR_DHLCK (0x08000000)
67 #define MCF548X_CACR_DDCM(x) (((x)<<25)&0x06000000)
68 #define MCF548X_CACR_DCINVA (0x01000000)
69 #define MCF548X_CACR_DDSP (0x00800000)
70 #define MCF548X_CACR_BEC (0x00080000)
71 #define MCF548X_CACR_BCINVA (0x00040000)
72 #define MCF548X_CACR_IEC (0x00008000)
73 #define MCF548X_CACR_DNFB (0x00002000)
74 #define MCF548X_CACR_IDPI (0x00001000)
75 #define MCF548X_CACR_IHLCK (0x00000800)
76 #define MCF548X_CACR_IDCM (0x00000400)
77 #define MCF548X_CACR_ICINVA (0x00000100)
78 #define MCF548X_CACR_IDSP (0x00000080)
79 #define MCF548X_CACR_EUSP (0x00000020)
80 #define MCF548X_CACR_DF (0x00000010)
81
82 /* Bit definitions and macros for MCF548X_CACR_DDCM (data cache mode) */
83 #define DCACHE_ON_WRIGHTTHROUGH 0
84 #define DCACHE_ON_COPYBACK 1
85 #define DCACHE_OFF_PRECISE 2
86 #define DCACHE_OFF_IMPRECISE 3
87
88 /*********************************************************************
89 *
90 * Access Control Registers (ACR0-3)
91 *
92 *********************************************************************/
93
94 /* Bit definitions and macros for MCF548X_ACRn */
95 #define MCF548X_ACR_BA(x) ((x)&0xFF000000)
96 #define MCF548X_ACR_ADMSK_AMM(x) (((x)>=0x1000000) ? (((x)&0xFF000000)>>8) : (((x)&0x00FF0000)|0x00000400))
97 #define MCF548X_ACR_E (0x00008000)
98 #define MCF548X_ACR_S(x) (((x)<<13)&0x00006000)
99 #define MCF548X_ACR_CM(x) (((x)<<5)&0x00000060)
100 #define MCF548X_ACR_SP (0x00000008)
101 #define MCF548X_ACR_W (0x00000004)
102
103 /* Bit definitions and macros for MCF548X_ACR_S (supervisor/user access) */
104 #define S_ACCESS_USER 0
105 #define S_ACCESS_SUPV 1
106 #define S_ACCESS_BOTH 2
107
108 /* Bit definitions and macros for MCF548X_ACR_CM (cache mode) */
109 #define CM_ON_WRIGHTTHROUGH 0
110 #define CM_ON_COPYBACK 1
111 #define CM_OFF_PRECISE 2
112 #define CM_OFF_IMPRECISE 3
113
114 /*********************************************************************
115 *
116 * System PLL Control Register (SPCR)
117 *
118 *********************************************************************/
119
120 /* Register read/write macro */
121 #define MCF548X_PLL_SPCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000300)))
122
123 /* Bit definitions and macros for MCF548X_PLL_SPCR (supervisor/user access) */
124 #define MCF548X_PLL_SPCR_PLLK 0x80000000
125 #define MCF548X_PLL_SPCR_COREN 0x00004000
126 #define MCF548X_PLL_SPCR_CRYENB 0x00002000
127 #define MCF548X_PLL_SPCR_CRYENA 0x00001000
128 #define MCF548X_PLL_SPCR_CAN1EN 0x00000800
129 #define MCF548X_PLL_SPCR_PSCEN 0x00000200
130 #define MCF548X_PLL_SPCR_USBEN 0x00000080
131 #define MCF548X_PLL_SPCR_FEC1EN 0x00000040
132 #define MCF548X_PLL_SPCR_FEC0EN 0x00000020
133 #define MCF548X_PLL_SPCR_DMAEN 0x00000010
134 #define MCF548X_PLL_SPCR_CAN0EN 0x00000008
135 #define MCF548X_PLL_SPCR_FBEN 0x00000004
136 #define MCF548X_PLL_SPCR_PCIEN 0x00000002
137 #define MCF548X_PLL_SPCR_MEMEN 0x00000001
138
139 /*********************************************************************
140 *
141 * XLB Arbiter Control (XLB)
142 *
143 *********************************************************************/
144
145 /* Register read/write macros */
146 #define MCF548X_XLB_CFG (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000240)))
147 #define MCF548X_XLB_ADRTO (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000258)))
148 #define MCF548X_XLB_DATTO (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00025C)))
149 #define MCF548X_XLB_BUSTO (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000260)))
150
151 /*********************************************************************
152 *
153 * Fast Ethernet Controller (FEC)
154 *
155 *********************************************************************/
156
157 /* Register read/write macros */
158 #define MCF548X_FEC_EIR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009004)))
159 #define MCF548X_FEC_EIMR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009008)))
160 #define MCF548X_FEC_ECR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009024)))
161 #define MCF548X_FEC_MMFR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009040)))
162 #define MCF548X_FEC_MSCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009044)))
163 #define MCF548X_FEC_MIBC0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009064)))
164 #define MCF548X_FEC_RCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009084)))
165 #define MCF548X_FEC_R_HASH0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009088)))
166 #define MCF548X_FEC_TCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090C4)))
167 #define MCF548X_FEC_PALR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090E4)))
168 #define MCF548X_FEC_PAUR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090E8)))
169 #define MCF548X_FEC_OPD0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090EC)))
170 #define MCF548X_FEC_IAUR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009118)))
171 #define MCF548X_FEC_IALR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00911C)))
172 #define MCF548X_FEC_GAUR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009120)))
173 #define MCF548X_FEC_GALR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009124)))
174 #define MCF548X_FEC_FECTFWR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009144)))
175 #define MCF548X_FEC_FECRFDR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009184)))
176 #define MCF548X_FEC_FECRFSR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009188)))
177 #define MCF548X_FEC_FECRFCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00918C)))
178 #define MCF548X_FEC_FECRLRFP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009190)))
179 #define MCF548X_FEC_FECRLWFP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009194)))
180 #define MCF548X_FEC_FECRFAR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009198)))
181 #define MCF548X_FEC_FECRFRP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00919C)))
182 #define MCF548X_FEC_FECRFWP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091A0)))
183 #define MCF548X_FEC_FECTFDR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091A4)))
184 #define MCF548X_FEC_FECTFSR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091A8)))
185 #define MCF548X_FEC_FECTFCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091AC)))
186 #define MCF548X_FEC_FECTLRFP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091B0)))
187 #define MCF548X_FEC_FECTLWFP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091B4)))
188 #define MCF548X_FEC_FECTFAR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091B8)))
189 #define MCF548X_FEC_FECTFRP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091BC)))
190 #define MCF548X_FEC_FECTFWP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091C0)))
191 #define MCF548X_FEC_FRST0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091C4)))
192 #define MCF548X_FEC_CTCWR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091C8)))
193 #define MCF548X_FEC_RMON_T_DROP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009200)))
194 #define MCF548X_FEC_RMON_T_PACKETS0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009204)))
195 #define MCF548X_FEC_RMON_T_BC_PKT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009208)))
196 #define MCF548X_FEC_RMON_T_MC_PKT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00920C)))
197 #define MCF548X_FEC_RMON_T_CRC_ALIGN0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009210)))
198 #define MCF548X_FEC_RMON_T_UNDERSIZE0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009214)))
199 #define MCF548X_FEC_RMON_T_OVERSIZE0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009218)))
200 #define MCF548X_FEC_RMON_T_FRAG0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00921C)))
201 #define MCF548X_FEC_RMON_T_JAB0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009220)))
202 #define MCF548X_FEC_RMON_T_COL0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009224)))
203 #define MCF548X_FEC_RMON_T_P640 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009228)))
204 #define MCF548X_FEC_RMON_T_P65TO1270 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00922C)))
205 #define MCF548X_FEC_RMON_T_P128TO2550 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009230)))
206 #define MCF548X_FEC_RMON_T_P256TO5110 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009234)))
207 #define MCF548X_FEC_RMON_T_P512TO10230 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009238)))
208 #define MCF548X_FEC_RMON_T_P1024TO20470 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00923C)))
209 #define MCF548X_FEC_RMON_T_P_GTE20480 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009240)))
210 #define MCF548X_FEC_RMON_T_OCTETS0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009244)))
211 #define MCF548X_FEC_IEEE_T_DROP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009248)))
212 #define MCF548X_FEC_IEEE_T_FRAME_OK0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00924C)))
213 #define MCF548X_FEC_IEEE_T_1COL0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009250)))
214 #define MCF548X_FEC_IEEE_T_MCOL0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009254)))
215 #define MCF548X_FEC_IEEE_T_DEF0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009258)))
216 #define MCF548X_FEC_IEEE_T_LCOL0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00925C)))
217 #define MCF548X_FEC_IEEE_T_EXCOL0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009260)))
218 #define MCF548X_FEC_IEEE_T_MACERR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009264)))
219 #define MCF548X_FEC_IEEE_T_CSERR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009268)))
220 #define MCF548X_FEC_IEEE_T_SQE0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00926C)))
221 #define MCF548X_FEC_IEEE_T_FDXFC0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009270)))
222 #define MCF548X_FEC_IEEE_T_OCTETS_OK0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009274)))
223 #define MCF548X_FEC_RMON_R_PACKETS0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009284)))
224 #define MCF548X_FEC_RMON_R_BC_PKT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009288)))
225 #define MCF548X_FEC_RMON_R_MC_PKT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00928C)))
226 #define MCF548X_FEC_RMON_R_CRC_ALIGN0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009290)))
227 #define MCF548X_FEC_RMON_R_UNDERSIZE0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009294)))
228 #define MCF548X_FEC_RMON_R_OVERSIZE0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009298)))
229 #define MCF548X_FEC_RMON_R_FRAG0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00929C)))
230 #define MCF548X_FEC_RMON_R_JAB0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092A0)))
231 #define MCF548X_FEC_RMON_R_RESVD_00 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092A4)))
232 #define MCF548X_FEC_RMON_R_P640 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092A8)))
233 #define MCF548X_FEC_RMON_R_P65TO1270 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092AC)))
234 #define MCF548X_FEC_RMON_R_P128TO2550 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092B0)))
235 #define MCF548X_FEC_RMON_R_P256TO5110 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092B4)))
236 #define MCF548X_FEC_RMON_R_512TO10230 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092B8)))
237 #define MCF548X_FEC_RMON_R_1024TO20470 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092BC)))
238 #define MCF548X_FEC_RMON_R_P_GTE20480 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092C0)))
239 #define MCF548X_FEC_RMON_R_OCTETS0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092C4)))
240 #define MCF548X_FEC_IEEE_R_DROP0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092C8)))
241 #define MCF548X_FEC_IEEE_R_FRAME_OK0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092CC)))
242 #define MCF548X_FEC_IEEE_R_CRC0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092D0)))
243 #define MCF548X_FEC_IEEE_R_ALIGN0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092D4)))
244 #define MCF548X_FEC_IEEE_R_MACERR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092D8)))
245 #define MCF548X_FEC_IEEE_R_FDXFC0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092DC)))
246 #define MCF548X_FEC_IEEE_R_OCTETS_OK0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092E0)))
247 #define MCF548X_FEC_EIR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009804)))
248 #define MCF548X_FEC_EIMR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009808)))
249 #define MCF548X_FEC_ECR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009824)))
250 #define MCF548X_FEC_MMFR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009840)))
251 #define MCF548X_FEC_MSCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009844)))
252 #define MCF548X_FEC_MIBC1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009864)))
253 #define MCF548X_FEC_RCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009884)))
254 #define MCF548X_FEC_R_HASH1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009888)))
255 #define MCF548X_FEC_TCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0098C4)))
256 #define MCF548X_FEC_PALR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0098E4)))
257 #define MCF548X_FEC_PAUR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0098E8)))
258 #define MCF548X_FEC_OPD1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0098EC)))
259 #define MCF548X_FEC_IAUR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009918)))
260 #define MCF548X_FEC_IALR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00991C)))
261 #define MCF548X_FEC_GAUR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009920)))
262 #define MCF548X_FEC_GALR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009924)))
263 #define MCF548X_FEC_FECTFWR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009944)))
264 #define MCF548X_FEC_FECRFDR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009984)))
265 #define MCF548X_FEC_FECRFSR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009988)))
266 #define MCF548X_FEC_FECRFCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00998C)))
267 #define MCF548X_FEC_FECRLRFP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009990)))
268 #define MCF548X_FEC_FECRLWFP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009994)))
269 #define MCF548X_FEC_FECRFAR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009998)))
270 #define MCF548X_FEC_FECRFRP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00999C)))
271 #define MCF548X_FEC_FECRFWP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099A0)))
272 #define MCF548X_FEC_FECTFDR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099A4)))
273 #define MCF548X_FEC_FECTFSR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099A8)))
274 #define MCF548X_FEC_FECTFCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099AC)))
275 #define MCF548X_FEC_FECTLRFP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099B0)))
276 #define MCF548X_FEC_FECTLWFP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099B4)))
277 #define MCF548X_FEC_FECTFAR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099B8)))
278 #define MCF548X_FEC_FECTFRP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099BC)))
279 #define MCF548X_FEC_FECTFWP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099C0)))
280 #define MCF548X_FEC_FRST1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099C4)))
281 #define MCF548X_FEC_CTCWR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0099C8)))
282 #define MCF548X_FEC_RMON_T_DROP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A00)))
283 #define MCF548X_FEC_RMON_T_PACKETS1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A04)))
284 #define MCF548X_FEC_RMON_T_BC_PKT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A08)))
285 #define MCF548X_FEC_RMON_T_MC_PKT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A0C)))
286 #define MCF548X_FEC_RMON_T_CRC_ALIGN1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A10)))
287 #define MCF548X_FEC_RMON_T_UNDERSIZE1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A14)))
288 #define MCF548X_FEC_RMON_T_OVERSIZE1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A18)))
289 #define MCF548X_FEC_RMON_T_FRAG1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A1C)))
290 #define MCF548X_FEC_RMON_T_JAB1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A20)))
291 #define MCF548X_FEC_RMON_T_COL1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A24)))
292 #define MCF548X_FEC_RMON_T_P641 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A28)))
293 #define MCF548X_FEC_RMON_T_P65TO1271 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A2C)))
294 #define MCF548X_FEC_RMON_T_P128TO2551 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A30)))
295 #define MCF548X_FEC_RMON_T_P256TO5111 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A34)))
296 #define MCF548X_FEC_RMON_T_P512TO10231 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A38)))
297 #define MCF548X_FEC_RMON_T_P1024TO20471 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A3C)))
298 #define MCF548X_FEC_RMON_T_P_GTE20481 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A40)))
299 #define MCF548X_FEC_RMON_T_OCTETS1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A44)))
300 #define MCF548X_FEC_IEEE_T_DROP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A48)))
301 #define MCF548X_FEC_IEEE_T_FRAME_OK1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A4C)))
302 #define MCF548X_FEC_IEEE_T_1COL1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A50)))
303 #define MCF548X_FEC_IEEE_T_MCOL1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A54)))
304 #define MCF548X_FEC_IEEE_T_DEF1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A58)))
305 #define MCF548X_FEC_IEEE_T_LCOL1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A5C)))
306 #define MCF548X_FEC_IEEE_T_EXCOL1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A60)))
307 #define MCF548X_FEC_IEEE_T_MACERR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A64)))
308 #define MCF548X_FEC_IEEE_T_CSERR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A68)))
309 #define MCF548X_FEC_IEEE_T_SQE1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A6C)))
310 #define MCF548X_FEC_IEEE_T_FDXFC1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A70)))
311 #define MCF548X_FEC_IEEE_T_OCTETS_OK1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A74)))
312 #define MCF548X_FEC_RMON_R_PACKETS1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A84)))
313 #define MCF548X_FEC_RMON_R_BC_PKT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A88)))
314 #define MCF548X_FEC_RMON_R_MC_PKT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A8C)))
315 #define MCF548X_FEC_RMON_R_CRC_ALIGN1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A90)))
316 #define MCF548X_FEC_RMON_R_UNDERSIZE1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A94)))
317 #define MCF548X_FEC_RMON_R_OVERSIZE1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A98)))
318 #define MCF548X_FEC_RMON_R_FRAG1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009A9C)))
319 #define MCF548X_FEC_RMON_R_JAB1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AA0)))
320 #define MCF548X_FEC_RMON_R_RESVD_01 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AA4)))
321 #define MCF548X_FEC_RMON_R_P641 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AA8)))
322 #define MCF548X_FEC_RMON_R_P65TO1271 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AAC)))
323 #define MCF548X_FEC_RMON_R_P128TO2551 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AB0)))
324 #define MCF548X_FEC_RMON_R_P256TO5111 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AB4)))
325 #define MCF548X_FEC_RMON_R_512TO10231 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AB8)))
326 #define MCF548X_FEC_RMON_R_1024TO20471 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009ABC)))
327 #define MCF548X_FEC_RMON_R_P_GTE20481 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AC0)))
328 #define MCF548X_FEC_RMON_R_OCTETS1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AC4)))
329 #define MCF548X_FEC_IEEE_R_DROP1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AC8)))
330 #define MCF548X_FEC_IEEE_R_FRAME_OK1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009ACC)))
331 #define MCF548X_FEC_IEEE_R_CRC1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AD0)))
332 #define MCF548X_FEC_IEEE_R_ALIGN1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AD4)))
333 #define MCF548X_FEC_IEEE_R_MACERR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AD8)))
334 #define MCF548X_FEC_IEEE_R_FDXFC1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009ADC)))
335 #define MCF548X_FEC_IEEE_R_OCTETS_OK1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009AE0)))
336 #define MCF548X_FEC_EIR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009004U+((x)*0x800))))
337 #define MCF548X_FEC_EIMR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009008U+((x)*0x800))))
338 #define MCF548X_FEC_ECR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009024U+((x)*0x800))))
339 #define MCF548X_FEC_MMFR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009040U+((x)*0x800))))
340 #define MCF548X_FEC_MSCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009044U+((x)*0x800))))
341 #define MCF548X_FEC_MIBC(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009064U+((x)*0x800))))
342 #define MCF548X_FEC_RCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009084U+((x)*0x800))))
343 #define MCF548X_FEC_R_HASH(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009088U+((x)*0x800))))
344 #define MCF548X_FEC_TCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090C4U+((x)*0x800))))
345 #define MCF548X_FEC_PALR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090E4U+((x)*0x800))))
346 #define MCF548X_FEC_PAUR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090E8U+((x)*0x800))))
347 #define MCF548X_FEC_OPD(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0090ECU+((x)*0x800))))
348 #define MCF548X_FEC_IAUR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009118U+((x)*0x800))))
349 #define MCF548X_FEC_IALR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00911CU+((x)*0x800))))
350 #define MCF548X_FEC_GAUR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009120U+((x)*0x800))))
351 #define MCF548X_FEC_GALR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009124U+((x)*0x800))))
352 #define MCF548X_FEC_FECTFWR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009144U+((x)*0x800))))
353 #define MCF548X_FEC_FECRFDR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009184U+((x)*0x800))))
354 #define MCF548X_FEC_FECRFSR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009188U+((x)*0x800))))
355 #define MCF548X_FEC_FECRFCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00918CU+((x)*0x800))))
356 #define MCF548X_FEC_FECRLRFP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009190U+((x)*0x800))))
357 #define MCF548X_FEC_FECRLWFP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009194U+((x)*0x800))))
358 #define MCF548X_FEC_FECRFAR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009198U+((x)*0x800))))
359 #define MCF548X_FEC_FECRFRP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00919CU+((x)*0x800))))
360 #define MCF548X_FEC_FECRFWP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091A0U+((x)*0x800))))
361 #define MCF548X_FEC_FECTFDR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091A4U+((x)*0x800))))
362 #define MCF548X_FEC_FECTFSR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091A8U+((x)*0x800))))
363 #define MCF548X_FEC_FECTFCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091ACU+((x)*0x800))))
364 #define MCF548X_FEC_FECTLRFP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091B0U+((x)*0x800))))
365 #define MCF548X_FEC_FECTLWFP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091B4U+((x)*0x800))))
366 #define MCF548X_FEC_FECTFAR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091B8U+((x)*0x800))))
367 #define MCF548X_FEC_FECTFRP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091BCU+((x)*0x800))))
368 #define MCF548X_FEC_FECTFWP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091C0U+((x)*0x800))))
369 #define MCF548X_FEC_FRST(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091C4U+((x)*0x800))))
370 #define MCF548X_FEC_CTCWR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0091C8U+((x)*0x800))))
371 #define MCF548X_FEC_RMON_T_DROP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009200U+((x)*0x800))))
372 #define MCF548X_FEC_RMON_T_PACKETS(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009204U+((x)*0x800))))
373 #define MCF548X_FEC_RMON_T_BC_PKT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009208U+((x)*0x800))))
374 #define MCF548X_FEC_RMON_T_MC_PKT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00920CU+((x)*0x800))))
375 #define MCF548X_FEC_RMON_T_CRC_ALIGN(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009210U+((x)*0x800))))
376 #define MCF548X_FEC_RMON_T_UNDERSIZE(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009214U+((x)*0x800))))
377 #define MCF548X_FEC_RMON_T_OVERSIZE(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009218U+((x)*0x800))))
378 #define MCF548X_FEC_RMON_T_FRAG(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00921CU+((x)*0x800))))
379 #define MCF548X_FEC_RMON_T_JAB(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009220U+((x)*0x800))))
380 #define MCF548X_FEC_RMON_T_COL(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009224U+((x)*0x800))))
381 #define MCF548X_FEC_RMON_T_P64(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009228U+((x)*0x800))))
382 #define MCF548X_FEC_RMON_T_P65TO127(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00922CU+((x)*0x800))))
383 #define MCF548X_FEC_RMON_T_P128TO255(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009230U+((x)*0x800))))
384 #define MCF548X_FEC_RMON_T_P256TO511(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009234U+((x)*0x800))))
385 #define MCF548X_FEC_RMON_T_P512TO1023(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009238U+((x)*0x800))))
386 #define MCF548X_FEC_RMON_T_P1024TO2047(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00923CU+((x)*0x800))))
387 #define MCF548X_FEC_RMON_T_P_GTE2048(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009240U+((x)*0x800))))
388 #define MCF548X_FEC_RMON_T_OCTETS(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009244U+((x)*0x800))))
389 #define MCF548X_FEC_IEEE_T_DROP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009248U+((x)*0x800))))
390 #define MCF548X_FEC_IEEE_T_FRAME_OK(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00924CU+((x)*0x800))))
391 #define MCF548X_FEC_IEEE_T_1COL(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009250U+((x)*0x800))))
392 #define MCF548X_FEC_IEEE_T_MCOL(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009254U+((x)*0x800))))
393 #define MCF548X_FEC_IEEE_T_DEF(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009258U+((x)*0x800))))
394 #define MCF548X_FEC_IEEE_T_LCOL(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00925CU+((x)*0x800))))
395 #define MCF548X_FEC_IEEE_T_EXCOL(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009260U+((x)*0x800))))
396 #define MCF548X_FEC_IEEE_T_MACERR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009264U+((x)*0x800))))
397 #define MCF548X_FEC_IEEE_T_CSERR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009268U+((x)*0x800))))
398 #define MCF548X_FEC_IEEE_T_SQE(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00926CU+((x)*0x800))))
399 #define MCF548X_FEC_IEEE_T_FDXFC(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009270U+((x)*0x800))))
400 #define MCF548X_FEC_IEEE_T_OCTETS_OK(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009274U+((x)*0x800))))
401 #define MCF548X_FEC_RMON_R_PACKETS(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009284U+((x)*0x800))))
402 #define MCF548X_FEC_RMON_R_BC_PKT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009288U+((x)*0x800))))
403 #define MCF548X_FEC_RMON_R_MC_PKT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00928CU+((x)*0x800))))
404 #define MCF548X_FEC_RMON_R_CRC_ALIGN(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009290U+((x)*0x800))))
405 #define MCF548X_FEC_RMON_R_UNDERSIZE(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009294U+((x)*0x800))))
406 #define MCF548X_FEC_RMON_R_OVERSIZE(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x009298U+((x)*0x800))))
407 #define MCF548X_FEC_RMON_R_FRAG(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00929CU+((x)*0x800))))
408 #define MCF548X_FEC_RMON_R_JAB(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092A0U+((x)*0x800))))
409 #define MCF548X_FEC_RMON_R_RESVD_0(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092A4U+((x)*0x800))))
410 #define MCF548X_FEC_RMON_R_P64(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092A8U+((x)*0x800))))
411 #define MCF548X_FEC_RMON_R_P65TO127(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092ACU+((x)*0x800))))
412 #define MCF548X_FEC_RMON_R_P128TO255(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092B0U+((x)*0x800))))
413 #define MCF548X_FEC_RMON_R_P256TO511(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092B4U+((x)*0x800))))
414 #define MCF548X_FEC_RMON_R_512TO1023(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092B8U+((x)*0x800))))
415 #define MCF548X_FEC_RMON_R_1024TO2047(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092BCU+((x)*0x800))))
416 #define MCF548X_FEC_RMON_R_P_GTE2048(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092C0U+((x)*0x800))))
417 #define MCF548X_FEC_RMON_R_OCTETS(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092C4U+((x)*0x800))))
418 #define MCF548X_FEC_IEEE_R_DROP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092C8U+((x)*0x800))))
419 #define MCF548X_FEC_IEEE_R_FRAME_OK(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092CCU+((x)*0x800))))
420 #define MCF548X_FEC_IEEE_R_CRC(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092D0U+((x)*0x800))))
421 #define MCF548X_FEC_IEEE_R_ALIGN(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092D4U+((x)*0x800))))
422 #define MCF548X_FEC_IEEE_R_MACERR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092D8U+((x)*0x800))))
423 #define MCF548X_FEC_IEEE_R_FDXFC(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092DCU+((x)*0x800))))
424 #define MCF548X_FEC_IEEE_R_OCTETS_OK(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0092E0U+((x)*0x800))))
425
426 /* Bit definitions and macros for MCF548X_FEC_EIR */
427 #define MCF548X_FEC_EIR_RFERR (0x00020000)
428 #define MCF548X_FEC_EIR_XFERR (0x00040000)
429 #define MCF548X_FEC_EIR_XFUN (0x00080000)
430 #define MCF548X_FEC_EIR_RL (0x00100000)
431 #define MCF548X_FEC_EIR_LC (0x00200000)
432 #define MCF548X_FEC_EIR_MII (0x00800000)
433 #define MCF548X_FEC_EIR_TXF (0x08000000)
434 #define MCF548X_FEC_EIR_GRA (0x10000000)
435 #define MCF548X_FEC_EIR_BABT (0x20000000)
436 #define MCF548X_FEC_EIR_BABR (0x40000000)
437 #define MCF548X_FEC_EIR_HBERR (0x80000000)
438 #define MCF548X_FEC_EIR_CLEAR_ALL (0xFFFFFFFF)
439
440 /* Bit definitions and macros for MCF548X_FEC_EIMR */
441 #define MCF548X_FEC_EIMR_RFERR (0x00020000)
442 #define MCF548X_FEC_EIMR_XFERR (0x00040000)
443 #define MCF548X_FEC_EIMR_XFUN (0x00080000)
444 #define MCF548X_FEC_EIMR_RL (0x00100000)
445 #define MCF548X_FEC_EIMR_LC (0x00200000)
446 #define MCF548X_FEC_EIMR_MII (0x00800000)
447 #define MCF548X_FEC_EIMR_TXF (0x08000000)
448 #define MCF548X_FEC_EIMR_GRA (0x10000000)
449 #define MCF548X_FEC_EIMR_BABT (0x20000000)
450 #define MCF548X_FEC_EIMR_BABR (0x40000000)
451 #define MCF548X_FEC_EIMR_HBERR (0x80000000)
452 #define MCF548X_FEC_EIMR_MASK_ALL (0x00000000)
453 #define MCF548X_FEC_EIMR_UNMASK_ALL (0xFFFFFFFF)
454
455 /* Bit definitions and macros for MCF548X_FEC_ECR */
456 #define MCF548X_FEC_ECR_RESET (0x00000001)
457 #define MCF548X_FEC_ECR_ETHER_EN (0x00000002)
458
459 /* Bit definitions and macros for MCF548X_FEC_MMFR */
460 #define MCF548X_FEC_MMFR_DATA(x) (((x)&0x0000FFFF)<<0)
461 #define MCF548X_FEC_MMFR_TA(x) (((x)&0x00000003)<<16)
462 #define MCF548X_FEC_MMFR_RA(x) (((x)&0x0000001F)<<18)
463 #define MCF548X_FEC_MMFR_PA(x) (((x)&0x0000001F)<<23)
464 #define MCF548X_FEC_MMFR_OP(x) (((x)&0x00000003)<<28)
465 #define MCF548X_FEC_MMFR_ST(x) (((x)&0x00000003)<<30)
466 #define MCF548X_FEC_MMFR_ST_01 (0x40000000)
467 #define MCF548X_FEC_MMFR_OP_READ (0x20000000)
468 #define MCF548X_FEC_MMFR_OP_WRITE (0x10000000)
469 #define MCF548X_FEC_MMFR_TA_10 (0x00020000)
470
471 /* Bit definitions and macros for MCF548X_FEC_MSCR */
472 #define MCF548X_FEC_MSCR_MII_SPEED(x) (((x)&0x0000003F)<<1)
473 #define MCF548X_FEC_MSCR_DIS_PREAMBLE (0x00000080)
474 #define MCF548X_FEC_MSCR_MII_SPEED_133 (0x1B<<1)
475 #define MCF548X_FEC_MSCR_MII_SPEED_120 (0x18<<1)
476 #define MCF548X_FEC_MSCR_MII_SPEED_66 (0xE<<1)
477 #define MCF548X_FEC_MSCR_MII_SPEED_60 (0xC<<1)
478
479 /* Bit definitions and macros for MCF548X_FEC_MIBC */
480 #define MCF548X_FEC_MIBC_MIB_IDLE (0x40000000)
481 #define MCF548X_FEC_MIBC_MIB_DISABLE (0x80000000)
482
483 /* Bit definitions and macros for MCF548X_FEC_RCR */
484 #define MCF548X_FEC_RCR_LOOP (0x00000001)
485 #define MCF548X_FEC_RCR_DRT (0x00000002)
486 #define MCF548X_FEC_RCR_MII_MODE (0x00000004)
487 #define MCF548X_FEC_RCR_PROM (0x00000008)
488 #define MCF548X_FEC_RCR_BC_REJ (0x00000010)
489 #define MCF548X_FEC_RCR_FCE (0x00000020)
490 #define MCF548X_FEC_RCR_MAX_FL(x) (((x)&0x000007FF)<<16)
491
492 /* Bit definitions and macros for MCF548X_FEC_R_HASH */
493 #define MCF548X_FEC_R_HASH_HASH(x) (((x)&0x0000003F)<<24)
494 #define MCF548X_FEC_R_HASH_MULTCAST (0x40000000)
495 #define MCF548X_FEC_R_HASH_FCE_DC (0x80000000)
496
497 /* Bit definitions and macros for MCF548X_FEC_TCR */
498 #define MCF548X_FEC_TCR_GTS (0x00000001)
499 #define MCF548X_FEC_TCR_HBC (0x00000002)
500 #define MCF548X_FEC_TCR_FDEN (0x00000004)
501 #define MCF548X_FEC_TCR_TFC_PAUSE (0x00000008)
502 #define MCF548X_FEC_TCR_RFC_PAUSE (0x00000010)
503
504 /* Bit definitions and macros for MCF548X_FEC_PAUR */
505 #define MCF548X_FEC_PAUR_TYPE(x) (((x)&0x0000FFFF)<<0)
506 #define MCF548X_FEC_PAUR_PADDR2(x) (((x)&0x0000FFFF)<<16)
507
508 /* Bit definitions and macros for MCF548X_FEC_OPD */
509 #define MCF548X_FEC_OPD_OP_PAUSE(x) (((x)&0x0000FFFF)<<0)
510 #define MCF548X_FEC_OPD_OPCODE(x) (((x)&0x0000FFFF)<<16)
511
512 /* Bit definitions and macros for MCF548X_FEC_FECTFWR */
513 #define MCF548X_FEC_FECTFWR_X_WMRK(x) (((x)&0x0000000F)<<0)
514 #define MCF548X_FEC_FECTFWR_X_WMRK_64 (0x00000000)
515 #define MCF548X_FEC_FECTFWR_X_WMRK_128 (0x00000001)
516 #define MCF548X_FEC_FECTFWR_X_WMRK_192 (0x00000002)
517 #define MCF548X_FEC_FECTFWR_X_WMRK_256 (0x00000003)
518 #define MCF548X_FEC_FECTFWR_X_WMRK_320 (0x00000004)
519 #define MCF548X_FEC_FECTFWR_X_WMRK_384 (0x00000005)
520 #define MCF548X_FEC_FECTFWR_X_WMRK_448 (0x00000006)
521 #define MCF548X_FEC_FECTFWR_X_WMRK_512 (0x00000007)
522 #define MCF548X_FEC_FECTFWR_X_WMRK_576 (0x00000008)
523 #define MCF548X_FEC_FECTFWR_X_WMRK_640 (0x00000009)
524 #define MCF548X_FEC_FECTFWR_X_WMRK_704 (0x0000000A)
525 #define MCF548X_FEC_FECTFWR_X_WMRK_768 (0x0000000B)
526 #define MCF548X_FEC_FECTFWR_X_WMRK_832 (0x0000000C)
527 #define MCF548X_FEC_FECTFWR_X_WMRK_896 (0x0000000D)
528 #define MCF548X_FEC_FECTFWR_X_WMRK_960 (0x0000000E)
529 #define MCF548X_FEC_FECTFWR_X_WMRK_1024 (0x0000000F)
530
531 /* Bit definitions and macros for MCF548X_FEC_FECRFDR */
532 #define MCF548X_FEC_FECRFDR_ADDR0 (((uintptr_t)__MBAR + (0x009184)))
533 #define MCF548X_FEC_FECRFDR_ADDR1 (((uintptr_t)__MBAR + (0x009984)))
534 #define MCF548X_FEC_FECRFDR_ADDR(x) (((uintptr_t)__MBAR + (0x009184U+(0x800*x))))
535
536 /* Bit definitions and macros for MCF548X_FEC_FECRFSR */
537 #define MCF548X_FEC_FECRFSR_EMT (0x00010000)
538 #define MCF548X_FEC_FECRFSR_ALARM (0x00020000)
539 #define MCF548X_FEC_FECRFSR_FU (0x00040000)
540 #define MCF548X_FEC_FECRFSR_FR (0x00080000)
541 #define MCF548X_FEC_FECRFSR_OF (0x00100000)
542 #define MCF548X_FEC_FECRFSR_UF (0x00200000)
543 #define MCF548X_FEC_FECRFSR_RXW (0x00400000)
544 #define MCF548X_FEC_FECRFSR_FAE (0x00800000)
545 #define MCF548X_FEC_FECRFSR_FRM(x) (((x)&0x0000000F)<<24)
546 #define MCF548X_FEC_FECRFSR_IP (0x80000000)
547
548 /* Bit definitions and macros for MCF548X_FEC_FECRFCR */
549 #define MCF548X_FEC_FECRFCR_COUNTER(x) (((x)&0x0000FFFF)<<0)
550 #define MCF548X_FEC_FECRFCR_OF_MSK (0x00080000)
551 #define MCF548X_FEC_FECRFCR_UF_MSK (0x00100000)
552 #define MCF548X_FEC_FECRFCR_RXW_MSK (0x00200000)
553 #define MCF548X_FEC_FECRFCR_FAE_MSK (0x00400000)
554 #define MCF548X_FEC_FECRFCR_IP_MSK (0x00800000)
555 #define MCF548X_FEC_FECRFCR_GR(x) (((x)&0x00000007)<<24)
556 #define MCF548X_FEC_FECRFCR_FRM (0x08000000)
557 #define MCF548X_FEC_FECRFCR_TIMER (0x10000000)
558 #define MCF548X_FEC_FECRFCR_WFR (0x20000000)
559 #define MCF548X_FEC_FECRFCR_WCTL (0x40000000)
560
561 /* Bit definitions and macros for MCF548X_FEC_FECRLRFP */
562 #define MCF548X_FEC_FECRLRFP_LRFP(x) (((x)&0x00000FFF)<<0)
563
564 /* Bit definitions and macros for MCF548X_FEC_FECRLWFP */
565 #define MCF548X_FEC_FECRLWFP_LWFP(x) (((x)&0x00000FFF)<<0)
566
567 /* Bit definitions and macros for MCF548X_FEC_FECRFAR */
568 #define MCF548X_FEC_FECRFAR_ALARM(x) (((x)&0x00000FFF)<<0)
569
570 /* Bit definitions and macros for MCF548X_FEC_FECRFRP */
571 #define MCF548X_FEC_FECRFRP_READ(x) (((x)&0x00000FFF)<<0)
572
573 /* Bit definitions and macros for MCF548X_FEC_FECRFWP */
574 #define MCF548X_FEC_FECRFWP_WRITE(x) (((x)&0x00000FFF)<<0)
575
576 /* Bit definitions and macros for MCF548X_FEC_FECTFDR */
577 #define MCF548X_FEC_FECTFDR_TFCW_TC (0x04000000)
578 #define MCF548X_FEC_FECTFDR_TFCW_ABC (0x02000000)
579 #define MCF548X_FEC_FECTFDR_ADDR0 (((uintptr_t)__MBAR + (0x0091A4)))
580 #define MCF548X_FEC_FECTFDR_ADDR1 (((uintptr_t)__MBAR + (0x0099A4)))
581 #define MCF548X_FEC_FECTFDR_ADDR(x) (((uintptr_t)__MBAR + (0x0091A4U+(0x800*x))))
582
583 /* Bit definitions and macros for MCF548X_FEC_FECTFSR */
584 #define MCF548X_FEC_FECTFSR_EMT (0x00010000)
585 #define MCF548X_FEC_FECTFSR_ALARM (0x00020000)
586 #define MCF548X_FEC_FECTFSR_FU (0x00040000)
587 #define MCF548X_FEC_FECTFSR_FR (0x00080000)
588 #define MCF548X_FEC_FECTFSR_OF (0x00100000)
589 #define MCF548X_FEC_FECTFSR_UP (0x00200000)
590 #define MCF548X_FEC_FECTFSR_FAE (0x00800000)
591 #define MCF548X_FEC_FECTFSR_FRM(x) (((x)&0x0000000F)<<24)
592 #define MCF548X_FEC_FECTFSR_TXW (0x40000000)
593 #define MCF548X_FEC_FECTFSR_IP (0x80000000)
594
595 /* Bit definitions and macros for MCF548X_FEC_FECTFCR */
596 #define MCF548X_FEC_FECTFCR_RESERVED (0x00200000)
597 #define MCF548X_FEC_FECTFCR_COUNTER(x) (((x)&0x0000FFFF)<<0|0x00200000)
598 #define MCF548X_FEC_FECTFCR_TXW_MSK (0x00240000)
599 #define MCF548X_FEC_FECTFCR_OF_MSK (0x00280000)
600 #define MCF548X_FEC_FECTFCR_UF_MSK (0x00300000)
601 #define MCF548X_FEC_FECTFCR_FAE_MSK (0x00600000)
602 #define MCF548X_FEC_FECTFCR_IP_MSK (0x00A00000)
603 #define MCF548X_FEC_FECTFCR_GR(x) (((x)&0x00000007)<<24|0x00200000)
604 #define MCF548X_FEC_FECTFCR_FRM (0x08200000)
605 #define MCF548X_FEC_FECTFCR_TIMER (0x10200000)
606 #define MCF548X_FEC_FECTFCR_WFR (0x20200000)
607 #define MCF548X_FEC_FECTFCR_WCTL (0x40200000)
608
609 /* Bit definitions and macros for MCF548X_FEC_FECTLRFP */
610 #define MCF548X_FEC_FECTLRFP_LRFP(x) (((x)&0x00000FFF)<<0)
611
612 /* Bit definitions and macros for MCF548X_FEC_FECTLWFP */
613 #define MCF548X_FEC_FECTLWFP_LWFP(x) (((x)&0x00000FFF)<<0)
614
615 /* Bit definitions and macros for MCF548X_FEC_FECTFAR */
616 #define MCF548X_FEC_FECTFAR_ALARM(x) (((x)&0x00000FFF)<<0)
617
618 /* Bit definitions and macros for MCF548X_FEC_FECTFRP */
619 #define MCF548X_FEC_FECTFRP_READ(x) (((x)&0x00000FFF)<<0)
620
621 /* Bit definitions and macros for MCF548X_FEC_FECTFWP */
622 #define MCF548X_FEC_FECTFWP_WRITE(x) (((x)&0x00000FFF)<<0)
623
624 /* Bit definitions and macros for MCF548X_FEC_FRST */
625 #define MCF548X_FEC_FRST_RST_CTL (0x01000000)
626 #define MCF548X_FEC_FRST_SW_RST (0x02000000)
627
628 /* Bit definitions and macros for MCF548X_FEC_CTCWR */
629 #define MCF548X_FEC_CTCWR_TFCW (0x01000000)
630 #define MCF548X_FEC_CTCWR_CRC (0x02000000)
631
632
633 /*********************************************************************
634 *
635 * System Integration Unit (SIU)
636 *
637 *********************************************************************/
638
639 /* Register read/write macros */
640 #define MCF548X_SIU_SBCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000010)))
641 #define MCF548X_SIU_SECSACR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000038)))
642 #define MCF548X_SIU_RSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000044)))
643 #define MCF548X_SIU_JTAGID (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000050)))
644
645 /* Bit definitions and macros for MCF548X_SIU_SBCR */
646 #define MCF548X_SIU_SBCR_PIN2DSPI (0x08000000)
647 #define MCF548X_SIU_SBCR_DMA2CPU (0x10000000)
648 #define MCF548X_SIU_SBCR_CPU2DMA (0x20000000)
649 #define MCF548X_SIU_SBCR_PIN2DMA (0x40000000)
650 #define MCF548X_SIU_SBCR_PIN2CPU (0x80000000)
651
652 /* Bit definitions and macros for MCF548X_SIU_SECSACR */
653 #define MCF548X_SIU_SECSACR_SEQEN (0x00000001)
654
655 /* Bit definitions and macros for MCF548X_SIU_RSR */
656 #define MCF548X_SIU_RSR_RST (0x00000001)
657 #define MCF548X_SIU_RSR_RSTWD (0x00000002)
658 #define MCF548X_SIU_RSR_RSTJTG (0x00000008)
659
660 /* Bit definitions and macros for MCF548X_SIU_JTAGID */
661 #define MCF548X_SIU_JTAGID_REV (0xF0000000)
662 #define MCF548X_SIU_JTAGID_PROCESSOR (0x0FFFFFFF)
663 #define MCF548X_SIU_JTAGID_MCF5485 (0x0800C01D)
664 #define MCF548X_SIU_JTAGID_MCF5484 (0x0800D01D)
665 #define MCF548X_SIU_JTAGID_MCF5483 (0x0800E01D)
666 #define MCF548X_SIU_JTAGID_MCF5482 (0x0800F01D)
667 #define MCF548X_SIU_JTAGID_MCF5481 (0x0801001D)
668 #define MCF548X_SIU_JTAGID_MCF5480 (0x0801101D)
669 #define MCF548X_SIU_JTAGID_MCF5475 (0x0801201D)
670 #define MCF548X_SIU_JTAGID_MCF5474 (0x0801301D)
671 #define MCF548X_SIU_JTAGID_MCF5473 (0x0801401D)
672 #define MCF548X_SIU_JTAGID_MCF5472 (0x0801501D)
673 #define MCF548X_SIU_JTAGID_MCF5471 (0x0801601D)
674 #define MCF548X_SIU_JTAGID_MCF5470 (0x0801701D)
675
676 /*********************************************************************
677 *
678 * Comm Timer Module (CTM)
679 *
680 *********************************************************************/
681
682 /* Register read/write macros */
683 #define MCF548X_CTM_CTCRF0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F00)))
684 #define MCF548X_CTM_CTCRF1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F04)))
685 #define MCF548X_CTM_CTCRF2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F08)))
686 #define MCF548X_CTM_CTCRF3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F0C)))
687 #define MCF548X_CTM_CTCRFn(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F00U+((x)*0x004))))
688 #define MCF548X_CTM_CTCRV4 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F10)))
689 #define MCF548X_CTM_CTCRV5 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F14)))
690 #define MCF548X_CTM_CTCRV6 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F18)))
691 #define MCF548X_CTM_CTCRV7 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F1C)))
692 #define MCF548X_CTM_CTCRVn(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x007F10U+((x)*0x004))))
693
694 /* Bit definitions and macros for MCF548X_CTM_CTCRFn */
695 #define MCF548X_CTM_CTCRFn_CRV(x) (((x)&0x0000FFFF)<<0)
696 #define MCF548X_CTM_CTCRFn_S(x) (((x)&0x0000000F)<<16)
697 #define MCF548X_CTM_CTCRFn_PCT(x) (((x)&0x00000007)<<20)
698 #define MCF548X_CTM_CTCRFn_M (0x00800000)
699 #define MCF548X_CTM_CTCRFn_IM (0x01000000)
700 #define MCF548X_CTM_CTCRFn_I (0x80000000)
701 #define MCF548X_CTM_CTCRFn_PCT_100 (0x00000000)
702 #define MCF548X_CTM_CTCRFn_PCT_50 (0x00100000)
703 #define MCF548X_CTM_CTCRFn_PCT_25 (0x00200000)
704 #define MCF548X_CTM_CTCRFn_PCT_12p5 (0x00300000)
705 #define MCF548X_CTM_CTCRFn_PCT_6p25 (0x00400000)
706 #define MCF548X_CTM_CTCRFn_PCT_OFF (0x00500000)
707 #define MCF548X_CTM_CTCRFn_S_CLK_1 (0x00000000)
708 #define MCF548X_CTM_CTCRFn_S_CLK_2 (0x00010000)
709 #define MCF548X_CTM_CTCRFn_S_CLK_4 (0x00020000)
710 #define MCF548X_CTM_CTCRFn_S_CLK_8 (0x00030000)
711 #define MCF548X_CTM_CTCRFn_S_CLK_16 (0x00040000)
712 #define MCF548X_CTM_CTCRFn_S_CLK_32 (0x00050000)
713 #define MCF548X_CTM_CTCRFn_S_CLK_64 (0x00060000)
714 #define MCF548X_CTM_CTCRFn_S_CLK_128 (0x00070000)
715 #define MCF548X_CTM_CTCRFn_S_CLK_256 (0x00080000)
716
717 /* Bit definitions and macros for MCF548X_CTM_CTCRVn */
718 #define MCF548X_CTM_CTCRVn_CRV(x) (((x)&0x00FFFFFF)<<0)
719 #define MCF548X_CTM_CTCRVn_PCT(x) (((x)&0x00000007)<<24)
720 #define MCF548X_CTM_CTCRVn_M (0x08000000)
721 #define MCF548X_CTM_CTCRVn_S(x) (((x)&0x0000000F)<<28)
722 #define MCF548X_CTM_CTCRVn_S_CLK_1 (0x00000000)
723 #define MCF548X_CTM_CTCRVn_S_CLK_2 (0x10000000)
724 #define MCF548X_CTM_CTCRVn_S_CLK_4 (0x20000000)
725 #define MCF548X_CTM_CTCRVn_S_CLK_8 (0x30000000)
726 #define MCF548X_CTM_CTCRVn_S_CLK_16 (0x40000000)
727 #define MCF548X_CTM_CTCRVn_S_CLK_32 (0x50000000)
728 #define MCF548X_CTM_CTCRVn_S_CLK_64 (0x60000000)
729 #define MCF548X_CTM_CTCRVn_S_CLK_128 (0x70000000)
730 #define MCF548X_CTM_CTCRVn_S_CLK_256 (0x80000000)
731 #define MCF548X_CTM_CTCRVn_PCT_100 (0x00000000)
732 #define MCF548X_CTM_CTCRVn_PCT_50 (0x01000000)
733 #define MCF548X_CTM_CTCRVn_PCT_25 (0x02000000)
734 #define MCF548X_CTM_CTCRVn_PCT_12p5 (0x03000000)
735 #define MCF548X_CTM_CTCRVn_PCT_6p25 (0x04000000)
736 #define MCF548X_CTM_CTCRVn_PCT_OFF (0x05000000)
737
738 /*********************************************************************
739 *
740 * DMA Serial Peripheral Interface (DSPI)
741 *
742 *********************************************************************/
743
744 /* Register read/write macros */
745 #define MCF548X_DSPI_DMCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A00)))
746 #define MCF548X_DSPI_DTCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A08)))
747 #define MCF548X_DSPI_DCTAR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A0C)))
748 #define MCF548X_DSPI_DCTAR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A10)))
749 #define MCF548X_DSPI_DCTAR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A14)))
750 #define MCF548X_DSPI_DCTAR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A18)))
751 #define MCF548X_DSPI_DCTAR4 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A1C)))
752 #define MCF548X_DSPI_DCTAR5 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A20)))
753 #define MCF548X_DSPI_DCTAR6 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A24)))
754 #define MCF548X_DSPI_DCTAR7 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A28)))
755 #define MCF548X_DSPI_DCTARn(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A0CU+((x)*0x004))))
756 #define MCF548X_DSPI_DSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A2C)))
757 #define MCF548X_DSPI_DIRSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A30)))
758 #define MCF548X_DSPI_DTFR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A34)))
759 #define MCF548X_DSPI_DRFR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A38)))
760 #define MCF548X_DSPI_DTFDR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A3C)))
761 #define MCF548X_DSPI_DTFDR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A40)))
762 #define MCF548X_DSPI_DTFDR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A44)))
763 #define MCF548X_DSPI_DTFDR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A48)))
764 #define MCF548X_DSPI_DTFDRn(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A3CU+((x)*0x004))))
765 #define MCF548X_DSPI_DRFDR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A7C)))
766 #define MCF548X_DSPI_DRFDR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A80)))
767 #define MCF548X_DSPI_DRFDR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A84)))
768 #define MCF548X_DSPI_DRFDR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A88)))
769 #define MCF548X_DSPI_DRFDRn(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008A7CU+((x)*0x004))))
770
771 /* Bit definitions and macros for MCF548X_DSPI_DMCR */
772 #define MCF548X_DSPI_DMCR_HALT (0x00000001)
773 #define MCF548X_DSPI_DMCR_SMPL_PT(x) (((x)&0x00000003)<<8)
774 #define MCF548X_DSPI_DMCR_CRXF (0x00000400)
775 #define MCF548X_DSPI_DMCR_CTXF (0x00000800)
776 #define MCF548X_DSPI_DMCR_DRXF (0x00001000)
777 #define MCF548X_DSPI_DMCR_DTXF (0x00002000)
778 #define MCF548X_DSPI_DMCR_CSIS0 (0x00010000)
779 #define MCF548X_DSPI_DMCR_CSIS2 (0x00040000)
780 #define MCF548X_DSPI_DMCR_CSIS3 (0x00080000)
781 #define MCF548X_DSPI_DMCR_CSIS5 (0x00200000)
782 #define MCF548X_DSPI_DMCR_ROOE (0x01000000)
783 #define MCF548X_DSPI_DMCR_PCSSE (0x02000000)
784 #define MCF548X_DSPI_DMCR_MTFE (0x04000000)
785 #define MCF548X_DSPI_DMCR_FRZ (0x08000000)
786 #define MCF548X_DSPI_DMCR_DCONF(x) (((x)&0x00000003)<<28)
787 #define MCF548X_DSPI_DMCR_CSCK (0x40000000)
788 #define MCF548X_DSPI_DMCR_MSTR (0x80000000)
789
790 /* Bit definitions and macros for MCF548X_DSPI_DTCR */
791 #define MCF548X_DSPI_DTCR_SPI_TCNT(x) (((x)&0x0000FFFF)<<16)
792
793 /* Bit definitions and macros for MCF548X_DSPI_DCTARn */
794 #define MCF548X_DSPI_DCTARn_BR(x) (((x)&0x0000000F)<<0)
795 #define MCF548X_DSPI_DCTARn_DT(x) (((x)&0x0000000F)<<4)
796 #define MCF548X_DSPI_DCTARn_ASC(x) (((x)&0x0000000F)<<8)
797 #define MCF548X_DSPI_DCTARn_CSSCK(x) (((x)&0x0000000F)<<12)
798 #define MCF548X_DSPI_DCTARn_PBR(x) (((x)&0x00000003)<<16)
799 #define MCF548X_DSPI_DCTARn_PDT(x) (((x)&0x00000003)<<18)
800 #define MCF548X_DSPI_DCTARn_PASC(x) (((x)&0x00000003)<<20)
801 #define MCF548X_DSPI_DCTARn_PCSSCK(x) (((x)&0x00000003)<<22)
802 #define MCF548X_DSPI_DCTARn_LSBFE (0x01000000)
803 #define MCF548X_DSPI_DCTARn_CPHA (0x02000000)
804 #define MCF548X_DSPI_DCTARn_CPOL (0x04000000)
805 #define MCF548X_DSPI_DCTARn_TRSZ(x) (((x)&0x0000000F)<<27)
806 #define MCF548X_DSPI_DCTARn_PCSSCK_1CLK (0x00000000)
807 #define MCF548X_DSPI_DCTARn_PCSSCK_3CLK (0x00400000)
808 #define MCF548X_DSPI_DCTARn_PCSSCK_5CLK (0x00800000)
809 #define MCF548X_DSPI_DCTARn_PCSSCK_7CLK (0x00A00000)
810 #define MCF548X_DSPI_DCTARn_PASC_1CLK (0x00000000)
811 #define MCF548X_DSPI_DCTARn_PASC_3CLK (0x00100000)
812 #define MCF548X_DSPI_DCTARn_PASC_5CLK (0x00200000)
813 #define MCF548X_DSPI_DCTARn_PASC_7CLK (0x00300000)
814 #define MCF548X_DSPI_DCTARn_PDT_1CLK (0x00000000)
815 #define MCF548X_DSPI_DCTARn_PDT_3CLK (0x00040000)
816 #define MCF548X_DSPI_DCTARn_PDT_5CLK (0x00080000)
817 #define MCF548X_DSPI_DCTARn_PDT_7CLK (0x000A0000)
818 #define MCF548X_DSPI_DCTARn_PBR_1CLK (0x00000000)
819 #define MCF548X_DSPI_DCTARn_PBR_3CLK (0x00010000)
820 #define MCF548X_DSPI_DCTARn_PBR_5CLK (0x00020000)
821 #define MCF548X_DSPI_DCTARn_PBR_7CLK (0x00030000)
822
823 /* Bit definitions and macros for MCF548X_DSPI_DSR */
824 #define MCF548X_DSPI_DSR_RXPTR(x) (((x)&0x0000000F)<<0)
825 #define MCF548X_DSPI_DSR_RXCTR(x) (((x)&0x0000000F)<<4)
826 #define MCF548X_DSPI_DSR_TXPTR(x) (((x)&0x0000000F)<<8)
827 #define MCF548X_DSPI_DSR_TXCTR(x) (((x)&0x0000000F)<<12)
828 #define MCF548X_DSPI_DSR_RFDF (0x00020000)
829 #define MCF548X_DSPI_DSR_RFOF (0x00080000)
830 #define MCF548X_DSPI_DSR_TFFF (0x02000000)
831 #define MCF548X_DSPI_DSR_TFUF (0x08000000)
832 #define MCF548X_DSPI_DSR_EOQF (0x10000000)
833 #define MCF548X_DSPI_DSR_TXRXS (0x40000000)
834 #define MCF548X_DSPI_DSR_TCF (0x80000000)
835
836 /* Bit definitions and macros for MCF548X_DSPI_DIRSR */
837 #define MCF548X_DSPI_DIRSR_RFDFS (0x00010000)
838 #define MCF548X_DSPI_DIRSR_RFDFE (0x00020000)
839 #define MCF548X_DSPI_DIRSR_RFOFE (0x00080000)
840 #define MCF548X_DSPI_DIRSR_TFFFS (0x01000000)
841 #define MCF548X_DSPI_DIRSR_TFFFE (0x02000000)
842 #define MCF548X_DSPI_DIRSR_TFUFE (0x08000000)
843 #define MCF548X_DSPI_DIRSR_EOQFE (0x10000000)
844 #define MCF548X_DSPI_DIRSR_TCFE (0x80000000)
845
846 /* Bit definitions and macros for MCF548X_DSPI_DTFR */
847 #define MCF548X_DSPI_DTFR_TXDATA(x) (((x)&0x0000FFFF)<<0)
848 #define MCF548X_DSPI_DTFR_CS0 (0x00010000)
849 #define MCF548X_DSPI_DTFR_CS2 (0x00040000)
850 #define MCF548X_DSPI_DTFR_CS3 (0x00080000)
851 #define MCF548X_DSPI_DTFR_CS5 (0x00200000)
852 #define MCF548X_DSPI_DTFR_CTCNT (0x04000000)
853 #define MCF548X_DSPI_DTFR_EOQ (0x08000000)
854 #define MCF548X_DSPI_DTFR_CTAS(x) (((x)&0x00000007)<<28)
855 #define MCF548X_DSPI_DTFR_CONT (0x80000000)
856
857 /* Bit definitions and macros for MCF548X_DSPI_DRFR */
858 #define MCF548X_DSPI_DRFR_RXDATA(x) (((x)&0x0000FFFF)<<0)
859
860 /* Bit definitions and macros for MCF548X_DSPI_DTFDRn */
861 #define MCF548X_DSPI_DTFDRn_TXDATA(x) (((x)&0x0000FFFF)<<0)
862 #define MCF548X_DSPI_DTFDRn_TXCMD(x) (((x)&0x0000FFFF)<<16)
863
864 /* Bit definitions and macros for MCF548X_DSPI_DRFDRn */
865 #define MCF548X_DSPI_DRFDRn_RXDATA(x) (((x)&0x0000FFFF)<<0)
866
867
868 /*********************************************************************
869 *
870 * Edge Port Module (EPORT)
871 *
872 *********************************************************************/
873
874 /* Register read/write macros */
875 #define MCF548X_EPORT_EPPAR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x000F00)))
876 #define MCF548X_EPORT_EPDDR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000F04)))
877 #define MCF548X_EPORT_EPIER (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000F05)))
878 #define MCF548X_EPORT_EPDR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000F08)))
879 #define MCF548X_EPORT_EPPDR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000F09)))
880 #define MCF548X_EPORT_EPFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000F0C)))
881
882 /* Bit definitions and macros for MCF548X_EPORT_EPPAR */
883 #define MCF548X_EPORT_EPPAR_EPPA1(x) (((x)&0x0003)<<2)
884 #define MCF548X_EPORT_EPPAR_EPPA2(x) (((x)&0x0003)<<4)
885 #define MCF548X_EPORT_EPPAR_EPPA3(x) (((x)&0x0003)<<6)
886 #define MCF548X_EPORT_EPPAR_EPPA4(x) (((x)&0x0003)<<8)
887 #define MCF548X_EPORT_EPPAR_EPPA5(x) (((x)&0x0003)<<10)
888 #define MCF548X_EPORT_EPPAR_EPPA6(x) (((x)&0x0003)<<12)
889 #define MCF548X_EPORT_EPPAR_EPPA7(x) (((x)&0x0003)<<14)
890 #define MCF548X_EPORT_EPPAR_EPPAx_LEVEL (0)
891 #define MCF548X_EPORT_EPPAR_EPPAx_RISING (1)
892 #define MCF548X_EPORT_EPPAR_EPPAx_FALLING (2)
893 #define MCF548X_EPORT_EPPAR_EPPAx_BOTH (3)
894
895 /* Bit definitions and macros for MCF548X_EPORT_EPDDR */
896 #define MCF548X_EPORT_EPDDR_EPDD1 (0x02)
897 #define MCF548X_EPORT_EPDDR_EPDD2 (0x04)
898 #define MCF548X_EPORT_EPDDR_EPDD3 (0x08)
899 #define MCF548X_EPORT_EPDDR_EPDD4 (0x10)
900 #define MCF548X_EPORT_EPDDR_EPDD5 (0x20)
901 #define MCF548X_EPORT_EPDDR_EPDD6 (0x40)
902 #define MCF548X_EPORT_EPDDR_EPDD7 (0x80)
903
904 /* Bit definitions and macros for MCF548X_EPORT_EPIER */
905 #define MCF548X_EPORT_EPIER_EPIE1 (0x02)
906 #define MCF548X_EPORT_EPIER_EPIE2 (0x04)
907 #define MCF548X_EPORT_EPIER_EPIE3 (0x08)
908 #define MCF548X_EPORT_EPIER_EPIE4 (0x10)
909 #define MCF548X_EPORT_EPIER_EPIE5 (0x20)
910 #define MCF548X_EPORT_EPIER_EPIE6 (0x40)
911 #define MCF548X_EPORT_EPIER_EPIE7 (0x80)
912
913 /* Bit definitions and macros for MCF548X_EPORT_EPDR */
914 #define MCF548X_EPORT_EPDR_EPD1 (0x02)
915 #define MCF548X_EPORT_EPDR_EPD2 (0x04)
916 #define MCF548X_EPORT_EPDR_EPD3 (0x08)
917 #define MCF548X_EPORT_EPDR_EPD4 (0x10)
918 #define MCF548X_EPORT_EPDR_EPD5 (0x20)
919 #define MCF548X_EPORT_EPDR_EPD6 (0x40)
920 #define MCF548X_EPORT_EPDR_EPD7 (0x80)
921
922 /* Bit definitions and macros for MCF548X_EPORT_EPPDR */
923 #define MCF548X_EPORT_EPPDR_EPPD1 (0x02)
924 #define MCF548X_EPORT_EPPDR_EPPD2 (0x04)
925 #define MCF548X_EPORT_EPPDR_EPPD3 (0x08)
926 #define MCF548X_EPORT_EPPDR_EPPD4 (0x10)
927 #define MCF548X_EPORT_EPPDR_EPPD5 (0x20)
928 #define MCF548X_EPORT_EPPDR_EPPD6 (0x40)
929 #define MCF548X_EPORT_EPPDR_EPPD7 (0x80)
930
931 /* Bit definitions and macros for MCF548X_EPORT_EPFR */
932 #define MCF548X_EPORT_EPFR_EPF1 (0x02)
933 #define MCF548X_EPORT_EPFR_EPF2 (0x04)
934 #define MCF548X_EPORT_EPFR_EPF3 (0x08)
935 #define MCF548X_EPORT_EPFR_EPF4 (0x10)
936 #define MCF548X_EPORT_EPFR_EPF5 (0x20)
937 #define MCF548X_EPORT_EPFR_EPF6 (0x40)
938 #define MCF548X_EPORT_EPFR_EPF7 (0x80)
939
940 /*********************************************************************
941 *
942 * FlexBus Chip Selects (FBCS)
943 *
944 *********************************************************************/
945
946 /* Register read/write macros */
947 #define MCF548X_FBCS_CSAR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000500)))
948 #define MCF548X_FBCS_CSMR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000504)))
949 #define MCF548X_FBCS_CSCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000508)))
950 #define MCF548X_FBCS_CSAR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00050C)))
951 #define MCF548X_FBCS_CSMR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000510)))
952 #define MCF548X_FBCS_CSCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000514)))
953 #define MCF548X_FBCS_CSAR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000518)))
954 #define MCF548X_FBCS_CSMR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00051C)))
955 #define MCF548X_FBCS_CSCR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000520)))
956 #define MCF548X_FBCS_CSAR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000524)))
957 #define MCF548X_FBCS_CSMR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000528)))
958 #define MCF548X_FBCS_CSCR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00052C)))
959 #define MCF548X_FBCS_CSAR4 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000530)))
960 #define MCF548X_FBCS_CSMR4 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000534)))
961 #define MCF548X_FBCS_CSCR4 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000538)))
962 #define MCF548X_FBCS_CSAR5 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00053C)))
963 #define MCF548X_FBCS_CSMR5 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000540)))
964 #define MCF548X_FBCS_CSCR5 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000544)))
965 #define MCF548X_FBCS_CSAR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000500U+((x)*0x00C))))
966 #define MCF548X_FBCS_CSMR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000504U+((x)*0x00C))))
967 #define MCF548X_FBCS_CSCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000508U+((x)*0x00C))))
968
969 /* Bit definitions and macros for MCF548X_FBCS_CSAR */
970 #define MCF548X_FBCS_CSAR_BA(x) ((x)&0xFFFF0000)
971
972 /* Bit definitions and macros for MCF548X_FBCS_CSMR */
973 #define MCF548X_FBCS_CSMR_V (0x00000001)
974 #define MCF548X_FBCS_CSMR_WP (0x00000100)
975 #define MCF548X_FBCS_CSMR_BAM(x) (((x)&0x0000FFFF)<<16)
976 #define MCF548X_FBCS_CSMR_BAM_4G (0xFFFF0000)
977 #define MCF548X_FBCS_CSMR_BAM_2G (0x7FFF0000)
978 #define MCF548X_FBCS_CSMR_BAM_1G (0x3FFF0000)
979 #define MCF548X_FBCS_CSMR_BAM_1024M (0x3FFF0000)
980 #define MCF548X_FBCS_CSMR_BAM_512M (0x1FFF0000)
981 #define MCF548X_FBCS_CSMR_BAM_256M (0x0FFF0000)
982 #define MCF548X_FBCS_CSMR_BAM_128M (0x07FF0000)
983 #define MCF548X_FBCS_CSMR_BAM_64M (0x03FF0000)
984 #define MCF548X_FBCS_CSMR_BAM_32M (0x01FF0000)
985 #define MCF548X_FBCS_CSMR_BAM_16M (0x00FF0000)
986 #define MCF548X_FBCS_CSMR_BAM_8M (0x007F0000)
987 #define MCF548X_FBCS_CSMR_BAM_4M (0x003F0000)
988 #define MCF548X_FBCS_CSMR_BAM_2M (0x001F0000)
989 #define MCF548X_FBCS_CSMR_BAM_1M (0x000F0000)
990 #define MCF548X_FBCS_CSMR_BAM_1024K (0x000F0000)
991 #define MCF548X_FBCS_CSMR_BAM_512K (0x00070000)
992 #define MCF548X_FBCS_CSMR_BAM_256K (0x00030000)
993 #define MCF548X_FBCS_CSMR_BAM_128K (0x00010000)
994 #define MCF548X_FBCS_CSMR_BAM_64K (0x00000000)
995
996 /* Bit definitions and macros for MCF548X_FBCS_CSCR */
997 #define MCF548X_FBCS_CSCR_BSTW (0x00000008)
998 #define MCF548X_FBCS_CSCR_BSTR (0x00000010)
999 #define MCF548X_FBCS_CSCR_PS(x) (((x)&0x00000003)<<6)
1000 #define MCF548X_FBCS_CSCR_AA (0x00000100)
1001 #define MCF548X_FBCS_CSCR_WS(x) (((x)&0x0000003F)<<10)
1002 #define MCF548X_FBCS_CSCR_WRAH(x) (((x)&0x00000003)<<16)
1003 #define MCF548X_FBCS_CSCR_RDAH(x) (((x)&0x00000003)<<18)
1004 #define MCF548X_FBCS_CSCR_ASET(x) (((x)&0x00000003)<<20)
1005 #define MCF548X_FBCS_CSCR_SWSEN (0x00800000)
1006 #define MCF548X_FBCS_CSCR_SWS(x) (((x)&0x0000003F)<<26)
1007 #define MCF548X_FBCS_CSCR_PS_8 (0x00000040)
1008 #define MCF548X_FBCS_CSCR_PS_16 (0x00000080)
1009 #define MCF548X_FBCS_CSCR_PS_32 (0x00000000)
1010
1011
1012 /*********************************************************************
1013 *
1014 * General Purpose I/O (GPIO)
1015 *
1016 *********************************************************************/
1017
1018 /* Register read/write macros */
1019 #define MCF548X_GPIO_PODR_FBCTL (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A00)))
1020 #define MCF548X_GPIO_PODR_FBCS (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A01)))
1021 #define MCF548X_GPIO_PODR_DMA (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A02)))
1022 #define MCF548X_GPIO_PODR_FEC0H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A04)))
1023 #define MCF548X_GPIO_PODR_FEC0L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A05)))
1024 #define MCF548X_GPIO_PODR_FEC1H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A06)))
1025 #define MCF548X_GPIO_PODR_FEC1L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A07)))
1026 #define MCF548X_GPIO_PODR_FECI2C (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A08)))
1027 #define MCF548X_GPIO_PODR_PCIBG (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A09)))
1028 #define MCF548X_GPIO_PODR_PCIBR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A0A)))
1029 #define MCF548X_GPIO_PODR_PSC3PSC2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A0C)))
1030 #define MCF548X_GPIO_PODR_PSC1PSC0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A0D)))
1031 #define MCF548X_GPIO_PODR_DSPI (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A0E)))
1032 #define MCF548X_GPIO_PDDR_FBCTL (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A10)))
1033 #define MCF548X_GPIO_PDDR_FBCS (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A11)))
1034 #define MCF548X_GPIO_PDDR_DMA (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A12)))
1035 #define MCF548X_GPIO_PDDR_FEC0H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A14)))
1036 #define MCF548X_GPIO_PDDR_FEC0L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A15)))
1037 #define MCF548X_GPIO_PDDR_FEC1H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A16)))
1038 #define MCF548X_GPIO_PDDR_FEC1L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A17)))
1039 #define MCF548X_GPIO_PDDR_FECI2C (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A18)))
1040 #define MCF548X_GPIO_PDDR_PCIBG (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A19)))
1041 #define MCF548X_GPIO_PDDR_PCIBR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A1A)))
1042 #define MCF548X_GPIO_PDDR_PSC3PSC2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A1C)))
1043 #define MCF548X_GPIO_PDDR_PSC1PSC0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A1D)))
1044 #define MCF548X_GPIO_PDDR_DSPI (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A1E)))
1045 #define MCF548X_GPIO_PPDSDR_FBCTL (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A20)))
1046 #define MCF548X_GPIO_PPDSDR_FBCS (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A21)))
1047 #define MCF548X_GPIO_PPDSDR_DMA (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A22)))
1048 #define MCF548X_GPIO_PPDSDR_FEC0H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A24)))
1049 #define MCF548X_GPIO_PPDSDR_FEC0L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A25)))
1050 #define MCF548X_GPIO_PPDSDR_FEC1H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A26)))
1051 #define MCF548X_GPIO_PPDSDR_FEC1L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A27)))
1052 #define MCF548X_GPIO_PPDSDR_FECI2C (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A28)))
1053 #define MCF548X_GPIO_PPDSDR_PCIBG (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A29)))
1054 #define MCF548X_GPIO_PPDSDR_PCIBR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A2A)))
1055 #define MCF548X_GPIO_PPDSDR_PSC3PSC2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A2C)))
1056 #define MCF548X_GPIO_PPDSDR_PSC1PSC0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A2D)))
1057 #define MCF548X_GPIO_PPDSDR_DSPI (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A2E)))
1058 #define MCF548X_GPIO_PCLRR_FBCTL (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A30)))
1059 #define MCF548X_GPIO_PCLRR_FBCS (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A31)))
1060 #define MCF548X_GPIO_PCLRR_DMA (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A32)))
1061 #define MCF548X_GPIO_PCLRR_FEC0H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A34)))
1062 #define MCF548X_GPIO_PCLRR_FEC0L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A35)))
1063 #define MCF548X_GPIO_PCLRR_FEC1H (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A36)))
1064 #define MCF548X_GPIO_PCLRR_FEC1L (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A37)))
1065 #define MCF548X_GPIO_PCLRR_FECI2C (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A38)))
1066 #define MCF548X_GPIO_PCLRR_PCIBG (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A39)))
1067 #define MCF548X_GPIO_PCLRR_PCIBR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A3A)))
1068 #define MCF548X_GPIO_PCLRR_PSC3PSC2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A3C)))
1069 #define MCF548X_GPIO_PCLRR_PSC1PSC0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A3D)))
1070 #define MCF548X_GPIO_PCLRR_DSPI (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A3E)))
1071 #define MCF548X_GPIO_PAR_FBCTL (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x000A40)))
1072 #define MCF548X_GPIO_PAR_FBCS (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A42)))
1073 #define MCF548X_GPIO_PAR_DMA (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A43)))
1074 #define MCF548X_GPIO_PAR_FECI2CIRQ (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x000A44)))
1075 #define MCF548X_GPIO_PAR_PCIBG (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x000A48)))
1076 #define MCF548X_GPIO_PAR_PCIBR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x000A4A)))
1077 #define MCF548X_GPIO_PAR_PSC3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A4C)))
1078 #define MCF548X_GPIO_PAR_PSC2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A4D)))
1079 #define MCF548X_GPIO_PAR_PSC1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A4E)))
1080 #define MCF548X_GPIO_PAR_PSC0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A4F)))
1081 #define MCF548X_GPIO_PAR_DSPI (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x000A50)))
1082 #define MCF548X_GPIO_PAR_TIMER (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000A52)))
1083
1084 /* Bit definitions and macros for MCF548X_GPIO_PODR_FBCTL */
1085 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL0 (0x01)
1086 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL1 (0x02)
1087 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL2 (0x04)
1088 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL3 (0x08)
1089 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL4 (0x10)
1090 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL5 (0x20)
1091 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL6 (0x40)
1092 #define MCF548X_GPIO_PODR_FBCTL_PODR_FBCTL7 (0x80)
1093
1094 /* Bit definitions and macros for MCF548X_GPIO_PODR_FBCS */
1095 #define MCF548X_GPIO_PODR_FBCS_PODR_FBCS1 (0x02)
1096 #define MCF548X_GPIO_PODR_FBCS_PODR_FBCS2 (0x04)
1097 #define MCF548X_GPIO_PODR_FBCS_PODR_FBCS3 (0x08)
1098 #define MCF548X_GPIO_PODR_FBCS_PODR_FBCS4 (0x10)
1099 #define MCF548X_GPIO_PODR_FBCS_PODR_FBCS5 (0x20)
1100
1101 /* Bit definitions and macros for MCF548X_GPIO_PODR_DMA */
1102 #define MCF548X_GPIO_PODR_DMA_PODR_DMA0 (0x01)
1103 #define MCF548X_GPIO_PODR_DMA_PODR_DMA1 (0x02)
1104 #define MCF548X_GPIO_PODR_DMA_PODR_DMA2 (0x04)
1105 #define MCF548X_GPIO_PODR_DMA_PODR_DMA3 (0x08)
1106
1107 /* Bit definitions and macros for MCF548X_GPIO_PODR_FEC0H */
1108 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H0 (0x01)
1109 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H1 (0x02)
1110 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H2 (0x04)
1111 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H3 (0x08)
1112 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H4 (0x10)
1113 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H5 (0x20)
1114 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H6 (0x40)
1115 #define MCF548X_GPIO_PODR_FEC0H_PODR_FEC0H7 (0x80)
1116
1117 /* Bit definitions and macros for MCF548X_GPIO_PODR_FEC0L */
1118 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L0 (0x01)
1119 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L1 (0x02)
1120 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L2 (0x04)
1121 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L3 (0x08)
1122 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L4 (0x10)
1123 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L5 (0x20)
1124 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L6 (0x40)
1125 #define MCF548X_GPIO_PODR_FEC0L_PODR_FEC0L7 (0x80)
1126
1127 /* Bit definitions and macros for MCF548X_GPIO_PODR_FEC1H */
1128 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H0 (0x01)
1129 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H1 (0x02)
1130 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H2 (0x04)
1131 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H3 (0x08)
1132 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H4 (0x10)
1133 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H5 (0x20)
1134 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H6 (0x40)
1135 #define MCF548X_GPIO_PODR_FEC1H_PODR_FEC1H7 (0x80)
1136
1137 /* Bit definitions and macros for MCF548X_GPIO_PODR_FEC1L */
1138 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L0 (0x01)
1139 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L1 (0x02)
1140 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L2 (0x04)
1141 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L3 (0x08)
1142 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L4 (0x10)
1143 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L5 (0x20)
1144 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L6 (0x40)
1145 #define MCF548X_GPIO_PODR_FEC1L_PODR_FEC1L7 (0x80)
1146
1147 /* Bit definitions and macros for MCF548X_GPIO_PODR_FECI2C */
1148 #define MCF548X_GPIO_PODR_FECI2C_PODR_FECI2C0 (0x01)
1149 #define MCF548X_GPIO_PODR_FECI2C_PODR_FECI2C1 (0x02)
1150 #define MCF548X_GPIO_PODR_FECI2C_PODR_FECI2C2 (0x04)
1151 #define MCF548X_GPIO_PODR_FECI2C_PODR_FECI2C3 (0x08)
1152
1153 /* Bit definitions and macros for MCF548X_GPIO_PODR_PCIBG */
1154 #define MCF548X_GPIO_PODR_PCIBG_PODR_PCIBG0 (0x01)
1155 #define MCF548X_GPIO_PODR_PCIBG_PODR_PCIBG1 (0x02)
1156 #define MCF548X_GPIO_PODR_PCIBG_PODR_PCIBG2 (0x04)
1157 #define MCF548X_GPIO_PODR_PCIBG_PODR_PCIBG3 (0x08)
1158 #define MCF548X_GPIO_PODR_PCIBG_PODR_PCIBG4 (0x10)
1159
1160 /* Bit definitions and macros for MCF548X_GPIO_PODR_PCIBR */
1161 #define MCF548X_GPIO_PODR_PCIBR_PODR_PCIBR0 (0x01)
1162 #define MCF548X_GPIO_PODR_PCIBR_PODR_PCIBR1 (0x02)
1163 #define MCF548X_GPIO_PODR_PCIBR_PODR_PCIBR2 (0x04)
1164 #define MCF548X_GPIO_PODR_PCIBR_PODR_PCIBR3 (0x08)
1165 #define MCF548X_GPIO_PODR_PCIBR_PODR_PCIBR4 (0x10)
1166
1167 /* Bit definitions and macros for MCF548X_GPIO_PODR_PSC3PSC2 */
1168 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC20 (0x01)
1169 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC21 (0x02)
1170 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC22 (0x04)
1171 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC23 (0x08)
1172 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC24 (0x10)
1173 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC25 (0x20)
1174 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC26 (0x40)
1175 #define MCF548X_GPIO_PODR_PSC3PSC2_PODR_PSC3PSC27 (0x80)
1176
1177 /* Bit definitions and macros for MCF548X_GPIO_PODR_PSC1PSC0 */
1178 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC00 (0x01)
1179 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC01 (0x02)
1180 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC02 (0x04)
1181 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC03 (0x08)
1182 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC04 (0x10)
1183 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC05 (0x20)
1184 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC06 (0x40)
1185 #define MCF548X_GPIO_PODR_PSC1PSC0_PODR_PSC1PSC07 (0x80)
1186
1187 /* Bit definitions and macros for MCF548X_GPIO_PODR_DSPI */
1188 #define MCF548X_GPIO_PODR_DSPI_PODR_DSPI0 (0x01)
1189 #define MCF548X_GPIO_PODR_DSPI_PODR_DSPI1 (0x02)
1190 #define MCF548X_GPIO_PODR_DSPI_PODR_DSPI2 (0x04)
1191 #define MCF548X_GPIO_PODR_DSPI_PODR_DSPI3 (0x08)
1192 #define MCF548X_GPIO_PODR_DSPI_PODR_DSPI4 (0x10)
1193 #define MCF548X_GPIO_PODR_DSPI_PODR_DSPI5 (0x20)
1194 #define MCF548X_GPIO_PODR_DSPI_PODR_DSPI6 (0x40)
1195
1196 /* Bit definitions and macros for MCF548X_GPIO_PDDR_FBCTL */
1197 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL0 (0x01)
1198 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL1 (0x02)
1199 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL2 (0x04)
1200 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL3 (0x08)
1201 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL4 (0x10)
1202 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL5 (0x20)
1203 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL6 (0x40)
1204 #define MCF548X_GPIO_PDDR_FBCTL_PDDR_FBCTL7 (0x80)
1205
1206 /* Bit definitions and macros for MCF548X_GPIO_PDDR_FBCS */
1207 #define MCF548X_GPIO_PDDR_FBCS_PDDR_FBCS1 (0x02)
1208 #define MCF548X_GPIO_PDDR_FBCS_PDDR_FBCS2 (0x04)
1209 #define MCF548X_GPIO_PDDR_FBCS_PDDR_FBCS3 (0x08)
1210 #define MCF548X_GPIO_PDDR_FBCS_PDDR_FBCS4 (0x10)
1211 #define MCF548X_GPIO_PDDR_FBCS_PDDR_FBCS5 (0x20)
1212
1213 /* Bit definitions and macros for MCF548X_GPIO_PDDR_DMA */
1214 #define MCF548X_GPIO_PDDR_DMA_PDDR_DMA0 (0x01)
1215 #define MCF548X_GPIO_PDDR_DMA_PDDR_DMA1 (0x02)
1216 #define MCF548X_GPIO_PDDR_DMA_PDDR_DMA2 (0x04)
1217 #define MCF548X_GPIO_PDDR_DMA_PDDR_DMA3 (0x08)
1218
1219 /* Bit definitions and macros for MCF548X_GPIO_PDDR_FEC0H */
1220 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H0 (0x01)
1221 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H1 (0x02)
1222 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H2 (0x04)
1223 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H3 (0x08)
1224 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H4 (0x10)
1225 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H5 (0x20)
1226 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H6 (0x40)
1227 #define MCF548X_GPIO_PDDR_FEC0H_PDDR_FEC0H7 (0x80)
1228
1229 /* Bit definitions and macros for MCF548X_GPIO_PDDR_FEC0L */
1230 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L0 (0x01)
1231 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L1 (0x02)
1232 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L2 (0x04)
1233 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L3 (0x08)
1234 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L4 (0x10)
1235 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L5 (0x20)
1236 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L6 (0x40)
1237 #define MCF548X_GPIO_PDDR_FEC0L_PDDR_FEC0L7 (0x80)
1238
1239 /* Bit definitions and macros for MCF548X_GPIO_PDDR_FEC1H */
1240 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H0 (0x01)
1241 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H1 (0x02)
1242 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H2 (0x04)
1243 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H3 (0x08)
1244 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H4 (0x10)
1245 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H5 (0x20)
1246 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H6 (0x40)
1247 #define MCF548X_GPIO_PDDR_FEC1H_PDDR_FEC1H7 (0x80)
1248
1249 /* Bit definitions and macros for MCF548X_GPIO_PDDR_FEC1L */
1250 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L0 (0x01)
1251 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L1 (0x02)
1252 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L2 (0x04)
1253 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L3 (0x08)
1254 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L4 (0x10)
1255 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L5 (0x20)
1256 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L6 (0x40)
1257 #define MCF548X_GPIO_PDDR_FEC1L_PDDR_FEC1L7 (0x80)
1258
1259 /* Bit definitions and macros for MCF548X_GPIO_PDDR_FECI2C */
1260 #define MCF548X_GPIO_PDDR_FECI2C_PDDR_FECI2C0 (0x01)
1261 #define MCF548X_GPIO_PDDR_FECI2C_PDDR_FECI2C1 (0x02)
1262 #define MCF548X_GPIO_PDDR_FECI2C_PDDR_FECI2C2 (0x04)
1263 #define MCF548X_GPIO_PDDR_FECI2C_PDDR_FECI2C3 (0x08)
1264
1265 /* Bit definitions and macros for MCF548X_GPIO_PDDR_PCIBG */
1266 #define MCF548X_GPIO_PDDR_PCIBG_PDDR_PCIBG0 (0x01)
1267 #define MCF548X_GPIO_PDDR_PCIBG_PDDR_PCIBG1 (0x02)
1268 #define MCF548X_GPIO_PDDR_PCIBG_PDDR_PCIBG2 (0x04)
1269 #define MCF548X_GPIO_PDDR_PCIBG_PDDR_PCIBG3 (0x08)
1270 #define MCF548X_GPIO_PDDR_PCIBG_PDDR_PCIBG4 (0x10)
1271
1272 /* Bit definitions and macros for MCF548X_GPIO_PDDR_PCIBR */
1273 #define MCF548X_GPIO_PDDR_PCIBR_PDDR_PCIBR0 (0x01)
1274 #define MCF548X_GPIO_PDDR_PCIBR_PDDR_PCIBR1 (0x02)
1275 #define MCF548X_GPIO_PDDR_PCIBR_PDDR_PCIBR2 (0x04)
1276 #define MCF548X_GPIO_PDDR_PCIBR_PDDR_PCIBR3 (0x08)
1277 #define MCF548X_GPIO_PDDR_PCIBR_PDDR_PCIBR4 (0x10)
1278
1279 /* Bit definitions and macros for MCF548X_GPIO_PDDR_PSC3PSC2 */
1280 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC20 (0x01)
1281 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC21 (0x02)
1282 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC22 (0x04)
1283 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC23 (0x08)
1284 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC24 (0x10)
1285 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC25 (0x20)
1286 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC26 (0x40)
1287 #define MCF548X_GPIO_PDDR_PSC3PSC2_PDDR_PSC3PSC27 (0x80)
1288
1289 /* Bit definitions and macros for MCF548X_GPIO_PDDR_PSC1PSC0 */
1290 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC00 (0x01)
1291 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC01 (0x02)
1292 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC02 (0x04)
1293 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC03 (0x08)
1294 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC04 (0x10)
1295 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC05 (0x20)
1296 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC06 (0x40)
1297 #define MCF548X_GPIO_PDDR_PSC1PSC0_PDDR_PSC1PSC07 (0x80)
1298
1299 /* Bit definitions and macros for MCF548X_GPIO_PDDR_DSPI */
1300 #define MCF548X_GPIO_PDDR_DSPI_PDDR_DSPI0 (0x01)
1301 #define MCF548X_GPIO_PDDR_DSPI_PDDR_DSPI1 (0x02)
1302 #define MCF548X_GPIO_PDDR_DSPI_PDDR_DSPI2 (0x04)
1303 #define MCF548X_GPIO_PDDR_DSPI_PDDR_DSPI3 (0x08)
1304 #define MCF548X_GPIO_PDDR_DSPI_PDDR_DSPI4 (0x10)
1305 #define MCF548X_GPIO_PDDR_DSPI_PDDR_DSPI5 (0x20)
1306 #define MCF548X_GPIO_PDDR_DSPI_PDDR_DSPI6 (0x40)
1307
1308 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_FBCTL */
1309 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL0 (0x01)
1310 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL1 (0x02)
1311 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL2 (0x04)
1312 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL3 (0x08)
1313 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL4 (0x10)
1314 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL5 (0x20)
1315 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL6 (0x40)
1316 #define MCF548X_GPIO_PPDSDR_FBCTL_PPDSDR_FBCTL7 (0x80)
1317
1318 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_FBCS */
1319 #define MCF548X_GPIO_PPDSDR_FBCS_PPDSDR_FBCS1 (0x02)
1320 #define MCF548X_GPIO_PPDSDR_FBCS_PPDSDR_FBCS2 (0x04)
1321 #define MCF548X_GPIO_PPDSDR_FBCS_PPDSDR_FBCS3 (0x08)
1322 #define MCF548X_GPIO_PPDSDR_FBCS_PPDSDR_FBCS4 (0x10)
1323 #define MCF548X_GPIO_PPDSDR_FBCS_PPDSDR_FBCS5 (0x20)
1324
1325 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_DMA */
1326 #define MCF548X_GPIO_PPDSDR_DMA_PPDSDR_DMA0 (0x01)
1327 #define MCF548X_GPIO_PPDSDR_DMA_PPDSDR_DMA1 (0x02)
1328 #define MCF548X_GPIO_PPDSDR_DMA_PPDSDR_DMA2 (0x04)
1329 #define MCF548X_GPIO_PPDSDR_DMA_PPDSDR_DMA3 (0x08)
1330
1331 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_FEC0H */
1332 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H0 (0x01)
1333 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H1 (0x02)
1334 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H2 (0x04)
1335 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H3 (0x08)
1336 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H4 (0x10)
1337 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H5 (0x20)
1338 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H6 (0x40)
1339 #define MCF548X_GPIO_PPDSDR_FEC0H_PPDSDR_FEC0H7 (0x80)
1340
1341 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_FEC0L */
1342 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L0 (0x01)
1343 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L1 (0x02)
1344 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L2 (0x04)
1345 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L3 (0x08)
1346 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L4 (0x10)
1347 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L5 (0x20)
1348 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L6 (0x40)
1349 #define MCF548X_GPIO_PPDSDR_FEC0L_PPDSDR_FEC0L7 (0x80)
1350
1351 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_FEC1H */
1352 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H0 (0x01)
1353 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H1 (0x02)
1354 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H2 (0x04)
1355 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H3 (0x08)
1356 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H4 (0x10)
1357 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H5 (0x20)
1358 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H6 (0x40)
1359 #define MCF548X_GPIO_PPDSDR_FEC1H_PPDSDR_FEC1H7 (0x80)
1360
1361 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_FEC1L */
1362 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L0 (0x01)
1363 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L1 (0x02)
1364 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L2 (0x04)
1365 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L3 (0x08)
1366 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L4 (0x10)
1367 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L5 (0x20)
1368 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L6 (0x40)
1369 #define MCF548X_GPIO_PPDSDR_FEC1L_PPDSDR_FEC1L7 (0x80)
1370
1371 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_FECI2C */
1372 #define MCF548X_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C0 (0x01)
1373 #define MCF548X_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C1 (0x02)
1374 #define MCF548X_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C2 (0x04)
1375 #define MCF548X_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C3 (0x08)
1376
1377 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_PCIBG */
1378 #define MCF548X_GPIO_PPDSDR_PCIBG_PPDSDR_PCIBG0 (0x01)
1379 #define MCF548X_GPIO_PPDSDR_PCIBG_PPDSDR_PCIBG1 (0x02)
1380 #define MCF548X_GPIO_PPDSDR_PCIBG_PPDSDR_PCIBG2 (0x04)
1381 #define MCF548X_GPIO_PPDSDR_PCIBG_PPDSDR_PCIBG3 (0x08)
1382 #define MCF548X_GPIO_PPDSDR_PCIBG_PPDSDR_PCIBG4 (0x10)
1383
1384 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_PCIBR */
1385 #define MCF548X_GPIO_PPDSDR_PCIBR_PPDSDR_PCIBR0 (0x01)
1386 #define MCF548X_GPIO_PPDSDR_PCIBR_PPDSDR_PCIBR1 (0x02)
1387 #define MCF548X_GPIO_PPDSDR_PCIBR_PPDSDR_PCIBR2 (0x04)
1388 #define MCF548X_GPIO_PPDSDR_PCIBR_PPDSDR_PCIBR3 (0x08)
1389 #define MCF548X_GPIO_PPDSDR_PCIBR_PPDSDR_PCIBR4 (0x10)
1390
1391 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_PSC3PSC2 */
1392 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PPDSDR_PSC3PSC20 (0x01)
1393 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PPDSDR_PSC3PSC21 (0x02)
1394 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PPDSDR_PSC3PSC22 (0x04)
1395 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PPDSDR_PSC3PSC23 (0x08)
1396 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PDDR_PSC3PSC24 (0x10)
1397 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PDDR_PSC3PSC25 (0x20)
1398 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PPDSDR_PSC3PSC26 (0x40)
1399 #define MCF548X_GPIO_PPDSDR_PSC3PSC2_PPDSDR_PSC3PSC27 (0x80)
1400
1401 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_PSC1PSC0 */
1402 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PPDSDR_PSC1PSC00 (0x01)
1403 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PDDR_PSC1PSC01 (0x02)
1404 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PPDSDR_PSC1PSC02 (0x04)
1405 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PDDR_PSC1PSC03 (0x08)
1406 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PPDSDR_PSC1PSC04 (0x10)
1407 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PPDSDR_PSC1PSC05 (0x20)
1408 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PPDSDR_PSC1PSC06 (0x40)
1409 #define MCF548X_GPIO_PPDSDR_PSC1PSC0_PPDSDR_PSC1PSC07 (0x80)
1410
1411 /* Bit definitions and macros for MCF548X_GPIO_PPDSDR_DSPI */
1412 #define MCF548X_GPIO_PPDSDR_DSPI_PPDSDR_DSPI0 (0x01)
1413 #define MCF548X_GPIO_PPDSDR_DSPI_PPDSDR_DSPI1 (0x02)
1414 #define MCF548X_GPIO_PPDSDR_DSPI_PPDSDR_DSPI2 (0x04)
1415 #define MCF548X_GPIO_PPDSDR_DSPI_PPDSDR_DSPI3 (0x08)
1416 #define MCF548X_GPIO_PPDSDR_DSPI_PDDR_DSPI4 (0x10)
1417 #define MCF548X_GPIO_PPDSDR_DSPI_PPDSDR_DSPI5 (0x20)
1418 #define MCF548X_GPIO_PPDSDR_DSPI_PPDSDR_DSPI6 (0x40)
1419
1420 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_FBCTL */
1421 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL0 (0x01)
1422 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL1 (0x02)
1423 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL2 (0x04)
1424 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL3 (0x08)
1425 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL4 (0x10)
1426 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL5 (0x20)
1427 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL6 (0x40)
1428 #define MCF548X_GPIO_PCLRR_FBCTL_PCLRR_FBCTL7 (0x80)
1429
1430 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_FBCS */
1431 #define MCF548X_GPIO_PCLRR_FBCS_PCLRR_FBCS1 (0x02)
1432 #define MCF548X_GPIO_PCLRR_FBCS_PCLRR_FBCS2 (0x04)
1433 #define MCF548X_GPIO_PCLRR_FBCS_PCLRR_FBCS3 (0x08)
1434 #define MCF548X_GPIO_PCLRR_FBCS_PCLRR_FBCS4 (0x10)
1435 #define MCF548X_GPIO_PCLRR_FBCS_PCLRR_FBCS5 (0x20)
1436
1437 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_DMA */
1438 #define MCF548X_GPIO_PCLRR_DMA_PCLRR_DMA0 (0x01)
1439 #define MCF548X_GPIO_PCLRR_DMA_PCLRR_DMA1 (0x02)
1440 #define MCF548X_GPIO_PCLRR_DMA_PCLRR_DMA2 (0x04)
1441 #define MCF548X_GPIO_PCLRR_DMA_PCLRR_DMA3 (0x08)
1442
1443 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_FEC0H */
1444 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H0 (0x01)
1445 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H1 (0x02)
1446 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H2 (0x04)
1447 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H3 (0x08)
1448 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H4 (0x10)
1449 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H5 (0x20)
1450 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H6 (0x40)
1451 #define MCF548X_GPIO_PCLRR_FEC0H_PCLRR_FEC0H7 (0x80)
1452
1453 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_FEC0L */
1454 #define MCF548X_GPIO_PCLRR_FEC0L_PCLRR_FEC0L0 (0x01)
1455 #define MCF548X_GPIO_PCLRR_FEC0L_PODR_FEC0L1 (0x02)
1456 #define MCF548X_GPIO_PCLRR_FEC0L_PCLRR_FEC0L2 (0x04)
1457 #define MCF548X_GPIO_PCLRR_FEC0L_PCLRR_FEC0L3 (0x08)
1458 #define MCF548X_GPIO_PCLRR_FEC0L_PODR_FEC0L4 (0x10)
1459 #define MCF548X_GPIO_PCLRR_FEC0L_PODR_FEC0L5 (0x20)
1460 #define MCF548X_GPIO_PCLRR_FEC0L_PODR_FEC0L6 (0x40)
1461 #define MCF548X_GPIO_PCLRR_FEC0L_PCLRR_FEC0L7 (0x80)
1462
1463 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_FEC1H */
1464 #define MCF548X_GPIO_PCLRR_FEC1H_PCLRR_FEC1H0 (0x01)
1465 #define MCF548X_GPIO_PCLRR_FEC1H_PCLRR_FEC1H1 (0x02)
1466 #define MCF548X_GPIO_PCLRR_FEC1H_PCLRR_FEC1H2 (0x04)
1467 #define MCF548X_GPIO_PCLRR_FEC1H_PODR_FEC1H3 (0x08)
1468 #define MCF548X_GPIO_PCLRR_FEC1H_PODR_FEC1H4 (0x10)
1469 #define MCF548X_GPIO_PCLRR_FEC1H_PCLRR_FEC1H5 (0x20)
1470 #define MCF548X_GPIO_PCLRR_FEC1H_PCLRR_FEC1H6 (0x40)
1471 #define MCF548X_GPIO_PCLRR_FEC1H_PCLRR_FEC1H7 (0x80)
1472
1473 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_FEC1L */
1474 #define MCF548X_GPIO_PCLRR_FEC1L_PCLRR_FEC1L0 (0x01)
1475 #define MCF548X_GPIO_PCLRR_FEC1L_PCLRR_FEC1L1 (0x02)
1476 #define MCF548X_GPIO_PCLRR_FEC1L_PCLRR_FEC1L2 (0x04)
1477 #define MCF548X_GPIO_PCLRR_FEC1L_PCLRR_FEC1L3 (0x08)
1478 #define MCF548X_GPIO_PCLRR_FEC1L_PODR_FEC1L4 (0x10)
1479 #define MCF548X_GPIO_PCLRR_FEC1L_PCLRR_FEC1L5 (0x20)
1480 #define MCF548X_GPIO_PCLRR_FEC1L_PCLRR_FEC1L6 (0x40)
1481 #define MCF548X_GPIO_PCLRR_FEC1L_PCLRR_FEC1L7 (0x80)
1482
1483 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_FECI2C */
1484 #define MCF548X_GPIO_PCLRR_FECI2C_PCLRR_FECI2C0 (0x01)
1485 #define MCF548X_GPIO_PCLRR_FECI2C_PCLRR_FECI2C1 (0x02)
1486 #define MCF548X_GPIO_PCLRR_FECI2C_PODR_FECI2C2 (0x04)
1487 #define MCF548X_GPIO_PCLRR_FECI2C_PCLRR_FECI2C3 (0x08)
1488
1489 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_PCIBG */
1490 #define MCF548X_GPIO_PCLRR_PCIBG_PODR_PCIBG0 (0x01)
1491 #define MCF548X_GPIO_PCLRR_PCIBG_PODR_PCIBG1 (0x02)
1492 #define MCF548X_GPIO_PCLRR_PCIBG_PODR_PCIBG2 (0x04)
1493 #define MCF548X_GPIO_PCLRR_PCIBG_PCLRR_PCIBG3 (0x08)
1494 #define MCF548X_GPIO_PCLRR_PCIBG_PCLRR_PCIBG4 (0x10)
1495
1496 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_PCIBR */
1497 #define MCF548X_GPIO_PCLRR_PCIBR_PCLRR_PCIBR0 (0x01)
1498 #define MCF548X_GPIO_PCLRR_PCIBR_PCLRR_PCIBR1 (0x02)
1499 #define MCF548X_GPIO_PCLRR_PCIBR_PCLRR_PCIBR2 (0x04)
1500 #define MCF548X_GPIO_PCLRR_PCIBR_PODR_PCIBR3 (0x08)
1501 #define MCF548X_GPIO_PCLRR_PCIBR_PODR_PCIBR4 (0x10)
1502
1503 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_PSC3PSC2 */
1504 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PODR_PSC3PSC20 (0x01)
1505 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PODR_PSC3PSC21 (0x02)
1506 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PCLRR_PSC3PSC22 (0x04)
1507 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PCLRR_PSC3PSC23 (0x08)
1508 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PCLRR_PSC3PSC24 (0x10)
1509 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PODR_PSC3PSC25 (0x20)
1510 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PODR_PSC3PSC26 (0x40)
1511 #define MCF548X_GPIO_PCLRR_PSC3PSC2_PCLRR_PSC3PSC27 (0x80)
1512
1513 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_PSC1PSC0 */
1514 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PCLRR_PSC1PSC00 (0x01)
1515 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PCLRR_PSC1PSC01 (0x02)
1516 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PCLRR_PSC1PSC02 (0x04)
1517 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PCLRR_PSC1PSC03 (0x08)
1518 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PCLRR_PSC1PSC04 (0x10)
1519 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PCLRR_PSC1PSC05 (0x20)
1520 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PODR_PSC1PSC06 (0x40)
1521 #define MCF548X_GPIO_PCLRR_PSC1PSC0_PCLRR_PSC1PSC07 (0x80)
1522
1523 /* Bit definitions and macros for MCF548X_GPIO_PCLRR_DSPI */
1524 #define MCF548X_GPIO_PCLRR_DSPI_PCLRR_DSPI0 (0x01)
1525 #define MCF548X_GPIO_PCLRR_DSPI_PCLRR_DSPI1 (0x02)
1526 #define MCF548X_GPIO_PCLRR_DSPI_PCLRR_DSPI2 (0x04)
1527 #define MCF548X_GPIO_PCLRR_DSPI_PCLRR_DSPI3 (0x08)
1528 #define MCF548X_GPIO_PCLRR_DSPI_PCLRR_DSPI4 (0x10)
1529 #define MCF548X_GPIO_PCLRR_DSPI_PCLRR_DSPI5 (0x20)
1530 #define MCF548X_GPIO_PCLRR_DSPI_PCLRR_DSPI6 (0x40)
1531
1532 /* Bit definitions and macros for MCF548X_GPIO_PAR_FBCTL */
1533 #define MCF548X_GPIO_PAR_FBCTL_PAR_TS(x) (((x)&0x0003)<<0)
1534 #define MCF548X_GPIO_PAR_FBCTL_PAR_TA (0x0004)
1535 #define MCF548X_GPIO_PAR_FBCTL_PAR_RWB(x) (((x)&0x0003)<<4)
1536 #define MCF548X_GPIO_PAR_FBCTL_PAR_OE (0x0040)
1537 #define MCF548X_GPIO_PAR_FBCTL_PAR_BWE0 (0x0100)
1538 #define MCF548X_GPIO_PAR_FBCTL_PAR_BWE1 (0x0400)
1539 #define MCF548X_GPIO_PAR_FBCTL_PAR_BWE2 (0x1000)
1540 #define MCF548X_GPIO_PAR_FBCTL_PAR_BWE3 (0x4000)
1541 #define MCF548X_GPIO_PAR_FBCTL_PAR_TS_GPIO (0)
1542 #define MCF548X_GPIO_PAR_FBCTL_PAR_TS_TBST (2)
1543 #define MCF548X_GPIO_PAR_FBCTL_PAR_TS_TS (3)
1544 #define MCF548X_GPIO_PAR_FBCTL_PAR_RWB_GPIO (0x0000)
1545 #define MCF548X_GPIO_PAR_FBCTL_PAR_RWB_TBST (0x0020)
1546 #define MCF548X_GPIO_PAR_FBCTL_PAR_RWB_RWB (0x0030)
1547
1548 /* Bit definitions and macros for MCF548X_GPIO_PAR_FBCS */
1549 #define MCF548X_GPIO_PAR_FBCS_PAR_CS1 (0x02)
1550 #define MCF548X_GPIO_PAR_FBCS_PAR_CS2 (0x04)
1551 #define MCF548X_GPIO_PAR_FBCS_PAR_CS3 (0x08)
1552 #define MCF548X_GPIO_PAR_FBCS_PAR_CS4 (0x10)
1553 #define MCF548X_GPIO_PAR_FBCS_PAR_CS5 (0x20)
1554
1555 /* Bit definitions and macros for MCF548X_GPIO_PAR_DMA */
1556 #define MCF548X_GPIO_PAR_DMA_PAR_DREQ0(x) (((x)&0x03)<<0)
1557 #define MCF548X_GPIO_PAR_DMA_PAR_DREQ1(x) (((x)&0x03)<<2)
1558 #define MCF548X_GPIO_PAR_DMA_PAR_DACK0(x) (((x)&0x03)<<4)
1559 #define MCF548X_GPIO_PAR_DMA_PAR_DACK1(x) (((x)&0x03)<<6)
1560 #define MCF548X_GPIO_PAR_DMA_PAR_DACKx_GPIO (0)
1561 #define MCF548X_GPIO_PAR_DMA_PAR_DACKx_TOUT (2)
1562 #define MCF548X_GPIO_PAR_DMA_PAR_DACKx_DACK (3)
1563 #define MCF548X_GPIO_PAR_DMA_PAR_DREQx_GPIO (0)
1564 #define MCF548X_GPIO_PAR_DMA_PAR_DREQx_TIN (2)
1565 #define MCF548X_GPIO_PAR_DMA_PAR_DREQx_DREQ (3)
1566
1567 /* Bit definitions and macros for MCF548X_GPIO_PAR_FECI2CIRQ */
1568 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_IRQ5 (0x0001)
1569 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_IRQ6 (0x0002)
1570 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_SCL (0x0004)
1571 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_SDA (0x0008)
1572 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDC(x) (((x)&0x0003)<<6)
1573 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDIO(x) (((x)&0x0003)<<8)
1574 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MII (0x0400)
1575 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E17 (0x0800)
1576 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E0MDC (0x1000)
1577 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E0MDIO (0x2000)
1578 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E0MII (0x4000)
1579 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E07 (0x8000)
1580 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDIO_CANRX (0x0000)
1581 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDIO_SDA (0x0200)
1582 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDIO_EMDIO (0x0300)
1583 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDC_CANTX (0x0000)
1584 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDC_SCL (0x0080)
1585 #define MCF548X_GPIO_PAR_FECI2CIRQ_PAR_E1MDC_EMDC (0x00C0)
1586
1587 /* Bit definitions and macros for MCF548X_GPIO_PAR_PCIBG */
1588 #define MCF548X_GPIO_PAR_PCIBG_PAR_PCIBG0(x) (((x)&0x0003)<<0)
1589 #define MCF548X_GPIO_PAR_PCIBG_PAR_PCIBG1(x) (((x)&0x0003)<<2)
1590 #define MCF548X_GPIO_PAR_PCIBG_PAR_PCIBG2(x) (((x)&0x0003)<<4)
1591 #define MCF548X_GPIO_PAR_PCIBG_PAR_PCIBG3(x) (((x)&0x0003)<<6)
1592 #define MCF548X_GPIO_PAR_PCIBG_PAR_PCIBG4(x) (((x)&0x0003)<<8)
1593
1594 /* Bit definitions and macros for MCF548X_GPIO_PAR_PCIBR */
1595 #define MCF548X_GPIO_PAR_PCIBR_PAR_PCIBG0(x) (((x)&0x0003)<<0)
1596 #define MCF548X_GPIO_PAR_PCIBR_PAR_PCIBG1(x) (((x)&0x0003)<<2)
1597 #define MCF548X_GPIO_PAR_PCIBR_PAR_PCIBG2(x) (((x)&0x0003)<<4)
1598 #define MCF548X_GPIO_PAR_PCIBR_PAR_PCIBG3(x) (((x)&0x0003)<<6)
1599 #define MCF548X_GPIO_PAR_PCIBR_PAR_PCIBR4(x) (((x)&0x0003)<<8)
1600
1601 /* Bit definitions and macros for MCF548X_GPIO_PAR_PSC3 */
1602 #define MCF548X_GPIO_PAR_PSC3_PAR_TXD3 (0x04)
1603 #define MCF548X_GPIO_PAR_PSC3_PAR_RXD3 (0x08)
1604 #define MCF548X_GPIO_PAR_PSC3_PAR_RTS3(x) (((x)&0x03)<<4)
1605 #define MCF548X_GPIO_PAR_PSC3_PAR_CTS3(x) (((x)&0x03)<<6)
1606 #define MCF548X_GPIO_PAR_PSC3_PAR_CTS3_GPIO (0x00)
1607 #define MCF548X_GPIO_PAR_PSC3_PAR_CTS3_BCLK (0x80)
1608 #define MCF548X_GPIO_PAR_PSC3_PAR_CTS3_CTS (0xC0)
1609 #define MCF548X_GPIO_PAR_PSC3_PAR_RTS3_GPIO (0x00)
1610 #define MCF548X_GPIO_PAR_PSC3_PAR_RTS3_FSYNC (0x20)
1611 #define MCF548X_GPIO_PAR_PSC3_PAR_RTS3_RTS (0x30)
1612 #define MCF548X_GPIO_PAR_PSC3_PAR_CTS2_CANRX (0x40)
1613
1614 /* Bit definitions and macros for MCF548X_GPIO_PAR_PSC2 */
1615 #define MCF548X_GPIO_PAR_PSC2_PAR_TXD2 (0x04)
1616 #define MCF548X_GPIO_PAR_PSC2_PAR_RXD2 (0x08)
1617 #define MCF548X_GPIO_PAR_PSC2_PAR_RTS2(x) (((x)&0x03)<<4)
1618 #define MCF548X_GPIO_PAR_PSC2_PAR_CTS2(x) (((x)&0x03)<<6)
1619 #define MCF548X_GPIO_PAR_PSC2_PAR_CTS2_GPIO (0x00)
1620 #define MCF548X_GPIO_PAR_PSC2_PAR_CTS2_BCLK (0x80)
1621 #define MCF548X_GPIO_PAR_PSC2_PAR_CTS2_CTS (0xC0)
1622 #define MCF548X_GPIO_PAR_PSC2_PAR_RTS2_GPIO (0x00)
1623 #define MCF548X_GPIO_PAR_PSC2_PAR_RTS2_CANTX (0x10)
1624 #define MCF548X_GPIO_PAR_PSC2_PAR_RTS2_FSYNC (0x20)
1625 #define MCF548X_GPIO_PAR_PSC2_PAR_RTS2_RTS (0x30)
1626
1627 /* Bit definitions and macros for MCF548X_GPIO_PAR_PSC1 */
1628 #define MCF548X_GPIO_PAR_PSC1_PAR_TXD1 (0x04)
1629 #define MCF548X_GPIO_PAR_PSC1_PAR_RXD1 (0x08)
1630 #define MCF548X_GPIO_PAR_PSC1_PAR_RTS1(x) (((x)&0x03)<<4)
1631 #define MCF548X_GPIO_PAR_PSC1_PAR_CTS1(x) (((x)&0x03)<<6)
1632 #define MCF548X_GPIO_PAR_PSC1_PAR_CTS1_GPIO (0x00)
1633 #define MCF548X_GPIO_PAR_PSC1_PAR_CTS1_BCLK (0x80)
1634 #define MCF548X_GPIO_PAR_PSC1_PAR_CTS1_CTS (0xC0)
1635 #define MCF548X_GPIO_PAR_PSC1_PAR_RTS1_GPIO (0x00)
1636 #define MCF548X_GPIO_PAR_PSC1_PAR_RTS1_FSYNC (0x20)
1637 #define MCF548X_GPIO_PAR_PSC1_PAR_RTS1_RTS (0x30)
1638
1639 /* Bit definitions and macros for MCF548X_GPIO_PAR_PSC0 */
1640 #define MCF548X_GPIO_PAR_PSC0_PAR_TXD0 (0x04)
1641 #define MCF548X_GPIO_PAR_PSC0_PAR_RXD0 (0x08)
1642 #define MCF548X_GPIO_PAR_PSC0_PAR_RTS0(x) (((x)&0x03)<<4)
1643 #define MCF548X_GPIO_PAR_PSC0_PAR_CTS0(x) (((x)&0x03)<<6)
1644 #define MCF548X_GPIO_PAR_PSC0_PAR_CTS0_GPIO (0x00)
1645 #define MCF548X_GPIO_PAR_PSC0_PAR_CTS0_BCLK (0x80)
1646 #define MCF548X_GPIO_PAR_PSC0_PAR_CTS0_CTS (0xC0)
1647 #define MCF548X_GPIO_PAR_PSC0_PAR_RTS0_GPIO (0x00)
1648 #define MCF548X_GPIO_PAR_PSC0_PAR_RTS0_FSYNC (0x20)
1649 #define MCF548X_GPIO_PAR_PSC0_PAR_RTS0_RTS (0x30)
1650
1651 /* Bit definitions and macros for MCF548X_GPIO_PAR_DSPI */
1652 #define MCF548X_GPIO_PAR_DSPI_PAR_SOUT(x) (((x)&0x0003)<<0)
1653 #define MCF548X_GPIO_PAR_DSPI_PAR_SIN(x) (((x)&0x0003)<<2)
1654 #define MCF548X_GPIO_PAR_DSPI_PAR_SCK(x) (((x)&0x0003)<<4)
1655 #define MCF548X_GPIO_PAR_DSPI_PAR_CS0(x) (((x)&0x0003)<<6)
1656 #define MCF548X_GPIO_PAR_DSPI_PAR_CS2(x) (((x)&0x0003)<<8)
1657 #define MCF548X_GPIO_PAR_DSPI_PAR_CS3(x) (((x)&0x0003)<<10)
1658 #define MCF548X_GPIO_PAR_DSPI_PAR_CS5 (0x1000)
1659 #define MCF548X_GPIO_PAR_DSPI_PAR_CS3_GPIO (0x0000)
1660 #define MCF548X_GPIO_PAR_DSPI_PAR_CS3_CANTX (0x0400)
1661 #define MCF548X_GPIO_PAR_DSPI_PAR_CS3_TOUT (0x0800)
1662 #define MCF548X_GPIO_PAR_DSPI_PAR_CS3_DSPICS (0x0C00)
1663 #define MCF548X_GPIO_PAR_DSPI_PAR_CS2_GPIO (0x0000)
1664 #define MCF548X_GPIO_PAR_DSPI_PAR_CS2_CANTX (0x0100)
1665 #define MCF548X_GPIO_PAR_DSPI_PAR_CS2_TOUT (0x0200)
1666 #define MCF548X_GPIO_PAR_DSPI_PAR_CS2_DSPICS (0x0300)
1667 #define MCF548X_GPIO_PAR_DSPI_PAR_CS0_GPIO (0x0000)
1668 #define MCF548X_GPIO_PAR_DSPI_PAR_CS0_FSYNC (0x0040)
1669 #define MCF548X_GPIO_PAR_DSPI_PAR_CS0_RTS (0x0080)
1670 #define MCF548X_GPIO_PAR_DSPI_PAR_CS0_DSPICS (0x00C0)
1671 #define MCF548X_GPIO_PAR_DSPI_PAR_SCK_GPIO (0x0000)
1672 #define MCF548X_GPIO_PAR_DSPI_PAR_SCK_BCLK (0x0010)
1673 #define MCF548X_GPIO_PAR_DSPI_PAR_SCK_CTS (0x0020)
1674 #define MCF548X_GPIO_PAR_DSPI_PAR_SCK_SCK (0x0030)
1675 #define MCF548X_GPIO_PAR_DSPI_PAR_SIN_GPIO (0x0000)
1676 #define MCF548X_GPIO_PAR_DSPI_PAR_SIN_RXD (0x0008)
1677 #define MCF548X_GPIO_PAR_DSPI_PAR_SIN_SIN (0x000C)
1678 #define MCF548X_GPIO_PAR_DSPI_PAR_SOUT_GPIO (0x0000)
1679 #define MCF548X_GPIO_PAR_DSPI_PAR_SOUT_TXD (0x0002)
1680 #define MCF548X_GPIO_PAR_DSPI_PAR_SOUT_SOUT (0x0003)
1681
1682 /* Bit definitions and macros for MCF548X_GPIO_PAR_TIMER */
1683 #define MCF548X_GPIO_PAR_TIMER_PAR_TOUT2 (0x01)
1684 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN2(x) (((x)&0x03)<<1)
1685 #define MCF548X_GPIO_PAR_TIMER_PAR_TOUT3 (0x08)
1686 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN3(x) (((x)&0x03)<<4)
1687 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN3_CANRX (0x00)
1688 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN3_IRQ (0x20)
1689 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN3_TIN (0x30)
1690 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN2_CANRX (0x00)
1691 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN2_IRQ (0x04)
1692 #define MCF548X_GPIO_PAR_TIMER_PAR_TIN2_TIN (0x06)
1693
1694 /*********************************************************************
1695 *
1696 * General Purpose Timers (GPT)
1697 *
1698 *********************************************************************/
1699
1700 /* Register read/write macros */
1701 #define MCF548X_GPT_GMS0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000800)))
1702 #define MCF548X_GPT_GCIR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000804)))
1703 #define MCF548X_GPT_GPWM0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000808)))
1704 #define MCF548X_GPT_GSR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00080C)))
1705 #define MCF548X_GPT_GMS1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000810)))
1706 #define MCF548X_GPT_GCIR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000814)))
1707 #define MCF548X_GPT_GPWM1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000818)))
1708 #define MCF548X_GPT_GSR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00081C)))
1709 #define MCF548X_GPT_GMS2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000820)))
1710 #define MCF548X_GPT_GCIR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000824)))
1711 #define MCF548X_GPT_GPWM2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000828)))
1712 #define MCF548X_GPT_GSR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00082C)))
1713 #define MCF548X_GPT_GMS3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000830)))
1714 #define MCF548X_GPT_GCIR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000834)))
1715 #define MCF548X_GPT_GPWM3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000838)))
1716 #define MCF548X_GPT_GSR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00083C)))
1717 #define MCF548X_GPT_GMS(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000800U+((x)*0x010))))
1718 #define MCF548X_GPT_GCIR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000804U+((x)*0x010))))
1719 #define MCF548X_GPT_GPWM(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000808U+((x)*0x010))))
1720 #define MCF548X_GPT_GSR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00080CU+((x)*0x010))))
1721
1722 /* Bit definitions and macros for MCF548X_GPT_GMS */
1723 #define MCF548X_GPT_GMS_TMS(x) (((x)&0x00000007)<<0)
1724 #define MCF548X_GPT_GMS_GPIO(x) (((x)&0x00000003)<<4)
1725 #define MCF548X_GPT_GMS_IEN (0x00000100)
1726 #define MCF548X_GPT_GMS_OD (0x00000200)
1727 #define MCF548X_GPT_GMS_SC (0x00000400)
1728 #define MCF548X_GPT_GMS_CE (0x00001000)
1729 #define MCF548X_GPT_GMS_WDEN (0x00008000)
1730 #define MCF548X_GPT_GMS_ICT(x) (((x)&0x00000003)<<16)
1731 #define MCF548X_GPT_GMS_OCT(x) (((x)&0x00000003)<<20)
1732 #define MCF548X_GPT_GMS_OCPW(x) (((x)&0x000000FF)<<24)
1733 #define MCF548X_GPT_GMS_OCT_FRCLOW (0x00000000)
1734 #define MCF548X_GPT_GMS_OCT_PULSEHI (0x00100000)
1735 #define MCF548X_GPT_GMS_OCT_PULSELO (0x00200000)
1736 #define MCF548X_GPT_GMS_OCT_TOGGLE (0x00300000)
1737 #define MCF548X_GPT_GMS_ICT_ANY (0x00000000)
1738 #define MCF548X_GPT_GMS_ICT_RISE (0x00010000)
1739 #define MCF548X_GPT_GMS_ICT_FALL (0x00020000)
1740 #define MCF548X_GPT_GMS_ICT_PULSE (0x00030000)
1741 #define MCF548X_GPT_GMS_GPIO_INPUT (0x00000000)
1742 #define MCF548X_GPT_GMS_GPIO_OUTLO (0x00000020)
1743 #define MCF548X_GPT_GMS_GPIO_OUTHI (0x00000030)
1744 #define MCF548X_GPT_GMS_TMS_DISABLE (0x00000000)
1745 #define MCF548X_GPT_GMS_TMS_INCAPT (0x00000001)
1746 #define MCF548X_GPT_GMS_TMS_OUTCAPT (0x00000002)
1747 #define MCF548X_GPT_GMS_TMS_PWM (0x00000003)
1748 #define MCF548X_GPT_GMS_TMS_GPIO (0x00000004)
1749
1750 /* Bit definitions and macros for MCF548X_GPT_GCIR */
1751 #define MCF548X_GPT_GCIR_CNT(x) (((x)&0x0000FFFF)<<0)
1752 #define MCF548X_GPT_GCIR_PRE(x) (((x)&0x0000FFFF)<<16)
1753
1754 /* Bit definitions and macros for MCF548X_GPT_GPWM */
1755 #define MCF548X_GPT_GPWM_LOAD (0x00000001)
1756 #define MCF548X_GPT_GPWM_PWMOP (0x00000100)
1757 #define MCF548X_GPT_GPWM_WIDTH(x) (((x)&0x0000FFFF)<<16)
1758
1759 /* Bit definitions and macros for MCF548X_GPT_GSR */
1760 #define MCF548X_GPT_GSR_CAPT (0x00000001)
1761 #define MCF548X_GPT_GSR_COMP (0x00000002)
1762 #define MCF548X_GPT_GSR_PWMP (0x00000004)
1763 #define MCF548X_GPT_GSR_TEXP (0x00000008)
1764 #define MCF548X_GPT_GSR_PIN (0x00000100)
1765 #define MCF548X_GPT_GSR_OVF(x) (((x)&0x00000007)<<12)
1766 #define MCF548X_GPT_GSR_CAPTURE(x) (((x)&0x0000FFFF)<<16)
1767
1768
1769 /*********************************************************************
1770 *
1771 * I2C Module (I2C)
1772 *
1773 *********************************************************************/
1774
1775 /* Register read/write macros */
1776 #define MCF548X_I2C_I2AR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008F00)))
1777 #define MCF548X_I2C_I2FDR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008F04)))
1778 #define MCF548X_I2C_I2CR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008F08)))
1779 #define MCF548X_I2C_I2SR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008F0C)))
1780 #define MCF548X_I2C_I2DR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008F10)))
1781 #define MCF548X_I2C_I2ICR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008F20)))
1782
1783 /* Bit definitions and macros for MCF548X_I2C_I2AR */
1784 #define MCF548X_I2C_I2AR_ADR(x) (((x)&0x7F)<<1)
1785
1786 /* Bit definitions and macros for MCF548X_I2C_I2FDR */
1787 #define MCF548X_I2C_I2FDR_IC(x) (((x)&0x3F)<<0)
1788
1789 /* Bit definitions and macros for MCF548X_I2C_I2CR */
1790 #define MCF548X_I2C_I2CR_RSTA (0x04)
1791 #define MCF548X_I2C_I2CR_TXAK (0x08)
1792 #define MCF548X_I2C_I2CR_MTX (0x10)
1793 #define MCF548X_I2C_I2CR_MSTA (0x20)
1794 #define MCF548X_I2C_I2CR_IIEN (0x40)
1795 #define MCF548X_I2C_I2CR_IEN (0x80)
1796
1797 /* Bit definitions and macros for MCF548X_I2C_I2SR */
1798 #define MCF548X_I2C_I2SR_RXAK (0x01)
1799 #define MCF548X_I2C_I2SR_IIF (0x02)
1800 #define MCF548X_I2C_I2SR_SRW (0x04)
1801 #define MCF548X_I2C_I2SR_IAL (0x10)
1802 #define MCF548X_I2C_I2SR_IBB (0x20)
1803 #define MCF548X_I2C_I2SR_IAAS (0x40)
1804 #define MCF548X_I2C_I2SR_ICF (0x80)
1805
1806 /* Bit definitions and macros for MCF548X_I2C_I2ICR */
1807 #define MCF548X_I2C_I2ICR_IE (0x01)
1808 #define MCF548X_I2C_I2ICR_RE (0x02)
1809 #define MCF548X_I2C_I2ICR_TE (0x04)
1810 #define MCF548X_I2C_I2ICR_BNBE (0x08)
1811
1812 /*********************************************************************
1813 *
1814 * Interrupt Controller (INTC)
1815 *
1816 *********************************************************************/
1817
1818 /* Register read/write macros */
1819 #define MCF548X_INTC_IPRH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000700)))
1820 #define MCF548X_INTC_IPRL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000704)))
1821 #define MCF548X_INTC_IMRH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000708)))
1822 #define MCF548X_INTC_IMRL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00070C)))
1823 #define MCF548X_INTC_INTFRCH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000710)))
1824 #define MCF548X_INTC_INTFRCL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000714)))
1825 #define MCF548X_INTC_IRLR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000718)))
1826 #define MCF548X_INTC_IACKLPR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000719)))
1827 #define MCF548X_INTC_ICR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000740)))
1828 #define MCF548X_INTC_ICR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000741)))
1829 #define MCF548X_INTC_ICR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000742)))
1830 #define MCF548X_INTC_ICR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000743)))
1831 #define MCF548X_INTC_ICR4 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000744)))
1832 #define MCF548X_INTC_ICR5 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000745)))
1833 #define MCF548X_INTC_ICR6 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000746)))
1834 #define MCF548X_INTC_ICR7 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000747)))
1835 #define MCF548X_INTC_ICR8 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000748)))
1836 #define MCF548X_INTC_ICR9 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000749)))
1837 #define MCF548X_INTC_ICR10 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00074A)))
1838 #define MCF548X_INTC_ICR11 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00074B)))
1839 #define MCF548X_INTC_ICR12 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00074C)))
1840 #define MCF548X_INTC_ICR13 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00074D)))
1841 #define MCF548X_INTC_ICR14 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00074E)))
1842 #define MCF548X_INTC_ICR15 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00074F)))
1843 #define MCF548X_INTC_ICR16 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000750)))
1844 #define MCF548X_INTC_ICR17 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000751)))
1845 #define MCF548X_INTC_ICR18 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000752)))
1846 #define MCF548X_INTC_ICR19 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000753)))
1847 #define MCF548X_INTC_ICR20 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000754)))
1848 #define MCF548X_INTC_ICR21 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000755)))
1849 #define MCF548X_INTC_ICR22 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000756)))
1850 #define MCF548X_INTC_ICR23 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000757)))
1851 #define MCF548X_INTC_ICR24 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000758)))
1852 #define MCF548X_INTC_ICR25 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000759)))
1853 #define MCF548X_INTC_ICR26 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00075A)))
1854 #define MCF548X_INTC_ICR27 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00075B)))
1855 #define MCF548X_INTC_ICR28 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00075C)))
1856 #define MCF548X_INTC_ICR29 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00075D)))
1857 #define MCF548X_INTC_ICR30 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00075E)))
1858 #define MCF548X_INTC_ICR31 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00075F)))
1859 #define MCF548X_INTC_ICR32 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000760)))
1860 #define MCF548X_INTC_ICR33 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000761)))
1861 #define MCF548X_INTC_ICR34 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000762)))
1862 #define MCF548X_INTC_ICR35 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000763)))
1863 #define MCF548X_INTC_ICR36 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000764)))
1864 #define MCF548X_INTC_ICR37 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000765)))
1865 #define MCF548X_INTC_ICR38 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000766)))
1866 #define MCF548X_INTC_ICR39 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000767)))
1867 #define MCF548X_INTC_ICR40 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000768)))
1868 #define MCF548X_INTC_ICR41 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000769)))
1869 #define MCF548X_INTC_ICR42 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00076A)))
1870 #define MCF548X_INTC_ICR43 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00076B)))
1871 #define MCF548X_INTC_ICR44 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00076C)))
1872 #define MCF548X_INTC_ICR45 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00076D)))
1873 #define MCF548X_INTC_ICR46 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00076E)))
1874 #define MCF548X_INTC_ICR47 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00076F)))
1875 #define MCF548X_INTC_ICR48 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000770)))
1876 #define MCF548X_INTC_ICR49 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000771)))
1877 #define MCF548X_INTC_ICR50 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000772)))
1878 #define MCF548X_INTC_ICR51 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000773)))
1879 #define MCF548X_INTC_ICR52 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000774)))
1880 #define MCF548X_INTC_ICR53 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000775)))
1881 #define MCF548X_INTC_ICR54 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000776)))
1882 #define MCF548X_INTC_ICR55 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000777)))
1883 #define MCF548X_INTC_ICR56 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000778)))
1884 #define MCF548X_INTC_ICR57 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000779)))
1885 #define MCF548X_INTC_ICR58 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00077A)))
1886 #define MCF548X_INTC_ICR59 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00077B)))
1887 #define MCF548X_INTC_ICR60 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00077C)))
1888 #define MCF548X_INTC_ICR61 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00077D)))
1889 #define MCF548X_INTC_ICR62 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00077E)))
1890 #define MCF548X_INTC_ICR63 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00077F)))
1891 #define MCF548X_INTC_ICRn(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x000740U+((x)*0x001))))
1892 #define MCF548X_INTC_SWIACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007E0)))
1893 #define MCF548X_INTC_L1IACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007E4)))
1894 #define MCF548X_INTC_L2IACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007E8)))
1895 #define MCF548X_INTC_L3IACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007EC)))
1896 #define MCF548X_INTC_L4IACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007F0)))
1897 #define MCF548X_INTC_L5IACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007F4)))
1898 #define MCF548X_INTC_L6IACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007F8)))
1899 #define MCF548X_INTC_L7IACK (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007FC)))
1900 #define MCF548X_INTC_LnIACK(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x0007E4U+((x)*0x004))))
1901
1902 /* Bit definitions and macros for MCF548X_INTC_IPRH */
1903 #define MCF548X_INTC_IPRH_INT32 (0x00000001)
1904 #define MCF548X_INTC_IPRH_INT33 (0x00000002)
1905 #define MCF548X_INTC_IPRH_INT34 (0x00000004)
1906 #define MCF548X_INTC_IPRH_INT35 (0x00000008)
1907 #define MCF548X_INTC_IPRH_INT36 (0x00000010)
1908 #define MCF548X_INTC_IPRH_INT37 (0x00000020)
1909 #define MCF548X_INTC_IPRH_INT38 (0x00000040)
1910 #define MCF548X_INTC_IPRH_INT39 (0x00000080)
1911 #define MCF548X_INTC_IPRH_INT40 (0x00000100)
1912 #define MCF548X_INTC_IPRH_INT41 (0x00000200)
1913 #define MCF548X_INTC_IPRH_INT42 (0x00000400)
1914 #define MCF548X_INTC_IPRH_INT43 (0x00000800)
1915 #define MCF548X_INTC_IPRH_INT44 (0x00001000)
1916 #define MCF548X_INTC_IPRH_INT45 (0x00002000)
1917 #define MCF548X_INTC_IPRH_INT46 (0x00004000)
1918 #define MCF548X_INTC_IPRH_INT47 (0x00008000)
1919 #define MCF548X_INTC_IPRH_INT48 (0x00010000)
1920 #define MCF548X_INTC_IPRH_INT49 (0x00020000)
1921 #define MCF548X_INTC_IPRH_INT50 (0x00040000)
1922 #define MCF548X_INTC_IPRH_INT51 (0x00080000)
1923 #define MCF548X_INTC_IPRH_INT52 (0x00100000)
1924 #define MCF548X_INTC_IPRH_INT53 (0x00200000)
1925 #define MCF548X_INTC_IPRH_INT54 (0x00400000)
1926 #define MCF548X_INTC_IPRH_INT55 (0x00800000)
1927 #define MCF548X_INTC_IPRH_INT56 (0x01000000)
1928 #define MCF548X_INTC_IPRH_INT57 (0x02000000)
1929 #define MCF548X_INTC_IPRH_INT58 (0x04000000)
1930 #define MCF548X_INTC_IPRH_INT59 (0x08000000)
1931 #define MCF548X_INTC_IPRH_INT60 (0x10000000)
1932 #define MCF548X_INTC_IPRH_INT61 (0x20000000)
1933 #define MCF548X_INTC_IPRH_INT62 (0x40000000)
1934 #define MCF548X_INTC_IPRH_INT63 (0x80000000)
1935
1936 /* Bit definitions and macros for MCF548X_INTC_IPRL */
1937 #define MCF548X_INTC_IPRL_INT1 (0x00000002)
1938 #define MCF548X_INTC_IPRL_INT2 (0x00000004)
1939 #define MCF548X_INTC_IPRL_INT3 (0x00000008)
1940 #define MCF548X_INTC_IPRL_INT4 (0x00000010)
1941 #define MCF548X_INTC_IPRL_INT5 (0x00000020)
1942 #define MCF548X_INTC_IPRL_INT6 (0x00000040)
1943 #define MCF548X_INTC_IPRL_INT7 (0x00000080)
1944 #define MCF548X_INTC_IPRL_INT8 (0x00000100)
1945 #define MCF548X_INTC_IPRL_INT9 (0x00000200)
1946 #define MCF548X_INTC_IPRL_INT10 (0x00000400)
1947 #define MCF548X_INTC_IPRL_INT11 (0x00000800)
1948 #define MCF548X_INTC_IPRL_INT12 (0x00001000)
1949 #define MCF548X_INTC_IPRL_INT13 (0x00002000)
1950 #define MCF548X_INTC_IPRL_INT14 (0x00004000)
1951 #define MCF548X_INTC_IPRL_INT15 (0x00008000)
1952 #define MCF548X_INTC_IPRL_INT16 (0x00010000)
1953 #define MCF548X_INTC_IPRL_INT17 (0x00020000)
1954 #define MCF548X_INTC_IPRL_INT18 (0x00040000)
1955 #define MCF548X_INTC_IPRL_INT19 (0x00080000)
1956 #define MCF548X_INTC_IPRL_INT20 (0x00100000)
1957 #define MCF548X_INTC_IPRL_INT21 (0x00200000)
1958 #define MCF548X_INTC_IPRL_INT22 (0x00400000)
1959 #define MCF548X_INTC_IPRL_INT23 (0x00800000)
1960 #define MCF548X_INTC_IPRL_INT24 (0x01000000)
1961 #define MCF548X_INTC_IPRL_INT25 (0x02000000)
1962 #define MCF548X_INTC_IPRL_INT26 (0x04000000)
1963 #define MCF548X_INTC_IPRL_INT27 (0x08000000)
1964 #define MCF548X_INTC_IPRL_INT28 (0x10000000)
1965 #define MCF548X_INTC_IPRL_INT29 (0x20000000)
1966 #define MCF548X_INTC_IPRL_INT30 (0x40000000)
1967 #define MCF548X_INTC_IPRL_INT31 (0x80000000)
1968
1969 /* Bit definitions and macros for MCF548X_INTC_IMRH */
1970 #define MCF548X_INTC_IMRH_INT_MASK32 (0x00000001)
1971 #define MCF548X_INTC_IMRH_INT_MASK33 (0x00000002)
1972 #define MCF548X_INTC_IMRH_INT_MASK34 (0x00000004)
1973 #define MCF548X_INTC_IMRH_INT_MASK35 (0x00000008)
1974 #define MCF548X_INTC_IMRH_INT_MASK36 (0x00000010)
1975 #define MCF548X_INTC_IMRH_INT_MASK37 (0x00000020)
1976 #define MCF548X_INTC_IMRH_INT_MASK38 (0x00000040)
1977 #define MCF548X_INTC_IMRH_INT_MASK39 (0x00000080)
1978 #define MCF548X_INTC_IMRH_INT_MASK40 (0x00000100)
1979 #define MCF548X_INTC_IMRH_INT_MASK41 (0x00000200)
1980 #define MCF548X_INTC_IMRH_INT_MASK42 (0x00000400)
1981 #define MCF548X_INTC_IMRH_INT_MASK43 (0x00000800)
1982 #define MCF548X_INTC_IMRH_INT_MASK44 (0x00001000)
1983 #define MCF548X_INTC_IMRH_INT_MASK45 (0x00002000)
1984 #define MCF548X_INTC_IMRH_INT_MASK46 (0x00004000)
1985 #define MCF548X_INTC_IMRH_INT_MASK47 (0x00008000)
1986 #define MCF548X_INTC_IMRH_INT_MASK48 (0x00010000)
1987 #define MCF548X_INTC_IMRH_INT_MASK49 (0x00020000)
1988 #define MCF548X_INTC_IMRH_INT_MASK50 (0x00040000)
1989 #define MCF548X_INTC_IMRH_INT_MASK51 (0x00080000)
1990 #define MCF548X_INTC_IMRH_INT_MASK52 (0x00100000)
1991 #define MCF548X_INTC_IMRH_INT_MASK53 (0x00200000)
1992 #define MCF548X_INTC_IMRH_INT_MASK54 (0x00400000)
1993 #define MCF548X_INTC_IMRH_INT_MASK55 (0x00800000)
1994 #define MCF548X_INTC_IMRH_INT_MASK56 (0x01000000)
1995 #define MCF548X_INTC_IMRH_INT_MASK57 (0x02000000)
1996 #define MCF548X_INTC_IMRH_INT_MASK58 (0x04000000)
1997 #define MCF548X_INTC_IMRH_INT_MASK59 (0x08000000)
1998 #define MCF548X_INTC_IMRH_INT_MASK60 (0x10000000)
1999 #define MCF548X_INTC_IMRH_INT_MASK61 (0x20000000)
2000 #define MCF548X_INTC_IMRH_INT_MASK62 (0x40000000)
2001 #define MCF548X_INTC_IMRH_INT_MASK63 (0x80000000)
2002
2003 /* Bit definitions and macros for MCF548X_INTC_IMRL */
2004 #define MCF548X_INTC_IMRL_MASKALL (0x00000001)
2005 #define MCF548X_INTC_IMRL_INT_MASK1 (0x00000002)
2006 #define MCF548X_INTC_IMRL_INT_MASK2 (0x00000004)
2007 #define MCF548X_INTC_IMRL_INT_MASK3 (0x00000008)
2008 #define MCF548X_INTC_IMRL_INT_MASK4 (0x00000010)
2009 #define MCF548X_INTC_IMRL_INT_MASK5 (0x00000020)
2010 #define MCF548X_INTC_IMRL_INT_MASK6 (0x00000040)
2011 #define MCF548X_INTC_IMRL_INT_MASK7 (0x00000080)
2012 #define MCF548X_INTC_IMRL_INT_MASK8 (0x00000100)
2013 #define MCF548X_INTC_IMRL_INT_MASK9 (0x00000200)
2014 #define MCF548X_INTC_IMRL_INT_MASK10 (0x00000400)
2015 #define MCF548X_INTC_IMRL_INT_MASK11 (0x00000800)
2016 #define MCF548X_INTC_IMRL_INT_MASK12 (0x00001000)
2017 #define MCF548X_INTC_IMRL_INT_MASK13 (0x00002000)
2018 #define MCF548X_INTC_IMRL_INT_MASK14 (0x00004000)
2019 #define MCF548X_INTC_IMRL_INT_MASK15 (0x00008000)
2020 #define MCF548X_INTC_IMRL_INT_MASK16 (0x00010000)
2021 #define MCF548X_INTC_IMRL_INT_MASK17 (0x00020000)
2022 #define MCF548X_INTC_IMRL_INT_MASK18 (0x00040000)
2023 #define MCF548X_INTC_IMRL_INT_MASK19 (0x00080000)
2024 #define MCF548X_INTC_IMRL_INT_MASK20 (0x00100000)
2025 #define MCF548X_INTC_IMRL_INT_MASK21 (0x00200000)
2026 #define MCF548X_INTC_IMRL_INT_MASK22 (0x00400000)
2027 #define MCF548X_INTC_IMRL_INT_MASK23 (0x00800000)
2028 #define MCF548X_INTC_IMRL_INT_MASK24 (0x01000000)
2029 #define MCF548X_INTC_IMRL_INT_MASK25 (0x02000000)
2030 #define MCF548X_INTC_IMRL_INT_MASK26 (0x04000000)
2031 #define MCF548X_INTC_IMRL_INT_MASK27 (0x08000000)
2032 #define MCF548X_INTC_IMRL_INT_MASK28 (0x10000000)
2033 #define MCF548X_INTC_IMRL_INT_MASK29 (0x20000000)
2034 #define MCF548X_INTC_IMRL_INT_MASK30 (0x40000000)
2035 #define MCF548X_INTC_IMRL_INT_MASK31 (0x80000000)
2036
2037 /* Bit definitions and macros for MCF548X_INTC_INTFRCH */
2038 #define MCF548X_INTC_INTFRCH_INTFRC32 (0x00000001)
2039 #define MCF548X_INTC_INTFRCH_INTFRC33 (0x00000002)
2040 #define MCF548X_INTC_INTFRCH_INTFRC34 (0x00000004)
2041 #define MCF548X_INTC_INTFRCH_INTFRC35 (0x00000008)
2042 #define MCF548X_INTC_INTFRCH_INTFRC36 (0x00000010)
2043 #define MCF548X_INTC_INTFRCH_INTFRC37 (0x00000020)
2044 #define MCF548X_INTC_INTFRCH_INTFRC38 (0x00000040)
2045 #define MCF548X_INTC_INTFRCH_INTFRC39 (0x00000080)
2046 #define MCF548X_INTC_INTFRCH_INTFRC40 (0x00000100)
2047 #define MCF548X_INTC_INTFRCH_INTFRC41 (0x00000200)
2048 #define MCF548X_INTC_INTFRCH_INTFRC42 (0x00000400)
2049 #define MCF548X_INTC_INTFRCH_INTFRC43 (0x00000800)
2050 #define MCF548X_INTC_INTFRCH_INTFRC44 (0x00001000)
2051 #define MCF548X_INTC_INTFRCH_INTFRC45 (0x00002000)
2052 #define MCF548X_INTC_INTFRCH_INTFRC46 (0x00004000)
2053 #define MCF548X_INTC_INTFRCH_INTFRC47 (0x00008000)
2054 #define MCF548X_INTC_INTFRCH_INTFRC48 (0x00010000)
2055 #define MCF548X_INTC_INTFRCH_INTFRC49 (0x00020000)
2056 #define MCF548X_INTC_INTFRCH_INTFRC50 (0x00040000)
2057 #define MCF548X_INTC_INTFRCH_INTFRC51 (0x00080000)
2058 #define MCF548X_INTC_INTFRCH_INTFRC52 (0x00100000)
2059 #define MCF548X_INTC_INTFRCH_INTFRC53 (0x00200000)
2060 #define MCF548X_INTC_INTFRCH_INTFRC54 (0x00400000)
2061 #define MCF548X_INTC_INTFRCH_INTFRC55 (0x00800000)
2062 #define MCF548X_INTC_INTFRCH_INTFRC56 (0x01000000)
2063 #define MCF548X_INTC_INTFRCH_INTFRC57 (0x02000000)
2064 #define MCF548X_INTC_INTFRCH_INTFRC58 (0x04000000)
2065 #define MCF548X_INTC_INTFRCH_INTFRC59 (0x08000000)
2066 #define MCF548X_INTC_INTFRCH_INTFRC60 (0x10000000)
2067 #define MCF548X_INTC_INTFRCH_INTFRC61 (0x20000000)
2068 #define MCF548X_INTC_INTFRCH_INTFRC62 (0x40000000)
2069 #define MCF548X_INTC_INTFRCH_INTFRC63 (0x80000000)
2070
2071 /* Bit definitions and macros for MCF548X_INTC_INTFRCL */
2072 #define MCF548X_INTC_INTFRCL_INTFRC1 (0x00000002)
2073 #define MCF548X_INTC_INTFRCL_INTFRC2 (0x00000004)
2074 #define MCF548X_INTC_INTFRCL_INTFRC3 (0x00000008)
2075 #define MCF548X_INTC_INTFRCL_INTFRC4 (0x00000010)
2076 #define MCF548X_INTC_INTFRCL_INTFRC5 (0x00000020)
2077 #define MCF548X_INTC_INTFRCL_INT6 (0x00000040)
2078 #define MCF548X_INTC_INTFRCL_INT7 (0x00000080)
2079 #define MCF548X_INTC_INTFRCL_INT8 (0x00000100)
2080 #define MCF548X_INTC_INTFRCL_INT9 (0x00000200)
2081 #define MCF548X_INTC_INTFRCL_INT10 (0x00000400)
2082 #define MCF548X_INTC_INTFRCL_INTFRC11 (0x00000800)
2083 #define MCF548X_INTC_INTFRCL_INTFRC12 (0x00001000)
2084 #define MCF548X_INTC_INTFRCL_INTFRC13 (0x00002000)
2085 #define MCF548X_INTC_INTFRCL_INTFRC14 (0x00004000)
2086 #define MCF548X_INTC_INTFRCL_INT15 (0x00008000)
2087 #define MCF548X_INTC_INTFRCL_INTFRC16 (0x00010000)
2088 #define MCF548X_INTC_INTFRCL_INTFRC17 (0x00020000)
2089 #define MCF548X_INTC_INTFRCL_INTFRC18 (0x00040000)
2090 #define MCF548X_INTC_INTFRCL_INTFRC19 (0x00080000)
2091 #define MCF548X_INTC_INTFRCL_INTFRC20 (0x00100000)
2092 #define MCF548X_INTC_INTFRCL_INTFRC21 (0x00200000)
2093 #define MCF548X_INTC_INTFRCL_INTFRC22 (0x00400000)
2094 #define MCF548X_INTC_INTFRCL_INTFRC23 (0x00800000)
2095 #define MCF548X_INTC_INTFRCL_INTFRC24 (0x01000000)
2096 #define MCF548X_INTC_INTFRCL_INTFRC25 (0x02000000)
2097 #define MCF548X_INTC_INTFRCL_INTFRC26 (0x04000000)
2098 #define MCF548X_INTC_INTFRCL_INTFRC27 (0x08000000)
2099 #define MCF548X_INTC_INTFRCL_INTFRC28 (0x10000000)
2100 #define MCF548X_INTC_INTFRCL_INTFRC29 (0x20000000)
2101 #define MCF548X_INTC_INTFRCL_INTFRC30 (0x40000000)
2102 #define MCF548X_INTC_INTFRCL_INTFRC31 (0x80000000)
2103
2104 /* Bit definitions and macros for MCF548X_INTC_IRLR */
2105 #define MCF548X_INTC_IRLR_IRQ(x) (((x)&0x7F)<<1)
2106
2107 /* Bit definitions and macros for MCF548X_INTC_IACKLPR */
2108 #define MCF548X_INTC_IACKLPR_PRI(x) (((x)&0x0F)<<0)
2109 #define MCF548X_INTC_IACKLPR_LEVEL(x) (((x)&0x07)<<4)
2110
2111 /* Bit definitions and macros for MCF548X_INTC_ICRn */
2112 #define MCF548X_INTC_ICRn_IP(x) (((x)&0x07)<<0)
2113 #define MCF548X_INTC_ICRn_IL(x) (((x)&0x07)<<3)
2114
2115
2116 /*********************************************************************
2117 *
2118 * SDRAM Controller (SDRAMC)
2119 *
2120 *********************************************************************/
2121
2122 /* Register read/write macros */
2123 #define MCF548X_SDRAMC_SDRAMDS (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000004)))
2124 #define MCF548X_SDRAMC_CS0CFG (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000020)))
2125 #define MCF548X_SDRAMC_CS1CFG (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000024)))
2126 #define MCF548X_SDRAMC_CS2CFG (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000028)))
2127 #define MCF548X_SDRAMC_CS3CFG (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00002C)))
2128 #define MCF548X_SDRAMC_CSnCFG(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000020U+((x)*0x004))))
2129 #define MCF548X_SDRAMC_SDMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000100)))
2130 #define MCF548X_SDRAMC_SDCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000104)))
2131 #define MCF548X_SDRAMC_SDCFG1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000108)))
2132 #define MCF548X_SDRAMC_SDCFG2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00010C)))
2133
2134 /* Bit definitions and macros for MCF548X_SDRAMC_SDRAMDS */
2135 #define MCF548X_SDRAMC_SDRAMDS_SB_D(x) (((x)&0x00000003)<<0)
2136 #define MCF548X_SDRAMC_SDRAMDS_SB_S(x) (((x)&0x00000003)<<2)
2137 #define MCF548X_SDRAMC_SDRAMDS_SB_A(x) (((x)&0x00000003)<<4)
2138 #define MCF548X_SDRAMC_SDRAMDS_SB_C(x) (((x)&0x00000003)<<6)
2139 #define MCF548X_SDRAMC_SDRAMDS_SB_E(x) (((x)&0x00000003)<<8)
2140 #define MCF548X_SDRAMC_SDRAMDS_DRIVE_8MA (0x02)
2141 #define MCF548X_SDRAMC_SDRAMDS_DRIVE_16MA (0x01)
2142 #define MCF548X_SDRAMC_SDRAMDS_DRIVE_24MA (0x00)
2143 #define MCF548X_SDRAMC_SDRAMDS_DRIVE_NONE (0x03)
2144
2145 /* Bit definitions and macros for MCF548X_SDRAMC_CSnCFG */
2146 #define MCF548X_SDRAMC_CSnCFG_CSSZ(x) (((x)&0x0000001F)<<0)
2147 #define MCF548X_SDRAMC_CSnCFG_CSBA(x) (((x)&0x00000FFF)<<20)
2148 #define MCF548X_SDRAMC_CSnCFG_CSSZ_DIABLE (0x00000000)
2149 #define MCF548X_SDRAMC_CSnCFG_CSSZ_1MBYTE (0x00000013)
2150 #define MCF548X_SDRAMC_CSnCFG_CSSZ_2MBYTE (0x00000014)
2151 #define MCF548X_SDRAMC_CSnCFG_CSSZ_4MBYTE (0x00000015)
2152 #define MCF548X_SDRAMC_CSnCFG_CSSZ_8MBYTE (0x00000016)
2153 #define MCF548X_SDRAMC_CSnCFG_CSSZ_16MBYTE (0x00000017)
2154 #define MCF548X_SDRAMC_CSnCFG_CSSZ_32MBYTE (0x00000018)
2155 #define MCF548X_SDRAMC_CSnCFG_CSSZ_64MBYTE (0x00000019)
2156 #define MCF548X_SDRAMC_CSnCFG_CSSZ_128MBYTE (0x0000001A)
2157 #define MCF548X_SDRAMC_CSnCFG_CSSZ_256MBYTE (0x0000001B)
2158 #define MCF548X_SDRAMC_CSnCFG_CSSZ_512MBYTE (0x0000001C)
2159 #define MCF548X_SDRAMC_CSnCFG_CSSZ_1GBYTE (0x0000001D)
2160 #define MCF548X_SDRAMC_CSnCFG_CSSZ_2GBYTE (0x0000001E)
2161 #define MCF548X_SDRAMC_CSnCFG_CSSZ_4GBYTE (0x0000001F)
2162
2163 /* Bit definitions and macros for MCF548X_SDRAMC_SDMR */
2164 #define MCF548X_SDRAMC_SDMR_CMD (0x00010000)
2165 #define MCF548X_SDRAMC_SDMR_AD(x) (((x)&0x00000FFF)<<18)
2166 #define MCF548X_SDRAMC_SDMR_BNKAD(x) (((x)&0x00000003)<<30)
2167 #define MCF548X_SDRAMC_SDMR_BNKAD_LMR (0x00000000)
2168 #define MCF548X_SDRAMC_SDMR_BNKAD_LEMR (0x40000000)
2169
2170 /* Bit definitions and macros for MCF548X_SDRAMC_SDCR */
2171 #define MCF548X_SDRAMC_SDCR_IPALL (0x00000002)
2172 #define MCF548X_SDRAMC_SDCR_IREF (0x00000004)
2173 #define MCF548X_SDRAMC_SDCR_BUFF (0x00000010)
2174 #define MCF548X_SDRAMC_SDCR_DQS_OE(x) (((x)&0x0000000F)<<8)
2175 #define MCF548X_SDRAMC_SDCR_RCNT(x) (((x)&0x0000003F)<<16)
2176 #define MCF548X_SDRAMC_SDCR_DRIVE (0x00400000)
2177 #define MCF548X_SDRAMC_SDCR_AP (0x00800000)
2178 #define MCF548X_SDRAMC_SDCR_MUX(x) (((x)&0x00000003)<<24)
2179 #define MCF548X_SDRAMC_SDCR_REF (0x10000000)
2180 #define MCF548X_SDRAMC_SDCR_DDR (0x20000000)
2181 #define MCF548X_SDRAMC_SDCR_CKE (0x40000000)
2182 #define MCF548X_SDRAMC_SDCR_MODE_EN (0x80000000)
2183
2184 /* Bit definitions and macros for MCF548X_SDRAMC_SDCFG1 */
2185 #define MCF548X_SDRAMC_SDCFG1_WTLAT(x) (((x)&0x00000007)<<4)
2186 #define MCF548X_SDRAMC_SDCFG1_REF2ACT(x) (((x)&0x0000000F)<<8)
2187 #define MCF548X_SDRAMC_SDCFG1_PRE2ACT(x) (((x)&0x00000007)<<12)
2188 #define MCF548X_SDRAMC_SDCFG1_ACT2RW(x) (((x)&0x00000007)<<16)
2189 #define MCF548X_SDRAMC_SDCFG1_RDLAT(x) (((x)&0x0000000F)<<20)
2190 #define MCF548X_SDRAMC_SDCFG1_SWT2RD(x) (((x)&0x00000007)<<24)
2191 #define MCF548X_SDRAMC_SDCFG1_SRD2RW(x) (((x)&0x0000000F)<<28)
2192
2193 /* Bit definitions and macros for MCF548X_SDRAMC_SDCFG2 */
2194 #define MCF548X_SDRAMC_SDCFG2_BL(x) (((x)&0x0000000F)<<16)
2195 #define MCF548X_SDRAMC_SDCFG2_BRD2WT(x) (((x)&0x0000000F)<<20)
2196 #define MCF548X_SDRAMC_SDCFG2_BWT2RW(x) (((x)&0x0000000F)<<24)
2197 #define MCF548X_SDRAMC_SDCFG2_BRD2PRE(x) (((x)&0x0000000F)<<28)
2198
2199 /*********************************************************************
2200 *
2201 * Integrated Security Engine (SEC)
2202 *
2203 *********************************************************************/
2204
2205 /* Register read/write macros */
2206 #define MCF548X_SEC_EUACRH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021000)))
2207 #define MCF548X_SEC_EUACRL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021004)))
2208 #define MCF548X_SEC_EUASRH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021028)))
2209 #define MCF548X_SEC_EUASRL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02102C)))
2210 #define MCF548X_SEC_SIMRH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021008)))
2211 #define MCF548X_SEC_SIMRL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02100C)))
2212 #define MCF548X_SEC_SISRH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021010)))
2213 #define MCF548X_SEC_SISRL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021014)))
2214 #define MCF548X_SEC_SICRH (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021018)))
2215 #define MCF548X_SEC_SICRL (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02101C)))
2216 #define MCF548X_SEC_SIDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021020)))
2217 #define MCF548X_SEC_SMCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021030)))
2218 #define MCF548X_SEC_MEAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x021038)))
2219 #define MCF548X_SEC_CCCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02200C)))
2220 #define MCF548X_SEC_CCCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02300C)))
2221 #define MCF548X_SEC_CCPSRH0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x022010)))
2222 #define MCF548X_SEC_CCPSRH1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x023010)))
2223 #define MCF548X_SEC_CCPSRL0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x022014)))
2224 #define MCF548X_SEC_CCPSRL1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x023014)))
2225 #define MCF548X_SEC_CDPR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x022044)))
2226 #define MCF548X_SEC_CDPR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x023044)))
2227 #define MCF548X_SEC_FR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02204C)))
2228 #define MCF548X_SEC_FR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02304C)))
2229 #define MCF548X_SEC_AFRCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x028018)))
2230 #define MCF548X_SEC_AFSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x028028)))
2231 #define MCF548X_SEC_AFISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x028030)))
2232 #define MCF548X_SEC_AFIMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x028038)))
2233 #define MCF548X_SEC_DRCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02A018)))
2234 #define MCF548X_SEC_DSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02A028)))
2235 #define MCF548X_SEC_DISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02A030)))
2236 #define MCF548X_SEC_DIMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02A038)))
2237 #define MCF548X_SEC_MDRCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02C018)))
2238 #define MCF548X_SEC_MDSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02C028)))
2239 #define MCF548X_SEC_MDISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02C030)))
2240 #define MCF548X_SEC_MDIMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02C038)))
2241 #define MCF548X_SEC_RNGRCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02E018)))
2242 #define MCF548X_SEC_RNGSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02E028)))
2243 #define MCF548X_SEC_RNGISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02E030)))
2244 #define MCF548X_SEC_RNGIMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x02E038)))
2245 #define MCF548X_SEC_AESRCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x032018)))
2246 #define MCF548X_SEC_AESSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x032028)))
2247 #define MCF548X_SEC_AESISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x032030)))
2248 #define MCF548X_SEC_AESIMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x032038)))
2249
2250 /* Bit definitions and macros for MCF548X_SEC_EUACRH */
2251 #define MCF548X_SEC_EUACRH_AFEU(x) (((x)&0x0000000F)<<0)
2252 #define MCF548X_SEC_EUACRH_MDEU(x) (((x)&0x0000000F)<<8)
2253 #define MCF548X_SEC_EUACRH_RNG(x) (((x)&0x0000000F)<<24)
2254 #define MCF548X_SEC_EUACRH_RNG_NOASSIGN (0x00000000)
2255 #define MCF548X_SEC_EUACRH_RNG_CHA0 (0x01000000)
2256 #define MCF548X_SEC_EUACRH_RNG_CHA1 (0x02000000)
2257 #define MCF548X_SEC_EUACRH_MDEU_NOASSIGN (0x00000000)
2258 #define MCF548X_SEC_EUACRH_MDEU_CHA0 (0x00000100)
2259 #define MCF548X_SEC_EUACRH_MDEU_CHA1 (0x00000200)
2260 #define MCF548X_SEC_EUACRH_AFEU_NOASSIGN (0x00000000)
2261 #define MCF548X_SEC_EUACRH_AFEU_CHA0 (0x00000001)
2262 #define MCF548X_SEC_EUACRH_AFEU_CHA1 (0x00000002)
2263
2264 /* Bit definitions and macros for MCF548X_SEC_EUACRL */
2265 #define MCF548X_SEC_EUACRL_AESU(x) (((x)&0x0000000F)<<16)
2266 #define MCF548X_SEC_EUACRL_DEU(x) (((x)&0x0000000F)<<24)
2267 #define MCF548X_SEC_EUACRL_DEU_NOASSIGN (0x00000000)
2268 #define MCF548X_SEC_EUACRL_DEU_CHA0 (0x01000000)
2269 #define MCF548X_SEC_EUACRL_DEU_CHA1 (0x02000000)
2270 #define MCF548X_SEC_EUACRL_AESU_NOASSIGN (0x00000000)
2271 #define MCF548X_SEC_EUACRL_AESU_CHA0 (0x00010000)
2272 #define MCF548X_SEC_EUACRL_AESU_CHA1 (0x00020000)
2273
2274 /* Bit definitions and macros for MCF548X_SEC_EUASRH */
2275 #define MCF548X_SEC_EUASRH_AFEU(x) (((x)&0x0000000F)<<0)
2276 #define MCF548X_SEC_EUASRH_MDEU(x) (((x)&0x0000000F)<<8)
2277 #define MCF548X_SEC_EUASRH_RNG(x) (((x)&0x0000000F)<<24)
2278
2279 /* Bit definitions and macros for MCF548X_SEC_EUASRL */
2280 #define MCF548X_SEC_EUASRL_AESU(x) (((x)&0x0000000F)<<16)
2281 #define MCF548X_SEC_EUASRL_DEU(x) (((x)&0x0000000F)<<24)
2282
2283 /* Bit definitions and macros for MCF548X_SEC_SIMRH */
2284 #define MCF548X_SEC_SIMRH_AERR (0x08000000)
2285 #define MCF548X_SEC_SIMRH_CHA0DN (0x10000000)
2286 #define MCF548X_SEC_SIMRH_CHA0ERR (0x20000000)
2287 #define MCF548X_SEC_SIMRH_CHA1DN (0x40000000)
2288 #define MCF548X_SEC_SIMRH_CHA1ERR (0x80000000)
2289
2290 /* Bit definitions and macros for MCF548X_SEC_SIMRL */
2291 #define MCF548X_SEC_SIMRL_TEA (0x00000040)
2292 #define MCF548X_SEC_SIMRL_DEUDN (0x00000100)
2293 #define MCF548X_SEC_SIMRL_DEUERR (0x00000200)
2294 #define MCF548X_SEC_SIMRL_AESUDN (0x00001000)
2295 #define MCF548X_SEC_SIMRL_AESUERR (0x00002000)
2296 #define MCF548X_SEC_SIMRL_MDEUDN (0x00010000)
2297 #define MCF548X_SEC_SIMRL_MDEUERR (0x00020000)
2298 #define MCF548X_SEC_SIMRL_AFEUDN (0x00100000)
2299 #define MCF548X_SEC_SIMRL_AFEUERR (0x00200000)
2300 #define MCF548X_SEC_SIMRL_RNGDN (0x01000000)
2301 #define MCF548X_SEC_SIMRL_RNGERR (0x02000000)
2302
2303 /* Bit definitions and macros for MCF548X_SEC_SISRH */
2304 #define MCF548X_SEC_SISRH_AERR (0x08000000)
2305 #define MCF548X_SEC_SISRH_CHA0DN (0x10000000)
2306 #define MCF548X_SEC_SISRH_CHA0ERR (0x20000000)
2307 #define MCF548X_SEC_SISRH_CHA1DN (0x40000000)
2308 #define MCF548X_SEC_SISRH_CHA1ERR (0x80000000)
2309
2310 /* Bit definitions and macros for MCF548X_SEC_SISRL */
2311 #define MCF548X_SEC_SISRL_TEA (0x00000040)
2312 #define MCF548X_SEC_SISRL_DEUDN (0x00000100)
2313 #define MCF548X_SEC_SISRL_DEUERR (0x00000200)
2314 #define MCF548X_SEC_SISRL_AESUDN (0x00001000)
2315 #define MCF548X_SEC_SISRL_AESUERR (0x00002000)
2316 #define MCF548X_SEC_SISRL_MDEUDN (0x00010000)
2317 #define MCF548X_SEC_SISRL_MDEUERR (0x00020000)
2318 #define MCF548X_SEC_SISRL_AFEUDN (0x00100000)
2319 #define MCF548X_SEC_SISRL_AFEUERR (0x00200000)
2320 #define MCF548X_SEC_SISRL_RNGDN (0x01000000)
2321 #define MCF548X_SEC_SISRL_RNGERR (0x02000000)
2322
2323 /* Bit definitions and macros for MCF548X_SEC_SICRH */
2324 #define MCF548X_SEC_SICRH_AERR (0x08000000)
2325 #define MCF548X_SEC_SICRH_CHA0DN (0x10000000)
2326 #define MCF548X_SEC_SICRH_CHA0ERR (0x20000000)
2327 #define MCF548X_SEC_SICRH_CHA1DN (0x40000000)
2328 #define MCF548X_SEC_SICRH_CHA1ERR (0x80000000)
2329
2330 /* Bit definitions and macros for MCF548X_SEC_SICRL */
2331 #define MCF548X_SEC_SICRL_TEA (0x00000040)
2332 #define MCF548X_SEC_SICRL_DEUDN (0x00000100)
2333 #define MCF548X_SEC_SICRL_DEUERR (0x00000200)
2334 #define MCF548X_SEC_SICRL_AESUDN (0x00001000)
2335 #define MCF548X_SEC_SICRL_AESUERR (0x00002000)
2336 #define MCF548X_SEC_SICRL_MDEUDN (0x00010000)
2337 #define MCF548X_SEC_SICRL_MDEUERR (0x00020000)
2338 #define MCF548X_SEC_SICRL_AFEUDN (0x00100000)
2339 #define MCF548X_SEC_SICRL_AFEUERR (0x00200000)
2340 #define MCF548X_SEC_SICRL_RNGDN (0x01000000)
2341 #define MCF548X_SEC_SICRL_RNGERR (0x02000000)
2342
2343 /* Bit definitions and macros for MCF548X_SEC_SMCR */
2344 #define MCF548X_SEC_SMCR_CURR_CHAN(x) (((x)&0x0000000F)<<4)
2345 #define MCF548X_SEC_SMCR_SWR (0x01000000)
2346 #define MCF548X_SEC_SMCR_CURR_CHAN_1 (0x00000010)
2347 #define MCF548X_SEC_SMCR_CURR_CHAN_2 (0x00000020)
2348
2349 /* Bit definitions and macros for MCF548X_SEC_CCCRn */
2350 #define MCF548X_SEC_CCCRn_RST (0x00000001)
2351 #define MCF548X_SEC_CCCRn_CDIE (0x00000002)
2352 #define MCF548X_SEC_CCCRn_NT (0x00000004)
2353 #define MCF548X_SEC_CCCRn_NE (0x00000008)
2354 #define MCF548X_SEC_CCCRn_WE (0x00000010)
2355 #define MCF548X_SEC_CCCRn_BURST_SIZE(x) (((x)&0x00000007)<<8)
2356 #define MCF548X_SEC_CCCRn_BURST_SIZE_2 (0x00000000)
2357 #define MCF548X_SEC_CCCRn_BURST_SIZE_8 (0x00000100)
2358 #define MCF548X_SEC_CCCRn_BURST_SIZE_16 (0x00000200)
2359 #define MCF548X_SEC_CCCRn_BURST_SIZE_24 (0x00000300)
2360 #define MCF548X_SEC_CCCRn_BURST_SIZE_32 (0x00000400)
2361 #define MCF548X_SEC_CCCRn_BURST_SIZE_40 (0x00000500)
2362 #define MCF548X_SEC_CCCRn_BURST_SIZE_48 (0x00000600)
2363 #define MCF548X_SEC_CCCRn_BURST_SIZE_56 (0x00000700)
2364
2365 /* Bit definitions and macros for MCF548X_SEC_CCPSRHn */
2366 #define MCF548X_SEC_CCPSRHn_STATE(x) (((x)&0x000000FF)<<0)
2367
2368 /* Bit definitions and macros for MCF548X_SEC_CCPSRLn */
2369 #define MCF548X_SEC_CCPSRLn_PAIR_PTR(x) (((x)&0x000000FF)<<0)
2370 #define MCF548X_SEC_CCPSRLn_EUERR (0x00000100)
2371 #define MCF548X_SEC_CCPSRLn_SERR (0x00000200)
2372 #define MCF548X_SEC_CCPSRLn_DERR (0x00000400)
2373 #define MCF548X_SEC_CCPSRLn_PERR (0x00001000)
2374 #define MCF548X_SEC_CCPSRLn_TEA (0x00002000)
2375 #define MCF548X_SEC_CCPSRLn_SD (0x00010000)
2376 #define MCF548X_SEC_CCPSRLn_PD (0x00020000)
2377 #define MCF548X_SEC_CCPSRLn_SRD (0x00040000)
2378 #define MCF548X_SEC_CCPSRLn_PRD (0x00080000)
2379 #define MCF548X_SEC_CCPSRLn_SG (0x00100000)
2380 #define MCF548X_SEC_CCPSRLn_PG (0x00200000)
2381 #define MCF548X_SEC_CCPSRLn_SR (0x00400000)
2382 #define MCF548X_SEC_CCPSRLn_PR (0x00800000)
2383 #define MCF548X_SEC_CCPSRLn_MO (0x01000000)
2384 #define MCF548X_SEC_CCPSRLn_MI (0x02000000)
2385 #define MCF548X_SEC_CCPSRLn_STAT (0x04000000)
2386
2387 /* Bit definitions and macros for MCF548X_SEC_AFRCR */
2388 #define MCF548X_SEC_AFRCR_SR (0x01000000)
2389 #define MCF548X_SEC_AFRCR_MI (0x02000000)
2390 #define MCF548X_SEC_AFRCR_RI (0x04000000)
2391
2392 /* Bit definitions and macros for MCF548X_SEC_AFSR */
2393 #define MCF548X_SEC_AFSR_RD (0x01000000)
2394 #define MCF548X_SEC_AFSR_ID (0x02000000)
2395 #define MCF548X_SEC_AFSR_IE (0x04000000)
2396 #define MCF548X_SEC_AFSR_OFE (0x08000000)
2397 #define MCF548X_SEC_AFSR_IFW (0x10000000)
2398 #define MCF548X_SEC_AFSR_HALT (0x20000000)
2399
2400 /* Bit definitions and macros for MCF548X_SEC_AFISR */
2401 #define MCF548X_SEC_AFISR_DSE (0x00010000)
2402 #define MCF548X_SEC_AFISR_KSE (0x00020000)
2403 #define MCF548X_SEC_AFISR_CE (0x00040000)
2404 #define MCF548X_SEC_AFISR_ERE (0x00080000)
2405 #define MCF548X_SEC_AFISR_IE (0x00100000)
2406 #define MCF548X_SEC_AFISR_OFU (0x02000000)
2407 #define MCF548X_SEC_AFISR_IFO (0x04000000)
2408 #define MCF548X_SEC_AFISR_IFE (0x10000000)
2409 #define MCF548X_SEC_AFISR_OFE (0x20000000)
2410 #define MCF548X_SEC_AFISR_AE (0x40000000)
2411 #define MCF548X_SEC_AFISR_ME (0x80000000)
2412
2413 /* Bit definitions and macros for MCF548X_SEC_AFIMR */
2414 #define MCF548X_SEC_AFIMR_DSE (0x00010000)
2415 #define MCF548X_SEC_AFIMR_KSE (0x00020000)
2416 #define MCF548X_SEC_AFIMR_CE (0x00040000)
2417 #define MCF548X_SEC_AFIMR_ERE (0x00080000)
2418 #define MCF548X_SEC_AFIMR_IE (0x00100000)
2419 #define MCF548X_SEC_AFIMR_OFU (0x02000000)
2420 #define MCF548X_SEC_AFIMR_IFO (0x04000000)
2421 #define MCF548X_SEC_AFIMR_IFE (0x10000000)
2422 #define MCF548X_SEC_AFIMR_OFE (0x20000000)
2423 #define MCF548X_SEC_AFIMR_AE (0x40000000)
2424 #define MCF548X_SEC_AFIMR_ME (0x80000000)
2425
2426 /* Bit definitions and macros for MCF548X_SEC_DRCR */
2427 #define MCF548X_SEC_DRCR_SR (0x01000000)
2428 #define MCF548X_SEC_DRCR_MI (0x02000000)
2429 #define MCF548X_SEC_DRCR_RI (0x04000000)
2430
2431 /* Bit definitions and macros for MCF548X_SEC_DSR */
2432 #define MCF548X_SEC_DSR_RD (0x01000000)
2433 #define MCF548X_SEC_DSR_ID (0x02000000)
2434 #define MCF548X_SEC_DSR_IE (0x04000000)
2435 #define MCF548X_SEC_DSR_OFR (0x08000000)
2436 #define MCF548X_SEC_DSR_IFW (0x10000000)
2437 #define MCF548X_SEC_DSR_HALT (0x20000000)
2438
2439 /* Bit definitions and macros for MCF548X_SEC_DISR */
2440 #define MCF548X_SEC_DISR_DSE (0x00010000)
2441 #define MCF548X_SEC_DISR_KSE (0x00020000)
2442 #define MCF548X_SEC_DISR_CE (0x00040000)
2443 #define MCF548X_SEC_DISR_ERE (0x00080000)
2444 #define MCF548X_SEC_DISR_IE (0x00100000)
2445 #define MCF548X_SEC_DISR_KPE (0x00200000)
2446 #define MCF548X_SEC_DISR_OFU (0x02000000)
2447 #define MCF548X_SEC_DISR_IFO (0x04000000)
2448 #define MCF548X_SEC_DISR_IFE (0x10000000)
2449 #define MCF548X_SEC_DISR_OFE (0x20000000)
2450 #define MCF548X_SEC_DISR_AE (0x40000000)
2451 #define MCF548X_SEC_DISR_ME (0x80000000)
2452
2453 /* Bit definitions and macros for MCF548X_SEC_DIMR */
2454 #define MCF548X_SEC_DIMR_DSE (0x00010000)
2455 #define MCF548X_SEC_DIMR_KSE (0x00020000)
2456 #define MCF548X_SEC_DIMR_CE (0x00040000)
2457 #define MCF548X_SEC_DIMR_ERE (0x00080000)
2458 #define MCF548X_SEC_DIMR_IE (0x00100000)
2459 #define MCF548X_SEC_DIMR_KPE (0x00200000)
2460 #define MCF548X_SEC_DIMR_OFU (0x02000000)
2461 #define MCF548X_SEC_DIMR_IFO (0x04000000)
2462 #define MCF548X_SEC_DIMR_IFE (0x10000000)
2463 #define MCF548X_SEC_DIMR_OFE (0x20000000)
2464 #define MCF548X_SEC_DIMR_AE (0x40000000)
2465 #define MCF548X_SEC_DIMR_ME (0x80000000)
2466
2467 /* Bit definitions and macros for MCF548X_SEC_MDRCR */
2468 #define MCF548X_SEC_MDRCR_SR (0x01000000)
2469 #define MCF548X_SEC_MDRCR_MI (0x02000000)
2470 #define MCF548X_SEC_MDRCR_RI (0x04000000)
2471
2472 /* Bit definitions and macros for MCF548X_SEC_MDSR */
2473 #define MCF548X_SEC_MDSR_RD (0x01000000)
2474 #define MCF548X_SEC_MDSR_ID (0x02000000)
2475 #define MCF548X_SEC_MDSR_IE (0x04000000)
2476 #define MCF548X_SEC_MDSR_IFW (0x10000000)
2477 #define MCF548X_SEC_MDSR_HALT (0x20000000)
2478
2479 /* Bit definitions and macros for MCF548X_SEC_MDISR */
2480 #define MCF548X_SEC_MDISR_DSE (0x00010000)
2481 #define MCF548X_SEC_MDISR_KSE (0x00020000)
2482 #define MCF548X_SEC_MDISR_CE (0x00040000)
2483 #define MCF548X_SEC_MDISR_ERE (0x00080000)
2484 #define MCF548X_SEC_MDISR_IE (0x00100000)
2485 #define MCF548X_SEC_MDISR_IFO (0x04000000)
2486 #define MCF548X_SEC_MDISR_AE (0x40000000)
2487 #define MCF548X_SEC_MDISR_ME (0x80000000)
2488
2489 /* Bit definitions and macros for MCF548X_SEC_MDIMR */
2490 #define MCF548X_SEC_MDIMR_DSE (0x00010000)
2491 #define MCF548X_SEC_MDIMR_KSE (0x00020000)
2492 #define MCF548X_SEC_MDIMR_CE (0x00040000)
2493 #define MCF548X_SEC_MDIMR_ERE (0x00080000)
2494 #define MCF548X_SEC_MDIMR_IE (0x00100000)
2495 #define MCF548X_SEC_MDIMR_IFO (0x04000000)
2496 #define MCF548X_SEC_MDIMR_AE (0x40000000)
2497 #define MCF548X_SEC_MDIMR_ME (0x80000000)
2498
2499 /* Bit definitions and macros for MCF548X_SEC_RNGRCR */
2500 #define MCF548X_SEC_RNGRCR_SR (0x01000000)
2501 #define MCF548X_SEC_RNGRCR_MI (0x02000000)
2502 #define MCF548X_SEC_RNGRCR_RI (0x04000000)
2503
2504 /* Bit definitions and macros for MCF548X_SEC_RNGSR */
2505 #define MCF548X_SEC_RNGSR_RD (0x01000000)
2506 #define MCF548X_SEC_RNGSR_O (0x02000000)
2507 #define MCF548X_SEC_RNGSR_IE (0x04000000)
2508 #define MCF548X_SEC_RNGSR_OFR (0x08000000)
2509 #define MCF548X_SEC_RNGSR_HALT (0x20000000)
2510
2511 /* Bit definitions and macros for MCF548X_SEC_RNGISR */
2512 #define MCF548X_SEC_RNGISR_IE (0x00100000)
2513 #define MCF548X_SEC_RNGISR_OFU (0x02000000)
2514 #define MCF548X_SEC_RNGISR_AE (0x40000000)
2515 #define MCF548X_SEC_RNGISR_ME (0x80000000)
2516
2517 /* Bit definitions and macros for MCF548X_SEC_RNGIMR */
2518 #define MCF548X_SEC_RNGIMR_IE (0x00100000)
2519 #define MCF548X_SEC_RNGIMR_OFU (0x02000000)
2520 #define MCF548X_SEC_RNGIMR_AE (0x40000000)
2521 #define MCF548X_SEC_RNGIMR_ME (0x80000000)
2522
2523 /* Bit definitions and macros for MCF548X_SEC_AESRCR */
2524 #define MCF548X_SEC_AESRCR_SR (0x01000000)
2525 #define MCF548X_SEC_AESRCR_MI (0x02000000)
2526 #define MCF548X_SEC_AESRCR_RI (0x04000000)
2527
2528 /* Bit definitions and macros for MCF548X_SEC_AESSR */
2529 #define MCF548X_SEC_AESSR_RD (0x01000000)
2530 #define MCF548X_SEC_AESSR_ID (0x02000000)
2531 #define MCF548X_SEC_AESSR_IE (0x04000000)
2532 #define MCF548X_SEC_AESSR_OFR (0x08000000)
2533 #define MCF548X_SEC_AESSR_IFW (0x10000000)
2534 #define MCF548X_SEC_AESSR_HALT (0x20000000)
2535
2536 /* Bit definitions and macros for MCF548X_SEC_AESISR */
2537 #define MCF548X_SEC_AESISR_DSE (0x00010000)
2538 #define MCF548X_SEC_AESISR_KSE (0x00020000)
2539 #define MCF548X_SEC_AESISR_CE (0x00040000)
2540 #define MCF548X_SEC_AESISR_ERE (0x00080000)
2541 #define MCF548X_SEC_AESISR_IE (0x00100000)
2542 #define MCF548X_SEC_AESISR_OFU (0x02000000)
2543 #define MCF548X_SEC_AESISR_IFO (0x04000000)
2544 #define MCF548X_SEC_AESISR_IFE (0x10000000)
2545 #define MCF548X_SEC_AESISR_OFE (0x20000000)
2546 #define MCF548X_SEC_AESISR_AE (0x40000000)
2547 #define MCF548X_SEC_AESISR_ME (0x80000000)
2548
2549 /* Bit definitions and macros for MCF548X_SEC_AESIMR */
2550 #define MCF548X_SEC_AESIMR_DSE (0x00010000)
2551 #define MCF548X_SEC_AESIMR_KSE (0x00020000)
2552 #define MCF548X_SEC_AESIMR_CE (0x00040000)
2553 #define MCF548X_SEC_AESIMR_ERE (0x00080000)
2554 #define MCF548X_SEC_AESIMR_IE (0x00100000)
2555 #define MCF548X_SEC_AESIMR_OFU (0x02000000)
2556 #define MCF548X_SEC_AESIMR_IFO (0x04000000)
2557 #define MCF548X_SEC_AESIMR_IFE (0x10000000)
2558 #define MCF548X_SEC_AESIMR_OFE (0x20000000)
2559 #define MCF548X_SEC_AESIMR_AE (0x40000000)
2560 #define MCF548X_SEC_AESIMR_ME (0x80000000)
2561
2562
2563 /*********************************************************************
2564 *
2565 * Slice Timers (SLT)
2566 *
2567 *********************************************************************/
2568
2569 /* Register read/write macros */
2570 #define MCF548X_SLT_SLTCNT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000900)))
2571 #define MCF548X_SLT_SCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000904)))
2572 #define MCF548X_SLT_SCNT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000908)))
2573 #define MCF548X_SLT_SSR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00090C)))
2574 #define MCF548X_SLT_SLTCNT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000910)))
2575 #define MCF548X_SLT_SCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000914)))
2576 #define MCF548X_SLT_SCNT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000918)))
2577 #define MCF548X_SLT_SSR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00091C)))
2578 #define MCF548X_SLT_SLTCNT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000900U+((x)*0x010))))
2579 #define MCF548X_SLT_SCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000904U+((x)*0x010))))
2580 #define MCF548X_SLT_SCNT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000908U+((x)*0x010))))
2581 #define MCF548X_SLT_SSR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00090CU+((x)*0x010))))
2582
2583 /* Bit definitions and macros for MCF548X_SLT_SCR */
2584 #define MCF548X_SLT_SCR_TEN (0x01000000)
2585 #define MCF548X_SLT_SCR_IEN (0x02000000)
2586 #define MCF548X_SLT_SCR_RUN (0x04000000)
2587
2588 /* Bit definitions and macros for MCF548X_SLT_SSR */
2589 #define MCF548X_SLT_SSR_ST (0x01000000)
2590 #define MCF548X_SLT_SSR_BE (0x02000000)
2591
2592
2593 /*********************************************************************
2594 *
2595 * Universal Serial Bus (USB)
2596 *
2597 *********************************************************************/
2598
2599 /* Register read/write macros */
2600 #define MCF548X_USB_USBAISR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B000)))
2601 #define MCF548X_USB_USBAIMR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B001)))
2602 #define MCF548X_USB_EPINFO (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B003)))
2603 #define MCF548X_USB_CFGR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B004)))
2604 #define MCF548X_USB_CFGAR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B005)))
2605 #define MCF548X_USB_SPEEDR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B006)))
2606 #define MCF548X_USB_FRMNUMR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B00E)))
2607 #define MCF548X_USB_EPTNR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B010)))
2608 #define MCF548X_USB_IFUR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B014)))
2609 #define MCF548X_USB_IFR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B040)))
2610 #define MCF548X_USB_IFR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B042)))
2611 #define MCF548X_USB_IFR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B044)))
2612 #define MCF548X_USB_IFR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B046)))
2613 #define MCF548X_USB_IFR4 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B048)))
2614 #define MCF548X_USB_IFR5 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B04A)))
2615 #define MCF548X_USB_IFR6 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B04C)))
2616 #define MCF548X_USB_IFR7 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B04E)))
2617 #define MCF548X_USB_IFR8 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B050)))
2618 #define MCF548X_USB_IFR9 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B052)))
2619 #define MCF548X_USB_IFR10 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B054)))
2620 #define MCF548X_USB_IFR11 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B056)))
2621 #define MCF548X_USB_IFR12 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B058)))
2622 #define MCF548X_USB_IFR13 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B05A)))
2623 #define MCF548X_USB_IFR14 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B05C)))
2624 #define MCF548X_USB_IFR15 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B05E)))
2625 #define MCF548X_USB_IFR16 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B060)))
2626 #define MCF548X_USB_IFR17 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B062)))
2627 #define MCF548X_USB_IFR18 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B064)))
2628 #define MCF548X_USB_IFR19 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B066)))
2629 #define MCF548X_USB_IFR20 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B068)))
2630 #define MCF548X_USB_IFR21 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B06A)))
2631 #define MCF548X_USB_IFR22 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B06C)))
2632 #define MCF548X_USB_IFR23 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B06E)))
2633 #define MCF548X_USB_IFR24 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B070)))
2634 #define MCF548X_USB_IFR25 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B072)))
2635 #define MCF548X_USB_IFR26 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B074)))
2636 #define MCF548X_USB_IFR27 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B076)))
2637 #define MCF548X_USB_IFR28 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B078)))
2638 #define MCF548X_USB_IFR29 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B07A)))
2639 #define MCF548X_USB_IFR30 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B07C)))
2640 #define MCF548X_USB_IFR31 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B07E)))
2641 #define MCF548X_USB_IFRn(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B040U+((x)*0x002))))
2642 #define MCF548X_USB_PPCNT (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B080)))
2643 #define MCF548X_USB_DPCNT (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B082)))
2644 #define MCF548X_USB_CRCECNT (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B084)))
2645 #define MCF548X_USB_BSECNT (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B086)))
2646 #define MCF548X_USB_PIDECNT (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B088)))
2647 #define MCF548X_USB_FRMECNT (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B08A)))
2648 #define MCF548X_USB_TXPCNT (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B08C)))
2649 #define MCF548X_USB_CNTOVR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B08E)))
2650 #define MCF548X_USB_EP0ACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B101)))
2651 #define MCF548X_USB_EP0MPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B102)))
2652 #define MCF548X_USB_EP0IFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B104)))
2653 #define MCF548X_USB_EP0SR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B105)))
2654 #define MCF548X_USB_BMRTR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B106)))
2655 #define MCF548X_USB_BRTR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B107)))
2656 #define MCF548X_USB_WVALUER (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B108)))
2657 #define MCF548X_USB_WINDEXR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B10A)))
2658 #define MCF548X_USB_WLENGTH (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B10C)))
2659 #define MCF548X_USB_EP1OUTACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B131)))
2660 #define MCF548X_USB_EP2OUTACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B161)))
2661 #define MCF548X_USB_EP3OUTACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B191)))
2662 #define MCF548X_USB_EP4OUTACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1C1)))
2663 #define MCF548X_USB_EP5OUTACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1F1)))
2664 #define MCF548X_USB_EP6OUTACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B221)))
2665 #define MCF548X_USB_EPnOUTACR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B131U+((x)*0x030))))
2666 #define MCF548X_USB_EP1OUTMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B132)))
2667 #define MCF548X_USB_EP2OUTMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B162)))
2668 #define MCF548X_USB_EP3OUTMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B192)))
2669 #define MCF548X_USB_EP4OUTMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1C2)))
2670 #define MCF548X_USB_EP5OUTMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1F2)))
2671 #define MCF548X_USB_EP6OUTMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B222)))
2672 #define MCF548X_USB_EPnOUTMPSR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B132U+((x)*0x030))))
2673 #define MCF548X_USB_EP1OUTIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B134)))
2674 #define MCF548X_USB_EP2OUTIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B164)))
2675 #define MCF548X_USB_EP3OUTIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B194)))
2676 #define MCF548X_USB_EP4OUTIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1C4)))
2677 #define MCF548X_USB_EP5OUTIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1F4)))
2678 #define MCF548X_USB_EP6OUTIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B224)))
2679 #define MCF548X_USB_EPnOUTIFR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B134U+((x)*0x030))))
2680 #define MCF548X_USB_EP1OUTSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B135)))
2681 #define MCF548X_USB_EP2OUTSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B165)))
2682 #define MCF548X_USB_EP3OUTSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B195)))
2683 #define MCF548X_USB_EP4OUTSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1C5)))
2684 #define MCF548X_USB_EP5OUTSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1F5)))
2685 #define MCF548X_USB_EP6OUTSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B225)))
2686 #define MCF548X_USB_EPnOUTSR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B135U+((x)*0x030))))
2687 #define MCF548X_USB_EP1OUTSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B13E)))
2688 #define MCF548X_USB_EP2OUTSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B16E)))
2689 #define MCF548X_USB_EP3OUTSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B19E)))
2690 #define MCF548X_USB_EP4OUTSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1CE)))
2691 #define MCF548X_USB_EP5OUTSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1FE)))
2692 #define MCF548X_USB_EP6OUTSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B22E)))
2693 #define MCF548X_USB_EPnOUTSFR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B13EU+((x)*0x030))))
2694 #define MCF548X_USB_EP1INACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B149)))
2695 #define MCF548X_USB_EP2INACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B179)))
2696 #define MCF548X_USB_EP3INACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1A9)))
2697 #define MCF548X_USB_EP4INACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1D9)))
2698 #define MCF548X_USB_EP5INACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B209)))
2699 #define MCF548X_USB_EP6INACR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B239)))
2700 #define MCF548X_USB_EPnINACR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B149U+((x)*0x030))))
2701 #define MCF548X_USB_EP1INMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B14A)))
2702 #define MCF548X_USB_EP2INMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B17A)))
2703 #define MCF548X_USB_EP3INMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1AA)))
2704 #define MCF548X_USB_EP4INMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1DA)))
2705 #define MCF548X_USB_EP5INMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B20A)))
2706 #define MCF548X_USB_EP6INMPSR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B23A)))
2707 #define MCF548X_USB_EPnINMPSR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B14AU+((x)*0x030))))
2708 #define MCF548X_USB_EP1INIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B14C)))
2709 #define MCF548X_USB_EP2INIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B17C)))
2710 #define MCF548X_USB_EP3INIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1AC)))
2711 #define MCF548X_USB_EP4INIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1DC)))
2712 #define MCF548X_USB_EP5INIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B20C)))
2713 #define MCF548X_USB_EP6INIFR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B23C)))
2714 #define MCF548X_USB_EPnINIFR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B14CU+((x)*0x030))))
2715 #define MCF548X_USB_EP1INSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B14D)))
2716 #define MCF548X_USB_EP2INSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B17D)))
2717 #define MCF548X_USB_EP3INSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1AD)))
2718 #define MCF548X_USB_EP4INSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B1DD)))
2719 #define MCF548X_USB_EP5INSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B20D)))
2720 #define MCF548X_USB_EP6INSR (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B23D)))
2721 #define MCF548X_USB_EPnINSR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00B14DU+((x)*0x030))))
2722 #define MCF548X_USB_EP1INSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B15A)))
2723 #define MCF548X_USB_EP2INSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B18A)))
2724 #define MCF548X_USB_EP3INSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1BA)))
2725 #define MCF548X_USB_EP4INSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B1EA)))
2726 #define MCF548X_USB_EP5INSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B21A)))
2727 #define MCF548X_USB_EP6INSFR (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B24A)))
2728 #define MCF548X_USB_EPnINSFR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00B15AU+((x)*0x030))))
2729 #define MCF548X_USB_USBSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B400)))
2730 #define MCF548X_USB_USBCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B404)))
2731 #define MCF548X_USB_DRAMCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B408)))
2732 #define MCF548X_USB_DRAMDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B40C)))
2733 #define MCF548X_USB_USBISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B410)))
2734 #define MCF548X_USB_USBIMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B414)))
2735 #define MCF548X_USB_EP0STAT (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B440)))
2736 #define MCF548X_USB_EP1STAT (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B470)))
2737 #define MCF548X_USB_EP2STAT (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4A0)))
2738 #define MCF548X_USB_EP3STAT (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4D0)))
2739 #define MCF548X_USB_EP4STAT (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B500)))
2740 #define MCF548X_USB_EP5STAT (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B530)))
2741 #define MCF548X_USB_EP6STAT (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B560)))
2742 #define MCF548X_USB_EPnSTAT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B440U+((x)*0x030))))
2743 #define MCF548X_USB_EP0ISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B444)))
2744 #define MCF548X_USB_EP1ISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B474)))
2745 #define MCF548X_USB_EP2ISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4A4)))
2746 #define MCF548X_USB_EP3ISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4D4)))
2747 #define MCF548X_USB_EP4ISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B504)))
2748 #define MCF548X_USB_EP5ISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B534)))
2749 #define MCF548X_USB_EP6ISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B564)))
2750 #define MCF548X_USB_EPnISR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B444U+((x)*0x030))))
2751 #define MCF548X_USB_EP0IMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B448)))
2752 #define MCF548X_USB_EP1IMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B478)))
2753 #define MCF548X_USB_EP2IMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4A8)))
2754 #define MCF548X_USB_EP3IMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4D8)))
2755 #define MCF548X_USB_EP4IMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B508)))
2756 #define MCF548X_USB_EP5IMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B538)))
2757 #define MCF548X_USB_EP6IMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B568)))
2758 #define MCF548X_USB_EPnIMR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B448U+((x)*0x030))))
2759 #define MCF548X_USB_EP0FRCFGR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B44C)))
2760 #define MCF548X_USB_EP1FRCFGR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B47C)))
2761 #define MCF548X_USB_EP2FRCFGR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4AC)))
2762 #define MCF548X_USB_EP3FRCFGR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4DC)))
2763 #define MCF548X_USB_EP4FRCFGR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B50C)))
2764 #define MCF548X_USB_EP5FRCFGR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B53C)))
2765 #define MCF548X_USB_EP6FRCFGR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B56C)))
2766 #define MCF548X_USB_EPnFRCFGR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B44CU+((x)*0x030))))
2767 #define MCF548X_USB_EP0FDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B450)))
2768 #define MCF548X_USB_EP1FDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B480)))
2769 #define MCF548X_USB_EP2FDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4B0)))
2770 #define MCF548X_USB_EP3FDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4E0)))
2771 #define MCF548X_USB_EP4FDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B510)))
2772 #define MCF548X_USB_EP5FDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B540)))
2773 #define MCF548X_USB_EP6FDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B570)))
2774 #define MCF548X_USB_EPnFDR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B450U+((x)*0x030))))
2775 #define MCF548X_USB_EP0FSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B454)))
2776 #define MCF548X_USB_EP1FSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B484)))
2777 #define MCF548X_USB_EP2FSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4B4)))
2778 #define MCF548X_USB_EP3FSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4E4)))
2779 #define MCF548X_USB_EP4FSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B514)))
2780 #define MCF548X_USB_EP5FSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B544)))
2781 #define MCF548X_USB_EP6FSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B574)))
2782 #define MCF548X_USB_EPnFSR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B454U+((x)*0x030))))
2783 #define MCF548X_USB_EP0FCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B458)))
2784 #define MCF548X_USB_EP1FCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B488)))
2785 #define MCF548X_USB_EP2FCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4B8)))
2786 #define MCF548X_USB_EP3FCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4E8)))
2787 #define MCF548X_USB_EP4FCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B518)))
2788 #define MCF548X_USB_EP5FCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B548)))
2789 #define MCF548X_USB_EP6FCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B578)))
2790 #define MCF548X_USB_EPnFCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B458U+((x)*0x030))))
2791 #define MCF548X_USB_EP0FAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B45C)))
2792 #define MCF548X_USB_EP1FAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B48C)))
2793 #define MCF548X_USB_EP2FAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4BC)))
2794 #define MCF548X_USB_EP3FAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4EC)))
2795 #define MCF548X_USB_EP4FAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B51C)))
2796 #define MCF548X_USB_EP5FAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B54C)))
2797 #define MCF548X_USB_EP6FAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B57C)))
2798 #define MCF548X_USB_EPnFAR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B45CU+((x)*0x030))))
2799 #define MCF548X_USB_EP0FRP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B460)))
2800 #define MCF548X_USB_EP1FRP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B490)))
2801 #define MCF548X_USB_EP2FRP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4C0)))
2802 #define MCF548X_USB_EP3FRP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4F0)))
2803 #define MCF548X_USB_EP4FRP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B520)))
2804 #define MCF548X_USB_EP5FRP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B550)))
2805 #define MCF548X_USB_EP6FRP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B580)))
2806 #define MCF548X_USB_EPnFRP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B460U+((x)*0x030))))
2807 #define MCF548X_USB_EP0FWP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B464)))
2808 #define MCF548X_USB_EP1FWP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B494)))
2809 #define MCF548X_USB_EP2FWP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4C4)))
2810 #define MCF548X_USB_EP3FWP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4F4)))
2811 #define MCF548X_USB_EP4FWP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B524)))
2812 #define MCF548X_USB_EP5FWP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B554)))
2813 #define MCF548X_USB_EP6FWP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B584)))
2814 #define MCF548X_USB_EPnFWP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B464U+((x)*0x030))))
2815 #define MCF548X_USB_EP0LRFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B468)))
2816 #define MCF548X_USB_EP1LRFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B498)))
2817 #define MCF548X_USB_EP2LRFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4C8)))
2818 #define MCF548X_USB_EP3LRFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4F8)))
2819 #define MCF548X_USB_EP4LRFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B528)))
2820 #define MCF548X_USB_EP5LRFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B558)))
2821 #define MCF548X_USB_EP6LRFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B588)))
2822 #define MCF548X_USB_EPnLRFP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B468U+((x)*0x030))))
2823 #define MCF548X_USB_EP0LWFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B46C)))
2824 #define MCF548X_USB_EP1LWFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B49C)))
2825 #define MCF548X_USB_EP2LWFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4CC)))
2826 #define MCF548X_USB_EP3LWFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B4FC)))
2827 #define MCF548X_USB_EP4LWFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B52C)))
2828 #define MCF548X_USB_EP5LWFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B55C)))
2829 #define MCF548X_USB_EP6LWFP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B58C)))
2830 #define MCF548X_USB_EPnLWFP(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00B46CU+((x)*0x030))))
2831
2832 /* Bit definitions and macros for MCF548X_USB_USBAISR */
2833 #define MCF548X_USB_USBAISR_SETUP (0x01)
2834 #define MCF548X_USB_USBAISR_IN (0x02)
2835 #define MCF548X_USB_USBAISR_OUT (0x04)
2836 #define MCF548X_USB_USBAISR_EPHALT (0x08)
2837 #define MCF548X_USB_USBAISR_TRANSERR (0x10)
2838 #define MCF548X_USB_USBAISR_ACK (0x20)
2839 #define MCF548X_USB_USBAISR_CTROVFL (0x40)
2840 #define MCF548X_USB_USBAISR_EPSTALL (0x80)
2841
2842 /* Bit definitions and macros for MCF548X_USB_USBAIMR */
2843 #define MCF548X_USB_USBAIMR_SETUPEN (0x01)
2844 #define MCF548X_USB_USBAIMR_INEN (0x02)
2845 #define MCF548X_USB_USBAIMR_OUTEN (0x04)
2846 #define MCF548X_USB_USBAIMR_EPHALTEN (0x08)
2847 #define MCF548X_USB_USBAIMR_TRANSERREN (0x10)
2848 #define MCF548X_USB_USBAIMR_ACKEN (0x20)
2849 #define MCF548X_USB_USBAIMR_CTROVFLEN (0x40)
2850 #define MCF548X_USB_USBAIMR_EPSTALLEN (0x80)
2851
2852 /* Bit definitions and macros for MCF548X_USB_EPINFO */
2853 #define MCF548X_USB_EPINFO_EPDIR (0x01)
2854 #define MCF548X_USB_EPINFO_EPNUM(x) (((x)&0x07)<<1)
2855
2856 /* Bit definitions and macros for MCF548X_USB_CFGAR */
2857 #define MCF548X_USB_CFGAR_RESERVED (0xA0)
2858 #define MCF548X_USB_CFGAR_RMTWKEUP (0xE0)
2859
2860 /* Bit definitions and macros for MCF548X_USB_SPEEDR */
2861 #define MCF548X_USB_SPEEDR_HS (0x01)
2862 #define MCF548X_USB_SPEEDR_FS (0x02)
2863
2864 /* Bit definitions and macros for MCF548X_USB_FRMNUMR */
2865 #define MCF548X_USB_FRMNUMR_FRMNUM(x) (((x)&0x0FFF)<<0)
2866
2867 /* Bit definitions and macros for MCF548X_USB_EPTNR */
2868 #define MCF548X_USB_EPTNR_EP1T(x) (((x)&0x0003)<<0)
2869 #define MCF548X_USB_EPTNR_EP2T(x) (((x)&0x0003)<<2)
2870 #define MCF548X_USB_EPTNR_EP3T(x) (((x)&0x0003)<<4)
2871 #define MCF548X_USB_EPTNR_EP4T(x) (((x)&0x0003)<<6)
2872 #define MCF548X_USB_EPTNR_EP5T(x) (((x)&0x0003)<<8)
2873 #define MCF548X_USB_EPTNR_EP6T(x) (((x)&0x0003)<<10)
2874 #define MCF548X_USB_EPTNR_EPnT1 (0)
2875 #define MCF548X_USB_EPTNR_EPnT2 (1)
2876 #define MCF548X_USB_EPTNR_EPnT3 (2)
2877
2878 /* Bit definitions and macros for MCF548X_USB_IFUR */
2879 #define MCF548X_USB_IFUR_ALTSET(x) (((x)&0x00FF)<<0)
2880 #define MCF548X_USB_IFUR_IFNUM(x) (((x)&0x00FF)<<8)
2881
2882 /* Bit definitions and macros for MCF548X_USB_IFRn */
2883 #define MCF548X_USB_IFRn_ALTSET(x) (((x)&0x00FF)<<0)
2884 #define MCF548X_USB_IFRn_IFNUM(x) (((x)&0x00FF)<<8)
2885
2886 /* Bit definitions and macros for MCF548X_USB_CNTOVR */
2887 #define MCF548X_USB_CNTOVR_PPCNT (0x01)
2888 #define MCF548X_USB_CNTOVR_DPCNT (0x02)
2889 #define MCF548X_USB_CNTOVR_CRCECNT (0x04)
2890 #define MCF548X_USB_CNTOVR_BSECNT (0x08)
2891 #define MCF548X_USB_CNTOVR_PIDECNT (0x10)
2892 #define MCF548X_USB_CNTOVR_FRMECNT (0x20)
2893 #define MCF548X_USB_CNTOVR_TXPCNT (0x40)
2894
2895 /* Bit definitions and macros for MCF548X_USB_EP0ACR */
2896 #define MCF548X_USB_EP0ACR_TTYPE(x) (((x)&0x03)<<0)
2897 #define MCF548X_USB_EP0ACR_TTYPE_CTRL (0)
2898 #define MCF548X_USB_EP0ACR_TTYPE_ISOC (1)
2899 #define MCF548X_USB_EP0ACR_TTYPE_BULK (2)
2900 #define MCF548X_USB_EP0ACR_TTYPE_INT (3)
2901
2902 /* Bit definitions and macros for MCF548X_USB_EP0MPSR */
2903 #define MCF548X_USB_EP0MPSR_MAXPKTSZ(x) (((x)&0x07FF)<<0)
2904 #define MCF548X_USB_EP0MPSR_ADDTRANS(x) (((x)&0x0003)<<11)
2905
2906 /* Bit definitions and macros for MCF548X_USB_EP0SR */
2907 #define MCF548X_USB_EP0SR_HALT (0x01)
2908 #define MCF548X_USB_EP0SR_ACTIVE (0x02)
2909 #define MCF548X_USB_EP0SR_PSTALL (0x04)
2910 #define MCF548X_USB_EP0SR_CCOMP (0x08)
2911 #define MCF548X_USB_EP0SR_TXZERO (0x20)
2912 #define MCF548X_USB_EP0SR_INT (0x80)
2913
2914 /* Bit definitions and macros for MCF548X_USB_BMRTR */
2915 #define MCF548X_USB_BMRTR_DIR (0x80)
2916 #define MCF548X_USB_BMRTR_TYPE_STANDARD (0x00)
2917 #define MCF548X_USB_BMRTR_TYPE_CLASS (0x20)
2918 #define MCF548X_USB_BMRTR_TYPE_VENDOR (0x40)
2919 #define MCF548X_USB_BMRTR_REC_DEVICE (0x00)
2920 #define MCF548X_USB_BMRTR_REC_INTERFACE (0x01)
2921 #define MCF548X_USB_BMRTR_REC_ENDPOINT (0x02)
2922 #define MCF548X_USB_BMRTR_REC_OTHER (0x03)
2923
2924 /* Bit definitions and macros for MCF548X_USB_EPnOUTACR */
2925 #define MCF548X_USB_EPnOUTACR_TTYPE(x) (((x)&0x03)<<0)
2926
2927 /* Bit definitions and macros for MCF548X_USB_EPnOUTMPSR */
2928 #define MCF548X_USB_EPnOUTMPSR_MAXPKTSZ(x) (((x)&0x07FF)<<0)
2929 #define MCF548X_USB_EPnOUTMPSR_ADDTRANS(x) (((x)&0x0003)<<11)
2930
2931 /* Bit definitions and macros for MCF548X_USB_EPnOUTSR */
2932 #define MCF548X_USB_EPnOUTSR_HALT (0x01)
2933 #define MCF548X_USB_EPnOUTSR_ACTIVE (0x02)
2934 #define MCF548X_USB_EPnOUTSR_PSTALL (0x04)
2935 #define MCF548X_USB_EPnOUTSR_CCOMP (0x08)
2936 #define MCF548X_USB_EPnOUTSR_TXZERO (0x20)
2937 #define MCF548X_USB_EPnOUTSR_INT (0x80)
2938
2939 /* Bit definitions and macros for MCF548X_USB_EPnOUTSFR */
2940 #define MCF548X_USB_EPnOUTSFR_FRMNUM(x) (((x)&0x07FF)<<0)
2941
2942 /* Bit definitions and macros for MCF548X_USB_EPnINACR */
2943 #define MCF548X_USB_EPnINACR_TTYPE(x) (((x)&0x03)<<0)
2944
2945 /* Bit definitions and macros for MCF548X_USB_EPnINMPSR */
2946 #define MCF548X_USB_EPnINMPSR_MAXPKTSZ(x) (((x)&0x07FF)<<0)
2947 #define MCF548X_USB_EPnINMPSR_ADDTRANS(x) (((x)&0x0003)<<11)
2948
2949 /* Bit definitions and macros for MCF548X_USB_EPnINSR */
2950 #define MCF548X_USB_EPnINSR_HALT (0x01)
2951 #define MCF548X_USB_EPnINSR_ACTIVE (0x02)
2952 #define MCF548X_USB_EPnINSR_PSTALL (0x04)
2953 #define MCF548X_USB_EPnINSR_CCOMP (0x08)
2954 #define MCF548X_USB_EPnINSR_TXZERO (0x20)
2955 #define MCF548X_USB_EPnINSR_INT (0x80)
2956
2957 /* Bit definitions and macros for MCF548X_USB_EPnINSFR */
2958 #define MCF548X_USB_EPnINSFR_FRMNUM(x) (((x)&0x07FF)<<0)
2959
2960 /* Bit definitions and macros for MCF548X_USB_USBSR */
2961 #define MCF548X_USB_USBSR_SUSP (0x00000080)
2962 #define MCF548X_USB_USBSR_ISOERREP (0x0000000F)
2963
2964 /* Bit definitions and macros for MCF548X_USB_USBCR */
2965 #define MCF548X_USB_USBCR_RESUME (0x00000001)
2966 #define MCF548X_USB_USBCR_APPLOCK (0x00000002)
2967 #define MCF548X_USB_USBCR_RST (0x00000004)
2968 #define MCF548X_USB_USBCR_RAMEN (0x00000008)
2969 #define MCF548X_USB_USBCR_RAMSPLIT (0x00000020)
2970
2971 /* Bit definitions and macros for MCF548X_USB_DRAMCR */
2972 #define MCF548X_USB_DRAMCR_DADR(x) (((x)&0x000003FF)<<0)
2973 #define MCF548X_USB_DRAMCR_DSIZE(x) (((x)&0x000007FF)<<16)
2974 #define MCF548X_USB_DRAMCR_BSY (0x40000000)
2975 #define MCF548X_USB_DRAMCR_START (0x80000000)
2976
2977 /* Bit definitions and macros for MCF548X_USB_DRAMDR */
2978 #define MCF548X_USB_DRAMDR_DDAT(x) (((x)&0x000000FF)<<0)
2979
2980 /* Bit definitions and macros for MCF548X_USB_USBISR */
2981 #define MCF548X_USB_USBISR_ISOERR (0x00000001)
2982 #define MCF548X_USB_USBISR_FTUNLCK (0x00000002)
2983 #define MCF548X_USB_USBISR_SUSP (0x00000004)
2984 #define MCF548X_USB_USBISR_RES (0x00000008)
2985 #define MCF548X_USB_USBISR_UPDSOF (0x00000010)
2986 #define MCF548X_USB_USBISR_RSTSTOP (0x00000020)
2987 #define MCF548X_USB_USBISR_SOF (0x00000040)
2988 #define MCF548X_USB_USBISR_MSOF (0x00000080)
2989
2990 /* Bit definitions and macros for MCF548X_USB_USBIMR */
2991 #define MCF548X_USB_USBIMR_ISOERR (0x00000001)
2992 #define MCF548X_USB_USBIMR_FTUNLCK (0x00000002)
2993 #define MCF548X_USB_USBIMR_SUSP (0x00000004)
2994 #define MCF548X_USB_USBIMR_RES (0x00000008)
2995 #define MCF548X_USB_USBIMR_UPDSOF (0x00000010)
2996 #define MCF548X_USB_USBIMR_RSTSTOP (0x00000020)
2997 #define MCF548X_USB_USBIMR_SOF (0x00000040)
2998 #define MCF548X_USB_USBIMR_MSOF (0x00000080)
2999
3000 /* Bit definitions and macros for MCF548X_USB_EPnSTAT */
3001 #define MCF548X_USB_EPnSTAT_RST (0x00000001)
3002 #define MCF548X_USB_EPnSTAT_FLUSH (0x00000002)
3003 #define MCF548X_USB_EPnSTAT_DIR (0x00000080)
3004 #define MCF548X_USB_EPnSTAT_BYTECNT(x) (((x)&0x00000FFF)<<16)
3005
3006 /* Bit definitions and macros for MCF548X_USB_EPnISR */
3007 #define MCF548X_USB_EPnISR_EOF (0x00000001)
3008 #define MCF548X_USB_EPnISR_EOT (0x00000004)
3009 #define MCF548X_USB_EPnISR_FIFOLO (0x00000010)
3010 #define MCF548X_USB_EPnISR_FIFOHI (0x00000020)
3011 #define MCF548X_USB_EPnISR_ERR (0x00000040)
3012 #define MCF548X_USB_EPnISR_EMT (0x00000080)
3013 #define MCF548X_USB_EPnISR_FU (0x00000100)
3014
3015 /* Bit definitions and macros for MCF548X_USB_EPnIMR */
3016 #define MCF548X_USB_EPnIMR_EOF (0x00000001)
3017 #define MCF548X_USB_EPnIMR_EOT (0x00000004)
3018 #define MCF548X_USB_EPnIMR_FIFOLO (0x00000010)
3019 #define MCF548X_USB_EPnIMR_FIFOHI (0x00000020)
3020 #define MCF548X_USB_EPnIMR_ERR (0x00000040)
3021 #define MCF548X_USB_EPnIMR_EMT (0x00000080)
3022 #define MCF548X_USB_EPnIMR_FU (0x00000100)
3023
3024 /* Bit definitions and macros for MCF548X_USB_EPnFRCFGR */
3025 #define MCF548X_USB_EPnFRCFGR_DEPTH(x) (((x)&0x00001FFF)<<0)
3026 #define MCF548X_USB_EPnFRCFGR_BASE(x) (((x)&0x00000FFF)<<16)
3027
3028 /* Bit definitions and macros for MCF548X_USB_EPnFSR */
3029 #define MCF548X_USB_EPnFSR_EMT (0x00010000)
3030 #define MCF548X_USB_EPnFSR_ALRM (0x00020000)
3031 #define MCF548X_USB_EPnFSR_FR (0x00040000)
3032 #define MCF548X_USB_EPnFSR_FU (0x00080000)
3033 #define MCF548X_USB_EPnFSR_OF (0x00100000)
3034 #define MCF548X_USB_EPnFSR_UF (0x00200000)
3035 #define MCF548X_USB_EPnFSR_RXW (0x00400000)
3036 #define MCF548X_USB_EPnFSR_FAE (0x00800000)
3037 #define MCF548X_USB_EPnFSR_FRM(x) (((x)&0x0000000F)<<24)
3038 #define MCF548X_USB_EPnFSR_TXW (0x40000000)
3039 #define MCF548X_USB_EPnFSR_IP (0x80000000)
3040
3041 /* Bit definitions and macros for MCF548X_USB_EPnFCR */
3042 #define MCF548X_USB_EPnFCR_COUNTER(x) (((x)&0x0000FFFF)<<0)
3043 #define MCF548X_USB_EPnFCR_TXWMSK (0x00040000)
3044 #define MCF548X_USB_EPnFCR_OFMSK (0x00080000)
3045 #define MCF548X_USB_EPnFCR_UFMSK (0x00100000)
3046 #define MCF548X_USB_EPnFCR_RXWMSK (0x00200000)
3047 #define MCF548X_USB_EPnFCR_FAEMSK (0x00400000)
3048 #define MCF548X_USB_EPnFCR_IPMSK (0x00800000)
3049 #define MCF548X_USB_EPnFCR_GR(x) (((x)&0x00000007)<<24)
3050 #define MCF548X_USB_EPnFCR_FRM (0x08000000)
3051 #define MCF548X_USB_EPnFCR_TMR (0x10000000)
3052 #define MCF548X_USB_EPnFCR_WFR (0x20000000)
3053 #define MCF548X_USB_EPnFCR_SHAD (0x80000000)
3054
3055 /* Bit definitions and macros for MCF548X_USB_EPnFAR */
3056 #define MCF548X_USB_EPnFAR_ALRMP(x) (((x)&0x00000FFF)<<0)
3057
3058 /* Bit definitions and macros for MCF548X_USB_EPnFRP */
3059 #define MCF548X_USB_EPnFRP_RP(x) (((x)&0x00000FFF)<<0)
3060
3061 /* Bit definitions and macros for MCF548X_USB_EPnFWP */
3062 #define MCF548X_USB_EPnFWP_WP(x) (((x)&0x00000FFF)<<0)
3063
3064 /* Bit definitions and macros for MCF548X_USB_EPnLRFP */
3065 #define MCF548X_USB_EPnLRFP_LRFP(x) (((x)&0x00000FFF)<<0)
3066
3067 /* Bit definitions and macros for MCF548X_USB_EPnLWFP */
3068 #define MCF548X_USB_EPnLWFP_LWFP(x) (((x)&0x00000FFF)<<0)
3069
3070
3071 /*********************************************************************
3072 *
3073 * Programmable Serial Controller (PSC)
3074 *
3075 *********************************************************************/
3076
3077 /* Register read/write macros */
3078 #define MCF548X_PSC_MR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008600)))
3079 #define MCF548X_PSC_SR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008604)))
3080 #define MCF548X_PSC_CSR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008604)))
3081 #define MCF548X_PSC_CR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008608)))
3082 #define MCF548X_PSC_RB0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860C)))
3083 #define MCF548X_PSC_TB0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860C)))
3084 #define MCF548X_PSC_TB_8BIT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860C)))
3085 #define MCF548X_PSC_TB_16BIT0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860C)))
3086 #define MCF548X_PSC_TB_AC970 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860C)))
3087 #define MCF548X_PSC_IPCR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008610)))
3088 #define MCF548X_PSC_ACR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008610)))
3089 #define MCF548X_PSC_ISR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008614)))
3090 #define MCF548X_PSC_IMR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008614)))
3091 #define MCF548X_PSC_CTUR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008618)))
3092 #define MCF548X_PSC_CTLR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00861C)))
3093 #define MCF548X_PSC_IP0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008634)))
3094 #define MCF548X_PSC_OPSET0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008638)))
3095 #define MCF548X_PSC_OPRESET0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00863C)))
3096 #define MCF548X_PSC_SICR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008640)))
3097 #define MCF548X_PSC_IRCR10 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008644)))
3098 #define MCF548X_PSC_IRCR20 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008648)))
3099 #define MCF548X_PSC_IRSDR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00864C)))
3100 #define MCF548X_PSC_IRMDR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008650)))
3101 #define MCF548X_PSC_IRFDR0 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008654)))
3102 #define MCF548X_PSC_RFCNT0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008658)))
3103 #define MCF548X_PSC_TFCNT0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00865C)))
3104 #define MCF548X_PSC_RFSR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008664)))
3105 #define MCF548X_PSC_TFSR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008684)))
3106 #define MCF548X_PSC_RFCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008668)))
3107 #define MCF548X_PSC_TFCR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008688)))
3108 #define MCF548X_PSC_RFAR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00866E)))
3109 #define MCF548X_PSC_TFAR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00868E)))
3110 #define MCF548X_PSC_RFRP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008672)))
3111 #define MCF548X_PSC_TFRP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008692)))
3112 #define MCF548X_PSC_RFWP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008676)))
3113 #define MCF548X_PSC_TFWP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008696)))
3114 #define MCF548X_PSC_RLRFP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00867A)))
3115 #define MCF548X_PSC_TLRFP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00869A)))
3116 #define MCF548X_PSC_RLWFP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00867E)))
3117 #define MCF548X_PSC_TLWFP0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00869E)))
3118 #define MCF548X_PSC_MR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008700)))
3119 #define MCF548X_PSC_SR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008704)))
3120 #define MCF548X_PSC_CSR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008704)))
3121 #define MCF548X_PSC_CR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008708)))
3122 #define MCF548X_PSC_RB1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00870C)))
3123 #define MCF548X_PSC_TB1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00870C)))
3124 #define MCF548X_PSC_TB_8BIT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00870C)))
3125 #define MCF548X_PSC_TB_16BIT1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00870C)))
3126 #define MCF548X_PSC_TB_AC971 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00870C)))
3127 #define MCF548X_PSC_IPCR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008710)))
3128 #define MCF548X_PSC_ACR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008710)))
3129 #define MCF548X_PSC_ISR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008714)))
3130 #define MCF548X_PSC_IMR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008714)))
3131 #define MCF548X_PSC_CTUR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008718)))
3132 #define MCF548X_PSC_CTLR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00871C)))
3133 #define MCF548X_PSC_IP1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008734)))
3134 #define MCF548X_PSC_OPSET1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008738)))
3135 #define MCF548X_PSC_OPRESET1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00873C)))
3136 #define MCF548X_PSC_SICR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008740)))
3137 #define MCF548X_PSC_IRCR11 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008744)))
3138 #define MCF548X_PSC_IRCR21 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008748)))
3139 #define MCF548X_PSC_IRSDR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00874C)))
3140 #define MCF548X_PSC_IRMDR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008750)))
3141 #define MCF548X_PSC_IRFDR1 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008754)))
3142 #define MCF548X_PSC_RFCNT1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008758)))
3143 #define MCF548X_PSC_TFCNT1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00875C)))
3144 #define MCF548X_PSC_RFSR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008764)))
3145 #define MCF548X_PSC_TFSR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008784)))
3146 #define MCF548X_PSC_RFCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008768)))
3147 #define MCF548X_PSC_TFCR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008788)))
3148 #define MCF548X_PSC_RFAR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00876E)))
3149 #define MCF548X_PSC_TFAR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00878E)))
3150 #define MCF548X_PSC_RFRP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008772)))
3151 #define MCF548X_PSC_TFRP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008792)))
3152 #define MCF548X_PSC_RFWP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008776)))
3153 #define MCF548X_PSC_TFWP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008796)))
3154 #define MCF548X_PSC_RLRFP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00877A)))
3155 #define MCF548X_PSC_TLRFP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00879A)))
3156 #define MCF548X_PSC_RLWFP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00877E)))
3157 #define MCF548X_PSC_TLWFP1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00879E)))
3158 #define MCF548X_PSC_MR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008800)))
3159 #define MCF548X_PSC_SR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008804)))
3160 #define MCF548X_PSC_CSR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008804)))
3161 #define MCF548X_PSC_CR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008808)))
3162 #define MCF548X_PSC_RB2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00880C)))
3163 #define MCF548X_PSC_TB2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00880C)))
3164 #define MCF548X_PSC_TB_8BIT2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00880C)))
3165 #define MCF548X_PSC_TB_16BIT2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00880C)))
3166 #define MCF548X_PSC_TB_AC972 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00880C)))
3167 #define MCF548X_PSC_IPCR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008810)))
3168 #define MCF548X_PSC_ACR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008810)))
3169 #define MCF548X_PSC_ISR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008814)))
3170 #define MCF548X_PSC_IMR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008814)))
3171 #define MCF548X_PSC_CTUR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008818)))
3172 #define MCF548X_PSC_CTLR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00881C)))
3173 #define MCF548X_PSC_IP2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008834)))
3174 #define MCF548X_PSC_OPSET2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008838)))
3175 #define MCF548X_PSC_OPRESET2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00883C)))
3176 #define MCF548X_PSC_SICR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008840)))
3177 #define MCF548X_PSC_IRCR12 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008844)))
3178 #define MCF548X_PSC_IRCR22 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008848)))
3179 #define MCF548X_PSC_IRSDR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00884C)))
3180 #define MCF548X_PSC_IRMDR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008850)))
3181 #define MCF548X_PSC_IRFDR2 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008854)))
3182 #define MCF548X_PSC_RFCNT2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008858)))
3183 #define MCF548X_PSC_TFCNT2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00885C)))
3184 #define MCF548X_PSC_RFSR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008864)))
3185 #define MCF548X_PSC_TFSR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008884)))
3186 #define MCF548X_PSC_RFCR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008868)))
3187 #define MCF548X_PSC_TFCR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008888)))
3188 #define MCF548X_PSC_RFAR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00886E)))
3189 #define MCF548X_PSC_TFAR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00888E)))
3190 #define MCF548X_PSC_RFRP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008872)))
3191 #define MCF548X_PSC_TFRP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008892)))
3192 #define MCF548X_PSC_RFWP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008876)))
3193 #define MCF548X_PSC_TFWP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008896)))
3194 #define MCF548X_PSC_RLRFP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00887A)))
3195 #define MCF548X_PSC_TLRFP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00889A)))
3196 #define MCF548X_PSC_RLWFP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00887E)))
3197 #define MCF548X_PSC_TLWFP2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00889E)))
3198 #define MCF548X_PSC_MR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008900)))
3199 #define MCF548X_PSC_SR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008904)))
3200 #define MCF548X_PSC_CSR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008904)))
3201 #define MCF548X_PSC_CR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008908)))
3202 #define MCF548X_PSC_RB3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00890C)))
3203 #define MCF548X_PSC_TB3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00890C)))
3204 #define MCF548X_PSC_TB_8BIT3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00890C)))
3205 #define MCF548X_PSC_TB_16BIT3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00890C)))
3206 #define MCF548X_PSC_TB_AC973 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00890C)))
3207 #define MCF548X_PSC_IPCR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008910)))
3208 #define MCF548X_PSC_ACR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008910)))
3209 #define MCF548X_PSC_ISR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008914)))
3210 #define MCF548X_PSC_IMR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008914)))
3211 #define MCF548X_PSC_CTUR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008918)))
3212 #define MCF548X_PSC_CTLR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00891C)))
3213 #define MCF548X_PSC_IP3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008934)))
3214 #define MCF548X_PSC_OPSET3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008938)))
3215 #define MCF548X_PSC_OPRESET3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00893C)))
3216 #define MCF548X_PSC_SICR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008940)))
3217 #define MCF548X_PSC_IRCR13 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008944)))
3218 #define MCF548X_PSC_IRCR23 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008948)))
3219 #define MCF548X_PSC_IRSDR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00894C)))
3220 #define MCF548X_PSC_IRMDR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008950)))
3221 #define MCF548X_PSC_IRFDR3 (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008954)))
3222 #define MCF548X_PSC_RFCNT3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008958)))
3223 #define MCF548X_PSC_TFCNT3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00895C)))
3224 #define MCF548X_PSC_RFSR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008964)))
3225 #define MCF548X_PSC_TFSR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008984)))
3226 #define MCF548X_PSC_RFCR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008968)))
3227 #define MCF548X_PSC_TFCR3 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008988)))
3228 #define MCF548X_PSC_RFAR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00896E)))
3229 #define MCF548X_PSC_TFAR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00898E)))
3230 #define MCF548X_PSC_RFRP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008972)))
3231 #define MCF548X_PSC_TFRP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008992)))
3232 #define MCF548X_PSC_RFWP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008976)))
3233 #define MCF548X_PSC_TFWP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008996)))
3234 #define MCF548X_PSC_RLRFP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00897A)))
3235 #define MCF548X_PSC_TLRFP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00899A)))
3236 #define MCF548X_PSC_RLWFP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00897E)))
3237 #define MCF548X_PSC_TLWFP3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00899E)))
3238 #define MCF548X_PSC_MR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008600U+((x)*0x100))))
3239 #define MCF548X_PSC_SR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008604U+((x)*0x100))))
3240 #define MCF548X_PSC_CSR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008604U+((x)*0x100))))
3241 #define MCF548X_PSC_CR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008608U+((x)*0x100))))
3242 #define MCF548X_PSC_RB(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860CU+((x)*0x100))))
3243 #define MCF548X_PSC_TB(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860CU+((x)*0x100))))
3244 #define MCF548X_PSC_TB_8BIT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860CU+((x)*0x100))))
3245 #define MCF548X_PSC_TB_16BIT(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860CU+((x)*0x100))))
3246 #define MCF548X_PSC_TB_AC97(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00860CU+((x)*0x100))))
3247 #define MCF548X_PSC_IPCR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008610U+((x)*0x100))))
3248 #define MCF548X_PSC_ACR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008610U+((x)*0x100))))
3249 #define MCF548X_PSC_ISR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008614U+((x)*0x100))))
3250 #define MCF548X_PSC_IMR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008614U+((x)*0x100))))
3251 #define MCF548X_PSC_CTUR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008618U+((x)*0x100))))
3252 #define MCF548X_PSC_CTLR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00861CU+((x)*0x100))))
3253 #define MCF548X_PSC_IP(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008634U+((x)*0x100))))
3254 #define MCF548X_PSC_OPSET(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008638U+((x)*0x100))))
3255 #define MCF548X_PSC_OPRESET(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00863CU+((x)*0x100))))
3256 #define MCF548X_PSC_SICR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008640U+((x)*0x100))))
3257 #define MCF548X_PSC_IRCR1(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008644U+((x)*0x100))))
3258 #define MCF548X_PSC_IRCR2(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008648U+((x)*0x100))))
3259 #define MCF548X_PSC_IRSDR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x00864CU+((x)*0x100))))
3260 #define MCF548X_PSC_IRMDR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008650U+((x)*0x100))))
3261 #define MCF548X_PSC_IRFDR(x) (*(volatile uint8_t *)((uintptr_t)__MBAR + (0x008654U+((x)*0x100))))
3262 #define MCF548X_PSC_RFCNT(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008658U+((x)*0x100))))
3263 #define MCF548X_PSC_TFCNT(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00865CU+((x)*0x100))))
3264 #define MCF548X_PSC_RFSR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008664U+((x)*0x100))))
3265 #define MCF548X_PSC_TFSR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008684U+((x)*0x100))))
3266 #define MCF548X_PSC_RFCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008668U+((x)*0x100))))
3267 #define MCF548X_PSC_TFCR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008688U+((x)*0x100))))
3268 #define MCF548X_PSC_RFAR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00866EU+((x)*0x100))))
3269 #define MCF548X_PSC_TFAR(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00868EU+((x)*0x100))))
3270 #define MCF548X_PSC_RFRP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008672U+((x)*0x100))))
3271 #define MCF548X_PSC_TFRP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008692U+((x)*0x100))))
3272 #define MCF548X_PSC_RFWP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008676U+((x)*0x100))))
3273 #define MCF548X_PSC_TFWP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008696U+((x)*0x100))))
3274 #define MCF548X_PSC_RLRFP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00867AU+((x)*0x100))))
3275 #define MCF548X_PSC_TLRFP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00869AU+((x)*0x100))))
3276 #define MCF548X_PSC_RLWFP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00867EU+((x)*0x100))))
3277 #define MCF548X_PSC_TLWFP(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00869EU+((x)*0x100))))
3278
3279 /* Bit definitions and macros for MCF548X_PSC_MR */
3280 #define MCF548X_PSC_MR_BC(x) (((x)&0x03)<<0)
3281 #define MCF548X_PSC_MR_PT (0x04)
3282 #define MCF548X_PSC_MR_PM(x) (((x)&0x03)<<3)
3283 #define MCF548X_PSC_MR_ERR (0x20)
3284 #define MCF548X_PSC_MR_RXIRQ (0x40)
3285 #define MCF548X_PSC_MR_RXRTS (0x80)
3286 #define MCF548X_PSC_MR_SB(x) (((x)&0x0F)<<0)
3287 #define MCF548X_PSC_MR_TXCTS (0x10)
3288 #define MCF548X_PSC_MR_TXRTS (0x20)
3289 #define MCF548X_PSC_MR_CM(x) (((x)&0x03)<<6)
3290 #define MCF548X_PSC_MR_PM_MULTI_ADDR (0x1C)
3291 #define MCF548X_PSC_MR_PM_MULTI_DATA (0x18)
3292 #define MCF548X_PSC_MR_PM_NONE (0x10)
3293 #define MCF548X_PSC_MR_PM_FORCE_HI (0x0C)
3294 #define MCF548X_PSC_MR_PM_FORCE_LO (0x08)
3295 #define MCF548X_PSC_MR_PM_ODD (0x04)
3296 #define MCF548X_PSC_MR_PM_EVEN (0x00)
3297 #define MCF548X_PSC_MR_BC_5 (0x00)
3298 #define MCF548X_PSC_MR_BC_6 (0x01)
3299 #define MCF548X_PSC_MR_BC_7 (0x02)
3300 #define MCF548X_PSC_MR_BC_8 (0x03)
3301 #define MCF548X_PSC_MR_CM_NORMAL (0x00)
3302 #define MCF548X_PSC_MR_CM_ECHO (0x40)
3303 #define MCF548X_PSC_MR_CM_LOCAL_LOOP (0x80)
3304 #define MCF548X_PSC_MR_CM_REMOTE_LOOP (0xC0)
3305 #define MCF548X_PSC_MR_SB_STOP_BITS_1 (0x07)
3306 #define MCF548X_PSC_MR_SB_STOP_BITS_15 (0x08)
3307 #define MCF548X_PSC_MR_SB_STOP_BITS_2 (0x0F)
3308
3309 /* Bit definitions and macros for MCF548X_PSC_SR */
3310 #define MCF548X_PSC_SR_ERR (0x0040)
3311 #define MCF548X_PSC_SR_CDE_DEOF (0x0080)
3312 #define MCF548X_PSC_SR_RXRDY (0x0100)
3313 #define MCF548X_PSC_SR_FU (0x0200)
3314 #define MCF548X_PSC_SR_TXRDY (0x0400)
3315 #define MCF548X_PSC_SR_TXEMP_URERR (0x0800)
3316 #define MCF548X_PSC_SR_OE (0x1000)
3317 #define MCF548X_PSC_SR_PE_CRCERR (0x2000)
3318 #define MCF548X_PSC_SR_FE_PHYERR (0x4000)
3319 #define MCF548X_PSC_SR_RB_NEOF (0x8000)
3320
3321 /* Bit definitions and macros for MCF548X_PSC_CSR */
3322 #define MCF548X_PSC_CSR_TCSEL(x) (((x)&0x0F)<<0)
3323 #define MCF548X_PSC_CSR_RCSEL(x) (((x)&0x0F)<<4)
3324 #define MCF548X_PSC_CSR_RCSEL_SYS_CLK (0xD0)
3325 #define MCF548X_PSC_CSR_RCSEL_CTM16 (0xE0)
3326 #define MCF548X_PSC_CSR_RCSEL_CTM (0xF0)
3327 #define MCF548X_PSC_CSR_TCSEL_SYS_CLK (0x0D)
3328 #define MCF548X_PSC_CSR_TCSEL_CTM16 (0x0E)
3329 #define MCF548X_PSC_CSR_TCSEL_CTM (0x0F)
3330
3331 /* Bit definitions and macros for MCF548X_PSC_CR */
3332 #define MCF548X_PSC_CR_RXC(x) (((x)&0x03)<<0)
3333 #define MCF548X_PSC_CR_TXC(x) (((x)&0x03)<<2)
3334 #define MCF548X_PSC_CR_MISC(x) (((x)&0x07)<<4)
3335 #define MCF548X_PSC_CR_NONE (0x00)
3336 #define MCF548X_PSC_CR_STOP_BREAK (0x70)
3337 #define MCF548X_PSC_CR_START_BREAK (0x60)
3338 #define MCF548X_PSC_CR_BKCHGINT (0x50)
3339 #define MCF548X_PSC_CR_RESET_ERROR (0x40)
3340 #define MCF548X_PSC_CR_RESET_TX (0x30)
3341 #define MCF548X_PSC_CR_RESET_RX (0x20)
3342 #define MCF548X_PSC_CR_RESET_MR (0x10)
3343 #define MCF548X_PSC_CR_TX_DISABLED (0x08)
3344 #define MCF548X_PSC_CR_TX_ENABLED (0x04)
3345 #define MCF548X_PSC_CR_RX_DISABLED (0x02)
3346 #define MCF548X_PSC_CR_RX_ENABLED (0x01)
3347
3348 /* Bit definitions and macros for MCF548X_PSC_TB_8BIT */
3349 #define MCF548X_PSC_TB_8BIT_TB3(x) (((x)&0x000000FF)<<0)
3350 #define MCF548X_PSC_TB_8BIT_TB2(x) (((x)&0x000000FF)<<8)
3351 #define MCF548X_PSC_TB_8BIT_TB1(x) (((x)&0x000000FF)<<16)
3352 #define MCF548X_PSC_TB_8BIT_TB0(x) (((x)&0x000000FF)<<24)
3353
3354 /* Bit definitions and macros for MCF548X_PSC_TB_16BIT */
3355 #define MCF548X_PSC_TB_16BIT_TB1(x) (((x)&0x0000FFFF)<<0)
3356 #define MCF548X_PSC_TB_16BIT_TB0(x) (((x)&0x0000FFFF)<<16)
3357
3358 /* Bit definitions and macros for MCF548X_PSC_TB_AC97 */
3359 #define MCF548X_PSC_TB_AC97_SOF (0x00000800)
3360 #define MCF548X_PSC_TB_AC97_TB(x) (((x)&0x000FFFFF)<<12)
3361
3362 /* Bit definitions and macros for MCF548X_PSC_IPCR */
3363 #define MCF548X_PSC_IPCR_RESERVED (0x0C)
3364 #define MCF548X_PSC_IPCR_CTS (0x0D)
3365 #define MCF548X_PSC_IPCR_D_CTS (0x1C)
3366 #define MCF548X_PSC_IPCR_SYNC (0x8C)
3367
3368 /* Bit definitions and macros for MCF548X_PSC_ACR */
3369 #define MCF548X_PSC_ACR_IEC0 (0x01)
3370 #define MCF548X_PSC_ACR_CTMS(x) (((x)&0x07)<<4)
3371 #define MCF548X_PSC_ACR_BRG (0x80)
3372
3373 /* Bit definitions and macros for MCF548X_PSC_ISR */
3374 #define MCF548X_PSC_ISR_ERR (0x0040)
3375 #define MCF548X_PSC_ISR_DEOF (0x0080)
3376 #define MCF548X_PSC_ISR_TXRDY (0x0100)
3377 #define MCF548X_PSC_ISR_RXRDY_FU (0x0200)
3378 #define MCF548X_PSC_ISR_DB (0x0400)
3379 #define MCF548X_PSC_ISR_IPC (0x8000)
3380
3381 /* Bit definitions and macros for MCF548X_PSC_IMR */
3382 #define MCF548X_PSC_IMR_ERR (0x0040)
3383 #define MCF548X_PSC_IMR_DEOF (0x0080)
3384 #define MCF548X_PSC_IMR_TXRDY (0x0100)
3385 #define MCF548X_PSC_IMR_RXRDY_FU (0x0200)
3386 #define MCF548X_PSC_IMR_DB (0x0400)
3387 #define MCF548X_PSC_IMR_IPC (0x8000)
3388
3389 /* Bit definitions and macros for MCF548X_PSC_IP */
3390 #define MCF548X_PSC_IP_CTS (0x01)
3391 #define MCF548X_PSC_IP_TGL (0x40)
3392 #define MCF548X_PSC_IP_LWPR_B (0x80)
3393
3394 /* Bit definitions and macros for MCF548X_PSC_OPSET */
3395 #define MCF548X_PSC_OPSET_RTS (0x01)
3396
3397 /* Bit definitions and macros for MCF548X_PSC_OPRESET */
3398 #define MCF548X_PSC_OPRESET_RTS (0x01)
3399
3400 /* Bit definitions and macros for MCF548X_PSC_SICR */
3401 #define MCF548X_PSC_SICR_SIM(x) (((x)&0x07)<<0)
3402 #define MCF548X_PSC_SICR_SHDIR (0x10)
3403 #define MCF548X_PSC_SICR_DTS (0x20)
3404 #define MCF548X_PSC_SICR_AWR (0x40)
3405 #define MCF548X_PSC_SICR_ACRB (0x80)
3406 #define MCF548X_PSC_SICR_SIM_UART (0x00)
3407 #define MCF548X_PSC_SICR_SIM_MODEM8 (0x01)
3408 #define MCF548X_PSC_SICR_SIM_MODEM16 (0x02)
3409 #define MCF548X_PSC_SICR_SIM_AC97 (0x03)
3410 #define MCF548X_PSC_SICR_SIM_SIR (0x04)
3411 #define MCF548X_PSC_SICR_SIM_MIR (0x05)
3412 #define MCF548X_PSC_SICR_SIM_FIR (0x06)
3413
3414 /* Bit definitions and macros for MCF548X_PSC_IRCR1 */
3415 #define MCF548X_PSC_IRCR1_SPUL (0x01)
3416 #define MCF548X_PSC_IRCR1_SIPEN (0x02)
3417 #define MCF548X_PSC_IRCR1_FD (0x04)
3418
3419 /* Bit definitions and macros for MCF548X_PSC_IRCR2 */
3420 #define MCF548X_PSC_IRCR2_NXTEOF (0x01)
3421 #define MCF548X_PSC_IRCR2_ABORT (0x02)
3422 #define MCF548X_PSC_IRCR2_SIPREQ (0x04)
3423
3424 /* Bit definitions and macros for MCF548X_PSC_IRMDR */
3425 #define MCF548X_PSC_IRMDR_M_FDIV(x) (((x)&0x7F)<<0)
3426 #define MCF548X_PSC_IRMDR_FREQ (0x80)
3427
3428 /* Bit definitions and macros for MCF548X_PSC_IRFDR */
3429 #define MCF548X_PSC_IRFDR_F_FDIV(x) (((x)&0x0F)<<0)
3430
3431 /* Bit definitions and macros for MCF548X_PSC_RFCNT */
3432 #define MCF548X_PSC_RFCNT_CNT(x) (((x)&0x01FF)<<0)
3433
3434 /* Bit definitions and macros for MCF548X_PSC_TFCNT */
3435 #define MCF548X_PSC_TFCNT_CNT(x) (((x)&0x01FF)<<0)
3436
3437 /* Bit definitions and macros for MCF548X_PSC_RFSR */
3438 #define MCF548X_PSC_RFSR_EMT (0x0001)
3439 #define MCF548X_PSC_RFSR_ALARM (0x0002)
3440 #define MCF548X_PSC_RFSR_FU (0x0004)
3441 #define MCF548X_PSC_RFSR_FRMRY (0x0008)
3442 #define MCF548X_PSC_RFSR_OF (0x0010)
3443 #define MCF548X_PSC_RFSR_UF (0x0020)
3444 #define MCF548X_PSC_RFSR_RXW (0x0040)
3445 #define MCF548X_PSC_RFSR_FAE (0x0080)
3446 #define MCF548X_PSC_RFSR_FRM(x) (((x)&0x000F)<<8)
3447 #define MCF548X_PSC_RFSR_TAG (0x1000)
3448 #define MCF548X_PSC_RFSR_TXW (0x4000)
3449 #define MCF548X_PSC_RFSR_IP (0x8000)
3450 #define MCF548X_PSC_RFSR_FRM_BYTE0 (0x0800)
3451 #define MCF548X_PSC_RFSR_FRM_BYTE1 (0x0400)
3452 #define MCF548X_PSC_RFSR_FRM_BYTE2 (0x0200)
3453 #define MCF548X_PSC_RFSR_FRM_BYTE3 (0x0100)
3454
3455 /* Bit definitions and macros for MCF548X_PSC_TFSR */
3456 #define MCF548X_PSC_TFSR_EMT (0x0001)
3457 #define MCF548X_PSC_TFSR_ALARM (0x0002)
3458 #define MCF548X_PSC_TFSR_FU (0x0004)
3459 #define MCF548X_PSC_TFSR_FRMRY (0x0008)
3460 #define MCF548X_PSC_TFSR_OF (0x0010)
3461 #define MCF548X_PSC_TFSR_UF (0x0020)
3462 #define MCF548X_PSC_TFSR_RXW (0x0040)
3463 #define MCF548X_PSC_TFSR_FAE (0x0080)
3464 #define MCF548X_PSC_TFSR_FRM(x) (((x)&0x000F)<<8)
3465 #define MCF548X_PSC_TFSR_TAG (0x1000)
3466 #define MCF548X_PSC_TFSR_TXW (0x4000)
3467 #define MCF548X_PSC_TFSR_IP (0x8000)
3468 #define MCF548X_PSC_TFSR_FRM_BYTE0 (0x0800)
3469 #define MCF548X_PSC_TFSR_FRM_BYTE1 (0x0400)
3470 #define MCF548X_PSC_TFSR_FRM_BYTE2 (0x0200)
3471 #define MCF548X_PSC_TFSR_FRM_BYTE3 (0x0100)
3472
3473 /* Bit definitions and macros for MCF548X_PSC_RFCR */
3474 #define MCF548X_PSC_RFCR_CNTR(x) (((x)&0x0000FFFF)<<0)
3475 #define MCF548X_PSC_RFCR_TXW_MSK (0x00040000)
3476 #define MCF548X_PSC_RFCR_OF_MSK (0x00080000)
3477 #define MCF548X_PSC_RFCR_UF_MSK (0x00100000)
3478 #define MCF548X_PSC_RFCR_RXW_MSK (0x00200000)
3479 #define MCF548X_PSC_RFCR_FAE_MSK (0x00400000)
3480 #define MCF548X_PSC_RFCR_IP_MSK (0x00800000)
3481 #define MCF548X_PSC_RFCR_GR(x) (((x)&0x00000007)<<24)
3482 #define MCF548X_PSC_RFCR_FRMEN (0x08000000)
3483 #define MCF548X_PSC_RFCR_TIMER (0x10000000)
3484 #define MCF548X_PSC_RFCR_WRITETAG (0x20000000)
3485 #define MCF548X_PSC_RFCR_SHADOW (0x80000000)
3486
3487 /* Bit definitions and macros for MCF548X_PSC_TFCR */
3488 #define MCF548X_PSC_TFCR_CNTR(x) (((x)&0x0000FFFF)<<0)
3489 #define MCF548X_PSC_TFCR_TXW_MSK (0x00040000)
3490 #define MCF548X_PSC_TFCR_OF_MSK (0x00080000)
3491 #define MCF548X_PSC_TFCR_UF_MSK (0x00100000)
3492 #define MCF548X_PSC_TFCR_RXW_MSK (0x00200000)
3493 #define MCF548X_PSC_TFCR_FAE_MSK (0x00400000)
3494 #define MCF548X_PSC_TFCR_IP_MSK (0x00800000)
3495 #define MCF548X_PSC_TFCR_GR(x) (((x)&0x00000007)<<24)
3496 #define MCF548X_PSC_TFCR_FRMEN (0x08000000)
3497 #define MCF548X_PSC_TFCR_TIMER (0x10000000)
3498 #define MCF548X_PSC_TFCR_WRITETAG (0x20000000)
3499 #define MCF548X_PSC_TFCR_SHADOW (0x80000000)
3500
3501 /* Bit definitions and macros for MCF548X_PSC_RFAR */
3502 #define MCF548X_PSC_RFAR_ALARM(x) (((x)&0x01FF)<<0)
3503
3504 /* Bit definitions and macros for MCF548X_PSC_TFAR */
3505 #define MCF548X_PSC_TFAR_ALARM(x) (((x)&0x01FF)<<0)
3506
3507 /* Bit definitions and macros for MCF548X_PSC_RFRP */
3508 #define MCF548X_PSC_RFRP_READ(x) (((x)&0x01FF)<<0)
3509
3510 /* Bit definitions and macros for MCF548X_PSC_TFRP */
3511 #define MCF548X_PSC_TFRP_READ(x) (((x)&0x01FF)<<0)
3512
3513 /* Bit definitions and macros for MCF548X_PSC_RFWP */
3514 #define MCF548X_PSC_RFWP_WRITE(x) (((x)&0x01FF)<<0)
3515
3516 /* Bit definitions and macros for MCF548X_PSC_TFWP */
3517 #define MCF548X_PSC_TFWP_WRITE(x) (((x)&0x01FF)<<0)
3518
3519 /* Bit definitions and macros for MCF548X_PSC_RLRFP */
3520 #define MCF548X_PSC_RLRFP_LFP(x) (((x)&0x01FF)<<0)
3521
3522 /* Bit definitions and macros for MCF548X_PSC_TLRFP */
3523 #define MCF548X_PSC_TLRFP_LFP(x) (((x)&0x01FF)<<0)
3524
3525 /* Bit definitions and macros for MCF548X_PSC_RLWFP */
3526 #define MCF548X_PSC_RLWFP_LFP(x) (((x)&0x01FF)<<0)
3527
3528 /* Bit definitions and macros for MCF548X_PSC_TLWFP */
3529 #define MCF548X_PSC_TLWFP_LFP(x) (((x)&0x01FF)<<0)
3530
3531
3532 /*********************************************************************
3533 *
3534 * 32KByte System SRAM (SRAM)
3535 *
3536 *********************************************************************/
3537
3538 /* Register read/write macros */
3539 #define MCF548X_SRAM_SSCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x01FFC0)))
3540 #define MCF548X_SRAM_TCCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x01FFC4)))
3541 #define MCF548X_SRAM_TCCRDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x01FFC8)))
3542 #define MCF548X_SRAM_TCCRDW (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x01FFCC)))
3543 #define MCF548X_SRAM_TCCRSEC (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x01FFD0)))
3544
3545 /* Bit definitions and macros for MCF548X_SRAM_SSCR */
3546 #define MCF548X_SRAM_SSCR_INLV (0x00010000)
3547
3548 /* Bit definitions and macros for MCF548X_SRAM_TCCR */
3549 #define MCF548X_SRAM_TCCR_BANK0_TC(x) (((x)&0x0000000F)<<0)
3550 #define MCF548X_SRAM_TCCR_BANK1_TC(x) (((x)&0x0000000F)<<8)
3551 #define MCF548X_SRAM_TCCR_BANK2_TC(x) (((x)&0x0000000F)<<16)
3552 #define MCF548X_SRAM_TCCR_BANK3_TC(x) (((x)&0x0000000F)<<24)
3553
3554 /* Bit definitions and macros for MCF548X_SRAM_TCCRDR */
3555 #define MCF548X_SRAM_TCCRDR_BANK0_TC(x) (((x)&0x0000000F)<<0)
3556 #define MCF548X_SRAM_TCCRDR_BANK1_TC(x) (((x)&0x0000000F)<<8)
3557 #define MCF548X_SRAM_TCCRDR_BANK2_TC(x) (((x)&0x0000000F)<<16)
3558 #define MCF548X_SRAM_TCCRDR_BANK3_TC(x) (((x)&0x0000000F)<<24)
3559
3560 /* Bit definitions and macros for MCF548X_SRAM_TCCRDW */
3561 #define MCF548X_SRAM_TCCRDW_BANK0_TC(x) (((x)&0x0000000F)<<0)
3562 #define MCF548X_SRAM_TCCRDW_BANK1_TC(x) (((x)&0x0000000F)<<8)
3563 #define MCF548X_SRAM_TCCRDW_BANK2_TC(x) (((x)&0x0000000F)<<16)
3564 #define MCF548X_SRAM_TCCRDW_BANK3_TC(x) (((x)&0x0000000F)<<24)
3565
3566 /* Bit definitions and macros for MCF548X_SRAM_TCCRSEC */
3567 #define MCF548X_SRAM_TCCRSEC_BANK0_TC(x) (((x)&0x0000000F)<<0)
3568 #define MCF548X_SRAM_TCCRSEC_BANK1_TC(x) (((x)&0x0000000F)<<8)
3569 #define MCF548X_SRAM_TCCRSEC_BANK2_TC(x) (((x)&0x0000000F)<<16)
3570 #define MCF548X_SRAM_TCCRSEC_BANK3_TC(x) (((x)&0x0000000F)<<24)
3571
3572
3573 /*********************************************************************
3574 *
3575 * PCI Bus Controller (PCI)
3576 *
3577 *********************************************************************/
3578
3579 /* Register read/write macros */
3580 #define MCF548X_PCI_PCIIDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B00)))
3581 #define MCF548X_PCI_PCISCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B04)))
3582 #define MCF548X_PCI_PCICCRIR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B08)))
3583 #define MCF548X_PCI_PCICR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B0C)))
3584 #define MCF548X_PCI_PCIBAR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B10)))
3585 #define MCF548X_PCI_PCIBAR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B14)))
3586 #define MCF548X_PCI_PCICR2 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B3C)))
3587 #define MCF548X_PCI_PCIGSCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B60)))
3588 #define MCF548X_PCI_PCITBATR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B64)))
3589 #define MCF548X_PCI_PCITBATR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B68)))
3590 #define MCF548X_PCI_PCITCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B6C)))
3591 #define MCF548X_PCI_PCIIW0BTAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B70)))
3592 #define MCF548X_PCI_PCIIW1BTAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B74)))
3593 #define MCF548X_PCI_PCIIW2BTAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B78)))
3594 #define MCF548X_PCI_PCIIWCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B80)))
3595 #define MCF548X_PCI_PCIICR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B84)))
3596 #define MCF548X_PCI_PCIISR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000B88)))
3597 #define MCF548X_PCI_PCICAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000BF8)))
3598 #define MCF548X_PCI_PCITPSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008400)))
3599 #define MCF548X_PCI_PCITSAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008404)))
3600 #define MCF548X_PCI_PCITTCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008408)))
3601 #define MCF548X_PCI_PCITER (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00840C)))
3602 #define MCF548X_PCI_PCITNAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008410)))
3603 #define MCF548X_PCI_PCITLWR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008414)))
3604 #define MCF548X_PCI_PCITDCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008418)))
3605 #define MCF548X_PCI_PCITSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00841C)))
3606 #define MCF548X_PCI_PCITFDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008440)))
3607 #define MCF548X_PCI_PCITFSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008444)))
3608 #define MCF548X_PCI_PCITFCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008448)))
3609 #define MCF548X_PCI_PCITFAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00844C)))
3610 #define MCF548X_PCI_PCITFRPR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008450)))
3611 #define MCF548X_PCI_PCITFWPR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008454)))
3612 #define MCF548X_PCI_PCIRPSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008480)))
3613 #define MCF548X_PCI_PCIRSAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008484)))
3614 #define MCF548X_PCI_PCIRTCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008488)))
3615 #define MCF548X_PCI_PCIRER (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00848C)))
3616 #define MCF548X_PCI_PCIRNAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008490)))
3617 #define MCF548X_PCI_PCIRDCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008498)))
3618 #define MCF548X_PCI_PCIRSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00849C)))
3619 #define MCF548X_PCI_PCIRFDR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0084C0)))
3620 #define MCF548X_PCI_PCIRFSR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0084C4)))
3621 #define MCF548X_PCI_PCIRFCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0084C8)))
3622 #define MCF548X_PCI_PCIRFAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0084CC)))
3623 #define MCF548X_PCI_PCIRFRPR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0084D0)))
3624 #define MCF548X_PCI_PCIRFWPR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x0084D4)))
3625
3626 /* Bit definitions and macros for MCF548X_PCI_PCIIDR */
3627 #define MCF548X_PCI_PCIIDR_VENDORID(x) (((x)&0x0000FFFF)<<0)
3628 #define MCF548X_PCI_PCIIDR_DEVICEID(x) (((x)&0x0000FFFF)<<16)
3629
3630 /* Bit definitions and macros for MCF548X_PCI_PCISCR */
3631 #define MCF548X_PCI_PCISCR_M (0x00000002)
3632 #define MCF548X_PCI_PCISCR_B (0x00000004)
3633 #define MCF548X_PCI_PCISCR_SP (0x00000008)
3634 #define MCF548X_PCI_PCISCR_MW (0x00000010)
3635 #define MCF548X_PCI_PCISCR_PER (0x00000040)
3636 #define MCF548X_PCI_PCISCR_S (0x00000100)
3637 #define MCF548X_PCI_PCISCR_F (0x00000200)
3638 #define MCF548X_PCI_PCISCR_C (0x00100000)
3639 #define MCF548X_PCI_PCISCR_66M (0x00200000)
3640 #define MCF548X_PCI_PCISCR_R (0x00400000)
3641 #define MCF548X_PCI_PCISCR_FC (0x00800000)
3642 #define MCF548X_PCI_PCISCR_DP (0x01000000)
3643 #define MCF548X_PCI_PCISCR_DT(x) (((x)&0x00000003)<<25)
3644 #define MCF548X_PCI_PCISCR_TS (0x08000000)
3645 #define MCF548X_PCI_PCISCR_TR (0x10000000)
3646 #define MCF548X_PCI_PCISCR_MA (0x20000000)
3647 #define MCF548X_PCI_PCISCR_SE (0x40000000)
3648 #define MCF548X_PCI_PCISCR_PE (0x80000000)
3649
3650 /* Bit definitions and macros for MCF548X_PCI_PCICCRIR */
3651 #define MCF548X_PCI_PCICCRIR_REVID(x) (((x)&0x000000FF)<<0)
3652 #define MCF548X_PCI_PCICCRIR_CLASSCODE(x) (((x)&0x00FFFFFF)<<8)
3653
3654 /* Bit definitions and macros for MCF548X_PCI_PCICR1 */
3655 #define MCF548X_PCI_PCICR1_CACHELINESIZE(x) (((x)&0x0000000F)<<0)
3656 #define MCF548X_PCI_PCICR1_LATTIMER(x) (((x)&0x000000FF)<<8)
3657 #define MCF548X_PCI_PCICR1_HEADERTYPE(x) (((x)&0x000000FF)<<16)
3658 #define MCF548X_PCI_PCICR1_BIST(x) (((x)&0x000000FF)<<24)
3659
3660 /* Bit definitions and macros for MCF548X_PCI_PCIBAR0 */
3661 #define MCF548X_PCI_PCIBAR0_IO (0x00000001)
3662 #define MCF548X_PCI_PCIBAR0_RANGE(x) (((x)&0x00000003)<<1)
3663 #define MCF548X_PCI_PCIBAR0_PREF (0x00000008)
3664 #define MCF548X_PCI_PCIBAR0_BAR0(x) (((x)&0x00003FFF)<<18)
3665
3666 /* Bit definitions and macros for MCF548X_PCI_PCIBAR1 */
3667 #define MCF548X_PCI_PCIBAR1_IO (0x00000001)
3668 #define MCF548X_PCI_PCIBAR1_PREF (0x00000008)
3669 #define MCF548X_PCI_PCIBAR1_BAR1(x) (((x)&0x00000003)<<30)
3670
3671 /* Bit definitions and macros for MCF548X_PCI_PCICR2 */
3672 #define MCF548X_PCI_PCICR2_INTLINE(x) (((x)&0x000000FF)<<0)
3673 #define MCF548X_PCI_PCICR2_INTPIN(x) (((x)&0x000000FF)<<8)
3674 #define MCF548X_PCI_PCICR2_MINGNT(x) (((x)&0x000000FF)<<16)
3675 #define MCF548X_PCI_PCICR2_MAXLAT(x) (((x)&0x000000FF)<<24)
3676
3677 /* Bit definitions and macros for MCF548X_PCI_PCIGSCR */
3678 #define MCF548X_PCI_PCIGSCR_PR (0x00000001)
3679 #define MCF548X_PCI_PCIGSCR_SEE (0x00001000)
3680 #define MCF548X_PCI_PCIGSCR_PEE (0x00002000)
3681 #define MCF548X_PCI_PCIGSCR_SE (0x10000000)
3682 #define MCF548X_PCI_PCIGSCR_PE (0x20000000)
3683
3684 /* Bit definitions and macros for MCF548X_PCI_PCITBATR0 */
3685 #define MCF548X_PCI_PCITBATR0_EN (0x00000001)
3686 #define MCF548X_PCI_PCITBATR0_BAT0(x) (((x)&0x00003FFF)<<18)
3687
3688 /* Bit definitions and macros for MCF548X_PCI_PCITBATR1 */
3689 #define MCF548X_PCI_PCITBATR1_EN (0x00000001)
3690 #define MCF548X_PCI_PCITBATR1_BAT1(x) (((x)&0x00000003)<<30)
3691
3692 /* Bit definitions and macros for MCF548X_PCI_PCITCR */
3693 #define MCF548X_PCI_PCITCR_P (0x00010000)
3694 #define MCF548X_PCI_PCITCR_LD (0x01000000)
3695
3696 /* Bit definitions and macros for MCF548X_PCI_PCIIW0BTAR */
3697 #define MCF548X_PCI_PCIIW0BTAR_WTA0(x) (((x)&0x000000FF)<<8)
3698 #define MCF548X_PCI_PCIIW0BTAR_WAM0(x) (((x)&0x000000FF)<<16)
3699 #define MCF548X_PCI_PCIIW0BTAR_WBA0(x) (((x)&0x000000FF)<<24)
3700
3701 /* Bit definitions and macros for MCF548X_PCI_PCIIW1BTAR */
3702 #define MCF548X_PCI_PCIIW1BTAR_WTA1(x) (((x)&0x000000FF)<<8)
3703 #define MCF548X_PCI_PCIIW1BTAR_WAM1(x) (((x)&0x000000FF)<<16)
3704 #define MCF548X_PCI_PCIIW1BTAR_WBA1(x) (((x)&0x000000FF)<<24)
3705
3706 /* Bit definitions and macros for MCF548X_PCI_PCIIW2BTAR */
3707 #define MCF548X_PCI_PCIIW2BTAR_WTA2(x) (((x)&0x000000FF)<<8)
3708 #define MCF548X_PCI_PCIIW2BTAR_WAM2(x) (((x)&0x000000FF)<<16)
3709 #define MCF548X_PCI_PCIIW2BTAR_WBA2(x) (((x)&0x000000FF)<<24)
3710
3711 /* Bit definitions and macros for MCF548X_PCI_PCIIWCR */
3712 #define MCF548X_PCI_PCIIWCR_WINCTRL2(x) (((x)&0x0000000F)<<8)
3713 #define MCF548X_PCI_PCIIWCR_WINCTRL1(x) (((x)&0x0000000F)<<16)
3714 #define MCF548X_PCI_PCIIWCR_WINCTRL0(x) (((x)&0x0000000F)<<24)
3715 #define MCF548X_PCI_PCIIWCR_WINCTRL0_MEMREAD (0x01000000)
3716 #define MCF548X_PCI_PCIIWCR_WINCTRL0_MEMRDLINE (0x03000000)
3717 #define MCF548X_PCI_PCIIWCR_WINCTRL0_MEMRDMUL (0x05000000)
3718 #define MCF548X_PCI_PCIIWCR_WINCTRL0_IO (0x09000000)
3719 #define MCF548X_PCI_PCIIWCR_WINCTRL1_MEMREAD (0x00010000)
3720 #define MCF548X_PCI_PCIIWCR_WINCTRL1_MEMRDLINE (0x00030000)
3721 #define MCF548X_PCI_PCIIWCR_WINCTRL1_MEMRDMUL (0x00050000)
3722 #define MCF548X_PCI_PCIIWCR_WINCTRL1_IO (0x00090000)
3723 #define MCF548X_PCI_PCIIWCR_WINCTRL2_MEMREAD (0x00000100)
3724 #define MCF548X_PCI_PCIIWCR_WINCTRL2_MEMRDLINE (0x00000300)
3725 #define MCF548X_PCI_PCIIWCR_WINCTRL2_MEMRDMUL (0x00000500)
3726 #define MCF548X_PCI_PCIIWCR_WINCTRL2_IO (0x00000900)
3727
3728 /* Bit definitions and macros for MCF548X_PCI_PCIICR */
3729 #define MCF548X_PCI_PCIICR_MAXRETRY(x) (((x)&0x000000FF)<<0)
3730 #define MCF548X_PCI_PCIICR_TAE (0x01000000)
3731 #define MCF548X_PCI_PCIICR_IAE (0x02000000)
3732 #define MCF548X_PCI_PCIICR_REE (0x04000000)
3733
3734 /* Bit definitions and macros for MCF548X_PCI_PCIISR */
3735 #define MCF548X_PCI_PCIISR_TA (0x01000000)
3736 #define MCF548X_PCI_PCIISR_IA (0x02000000)
3737 #define MCF548X_PCI_PCIISR_RE (0x04000000)
3738
3739 /* Bit definitions and macros for MCF548X_PCI_PCICAR */
3740 #define MCF548X_PCI_PCICAR_DWORD(x) (((x)&0x0000003F)<<2)
3741 #define MCF548X_PCI_PCICAR_FUNCNUM(x) (((x)&0x00000007)<<8)
3742 #define MCF548X_PCI_PCICAR_DEVNUM(x) (((x)&0x0000001F)<<11)
3743 #define MCF548X_PCI_PCICAR_BUSNUM(x) (((x)&0x000000FF)<<16)
3744 #define MCF548X_PCI_PCICAR_E (0x80000000)
3745
3746 /* Bit definitions and macros for MCF548X_PCI_PCITPSR */
3747 #define MCF548X_PCI_PCITPSR_PKTSIZE(x) (((x)&0x0000FFFF)<<16)
3748
3749 /* Bit definitions and macros for MCF548X_PCI_PCITTCR */
3750 #define MCF548X_PCI_PCITTCR_DI (0x00000001)
3751 #define MCF548X_PCI_PCITTCR_W (0x00000010)
3752 #define MCF548X_PCI_PCITTCR_MAXBEATS(x) (((x)&0x00000007)<<8)
3753 #define MCF548X_PCI_PCITTCR_MAXRETRY(x) (((x)&0x000000FF)<<16)
3754 #define MCF548X_PCI_PCITTCR_PCICMD(x) (((x)&0x0000000F)<<24)
3755
3756 /* Bit definitions and macros for MCF548X_PCI_PCITER */
3757 #define MCF548X_PCI_PCITER_NE (0x00010000)
3758 #define MCF548X_PCI_PCITER_IAE (0x00020000)
3759 #define MCF548X_PCI_PCITER_TAE (0x00040000)
3760 #define MCF548X_PCI_PCITER_RE (0x00080000)
3761 #define MCF548X_PCI_PCITER_SE (0x00100000)
3762 #define MCF548X_PCI_PCITER_FEE (0x00200000)
3763 #define MCF548X_PCI_PCITER_ME (0x01000000)
3764 #define MCF548X_PCI_PCITER_BE (0x08000000)
3765 #define MCF548X_PCI_PCITER_CM (0x10000000)
3766 #define MCF548X_PCI_PCITER_RF (0x40000000)
3767 #define MCF548X_PCI_PCITER_RC (0x80000000)
3768
3769 /* Bit definitions and macros for MCF548X_PCI_PCITDCR */
3770 #define MCF548X_PCI_PCITDCR_PKTSDONE(x) (((x)&0x0000FFFF)<<0)
3771 #define MCF548X_PCI_PCITDCR_BYTESDONE(x) (((x)&0x0000FFFF)<<16)
3772
3773 /* Bit definitions and macros for MCF548X_PCI_PCITSR */
3774 #define MCF548X_PCI_PCITSR_IA (0x00010000)
3775 #define MCF548X_PCI_PCITSR_TA (0x00020000)
3776 #define MCF548X_PCI_PCITSR_RE (0x00040000)
3777 #define MCF548X_PCI_PCITSR_SE (0x00080000)
3778 #define MCF548X_PCI_PCITSR_FE (0x00100000)
3779 #define MCF548X_PCI_PCITSR_BE1 (0x00200000)
3780 #define MCF548X_PCI_PCITSR_BE2 (0x00400000)
3781 #define MCF548X_PCI_PCITSR_BE3 (0x00800000)
3782 #define MCF548X_PCI_PCITSR_NT (0x01000000)
3783
3784 /* Bit definitions and macros for MCF548X_PCI_PCITFSR */
3785 #define MCF548X_PCI_PCITFSR_EMT (0x00010000)
3786 #define MCF548X_PCI_PCITFSR_ALARM (0x00020000)
3787 #define MCF548X_PCI_PCITFSR_FU (0x00040000)
3788 #define MCF548X_PCI_PCITFSR_FR (0x00080000)
3789 #define MCF548X_PCI_PCITFSR_OF (0x00100000)
3790 #define MCF548X_PCI_PCITFSR_UF (0x00200000)
3791 #define MCF548X_PCI_PCITFSR_RXW (0x00400000)
3792
3793 /* Bit definitions and macros for MCF548X_PCI_PCITFCR */
3794 #define MCF548X_PCI_PCITFCR_OF_MSK (0x00080000)
3795 #define MCF548X_PCI_PCITFCR_UF_MSK (0x00100000)
3796 #define MCF548X_PCI_PCITFCR_RXW_MSK (0x00200000)
3797 #define MCF548X_PCI_PCITFCR_FAE_MSK (0x00400000)
3798 #define MCF548X_PCI_PCITFCR_IP_MSK (0x00800000)
3799 #define MCF548X_PCI_PCITFCR_GR(x) (((x)&0x00000007)<<24)
3800
3801 /* Bit definitions and macros for MCF548X_PCI_PCITFAR */
3802 #define MCF548X_PCI_PCITFAR_ALARM(x) (((x)&0x0000007F)<<0)
3803
3804 /* Bit definitions and macros for MCF548X_PCI_PCITFRPR */
3805 #define MCF548X_PCI_PCITFRPR_READ(x) (((x)&0x00000FFF)<<0)
3806
3807 /* Bit definitions and macros for MCF548X_PCI_PCITFWPR */
3808 #define MCF548X_PCI_PCITFWPR_WRITE(x) (((x)&0x00000FFF)<<0)
3809
3810 /* Bit definitions and macros for MCF548X_PCI_PCIRPSR */
3811 #define MCF548X_PCI_PCIRPSR_PKTSIZE(x) (((x)&0x0000FFFF)<<16)
3812
3813 /* Bit definitions and macros for MCF548X_PCI_PCIRTCR */
3814 #define MCF548X_PCI_PCIRTCR_DI (0x00000001)
3815 #define MCF548X_PCI_PCIRTCR_W (0x00000010)
3816 #define MCF548X_PCI_PCIRTCR_MAXBEATS(x) (((x)&0x00000007)<<8)
3817 #define MCF548X_PCI_PCIRTCR_FB (0x00001000)
3818 #define MCF548X_PCI_PCIRTCR_MAXRETRY(x) (((x)&0x000000FF)<<16)
3819 #define MCF548X_PCI_PCIRTCR_PCICMD(x) (((x)&0x0000000F)<<24)
3820
3821 /* Bit definitions and macros for MCF548X_PCI_PCIRER */
3822 #define MCF548X_PCI_PCIRER_NE (0x00010000)
3823 #define MCF548X_PCI_PCIRER_IAE (0x00020000)
3824 #define MCF548X_PCI_PCIRER_TAE (0x00040000)
3825 #define MCF548X_PCI_PCIRER_RE (0x00080000)
3826 #define MCF548X_PCI_PCIRER_SE (0x00100000)
3827 #define MCF548X_PCI_PCIRER_FEE (0x00200000)
3828 #define MCF548X_PCI_PCIRER_ME (0x01000000)
3829 #define MCF548X_PCI_PCIRER_BE (0x08000000)
3830 #define MCF548X_PCI_PCIRER_CM (0x10000000)
3831 #define MCF548X_PCI_PCIRER_FE (0x20000000)
3832 #define MCF548X_PCI_PCIRER_RF (0x40000000)
3833 #define MCF548X_PCI_PCIRER_RC (0x80000000)
3834
3835 /* Bit definitions and macros for MCF548X_PCI_PCIRDCR */
3836 #define MCF548X_PCI_PCIRDCR_PKTSDONE(x) (((x)&0x0000FFFF)<<0)
3837 #define MCF548X_PCI_PCIRDCR_BYTESDONE(x) (((x)&0x0000FFFF)<<16)
3838
3839 /* Bit definitions and macros for MCF548X_PCI_PCIRSR */
3840 #define MCF548X_PCI_PCIRSR_IA (0x00010000)
3841 #define MCF548X_PCI_PCIRSR_TA (0x00020000)
3842 #define MCF548X_PCI_PCIRSR_RE (0x00040000)
3843 #define MCF548X_PCI_PCIRSR_SE (0x00080000)
3844 #define MCF548X_PCI_PCIRSR_FE (0x00100000)
3845 #define MCF548X_PCI_PCIRSR_BE1 (0x00200000)
3846 #define MCF548X_PCI_PCIRSR_BE2 (0x00400000)
3847 #define MCF548X_PCI_PCIRSR_BE3 (0x00800000)
3848 #define MCF548X_PCI_PCIRSR_NT (0x01000000)
3849
3850 /* Bit definitions and macros for MCF548X_PCI_PCIRFSR */
3851 #define MCF548X_PCI_PCIRFSR_EMT (0x00010000)
3852 #define MCF548X_PCI_PCIRFSR_ALARM (0x00020000)
3853 #define MCF548X_PCI_PCIRFSR_FU (0x00040000)
3854 #define MCF548X_PCI_PCIRFSR_FR (0x00080000)
3855 #define MCF548X_PCI_PCIRFSR_OF (0x00100000)
3856 #define MCF548X_PCI_PCIRFSR_UF (0x00200000)
3857 #define MCF548X_PCI_PCIRFSR_RXW (0x00400000)
3858
3859 /* Bit definitions and macros for MCF548X_PCI_PCIRFCR */
3860 #define MCF548X_PCI_PCIRFCR_OF_MSK (0x00080000)
3861 #define MCF548X_PCI_PCIRFCR_UF_MSK (0x00100000)
3862 #define MCF548X_PCI_PCIRFCR_RXW_MSK (0x00200000)
3863 #define MCF548X_PCI_PCIRFCR_FAE_MSK (0x00400000)
3864 #define MCF548X_PCI_PCIRFCR_IP_MSK (0x00800000)
3865 #define MCF548X_PCI_PCIRFCR_GR(x) (((x)&0x00000007)<<24)
3866
3867 /* Bit definitions and macros for MCF548X_PCI_PCIRFAR */
3868 #define MCF548X_PCI_PCIRFAR_ALARM(x) (((x)&0x0000007F)<<0)
3869
3870 /* Bit definitions and macros for MCF548X_PCI_PCIRFRPR */
3871 #define MCF548X_PCI_PCIRFRPR_READ(x) (((x)&0x00000FFF)<<0)
3872
3873 /* Bit definitions and macros for MCF548X_PCI_PCIRFWPR */
3874 #define MCF548X_PCI_PCIRFWPR_WRITE(x) (((x)&0x00000FFF)<<0)
3875
3876
3877 /*********************************************************************
3878 *
3879 * PCI Arbiter Module (PCIARB)
3880 *
3881 *********************************************************************/
3882
3883 /* Register read/write macros */
3884 #define MCF548X_PCIARB_PACR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000C00)))
3885 #define MCF548X_PCIARB_PASR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000C04)))
3886
3887 /* Bit definitions and macros for MCF548X_PCIARB_PACR */
3888 #define MCF548X_PCIARB_PACR_INTMPRI (0x00000001)
3889 #define MCF548X_PCIARB_PACR_EXTMPRI(x) (((x)&0x0000001F)<<1)
3890 #define MCF548X_PCIARB_PACR_INTMINTEN (0x00010000)
3891 #define MCF548X_PCIARB_PACR_EXTMINTEN(x) (((x)&0x0000001F)<<17)
3892 #define MCF548X_PCIARB_PACR_PKMD (0x40000000)
3893 #define MCF548X_PCIARB_PACR_DS (0x80000000)
3894
3895 /* Bit definitions and macros for MCF548X_PCIARB_PASR */
3896 #define MCF548X_PCIARB_PASR_ITLMBK (0x00010000)
3897 #define MCF548X_PCIARB_PASR_EXTMBK(x) (((x)&0x0000001F)<<17)
3898
3899
3900 /*********************************************************************
3901 *
3902 * Multi-Channel DMA (DMA)
3903 *
3904 *********************************************************************/
3905
3906 /* Register read/write macros */
3907 #define MCF548X_DMA_TASKBAR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008000)))
3908 #define MCF548X_DMA_CP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008004)))
3909 #define MCF548X_DMA_EP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008008)))
3910 #define MCF548X_DMA_VP (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00800C)))
3911 #define MCF548X_DMA_DIPR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008014)))
3912 #define MCF548X_DMA_DIMR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008018)))
3913 #define MCF548X_DMA_TCR0 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00801C)))
3914 #define MCF548X_DMA_TCR1 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00801E)))
3915 #define MCF548X_DMA_TCR2 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008020)))
3916 #define MCF548X_DMA_TCR3 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008022)))
3917 #define MCF548X_DMA_TCR4 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008024)))
3918 #define MCF548X_DMA_TCR5 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008026)))
3919 #define MCF548X_DMA_TCR6 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008028)))
3920 #define MCF548X_DMA_TCR7 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00802A)))
3921 #define MCF548X_DMA_TCR8 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00802C)))
3922 #define MCF548X_DMA_TCR9 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00802E)))
3923 #define MCF548X_DMA_TCR10 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008030)))
3924 #define MCF548X_DMA_TCR11 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008032)))
3925 #define MCF548X_DMA_TCR12 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008034)))
3926 #define MCF548X_DMA_TCR13 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008036)))
3927 #define MCF548X_DMA_TCR14 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x008038)))
3928 #define MCF548X_DMA_TCR15 (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00803A)))
3929 #define MCF548X_DMA_TCRn(x) (*(volatile uint16_t*)((uintptr_t)__MBAR + (0x00801CU+((x)*0x002))))
3930 #define MCF548X_DMA_IMCR (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x00805C)))
3931 #define MCF548X_DMA_PTDDBG (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x008080)))
3932
3933 /* Bit definitions and macros for MCF548X_DMA_DIPR */
3934 #define MCF548X_DMA_DIPR_TASK0 (0x00000001)
3935 #define MCF548X_DMA_DIPR_TASK1 (0x00000002)
3936 #define MCF548X_DMA_DIPR_TASK2 (0x00000004)
3937 #define MCF548X_DMA_DIPR_TASK3 (0x00000008)
3938 #define MCF548X_DMA_DIPR_TASK4 (0x00000010)
3939 #define MCF548X_DMA_DIPR_TASK5 (0x00000020)
3940 #define MCF548X_DMA_DIPR_TASK6 (0x00000040)
3941 #define MCF548X_DMA_DIPR_TASK7 (0x00000080)
3942 #define MCF548X_DMA_DIPR_TASK8 (0x00000100)
3943 #define MCF548X_DMA_DIPR_TASK9 (0x00000200)
3944 #define MCF548X_DMA_DIPR_TASK10 (0x00000400)
3945 #define MCF548X_DMA_DIPR_TASK11 (0x00000800)
3946 #define MCF548X_DMA_DIPR_TASK12 (0x00001000)
3947 #define MCF548X_DMA_DIPR_TASK13 (0x00002000)
3948 #define MCF548X_DMA_DIPR_TASK14 (0x00004000)
3949 #define MCF548X_DMA_DIPR_TASK15 (0x00008000)
3950
3951 /* Bit definitions and macros for MCF548X_DMA_DIMR */
3952 #define MCF548X_DMA_DIMR_TASK0 (0x00000001)
3953 #define MCF548X_DMA_DIMR_TASK1 (0x00000002)
3954 #define MCF548X_DMA_DIMR_TASK2 (0x00000004)
3955 #define MCF548X_DMA_DIMR_TASK3 (0x00000008)
3956 #define MCF548X_DMA_DIMR_TASK4 (0x00000010)
3957 #define MCF548X_DMA_DIMR_TASK5 (0x00000020)
3958 #define MCF548X_DMA_DIMR_TASK6 (0x00000040)
3959 #define MCF548X_DMA_DIMR_TASK7 (0x00000080)
3960 #define MCF548X_DMA_DIMR_TASK8 (0x00000100)
3961 #define MCF548X_DMA_DIMR_TASK9 (0x00000200)
3962 #define MCF548X_DMA_DIMR_TASK10 (0x00000400)
3963 #define MCF548X_DMA_DIMR_TASK11 (0x00000800)
3964 #define MCF548X_DMA_DIMR_TASK12 (0x00001000)
3965 #define MCF548X_DMA_DIMR_TASK13 (0x00002000)
3966 #define MCF548X_DMA_DIMR_TASK14 (0x00004000)
3967 #define MCF548X_DMA_DIMR_TASK15 (0x00008000)
3968
3969 /* Bit definitions and macros for MCF548X_DMA_IMCR */
3970 #define MCF548X_DMA_IMCR_SRC16(x) (((x)&0x00000003)<<0)
3971 #define MCF548X_DMA_IMCR_SRC17(x) (((x)&0x00000003)<<2)
3972 #define MCF548X_DMA_IMCR_SRC18(x) (((x)&0x00000003)<<4)
3973 #define MCF548X_DMA_IMCR_SRC19(x) (((x)&0x00000003)<<6)
3974 #define MCF548X_DMA_IMCR_SRC20(x) (((x)&0x00000003)<<8)
3975 #define MCF548X_DMA_IMCR_SRC21(x) (((x)&0x00000003)<<10)
3976 #define MCF548X_DMA_IMCR_SRC22(x) (((x)&0x00000003)<<12)
3977 #define MCF548X_DMA_IMCR_SRC23(x) (((x)&0x00000003)<<14)
3978 #define MCF548X_DMA_IMCR_SRC24(x) (((x)&0x00000003)<<16)
3979 #define MCF548X_DMA_IMCR_SRC25(x) (((x)&0x00000003)<<18)
3980 #define MCF548X_DMA_IMCR_SRC26(x) (((x)&0x00000003)<<20)
3981 #define MCF548X_DMA_IMCR_SRC27(x) (((x)&0x00000003)<<22)
3982 #define MCF548X_DMA_IMCR_SRC28(x) (((x)&0x00000003)<<24)
3983 #define MCF548X_DMA_IMCR_SRC29(x) (((x)&0x00000003)<<26)
3984 #define MCF548X_DMA_IMCR_SRC30(x) (((x)&0x00000003)<<28)
3985 #define MCF548X_DMA_IMCR_SRC31(x) (((x)&0x00000003)<<30)
3986 #define MCF548X_DMA_IMCR_SRC16_FEC0RX (0x00000000)
3987 #define MCF548X_DMA_IMCR_SRC17_FEC0TX (0x00000000)
3988 #define MCF548X_DMA_IMCR_SRC18_FEC0RX (0x00000020)
3989 #define MCF548X_DMA_IMCR_SRC19_FEC0TX (0x00000080)
3990 #define MCF548X_DMA_IMCR_SRC20_FEC1RX (0x00000100)
3991 #define MCF548X_DMA_IMCR_SRC21_DREQ1 (0x00000000)
3992 #define MCF548X_DMA_IMCR_SRC21_FEC1TX (0x00000400)
3993 #define MCF548X_DMA_IMCR_SRC22_FEC0RX (0x00001000)
3994 #define MCF548X_DMA_IMCR_SRC23_FEC0TX (0x00004000)
3995 #define MCF548X_DMA_IMCR_SRC24_CTM0 (0x00010000)
3996 #define MCF548X_DMA_IMCR_SRC24_FEC1RX (0x00020000)
3997 #define MCF548X_DMA_IMCR_SRC25_CTM1 (0x00040000)
3998 #define MCF548X_DMA_IMCR_SRC25_FEC1TX (0x00080000)
3999 #define MCF548X_DMA_IMCR_SRC26_USBEP4 (0x00000000)
4000 #define MCF548X_DMA_IMCR_SRC26_CTM2 (0x00200000)
4001 #define MCF548X_DMA_IMCR_SRC27_USBEP5 (0x00000000)
4002 #define MCF548X_DMA_IMCR_SRC27_CTM3 (0x00800000)
4003 #define MCF548X_DMA_IMCR_SRC28_USBEP6 (0x00000000)
4004 #define MCF548X_DMA_IMCR_SRC28_CTM4 (0x01000000)
4005 #define MCF548X_DMA_IMCR_SRC28_DREQ1 (0x02000000)
4006 #define MCF548X_DMA_IMCR_SRC28_PSC2RX (0x03000000)
4007 #define MCF548X_DMA_IMCR_SRC29_DREQ1 (0x04000000)
4008 #define MCF548X_DMA_IMCR_SRC29_CTM5 (0x08000000)
4009 #define MCF548X_DMA_IMCR_SRC29_PSC2TX (0x0C000000)
4010 #define MCF548X_DMA_IMCR_SRC30_FEC1RX (0x00000000)
4011 #define MCF548X_DMA_IMCR_SRC30_CTM6 (0x10000000)
4012 #define MCF548X_DMA_IMCR_SRC30_PSC3RX (0x30000000)
4013 #define MCF548X_DMA_IMCR_SRC31_FEC1TX (0x00000000)
4014 #define MCF548X_DMA_IMCR_SRC31_CTM7 (0x80000000)
4015 #define MCF548X_DMA_IMCR_SRC31_PSC3TX (0xC0000000)
4016
4017
4018 /*********************************************************************
4019 *
4020 * Multi-Channel DMA External Requests (DMA_EREQ)
4021 *
4022 *********************************************************************/
4023
4024 /* Register read/write macros */
4025 #define MCF548X_DMA_EREQ_EREQBAR0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D00)))
4026 #define MCF548X_DMA_EREQ_EREQMASK0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D04)))
4027 #define MCF548X_DMA_EREQ_EREQCTRL0 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D08)))
4028 #define MCF548X_DMA_EREQ_EREQBAR1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D10)))
4029 #define MCF548X_DMA_EREQ_EREQMASK1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D14)))
4030 #define MCF548X_DMA_EREQ_EREQCTRL1 (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D18)))
4031 #define MCF548X_DMA_EREQ_EREQBAR(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D00U+((x)*0x010))))
4032 #define MCF548X_DMA_EREQ_EREQMASK(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D04U+((x)*0x010))))
4033 #define MCF548X_DMA_EREQ_EREQCTRL(x) (*(volatile uint32_t*)((uintptr_t)__MBAR + (0x000D08U+((x)*0x010))))
4034
4035 /* Bit definitions and macros for MCF548X_DMA_EREQ_EREQCTRL */
4036 #define MCF548X_DMA_EREQ_EREQCTRL_EN (0x00000001)
4037 #define MCF548X_DMA_EREQ_EREQCTRL_SYNC (0x00000002)
4038 #define MCF548X_DMA_EREQ_EREQCTRL_DACKWID(x) (((x)&0x00000003)<<2)
4039 #define MCF548X_DMA_EREQ_EREQCTRL_BSEL(x) (((x)&0x00000003)<<4)
4040 #define MCF548X_DMA_EREQ_EREQCTRL_MD(x) (((x)&0x00000003)<<6)
4041 #define MCF548X_DMA_EREQ_EREQCTRL_MD_IDLE (0x00000000)
4042 #define MCF548X_DMA_EREQ_EREQCTRL_MD_LEVEL (0x00000040)
4043 #define MCF548X_DMA_EREQ_EREQCTRL_MD_EDGE (0x00000080)
4044 #define MCF548X_DMA_EREQ_EREQCTRL_MD_PIPED (0x000000C0)
4045 #define MCF548X_DMA_EREQ_EREQCTRL_BSEL_MEM_WRITE (0x00000000)
4046 #define MCF548X_DMA_EREQ_EREQCTRL_BSEL_MEM_READ (0x00000010)
4047 #define MCF548X_DMA_EREQ_EREQCTRL_BSEL_PERIPH_WRITE (0x00000020)
4048 #define MCF548X_DMA_EREQ_EREQCTRL_BSEL_PERIPH_READ (0x00000030)
4049 #define MCF548X_DMA_EREQ_EREQCTRL_DACKWID_ONE (0x00000000)
4050 #define MCF548X_DMA_EREQ_EREQCTRL_DACKWID_TWO (0x00000004)
4051 #define MCF548X_DMA_EREQ_EREQCTRL_DACKWID_THREE (0x00000008)
4052 #define MCF548X_DMA_EREQ_EREQCTRL_DACKWID_FOUR (0x0000000C)
4053
4054 /*********************************************************************/
4055
4056 #endif /* __MCF548X_H__ */
