RTEMS  5.1
mcf5272.h
1 /*
2  * Coldfire MCF5272 definitions.
3  * Contents of this file based on information provided in
4  * Motorola MCF5272 User's Manual.
5  *
6  * Copyright (C) 2004 Jay Monkman <jtm@lopingdog.com>
7  *
8  * The license and distribution terms for this file may be
9  * found in the file LICENSE in this distribution or at
10  * http://www.rtems.org/license/LICENSE.
11  */
12
13 #ifndef __MCF5272_H__
14 #define __MCF5272_H__
15
16 #ifndef ASM
17 #include <rtems.h>
18 #endif
19
20 #define bit(x) (1 << (x))
21
22 #define MCF5272_SIM_BASE(mbar) ((mbar) + 0x0000)
23 #define MCF5272_INT_BASE(mbar) ((mbar) + 0x0020)
24 #define MCF5272_CS_BASE(mbar) ((mbar) + 0x0040)
25 #define MCF5272_GPIO_BASE(mbar) ((mbar) + 0x0080)
26 #define MCF5272_QSPI_BASE(mbar) ((mbar) + 0x00A0)
27 #define MCF5272_PWM_BASE(mbar) ((mbar) + 0x00C0)
28 #define MCF5272_DMAC_BASE(mbar) ((mbar) + 0x00E0)
29 #define MCF5272_UART0_BASE(mbar) ((mbar) + 0x0100)
30 #define MCF5272_UART1_BASE(mbar) ((mbar) + 0x0140)
31 #define MCF5272_SDRAMC_BASE(mbar) ((mbar) + 0x0180)
32 #define MCF5272_TIMER_BASE(mbar) ((mbar) + 0x0200)
33 #define MCF5272_PLIC_BASE(mbar) ((mbar) + 0x0300)
34 #define MCF5272_ENET_BASE(mbar) ((mbar) + 0x0840)
35 #define MCF5272_USB_BASE(mbar) ((mbar) + 0x1000)
36
37
38 /* RAMBAR - SRAM Base Address Register */
39 #define MCF5272_RAMBAR_BA (0xfffff000) /* SRAM Base Address */
40 #define MCF5272_RAMBAR_WP (0x00000100) /* Write Protect */
41 #define MCF5272_RAMBAR_CI (0x00000020) /* CPU Space mask */
42 #define MCF5272_RAMBAR_SC (0x00000010) /* Supervisor Code Space Mask */
43 #define MCF5272_RAMBAR_SD (0x00000008) /* Supervisor Data Space Mask */
44 #define MCF5272_RAMBAR_UC (0x00000004) /* User Code Space Mask */
45 #define MCF5272_RAMBAR_UD (0x00000002) /* User Data Space Mask */
46 #define MCF5272_RAMBAR_V (0x00000001) /* Contents of RAMBAR are valid */
47
48 /* MBAR - Module Base Address Register */
49 #define MCF5272_MBAR_BA (0xffff0000) /* Base Address */
50 #define MCF5272_MBAR_SC (0x00000010) /* Supervisor Code Space Mask */
51 #define MCF5272_MBAR_SD (0x00000008) /* Supervisor Data Space Mask */
52 #define MCF5272_MBAR_UC (0x00000004) /* User Code Space Mask */
53 #define MCF5272_MBAR_UD (0x00000002) /* User Data Space Mask */
54 #define MCF5272_MBAR_V (0x00000001) /* Contents of MBAR are valid */
55
56 /* CACR - Cache Control Register */
57 #define MCF5272_CACR_CENB (0x80000000) /* Cache Enable */
58 #define MCF5272_CACR_CPDI (0x10000000) /* Disable CPUSHL Invalidation */
59 #define MCF5272_CACR_CFRZ (0x08000000) /* Cache Freeze */
60 #define MCF5272_CACR_CINV (0x01000000) /* Cache Invalidate */
61 #define MCF5272_CACR_CEIB (0x00000400) /* Cache Enable Noncacheable
62  instruction bursting */
63 #define MCF5272_CACR_DCM (0x00000200) /* Default cache mode - noncacheable*/
64 #define MCF5272_CACR_DBWE (0x00000100) /* Default Buffered Write Enable */
65 #define MCF5272_CACR_DWP (0x00000020) /* Default Write Protection */
66 #define MCF5272_CACR_CLNF (0x00000003) /* Cache Line Fill */
67
68 /* ACRx - Cache Access Control Registers */
69 #define MCF5272_ACR_BA (0xff000000) /* Address Base */
70 #define MCF5272_ACR_BAM (0x00ff0000) /* Address Mask */
71 #define MCF5272_ACR_EN (0x00008000) /* Enable */
72 #define MCF5272_ACR_SM_USR (0x00000000) /* Match if user mode */
73 #define MCF5272_ACR_SM_SVR (0x00002000) /* Match if supervisor mode */
74 #define MCF5272_ACR_SM_ANY (0x00004000) /* Match Always */
75 #define MCF527_ACR_CM (0x00000040) /* Cache Mode (1 - noncacheable) */
76 #define MCF5272_ACR_BWE (0x00000020) /* Buffered Write Enable */
77 #define MCF5272_ACR_WP (0x00000004) /* Write Protect */
78 #define MCF5272_ACR_BASE(base) ((base) & MCF5272_ACR_BA)
79 #define MCF5272_ACR_MASK(mask) (((mask) >> 8) & MCF5272_ACR_BAM)
80
81
82 #define MCF5272_ICR1_INT1_PI (bit(31))
83 #define MCF5272_ICR1_INT1_IPL(x) ((x) << 28)
84 #define MCF5272_ICR1_INT1_MASK ((7) << 28)
85 #define MCF5272_ICR1_INT2_PI (bit(27))
86 #define MCF5272_ICR1_INT2_IPL(x) ((x) << 24)
87 #define MCF5272_ICR1_INT2_MASK ((7) << 24)
88 #define MCF5272_ICR1_INT3_PI (bit(23))
89 #define MCF5272_ICR1_INT3_IPL(x) ((x) << 20)
90 #define MCF5272_ICR1_INT3_MASK ((7) << 20)
91 #define MCF5272_ICR1_INT4_PI (bit(19))
92 #define MCF5272_ICR1_INT4_IPL(x) ((x) << 16)
93 #define MCF5272_ICR1_INT4_MASK ((7) << 16)
94 #define MCF5272_ICR1_TMR0_PI (bit(15))
95 #define MCF5272_ICR1_TMR0_IPL(x) ((x) << 12)
96 #define MCF5272_ICR1_TMR0_MASK ((7) << 12)
97 #define MCF5272_ICR1_TMR1_PI (bit(11))
98 #define MCF5272_ICR1_TMR1_IPL(x) ((x) << 8)
99 #define MCF5272_ICR1_TMR1_MASK ((7) << 8)
100 #define MCF5272_ICR1_TMR2_PI (bit(7))
101 #define MCF5272_ICR1_TMR2_IPL(x) ((x) << 4)
102 #define MCF5272_ICR1_TMR2_MASK ((7) << 4)
103 #define MCF5272_ICR1_TMR3_PI (bit(3))
104 #define MCF5272_ICR1_TMR3_IPL(x) ((x) << 0)
105 #define MCF5272_ICR1_TMR3_MASK ((7) << 0)
106
107 #define MCF5272_ICR3_USB4_PI (bit(31))
108 #define MCF5272_ICR3_USB4_IPL(x) ((x) << 28)
109 #define MCF5272_ICR3_USB4_MASK ((7) << 28)
110 #define MCF5272_ICR3_USB5_PI (bit(27))
111 #define MCF5272_ICR3_USB5_IPL(x) ((x) << 24)
112 #define MCF5272_ICR3_USB5_MASK ((7) << 24)
113 #define MCF5272_ICR3_USB6_PI (bit(23))
114 #define MCF5272_ICR3_USB6_IPL(x) ((x) << 20)
115 #define MCF5272_ICR3_USB6_MASK ((7) << 20)
116 #define MCF5272_ICR3_USB7_PI (bit(19))
117 #define MCF5272_ICR3_USB7_IPL(x) ((x) << 16)
118 #define MCF5272_ICR3_USB7_MASK ((7) << 16)
119 #define MCF5272_ICR3_DMA_PI (bit(15))
120 #define MCF5272_ICR3_DMA_IPL(x) ((x) << 12)
121 #define MCF5272_ICR3_DMA_MASK ((7) << 12)
122 #define MCF5272_ICR3_ERX_PI (bit(11))
123 #define MCF5272_ICR3_ERX_IPL(x) ((x) << 8)
124 #define MCF5272_ICR3_ERX_MASK ((7) << 8)
125 #define MCF5272_ICR3_ETX_PI (bit(7))
126 #define MCF5272_ICR3_ETX_IPL(x) ((x) << 4)
127 #define MCF5272_ICR3_ETX_MASK ((7) << 4)
128 #define MCF5272_ICR3_ENTC_PI (bit(3))
129 #define MCF5272_ICR3_ENTC_IPL(x) ((x) << 0)
130 #define MCF5272_ICR3_ENTC_MASK ((7) << 0)
131
132
133 #define MCF5272_USR_RB (bit(7))
134 #define MCF5272_USR_FE (bit(6))
135 #define MCF5272_USR_PE (bit(5))
136 #define MCF5272_USR_OE (bit(4))
137 #define MCF5272_USR_TXEMP (bit(3))
138 #define MCF5272_USR_TXRDY (bit(2))
139 #define MCF5272_USR_FFULL (bit(1))
140 #define MCF5272_USR_RXRDY (bit(0))
141
142 #define MCF5272_TMR_PS_MASK 0xff00
143 #define MCF5272_TMR_PS_SHIFT 8
144 #define MCF5272_TMR_CE_DISABLE (0 << 6)
145 #define MCF5272_TMR_CE_RISING (1 << 6)
146 #define MCF5272_TMR_CE_FALLING (2 << 6)
147 #define MCF5272_TMR_CE_ANY (3 << 6)
148 #define MCF5272_TMR_OM (bit(5))
149 #define MCF5272_TMR_ORI (bit(4))
150 #define MCF5272_TMR_FRR (bit(3))
151 #define MCF5272_TMR_CLK_STOP (0 << 1)
152 #define MCF5272_TMR_CLK_MSTR (1 << 1)
153 #define MCF5272_TMR_CLK_MSTR16 (2 << 1)
154 #define MCF5272_TMR_CLK_TIN (3 << 1)
155 #define MCF5272_TMR_RST (bit(0))
156 #define MCF5272_TER_REF (bit(1))
157 #define MCF5272_TER_CAP (bit(0))
158
159 #define MCF5272_SCR_PRI (bit(8))
160 #define MCF5272_SCR_AR (bit(7))
161 #define MCF5272_SCR_SRST (bit(6))
162 #define MCF5272_SCR_BUSLOCK (bit(3))
163 #define MCF5272_SCR_HWR_128 (0)
164 #define MCF5272_SCR_HWR_256 (1)
165 #define MCF5272_SCR_HWR_512 (2)
166 #define MCF5272_SCR_HWR_1024 (3)
167 #define MCF5272_SCR_HWR_2048 (4)
168 #define MCF5272_SCR_HWR_4096 (5)
169 #define MCF5272_SCR_HWR_8192 (6)
170 #define MCF5272_SCR_HWR_16384 (7)
171
172 #define MCF5272_SPR_ADC (bit(15))
173 #define MCF5272_SPR_WPV (bit(15))
174 #define MCF5272_SPR_SMV (bit(15))
175 #define MCF5272_SPR_PE (bit(15))
176 #define MCF5272_SPR_HWT (bit(15))
177 #define MCF5272_SPR_RPV (bit(15))
178 #define MCF5272_SPR_EXT (bit(15))
179 #define MCF5272_SPR_SUV (bit(15))
180 #define MCF5272_SPR_ADCEN (bit(15))
181 #define MCF5272_SPR_WPVEN (bit(15))
182 #define MCF5272_SPR_SMVEN (bit(15))
183 #define MCF5272_SPR_PEEN (bit(15))
184 #define MCF5272_SPR_HWTEN (bit(15))
185 #define MCF5272_SPR_RPVEN (bit(15))
186 #define MCF5272_SPR_EXTEN (bit(15))
187 #define MCF5272_SPR_SUVEN (bit(15))
188
189 #define MCF5272_ENET_TX_RT (bit(25))
190 #define MCF5272_ENET_ETHERN_EN (bit(1))
191 #define MCF5272_ENET_RESET (bit(0))
192
193 #define MCF5272_ENET_EIR_HBERR (bit(31))
194 #define MCF5272_ENET_EIR_BABR (bit(30))
195 #define MCF5272_ENET_EIR_BABT (bit(29))
196 #define MCF5272_ENET_EIR_GRA (bit(28))
197 #define MCF5272_ENET_EIR_TXF (bit(27))
198 #define MCF5272_ENET_EIR_TXB (bit(26))
199 #define MCF5272_ENET_EIR_RXF (bit(25))
200 #define MCF5272_ENET_EIR_RXB (bit(24))
201 #define MCF5272_ENET_EIR_MII (bit(23))
202 #define MCF5272_ENET_EIR_EBERR (bit(22))
203 #define MCF5272_ENET_EIR_UMINT (bit(21))
204
205 #define MCF5272_ENET_RCR_PROM (bit(3))
206 #define MCF5272_ENET_RCR_MII (bit(2))
207 #define MCF5272_ENET_RCR_DRT (bit(1))
208 #define MCF5272_ENET_RCR_LOOP (bit(0))
209
210 #define MCF5272_ENET_TCR_FDEN (bit(2))
211 #define MCF5272_ENET_TCR_HBC (bit(1))
212 #define MCF5272_ENET_TCR_GTS (bit(0))
213
214
215 #ifndef ASM
216 typedef struct {
217  volatile uint32_t mbar; /* READ ONLY!! */
218
219  volatile uint16_t scr;
220  volatile uint16_t _res0;
221
222  volatile uint16_t _res1;
223  volatile uint16_t spr;
224
225  volatile uint32_t pmr;
226
227  volatile uint16_t _res2;
228  volatile uint16_t alpr;
229
230  volatile uint32_t dir;
231 } sim_regs_t;
232
233 typedef struct {
234  volatile uint32_t icr1;
235  volatile uint32_t icr2;
236  volatile uint32_t icr3;
237  volatile uint32_t icr4;
238  volatile uint32_t isr;
239  volatile uint32_t pitr;
240  volatile uint32_t piwr;
241  volatile uint8_t _res0[3];
242  volatile uint8_t pivr;
244
245 typedef struct {
246  volatile uint32_t csbr0;
247  volatile uint32_t csor0;
248  volatile uint32_t csbr1;
249  volatile uint32_t csor1;
250  volatile uint32_t csbr2;
251  volatile uint32_t csor2;
252  volatile uint32_t csbr3;
253  volatile uint32_t csor3;
254  volatile uint32_t csbr4;
255  volatile uint32_t csor4;
256  volatile uint32_t csbr5;
257  volatile uint32_t csor5;
258  volatile uint32_t csbr6;
259  volatile uint32_t csor6;
260  volatile uint32_t csbr7;
261  volatile uint32_t csor7;
263
264 typedef struct {
265  volatile uint32_t pacnt;
266
267  volatile uint16_t paddr;
268  volatile uint16_t _res0;
269
270  volatile uint16_t _res1;
271  volatile uint16_t padat;
272
273  volatile uint32_t pbcnt;
274
275  volatile uint16_t pbddr;
276  volatile uint16_t _res2;
277
278  volatile uint16_t _res3;
279  volatile uint16_t pbdat;
280
281  volatile uint16_t pcddr;
282  volatile uint16_t _res4;
283
284  volatile uint16_t _res5;
285  volatile uint16_t pcdat;
286
287  volatile uint32_t pdcnt;
288 } gpio_regs_t;
289
290 typedef struct {
291  volatile uint32_t qmr;
292  volatile uint32_t qdlyr;
293  volatile uint32_t qwr;
294  volatile uint32_t qir;
295  volatile uint32_t qar;
296  volatile uint32_t qdr;
297 } qspi_regs_t;
298
299 typedef struct {
300  volatile uint8_t pwcr1;
301  volatile uint8_t _res0[3];
302
303  volatile uint8_t pwcr2;
304  volatile uint8_t _res1[3];
305
306  volatile uint8_t pwcr3;
307  volatile uint8_t _res2[3];
308
309  volatile uint8_t pwwd1;
310  volatile uint8_t _res3[3];
311
312  volatile uint8_t pwwd2;
313  volatile uint8_t _res4[3];
314
315  volatile uint8_t pwwd3;
316  volatile uint8_t _res5[3];
317 } pwm_regs_t;
318
319 typedef struct {
320  volatile uint32_t dcmr;
321
322  volatile uint16_t _res0;
323  volatile uint16_t dcir;
324
325  volatile uint32_t dbcr;
326
327  volatile uint32_t dsar;
328
329  volatile uint32_t ddar;
330 } dma_regs_t;
331
332 typedef struct {
333  volatile uint8_t umr; /* 0x000 */
334  volatile uint8_t _res0[3];
335
336  volatile uint8_t ucsr; /* 0x004 */
337  volatile uint8_t _res2[3];
338
339  volatile uint8_t ucr; /* 0x008 */
340  volatile uint8_t _res3[3];
341
342  volatile uint8_t udata; /* 0x00c */
343  volatile uint8_t _res4[3];
344
345  volatile uint8_t uccr; /* 0x010 */
346  volatile uint8_t _res6[3];
347
348  volatile uint8_t uisr; /* 0x014 */
349  volatile uint8_t _res8[3];
350
351  volatile uint8_t ubg1; /* 0x018 */
352  volatile uint8_t _res10[3];
353
354  volatile uint8_t ubg2; /* 0x01c */
355  volatile uint8_t _res11[3];
356
357  volatile uint8_t uabr1; /* 0x020 */
358  volatile uint8_t _res12[3];
359
360  volatile uint8_t uabr2; /* 0x024 */
361  volatile uint8_t _res13[3];
362
363  volatile uint8_t utxfcsr; /* 0x028 */
364  volatile uint8_t _res14[3];
365
366  volatile uint8_t urxfcsr; /* 0x02c */
367  volatile uint8_t _res15[3];
368
369  volatile uint8_t ufpdn; /* 0x030 */
370  volatile uint8_t _res16[3];
371
372  volatile uint8_t uip; /* 0x034 */
373  volatile uint8_t _res17[3];
374
375  volatile uint8_t uop1; /* 0x038 */
376  volatile uint8_t _res18[3];
377
378  volatile uint8_t uop0; /* 0x03c */
379  volatile uint8_t _res19[3];
380 } uart_regs_t;
381
382 typedef struct {
383  volatile uint16_t tmr0;
384  volatile uint16_t _res0;
385
386  volatile uint16_t trr0;
387  volatile uint16_t _res1;
388
389  volatile uint16_t tcap0;
390  volatile uint16_t _res2;
391
392  volatile uint16_t tcn0;
393  volatile uint16_t _res3;
394
395  volatile uint16_t ter0;
396  volatile uint16_t _res4;
397
398  volatile uint8_t _res40[12];
399
400  volatile uint16_t tmr1;
401  volatile uint16_t _res5;
402
403  volatile uint16_t trr1;
404  volatile uint16_t _res6;
405
406  volatile uint16_t tcap1;
407  volatile uint16_t _res7;
408
409  volatile uint16_t tcn1;
410  volatile uint16_t _res8;
411
412  volatile uint16_t ter1;
413  volatile uint16_t _res9;
414
415  volatile uint8_t _res91[12];
416
417  volatile uint16_t tmr2;
418  volatile uint16_t _res10;
419
420  volatile uint16_t trr2;
421  volatile uint16_t _res11;
422
423  volatile uint16_t tcap2;
424  volatile uint16_t _res12;
425
426  volatile uint16_t tcn2;
427  volatile uint16_t _res13;
428
429  volatile uint16_t ter2;
430  volatile uint16_t _res14;
431
432  volatile uint8_t _res140[12];
433
434  volatile uint16_t tmr3;
435  volatile uint16_t _res15;
436
437  volatile uint16_t trr3;
438  volatile uint16_t _res16;
439
440  volatile uint16_t tcap3;
441  volatile uint16_t _res17;
442
443  volatile uint16_t tcn3;
444  volatile uint16_t _res18;
445
446  volatile uint16_t ter3;
447  volatile uint16_t _res19;
448
449  volatile uint8_t _res190[12];
450
451  volatile uint16_t wrrr;
452  volatile uint16_t _res20;
453
454  volatile uint16_t wirr;
455  volatile uint16_t _res21;
456
457  volatile uint16_t wcr;
458  volatile uint16_t _res22;
459
460  volatile uint16_t wer;
461  volatile uint16_t _res23;
462 } timer_regs_t;
463
464 typedef struct {
465  volatile uint32_t p0b1rr;
466  volatile uint32_t p1b1rr;
467  volatile uint32_t p2b1rr;
468  volatile uint32_t p3b1rr;
469  volatile uint32_t p0b2rr;
470  volatile uint32_t p1b2rr;
471  volatile uint32_t p2b2rr;
472  volatile uint32_t p3b2rr;
473
474  volatile uint8_t p0drr;
475  volatile uint8_t p1drr;
476  volatile uint8_t p2drr;
477  volatile uint8_t p3drr;
478
479  volatile uint32_t p0b1tr;
480  volatile uint32_t p1b1tr;
481  volatile uint32_t p2b1tr;
482  volatile uint32_t p3b1tr;
483  volatile uint32_t p0b2tr;
484  volatile uint32_t p1b2tr;
485  volatile uint32_t p2b2tr;
486  volatile uint32_t p3b2tr;
487
488  volatile uint8_t p0dtr;
489  volatile uint8_t p1dtr;
490  volatile uint8_t p2dtr;
491  volatile uint8_t p3dtr;
492
493  volatile uint16_t p0cr;
494  volatile uint16_t p1cr;
495  volatile uint16_t p2cr;
496  volatile uint16_t p3cr;
497  volatile uint16_t p0icr;
498  volatile uint16_t p1icr;
499  volatile uint16_t p2icr;
500  volatile uint16_t p3icr;
501  volatile uint16_t p0gmr;
502  volatile uint16_t p1gmr;
503  volatile uint16_t p2gmr;
504  volatile uint16_t p3gmr;
505  volatile uint16_t p0gmt;
506  volatile uint16_t p1gmt;
507  volatile uint16_t p2gmt;
508  volatile uint16_t p3gmt;
509
510  volatile uint8_t _res0;
511  volatile uint8_t pgmts;
512  volatile uint8_t pgmta;
513  volatile uint8_t _res1;
514  volatile uint8_t p0gcir;
515  volatile uint8_t p1gcir;
516  volatile uint8_t p2gcir;
517  volatile uint8_t p3gcir;
518  volatile uint8_t p0gcit;
519  volatile uint8_t p1gcit;
520  volatile uint8_t p2gcit;
521  volatile uint8_t p3gcit;
522  volatile uint8_t _res3[3];
523  volatile uint8_t pgcitsr;
524  volatile uint8_t _res4[3];
525  volatile uint8_t pdcsr;
526
527  volatile uint16_t p0psr;
528  volatile uint16_t p1psr;
529  volatile uint16_t p2psr;
530  volatile uint16_t p3psr;
531  volatile uint16_t pasr;
532  volatile uint8_t _res5;
533  volatile uint8_t plcr;
534  volatile uint16_t _res6;
535  volatile uint16_t pdrqr;
536  volatile uint16_t p0sdr;
537  volatile uint16_t p1sdr;
538  volatile uint16_t p2sdr;
539  volatile uint16_t p3sdr;
540  volatile uint16_t _res7;
541  volatile uint16_t pcsr;
542 } plic_regs_t;
543
544 typedef struct {
545  volatile uint32_t ecr;
546  volatile uint32_t eir;
547  volatile uint32_t eimr;
548  volatile uint32_t ivsr;
549  volatile uint32_t rdar;
550  volatile uint32_t tdar;
551  volatile uint32_t _res0[10];
552  volatile uint32_t mmfr;
553  volatile uint32_t mscr;
554  volatile uint32_t _res1[17];
555  volatile uint32_t frbr;
556  volatile uint32_t frsr;
557  volatile uint32_t _res2[4];
558  volatile uint32_t tfwr;
559  volatile uint32_t _res3[1];
560  volatile uint32_t tfsr;
561  volatile uint32_t _res4[21];
562  volatile uint32_t rcr;
563  volatile uint32_t mflr;
564  volatile uint32_t _res5[14];
565  volatile uint32_t tcr;
566  volatile uint32_t _res6[158];
567  volatile uint32_t malr;
568  volatile uint32_t maur;
569  volatile uint32_t htur;
570  volatile uint32_t htlr;
571  volatile uint32_t erdsr;
572  volatile uint32_t etdsr;
573  volatile uint32_t emrbr;
574 /* volatile uint8_t fifo[448]; */
575 } enet_regs_t;
576
577 typedef struct {
578  volatile uint16_t _res0;
579  volatile uint16_t fnr;
580  volatile uint16_t _res1;
581  volatile uint16_t fnmr;
582  volatile uint16_t _res2;
583  volatile uint16_t rfmr;
584  volatile uint16_t _res3;
585  volatile uint16_t rfmmr;
586  volatile uint8_t _res4[3];
587  volatile uint8_t far;
588  volatile uint32_t asr;
589  volatile uint32_t drr1;
590  volatile uint32_t drr2;
591  volatile uint16_t _res5;
592  volatile uint16_t specr;
593  volatile uint16_t _res6;
594  volatile uint16_t ep0sr;
595
596  volatile uint32_t iep0cfg;
597  volatile uint32_t oep0cfg;
598  volatile uint32_t ep1cfg;
599  volatile uint32_t ep2cfg;
600  volatile uint32_t ep3cfg;
601  volatile uint32_t ep4cfg;
602  volatile uint32_t ep5cfg;
603  volatile uint32_t ep6cfg;
604  volatile uint32_t ep7cfg;
605  volatile uint32_t ep0ctl;
606
607  volatile uint16_t _res7;
608  volatile uint16_t ep1ctl;
609  volatile uint16_t _res8;
610  volatile uint16_t ep2ctl;
611  volatile uint16_t _res9;
612  volatile uint16_t ep3ctl;
613  volatile uint16_t _res10;
614  volatile uint16_t ep4ctl;
615  volatile uint16_t _res11;
616  volatile uint16_t ep5ctl;
617  volatile uint16_t _res12;
618  volatile uint16_t ep6ctl;
619  volatile uint16_t _res13;
620  volatile uint16_t ep7ctl;
621
622  volatile uint32_t ep0isr;
623
624  volatile uint16_t _res14;
625  volatile uint16_t ep1isr;
626  volatile uint16_t _res15;
627  volatile uint16_t ep2isr;
628  volatile uint16_t _res16;
629  volatile uint16_t ep3isr;
630  volatile uint16_t _res17;
631  volatile uint16_t ep4isr;
632  volatile uint16_t _res18;
633  volatile uint16_t ep5isr;
634  volatile uint16_t _res19;
635  volatile uint16_t ep6isr;
636  volatile uint16_t _res20;
637  volatile uint16_t ep7isr;
638
639  volatile uint32_t ep0imr;
640
641  volatile uint16_t _res21;
642  volatile uint16_t ep1imr;
643  volatile uint16_t _res22;
644  volatile uint16_t ep2imr;
645  volatile uint16_t _res23;
646  volatile uint16_t ep3imr;
647  volatile uint16_t _res24;
648  volatile uint16_t ep4imr;
649  volatile uint16_t _res25;
650  volatile uint16_t ep5imr;
651  volatile uint16_t _res26;
652  volatile uint16_t ep6imr;
653  volatile uint16_t _res27;
654  volatile uint16_t ep7imr;
655
656  volatile uint32_t ep0dr;
657  volatile uint32_t ep1dr;
658  volatile uint32_t ep2dr;
659  volatile uint32_t ep3dr;
660  volatile uint32_t ep4dr;
661  volatile uint32_t ep5dr;
662  volatile uint32_t ep6dr;
663  volatile uint32_t ep7dr;
664
665  volatile uint16_t _res28;
666  volatile uint16_t ep0dpr;
667  volatile uint16_t _res29;
668  volatile uint16_t ep1dpr;
669  volatile uint16_t _res30;
670  volatile uint16_t ep2dpr;
671  volatile uint16_t _res31;
672  volatile uint16_t ep3dpr;
673  volatile uint16_t _res32;
674  volatile uint16_t ep4dpr;
675  volatile uint16_t _res33;
676  volatile uint16_t ep5dpr;
677  volatile uint16_t _res34;
678  volatile uint16_t ep6dpr;
679  volatile uint16_t _res35;
680  volatile uint16_t ep7dpr;
681 /* uint8_t ram[1024]; */
682 } usb_regs_t;
683
684 extern intctrl_regs_t *g_intctrl_regs;
685 extern chipsel_regs_t *g_chipsel_regs;
686 extern gpio_regs_t *g_gpio_regs;
687 extern qspi_regs_t *g_qspi_regs;
688 extern pwm_regs_t *g_pwm_regs;
689 extern dma_regs_t *g_dma_regs;
690 extern uart_regs_t *g_uart0_regs;
691 extern uart_regs_t *g_uart1_regs;
692 extern timer_regs_t *g_timer_regs;
693 extern plic_regs_t *g_plic_regs;
694 extern enet_regs_t *g_enet_regs;
695 extern usb_regs_t *g_usb_regs;
696
697 #endif /* ASM */
698
699 #endif /* __MCF5272_H__ */
Definition: mcf5272.h:332
Definition: mcf5272.h:319
Definition: mcf5272.h:264
Definition: mcf5272.h:216
Definition: mcf5272.h:544
Definition: mcf5272.h:245
Definition: mcf5272.h:464
Definition: mcf5272.h:233
Definition: mcf5272.h:577
Definition: mcf5272.h:290
Definition: mcf5272.h:299
Definition: mcf5272.h:382
