RTEMS  5.1
mcf5282.h
1 /*
2  *******************************************
3  * Definitions from Motorola/FreeScale *
4  *******************************************
5  */
6
7 /*
8  * File: mcf5282.h
9  * Purpose: MCF5282 definitions
10  *
11  * Notes:
12  */
13
14 #ifndef _CPU_MCF5282_H
15 #define _CPU_MCF5282_H
16
17 /********************************************************************/
18
19 /*
20  * File: mcf5xxx.h
21  * Purpose: Definitions common to all ColdFire processors
22  *
23  * Notes:
24  */
25
26 #ifndef _CPU_MCF5XXX_H
27 #define _CPU_MCF5XXX_H
28
29 /***********************************************************************/
30 /*
31  * The basic data types
32  *
33  * Those are low-level so we mark them so that they may alias anything
34  */
35
36 typedef unsigned char uint8; /* 8 bits */
37 typedef unsigned short int uint16 __attribute__((__may_alias__)); /* 16 bits */
38 typedef unsigned long int uint32 __attribute__((__may_alias__)); /* 32 bits */
39
40 typedef signed char int8; /* 8 bits */
41 typedef signed short int int16 __attribute__((__may_alias__)); /* 16 bits */
42 typedef signed long int int32 __attribute__((__may_alias__)); /* 32 bits */
43
44 typedef volatile uint8 vuint8 __attribute__((__may_alias__)); /* 8 bits */
45 typedef volatile uint16 vuint16 __attribute__((__may_alias__)); /* 16 bits */
46 typedef volatile uint32 vuint32 __attribute__((__may_alias__)); /* 32 bits */
47
48 /***********************************************************************/
49 /*
50  * Common M68K & ColdFire definitions
51  */
52
53 #define ADDRESS uint32
54 #define INSTRUCTION uint16
55 #define ILLEGAL 0x4AFC
56 #define CPU_WORD_SIZE 16
57
58 #define MCF5XXX_SR_T (0x8000)
59 #define MCF5XXX_SR_S (0x2000)
60 #define MCF5XXX_SR_M (0x1000)
61 #define MCF5XXX_SR_IPL (0x0700)
62 #define MCF5XXX_SR_IPL_0 (0x0000)
63 #define MCF5XXX_SR_IPL_1 (0x0100)
64 #define MCF5XXX_SR_IPL_2 (0x0200)
65 #define MCF5XXX_SR_IPL_3 (0x0300)
66 #define MCF5XXX_SR_IPL_4 (0x0400)
67 #define MCF5XXX_SR_IPL_5 (0x0500)
68 #define MCF5XXX_SR_IPL_6 (0x0600)
69 #define MCF5XXX_SR_IPL_7 (0x0700)
70 #define MCF5XXX_SR_X (0x0010)
71 #define MCF5XXX_SR_N (0x0008)
72 #define MCF5XXX_SR_Z (0x0004)
73 #define MCF5XXX_SR_V (0x0002)
74 #define MCF5XXX_SR_C (0x0001)
75
76 /*
77  * Used to set the initialize the cacr register to the BSP's desired
78  * starting value.
79  */
80 void mcf5xxx_initialize_cacr(uint32_t);
81
82 #define MCF5XXX_CACR_CENB (0x80000000)
83 #define MCF5XXX_CACR_CPDI (0x10000000)
84 #define MCF5XXX_CACR_CPD (0x10000000)
85 #define MCF5XXX_CACR_CFRZ (0x08000000)
86 #define MCF5XXX_CACR_CINV (0x01000000)
87 #define MCF5XXX_CACR_DIDI (0x00800000)
88 #define MCF5XXX_CACR_DISD (0x00400000)
89 #define MCF5XXX_CACR_INVI (0x00200000)
90 #define MCF5XXX_CACR_INVD (0x00100000)
91 #define MCF5XXX_CACR_CEIB (0x00000400)
92 #define MCF5XXX_CACR_DCM_WR (0x00000000)
93 #define MCF5XXX_CACR_DCM_CB (0x00000100)
94 #define MCF5XXX_CACR_DCM_IP (0x00000200)
95 #define MCF5XXX_CACR_DCM (0x00000200)
96 #define MCF5XXX_CACR_DCM_II (0x00000300)
97 #define MCF5XXX_CACR_DBWE (0x00000100)
98 #define MCF5XXX_CACR_DWP (0x00000020)
99 #define MCF5XXX_CACR_EUST (0x00000010)
100 #define MCF5XXX_CACR_CLNF_00 (0x00000000)
101 #define MCF5XXX_CACR_CLNF_01 (0x00000002)
102 #define MCF5XXX_CACR_CLNF_10 (0x00000004)
103 #define MCF5XXX_CACR_CLNF_11 (0x00000006)
104
105 #define MCF5XXX_ACR_AB(a) ((a)&0xFF000000)
106 #define MCF5XXX_ACR_AM(a) (((a)&0xFF000000) >> 8)
107 #define MCF5XXX_ACR_EN (0x00008000)
108 #define MCF5XXX_ACR_SM_USER (0x00000000)
109 #define MCF5XXX_ACR_SM_SUPER (0x00002000)
110 #define MCF5XXX_ACR_SM_IGNORE (0x00006000)
111 #define MCF5XXX_ACR_ENIB (0x00000080)
112 #define MCF5XXX_ACR_CM (0x00000040)
113 #define MCF5XXX_ACR_DCM_WR (0x00000000)
114 #define MCF5XXX_ACR_DCM_CB (0x00000020)
115 #define MCF5XXX_ACR_DCM_IP (0x00000040)
116 #define MCF5XXX_ACR_DCM_II (0x00000060)
117 #define MCF5XXX_ACR_CM (0x00000040)
118 #define MCF5XXX_ACR_BWE (0x00000020)
119 #define MCF5XXX_ACR_WP (0x00000004)
120
121 #define MCF5XXX_RAMBAR_BA(a) ((a)&0xFFFFC000)
122 #define MCF5XXX_RAMBAR_PRI_00 (0x00000000)
123 #define MCF5XXX_RAMBAR_PRI_01 (0x00004000)
124 #define MCF5XXX_RAMBAR_PRI_10 (0x00008000)
125 #define MCF5XXX_RAMBAR_PRI_11 (0x0000C000)
126 #define MCF5XXX_RAMBAR_WP (0x00000100)
127 #define MCF5XXX_RAMBAR_CI (0x00000020)
128 #define MCF5XXX_RAMBAR_SC (0x00000010)
129 #define MCF5XXX_RAMBAR_SD (0x00000008)
130 #define MCF5XXX_RAMBAR_UC (0x00000004)
131 #define MCF5XXX_RAMBAR_UD (0x00000002)
132 #define MCF5XXX_RAMBAR_V (0x00000001)
133
134 /***********************************************************************/
135 /*
136  * The ColdFire family of processors has a simplified exception stack
137  * frame that looks like the following:
138  *
139  * 3322222222221111 111111
140  * 1098765432109876 5432109876543210
141  * 8 +----------------+----------------+
142  * | Program Counter |
143  * 4 +----------------+----------------+
144  * |FS/Fmt/Vector/FS| SR |
145  * SP --> 0 +----------------+----------------+
146  *
147  * The stack self-aligns to a 4-byte boundary at an exception, with
148  * the FS/Fmt/Vector/FS field indicating the size of the adjustment
149  * (SP += 0,1,2,3 bytes).
150  */
151
152 #define MCF5XXX_RD_SF_FORMAT(PTR) \
153  ((*((uint16 *)(PTR)) >> 12) & 0x00FF)
154
155 #define MCF5XXX_RD_SF_VECTOR(PTR) \
156  ((*((uint16 *)(PTR)) >> 2) & 0x00FF)
157
158 #define MCF5XXX_RD_SF_FS(PTR) \
159  ( ((*((uint16 *)(PTR)) & 0x0C00) >> 8) | (*((uint16 *)(PTR)) & 0x0003) )
160
161 #define MCF5XXX_SF_SR(PTR) *((uint16 *)(PTR)+1)
162 #define MCF5XXX_SF_PC(PTR) *((uint32 *)(PTR)+1)
163
164 /********************************************************************/
165 /*
166  * Functions provided by mcf5xxx.s
167  */
168
169 int asm_set_ipl (uint32);
170 void mcf5xxx_wr_cacr (uint32);
171 void mcf5xxx_wr_acr0 (uint32);
172 void mcf5xxx_wr_acr1 (uint32);
173 void mcf5xxx_wr_acr2 (uint32);
174 void mcf5xxx_wr_acr3 (uint32);
175 void mcf5xxx_wr_other_a7 (uint32);
176 void mcf5xxx_wr_other_sp (uint32);
177 void mcf5xxx_wr_vbr (uint32);
178 void mcf5xxx_wr_macsr (uint32);
179 void mcf5xxx_wr_mask (uint32);
180 void mcf5xxx_wr_acc0 (uint32);
181 void mcf5xxx_wr_accext01 (uint32);
182 void mcf5xxx_wr_accext23 (uint32);
183 void mcf5xxx_wr_acc1 (uint32);
184 void mcf5xxx_wr_acc2 (uint32);
185 void mcf5xxx_wr_acc3 (uint32);
186 void mcf5xxx_wr_sr (uint32);
187 void mcf5xxx_wr_rambar0 (uint32);
188 void mcf5xxx_wr_rambar1 (uint32);
189 void mcf5xxx_wr_mbar (uint32);
190 void mcf5xxx_wr_mbar0 (uint32);
191 void mcf5xxx_wr_mbar1 (uint32);
192
193 /********************************************************************/
194
195 #endif /* _CPU_MCF5XXX_H */
196
197
198 /********************************************************************/
199 /*
200  * Memory map definitions from linker command files
201  */
202 extern uint8 __IPSBAR[];
203
204 /*********************************************************************
205 *
206 * System Control Module (SCM)
207 *
208 *********************************************************************/
209
210 /* Read/Write access macros for general use */
211 #define MCF5282_SCM_IPSBAR (*(vuint32 *)(&__IPSBAR[0x0000]))
212 #define MCF5282_SCM_RAMBAR (*(vuint32 *)(&__IPSBAR[0x0008]))
213 #define MCF5282_SCM_CRSR (*(vuint8 *)(&__IPSBAR[0x0010]))
214 #define MCF5282_SCM_CWCR (*(vuint8 *)(&__IPSBAR[0x0011]))
215 #define MCF5282_SCM_LPICR (*(vuint8 *)(&__IPSBAR[0x0012]))
216 #define MCF5282_SCM_CWSR (*(vuint8 *)(&__IPSBAR[0x0013]))
217 #define MCF5282_SCM_DMAREQC (*(vuint32 *)(&__IPSBAR[0x0014]))
218 #define MCF5282_SCM_MPARK (*(vuint32 *)(&__IPSBAR[0x001C]))
219 #define MCF5282_SCM_MPR (*(vuint8 *)(&__IPSBAR[0x0020]))
220 #define MCF5282_SCM_PACR0 (*(vuint8 *)(&__IPSBAR[0x0024]))
221 #define MCF5282_SCM_PACR1 (*(vuint8 *)(&__IPSBAR[0x0025]))
222 #define MCF5282_SCM_PACR2 (*(vuint8 *)(&__IPSBAR[0x0026]))
223 #define MCF5282_SCM_PACR3 (*(vuint8 *)(&__IPSBAR[0x0027]))
224 #define MCF5282_SCM_PACR4 (*(vuint8 *)(&__IPSBAR[0x0028]))
225 #define MCF5282_SCM_PACR5 (*(vuint8 *)(&__IPSBAR[0x002A]))
226 #define MCF5282_SCM_PACR6 (*(vuint8 *)(&__IPSBAR[0x002B]))
227 #define MCF5282_SCM_PACR7 (*(vuint8 *)(&__IPSBAR[0x002C]))
228 #define MCF5282_SCM_PACR8 (*(vuint8 *)(&__IPSBAR[0x002E]))
229 #define MCF5282_SCM_GPACR0 (*(vuint8 *)(&__IPSBAR[0x0030]))
230 #define MCF5282_SCM_GPACR1 (*(vuint8 *)(&__IPSBAR[0x0031]))
231
232 /* Bit level definitions and macros */
233 #define MCF5282_SCM_IPSBAR_BA(x) ((x)&0xC0000000)
234 #define MCF5282_SCM_IPSBAR_V (0x00000001)
235
236 #define MCF5282_SCM_RAMBAR_BA(x) ((x)&0xFFFF0000)
237 #define MCF5282_SCM_RAMBAR_BDE (0x00000200)
238
239 #define MCF5282_SCM_CRSR_EXT (0x80)
240 #define MCF5282_SCM_CRSR_CWDR (0x20)
241
242 #define MCF5282_SCM_CWCR_CWE (0x80)
243 #define MCF5282_SCM_CWCR_CWRI (0x40)
244 #define MCF5282_SCM_CWCR_CWT(x) (((x)&0x03)<<3)
245 #define MCF5282_SCM_CWCR_CWTA (0x04)
246 #define MCF5282_SCM_CWCR_CWTAVAL (0x02)
247 #define MCF5282_SCM_CWCR_CWTIC (0x01)
248
249 #define MCF5282_SCM_LPICR_ENBSTOP (0x80)
250 #define MCF5282_SCM_LPICR_XSTOP_IPL(x) (((x)&0x07)<<4)
251
252 #define MCF5282_SCM_CWSR_SEQ1 (0x55)
253 #define MCF5282_SCM_CWSR_SEQ2 (0xAA)
254
255 #define MCF5282_SCM_DMAREQC_DMAC3(x) (((x)&0x000F)<<12)
256 #define MCF5282_SCM_DMAREQC_DMAC2(x) (((x)&0x000F)<<8)
257 #define MCF5282_SCM_DMAREQC_DMAC1(x) (((x)&0x000F)<<4)
258 #define MCF5282_SCM_DMAREQC_DMAC0(x) (((x)&0x000F))
259 #define MCF5282_SCM_DMAREQC_DMATIMER0 (0x4)
260 #define MCF5282_SCM_DMAREQC_DMATIMER1 (0x5)
261 #define MCF5282_SCM_DMAREQC_DMATIMER2 (0x6)
262 #define MCF5282_SCM_DMAREQC_DMATIMER3 (0x7)
263 #define MCF5282_SCM_DMAREQC_UART0 (0x8)
264 #define MCF5282_SCM_DMAREQC_UART1 (0x9)
265 #define MCF5282_SCM_DMAREQC_UART2 (0xA)
266
267 #define MCF5282_SCM_MPARK_M2_P_EN (0x02000000)
268 #define MCF5282_SCM_MPARK_BCR24BIT (0x01000000)
269 #define MCF5282_SCM_MPARK_M3_PRTY(x) (((x)&0x03)<<22)
270 #define MCF5282_SCM_MPARK_M2_PRTY(x) (((x)&0x03)<<20)
271 #define MCF5282_SCM_MPARK_M0_PRTY(x) (((x)&0x03)<<18)
272 #define MCF5282_SCM_MPARK_M1_PRTY(x) (((x)&0x03)<<16)
273 #define MCF5282_SCM_MPARK_FIXED (0x00040000)
274 #define MCF5282_SCM_MPARK_TIMEOUT (0x00020000)
275 #define MCF5282_SCM_MPARK_PRK_LAST (0x00010000)
276 #define MCF5282_SCM_MPARK_LCKOUT_TIME(x) (((x)&0x000F)<<8)
277
278 #define MCF5282_SCM_MPARK_MX_PRTY_FIRST (0x3)
279 #define MCF5282_SCM_MPARK_MX_PRTY_SECOND (0x2)
280 #define MCF5282_SCM_MPARK_MX_PRTY_THIRD (0x1)
281 #define MCF5282_SCM_MPARK_MX_PRTY_FOURTH (0x0)
282
283 #define MCF5282_SCM_MPR_MPR(x) (((x)&0x0F))
284
285 #define MCF5282_SCM_PACR_LOCK1 (0x80)
286 #define MCF5282_SCM_PACR_ACCESSCTRL1(x) (((x)&0x07)<<4)
287 #define MCF5282_SCM_PACR_LOCK0 (0x08)
288 #define MCF5282_SCM_PACR_ACCESSCTRL0(x) (((x)&0x07))
289 #define MCF5282_SCM_PACR_RW_NA (0x0)
290 #define MCF5282_SCM_PACR_R_NA (0x1)
291 #define MCF5282_SCM_PACR_R_R (0x2)
292 #define MCF5282_SCM_PACR_RW_RW (0x4)
293 #define MCF5282_SCM_PACR_RW_R (0x5)
294 #define MCF5282_SCM_PACR_NA_NA (0x7)
295
296 #define MCF5282_SCM_GPACR_LOCK (0x80)
297 #define MCF5282_SCM_GPACR_ACCESSCTRL(x) (((x)&0x0F))
298 #define MCF5282_SCM_GPACR_ACCESSCTRL_RW_NA (0x0)
299 #define MCF5282_SCM_GPACR_ACCESSCTRL_R_NA (0x1)
300 #define MCF5282_SCM_GPACR_ACCESSCTRL_R_R (0x2)
301 #define MCF5282_SCM_GPACR_ACCESSCTRL_RW_RW (0x4)
302 #define MCF5282_SCM_GPACR_ACCESSCTRL_RW_R (0x5)
303 #define MCF5282_SCM_GPACR_ACCESSCTRL_NA_NA (0x7)
304 #define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_NA (0x8)
305 #define MCF5282_SCM_GPACR_ACCESSCTRL_RE_NA (0x9)
306 #define MCF5282_SCM_GPACR_ACCESSCTRL_RE_RE (0xA)
307 #define MCF5282_SCM_GPACR_ACCESSCTRL_E_NA (0xB)
308 #define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_RWE (0xC)
309 #define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_RE (0xD)
310 #define MCF5282_SCM_GPACR_ACCESSCTRL_RWE_E (0xF)
311
312 /*********************************************************************
313 *
314 * SDRAM Controller Module
315 *
316 *********************************************************************/
317
318 /* Read/Write access macros for general use */
319 #define MCF5282_SDRAMC_DCR (*(vuint16 *)(&__IPSBAR[0x0040]))
320 #define MCF5282_SDRAMC_DACR0 (*(vuint32 *)(&__IPSBAR[0x0048]))
321 #define MCF5282_SDRAMC_DMR0 (*(vuint32 *)(&__IPSBAR[0x004C]))
322 #define MCF5282_SDRAMC_DACR1 (*(vuint32 *)(&__IPSBAR[0x0050]))
323 #define MCF5282_SDRAMC_DMR1 (*(vuint32 *)(&__IPSBAR[0x0054]))
324
325 /* Bit level definitions and macros */
326 #define MCF5282_SDRAMC_DCR_NAM (0x2000)
327 #define MCF5282_SDRAMC_DCR_COC (0x1000)
328 #define MCF5282_SDRAMC_DCR_IS (0x0800)
329 #define MCF5282_SDRAMC_DCR_RTIM_3 (0x0000)
330 #define MCF5282_SDRAMC_DCR_RTIM_6 (0x0200)
331 #define MCF5282_SDRAMC_DCR_RTIM_9 (0x0400)
332 #define MCF5282_SDRAMC_DCR_RC(x) ((x)&0x01FF)
333
334 #define MCF5282_SDRAMC_DACR_BASE(x) ((x)&0xFFFC0000)
335 #define MCF5282_SDRAMC_DACR_RE (0x00008000)
336 #define MCF5282_SDRAMC_DACR_CASL(x) (((x)&0x03)<<12)
337 #define MCF5282_SDRAMC_DACR_CBM(x) (((x)&0x07)<<8)
338 #define MCF5282_SDRAMC_DACR_PS_32 (0x00000000)
339 #define MCF5282_SDRAMC_DACR_PS_8 (0x00000010)
340 #define MCF5282_SDRAMC_DACR_PS_16 (0x00000020)
341 #define MCF5282_SDRAMC_DACR_IMRS (0x00000040)
342 #define MCF5282_SDRAMC_DACR_IP (0x00000008)
343
344 #define MCF5282_SDRAMC_DMR_BAM_4G (0xFFFC0000)
345 #define MCF5282_SDRAMC_DMR_BAM_2G (0x7FFC0000)
346 #define MCF5282_SDRAMC_DMR_BAM_1G (0x3FFC0000)
347 #define MCF5282_SDRAMC_DMR_BAM_1024M (0x3FFC0000)
348 #define MCF5282_SDRAMC_DMR_BAM_512M (0x1FFC0000)
349 #define MCF5282_SDRAMC_DMR_BAM_256M (0x0FFC0000)
350 #define MCF5282_SDRAMC_DMR_BAM_128M (0x07FC0000)
351 #define MCF5282_SDRAMC_DMR_BAM_64M (0x03FC0000)
352 #define MCF5282_SDRAMC_DMR_BAM_32M (0x01FC0000)
353 #define MCF5282_SDRAMC_DMR_BAM_16M (0x00FC0000)
354 #define MCF5282_SDRAMC_DMR_BAM_8M (0x007C0000)
355 #define MCF5282_SDRAMC_DMR_BAM_4M (0x003C0000)
356 #define MCF5282_SDRAMC_DMR_BAM_2M (0x001C0000)
357 #define MCF5282_SDRAMC_DMR_BAM_1M (0x000C0000)
358 #define MCF5282_SDRAMC_DMR_BAM_1024K (0x000C0000)
359 #define MCF5282_SDRAMC_DMR_BAM_512K (0x00040000)
360 #define MCF5282_SDRAMC_DMR_BAM_256K (0x00000000)
361 #define MCF5282_SDRAMC_DMR_WP (0x00000100)
362 #define MCF5282_SDRAMC_DMR_CI (0x00000040)
363 #define MCF5282_SDRAMC_DMR_AM (0x00000020)
364 #define MCF5282_SDRAMC_DMR_SC (0x00000010)
365 #define MCF5282_SDRAMC_DMR_SD (0x00000008)
366 #define MCF5282_SDRAMC_DMR_UC (0x00000004)
367 #define MCF5282_SDRAMC_DMR_UD (0x00000002)
368 #define MCF5282_SDRAMC_DMR_V (0x00000001)
369
370 /*********************************************************************
371 *
372 * Chip Select Module
373 *
374 *********************************************************************/
375
376 /* Read/Write access macros for general use */
377 #define MCF5282_CS0_CSAR (*(vuint16 *)(&__IPSBAR[0x0080]))
378 #define MCF5282_CS0_CSMR (*(vuint32 *)(&__IPSBAR[0x0084]))
379 #define MCF5282_CS0_CSCR (*(vuint16 *)(&__IPSBAR[0x008A]))
380
381 #define MCF5282_CS1_CSAR (*(vuint16 *)(&__IPSBAR[0x008C]))
382 #define MCF5282_CS1_CSMR (*(vuint32 *)(&__IPSBAR[0x0090]))
383 #define MCF5282_CS1_CSCR (*(vuint16 *)(&__IPSBAR[0x0096]))
384
385 #define MCF5282_CS2_CSAR (*(vuint16 *)(&__IPSBAR[0x0098]))
386 #define MCF5282_CS2_CSMR (*(vuint32 *)(&__IPSBAR[0x009C]))
387 #define MCF5282_CS2_CSCR (*(vuint16 *)(&__IPSBAR[0x00A2]))
388
389 #define MCF5282_CS3_CSAR (*(vuint16 *)(&__IPSBAR[0x00A4]))
390 #define MCF5282_CS3_CSMR (*(vuint32 *)(&__IPSBAR[0x00A8]))
391 #define MCF5282_CS3_CSCR (*(vuint16 *)(&__IPSBAR[0x00AE]))
392
393 #define MCF5282_CS4_CSAR (*(vuint16 *)(&__IPSBAR[0x00B0]))
394 #define MCF5282_CS4_CSMR (*(vuint32 *)(&__IPSBAR[0x00B4]))
395 #define MCF5282_CS4_CSCR (*(vuint16 *)(&__IPSBAR[0x00BA]))
396
397 #define MCF5282_CS5_CSAR (*(vuint16 *)(&__IPSBAR[0x00BC]))
398 #define MCF5282_CS5_CSMR (*(vuint32 *)(&__IPSBAR[0x00C0]))
399 #define MCF5282_CS5_CSCR (*(vuint16 *)(&__IPSBAR[0x00C6]))
400
401 #define MCF5282_CS6_CSAR (*(vuint16 *)(&__IPSBAR[0x00C8]))
402 #define MCF5282_CS6_CSMR (*(vuint32 *)(&__IPSBAR[0x00CC]))
403 #define MCF5282_CS6_CSCR (*(vuint16 *)(&__IPSBAR[0x00D2]))
404
405 #define MCF5282_CS_CSAR(x) (*(vuint16 *)(&__IPSBAR[0x0080+((x)*0x0C)]))
406 #define MCF5282_CS_CSMR(x) (*(vuint32 *)(&__IPSBAR[0x0084+((x)*0x0C)]))
407 #define MCF5282_CS_CSCR(x) (*(vuint16 *)(&__IPSBAR[0x008A+((x)*0x0C)]))
408
409 /* Bit level definitions and macros */
410 #define MCF5282_CS_CSAR_BA(a) (uint16)(((a)&0xFFFF0000)>>16)
411
412 #define MCF5282_CS_CSMR_BAM_4G (0xFFFF0000)
413 #define MCF5282_CS_CSMR_BAM_2G (0x7FFF0000)
414 #define MCF5282_CS_CSMR_BAM_1G (0x3FFF0000)
415 #define MCF5282_CS_CSMR_BAM_1024M (0x3FFF0000)
416 #define MCF5282_CS_CSMR_BAM_512M (0x1FFF0000)
417 #define MCF5282_CS_CSMR_BAM_256M (0x0FFF0000)
418 #define MCF5282_CS_CSMR_BAM_128M (0x07FF0000)
419 #define MCF5282_CS_CSMR_BAM_64M (0x03FF0000)
420 #define MCF5282_CS_CSMR_BAM_32M (0x01FF0000)
421 #define MCF5282_CS_CSMR_BAM_16M (0x00FF0000)
422 #define MCF5282_CS_CSMR_BAM_8M (0x007F0000)
423 #define MCF5282_CS_CSMR_BAM_4M (0x003F0000)
424 #define MCF5282_CS_CSMR_BAM_2M (0x001F0000)
425 #define MCF5282_CS_CSMR_BAM_1M (0x000F0000)
426 #define MCF5282_CS_CSMR_BAM_1024K (0x000F0000)
427 #define MCF5282_CS_CSMR_BAM_512K (0x00070000)
428 #define MCF5282_CS_CSMR_BAM_256K (0x00030000)
429 #define MCF5282_CS_CSMR_BAM_128K (0x00010000)
430 #define MCF5282_CS_CSMR_BAM_64K (0x00000000)
431 #define MCF5282_CS_CSMR_WP (0x00000100)
432 #define MCF5282_CS_CSMR_AM (0x00000040)
433 #define MCF5282_CS_CSMR_CI (0x00000020)
434 #define MCF5282_CS_CSMR_SC (0x00000010)
435 #define MCF5282_CS_CSMR_SD (0x00000008)
436 #define MCF5282_CS_CSMR_UC (0x00000004)
437 #define MCF5282_CS_CSMR_UD (0x00000002)
438 #define MCF5282_CS_CSMR_V (0x00000001)
439
440 #define MCF5282_CS_CSCR_WS(x) (((x)&0x0F)<<10)
441 #define MCF5282_CS_CSCR_AA (0x0100)
442 #define MCF5282_CS_CSCR_PS_8 (0x0040)
443 #define MCF5282_CS_CSCR_PS_16 (0x0080)
444 #define MCF5282_CS_CSCR_PS_32 (0x0000)
445 #define MCF5282_CS_CSCR_BEM (0x0020)
446 #define MCF5282_CS_CSCR_BSTR (0x0010)
447 #define MCF5282_CS_CSCR_BSTW (0x0008)
448
449 /*********************************************************************
450 *
451 * Direct Memory Access (DMA) Module
452 *
453 *********************************************************************/
454
455 /* Read/Write access macros for general use */
456 #define MCF5282_DMA0_SAR (*(vuint32 *)(&__IPSBAR[0x0100]))
457 #define MCF5282_DMA0_DAR (*(vuint32 *)(&__IPSBAR[0x0104]))
458 #define MCF5282_DMA0_DCR (*(vuint32 *)(&__IPSBAR[0x0108]))
459 #define MCF5282_DMA0_BCR (*(vuint32 *)(&__IPSBAR[0x010C]))
460 #define MCF5282_DMA0_DSR (*(vuint8 *)(&__IPSBAR[0x0110]))
461
462 #define MCF5282_DMA1_SAR (*(vuint32 *)(&__IPSBAR[0x0140]))
463 #define MCF5282_DMA1_DAR (*(vuint32 *)(&__IPSBAR[0x0144]))
464 #define MCF5282_DMA1_DCR (*(vuint32 *)(&__IPSBAR[0x0148]))
465 #define MCF5282_DMA1_BCR (*(vuint32 *)(&__IPSBAR[0x014C]))
466 #define MCF5282_DMA1_DSR (*(vuint8 *)(&__IPSBAR[0x0150]))
467
468 #define MCF5282_DMA2_SAR (*(vuint32 *)(&__IPSBAR[0x0180]))
469 #define MCF5282_DMA2_DAR (*(vuint32 *)(&__IPSBAR[0x0184]))
470 #define MCF5282_DMA2_DCR (*(vuint32 *)(&__IPSBAR[0x0188]))
471 #define MCF5282_DMA2_BCR (*(vuint32 *)(&__IPSBAR[0x018C]))
472 #define MCF5282_DMA2_DSR (*(vuint8 *)(&__IPSBAR[0x0190]))
473
474 #define MCF5282_DMA3_SAR (*(vuint32 *)(&__IPSBAR[0x01C0]))
475 #define MCF5282_DMA3_DAR (*(vuint32 *)(&__IPSBAR[0x01C4]))
476 #define MCF5282_DMA3_DCR (*(vuint32 *)(&__IPSBAR[0x01C8]))
477 #define MCF5282_DMA3_BCR (*(vuint32 *)(&__IPSBAR[0x01CC]))
478 #define MCF5282_DMA3_DSR (*(vuint8 *)(&__IPSBAR[0x01D0]))
479
480 #define MCF5282_DMA_SAR(x) (*(vuint32 *)(&__IPSBAR[0x0100+((x)*0x40)]))
481 #define MCF5282_DMA_DAR(x) (*(vuint32 *)(&__IPSBAR[0x0104+((x)*0x40)]))
482 #define MCF5282_DMA_DCR(x) (*(vuint32 *)(&__IPSBAR[0x0108+((x)*0x40)]))
483 #define MCF5282_DMA_BCR(x) (*(vuint32 *)(&__IPSBAR[0x010C+((x)*0x40)]))
484 #define MCF5282_DMA_DSR(x) (*(vuint8 *)(&__IPSBAR[0x0110+((x)*0x40)]))
485
486 /* Bit level definitions and macros */
487 #define MCF5282_DMA_DCR_INT (0x80000000)
488 #define MCF5282_DMA_DCR_EEXT (0x40000000)
489 #define MCF5282_DMA_DCR_CS (0x20000000)
490 #define MCF5282_DMA_DCR_AA (0x10000000)
491 #define MCF5282_DMA_DCR_BWC_DMA (0x00000000)
492 #define MCF5282_DMA_DCR_BWC_512 (0x02000000)
493 #define MCF5282_DMA_DCR_BWC_1024 (0x04000000)
494 #define MCF5282_DMA_DCR_BWC_2048 (0x06000000)
495 #define MCF5282_DMA_DCR_BWC_4096 (0x08000000)
496 #define MCF5282_DMA_DCR_BWC_8192 (0x0A000000)
497 #define MCF5282_DMA_DCR_BWC_16384 (0x0C000000)
498 #define MCF5282_DMA_DCR_BWC_32768 (0x0E000000)
499 #define MCF5282_DMA_DCR_SINC (0x00400000)
500 #define MCF5282_DMA_DCR_SSIZE_LONG (0x00000000)
501 #define MCF5282_DMA_DCR_SSIZE_BYTE (0x00100000)
502 #define MCF5282_DMA_DCR_SSIZE_WORD (0x00200000)
503 #define MCF5282_DMA_DCR_SSIZE_LINE (0x00300000)
504 #define MCF5282_DMA_DCR_DINC (0x00080000)
505 #define MCF5282_DMA_DCR_DSIZE_LONG (0x00000000)
506 #define MCF5282_DMA_DCR_DSIZE_BYTE (0x00020000)
507 #define MCF5282_DMA_DCR_DSIZE_WORD (0x00040000)
508 #define MCF5282_DMA_DCR_START (0x00010000)
509 #define MCF5282_DMA_DCR_AT (0x00008000)
510
511 #define MCF5282_DMA_DSR_CE (0x40)
512 #define MCF5282_DMA_DSR_BES (0x20)
513 #define MCF5282_DMA_DSR_BED (0x10)
514 #define MCF5282_DMA_DSR_REQ (0x04)
515 #define MCF5282_DMA_DSR_BSY (0x02)
516 #define MCF5282_DMA_DSR_DONE (0x01)
517
518 /*********************************************************************
519 *
520 * Universal Asychronous Receiver/Transmitter (UART) Module
521 *
522 *********************************************************************/
523
524 /* Read/Write access macros for general use */
525 #define MCF5282_UART0_UMR (*(vuint8 *)(&__IPSBAR[0x0200]))
526 #define MCF5282_UART0_USR (*(vuint8 *)(&__IPSBAR[0x0204]))
527 #define MCF5282_UART0_UCSR (*(vuint8 *)(&__IPSBAR[0x0204]))
528 #define MCF5282_UART0_UCR (*(vuint8 *)(&__IPSBAR[0x0208]))
529 #define MCF5282_UART0_URB (*(vuint8 *)(&__IPSBAR[0x020C]))
530 #define MCF5282_UART0_UTB (*(vuint8 *)(&__IPSBAR[0x020C]))
531 #define MCF5282_UART0_UIPCR (*(vuint8 *)(&__IPSBAR[0x0210]))
532 #define MCF5282_UART0_UACR (*(vuint8 *)(&__IPSBAR[0x0210]))
533 #define MCF5282_UART0_UISR (*(vuint8 *)(&__IPSBAR[0x0214]))
534 #define MCF5282_UART0_UIMR (*(vuint8 *)(&__IPSBAR[0x0214]))
535 #define MCF5282_UART0_UBG1 (*(vuint8 *)(&__IPSBAR[0x0218]))
536 #define MCF5282_UART0_UBG2 (*(vuint8 *)(&__IPSBAR[0x021C]))
537 #define MCF5282_UART0_UIP (*(vuint8 *)(&__IPSBAR[0x0234]))
538 #define MCF5282_UART0_UOP1 (*(vuint8 *)(&__IPSBAR[0x0238]))
539 #define MCF5282_UART0_UOP0 (*(vuint8 *)(&__IPSBAR[0x023C]))
540
541 #define MCF5282_UART1_UMR (*(vuint8 *)(&__IPSBAR[0x0240]))
542 #define MCF5282_UART1_USR (*(vuint8 *)(&__IPSBAR[0x0244]))
543 #define MCF5282_UART1_UCSR (*(vuint8 *)(&__IPSBAR[0x0244]))
544 #define MCF5282_UART1_UCR (*(vuint8 *)(&__IPSBAR[0x0248]))
545 #define MCF5282_UART1_URB (*(vuint8 *)(&__IPSBAR[0x024C]))
546 #define MCF5282_UART1_UTB (*(vuint8 *)(&__IPSBAR[0x024C]))
547 #define MCF5282_UART1_UIPCR (*(vuint8 *)(&__IPSBAR[0x0250]))
548 #define MCF5282_UART1_UACR (*(vuint8 *)(&__IPSBAR[0x0250]))
549 #define MCF5282_UART1_UISR (*(vuint8 *)(&__IPSBAR[0x0254]))
550 #define MCF5282_UART1_UIMR (*(vuint8 *)(&__IPSBAR[0x0254]))
551 #define MCF5282_UART1_UBG1 (*(vuint8 *)(&__IPSBAR[0x0258]))
552 #define MCF5282_UART1_UBG2 (*(vuint8 *)(&__IPSBAR[0x025C]))
553 #define MCF5282_UART1_UIP (*(vuint8 *)(&__IPSBAR[0x0274]))
554 #define MCF5282_UART1_UOP1 (*(vuint8 *)(&__IPSBAR[0x0278]))
555 #define MCF5282_UART1_UOP0 (*(vuint8 *)(&__IPSBAR[0x027C]))
556
557 #define MCF5282_UART2_UMR (*(vuint8 *)(&__IPSBAR[0x0280]))
558 #define MCF5282_UART2_USR (*(vuint8 *)(&__IPSBAR[0x0284]))
559 #define MCF5282_UART2_UCSR (*(vuint8 *)(&__IPSBAR[0x0284]))
560 #define MCF5282_UART2_UCR (*(vuint8 *)(&__IPSBAR[0x0288]))
561 #define MCF5282_UART2_URB (*(vuint8 *)(&__IPSBAR[0x028C]))
562 #define MCF5282_UART2_UTB (*(vuint8 *)(&__IPSBAR[0x028C]))
563 #define MCF5282_UART2_UIPCR (*(vuint8 *)(&__IPSBAR[0x0290]))
564 #define MCF5282_UART2_UACR (*(vuint8 *)(&__IPSBAR[0x0290]))
565 #define MCF5282_UART2_UISR (*(vuint8 *)(&__IPSBAR[0x0294]))
566 #define MCF5282_UART2_UIMR (*(vuint8 *)(&__IPSBAR[0x0294]))
567 #define MCF5282_UART2_UBG1 (*(vuint8 *)(&__IPSBAR[0x0298]))
568 #define MCF5282_UART2_UBG2 (*(vuint8 *)(&__IPSBAR[0x029C]))
569 #define MCF5282_UART2_UIP (*(vuint8 *)(&__IPSBAR[0x02B4]))
570 #define MCF5282_UART2_UOP1 (*(vuint8 *)(&__IPSBAR[0x02B8]))
571 #define MCF5282_UART2_UOP0 (*(vuint8 *)(&__IPSBAR[0x02BC]))
572
573 #define MCF5282_UART_UMR(x) (*(vuint8 *)(&__IPSBAR[0x0200+((x)*0x40)]))
574 #define MCF5282_UART_USR(x) (*(vuint8 *)(&__IPSBAR[0x0204+((x)*0x40)]))
575 #define MCF5282_UART_UCSR(x) (*(vuint8 *)(&__IPSBAR[0x0204+((x)*0x40)]))
576 #define MCF5282_UART_UCR(x) (*(vuint8 *)(&__IPSBAR[0x0208+((x)*0x40)]))
577 #define MCF5282_UART_URB(x) (*(vuint8 *)(&__IPSBAR[0x020C+((x)*0x40)]))
578 #define MCF5282_UART_UTB(x) (*(vuint8 *)(&__IPSBAR[0x020C+((x)*0x40)]))
579 #define MCF5282_UART_UIPCR(x) (*(vuint8 *)(&__IPSBAR[0x0210+((x)*0x40)]))
580 #define MCF5282_UART_UACR(x) (*(vuint8 *)(&__IPSBAR[0x0210+((x)*0x40)]))
581 #define MCF5282_UART_UISR(x) (*(vuint8 *)(&__IPSBAR[0x0214+((x)*0x40)]))
582 #define MCF5282_UART_UIMR(x) (*(vuint8 *)(&__IPSBAR[0x0214+((x)*0x40)]))
583 #define MCF5282_UART_UBG1(x) (*(vuint8 *)(&__IPSBAR[0x0218+((x)*0x40)]))
584 #define MCF5282_UART_UBG2(x) (*(vuint8 *)(&__IPSBAR[0x021C+((x)*0x40)]))
585 #define MCF5282_UART_UIP(x) (*(vuint8 *)(&__IPSBAR[0x0234+((x)*0x40)]))
586 #define MCF5282_UART_UOP1(x) (*(vuint8 *)(&__IPSBAR[0x0238+((x)*0x40)]))
587 #define MCF5282_UART_UOP0(x) (*(vuint8 *)(&__IPSBAR[0x023C+((x)*0x40)]))
588
589 /* Bit level definitions and macros */
590 #define MCF5282_UART_UMR1_RXRTS (0x80)
591 #define MCF5282_UART_UMR1_RXIRQ (0x40)
592 #define MCF5282_UART_UMR1_ERR (0x20)
593 #define MCF5282_UART_UMR1_PM_MULTI_ADDR (0x1C)
594 #define MCF5282_UART_UMR1_PM_MULTI_DATA (0x18)
595 #define MCF5282_UART_UMR1_PM_NONE (0x10)
596 #define MCF5282_UART_UMR1_PM_FORCE_HI (0x0C)
597 #define MCF5282_UART_UMR1_PM_FORCE_LO (0x08)
598 #define MCF5282_UART_UMR1_PM_ODD (0x04)
599 #define MCF5282_UART_UMR1_PM_EVEN (0x00)
600 #define MCF5282_UART_UMR1_BC_5 (0x00)
601 #define MCF5282_UART_UMR1_BC_6 (0x01)
602 #define MCF5282_UART_UMR1_BC_7 (0x02)
603 #define MCF5282_UART_UMR1_BC_8 (0x03)
604
605 #define MCF5282_UART_UMR2_CM_NORMAL (0x00)
606 #define MCF5282_UART_UMR2_CM_ECHO (0x40)
607 #define MCF5282_UART_UMR2_CM_LOCAL_LOOP (0x80)
608 #define MCF5282_UART_UMR2_CM_REMOTE_LOOP (0xC0)
609 #define MCF5282_UART_UMR2_TXRTS (0x20)
610 #define MCF5282_UART_UMR2_TXCTS (0x10)
611 #define MCF5282_UART_UMR2_STOP_BITS_1 (0x07)
612 #define MCF5282_UART_UMR2_STOP_BITS_15 (0x08)
613 #define MCF5282_UART_UMR2_STOP_BITS_2 (0x0F)
614 #define MCF5282_UART_UMR2_STOP_BITS(a) ((a)&0x0f)
615
616 #define MCF5282_UART_USR_RB (0x80)
617 #define MCF5282_UART_USR_FE (0x40)
618 #define MCF5282_UART_USR_PE (0x20)
619 #define MCF5282_UART_USR_OE (0x10)
620 #define MCF5282_UART_USR_TXEMP (0x08)
621 #define MCF5282_UART_USR_TXRDY (0x04)
622 #define MCF5282_UART_USR_FFULL (0x02)
623 #define MCF5282_UART_USR_RXRDY (0x01)
624
625 #define MCF5282_UART_UCSR_RCS_SYS_CLK (0xD0)
626 #define MCF5282_UART_UCSR_RCS_DTIN16 (0xE0)
627 #define MCF5282_UART_UCSR_RCS_DTIN (0xF0)
628 #define MCF5282_UART_UCSR_TCS_SYS_CLK (0x0D)
629 #define MCF5282_UART_UCSR_TCS_DTIN16 (0x0E)
630 #define MCF5282_UART_UCSR_TCS_DTIN (0x0F)
631
632 #define MCF5282_UART_UCR_NONE (0x00)
633 #define MCF5282_UART_UCR_STOP_BREAK (0x70)
634 #define MCF5282_UART_UCR_START_BREAK (0x60)
635 #define MCF5282_UART_UCR_RESET_BKCHGINT (0x50)
636 #define MCF5282_UART_UCR_RESET_ERROR (0x40)
637 #define MCF5282_UART_UCR_RESET_TX (0x30)
638 #define MCF5282_UART_UCR_RESET_RX (0x20)
639 #define MCF5282_UART_UCR_RESET_MR (0x10)
640 #define MCF5282_UART_UCR_TX_DISABLED (0x08)
641 #define MCF5282_UART_UCR_TX_ENABLED (0x04)
642 #define MCF5282_UART_UCR_RX_DISABLED (0x02)
643 #define MCF5282_UART_UCR_RX_ENABLED (0x01)
644
645 #define MCF5282_UART_UIPCR_COS (0x10)
646 #define MCF5282_UART_UIPCR_CTS (0x01)
647
648 #define MCF5282_UART_UACR_IEC (0x01)
649
650 #define MCF5282_UART_UISR_COS (0x80)
651 #define MCF5282_UART_UISR_ABC (0x40)
652 #define MCF5282_UART_UISR_RXFIFO (0x20)
653 #define MCF5282_UART_UISR_TXFIFO (0x10)
654 #define MCF5282_UART_UISR_RXFTO (0x08)
655 #define MCF5282_UART_UISR_DB (0x04)
656 #define MCF5282_UART_UISR_RXRDY (0x02)
657 #define MCF5282_UART_UISR_TXRDY (0x01)
658
659 #define MCF5282_UART_UIMR_COS (0x80)
660 #define MCF5282_UART_UIMR_DB (0x04)
661 #define MCF5282_UART_UIMR_FFULL (0x02)
662 #define MCF5282_UART_UIMR_TXRDY (0x01)
663
664 #define MCF5282_UART_UIP_CTS (0x01)
665
666 #define MCF5282_UART_UOP_RTS (0x01)
667
668 /*********************************************************************
669 *
670 * Inter-IC (I2C) Module
671 *
672 *********************************************************************/
673
674 /* Read/Write access macros for general use */
675 #define MCF5282_I2C_I2ADR (*(vuint8 *)(&__IPSBAR[0x0300]))
676 #define MCF5282_I2C_I2FDR (*(vuint8 *)(&__IPSBAR[0x0304]))
677 #define MCF5282_I2C_I2CR (*(vuint8 *)(&__IPSBAR[0x0308]))
678 #define MCF5282_I2C_I2SR (*(vuint8 *)(&__IPSBAR[0x030C]))
679 #define MCF5282_I2C_I2DR (*(vuint8 *)(&__IPSBAR[0x0310]))
680
681 /* Bit level definitions and macros */
682 #define MCF5282_I2C_I2ADR_ADDR(x) (((x)&0x7F)<<0x01)
683
684 #define MCF5282_I2C_I2FDR_IC(x) (((x)&0x3F))
685
686 #define MCF5282_I2C_I2CR_IEN (0x80)
687 #define MCF5282_I2C_I2CR_IIEN (0x40)
688 #define MCF5282_I2C_I2CR_MSTA (0x20)
689 #define MCF5282_I2C_I2CR_MTX (0x10)
690 #define MCF5282_I2C_I2CR_TXAK (0x08)
691 #define MCF5282_I2C_I2CR_RSTA (0x04)
692
693 #define MCF5282_I2C_I2SR_ICF (0x80)
694 #define MCF5282_I2C_I2SR_IAAS (0x40)
695 #define MCF5282_I2C_I2SR_IBB (0x20)
696 #define MCF5282_I2C_I2SR_IAL (0x10)
697 #define MCF5282_I2C_I2SR_SRW (0x04)
698 #define MCF5282_I2C_I2SR_IIF (0x02)
699 #define MCF5282_I2C_I2SR_RXAK (0x01)
700
701 /*********************************************************************
702 *
703 * Queued Serial Peripheral Interface (QSPI) Module
704 *
705 *********************************************************************/
706
707 /* Read/Write access macros for general use */
708 #define MCF5282_QSPI_QMR (*(vuint16 *)(&__IPSBAR[0x0340]))
709 #define MCF5282_QSPI_QDLYR (*(vuint16 *)(&__IPSBAR[0x0344]))
710 #define MCF5282_QSPI_QWR (*(vuint16 *)(&__IPSBAR[0x0348]))
711 #define MCF5282_QSPI_QIR (*(vuint16 *)(&__IPSBAR[0x034C]))
712 #define MCF5282_QSPI_QAR (*(vuint16 *)(&__IPSBAR[0x0350]))
713 #define MCF5282_QSPI_QDR (*(vuint16 *)(&__IPSBAR[0x0354]))
714 #define MCF5282_QSPI_QCR (*(vuint16 *)(&__IPSBAR[0x0354]))
715
716 /* Bit level definitions and macros */
717 #define MCF5282_QSPI_QMR_MSTR (0x8000)
718 #define MCF5282_QSPI_QMR_DOHIE (0x4000)
719 #define MCF5282_QSPI_QMR_BITS_16 (0x0000)
720 #define MCF5282_QSPI_QMR_BITS_8 (0x2000)
721 #define MCF5282_QSPI_QMR_BITS_9 (0x2400)
722 #define MCF5282_QSPI_QMR_BITS_10 (0x2800)
723 #define MCF5282_QSPI_QMR_BITS_11 (0x2C00)
724 #define MCF5282_QSPI_QMR_BITS_12 (0x3000)
725 #define MCF5282_QSPI_QMR_BITS_13 (0x3400)
726 #define MCF5282_QSPI_QMR_BITS_14 (0x3800)
727 #define MCF5282_QSPI_QMR_BITS_15 (0x3C00)
728 #define MCF5282_QSPI_QMR_CPOL (0x0200)
729 #define MCF5282_QSPI_QMR_CPHA (0x0100)
730 #define MCF5282_QSPI_QMR_BAUD(x) (((x)&0x00FF))
731
732 #define MCF5282_QSPI_QDLYR_SPE (0x8000)
733 #define MCF5282_QSPI_QDLYR_QCD(x) (((x)&0x007F)<<8)
734 #define MCF5282_QSPI_QDLYR_DTL(x) (((x)&0x00FF))
735
736 #define MCF5282_QSPI_QWR_HALT (0x8000)
737 #define MCF5282_QSPI_QWR_WREN (0x4000)
738 #define MCF5282_QSPI_QWR_WRTO (0x2000)
739 #define MCF5282_QSPI_QWR_CSIV (0x1000)
740 #define MCF5282_QSPI_QWR_ENDQP(x) (((x)&0x000F)<<8)
741 #define MCF5282_QSPI_QWR_CPTQP(x) (((x)&0x000F)<<4)
742 #define MCF5282_QSPI_QWR_NEWQP(x) (((x)&0x000F))
743
744 #define MCF5282_QSPI_QIR_WCEFB (0x8000)
745 #define MCF5282_QSPI_QIR_ABRTB (0x4000)
746 #define MCF5282_QSPI_QIR_ABRTL (0x1000)
747 #define MCF5282_QSPI_QIR_WCEFE (0x0800)
748 #define MCF5282_QSPI_QIR_ABRTE (0x0400)
749 #define MCF5282_QSPI_QIR_SPIFE (0x0100)
750 #define MCF5282_QSPI_QIR_WCEF (0x0008)
751 #define MCF5282_QSPI_QIR_ABRT (0x0004)
752 #define MCF5282_QSPI_QIR_SPIF (0x0001)
753
754 #define MCF5282_QSPI_QAR_ADDR(x) (((x)&0x003F))
755
756 #define MCF5282_QSPI_QDR_COMMAND(x) (((x)&0xFF00))
757
758 #define MCF5282_QSPI_QCR_DATA(x) (((x)&0x00FF)<<8)
759 #define MCF5282_QSPI_QCR_CONT (0x8000)
760 #define MCF5282_QSPI_QCR_BITSE (0x4000)
761 #define MCF5282_QSPI_QCR_DT (0x2000)
762 #define MCF5282_QSPI_QCR_DSCK (0x1000)
763 #define MCF5282_QSPI_QCR_CS(x) (((x)&0x000F)<<8)
764
765 /*********************************************************************
766 *
767 * DMA Timer Module
768 *
769 *********************************************************************/
770
771 /* Read/Write access macros for general use */
772 #define MCF5282_TIMER0_DTMR (*(vuint16 *)(&__IPSBAR[0x0400]))
773 #define MCF5282_TIMER0_DTXMR (*(vuint8 *)(&__IPSBAR[0x0402]))
774 #define MCF5282_TIMER0_DTER (*(vuint8 *)(&__IPSBAR[0x0403]))
775 #define MCF5282_TIMER0_DTRR (*(vuint32 *)(&__IPSBAR[0x0404]))
776 #define MCF5282_TIMER0_DTCR (*(vuint32 *)(&__IPSBAR[0x0408]))
777 #define MCF5282_TIMER0_DTCN (*(vuint32 *)(&__IPSBAR[0x040C]))
778
779 #define MCF5282_TIMER1_DTMR (*(vuint16 *)(&__IPSBAR[0x0440]))
780 #define MCF5282_TIMER1_DTXMR (*(vuint8 *)(&__IPSBAR[0x0442]))
781 #define MCF5282_TIMER1_DTER (*(vuint8 *)(&__IPSBAR[0x0443]))
782 #define MCF5282_TIMER1_DTRR (*(vuint32 *)(&__IPSBAR[0x0444]))
783 #define MCF5282_TIMER1_DTCR (*(vuint32 *)(&__IPSBAR[0x0448]))
784 #define MCF5282_TIMER1_DTCN (*(vuint32 *)(&__IPSBAR[0x044C]))
785
786 #define MCF5282_TIMER2_DTMR (*(vuint16 *)(&__IPSBAR[0x0480]))
787 #define MCF5282_TIMER2_DTXMR (*(vuint8 *)(&__IPSBAR[0x0482]))
788 #define MCF5282_TIMER2_DTER (*(vuint8 *)(&__IPSBAR[0x0483]))
789 #define MCF5282_TIMER2_DTRR (*(vuint32 *)(&__IPSBAR[0x0484]))
790 #define MCF5282_TIMER2_DTCR (*(vuint32 *)(&__IPSBAR[0x0488]))
791 #define MCF5282_TIMER2_DTCN (*(vuint32 *)(&__IPSBAR[0x048C]))
792
793 #define MCF5282_TIMER3_DTMR (*(vuint16 *)(&__IPSBAR[0x04C0]))
794 #define MCF5282_TIMER3_DTXMR (*(vuint8 *)(&__IPSBAR[0x04C2]))
795 #define MCF5282_TIMER3_DTER (*(vuint8 *)(&__IPSBAR[0x04C3]))
796 #define MCF5282_TIMER3_DTRR (*(vuint32 *)(&__IPSBAR[0x04C4]))
797 #define MCF5282_TIMER3_DTCR (*(vuint32 *)(&__IPSBAR[0x04C8]))
798 #define MCF5282_TIMER3_DTCN (*(vuint32 *)(&__IPSBAR[0x04CC]))
799
800 #define MCF5282_TIMER_DTMR(x) (*(vuint16 *)(&__IPSBAR[0x0400+((x)*0x40)]))
801 #define MCF5282_TIMER_DTXMR(x) (*(vuint8 *)(&__IPSBAR[0x0402+((x)*0x40)]))
802 #define MCF5282_TIMER_DTER(x) (*(vuint8 *)(&__IPSBAR[0x0403+((x)*0x40)]))
803 #define MCF5282_TIMER_DTRR(x) (*(vuint32 *)(&__IPSBAR[0x0404+((x)*0x40)]))
804 #define MCF5282_TIMER_DTCR(x) (*(vuint32 *)(&__IPSBAR[0x0408+((x)*0x40)]))
805 #define MCF5282_TIMER_DTCN(x) (*(vuint32 *)(&__IPSBAR[0x040C+((x)*0x40)]))
806
807 /* Bit level definitions and macros */
808 #define MCF5282_TIMER_DTMR_PS(a) (((a)&0x00FF)<<8)
809 #define MCF5282_TIMER_DTMR_CE_ANY (0x00C0)
810 #define MCF5282_TIMER_DTMR_CE_FALL (0x0080)
811 #define MCF5282_TIMER_DTMR_CE_RISE (0x0040)
812 #define MCF5282_TIMER_DTMR_CE_NONE (0x0000)
813 #define MCF5282_TIMER_DTMR_OM (0x0020)
814 #define MCF5282_TIMER_DTMR_ORRI (0x0010)
815 #define MCF5282_TIMER_DTMR_FRR (0x0008)
816 #define MCF5282_TIMER_DTMR_CLK_DTIN (0x0006)
817 #define MCF5282_TIMER_DTMR_CLK_DIV16 (0x0004)
818 #define MCF5282_TIMER_DTMR_CLK_DIV1 (0x0002)
819 #define MCF5282_TIMER_DTMR_CLK_STOP (0x0000)
820 #define MCF5282_TIMER_DTMR_RST (0x0001)
821
822 #define MCF5282_TIMER_DTXMR_DMAEN (0x80)
823 #define MCF5282_TIMER_DTXMR_MODE16 (0x01)
824
825 #define MCF5282_TIMER_DTER_REF (0x02)
826 #define MCF5282_TIMER_DTER_CAP (0x01)
827
828 /*********************************************************************
829 *
830 * Interrupt Controller (INTC) Module
831 *
832 *********************************************************************/
833
834 /* Read/Write access macros for general use */
835 #define MCF5282_INTC0_IPRH (*(vuint32 *)(&__IPSBAR[0x0C00]))
836 #define MCF5282_INTC0_IPRL (*(vuint32 *)(&__IPSBAR[0x0C04]))
837 #define MCF5282_INTC0_IMRH (*(vuint32 *)(&__IPSBAR[0x0C08]))
838 #define MCF5282_INTC0_IMRL (*(vuint32 *)(&__IPSBAR[0x0C0C]))
839 #define MCF5282_INTC0_INTFRCH (*(vuint32 *)(&__IPSBAR[0x0C10]))
840 #define MCF5282_INTC0_INTFRCL (*(vuint32 *)(&__IPSBAR[0x0C14]))
841 #define MCF5282_INTC0_IRLR (*(vuint8 *)(&__IPSBAR[0x0C18]))
842 #define MCF5282_INTC0_IACKLPR (*(vuint8 *)(&__IPSBAR[0x0C19]))
843 #define MCF5282_INTC0_ICR1 (*(vuint8 *)(&__IPSBAR[0x0C41]))
844 #define MCF5282_INTC0_ICR2 (*(vuint8 *)(&__IPSBAR[0x0C42]))
845 #define MCF5282_INTC0_ICR3 (*(vuint8 *)(&__IPSBAR[0x0C43]))
846 #define MCF5282_INTC0_ICR4 (*(vuint8 *)(&__IPSBAR[0x0C44]))
847 #define MCF5282_INTC0_ICR5 (*(vuint8 *)(&__IPSBAR[0x0C45]))
848 #define MCF5282_INTC0_ICR6 (*(vuint8 *)(&__IPSBAR[0x0C46]))
849 #define MCF5282_INTC0_ICR7 (*(vuint8 *)(&__IPSBAR[0x0C47]))
850 #define MCF5282_INTC0_ICR8 (*(vuint8 *)(&__IPSBAR[0x0C48]))
851 #define MCF5282_INTC0_ICR9 (*(vuint8 *)(&__IPSBAR[0x0C49]))
852 #define MCF5282_INTC0_ICR10 (*(vuint8 *)(&__IPSBAR[0x0C4A]))
853 #define MCF5282_INTC0_ICR11 (*(vuint8 *)(&__IPSBAR[0x0C4B]))
854 #define MCF5282_INTC0_ICR12 (*(vuint8 *)(&__IPSBAR[0x0C4C]))
855 #define MCF5282_INTC0_ICR13 (*(vuint8 *)(&__IPSBAR[0x0C4D]))
856 #define MCF5282_INTC0_ICR14 (*(vuint8 *)(&__IPSBAR[0x0C4E]))
857 #define MCF5282_INTC0_ICR15 (*(vuint8 *)(&__IPSBAR[0x0C4F]))
858 #define MCF5282_INTC0_ICR17 (*(vuint8 *)(&__IPSBAR[0x0C51]))
859 #define MCF5282_INTC0_ICR18 (*(vuint8 *)(&__IPSBAR[0x0C52]))
860 #define MCF5282_INTC0_ICR19 (*(vuint8 *)(&__IPSBAR[0x0C53]))
861 #define MCF5282_INTC0_ICR20 (*(vuint8 *)(&__IPSBAR[0x0C54]))
862 #define MCF5282_INTC0_ICR21 (*(vuint8 *)(&__IPSBAR[0x0C55]))
863 #define MCF5282_INTC0_ICR22 (*(vuint8 *)(&__IPSBAR[0x0C56]))
864 #define MCF5282_INTC0_ICR23 (*(vuint8 *)(&__IPSBAR[0x0C57]))
865 #define MCF5282_INTC0_ICR24 (*(vuint8 *)(&__IPSBAR[0x0C58]))
866 #define MCF5282_INTC0_ICR25 (*(vuint8 *)(&__IPSBAR[0x0C59]))
867 #define MCF5282_INTC0_ICR26 (*(vuint8 *)(&__IPSBAR[0x0C5A]))
868 #define MCF5282_INTC0_ICR27 (*(vuint8 *)(&__IPSBAR[0x0C5B]))
869 #define MCF5282_INTC0_ICR28 (*(vuint8 *)(&__IPSBAR[0x0C5C]))
870 #define MCF5282_INTC0_ICR29 (*(vuint8 *)(&__IPSBAR[0x0C5D]))
871 #define MCF5282_INTC0_ICR30 (*(vuint8 *)(&__IPSBAR[0x0C5E]))
872 #define MCF5282_INTC0_ICR31 (*(vuint8 *)(&__IPSBAR[0x0C5F]))
873 #define MCF5282_INTC0_ICR32 (*(vuint8 *)(&__IPSBAR[0x0C60]))
874 #define MCF5282_INTC0_ICR33 (*(vuint8 *)(&__IPSBAR[0x0C61]))
875 #define MCF5282_INTC0_ICR34 (*(vuint8 *)(&__IPSBAR[0x0C62]))
876 #define MCF5282_INTC0_ICR35 (*(vuint8 *)(&__IPSBAR[0x0C63]))
877 #define MCF5282_INTC0_ICR36 (*(vuint8 *)(&__IPSBAR[0x0C64]))
878 #define MCF5282_INTC0_ICR37 (*(vuint8 *)(&__IPSBAR[0x0C65]))
879 #define MCF5282_INTC0_ICR38 (*(vuint8 *)(&__IPSBAR[0x0C66]))
880 #define MCF5282_INTC0_ICR39 (*(vuint8 *)(&__IPSBAR[0x0C67]))
881 #define MCF5282_INTC0_ICR40 (*(vuint8 *)(&__IPSBAR[0x0C68]))
882 #define MCF5282_INTC0_ICR41 (*(vuint8 *)(&__IPSBAR[0x0C69]))
883 #define MCF5282_INTC0_ICR42 (*(vuint8 *)(&__IPSBAR[0x0C6A]))
884 #define MCF5282_INTC0_ICR43 (*(vuint8 *)(&__IPSBAR[0x0C6B]))
885 #define MCF5282_INTC0_ICR44 (*(vuint8 *)(&__IPSBAR[0x0C6C]))
886 #define MCF5282_INTC0_ICR45 (*(vuint8 *)(&__IPSBAR[0x0C6D]))
887 #define MCF5282_INTC0_ICR46 (*(vuint8 *)(&__IPSBAR[0x0C6E]))
888 #define MCF5282_INTC0_ICR47 (*(vuint8 *)(&__IPSBAR[0x0C6F]))
889 #define MCF5282_INTC0_ICR48 (*(vuint8 *)(&__IPSBAR[0x0C70]))
890 #define MCF5282_INTC0_ICR49 (*(vuint8 *)(&__IPSBAR[0x0C71]))
891 #define MCF5282_INTC0_ICR50 (*(vuint8 *)(&__IPSBAR[0x0C72]))
892 #define MCF5282_INTC0_ICR51 (*(vuint8 *)(&__IPSBAR[0x0C73]))
893 #define MCF5282_INTC0_ICR52 (*(vuint8 *)(&__IPSBAR[0x0C74]))
894 #define MCF5282_INTC0_ICR53 (*(vuint8 *)(&__IPSBAR[0x0C75]))
895 #define MCF5282_INTC0_ICR54 (*(vuint8 *)(&__IPSBAR[0x0C76]))
896 #define MCF5282_INTC0_ICR55 (*(vuint8 *)(&__IPSBAR[0x0C77]))
897 #define MCF5282_INTC0_ICR56 (*(vuint8 *)(&__IPSBAR[0x0C78]))
898 #define MCF5282_INTC0_ICR57 (*(vuint8 *)(&__IPSBAR[0x0C79]))
899 #define MCF5282_INTC0_ICR58 (*(vuint8 *)(&__IPSBAR[0x0C7A]))
900 #define MCF5282_INTC0_ICR59 (*(vuint8 *)(&__IPSBAR[0x0C7B]))
901 #define MCF5282_INTC0_ICR60 (*(vuint8 *)(&__IPSBAR[0x0C7C]))
902 #define MCF5282_INTC0_ICR61 (*(vuint8 *)(&__IPSBAR[0x0C7D]))
903 #define MCF5282_INTC0_ICR62 (*(vuint8 *)(&__IPSBAR[0x0C7E]))
904 #define MCF5282_INTC0_SWIACK (*(vuint8 *)(&__IPSBAR[0x0CE0]))
905 #define MCF5282_INTC0_L1IACK (*(vuint8 *)(&__IPSBAR[0x0CE4]))
906 #define MCF5282_INTC0_L2IACK (*(vuint8 *)(&__IPSBAR[0x0CE8]))
907 #define MCF5282_INTC0_L3IACK (*(vuint8 *)(&__IPSBAR[0x0CEC]))
908 #define MCF5282_INTC0_L4IACK (*(vuint8 *)(&__IPSBAR[0x0CF0]))
909 #define MCF5282_INTC0_L5IACK (*(vuint8 *)(&__IPSBAR[0x0CF4]))
910 #define MCF5282_INTC0_L6IACK (*(vuint8 *)(&__IPSBAR[0x0CF8]))
911 #define MCF5282_INTC0_L7IACK (*(vuint8 *)(&__IPSBAR[0x0CFC]))
912
913 #define MCF5282_INTC1_IPRH (*(vuint32 *)(&__IPSBAR[0x0D00]))
914 #define MCF5282_INTC1_IPRL (*(vuint32 *)(&__IPSBAR[0x0D04]))
915 #define MCF5282_INTC1_IMRH (*(vuint32 *)(&__IPSBAR[0x0D08]))
916 #define MCF5282_INTC1_IMRL (*(vuint32 *)(&__IPSBAR[0x0D0C]))
917 #define MCF5282_INTC1_INTFRCH (*(vuint32 *)(&__IPSBAR[0x0D10]))
918 #define MCF5282_INTC1_INTFRCL (*(vuint32 *)(&__IPSBAR[0x0D14]))
919 #define MCF5282_INTC1_IRLR (*(vuint8 *)(&__IPSBAR[0x0D18]))
920 #define MCF5282_INTC1_IACKLPR (*(vuint8 *)(&__IPSBAR[0x0D19]))
921 #define MCF5282_INTC1_ICR08 (*(vuint8 *)(&__IPSBAR[0x0D48]))
922 #define MCF5282_INTC1_ICR09 (*(vuint8 *)(&__IPSBAR[0x0D49]))
923 #define MCF5282_INTC1_ICR10 (*(vuint8 *)(&__IPSBAR[0x0D4A]))
924 #define MCF5282_INTC1_ICR11 (*(vuint8 *)(&__IPSBAR[0x0D4B]))
925 #define MCF5282_INTC1_ICR12 (*(vuint8 *)(&__IPSBAR[0x0D4C]))
926 #define MCF5282_INTC1_ICR13 (*(vuint8 *)(&__IPSBAR[0x0D4D]))
927 #define MCF5282_INTC1_ICR14 (*(vuint8 *)(&__IPSBAR[0x0D4E]))
928 #define MCF5282_INTC1_ICR15 (*(vuint8 *)(&__IPSBAR[0x0D4F]))
929 #define MCF5282_INTC1_ICR16 (*(vuint8 *)(&__IPSBAR[0x0D50]))
930 #define MCF5282_INTC1_ICR17 (*(vuint8 *)(&__IPSBAR[0x0D51]))
931 #define MCF5282_INTC1_ICR18 (*(vuint8 *)(&__IPSBAR[0x0D52]))
932 #define MCF5282_INTC1_ICR19 (*(vuint8 *)(&__IPSBAR[0x0D53]))
933 #define MCF5282_INTC1_ICR20 (*(vuint8 *)(&__IPSBAR[0x0D54]))
934 #define MCF5282_INTC1_ICR21 (*(vuint8 *)(&__IPSBAR[0x0D55]))
935 #define MCF5282_INTC1_ICR22 (*(vuint8 *)(&__IPSBAR[0x0D56]))
936 #define MCF5282_INTC1_ICR23 (*(vuint8 *)(&__IPSBAR[0x0D57]))
937 #define MCF5282_INTC1_ICR24 (*(vuint8 *)(&__IPSBAR[0x0D58]))
938 #define MCF5282_INTC1_ICR25 (*(vuint8 *)(&__IPSBAR[0x0D59]))
939 #define MCF5282_INTC1_ICR26 (*(vuint8 *)(&__IPSBAR[0x0D5A]))
940 #define MCF5282_INTC1_SWIACK (*(vuint8 *)(&__IPSBAR[0x0DE0]))
941 #define MCF5282_INTC1_L1IACK (*(vuint8 *)(&__IPSBAR[0x0DE4]))
942 #define MCF5282_INTC1_L2IACK (*(vuint8 *)(&__IPSBAR[0x0DE8]))
943 #define MCF5282_INTC1_L3IACK (*(vuint8 *)(&__IPSBAR[0x0DEC]))
944 #define MCF5282_INTC1_L4IACK (*(vuint8 *)(&__IPSBAR[0x0DF0]))
945 #define MCF5282_INTC1_L5IACK (*(vuint8 *)(&__IPSBAR[0x0DF4]))
946 #define MCF5282_INTC1_L6IACK (*(vuint8 *)(&__IPSBAR[0x0DF8]))
947 #define MCF5282_INTC1_L7IACK (*(vuint8 *)(&__IPSBAR[0x0DFC]))
948
949 /* Bit level definitions and macros */
950 #define MCF5282_INTC_IPRH_INT63 (0x80000000)
951 #define MCF5282_INTC_IPRH_INT62 (0x40000000)
952 #define MCF5282_INTC_IPRH_INT61 (0x20000000)
953 #define MCF5282_INTC_IPRH_INT60 (0x10000000)
954 #define MCF5282_INTC_IPRH_INT59 (0x08000000)
955 #define MCF5282_INTC_IPRH_INT58 (0x04000000)
956 #define MCF5282_INTC_IPRH_INT57 (0x02000000)
957 #define MCF5282_INTC_IPRH_INT56 (0x01000000)
958 #define MCF5282_INTC_IPRH_INT55 (0x00800000)
959 #define MCF5282_INTC_IPRH_INT54 (0x00400000)
960 #define MCF5282_INTC_IPRH_INT53 (0x00200000)
961 #define MCF5282_INTC_IPRH_INT52 (0x00100000)
962 #define MCF5282_INTC_IPRH_INT51 (0x00080000)
963 #define MCF5282_INTC_IPRH_INT50 (0x00040000)
964 #define MCF5282_INTC_IPRH_INT49 (0x00020000)
965 #define MCF5282_INTC_IPRH_INT48 (0x00010000)
966 #define MCF5282_INTC_IPRH_INT47 (0x00008000)
967 #define MCF5282_INTC_IPRH_INT46 (0x00004000)
968 #define MCF5282_INTC_IPRH_INT45 (0x00002000)
969 #define MCF5282_INTC_IPRH_INT44 (0x00001000)
970 #define MCF5282_INTC_IPRH_INT43 (0x00000800)
971 #define MCF5282_INTC_IPRH_INT42 (0x00000400)
972 #define MCF5282_INTC_IPRH_INT41 (0x00000200)
973 #define MCF5282_INTC_IPRH_INT40 (0x00000100)
974 #define MCF5282_INTC_IPRH_INT39 (0x00000080)
975 #define MCF5282_INTC_IPRH_INT38 (0x00000040)
976 #define MCF5282_INTC_IPRH_INT37 (0x00000020)
977 #define MCF5282_INTC_IPRH_INT36 (0x00000010)
978 #define MCF5282_INTC_IPRH_INT35 (0x00000008)
979 #define MCF5282_INTC_IPRH_INT34 (0x00000004)
980 #define MCF5282_INTC_IPRH_INT33 (0x00000002)
981 #define MCF5282_INTC_IPRH_INT32 (0x00000001)
982
983 #define MCF5282_INTC_IPRL_INT31 (0x80000000)
984 #define MCF5282_INTC_IPRL_INT30 (0x40000000)
985 #define MCF5282_INTC_IPRL_INT29 (0x20000000)
986 #define MCF5282_INTC_IPRL_INT28 (0x10000000)
987 #define MCF5282_INTC_IPRL_INT27 (0x08000000)
988 #define MCF5282_INTC_IPRL_INT26 (0x04000000)
989 #define MCF5282_INTC_IPRL_INT25 (0x02000000)
990 #define MCF5282_INTC_IPRL_INT24 (0x01000000)
991 #define MCF5282_INTC_IPRL_INT23 (0x00800000)
992 #define MCF5282_INTC_IPRL_INT22 (0x00400000)
993 #define MCF5282_INTC_IPRL_INT21 (0x00200000)
994 #define MCF5282_INTC_IPRL_INT20 (0x00100000)
995 #define MCF5282_INTC_IPRL_INT19 (0x00080000)
996 #define MCF5282_INTC_IPRL_INT18 (0x00040000)
997 #define MCF5282_INTC_IPRL_INT17 (0x00020000)
998 #define MCF5282_INTC_IPRL_INT16 (0x00010000)
999 #define MCF5282_INTC_IPRL_INT15 (0x00008000)
1000 #define MCF5282_INTC_IPRL_INT14 (0x00004000)
1001 #define MCF5282_INTC_IPRL_INT13 (0x00002000)
1002 #define MCF5282_INTC_IPRL_INT12 (0x00001000)
1003 #define MCF5282_INTC_IPRL_INT11 (0x00000800)
1004 #define MCF5282_INTC_IPRL_INT10 (0x00000400)
1005 #define MCF5282_INTC_IPRL_INT9 (0x00000200)
1006 #define MCF5282_INTC_IPRL_INT8 (0x00000100)
1007 #define MCF5282_INTC_IPRL_INT7 (0x00000080)
1008 #define MCF5282_INTC_IPRL_INT6 (0x00000040)
1009 #define MCF5282_INTC_IPRL_INT5 (0x00000020)
1010 #define MCF5282_INTC_IPRL_INT4 (0x00000010)
1011 #define MCF5282_INTC_IPRL_INT3 (0x00000008)
1012 #define MCF5282_INTC_IPRL_INT2 (0x00000004)
1013 #define MCF5282_INTC_IPRL_INT1 (0x00000002)
1014
1015 #define MCF5282_INTC_IMRH_INT63 (0x80000000)
1016 #define MCF5282_INTC_IMRH_INT62 (0x40000000)
1017 #define MCF5282_INTC_IMRH_INT61 (0x20000000)
1018 #define MCF5282_INTC_IMRH_INT60 (0x10000000)
1019 #define MCF5282_INTC_IMRH_INT59 (0x08000000)
1020 #define MCF5282_INTC_IMRH_INT58 (0x04000000)
1021 #define MCF5282_INTC_IMRH_INT57 (0x02000000)
1022 #define MCF5282_INTC_IMRH_INT56 (0x01000000)
1023 #define MCF5282_INTC_IMRH_INT55 (0x00800000)
1024 #define MCF5282_INTC_IMRH_INT54 (0x00400000)
1025 #define MCF5282_INTC_IMRH_INT53 (0x00200000)
1026 #define MCF5282_INTC_IMRH_INT52 (0x00100000)
1027 #define MCF5282_INTC_IMRH_INT51 (0x00080000)
1028 #define MCF5282_INTC_IMRH_INT50 (0x00040000)
1029 #define MCF5282_INTC_IMRH_INT49 (0x00020000)
1030 #define MCF5282_INTC_IMRH_INT48 (0x00010000)
1031 #define MCF5282_INTC_IMRH_INT47 (0x00008000)
1032 #define MCF5282_INTC_IMRH_INT46 (0x00004000)
1033 #define MCF5282_INTC_IMRH_INT45 (0x00002000)
1034 #define MCF5282_INTC_IMRH_INT44 (0x00001000)
1035 #define MCF5282_INTC_IMRH_INT43 (0x00000800)
1036 #define MCF5282_INTC_IMRH_INT42 (0x00000400)
1037 #define MCF5282_INTC_IMRH_INT41 (0x00000200)
1038 #define MCF5282_INTC_IMRH_INT40 (0x00000100)
1039 #define MCF5282_INTC_IMRH_INT39 (0x00000080)
1040 #define MCF5282_INTC_IMRH_INT38 (0x00000040)
1041 #define MCF5282_INTC_IMRH_INT37 (0x00000020)
1042 #define MCF5282_INTC_IMRH_INT36 (0x00000010)
1043 #define MCF5282_INTC_IMRH_INT35 (0x00000008)
1044 #define MCF5282_INTC_IMRH_INT34 (0x00000004)
1045 #define MCF5282_INTC_IMRH_INT33 (0x00000002)
1046 #define MCF5282_INTC_IMRH_INT32 (0x00000001)
1047
1048 #define MCF5282_INTC_IMRL_INT31 (0x80000000)
1049 #define MCF5282_INTC_IMRL_INT30 (0x40000000)
1050 #define MCF5282_INTC_IMRL_INT29 (0x20000000)
1051 #define MCF5282_INTC_IMRL_INT28 (0x10000000)
1052 #define MCF5282_INTC_IMRL_INT27 (0x08000000)
1053 #define MCF5282_INTC_IMRL_INT26 (0x04000000)
1054 #define MCF5282_INTC_IMRL_INT25 (0x02000000)
1055 #define MCF5282_INTC_IMRL_INT24 (0x01000000)
1056 #define MCF5282_INTC_IMRL_INT23 (0x00800000)
1057 #define MCF5282_INTC_IMRL_INT22 (0x00400000)
1058 #define MCF5282_INTC_IMRL_INT21 (0x00200000)
1059 #define MCF5282_INTC_IMRL_INT20 (0x00100000)
1060 #define MCF5282_INTC_IMRL_INT19 (0x00080000)
1061 #define MCF5282_INTC_IMRL_INT18 (0x00040000)
1062 #define MCF5282_INTC_IMRL_INT17 (0x00020000)
1063 #define MCF5282_INTC_IMRL_INT16 (0x00010000)
1064 #define MCF5282_INTC_IMRL_INT15 (0x00008000)
1065 #define MCF5282_INTC_IMRL_INT14 (0x00004000)
1066 #define MCF5282_INTC_IMRL_INT13 (0x00002000)
1067 #define MCF5282_INTC_IMRL_INT12 (0x00001000)
1068 #define MCF5282_INTC_IMRL_INT11 (0x00000800)
1069 #define MCF5282_INTC_IMRL_INT10 (0x00000400)
1070 #define MCF5282_INTC_IMRL_INT9 (0x00000200)
1071 #define MCF5282_INTC_IMRL_INT8 (0x00000100)
1072 #define MCF5282_INTC_IMRL_INT7 (0x00000080)
1073 #define MCF5282_INTC_IMRL_INT6 (0x00000040)
1074 #define MCF5282_INTC_IMRL_INT5 (0x00000020)
1075 #define MCF5282_INTC_IMRL_INT4 (0x00000010)
1076 #define MCF5282_INTC_IMRL_INT3 (0x00000008)
1077 #define MCF5282_INTC_IMRL_INT2 (0x00000004)
1078 #define MCF5282_INTC_IMRL_INT1 (0x00000002)
1079 #define MCF5282_INTC_IMRL_MASKALL (0x00000001)
1080
1081 #define MCF5282_INTC_INTFRCH_INT63 (0x80000000)
1082 #define MCF5282_INTC_INTFRCH_INT62 (0x40000000)
1083 #define MCF5282_INTC_INTFRCH_INT61 (0x20000000)
1084 #define MCF5282_INTC_INTFRCH_INT60 (0x10000000)
1085 #define MCF5282_INTC_INTFRCH_INT59 (0x08000000)
1086 #define MCF5282_INTC_INTFRCH_INT58 (0x04000000)
1087 #define MCF5282_INTC_INTFRCH_INT57 (0x02000000)
1088 #define MCF5282_INTC_INTFRCH_INT56 (0x01000000)
1089 #define MCF5282_INTC_INTFRCH_INT55 (0x00800000)
1090 #define MCF5282_INTC_INTFRCH_INT54 (0x00400000)
1091 #define MCF5282_INTC_INTFRCH_INT53 (0x00200000)
1092 #define MCF5282_INTC_INTFRCH_INT52 (0x00100000)
1093 #define MCF5282_INTC_INTFRCH_INT51 (0x00080000)
1094 #define MCF5282_INTC_INTFRCH_INT50 (0x00040000)
1095 #define MCF5282_INTC_INTFRCH_INT49 (0x00020000)
1096 #define MCF5282_INTC_INTFRCH_INT48 (0x00010000)
1097 #define MCF5282_INTC_INTFRCH_INT47 (0x00008000)
1098 #define MCF5282_INTC_INTFRCH_INT46 (0x00004000)
1099 #define MCF5282_INTC_INTFRCH_INT45 (0x00002000)
1100 #define MCF5282_INTC_INTFRCH_INT44 (0x00001000)
1101 #define MCF5282_INTC_INTFRCH_INT43 (0x00000800)
1102 #define MCF5282_INTC_INTFRCH_INT42 (0x00000400)
1103 #define MCF5282_INTC_INTFRCH_INT41 (0x00000200)
1104 #define MCF5282_INTC_INTFRCH_INT40 (0x00000100)
1105 #define MCF5282_INTC_INTFRCH_INT39 (0x00000080)
1106 #define MCF5282_INTC_INTFRCH_INT38 (0x00000040)
1107 #define MCF5282_INTC_INTFRCH_INT37 (0x00000020)
1108 #define MCF5282_INTC_INTFRCH_INT36 (0x00000010)
1109 #define MCF5282_INTC_INTFRCH_INT35 (0x00000008)
1110 #define MCF5282_INTC_INTFRCH_INT34 (0x00000004)
1111 #define MCF5282_INTC_INTFRCH_INT33 (0x00000002)
1112 #define MCF5282_INTC_INTFRCH_INT32 (0x00000001)
1113
1114 #define MCF5282_INTC_INTFRCL_INT31 (0x80000000)
1115 #define MCF5282_INTC_INTFRCL_INT30 (0x40000000)
1116 #define MCF5282_INTC_INTFRCL_INT29 (0x20000000)
1117 #define MCF5282_INTC_INTFRCL_INT28 (0x10000000)
1118 #define MCF5282_INTC_INTFRCL_INT27 (0x08000000)
1119 #define MCF5282_INTC_INTFRCL_INT26 (0x04000000)
1120 #define MCF5282_INTC_INTFRCL_INT25 (0x02000000)
1121 #define MCF5282_INTC_INTFRCL_INT24 (0x01000000)
1122 #define MCF5282_INTC_INTFRCL_INT23 (0x00800000)
1123 #define MCF5282_INTC_INTFRCL_INT22 (0x00400000)
1124 #define MCF5282_INTC_INTFRCL_INT21 (0x00200000)
1125 #define MCF5282_INTC_INTFRCL_INT20 (0x00100000)
1126 #define MCF5282_INTC_INTFRCL_INT19 (0x00080000)
1127 #define MCF5282_INTC_INTFRCL_INT18 (0x00040000)
1128 #define MCF5282_INTC_INTFRCL_INT17 (0x00020000)
1129 #define MCF5282_INTC_INTFRCL_INT16 (0x00010000)
1130 #define MCF5282_INTC_INTFRCL_INT15 (0x00008000)
1131 #define MCF5282_INTC_INTFRCL_INT14 (0x00004000)
1132 #define MCF5282_INTC_INTFRCL_INT13 (0x00002000)
1133 #define MCF5282_INTC_INTFRCL_INT12 (0x00001000)
1134 #define MCF5282_INTC_INTFRCL_INT11 (0x00000800)
1135 #define MCF5282_INTC_INTFRCL_INT10 (0x00000400)
1136 #define MCF5282_INTC_INTFRCL_INT9 (0x00000200)
1137 #define MCF5282_INTC_INTFRCL_INT8 (0x00000100)
1138 #define MCF5282_INTC_INTFRCL_INT7 (0x00000080)
1139 #define MCF5282_INTC_INTFRCL_INT6 (0x00000040)
1140 #define MCF5282_INTC_INTFRCL_INT5 (0x00000020)
1141 #define MCF5282_INTC_INTFRCL_INT4 (0x00000010)
1142 #define MCF5282_INTC_INTFRCL_INT3 (0x00000008)
1143 #define MCF5282_INTC_INTFRCL_INT2 (0x00000004)
1144 #define MCF5282_INTC_INTFRCL_INT1 (0x00000002)
1145
1146 #define MCF5282_INTC_IRLR_IRQ7 (0x80)
1147 #define MCF5282_INTC_IRLR_IRQ6 (0x40)
1148 #define MCF5282_INTC_IRLR_IRQ5 (0x20)
1149 #define MCF5282_INTC_IRLR_IRQ4 (0x10)
1150 #define MCF5282_INTC_IRLR_IRQ3 (0x08)
1151 #define MCF5282_INTC_IRLR_IRQ2 (0x04)
1152 #define MCF5282_INTC_IRLR_IRQ1 (0x02)
1153
1154 #define MCF5282_INTC_ICR_IL(x) (((x)&0x07)<<3)
1155 #define MCF5282_INTC_ICR_IP(x) (((x)&0x07)<<0)
1156
1157 /*********************************************************************
1158 *
1159 * Global Interrupt Acknowledge Cycle (GIAC) Registers
1160 *
1161 *********************************************************************/
1162
1163 /* Read/Write access macros for general use */
1164 #define MCF5282_GIAC_GSWIACK (*(vuint8 *)(&__IPSBAR[0x0FE0]))
1165 #define MCF5282_GIAC_GL1IACK (*(vuint8 *)(&__IPSBAR[0x0FE4]))
1166 #define MCF5282_GIAC_GL2IACK (*(vuint8 *)(&__IPSBAR[0x0FE8]))
1167 #define MCF5282_GIAC_GL3IACK (*(vuint8 *)(&__IPSBAR[0x0FEC]))
1168 #define MCF5282_GIAC_GL4IACK (*(vuint8 *)(&__IPSBAR[0x0FF0]))
1169 #define MCF5282_GIAC_GL5IACK (*(vuint8 *)(&__IPSBAR[0x0FF4]))
1170 #define MCF5282_GIAC_GL6IACK (*(vuint8 *)(&__IPSBAR[0x0FF8]))
1171 #define MCF5282_GIAC_GL7IACK (*(vuint8 *)(&__IPSBAR[0x0FFC]))
1172
1173 /* Bit level definitions and macros */
1174
1175 /* To do - add bit level definintions */
1176
1177 /*********************************************************************
1178 *
1179 * Fast Ethernet Controller (FEC) Module
1180 *
1181 *********************************************************************/
1182
1183 /* Read/Write access macros for general use */
1184 #define MCF5282_FEC_EIR (*(vuint32 *)(&__IPSBAR[0x1004]))
1185 #define MCF5282_FEC_EIMR (*(vuint32 *)(&__IPSBAR[0x1008]))
1186 #define MCF5282_FEC_RDAR (*(vuint32 *)(&__IPSBAR[0x1010]))
1187 #define MCF5282_FEC_TDAR (*(vuint32 *)(&__IPSBAR[0x1014]))
1188 #define MCF5282_FEC_ECR (*(vuint32 *)(&__IPSBAR[0x1024]))
1189 #define MCF5282_FEC_MMFR (*(vuint32 *)(&__IPSBAR[0x1040]))
1190 #define MCF5282_FEC_MSCR (*(vuint32 *)(&__IPSBAR[0x1044]))
1191 #define MCF5282_FEC_MIBC (*(vuint32 *)(&__IPSBAR[0x1064]))
1192 #define MCF5282_FEC_RCR (*(vuint32 *)(&__IPSBAR[0x1084]))
1193 #define MCF5282_FEC_TCR (*(vuint32 *)(&__IPSBAR[0x10C4]))
1194 #define MCF5282_FEC_PALR (*(vuint32 *)(&__IPSBAR[0x10E4]))
1195 #define MCF5282_FEC_PAUR (*(vuint32 *)(&__IPSBAR[0x10E8]))
1196 #define MCF5282_FEC_OPD (*(vuint32 *)(&__IPSBAR[0x10EC]))
1197 #define MCF5282_FEC_IAUR (*(vuint32 *)(&__IPSBAR[0x1118]))
1198 #define MCF5282_FEC_IALR (*(vuint32 *)(&__IPSBAR[0x111C]))
1199 #define MCF5282_FEC_GAUR (*(vuint32 *)(&__IPSBAR[0x1120]))
1200 #define MCF5282_FEC_GALR (*(vuint32 *)(&__IPSBAR[0x1124]))
1201 #define MCF5282_FEC_TFWR (*(vuint32 *)(&__IPSBAR[0x1144]))
1202 #define MCF5282_FEC_FRBR (*(vuint32 *)(&__IPSBAR[0x114C]))
1203 #define MCF5282_FEC_FRSR (*(vuint32 *)(&__IPSBAR[0x1150]))
1204 #define MCF5282_FEC_ERDSR (*(vuint32 *)(&__IPSBAR[0x1180]))
1205 #define MCF5282_FEC_ETDSR (*(vuint32 *)(&__IPSBAR[0x1184]))
1206 #define MCF5282_FEC_EMRBR (*(vuint32 *)(&__IPSBAR[0x1188]))
1207
1208 #define MCF5282_FEC_RMON_T_DROP (*(vuint32 *)(&__IPSBAR[0x1200]))
1209 #define MCF5282_FEC_RMON_T_PACKETS (*(vuint32 *)(&__IPSBAR[0x1204]))
1210 #define MCF5282_FEC_RMON_T_BC_PKT (*(vuint32 *)(&__IPSBAR[0x1208]))
1211 #define MCF5282_FEC_RMON_T_MC_PKT (*(vuint32 *)(&__IPSBAR[0x120C]))
1212 #define MCF5282_FEC_RMON_T_CRC_ALIGN (*(vuint32 *)(&__IPSBAR[0x1210]))
1213 #define MCF5282_FEC_RMON_T_UNDERSIZE (*(vuint32 *)(&__IPSBAR[0x1214]))
1214 #define MCF5282_FEC_RMON_T_OVERSIZE (*(vuint32 *)(&__IPSBAR[0x1218]))
1215 #define MCF5282_FEC_RMON_T_FRAG (*(vuint32 *)(&__IPSBAR[0x121C]))
1216 #define MCF5282_FEC_RMON_T_JAB (*(vuint32 *)(&__IPSBAR[0x1220]))
1217 #define MCF5282_FEC_RMON_T_COL (*(vuint32 *)(&__IPSBAR[0x1224]))
1218 #define MCF5282_FEC_RMON_T_P64 (*(vuint32 *)(&__IPSBAR[0x1228]))
1219 #define MCF5282_FEC_RMON_T_P65TO127 (*(vuint32 *)(&__IPSBAR[0x122C]))
1220 #define MCF5282_FEC_RMON_T_P128TO255 (*(vuint32 *)(&__IPSBAR[0x1230]))
1221 #define MCF5282_FEC_RMON_T_P256TO511 (*(vuint32 *)(&__IPSBAR[0x1234]))
1222 #define MCF5282_FEC_RMON_T_P512TO1023 (*(vuint32 *)(&__IPSBAR[0x1238]))
1223 #define MCF5282_FEC_RMON_T_P1024TO2047 (*(vuint32 *)(&__IPSBAR[0x123C]))
1224 #define MCF5282_FEC_RMON_T_P_GTE2048 (*(vuint32 *)(&__IPSBAR[0x1240]))
1225 #define MCF5282_FEC_RMON_T_OCTETS (*(vuint32 *)(&__IPSBAR[0x1244]))
1226 #define MCF5282_FEC_IEEE_T_DROP (*(vuint32 *)(&__IPSBAR[0x1248]))
1227 #define MCF5282_FEC_IEEE_T_FRAME_OK (*(vuint32 *)(&__IPSBAR[0x124C]))
1228 #define MCF5282_FEC_IEEE_T_1COL (*(vuint32 *)(&__IPSBAR[0x1250]))
1229 #define MCF5282_FEC_IEEE_T_MCOL (*(vuint32 *)(&__IPSBAR[0x1254]))
1230 #define MCF5282_FEC_IEEE_T_DEF (*(vuint32 *)(&__IPSBAR[0x1258]))
1231 #define MCF5282_FEC_IEEE_T_LCOL (*(vuint32 *)(&__IPSBAR[0x125C]))
1232 #define MCF5282_FEC_IEEE_T_EXCOL (*(vuint32 *)(&__IPSBAR[0x1260]))
1233 #define MCF5282_FEC_IEEE_T_MACERR (*(vuint32 *)(&__IPSBAR[0x1264]))
1234 #define MCF5282_FEC_IEEE_T_CSERR (*(vuint32 *)(&__IPSBAR[0x1268]))
1235 #define MCF5282_FEC_IEEE_T_SQE (*(vuint32 *)(&__IPSBAR[0x126C]))
1236 #define MCF5282_FEC_IEEE_T_FDXFC (*(vuint32 *)(&__IPSBAR[0x1270]))
1237 #define MCF5282_FEC_IEEE_T_OCTETS_OK (*(vuint32 *)(&__IPSBAR[0x1274]))
1238 #define MCF5282_FEC_RMON_R_PACKETS (*(vuint32 *)(&__IPSBAR[0x1284]))
1239 #define MCF5282_FEC_RMON_R_BC_PKT (*(vuint32 *)(&__IPSBAR[0x1288]))
1240 #define MCF5282_FEC_RMON_R_MC_PKT (*(vuint32 *)(&__IPSBAR[0x128C]))
1241 #define MCF5282_FEC_RMON_R_CRC_ALIGN (*(vuint32 *)(&__IPSBAR[0x1290]))
1242 #define MCF5282_FEC_RMON_R_UNDERSIZE (*(vuint32 *)(&__IPSBAR[0x1294]))
1243 #define MCF5282_FEC_RMON_R_OVERSIZE (*(vuint32 *)(&__IPSBAR[0x1298]))
1244 #define MCF5282_FEC_RMON_R_FRAG (*(vuint32 *)(&__IPSBAR[0x129C]))
1245 #define MCF5282_FEC_RMON_R_JAB (*(vuint32 *)(&__IPSBAR[0x12A0]))
1246 #define MCF5282_FEC_RMON_R_RESVD_0 (*(vuint32 *)(&__IPSBAR[0x12A4]))
1247 #define MCF5282_FEC_RMON_R_P64 (*(vuint32 *)(&__IPSBAR[0x12A8]))
1248 #define MCF5282_FEC_RMON_R_P65T0127 (*(vuint32 *)(&__IPSBAR[0x12AC]))
1249 #define MCF5282_FEC_RMON_R_P128TO255 (*(vuint32 *)(&__IPSBAR[0x12B0]))
1250 #define MCF5282_FEC_RMON_R_P256TO511 (*(vuint32 *)(&__IPSBAR[0x12B4]))
1251 #define MCF5282_FEC_RMON_R_P512TO1023 (*(vuint32 *)(&__IPSBAR[0x12B8]))
1252 #define MCF5282_FEC_RMON_R_P1024TO2047 (*(vuint32 *)(&__IPSBAR[0x12BC]))
1253 #define MCF5282_FEC_RMON_R_GTE2048 (*(vuint32 *)(&__IPSBAR[0x12C0]))
1254 #define MCF5282_FEC_RMON_R_OCTETS (*(vuint32 *)(&__IPSBAR[0x12C4]))
1255 #define MCF5282_FEC_IEEE_R_DROP (*(vuint32 *)(&__IPSBAR[0x12C8]))
1256 #define MCF5282_FEC_IEEE_R_FRAME_OK (*(vuint32 *)(&__IPSBAR[0x12CC]))
1257 #define MCF5282_FEC_IEEE_R_CRC (*(vuint32 *)(&__IPSBAR[0x12D0]))
1258 #define MCF5282_FEC_IEEE_R_ALIGN (*(vuint32 *)(&__IPSBAR[0x12D4]))
1259 #define MCF5282_FEC_IEEE_R_MACERR (*(vuint32 *)(&__IPSBAR[0x12D8]))
1260 #define MCF5282_FEC_IEEE_R_FDXFC (*(vuint32 *)(&__IPSBAR[0x12DC]))
1261 #define MCF5282_FEC_IEEE_R_OCTETS_OK (*(vuint32 *)(&__IPSBAR[0x12E0]))
1262
1263 /* Bit level definitions and macros */
1264 #define MCF5282_FEC_EIR_HBERR (0x80000000)
1265 #define MCF5282_FEC_EIR_BABR (0x40000000)
1266 #define MCF5282_FEC_EIR_BABT (0x20000000)
1267 #define MCF5282_FEC_EIR_GRA (0x10000000)
1268 #define MCF5282_FEC_EIR_TXF (0x08000000)
1269 #define MCF5282_FEC_EIR_TXB (0x04000000)
1270 #define MCF5282_FEC_EIR_RXF (0x02000000)
1271 #define MCF5282_FEC_EIR_RXB (0x01000000)
1272 #define MCF5282_FEC_EIR_MII (0x00800000)
1273 #define MCF5282_FEC_EIR_EBERR (0x00400000)
1274 #define MCF5282_FEC_EIR_LC (0x00200000)
1275 #define MCF5282_FEC_EIR_RL (0x00100000)
1276 #define MCF5282_FEC_EIR_UN (0x00080000)
1277
1278 #define MCF5282_FEC_EIMR_HBERR (0x80000000)
1279 #define MCF5282_FEC_EIMR_BABR (0x40000000)
1280 #define MCF5282_FEC_EIMR_BABT (0x20000000)
1281 #define MCF5282_FEC_EIMR_GRA (0x10000000)
1282 #define MCF5282_FEC_EIMR_TXF (0x08000000)
1283 #define MCF5282_FEC_EIMR_TXB (0x04000000)
1284 #define MCF5282_FEC_EIMR_RXF (0x02000000)
1285 #define MCF5282_FEC_EIMR_RXB (0x01000000)
1286 #define MCF5282_FEC_EIMR_MII (0x00800000)
1287 #define MCF5282_FEC_EIMR_EBERR (0x00400000)
1288 #define MCF5282_FEC_EIMR_LC (0x00200000)
1289 #define MCF5282_FEC_EIMR_RL (0x00100000)
1290 #define MCF5282_FEC_EIMR_UN (0x00080000)
1291
1292 #define MCF5282_FEC_RDAR_R_DES_ACTIVE (0x01000000)
1293
1294 #define MCF5282_FEC_TDAR_X_DES_ACTIVE (0x01000000)
1295
1296 #define MCF5282_FEC_ECR_ETHER_EN (0x00000002)
1297 #define MCF5282_FEC_ECR_RESET (0x00000001)
1298
1299 #define MCF5282_FEC_MMFR_ST (0x40000000)
1300 #define MCF5282_FEC_MMFR_OP_RD (0x20000000)
1301 #define MCF5282_FEC_MMFR_OP_WR (0x10000000)
1302 #define MCF5282_FEC_MMFR_PA(x) (((x)&0x1F)<<23)
1303 #define MCF5282_FEC_MMFR_RA(x) (((x)&0x1F)<<18)
1304 #define MCF5282_FEC_MMFR_TA (0x00020000)
1305 #define MCF5282_FEC_MMFR_DATA(x) (((x)&0xFFFF))
1306
1307 #define MCF5282_FEC_MSCR_DIS_PREAMBLE (0x00000008)
1308 #define MCF5282_FEC_MSCR_MII_SPEED(x) (((x)&0x1F)<<1)
1309
1310 #define MCF5282_FEC_MIBC_MIB_DISABLE (0x80000000)
1311 #define MCF5282_FEC_MIBC_MIB_IDLE (0x40000000)
1312
1313 #define MCF5282_FEC_RCR_MAX_FL(x) (((x)&0x07FF)<<16)
1314 #define MCF5282_FEC_RCR_FCE (0x00000020)
1315 #define MCF5282_FEC_RCR_BC_REJ (0x00000010)
1316 #define MCF5282_FEC_RCR_PROM (0x00000008)
1317 #define MCF5282_FEC_RCR_MII_MODE (0x00000004)
1318 #define MCF5282_FEC_RCR_DRT (0x00000002)
1319 #define MCF5282_FEC_RCR_LOOP (0x00000001)
1320
1321 #define MCF5282_FEC_TCR_RFC_PAUSE (0x00000010)
1322 #define MCF5282_FEC_TCR_TFC_PAUSE (0x00000008)
1323 #define MCF5282_FEC_TCR_FDEN (0x00000004)
1324 #define MCF5282_FEC_TCR_HBC (0x00000002)
1325 #define MCF5282_FEC_TCR_GTS (0x00000001)
1326
1327 #define MCF5282_FEC_PALR_BYTE0(x) (((x)&0xFF)<<24)
1328 #define MCF5282_FEC_PALR_BYTE1(x) (((x)&0xFF)<<16)
1329 #define MCF5282_FEC_PALR_BYTE2(x) (((x)&0xFF)<<8)
1330 #define MCF5282_FEC_PALR_BYTE3(x) (((x)&0xFF))
1331
1332 #define MCF5282_FEC_PAUR_BYTE4(x) (((x)&0xFF)<<24)
1333 #define MCF5282_FEC_PAUR_BYTE5(x) (((x)&0xFF)<<16)
1334
1335 #define MCF5282_FEC_OPD_PAUSE_DUR(x) (((x)&0xFFFF))
1336
1337 #define MCF5282_FEC_TFWR_X_WMRK_64 (0x00000001)
1338 #define MCF5282_FEC_TFWR_X_WMRK_128 (0x00000002)
1339 #define MCF5282_FEC_TFWR_X_WMRK_192 (0x00000003)
1340
1341 #define MCF5282_FEC_EMRBR_R_BUF_SIZE(x) (((x)&0x7F)<<4)
1342
1343 #define MCF5282_FEC_TxBD_R 0x8000
1344 #define MCF5282_FEC_TxBD_BUSY 0x4000
1345 #define MCF5282_FEC_TxBD_TO1 0x4000
1346 #define MCF5282_FEC_TxBD_W 0x2000
1347 #define MCF5282_FEC_TxBD_TO2 0x1000
1348 #define MCF5282_FEC_TxBD_FIRST 0x1000
1349 #define MCF5282_FEC_TxBD_L 0x0800
1350 #define MCF5282_FEC_TxBD_TC 0x0400
1351 #define MCF5282_FEC_TxBD_DEF 0x0200
1352 #define MCF5282_FEC_TxBD_HB 0x0100
1353 #define MCF5282_FEC_TxBD_LC 0x0080
1354 #define MCF5282_FEC_TxBD_RL 0x0040
1355 #define MCF5282_FEC_TxBD_UN 0x0002
1356 #define MCF5282_FEC_TxBD_CSL 0x0001
1357
1358 #define MCF5282_FEC_RxBD_E 0x8000
1359 #define MCF5282_FEC_RxBD_INUSE 0x4000
1360 #define MCF5282_FEC_RxBD_R01 0x4000
1361 #define MCF5282_FEC_RxBD_W 0x2000
1362 #define MCF5282_FEC_RxBD_R02 0x1000
1363 #define MCF5282_FEC_RxBD_L 0x0800
1364 #define MCF5282_FEC_RxBD_M 0x0100
1365 #define MCF5282_FEC_RxBD_BC 0x0080
1366 #define MCF5282_FEC_RxBD_MC 0x0040
1367 #define MCF5282_FEC_RxBD_LG 0x0020
1368 #define MCF5282_FEC_RxBD_NO 0x0010
1369 #define MCF5282_FEC_RxBD_CR 0x0004
1370 #define MCF5282_FEC_RxBD_OV 0x0002
1371 #define MCF5282_FEC_RxBD_TR 0x0001
1372
1373 /*********************************************************************
1374 *
1375 * General Purpose I/O (GPIO) Module
1376 *
1377 *********************************************************************/
1378
1379 /* Read/Write access macros for general use */
1380 #define MCF5282_GPIO_PORTA (*(vuint8 *)(&__IPSBAR[0x100000]))
1381 #define MCF5282_GPIO_PORTB (*(vuint8 *)(&__IPSBAR[0x100001]))
1382 #define MCF5282_GPIO_PORTC (*(vuint8 *)(&__IPSBAR[0x100002]))
1383 #define MCF5282_GPIO_PORTD (*(vuint8 *)(&__IPSBAR[0x100003]))
1384 #define MCF5282_GPIO_PORTE (*(vuint8 *)(&__IPSBAR[0x100004]))
1385 #define MCF5282_GPIO_PORTF (*(vuint8 *)(&__IPSBAR[0x100005]))
1386 #define MCF5282_GPIO_PORTG (*(vuint8 *)(&__IPSBAR[0x100006]))
1387 #define MCF5282_GPIO_PORTH (*(vuint8 *)(&__IPSBAR[0x100007]))
1388 #define MCF5282_GPIO_PORTJ (*(vuint8 *)(&__IPSBAR[0x100008]))
1389 #define MCF5282_GPIO_PORTDD (*(vuint8 *)(&__IPSBAR[0x100009]))
1390 #define MCF5282_GPIO_PORTEH (*(vuint8 *)(&__IPSBAR[0x10000A]))
1391 #define MCF5282_GPIO_PORTEL (*(vuint8 *)(&__IPSBAR[0x10000B]))
1392 #define MCF5282_GPIO_PORTAS (*(vuint8 *)(&__IPSBAR[0x10000C]))
1393 #define MCF5282_GPIO_PORTQS (*(vuint8 *)(&__IPSBAR[0x10000D]))
1394 #define MCF5282_GPIO_PORTSD (*(vuint8 *)(&__IPSBAR[0x10000E]))
1395 #define MCF5282_GPIO_PORTTC (*(vuint8 *)(&__IPSBAR[0x10000F]))
1396 #define MCF5282_GPIO_PORTTD (*(vuint8 *)(&__IPSBAR[0x100010]))
1397 #define MCF5282_GPIO_PORTUA (*(vuint8 *)(&__IPSBAR[0x100011]))
1398
1399 #define MCF5282_GPIO_DDRA (*(vuint8 *)(&__IPSBAR[0x100014]))
1400 #define MCF5282_GPIO_DDRB (*(vuint8 *)(&__IPSBAR[0x100015]))
1401 #define MCF5282_GPIO_DDRC (*(vuint8 *)(&__IPSBAR[0x100016]))
1402 #define MCF5282_GPIO_DDRD (*(vuint8 *)(&__IPSBAR[0x100017]))
1403 #define MCF5282_GPIO_DDRE (*(vuint8 *)(&__IPSBAR[0x100018]))
1404 #define MCF5282_GPIO_DDRF (*(vuint8 *)(&__IPSBAR[0x100019]))
1405 #define MCF5282_GPIO_DDRG (*(vuint8 *)(&__IPSBAR[0x10001A]))
1406 #define MCF5282_GPIO_DDRH (*(vuint8 *)(&__IPSBAR[0x10001B]))
1407 #define MCF5282_GPIO_DDRJ (*(vuint8 *)(&__IPSBAR[0x10001C]))
1408 #define MCF5282_GPIO_DDRDD (*(vuint8 *)(&__IPSBAR[0x10001D]))
1409 #define MCF5282_GPIO_DDREH (*(vuint8 *)(&__IPSBAR[0x10001E]))
1410 #define MCF5282_GPIO_DDREL (*(vuint8 *)(&__IPSBAR[0x10001F]))
1411 #define MCF5282_GPIO_DDRAS (*(vuint8 *)(&__IPSBAR[0x100020]))
1412 #define MCF5282_GPIO_DDRQS (*(vuint8 *)(&__IPSBAR[0x100021]))
1413 #define MCF5282_GPIO_DDRSD (*(vuint8 *)(&__IPSBAR[0x100022]))
1414 #define MCF5282_GPIO_DDRTC (*(vuint8 *)(&__IPSBAR[0x100023]))
1415 #define MCF5282_GPIO_DDRTD (*(vuint8 *)(&__IPSBAR[0x100024]))
1416 #define MCF5282_GPIO_DDRUA (*(vuint8 *)(&__IPSBAR[0x100025]))
1417
1418 #define MCF5282_GPIO_PORTAP (*(vuint8 *)(&__IPSBAR[0x100028]))
1419 #define MCF5282_GPIO_PORTBP (*(vuint8 *)(&__IPSBAR[0x100029]))
1420 #define MCF5282_GPIO_PORTCP (*(vuint8 *)(&__IPSBAR[0x10002A]))
1421 #define MCF5282_GPIO_PORTDP (*(vuint8 *)(&__IPSBAR[0x10002B]))
1422 #define MCF5282_GPIO_PORTEP (*(vuint8 *)(&__IPSBAR[0x10002C]))
1423 #define MCF5282_GPIO_PORTFP (*(vuint8 *)(&__IPSBAR[0x10002D]))
1424 #define MCF5282_GPIO_PORTGP (*(vuint8 *)(&__IPSBAR[0x10002E]))
1425 #define MCF5282_GPIO_PORTHP (*(vuint8 *)(&__IPSBAR[0x10002F]))
1426 #define MCF5282_GPIO_PORTJP (*(vuint8 *)(&__IPSBAR[0x100030]))
1427 #define MCF5282_GPIO_PORTDDP (*(vuint8 *)(&__IPSBAR[0x100031]))
1428 #define MCF5282_GPIO_PORTEHP (*(vuint8 *)(&__IPSBAR[0x100032]))
1429 #define MCF5282_GPIO_PORTELP (*(vuint8 *)(&__IPSBAR[0x100033]))
1430 #define MCF5282_GPIO_PORTASP (*(vuint8 *)(&__IPSBAR[0x100034]))
1431 #define MCF5282_GPIO_PORTQSP (*(vuint8 *)(&__IPSBAR[0x100035]))
1432 #define MCF5282_GPIO_PORTSDP (*(vuint8 *)(&__IPSBAR[0x100036]))
1433 #define MCF5282_GPIO_PORTTCP (*(vuint8 *)(&__IPSBAR[0x100037]))
1434 #define MCF5282_GPIO_PORTTDP (*(vuint8 *)(&__IPSBAR[0x100038]))
1435 #define MCF5282_GPIO_PORTUAP (*(vuint8 *)(&__IPSBAR[0x100039]))
1436
1437 #define MCF5282_GPIO_SETA (*(vuint8 *)(&__IPSBAR[0x100028]))
1438 #define MCF5282_GPIO_SETB (*(vuint8 *)(&__IPSBAR[0x100029]))
1439 #define MCF5282_GPIO_SETC (*(vuint8 *)(&__IPSBAR[0x10002A]))
1440 #define MCF5282_GPIO_SETD (*(vuint8 *)(&__IPSBAR[0x10002B]))
1441 #define MCF5282_GPIO_SETE (*(vuint8 *)(&__IPSBAR[0x10002C]))
1442 #define MCF5282_GPIO_SETF (*(vuint8 *)(&__IPSBAR[0x10002D]))
1443 #define MCF5282_GPIO_SETG (*(vuint8 *)(&__IPSBAR[0x10002E]))
1444 #define MCF5282_GPIO_SETH (*(vuint8 *)(&__IPSBAR[0x10002F]))
1445 #define MCF5282_GPIO_SETJ (*(vuint8 *)(&__IPSBAR[0x100030]))
1446 #define MCF5282_GPIO_SETDD (*(vuint8 *)(&__IPSBAR[0x100031]))
1447 #define MCF5282_GPIO_SETEH (*(vuint8 *)(&__IPSBAR[0x100032]))
1448 #define MCF5282_GPIO_SETEL (*(vuint8 *)(&__IPSBAR[0x100033]))
1449 #define MCF5282_GPIO_SETAS (*(vuint8 *)(&__IPSBAR[0x100034]))
1450 #define MCF5282_GPIO_SETQS (*(vuint8 *)(&__IPSBAR[0x100035]))
1451 #define MCF5282_GPIO_SETSD (*(vuint8 *)(&__IPSBAR[0x100036]))
1452 #define MCF5282_GPIO_SETTC (*(vuint8 *)(&__IPSBAR[0x100037]))
1453 #define MCF5282_GPIO_SETTD (*(vuint8 *)(&__IPSBAR[0x100038]))
1454 #define MCF5282_GPIO_SETUA (*(vuint8 *)(&__IPSBAR[0x100039]))
1455
1456 #define MCF5282_GPIO_CLRA (*(vuint8 *)(&__IPSBAR[0x10003C]))
1457 #define MCF5282_GPIO_CLRB (*(vuint8 *)(&__IPSBAR[0x10003D]))
1458 #define MCF5282_GPIO_CLRC (*(vuint8 *)(&__IPSBAR[0x10003E]))
1459 #define MCF5282_GPIO_CLRD (*(vuint8 *)(&__IPSBAR[0x10003F]))
1460 #define MCF5282_GPIO_CLRE (*(vuint8 *)(&__IPSBAR[0x100040]))
1461 #define MCF5282_GPIO_CLRF (*(vuint8 *)(&__IPSBAR[0x100041]))
1462 #define MCF5282_GPIO_CLRG (*(vuint8 *)(&__IPSBAR[0x100042]))
1463 #define MCF5282_GPIO_CLRH (*(vuint8 *)(&__IPSBAR[0x100043]))
1464 #define MCF5282_GPIO_CLRJ (*(vuint8 *)(&__IPSBAR[0x100044]))
1465 #define MCF5282_GPIO_CLRDD (*(vuint8 *)(&__IPSBAR[0x100045]))
1466 #define MCF5282_GPIO_CLREH (*(vuint8 *)(&__IPSBAR[0x100046]))
1467 #define MCF5282_GPIO_CLREL (*(vuint8 *)(&__IPSBAR[0x100047]))
1468 #define MCF5282_GPIO_CLRAS (*(vuint8 *)(&__IPSBAR[0x100048]))
1469 #define MCF5282_GPIO_CLRQS (*(vuint8 *)(&__IPSBAR[0x100049]))
1470 #define MCF5282_GPIO_CLRSD (*(vuint8 *)(&__IPSBAR[0x10004A]))
1471 #define MCF5282_GPIO_CLRTC (*(vuint8 *)(&__IPSBAR[0x10004B]))
1472 #define MCF5282_GPIO_CLRTD (*(vuint8 *)(&__IPSBAR[0x10004C]))
1473 #define MCF5282_GPIO_CLRUA (*(vuint8 *)(&__IPSBAR[0x10004D]))
1474
1475 #define MCF5282_GPIO_PBCDPAR (*(vuint8 *)(&__IPSBAR[0x100050]))
1476 #define MCF5282_GPIO_PFPAR (*(vuint8 *)(&__IPSBAR[0x100051]))
1477 #define MCF5282_GPIO_PEPAR (*(vuint16 *)(&__IPSBAR[0x100052]))
1478 #define MCF5282_GPIO_PJPAR (*(vuint8 *)(&__IPSBAR[0x100054]))
1479 #define MCF5282_GPIO_PSDPAR (*(vuint8 *)(&__IPSBAR[0x100055]))
1480 #define MCF5282_GPIO_PASPAR (*(vuint16 *)(&__IPSBAR[0x100056]))
1481 #define MCF5282_GPIO_PEHLPAR (*(vuint8 *)(&__IPSBAR[0x100058]))
1482 #define MCF5282_GPIO_PQSPAR (*(vuint8 *)(&__IPSBAR[0x100059]))
1483 #define MCF5282_GPIO_PTCPAR (*(vuint8 *)(&__IPSBAR[0x10005A]))
1484 #define MCF5282_GPIO_PTDPAR (*(vuint8 *)(&__IPSBAR[0x10005B]))
1485 #define MCF5282_GPIO_PUAPAR (*(vuint8 *)(&__IPSBAR[0x10005C]))
1486
1487 /* Bit level definitions and macros */
1488 #define MCF5282_GPIO_PORTx7 (0x80)
1489 #define MCF5282_GPIO_PORTx6 (0x40)
1490 #define MCF5282_GPIO_PORTx5 (0x20)
1491 #define MCF5282_GPIO_PORTx4 (0x10)
1492 #define MCF5282_GPIO_PORTx3 (0x08)
1493 #define MCF5282_GPIO_PORTx2 (0x04)
1494 #define MCF5282_GPIO_PORTx1 (0x02)
1495 #define MCF5282_GPIO_PORTx0 (0x01)
1496 #define MCF5282_GPIO_PORTx(x) (0x01<<(x))
1497
1498 #define MCF5282_GPIO_DDRx7 (0x80)
1499 #define MCF5282_GPIO_DDRx6 (0x40)
1500 #define MCF5282_GPIO_DDRx5 (0x20)
1501 #define MCF5282_GPIO_DDRx4 (0x10)
1502 #define MCF5282_GPIO_DDRx3 (0x08)
1503 #define MCF5282_GPIO_DDRx2 (0x04)
1504 #define MCF5282_GPIO_DDRx1 (0x02)
1505 #define MCF5282_GPIO_DDRx0 (0x01)
1506 #define MCF5282_GPIO_DDRx(x) (0x01<<(x))
1507
1508 #define MCF5282_GPIO_PORTxP7 (0x80)
1509 #define MCF5282_GPIO_PORTxP6 (0x40)
1510 #define MCF5282_GPIO_PORTxP5 (0x20)
1511 #define MCF5282_GPIO_PORTxP4 (0x10)
1512 #define MCF5282_GPIO_PORTxP3 (0x08)
1513 #define MCF5282_GPIO_PORTxP2 (0x04)
1514 #define MCF5282_GPIO_PORTxP1 (0x02)
1515 #define MCF5282_GPIO_PORTxP0 (0x01)
1516 #define MCF5282_GPIO_PORTxP(x) (0x01<<(x))
1517
1518 #define MCF5282_GPIO_SETx7 (0x80)
1519 #define MCF5282_GPIO_SETx6 (0x40)
1520 #define MCF5282_GPIO_SETx5 (0x20)
1521 #define MCF5282_GPIO_SETx4 (0x10)
1522 #define MCF5282_GPIO_SETx3 (0x08)
1523 #define MCF5282_GPIO_SETx2 (0x04)
1524 #define MCF5282_GPIO_SETx1 (0x02)
1525 #define MCF5282_GPIO_SETx0 (0x01)
1526 #define MCF5282_GPIO_SETx(x) (0x01<<(x))
1527
1528 #define MCF5282_GPIO_CLRx7 (0x80)
1529 #define MCF5282_GPIO_CLRx6 (0x40)
1530 #define MCF5282_GPIO_CLRx5 (0x20)
1531 #define MCF5282_GPIO_CLRx4 (0x10)
1532 #define MCF5282_GPIO_CLRx3 (0x08)
1533 #define MCF5282_GPIO_CLRx2 (0x04)
1534 #define MCF5282_GPIO_CLRx1 (0x02)
1535 #define MCF5282_GPIO_CLRx0 (0x01)
1536 #define MCF5282_GPIO_CLRx(x) (0x01<<(x))
1537
1538 #define MCF5282_GPIO_PBCDPAR_PBPA (0x80)
1539 #define MCF5282_GPIO_PBCDPAR_PCDPA (0x40)
1540
1541 #define MCF5282_GPIO_PEPAR_PEPA7 (0x4000)
1542 #define MCF5282_GPIO_PEPAR_PEPA6 (0x1000)
1543 #define MCF5282_GPIO_PEPAR_PEPA5 (0x0400)
1544 #define MCF5282_GPIO_PEPAR_PEPA4 (0x0100)
1545 #define MCF5282_GPIO_PEPAR_PEPA3 (0x0040)
1546 #define MCF5282_GPIO_PEPAR_PEPA2 (0x0010)
1547 #define MCF5282_GPIO_PEPAR_PEPA1(x) (((x)&0x3)<<2)
1548 #define MCF5282_GPIO_PEPAR_PEPA0(x) (((x)&0x3))
1549
1550 #define MCF5282_GPIO_PFPAR_PFPA7 (0x80)
1551 #define MCF5282_GPIO_PFPAR_PFPA6 (0x40)
1552 #define MCF5282_GPIO_PFPAR_PFPA5 (0x20)
1553
1554 #define MCF5282_GPIO_PJPAR_PJPA7 (0x80)
1555 #define MCF5282_GPIO_PJPAR_PJPA6 (0x40)
1556 #define MCF5282_GPIO_PJPAR_PJPA5 (0x20)
1557 #define MCF5282_GPIO_PJPAR_PJPA4 (0x10)
1558 #define MCF5282_GPIO_PJPAR_PJPA3 (0x08)
1559 #define MCF5282_GPIO_PJPAR_PJPA2 (0x04)
1560 #define MCF5282_GPIO_PJPAR_PJPA1 (0x02)
1561 #define MCF5282_GPIO_PJPAR_PJPA0 (0x01)
1562 #define MCF5282_GPIO_PJPAR_PJPA(x) (0x01<<(x))
1563
1564 #define MCF5282_GPIO_PSDPAR_PSDPA (0x80)
1565
1566 #define MCF5282_GPIO_PASPAR_PASPA5(x) (((x)&0x3)<<10)
1567 #define MCF5282_GPIO_PASPAR_PASPA4(x) (((x)&0x3)<<8)
1568 #define MCF5282_GPIO_PASPAR_PASPA3(x) (((x)&0x3)<<6)
1569 #define MCF5282_GPIO_PASPAR_PASPA2(x) (((x)&0x3)<<4)
1570 #define MCF5282_GPIO_PASPAR_PASPA1(x) (((x)&0x3)<<2)
1571 #define MCF5282_GPIO_PASPAR_PASPA0(x) (((x)&0x3))
1572
1573 #define MCF5282_GPIO_PEHLPAR_PEHPA (0x80)
1574 #define MCF5282_GPIO_PEHLPAR_PELPA (0x40)
1575
1576 #define MCF5282_GPIO_PQSPAR_PQSPA6 (0x40)
1577 #define MCF5282_GPIO_PQSPAR_PQSPA5 (0x20)
1578 #define MCF5282_GPIO_PQSPAR_PQSPA4 (0x10)
1579 #define MCF5282_GPIO_PQSPAR_PQSPA3 (0x08)
1580 #define MCF5282_GPIO_PQSPAR_PQSPA2 (0x04)
1581 #define MCF5282_GPIO_PQSPAR_PQSPA1 (0x02)
1582 #define MCF5282_GPIO_PQSPAR_PQSPA0 (0x01)
1583 #define MCF5282_GPIO_PQSPAR_PQSPA(x) (0x01<<(x))
1584
1585 #define MCF5282_GPIO_PTCPAR_PTCPA3(x) (((x)&0x3)<<6)
1586 #define MCF5282_GPIO_PTCPAR_PTCPA2(x) (((x)&0x3)<<4)
1587 #define MCF5282_GPIO_PTCPAR_PTCPA1(x) (((x)&0x3)<<2)
1588 #define MCF5282_GPIO_PTCPAR_PTCPA0(x) (((x)&0x3))
1589
1590 #define MCF5282_GPIO_PTDPAR_PTDPA3(x) (((x)&0x3)<<6)
1591 #define MCF5282_GPIO_PTDPAR_PTDPA2(x) (((x)&0x3)<<4)
1592 #define MCF5282_GPIO_PTDPAR_PTDPA1(x) (((x)&0x3)<<2)
1593 #define MCF5282_GPIO_PTDPAR_PTDPA0(x) (((x)&0x3))
1594
1595 #define MCF5282_GPIO_PUAPAR_PUAPA3 (0x08)
1596 #define MCF5282_GPIO_PUAPAR_PUAPA2 (0x04)
1597 #define MCF5282_GPIO_PUAPAR_PUAPA1 (0x02)
1598 #define MCF5282_GPIO_PUAPAR_PUAPA0 (0x01)
1599
1600 /*********************************************************************
1601 *
1602 * Reset Controller Module
1603 *
1604 *********************************************************************/
1605
1606 /* Read/Write access macros for general use */
1607 #define MCF5282_RESET_RCR (*(vuint8 *)(&__IPSBAR[0x110000]))
1608 #define MCF5282_RESET_RSR (*(vuint8 *)(&__IPSBAR[0x110001]))
1609
1610 /* Bit level definitions and macros */
1611 #define MCF5282_RESET_RCR_SOFTRST (0x80)
1612 #define MCF5282_RESET_RCR_FRCRSTOUT (0x40)
1613 #define MCF5282_RESET_RCR_LVDF (0x10)
1614 #define MCF5282_RESET_RCR_LVDIE (0x08)
1615 #define MCF5282_RESET_RCR_LVDRE (0x04)
1616 #define MCF5282_RESET_RCR_LVDE (0x01)
1617
1618 #define MCF5282_RESET_RSR_LVD (0x40)
1619 #define MCF5282_RESET_RSR_SOFT (0x20)
1620 #define MCF5282_RESET_RSR_WDR (0x10)
1621 #define MCF5282_RESET_RSR_POR (0x08)
1622 #define MCF5282_RESET_RSR_EXT (0x04)
1623 #define MCF5282_RESET_RSR_LOC (0x02)
1624 #define MCF5282_RESET_RSR_LOL (0x01)
1625
1626 /*********************************************************************
1627 *
1628 * Chip Configuration Module (CCM)
1629 *
1630 *********************************************************************/
1631
1632 /* Read/Write access macros for general use */
1633 #define MCF5282_CCM_CCR (*(vuint16 *)(&__IPSBAR[0x110004]))
1634 #define MCF5282_CCM_RCON (*(vuint16 *)(&__IPSBAR[0x110008]))
1635 #define MCF5282_CCM_CIR (*(vuint16 *)(&__IPSBAR[0x11000A]))
1636
1637 /* Bit level definitions and macros */
1638 #define MCF5282_CCM_CCR_LOAD (0x8000)
1639 #define MCF5282_CCM_CCR_MODE(x) (((x)&0x0007)<<8)
1640 #define MCF5282_CCM_CCR_SZEN (0x0040)
1641 #define MCF5282_CCM_CCR_PSTEN (0x0020)
1642 #define MCF5282_CCM_CCR_BME (0x0008)
1643 #define MCF5282_CCM_CCR_BMT(x) (((x)&0x0007))
1644
1645 /*********************************************************************
1646 *
1647 * Power Management Module (PMM)
1648 *
1649 *********************************************************************/
1650
1651 /* Read/Write access macros for general use */
1652 #define MCF5282_PMM_LPICR (*(vuint8 *)(&__IPSBAR[0x000012]))
1653 #define MCF5282_PMM_LPCR (*(vuint8 *)(&__IPSBAR[0x110007]))
1654
1655 /* Bit level definitions and macros */
1656 #define MCF5282_PMM_LPICR_ENBSTOP (0x80)
1657 #define MCF5282_PMM_LPICR_XLMP_IPL(x) (((x)&0x07)<<4)
1658
1659 #define MCF5282_PMM_LPCR_LPMD_STOP (0xC0)
1660 #define MCF5282_PMM_LPCR_LPMD_WAIT (0x80)
1661 #define MCF5282_PMM_LPCR_LPMD_DOZE (0x40)
1662 #define MCF5282_PMM_LPCR_LPMD_RUN (0x00)
1663 #define MCF5282_PMM_LPCR_STPMD(x) (((x)&0x03)<<3)
1664 #define MCF5282_PMM_LPCR_LVDSE (0x02)
1665
1666 /*********************************************************************
1667 *
1668 * Clock Module
1669 *
1670 *********************************************************************/
1671
1672 /* Read/Write access macros for general use */
1673 #define MCF5282_CLOCK_SYNCR (*(vuint16 *)(&__IPSBAR[0x120000]))
1674 #define MCF5282_CLOCK_SYNSR (*(vuint8 *)(&__IPSBAR[0x120002]))
1675
1676 /* Bit level definitions and macros */
1677 #define MCF5282_CLOCK_SYNCR_LOLRE (0x8000)
1678 #define MCF5282_CLOCK_SYNCR_MFD(x) (((x)&0x0007)<<12)
1679 #define MCF5282_CLOCK_SYNCR_LOCRE (0x0800)
1680 #define MCF5282_CLOCK_SYNCR_RFD(x) (((x)&0x0007)<<8)
1681 #define MCF5282_CLOCK_SYNCR_LOCEN (0x0080)
1682 #define MCF5282_CLOCK_SYNCR_DISCLK (0x0040)
1683 #define MCF5282_CLOCK_SYNCR_FWKUP (0x0020)
1684 #define MCF5282_CLOCK_SYNCR_STPMD(x) (((x)&0x0003)<<2)
1685
1686 #define MCF5282_CLOCK_SYNSR_PLLMODE (0x80)
1687 #define MCF5282_CLOCK_SYNSR_PLLSEL (0x40)
1688 #define MCF5282_CLOCK_SYNSR_PLLREF (0x20)
1689 #define MCF5282_CLOCK_SYNSR_LOCKS (0x10)
1690 #define MCF5282_CLOCK_SYNSR_LOCK (0x08)
1691 #define MCF5282_CLOCK_SYNSR_LOCS (0x04)
1692
1693 /*********************************************************************
1694 *
1695 * Edge Port (EPORT) Module
1696 *
1697 *********************************************************************/
1698
1699 /* Read/Write access macros for general use */
1700 #define MCF5282_EPORT_EPPAR (*(vuint16 *)(&__IPSBAR[0x130000]))
1701 #define MCF5282_EPORT_EPDDR (*(vuint8 *)(&__IPSBAR[0x130002]))
1702 #define MCF5282_EPORT_EPIER (*(vuint8 *)(&__IPSBAR[0x130003]))
1703 #define MCF5282_EPORT_EPDR (*(vuint8 *)(&__IPSBAR[0x130004]))
1704 #define MCF5282_EPORT_EPPDR (*(vuint8 *)(&__IPSBAR[0x130005]))
1705 #define MCF5282_EPORT_EPFR (*(vuint8 *)(&__IPSBAR[0x130006]))
1706
1707 /* Bit level definitions and macros */
1708 #define MCF5282_EPORT_EPPAR_EPPA7_LEVEL (0x0000)
1709 #define MCF5282_EPORT_EPPAR_EPPA7_RISING (0x4000)
1710 #define MCF5282_EPORT_EPPAR_EPPA7_FALLING (0x8000)
1711 #define MCF5282_EPORT_EPPAR_EPPA7_BOTHEDGE (0xC000)
1712 #define MCF5282_EPORT_EPPAR_EPPA6_LEVEL (0x0000)
1713 #define MCF5282_EPORT_EPPAR_EPPA6_RISING (0x1000)
1714 #define MCF5282_EPORT_EPPAR_EPPA6_FALLING (0x2000)
1715 #define MCF5282_EPORT_EPPAR_EPPA6_BOTHEDGE (0x3000)
1716 #define MCF5282_EPORT_EPPAR_EPPA5_LEVEL (0x0000)
1717 #define MCF5282_EPORT_EPPAR_EPPA5_RISING (0x0400)
1718 #define MCF5282_EPORT_EPPAR_EPPA5_FALLING (0x0800)
1719 #define MCF5282_EPORT_EPPAR_EPPA5_BOTHEDGE (0x0C00)
1720 #define MCF5282_EPORT_EPPAR_EPPA4_LEVEL (0x0000)
1721 #define MCF5282_EPORT_EPPAR_EPPA4_RISING (0x0100)
1722 #define MCF5282_EPORT_EPPAR_EPPA4_FALLING (0x0200)
1723 #define MCF5282_EPORT_EPPAR_EPPA4_BOTHEDGE (0x0300)
1724 #define MCF5282_EPORT_EPPAR_EPPA3_LEVEL (0x0000)
1725 #define MCF5282_EPORT_EPPAR_EPPA3_RISING (0x0040)
1726 #define MCF5282_EPORT_EPPAR_EPPA3_FALLING (0x0080)
1727 #define MCF5282_EPORT_EPPAR_EPPA3_BOTHEDGE (0x00C0)
1728 #define MCF5282_EPORT_EPPAR_EPPA2_LEVEL (0x0000)
1729 #define MCF5282_EPORT_EPPAR_EPPA2_RISING (0x0010)
1730 #define MCF5282_EPORT_EPPAR_EPPA2_FALLING (0x0020)
1731 #define MCF5282_EPORT_EPPAR_EPPA2_BOTHEDGE (0x0030)
1732 #define MCF5282_EPORT_EPPAR_EPPA1_LEVEL (0x0000)
1733 #define MCF5282_EPORT_EPPAR_EPPA1_RISING (0x0004)
1734 #define MCF5282_EPORT_EPPAR_EPPA1_FALLING (0x0008)
1735 #define MCF5282_EPORT_EPPAR_EPPA1_BOTHEDGE (0x000C)
1736
1737
1738 #define MCF5282_EPORT_EPDDR_EPDD7 (0x80)
1739 #define MCF5282_EPORT_EPDDR_EPDD6 (0x40)
1740 #define MCF5282_EPORT_EPDDR_EPDD5 (0x20)
1741 #define MCF5282_EPORT_EPDDR_EPDD4 (0x10)
1742 #define MCF5282_EPORT_EPDDR_EPDD3 (0x08)
1743 #define MCF5282_EPORT_EPDDR_EPDD2 (0x04)
1744 #define MCF5282_EPORT_EPDDR_EPDD1 (0x02)
1745 #define MCF5282_EPORT_EPDDR_EPDD(x) (0x01<<(x))
1746
1747 #define MCF5282_EPORT_EPIER_EPIE7 (0x80)
1748 #define MCF5282_EPORT_EPIER_EPIE6 (0x40)
1749 #define MCF5282_EPORT_EPIER_EPIE5 (0x20)
1750 #define MCF5282_EPORT_EPIER_EPIE4 (0x10)
1751 #define MCF5282_EPORT_EPIER_EPIE3 (0x08)
1752 #define MCF5282_EPORT_EPIER_EPIE2 (0x04)
1753 #define MCF5282_EPORT_EPIER_EPIE1 (0x02)
1754 #define MCF5282_EPORT_EPIER_EPIE(x) (0x01<<(x))
1755
1756 #define MCF5282_EPORT_EPDR_EPD7 (0x80)
1757 #define MCF5282_EPORT_EPDR_EPD6 (0x40)
1758 #define MCF5282_EPORT_EPDR_EPD5 (0x20)
1759 #define MCF5282_EPORT_EPDR_EPD4 (0x10)
1760 #define MCF5282_EPORT_EPDR_EPD3 (0x08)
1761 #define MCF5282_EPORT_EPDR_EPD2 (0x04)
1762 #define MCF5282_EPORT_EPDR_EPD1 (0x02)
1763 #define MCF5282_EPORT_EPDR_EPD(x) (0x01<<(x))
1764
1765 #define MCF5282_EPORT_EPPDR_EPPD7 (0x80)
1766 #define MCF5282_EPORT_EPPDR_EPPD6 (0x40)
1767 #define MCF5282_EPORT_EPPDR_EPPD5 (0x20)
1768 #define MCF5282_EPORT_EPPDR_EPPD4 (0x10)
1769 #define MCF5282_EPORT_EPPDR_EPPD3 (0x08)
1770 #define MCF5282_EPORT_EPPDR_EPPD2 (0x04)
1771 #define MCF5282_EPORT_EPPDR_EPPD1 (0x02)
1772 #define MCF5282_EPORT_EPPDR_EPPD(x) (0x01<<(x))
1773
1774 #define MCF5282_EPORT_EPFR_EPF7 (0x80)
1775 #define MCF5282_EPORT_EPFR_EPF6 (0x40)
1776 #define MCF5282_EPORT_EPFR_EPF5 (0x20)
1777 #define MCF5282_EPORT_EPFR_EPF4 (0x10)
1778 #define MCF5282_EPORT_EPFR_EPF3 (0x08)
1779 #define MCF5282_EPORT_EPFR_EPF2 (0x04)
1780 #define MCF5282_EPORT_EPFR_EPF1 (0x02)
1781 #define MCF5282_EPORT_EPFR_EPF(x) (0x01<<(x))
1782
1783 /*********************************************************************
1784 *
1785 * Watchdog Timer Module (WTM)
1786 *
1787 *********************************************************************/
1788
1789 /* Read/Write access macros for general use */
1790 #define MCF5282_WTM_WCR (*(vuint16 *)(&__IPSBAR[0x140000]))
1791 #define MCF5282_WTM_WMR (*(vuint16 *)(&__IPSBAR[0x140002]))
1792 #define MCF5282_WTM_WCNTR (*(vuint16 *)(&__IPSBAR[0x140004]))
1793 #define MCF5282_WTM_WSR (*(vuint16 *)(&__IPSBAR[0x140006]))
1794
1795 /* Bit level definitions and macros */
1796 #define MCF5282_WTM_WCR_WAIT (0x0008)
1797 #define MCF5282_WTM_WCR_DOZE (0x0004)
1798 #define MCF5282_WTM_WCR_HALTED (0x0002)
1799 #define MCF5282_WTM_WCR_EN (0x0001)
1800
1801 #define MCF5282_WTM_WSR_SEQ1 (0x5555)
1802 #define MCF5282_WTM_WSR_SEQ2 (0xAAAA)
1803
1804 /*********************************************************************
1805 *
1806 * Programmable Interrupt Timer (PIT) Module
1807 *
1808 *********************************************************************/
1809
1810 /* Read/Write access macros for general use */
1811 #define MCF5282_PIT0_PCSR (*(vuint16 *)(&__IPSBAR[0x150000]))
1812 #define MCF5282_PIT0_PMR (*(vuint16 *)(&__IPSBAR[0x150002]))
1813 #define MCF5282_PIT0_PCNTR (*(vuint16 *)(&__IPSBAR[0x150004]))
1814
1815 #define MCF5282_PIT1_PCSR (*(vuint16 *)(&__IPSBAR[0x160000]))
1816 #define MCF5282_PIT1_PMR (*(vuint16 *)(&__IPSBAR[0x160002]))
1817 #define MCF5282_PIT1_PCNTR (*(vuint16 *)(&__IPSBAR[0x160004]))
1818
1819 #define MCF5282_PIT2_PCSR (*(vuint16 *)(&__IPSBAR[0x170000]))
1820 #define MCF5282_PIT2_PMR (*(vuint16 *)(&__IPSBAR[0x170002]))
1821 #define MCF5282_PIT2_PCNTR (*(vuint16 *)(&__IPSBAR[0x170004]))
1822
1823 #define MCF5282_PIT3_PCSR (*(vuint16 *)(&__IPSBAR[0x180000]))
1824 #define MCF5282_PIT3_PMR (*(vuint16 *)(&__IPSBAR[0x180002]))
1825 #define MCF5282_PIT3_PCNTR (*(vuint16 *)(&__IPSBAR[0x180004]))
1826
1827 #define MCF5282_PIT_PCSR(x) (*(vuint16 *)(&__IPSBAR[0x150000+(0x1000*(x))]))
1828 #define MCF5282_PIT_PMR(x) (*(vuint16 *)(&__IPSBAR[0x150002+(0x1000*(x))]))
1829 #define MCF5282_PIT_PCNTR(x) (*(vuint16 *)(&__IPSBAR[0x150004+(0x1000*(x))]))
1830
1831 /* Bit level definitions and macros */
1832 #define MCF5282_PIT_PCSR_PRE(x) (((x)&0x000F)<<8)
1833 #define MCF5282_PIT_PCSR_DOZE (0x0040)
1834 #define MCF5282_PIT_PCSR_HALTED (0x0020)
1835 #define MCF5282_PIT_PCSR_OVW (0x0010)
1836 #define MCF5282_PIT_PCSR_PIE (0x0008)
1837 #define MCF5282_PIT_PCSR_PIF (0x0004)
1838 #define MCF5282_PIT_PCSR_RLD (0x0002)
1839 #define MCF5282_PIT_PCSR_EN (0x0001)
1840
1841 /*********************************************************************
1842 *
1843 * Queued Analog to Digital Converter (QADC) Module
1844 *
1845 *********************************************************************/
1846
1847 /* Read/Write access macros for general use */
1848 #define MCF5282_QADC_QADCMCR (*(vuint16 *)(&__IPSBAR[0x190000]))
1849 #define MCF5282_QADC_PORTQA (*(vuint8 *)(&__IPSBAR[0x190006]))
1850 #define MCF5282_QADC_PORTQB (*(vuint8 *)(&__IPSBAR[0x190007]))
1851 #define MCF5282_QADC_DDRQA (*(vuint8 *)(&__IPSBAR[0x190008]))
1852 #define MCF5282_QADC_DDRQB (*(vuint8 *)(&__IPSBAR[0x190009]))
1853 #define MCF5282_QADC_QACR0 (*(vuint16 *)(&__IPSBAR[0x19000A]))
1854 #define MCF5282_QADC_QACR1 (*(vuint16 *)(&__IPSBAR[0x19000C]))
1855 #define MCF5282_QADC_QACR2 (*(vuint16 *)(&__IPSBAR[0x19000E]))
1856 #define MCF5282_QADC_QASR0 (*(vuint16 *)(&__IPSBAR[0x190010]))
1857 #define MCF5282_QADC_QASR1 (*(vuint16 *)(&__IPSBAR[0x190012]))
1858 #define MCF5282_QADC_CCW(x) (*(vuint16 *)(&__IPSBAR[0x190200+((x)*2)]))
1859 #define MCF5282_QADC_RJURR(x) (*(vuint16 *)(&__IPSBAR[0x190280+((x)*2)]))
1860 #define MCF5282_QADC_LJSRR(x) (*(vuint16 *)(&__IPSBAR[0x190300+((x)*2)]))
1861 #define MCF5282_QADC_LJURR(x) (*(vuint16 *)(&__IPSBAR[0x190380+((x)*2)]))
1862
1863 /* Bit level definitions and macros */
1864 #define MCF5282_QADC_QADCMCR_QSTOP (0x8000)
1865 #define MCF5282_QADC_QADCMCR_QDBG (0x4000)
1866 #define MCF5282_QADC_QADCMCR_SUPV (0x0080)
1867
1868 #define MCF5282_QADC_PORTQA_PQA4 (0x10)
1869 #define MCF5282_QADC_PORTQA_PQA3 (0x08)
1870 #define MCF5282_QADC_PORTQA_PQA1 (0x02)
1871 #define MCF5282_QADC_PORTQA_PQA0 (0x01)
1872 #define MCF5282_QADC_PORTQA_AN56 (0x10)
1873 #define MCF5282_QADC_PORTQA_AN55 (0x08)
1874 #define MCF5282_QADC_PORTQA_ETRIG2 (0x10)
1875 #define MCF5282_QADC_PORTQA_ETRIG1 (0x08)
1876 #define MCF5282_QADC_PORTQA_AN53 (0x02)
1877 #define MCF5282_QADC_PORTQA_AN52 (0x01)
1878 #define MCF5282_QADC_PORTQA_MA1 (0x02)
1879 #define MCF5282_QADC_PORTQA_MA0 (0x01)
1880
1881 #define MCF5282_QADC_PORTQB_PQB3 (0x08)
1882 #define MCF5282_QADC_PORTQB_PQB2 (0x04)
1883 #define MCF5282_QADC_PORTQB_PQB1 (0x02)
1884 #define MCF5282_QADC_PORTQB_PQB0 (0x01)
1885 #define MCF5282_QADC_PORTQB_AN3 (0x08)
1886 #define MCF5282_QADC_PORTQB_AN2 (0x04)
1887 #define MCF5282_QADC_PORTQB_AN1 (0x02)
1888 #define MCF5282_QADC_PORTQB_AN0 (0x01)
1889 #define MCF5282_QADC_PORTQB_ANZ (0x08)
1890 #define MCF5282_QADC_PORTQB_ANY (0x04)
1891 #define MCF5282_QADC_PORTQB_ANX (0x02)
1892 #define MCF5282_QADC_PORTQB_ANW (0x01)
1893
1894 #define MCF5282_QADC_DDRQA_DDQA4 (0x10)
1895 #define MCF5282_QADC_DDRQA_DDQA3 (0x08)
1896 #define MCF5282_QADC_DDRQA_DDQA1 (0x02)
1897 #define MCF5282_QADC_DDRQA_DDQA0 (0x01)
1898
1899 #define MCF5282_QADC_DDRQB_DDQB3 (0x08)
1900 #define MCF5282_QADC_DDRQB_DDQB2 (0x04)
1901 #define MCF5282_QADC_DDRQB_DDQB1 (0x02)
1902 #define MCF5282_QADC_DDRQB_DDQB0 (0x01)
1903
1904 #define MCF5282_QADC_QACR0_MUX (0x8000)
1905 #define MCF5282_QADC_QACR0_TRG (0x1000)
1906 #define MCF5282_QADC_QACR0_QPR(x) (((x)&0x007F))
1907
1908 #define MCF5282_QADC_QACRx_CIE (0x8000)
1909 #define MCF5282_QADC_QACRx_PIE (0x4000)
1910 #define MCF5282_QADC_QACRx_SSE (0x2000)
1911 #define MCF5282_QADC_QACRx_MQ(x) (((x)&0x001F)<<8)
1912 #define MCF5282_QADC_QACRx_RESUME (0x0080)
1913 #define MCF5282_QADC_QACRx_BQ(x) (((x)&0x007F))
1914
1915 #define MCF5282_QADC_QASR0_CF1 (0x8000)
1916 #define MCF5282_QADC_QASR0_PF1 (0x4000)
1917 #define MCF5282_QADC_QASR0_CF2 (0x2000)
1918 #define MCF5282_QADC_QASR0_PF2 (0x1000)
1919 #define MCF5282_QADC_QASR0_TOR1 (0x0800)
1920 #define MCF5282_QADC_QASR0_TOR2 (0x0400)
1921
1922 #define MCF5282_QADC_CCW_P (0x0200)
1923 #define MCF5282_QADC_CCW_BYP (0x0100)
1924 #define MCF5282_QADC_CCW_IST(x) (((x)&0x0003)<<14)
1925 #define MCF5282_QADC_CCW_CHAN(x) (((x)&0x003F))
1926
1927 /*********************************************************************
1928 *
1929 * General Purpose Timer (GPT) Module
1930 *
1931 *********************************************************************/
1932
1933 /* Read/Write access macros for general use */
1934 #define MCF5282_GPTA_GPTIOS (*(vuint8 *)(&__IPSBAR[0x1A0000]))
1935 #define MCF5282_GPTA_GPTCFORC (*(vuint8 *)(&__IPSBAR[0x1A0001]))
1936 #define MCF5282_GPTA_GPTOC3M (*(vuint8 *)(&__IPSBAR[0x1A0002]))
1937 #define MCF5282_GPTA_GPTOC3D (*(vuint8 *)(&__IPSBAR[0x1A0003]))
1938 #define MCF5282_GPTA_GPTCNT (*(vuint16 *)(&__IPSBAR[0x1A0004]))
1939 #define MCF5282_GPTA_GPTSCR1 (*(vuint8 *)(&__IPSBAR[0x1A0006]))
1940 #define MCF5282_GPTA_GPTTOV (*(vuint8 *)(&__IPSBAR[0x1A0008]))
1941 #define MCF5282_GPTA_GPTCTL1 (*(vuint8 *)(&__IPSBAR[0x1A0009]))
1942 #define MCF5282_GPTA_GPTCTL2 (*(vuint8 *)(&__IPSBAR[0x1A000B]))
1943 #define MCF5282_GPTA_GPTIE (*(vuint8 *)(&__IPSBAR[0x1A000C]))
1944 #define MCF5282_GPTA_GPTSCR2 (*(vuint8 *)(&__IPSBAR[0x1A000D]))
1945 #define MCF5282_GPTA_GPTFLG1 (*(vuint8 *)(&__IPSBAR[0x1A000E]))
1946 #define MCF5282_GPTA_GPTFLG2 (*(vuint8 *)(&__IPSBAR[0x1A000F]))
1947 #define MCF5282_GPTA_GPTC0 (*(vuint16 *)(&__IPSBAR[0x1A0010]))
1948 #define MCF5282_GPTA_GPTC1 (*(vuint16 *)(&__IPSBAR[0x1A0012]))
1949 #define MCF5282_GPTA_GPTC2 (*(vuint16 *)(&__IPSBAR[0x1A0014]))
1950 #define MCF5282_GPTA_GPTC3 (*(vuint16 *)(&__IPSBAR[0x1A0016]))
1951 #define MCF5282_GPTA_GPTPACTL (*(vuint8 *)(&__IPSBAR[0x1A0018]))
1952 #define MCF5282_GPTA_GPTPAFLG (*(vuint8 *)(&__IPSBAR[0x1A0019]))
1953 #define MCF5282_GPTA_GPTPACNT (*(vuint16 *)(&__IPSBAR[0x1A001A]))
1954 #define MCF5282_GPTA_GPTPORT (*(vuint8 *)(&__IPSBAR[0x1A001D]))
1955 #define MCF5282_GPTA_GPTDDR (*(vuint8 *)(&__IPSBAR[0x1A001E]))
1956
1957 #define MCF5282_GPTB_GPTIOS (*(vuint8 *)(&__IPSBAR[0x1B0000]))
1958 #define MCF5282_GPTB_GPTCFORC (*(vuint8 *)(&__IPSBAR[0x1B0001]))
1959 #define MCF5282_GPTB_GPTOC3M (*(vuint8 *)(&__IPSBAR[0x1B0002]))
1960 #define MCF5282_GPTB_GPTOC3D (*(vuint8 *)(&__IPSBAR[0x1B0003]))
1961 #define MCF5282_GPTB_GPTCNT (*(vuint16 *)(&__IPSBAR[0x1B0004]))
1962 #define MCF5282_GPTB_GPTSCR1 (*(vuint8 *)(&__IPSBAR[0x1B0006]))
1963 #define MCF5282_GPTB_GPTTOV (*(vuint8 *)(&__IPSBAR[0x1B0008]))
1964 #define MCF5282_GPTB_GPTCTL1 (*(vuint8 *)(&__IPSBAR[0x1B0009]))
1965 #define MCF5282_GPTB_GPTCTL2 (*(vuint8 *)(&__IPSBAR[0x1B000B]))
1966 #define MCF5282_GPTB_GPTIE (*(vuint8 *)(&__IPSBAR[0x1B000C]))
1967 #define MCF5282_GPTB_GPTSCR2 (*(vuint8 *)(&__IPSBAR[0x1B000D]))
1968 #define MCF5282_GPTB_GPTFLG1 (*(vuint8 *)(&__IPSBAR[0x1B000E]))
1969 #define MCF5282_GPTB_GPTFLG2 (*(vuint8 *)(&__IPSBAR[0x1B000F]))
1970 #define MCF5282_GPTB_GPTC0 (*(vuint16 *)(&__IPSBAR[0x1B0010]))
1971 #define MCF5282_GPTB_GPTC1 (*(vuint16 *)(&__IPSBAR[0x1B0012]))
1972 #define MCF5282_GPTB_GPTC2 (*(vuint16 *)(&__IPSBAR[0x1B0014]))
1973 #define MCF5282_GPTB_GPTC3 (*(vuint16 *)(&__IPSBAR[0x1B0016]))
1974 #define MCF5282_GPTB_GPTPACTL (*(vuint8 *)(&__IPSBAR[0x1B0018]))
1975 #define MCF5282_GPTB_GPTPAFLG (*(vuint8 *)(&__IPSBAR[0x1B0019]))
1976 #define MCF5282_GPTB_GPTPACNT (*(vuint16 *)(&__IPSBAR[0x1B001A]))
1977 #define MCF5282_GPTB_GPTPORT (*(vuint8 *)(&__IPSBAR[0x1B001D]))
1978 #define MCF5282_GPTB_GPTDDR (*(vuint8 *)(&__IPSBAR[0x1B001E]))
1979
1980 /* Bit level definitions and macros */
1981 #define MCF5282_GPT_GPTIOS_IOS3 (0x08)
1982 #define MCF5282_GPT_GPTIOS_IOS2 (0x04)
1983 #define MCF5282_GPT_GPTIOS_IOS1 (0x02)
1984 #define MCF5282_GPT_GPTIOS_IOS0 (0x01)
1985
1986 #define MCF5282_GPT_GPTCFORC_FOC3 (0x08)
1987 #define MCF5282_GPT_GPTCFORC_FOC2 (0x04)
1988 #define MCF5282_GPT_GPTCFORC_FOC1 (0x02)
1989 #define MCF5282_GPT_GPTCFORC_FOC0 (0x01)
1990
1991 #define MCF5282_GPT_GPTOC3M_OC3M3 (0x08)
1992 #define MCF5282_GPT_GPTOC3M_OC3M2 (0x04)
1993 #define MCF5282_GPT_GPTOC3M_OC3M1 (0x02)
1994 #define MCF5282_GPT_GPTOC3M_OC3M0 (0x01)
1995
1996 #define MCF5282_GPT_GPTOC3M_OC3D(x) (((x)&0x04))
1997
1998 #define MCF5282_GPT_GPTSCR1_GPTEN (0x80)
1999 #define MCF5282_GPT_GPTSCR1_TFFCA (0x10)
2000
2001 #define MCF5282_GPT_GPTTOV3 (0x08)
2002 #define MCF5282_GPT_GPTTOV2 (0x04)
2003 #define MCF5282_GPT_GPTTOV1 (0x02)
2004 #define MCF5282_GPT_GPTTOV0 (0x01)
2005
2006 #define MCF5282_GPT_GPTCTL_OMOL3(x) (((x)&0x03)<<6)
2007 #define MCF5282_GPT_GPTCTL_OMOL2(x) (((x)&0x03)<<4)
2008 #define MCF5282_GPT_GPTCTL_OMOL1(x) (((x)&0x03)<<2)
2009 #define MCF5282_GPT_GPTCTL_OMOL0(x) (((x)&0x03))
2010
2011 #define MCF5282_GPT_GPTCTL2_EDG3(x) (((x)&0x03)<<6)
2012 #define MCF5282_GPT_GPTCTL2_EDG2(x) (((x)&0x03)<<4)
2013 #define MCF5282_GPT_GPTCTL2_EDG1(x) (((x)&0x03)<<2)
2014 #define MCF5282_GPT_GPTCTL2_EDG0(x) (((x)&0x03))
2015
2016 #define MCF5282_GPT_GPTIE_C3I (0x08)
2017 #define MCF5282_GPT_GPTIE_C2I (0x04)
2018 #define MCF5282_GPT_GPTIE_C1I (0x02)
2019 #define MCF5282_GPT_GPTIE_C0I (0x01)
2020
2021 #define MCF5282_GPT_GPTSCR2_TOI (0x80)
2022 #define MCF5282_GPT_GPTSCR2_PUPT (0x20)
2023 #define MCF5282_GPT_GPTSCR2_RDPT (0x10)
2024 #define MCF5282_GPT_GPTSCR2_TCRE (0x08)
2025 #define MCF5282_GPT_GPTSCR2_PR(x) (((x)&0x07))
2026
2027 #define MCF5282_GPT_GPTFLG1_C3F (0x08)
2028 #define MCF5282_GPT_GPTFLG1_C2F (0x04)
2029 #define MCF5282_GPT_GPTFLG1_C1F (0x02)
2030 #define MCF5282_GPT_GPTFLG1_C0F (0x01)
2031
2032 #define MCF5282_GPT_GPTFLG2_TOF (0x80)
2033 #define MCF5282_GPT_GPTFLG2_C3F (0x08)
2034 #define MCF5282_GPT_GPTFLG2_C2F (0x04)
2035 #define MCF5282_GPT_GPTFLG2_C1F (0x02)
2036 #define MCF5282_GPT_GPTFLG2_C0F (0x01)
2037
2038 #define MCF5282_GPT_GPTPACTL_PAE (0x40)
2039 #define MCF5282_GPT_GPTPACTL_PAMOD (0x20)
2040 #define MCF5282_GPT_GPTPACTL_PEDGE (0x10)
2041 #define MCF5282_GPT_GPTPACTL_CLK_PACLK (0x04)
2042 #define MCF5282_GPT_GPTPACTL_CLK_PACLK256 (0x08)
2043 #define MCF5282_GPT_GPTPACTL_CLK_PACLK65536 (0x0C)
2044 #define MCF5282_GPT_GPTPACTL_CLK(x) (((x)&0x03)<<2)
2045 #define MCF5282_GPT_GPTPACTL_PAOVI (0x02)
2046 #define MCF5282_GPT_GPTPACTL_PAI (0x01)
2047
2048 #define MCF5282_GPT_GPTPAFLG_PAOVF (0x02)
2049 #define MCF5282_GPT_GPTPAFLG_PAIF (0x01)
2050
2051 #define MCF5282_GPT_GPTPORT_PORTT3 (0x08)
2052 #define MCF5282_GPT_GPTPORT_PORTT2 (0x04)
2053 #define MCF5282_GPT_GPTPORT_PORTT1 (0x02)
2054 #define MCF5282_GPT_GPTPORT_PORTT0 (0x01)
2055
2056 #define MCF5282_GPT_GPTDDR_DDRT3 (0x08)
2057 #define MCF5282_GPT_GPTDDR_DDRT2 (0x04)
2058 #define MCF5282_GPT_GPTDDR_DDRT1 (0x02)
2059 #define MCF5282_GPT_GPTDDR_DDRT0 (0x01)
2060
2061 /*********************************************************************
2062 *
2063 * FlexCAN Module
2064 *
2065 *********************************************************************/
2066
2067 /* Read/Write access macros for general use */
2068 #define MCF5282_FLEXCAN_CANMCR (*(vuint16 *)(&__IPSBAR[0x1C0000]))
2069 #define MCF5282_FLEXCAN_CANCTRL0 (*(vuint8 *)(&__IPSBAR[0x1C0006]))
2070 #define MCF5282_FLEXCAN_CANCTRL1 (*(vuint8 *)(&__IPSBAR[0x1C0007]))
2071 #define MCF5282_FLEXCAN_PRESDIV (*(vuint8 *)(&__IPSBAR[0x1C0008]))
2072 #define MCF5282_FLEXCAN_CANCTRL2 (*(vuint8 *)(&__IPSBAR[0x1C0009]))
2073 #define MCF5282_FLEXCAN_TIMER (*(vuint16 *)(&__IPSBAR[0x1C000A]))
2074 #define MCF5282_FLEXCAN_RXGMASK (*(vuint32 *)(&__IPSBAR[0x1C0010]))
2075 #define MCF5282_FLEXCAN_RX14MASK (*(vuint32 *)(&__IPSBAR[0x1C0014]))
2076 #define MCF5282_FLEXCAN_RX15MASK (*(vuint32 *)(&__IPSBAR[0x1C0018]))
2077 #define MCF5282_FLEXCAN_ESTAT (*(vuint16 *)(&__IPSBAR[0x1C0020]))
2078 #define MCF5282_FLEXCAN_IMASK (*(vuint16 *)(&__IPSBAR[0x1C0022]))
2079 #define MCF5282_FLEXCAN_IFLAG (*(vuint16 *)(&__IPSBAR[0x1C0024]))
2080 #define MCF5282_FLEXCAN_RXECTR (*(vuint8 *)(&__IPSBAR[0x1C0026]))
2081 #define MCF5282_FLEXCAN_TXECTR (*(vuint8 *)(&__IPSBAR[0x1C0027]))
2082 #define MCF5282_FLEXCAN_MBUF0_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0081]))
2083 #define MCF5282_FLEXCAN_MBUF0_IDH (*(vuint16 *)(&__IPSBAR[0x1C0082]))
2084 #define MCF5282_FLEXCAN_MBUF0_IDL (*(vuint16 *)(&__IPSBAR[0x1C0084]))
2085 #define MCF5282_FLEXCAN_MBUF0_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0086]))
2086 #define MCF5282_FLEXCAN_MBUF0_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0087]))
2087 #define MCF5282_FLEXCAN_MBUF0_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0088]))
2088 #define MCF5282_FLEXCAN_MBUF0_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0089]))
2089 #define MCF5282_FLEXCAN_MBUF0_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C008A]))
2090 #define MCF5282_FLEXCAN_MBUF0_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C008B]))
2091 #define MCF5282_FLEXCAN_MBUF0_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C008C]))
2092 #define MCF5282_FLEXCAN_MBUF0_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C008D]))
2093 #define MCF5282_FLEXCAN_MBUF1_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0091]))
2094 #define MCF5282_FLEXCAN_MBUF1_IDH (*(vuint16 *)(&__IPSBAR[0x1C0092]))
2095 #define MCF5282_FLEXCAN_MBUF1_IDL (*(vuint16 *)(&__IPSBAR[0x1C0094]))
2096 #define MCF5282_FLEXCAN_MBUF1_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0096]))
2097 #define MCF5282_FLEXCAN_MBUF1_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0097]))
2098 #define MCF5282_FLEXCAN_MBUF1_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0098]))
2099 #define MCF5282_FLEXCAN_MBUF1_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0099]))
2100 #define MCF5282_FLEXCAN_MBUF1_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C009A]))
2101 #define MCF5282_FLEXCAN_MBUF1_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C009B]))
2102 #define MCF5282_FLEXCAN_MBUF1_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C009C]))
2103 #define MCF5282_FLEXCAN_MBUF1_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C009D]))
2104 #define MCF5282_FLEXCAN_MBUF2_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00A1]))
2105 #define MCF5282_FLEXCAN_MBUF2_IDH (*(vuint16 *)(&__IPSBAR[0x1C00A2]))
2106 #define MCF5282_FLEXCAN_MBUF2_IDL (*(vuint16 *)(&__IPSBAR[0x1C00A4]))
2107 #define MCF5282_FLEXCAN_MBUF2_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00A6]))
2108 #define MCF5282_FLEXCAN_MBUF2_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00A7]))
2109 #define MCF5282_FLEXCAN_MBUF2_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00A8]))
2110 #define MCF5282_FLEXCAN_MBUF2_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00A9]))
2111 #define MCF5282_FLEXCAN_MBUF2_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00AA]))
2112 #define MCF5282_FLEXCAN_MBUF2_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00AB]))
2113 #define MCF5282_FLEXCAN_MBUF2_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00AC]))
2114 #define MCF5282_FLEXCAN_MBUF2_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00AD]))
2115 #define MCF5282_FLEXCAN_MBUF3_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00B1]))
2116 #define MCF5282_FLEXCAN_MBUF3_IDH (*(vuint16 *)(&__IPSBAR[0x1C00B2]))
2117 #define MCF5282_FLEXCAN_MBUF3_IDL (*(vuint16 *)(&__IPSBAR[0x1C00B4]))
2118 #define MCF5282_FLEXCAN_MBUF3_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00B6]))
2119 #define MCF5282_FLEXCAN_MBUF3_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00B7]))
2120 #define MCF5282_FLEXCAN_MBUF3_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00B8]))
2121 #define MCF5282_FLEXCAN_MBUF3_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00B9]))
2122 #define MCF5282_FLEXCAN_MBUF3_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00BA]))
2123 #define MCF5282_FLEXCAN_MBUF3_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00BB]))
2124 #define MCF5282_FLEXCAN_MBUF3_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00BC]))
2125 #define MCF5282_FLEXCAN_MBUF3_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00BD]))
2126 #define MCF5282_FLEXCAN_MBUF4_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00C1]))
2127 #define MCF5282_FLEXCAN_MBUF4_IDH (*(vuint16 *)(&__IPSBAR[0x1C00C2]))
2128 #define MCF5282_FLEXCAN_MBUF4_IDL (*(vuint16 *)(&__IPSBAR[0x1C00C4]))
2129 #define MCF5282_FLEXCAN_MBUF4_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00C6]))
2130 #define MCF5282_FLEXCAN_MBUF4_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00C7]))
2131 #define MCF5282_FLEXCAN_MBUF4_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00C8]))
2132 #define MCF5282_FLEXCAN_MBUF4_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00C9]))
2133 #define MCF5282_FLEXCAN_MBUF4_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00CA]))
2134 #define MCF5282_FLEXCAN_MBUF4_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00CB]))
2135 #define MCF5282_FLEXCAN_MBUF4_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00CC]))
2136 #define MCF5282_FLEXCAN_MBUF4_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00CD]))
2137 #define MCF5282_FLEXCAN_MBUF5_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00D1]))
2138 #define MCF5282_FLEXCAN_MBUF5_IDH (*(vuint16 *)(&__IPSBAR[0x1C00D2]))
2139 #define MCF5282_FLEXCAN_MBUF5_IDL (*(vuint16 *)(&__IPSBAR[0x1C00D4]))
2140 #define MCF5282_FLEXCAN_MBUF5_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00D6]))
2141 #define MCF5282_FLEXCAN_MBUF5_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00D7]))
2142 #define MCF5282_FLEXCAN_MBUF5_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00D8]))
2143 #define MCF5282_FLEXCAN_MBUF5_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00D9]))
2144 #define MCF5282_FLEXCAN_MBUF5_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00DA]))
2145 #define MCF5282_FLEXCAN_MBUF5_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00DB]))
2146 #define MCF5282_FLEXCAN_MBUF5_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00DC]))
2147 #define MCF5282_FLEXCAN_MBUF5_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00DD]))
2148 #define MCF5282_FLEXCAN_MBUF6_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00E1]))
2149 #define MCF5282_FLEXCAN_MBUF6_IDH (*(vuint16 *)(&__IPSBAR[0x1C00E2]))
2150 #define MCF5282_FLEXCAN_MBUF6_IDL (*(vuint16 *)(&__IPSBAR[0x1C00E4]))
2151 #define MCF5282_FLEXCAN_MBUF6_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00E6]))
2152 #define MCF5282_FLEXCAN_MBUF6_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00E7]))
2153 #define MCF5282_FLEXCAN_MBUF6_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00E8]))
2154 #define MCF5282_FLEXCAN_MBUF6_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00E9]))
2155 #define MCF5282_FLEXCAN_MBUF6_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00EA]))
2156 #define MCF5282_FLEXCAN_MBUF6_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00EB]))
2157 #define MCF5282_FLEXCAN_MBUF6_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00EC]))
2158 #define MCF5282_FLEXCAN_MBUF6_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00ED]))
2159 #define MCF5282_FLEXCAN_MBUF7_CTRL (*(vuint8 *)(&__IPSBAR[0x1C00F1]))
2160 #define MCF5282_FLEXCAN_MBUF7_IDH (*(vuint16 *)(&__IPSBAR[0x1C00F2]))
2161 #define MCF5282_FLEXCAN_MBUF7_IDL (*(vuint16 *)(&__IPSBAR[0x1C00F4]))
2162 #define MCF5282_FLEXCAN_MBUF7_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C00F6]))
2163 #define MCF5282_FLEXCAN_MBUF7_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C00F7]))
2164 #define MCF5282_FLEXCAN_MBUF7_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C00F8]))
2165 #define MCF5282_FLEXCAN_MBUF7_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C00F9]))
2166 #define MCF5282_FLEXCAN_MBUF7_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C00FA]))
2167 #define MCF5282_FLEXCAN_MBUF7_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C00FB]))
2168 #define MCF5282_FLEXCAN_MBUF7_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C00FC]))
2169 #define MCF5282_FLEXCAN_MBUF7_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C00FD]))
2170 #define MCF5282_FLEXCAN_MBUF8_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0101]))
2171 #define MCF5282_FLEXCAN_MBUF8_IDH (*(vuint16 *)(&__IPSBAR[0x1C0102]))
2172 #define MCF5282_FLEXCAN_MBUF8_IDL (*(vuint16 *)(&__IPSBAR[0x1C0104]))
2173 #define MCF5282_FLEXCAN_MBUF8_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0106]))
2174 #define MCF5282_FLEXCAN_MBUF8_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0107]))
2175 #define MCF5282_FLEXCAN_MBUF8_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0108]))
2176 #define MCF5282_FLEXCAN_MBUF8_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0109]))
2177 #define MCF5282_FLEXCAN_MBUF8_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C010A]))
2178 #define MCF5282_FLEXCAN_MBUF8_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C010B]))
2179 #define MCF5282_FLEXCAN_MBUF8_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C010C]))
2180 #define MCF5282_FLEXCAN_MBUF8_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C010D]))
2181 #define MCF5282_FLEXCAN_MBUF9_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0111]))
2182 #define MCF5282_FLEXCAN_MBUF9_IDH (*(vuint16 *)(&__IPSBAR[0x1C0112]))
2183 #define MCF5282_FLEXCAN_MBUF9_IDL (*(vuint16 *)(&__IPSBAR[0x1C0114]))
2184 #define MCF5282_FLEXCAN_MBUF9_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0116]))
2185 #define MCF5282_FLEXCAN_MBUF9_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0117]))
2186 #define MCF5282_FLEXCAN_MBUF9_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0118]))
2187 #define MCF5282_FLEXCAN_MBUF9_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0119]))
2188 #define MCF5282_FLEXCAN_MBUF9_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C011A]))
2189 #define MCF5282_FLEXCAN_MBUF9_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C011B]))
2190 #define MCF5282_FLEXCAN_MBUF9_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C011C]))
2191 #define MCF5282_FLEXCAN_MBUF9_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C011D]))
2192 #define MCF5282_FLEXCAN_MBUF10_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0121]))
2193 #define MCF5282_FLEXCAN_MBUF10_IDH (*(vuint16 *)(&__IPSBAR[0x1C0122]))
2194 #define MCF5282_FLEXCAN_MBUF10_IDL (*(vuint16 *)(&__IPSBAR[0x1C0124]))
2195 #define MCF5282_FLEXCAN_MBUF10_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0126]))
2196 #define MCF5282_FLEXCAN_MBUF10_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0127]))
2197 #define MCF5282_FLEXCAN_MBUF10_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0128]))
2198 #define MCF5282_FLEXCAN_MBUF10_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0129]))
2199 #define MCF5282_FLEXCAN_MBUF10_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C012A]))
2200 #define MCF5282_FLEXCAN_MBUF10_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C012B]))
2201 #define MCF5282_FLEXCAN_MBUF10_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C012C]))
2202 #define MCF5282_FLEXCAN_MBUF10_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C012D]))
2203 #define MCF5282_FLEXCAN_MBUF11_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0131]))
2204 #define MCF5282_FLEXCAN_MBUF11_IDH (*(vuint16 *)(&__IPSBAR[0x1C0132]))
2205 #define MCF5282_FLEXCAN_MBUF11_IDL (*(vuint16 *)(&__IPSBAR[0x1C0134]))
2206 #define MCF5282_FLEXCAN_MBUF11_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0136]))
2207 #define MCF5282_FLEXCAN_MBUF11_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0137]))
2208 #define MCF5282_FLEXCAN_MBUF11_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0138]))
2209 #define MCF5282_FLEXCAN_MBUF11_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0139]))
2210 #define MCF5282_FLEXCAN_MBUF11_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C013A]))
2211 #define MCF5282_FLEXCAN_MBUF11_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C013B]))
2212 #define MCF5282_FLEXCAN_MBUF11_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C013C]))
2213 #define MCF5282_FLEXCAN_MBUF11_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C013D]))
2214 #define MCF5282_FLEXCAN_MBUF12_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0141]))
2215 #define MCF5282_FLEXCAN_MBUF12_IDH (*(vuint16 *)(&__IPSBAR[0x1C0142]))
2216 #define MCF5282_FLEXCAN_MBUF12_IDL (*(vuint16 *)(&__IPSBAR[0x1C0144]))
2217 #define MCF5282_FLEXCAN_MBUF12_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0146]))
2218 #define MCF5282_FLEXCAN_MBUF12_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0147]))
2219 #define MCF5282_FLEXCAN_MBUF12_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0148]))
2220 #define MCF5282_FLEXCAN_MBUF12_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0149]))
2221 #define MCF5282_FLEXCAN_MBUF12_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C014A]))
2222 #define MCF5282_FLEXCAN_MBUF12_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C014B]))
2223 #define MCF5282_FLEXCAN_MBUF12_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C014C]))
2224 #define MCF5282_FLEXCAN_MBUF12_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C014D]))
2225 #define MCF5282_FLEXCAN_MBUF13_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0151]))
2226 #define MCF5282_FLEXCAN_MBUF13_IDH (*(vuint16 *)(&__IPSBAR[0x1C0152]))
2227 #define MCF5282_FLEXCAN_MBUF13_IDL (*(vuint16 *)(&__IPSBAR[0x1C0154]))
2228 #define MCF5282_FLEXCAN_MBUF13_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0156]))
2229 #define MCF5282_FLEXCAN_MBUF13_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0157]))
2230 #define MCF5282_FLEXCAN_MBUF13_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0158]))
2231 #define MCF5282_FLEXCAN_MBUF13_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0159]))
2232 #define MCF5282_FLEXCAN_MBUF13_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C015A]))
2233 #define MCF5282_FLEXCAN_MBUF13_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C015B]))
2234 #define MCF5282_FLEXCAN_MBUF13_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C015C]))
2235 #define MCF5282_FLEXCAN_MBUF13_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C015D]))
2236 #define MCF5282_FLEXCAN_MBUF14_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0161]))
2237 #define MCF5282_FLEXCAN_MBUF14_IDH (*(vuint16 *)(&__IPSBAR[0x1C0162]))
2238 #define MCF5282_FLEXCAN_MBUF14_IDL (*(vuint16 *)(&__IPSBAR[0x1C0164]))
2239 #define MCF5282_FLEXCAN_MBUF14_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0166]))
2240 #define MCF5282_FLEXCAN_MBUF14_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0167]))
2241 #define MCF5282_FLEXCAN_MBUF14_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0168]))
2242 #define MCF5282_FLEXCAN_MBUF14_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0169]))
2243 #define MCF5282_FLEXCAN_MBUF14_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C016A]))
2244 #define MCF5282_FLEXCAN_MBUF14_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C016B]))
2245 #define MCF5282_FLEXCAN_MBUF14_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C016C]))
2246 #define MCF5282_FLEXCAN_MBUF14_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C016D]))
2247 #define MCF5282_FLEXCAN_MBUF15_CTRL (*(vuint8 *)(&__IPSBAR[0x1C0171]))
2248 #define MCF5282_FLEXCAN_MBUF15_IDH (*(vuint16 *)(&__IPSBAR[0x1C0172]))
2249 #define MCF5282_FLEXCAN_MBUF15_IDL (*(vuint16 *)(&__IPSBAR[0x1C0174]))
2250 #define MCF5282_FLEXCAN_MBUF15_BYTE0 (*(vuint8 *)(&__IPSBAR[0x1C0176]))
2251 #define MCF5282_FLEXCAN_MBUF15_BYTE1 (*(vuint8 *)(&__IPSBAR[0x1C0177]))
2252 #define MCF5282_FLEXCAN_MBUF15_BYTE2 (*(vuint8 *)(&__IPSBAR[0x1C0178]))
2253 #define MCF5282_FLEXCAN_MBUF15_BYTE3 (*(vuint8 *)(&__IPSBAR[0x1C0179]))
2254 #define MCF5282_FLEXCAN_MBUF15_BYTE4 (*(vuint8 *)(&__IPSBAR[0x1C017A]))
2255 #define MCF5282_FLEXCAN_MBUF15_BYTE5 (*(vuint8 *)(&__IPSBAR[0x1C017B]))
2256 #define MCF5282_FLEXCAN_MBUF15_BYTE6 (*(vuint8 *)(&__IPSBAR[0x1C017C]))
2257 #define MCF5282_FLEXCAN_MBUF15_BYTE7 (*(vuint8 *)(&__IPSBAR[0x1C017D]))
2258
2259 #define MCF5282_FLEXCAN_MBUF0_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0086+(x))]))
2260 #define MCF5282_FLEXCAN_MBUF1_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0096+(x))]))
2261 #define MCF5282_FLEXCAN_MBUF2_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00A6+(x))]))
2262 #define MCF5282_FLEXCAN_MBUF3_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00B6+(x))]))
2263 #define MCF5282_FLEXCAN_MBUF4_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00C6+(x))]))
2264 #define MCF5282_FLEXCAN_MBUF5_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00D6+(x))]))
2265 #define MCF5282_FLEXCAN_MBUF6_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00E6+(x))]))
2266 #define MCF5282_FLEXCAN_MBUF7_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C00F6+(x))]))
2267 #define MCF5282_FLEXCAN_MBUF8_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0106+(x))]))
2268 #define MCF5282_FLEXCAN_MBUF9_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0116+(x))]))
2269 #define MCF5282_FLEXCAN_MBUF10_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0126+(x))]))
2270 #define MCF5282_FLEXCAN_MBUF11_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0136+(x))]))
2271 #define MCF5282_FLEXCAN_MBUF12_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0146+(x))]))
2272 #define MCF5282_FLEXCAN_MBUF13_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0156+(x))]))
2273 #define MCF5282_FLEXCAN_MBUF14_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0166+(x))]))
2274 #define MCF5282_FLEXCAN_MBUF15_BYTE(x) (*(vuint8 *)(&__IPSBAR[(0x1C0176+(x))]))
2275
2276 #define MCF5282_FLEXCAN_MBUF_BYTE(x,y) (*(vuint8 *)(&__IPSBAR[((0x1C0086+(0x10*(x))+(y))]))
2277
2278 /* Bit level definitions and macros */
2279 #define MCF5282_FLEXCAN_CANMCR_STOP (0x8000)
2280 #define MCF5282_FLEXCAN_CANMCR_FRZ (0x4000)
2281 #define MCF5282_FLEXCAN_CANMCR_HALT (0x1000)
2282 #define MCF5282_FLEXCAN_CANMCR_NOTRDY (0x0800)
2283 #define MCF5282_FLEXCAN_CANMCR_WAKEMSK (0x0400)
2284 #define MCF5282_FLEXCAN_CANMCR_SOFTRST (0x0200)
2285 #define MCF5282_FLEXCAN_CANMCR_FRZACK (0x0100)
2286 #define MCF5282_FLEXCAN_CANMCR_SUPV (0x0080)
2287 #define MCF5282_FLEXCAN_CANMCR_SELFWAKE (0x0040)
2288 #define MCF5282_FLEXCAN_CANMCR_APS (0x0020)
2289
2290 #define MCF5282_FLEXCAN_CANCTRL0_BOFFMSK (0x80)
2291 #define MCF5282_FLEXCAN_CANCTRL0_ERRMSK (0x40)
2292 #define MCF5282_FLEXCAN_CANCTRL0_RXMODE (0x04)
2293 #define MCF5282_FLEXCAN_CANCTRL0_TXMODE_CMOSPOS (0x00)
2294 #define MCF5282_FLEXCAN_CANCTRL0_TXMODE_CMOSNEG (0x01)
2295 #define MCF5282_FLEXCAN_CANCTRL0_TXMODE_OPENDRAIN (0x02)
2296
2297 #define MCF5282_FLEXCAN_CANCTRL1_SAMP (0x80)
2298 #define MCF5282_FLEXCAN_CANCTRL1_TSYNC (0x20)
2299 #define MCF5282_FLEXCAN_CANCTRL1_LBUF (0x10)
2300 #define MCF5282_FLEXCAN_CANCTRL1_LOM (0x08)
2301 #define MCF5282_FLEXCAN_CANCTRL1_PROPSEG(x) (((x)&0x07))
2302
2303 #define MCF5282_FLEXCAN_CANCTRL2_RJW(x) (((x)&0x03)<<6)
2304 #define MCF5282_FLEXCAN_CANCTRL2_PSEG1(x) (((x)&0x07)<<3)
2305 #define MCF5282_FLEXCAN_CANCTRL2_PSEG2(x) (((x)&0x07)<<0)
2306
2307 #define MCF5282_FLEXCAN_ESTAT_BITERR(x) (((x)&0x03)<<14)
2308 #define MCF5282_FLEXCAN_ESTAT_ACKERR (0x2000)
2309 #define MCF5282_FLEXCAN_ESTAT_CRCERR (0x1000)
2310 #define MCF5282_FLEXCAN_ESTAT_FORMERR (0x0800)
2311 #define MCF5282_FLEXCAN_ESTAT_STUFFERR (0x0400)
2312 #define MCF5282_FLEXCAN_ESTAT_TXWARN (0x0200)
2313 #define MCF5282_FLEXCAN_ESTAT_RXWARN (0x0100)
2314 #define MCF5282_FLEXCAN_ESTAT_IDLE (0x0080)
2315 #define MCF5282_FLEXCAN_ESTAT_TXRX (0x0040)
2316 #define MCF5282_FLEXCAN_ESTAT_FCS(x) (((x)&0x03)<<4)
2317 #define MCF5282_FLEXCAN_ESTAT_BOFFINT (0x0004)
2318 #define MCF5282_FLEXCAN_ESTAT_ERRINT (0x0002)
2319 #define MCF5282_FLEXCAN_ESTAT_WAKEINT (0x0001)
2320
2321 #define MCF5282_FLEXCAN_IMASK_BUF15M (0x8000)
2322 #define MCF5282_FLEXCAN_IMASK_BUF14M (0x4000)
2323 #define MCF5282_FLEXCAN_IMASK_BUF13M (0x2000)
2324 #define MCF5282_FLEXCAN_IMASK_BUF12M (0x1000)
2325 #define MCF5282_FLEXCAN_IMASK_BUF11M (0x0800)
2326 #define MCF5282_FLEXCAN_IMASK_BUF10M (0x0400)
2327 #define MCF5282_FLEXCAN_IMASK_BUF9M (0x0200)
2328 #define MCF5282_FLEXCAN_IMASK_BUF8M (0x0100)
2329 #define MCF5282_FLEXCAN_IMASK_BUF7M (0x0080)
2330 #define MCF5282_FLEXCAN_IMASK_BUF6M (0x0040)
2331 #define MCF5282_FLEXCAN_IMASK_BUF5M (0x0020)
2332 #define MCF5282_FLEXCAN_IMASK_BUF4M (0x0010)
2333 #define MCF5282_FLEXCAN_IMASK_BUF3M (0x0008)
2334 #define MCF5282_FLEXCAN_IMASK_BUF2M (0x0004)
2335 #define MCF5282_FLEXCAN_IMASK_BUF1M (0x0002)
2336 #define MCF5282_FLEXCAN_IMASK_BUF0M (0x0001)
2337
2338 #define MCF5282_FLEXCAN_IFLAG_BUF15I (0x8000)
2339 #define MCF5282_FLEXCAN_IFLAG_BUF14I (0x4000)
2340 #define MCF5282_FLEXCAN_IFLAG_BUF13I (0x2000)
2341 #define MCF5282_FLEXCAN_IFLAG_BUF12I (0x1000)
2342 #define MCF5282_FLEXCAN_IFLAG_BUF11I (0x0800)
2343 #define MCF5282_FLEXCAN_IFLAG_BUF10I (0x0400)
2344 #define MCF5282_FLEXCAN_IFLAG_BUF9I (0x0200)
2345 #define MCF5282_FLEXCAN_IFLAG_BUF8I (0x0100)
2346 #define MCF5282_FLEXCAN_IFLAG_BUF7I (0x0080)
2347 #define MCF5282_FLEXCAN_IFLAG_BUF6I (0x0040)
2348 #define MCF5282_FLEXCAN_IFLAG_BUF5I (0x0020)
2349 #define MCF5282_FLEXCAN_IFLAG_BUF4I (0x0010)
2350 #define MCF5282_FLEXCAN_IFLAG_BUF3I (0x0008)
2351 #define MCF5282_FLEXCAN_IFLAG_BUF2I (0x0004)
2352 #define MCF5282_FLEXCAN_IFLAG_BUF1I (0x0002)
2353 #define MCF5282_FLEXCAN_IFLAG_BUF0I (0x0001)
2354
2355 /*********************************************************************
2356 *
2357 * ColdFire Flash Module (CFM)
2358 *
2359 *********************************************************************/
2360
2361 /* Read/Write access macros for general use */
2362 #define MCF5282_CFM_CFMMCR (*(vuint16 *)(&__IPSBAR[0x1D0000]))
2363 #define MCF5282_CFM_CFMCLKD (*(vuint8 *)(&__IPSBAR[0x1D0002]))
2364 #define MCF5282_CFM_CFMSEC (*(vuint32 *)(&__IPSBAR[0x1D0008]))
2365 #define MCF5282_CFM_CFMPROT (*(vuint32 *)(&__IPSBAR[0x1D0010]))
2366 #define MCF5282_CFM_CFMSACC (*(vuint32 *)(&__IPSBAR[0x1D0014]))
2367 #define MCF5282_CFM_CFMDACC (*(vuint32 *)(&__IPSBAR[0x1D0018]))
2368 #define MCF5282_CFM_CFMUSTAT (*(vuint8 *)(&__IPSBAR[0x1D0020]))
2369 #define MCF5282_CFM_CFMCMD (*(vuint8 *)(&__IPSBAR[0x1D0024]))
2370 #define MCF5282_CFM_CFMDISU (*(vuint16 *)(&__IPSBAR[0x1D0042]))
2371
2372 /* Bit level definitions and macros */
2373 #define MCF5282_CFM_FLASHBAR_BA(a) ((a)&0xFFF8000)
2374 #define MCF5282_CFM_FLASHBAR_WP (0x00000100)
2375 #define MCF5282_CFM_FLASHBAR_CI (0x00000020)
2376 #define MCF5282_CFM_FLASHBAR_SC (0x00000010)
2377 #define MCF5282_CFM_FLASHBAR_SD (0x00000008)
2378 #define MCF5282_CFM_FLASHBAR_UC (0x00000004)
2379 #define MCF5282_CFM_FLASHBAR_UD (0x00000002)
2380 #define MCF5282_CFM_FLASHBAR_V (0x00000001)
2381
2382 #define MCF5282_CFM_CFMMCR_LOCK (0x0400)
2383 #define MCF5282_CFM_CFMMCR_PVIE (0x0200)
2384 #define MCF5282_CFM_CFMMCR_AEIE (0x0100)
2385 #define MCF5282_CFM_CFMMCR_CBEIE (0x0080)
2386 #define MCF5282_CFM_CFMMCR_CCIE (0x0040)
2387 #define MCF5282_CFM_CFMMCR_KEYACC (0x0020)
2388
2389 #define MCF5282_CFM_CFMCLKD_DIVLD (0x80)
2390 #define MCF5282_CFM_CFMCLKD_PRDIV8 (0x40)
2391 #define MCF5282_CFM_CFMCLKD_DIV(x) (((x)&0x3F))
2392
2393 #define MCF5282_CFM_CFMSEC_KEYEN (0x80000000)
2394 #define MCF5282_CFM_CFMSEC_SECSTAT (0x40000000)
2395 #define MCF5282_CFM_CFMSEC_SEC(x) (((x)&0xFFFF))
2396
2397 #define MCF5282_CFM_CFMUSTAT_CBEIF (0x80)
2398 #define MCF5282_CFM_CFMUSTAT_CCIF (0x40)
2399 #define MCF5282_CFM_CFMUSTAT_PVIOL (0x20)
2400 #define MCF5282_CFM_CFMUSTAT_ACCERR (0x10)
2401 #define MCF5282_CFM_CFMUSTAT_BLANK (0x04)
2402
2403 #define MCF5282_CFM_CFMCMD_CMD(x) (((x)&0x7F))
2404
2405 /********************************************************************/
2406
2407 #endif /* _CPU_MCF5282_H */
typedef __attribute__
Disable IRQ Interrupts.
Definition: cmsis_gcc.h:69
#define __IPSBAR
Definition: bsp.h:40
