RTEMS  5.1
mcf5206e.h
1 /*
2  * Coldfire MCF5206e on-chip peripherial definitions.
3  * Contents of this file based on information provided in
4  * Motorola MCF5206e User's Manual
5  *
6  * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
7  * Author: Victor V. Vengerov <vvv@oktet.ru>
8  *
9  * The license and distribution terms for this file may be
10  * found in the file LICENSE in this distribution or at
11  * http://www.rtems.org/license/LICENSE.
12  */
13
14 #ifndef __MCF5206E_H__
15 #define __MCF5206E_H__
16
17 #ifdef ASM
18 #define MCF5206E_REG8(base,ofs) (ofs+base)
19 #define MCF5206E_REG16(base,ofs) (ofs+base)
20 #define MCF5206E_REG32(base,ofs) (ofs+base)
21 #else
22 #define MCF5206E_REG8(base,ofs) \
23  (volatile uint8_t*)((uint8_t*)(base) + (ofs))
24 #define MCF5206E_REG16(base,ofs) \
25  (volatile uint16_t*)((uint8_t*)(base) + (ofs))
26 #define MCF5206E_REG32(base,ofs) \
27  (volatile uint32_t*)((uint8_t*)(base) + (ofs))
28 #endif
29
30 /*** Instruction Cache -- MCF5206e User's Manual, Chapter 4 ***/
31
32 /* CACR - Cache Control Register */
33 #define MCF5206E_CACR_CENB (0x80000000) /* Cache Enable */
34 #define MCF5206E_CACR_CPDI (0x10000000) /* Disable CPUSHL Invalidation */
35 #define MCF5206E_CACR_CFRZ (0x08000000) /* Cache Freeze */
36 #define MCF5206E_CACR_CINV (0x01000000) /* Cache Invalidate */
37 #define MCF5206E_CACR_CEIB (0x00000400) /* Cache Enable Noncacheable
38  instruction bursting */
39 #define MCF5206E_CACR_DCM (0x00000200) /* Default cache mode - noncacheable*/
40 #define MCF5206E_CACR_DBWE (0x00000100) /* Default Buffered Write Enable */
41 #define MCF5206E_CACR_DWP (0x00000020) /* Default Write Protection */
42 #define MCF5206E_CACR_CLNF (0x00000003) /* Cache Line Fill */
43
44 /* ACR0, ACR1 - Access Control Registers */
45 #define MCF5206E_ACR_AB (0xff000000) /* Address Base */
46 #define MCF5206E_ACR_AB_S (24)
47 #define MCF5206E_ACR_AM (0x00ff0000) /* Address Mask */
48 #define MCF5206E_ACR_AM_S (16)
49 #define MCF5206E_ACR_EN (0x00008000) /* Enable ACR */
50 #define MCF5206E_ACR_SM (0x00006000) /* Supervisor Mode */
51 #define MCF5206E_ACR_SM_USR (0x00000000) /* Match if user mode */
52 #define MCF5206E_ACR_SM_SVR (0x00002000) /* Match if supervisor mode */
53 #define MCF5206E_ACR_SM_ANY (0x00004000) /* Match Always */
54 #define MCF5206E_ACR_CM (0x00000040) /* Cache Mode (1 - noncacheable) */
55 #define MCF5206E_ACR_BUFW (0x00000020) /* Buffered Write Enable */
56 #define MCF5206E_ACR_WP (0x00000004) /* Write Protect */
57 #define MCF5206E_ACR_BASE(base) ((base) & MCF5206E_ACR_AB)
58 #define MCF5206E_ACR_MASK(mask) (((mask) >> 8) & MCF5206E_ACR_AM)
59
60 /*** SRAM -- MCF5206e User's Manual, Chapter 5 ***/
61
62 /* RAMBAR - SRAM Base Address Register */
63 #define MCF5206E_RAMBAR_BA (0xffffe000) /* SRAM Base Address */
64 #define MCF5206E_RAMBAR_WP (0x00000100) /* Write Protect */
65 #define MCF5206E_RAMBAR_CI (0x00000020) /* CPU Space mask */
66 #define MCF5206E_RAMBAR_SC (0x00000010) /* Supervisor Code Space Mask */
67 #define MCF5206E_RAMBAR_SD (0x00000008) /* Supervisor Data Space Mask */
68 #define MCF5206E_RAMBAR_UC (0x00000004) /* User Code Space Mask */
69 #define MCF5206E_RAMBAR_UD (0x00000002) /* User Data Space Mask */
70 #define MCF5206E_RAMBAR_V (0x00000001) /* Contents of RAMBAR are valid */
71
72 /*** DMA Controller Module -- MCF5206e User's Manual, Chapter 7 ***/
73
74 /* DMA Source Address Register */
75 #define MCF5206E_SAR(mbar,chn) MCF5206E_REG32(mbar,0x200 + ((chn) * 0x40))
76
77 /* DMA Destination Address Register */
78 #define MCF5206E_DAR(mbar,chn) MCF5206E_REG32(mbar,0x204 + ((chn) * 0x40))
79
80 /* DMA Byte Count Register */
81 #define MCF5206E_BCR(mbar,chn) MCF5206E_REG16(mbar,0x20C + ((chn) * 0x40))
82
83 /* DMA Control Register */
84 #define MCF5206E_DCR(mbar,chn) MCF5206E_REG16(mbar,0x208 + ((chn) * 0x40))
85 #define MCF5206E_DCR_INT (0x8000) /* Interrupt on completion of transfer */
86 #define MCF5206E_DCR_EEXT (0x4000) /* Enable External DMA Request */
87 #define MCF5206E_DCR_CS (0x2000) /* Cycle Steal */
88 #define MCF5206E_DCR_AA (0x1000) /* Auto Align */
89 #define MCF5206E_DCR_BWC (0x0E00) /* Bandwidth Control: */
90 #define MCF5206E_DCR_BWC_DISABLE (0x0000) /* Bandwidth Control Disabled */
91 #define MCF5206E_DCR_BWC_512 (0x0200) /* 512 bytes */
92 #define MCF5206E_DCR_BWC_1024 (0x0400) /* 1024 bytes */
93 #define MCF5206E_DCR_BWC_2048 (0x0600) /* 2048 bytes */
94 #define MCF5206E_DCR_BWC_4096 (0x0800) /* 4096 bytes */
95 #define MCF5206E_DCR_BWC_8192 (0x0A00) /* 8192 bytes */
96 #define MCF5206E_DCR_BWC_16384 (0x0C00) /* 16384 bytes */
97 #define MCF5206E_DCR_BWC_32768 (0x0E00) /* 32768 bytes */
98 #define MCF5206E_DCR_SAA (0x0100) /* Single Address Access */
99 #define MCF5206E_DCR_S_RW (0x0080) /* Single Address Access Read/Write Val */
100 #define MCF5206E_DCR_SINC (0x0040) /* Source Increment */
101 #define MCF5206E_DCR_SSIZE (0x0030) /* Source Size: */
102 #define MCF5206E_DCR_SSIZE_LONG (0x0000) /* Longword (4 bytes) */
103 #define MCF5206E_DCR_SSIZE_BYTE (0x0010) /* Byte */
104 #define MCF5206E_DCR_SSIZE_WORD (0x0020) /* Word (2 bytes) */
105 #define MCF5206E_DCR_SSIZE_LINE (0x0030) /* Line (16 bytes) */
106 #define MCF5206E_DCR_DINC (0x0008) /* Destination Increment */
107 #define MCF5206E_DCR_DSIZE (0x0006) /* Destination Size: */
108 #define MCF5206E_DCR_DSIZE_LONG (0x0000) /* Longword (4 bytes) */
109 #define MCF5206E_DCR_DSIZE_BYTE (0x0002) /* Byte */
110 #define MCF5206E_DCR_DSIZE_WORD (0x0004) /* Word (2 bytes) */
111 #define MCF5206E_DCR_DSIZE_LINE (0x0006) /* Line (16 bytes) */
112 #define MCF5206E_DCR_START (0x0001) /* Start Transfer */
113
114 /* DMA Status Register */
115 #define MCF5206E_DSR(mbar,chn) MCF5206E_REG8(mbar,0x210 + ((chn) * 0x40))
116 #define MCF5206E_DSR_CE (0x40) /* Configuration Error has occured */
117 #define MCF5206E_DSR_BES (0x20) /* Bus Error on Source */
118 #define MCF5206E_DSR_BED (0x10) /* Bus Error on Destination */
119 #define MCF5206E_DSR_REQ (0x04) /* Request */
120 #define MCF5206E_DSR_BSY (0x02) /* Busy */
121 #define MCF5206E_DSR_DONE (0x01) /* Transaction Done */
122
123 /* DMA Interrupt Vector Register */
124 #define MCF5206E_DIVR(mbar,chn) MCF5206E_REG8(mbar,0x214 + ((chn) * 0x40))
125
126
127 /*** System Integration Module -- MCF5206e User's Manual, Chapter 8 ***/
128
129 /* MBAR - Module Base Address Register */
130 #define MCF5206E_MBAR_BA (0xFFFFFC00) /* Base Address */
131 #define MCF5206E_MBAR_SC (0x00000010) /* Supervisor Code Space Mask */
132 #define MCF5206E_MBAR_SD (0x00000008) /* Supervisor Data Space Mask */
133 #define MCF5206E_MBAR_UC (0x00000004) /* User Code Space Mask */
134 #define MCF5206E_MBAR_UD (0x00000002) /* User Data Space Mask */
135 #define MCF5206E_MBAR_V (0x00000001) /* Contents of MBAR are valid */
136
137 /* SIM Configuration Register */
138 #define MCF5206E_SIMR(mbar) MCF5206E_REG8(mbar,0x003)
139 #define MCF5206E_SIMR_FRZ1 (0x80) /* Disable Soft Wdog Timer when FREEZE */
140 #define MCF5206E_SIMR_FRZ0 (0x40) /* Disable Bus Timeout monitor when FREEZE*/
141 #define MCF5206E_SIMR_BL (0x01) /* Bus Lock Enable */
142
143 /* Interrupt numbers assignment */
144 #define MCF5206E_INTR_EXT_IRQ1 (1) /* External IRQ1 */
145 #define MCF5206E_INTR_EXT_IPL1 (1) /* External IPL1 */
146 #define MCF5206E_INTR_EXT_IPL2 (2) /* External IPL2 */
147 #define MCF5206E_INTR_EXT_IPL3 (3) /* External IPL3 */
148 #define MCF5206E_INTR_EXT_IRQ4 (4) /* External IRQ4 */
149 #define MCF5206E_INTR_EXT_IPL4 (4) /* External IPL4 */
150 #define MCF5206E_INTR_EXT_IPL5 (5) /* External IPL5 */
151 #define MCF5206E_INTR_EXT_IPL6 (6) /* External IPL6 */
152 #define MCF5206E_INTR_EXT_IRQ7 (7) /* External IRQ7 */
153 #define MCF5206E_INTR_EXT_IPL7 (7) /* External IPL7 */
154 #define MCF5206E_INTR_SWT (8) /* Software Watchdog Timer */
155 #define MCF5206E_INTR_TIMER_1 (9) /* Timer 1 interrupt */
156 #define MCF5206E_INTR_TIMER_2 (10) /* Timer 2 interrupt */
157 #define MCF5206E_INTR_MBUS (11) /* MBUS interrupt */
158 #define MCF5206E_INTR_UART_1 (12) /* UART 1 interrupt */
159 #define MCF5206E_INTR_UART_2 (13) /* UART 2 interrupt */
160 #define MCF5206E_INTR_DMA_0 (14) /* DMA channel 0 interrupt */
161 #define MCF5206E_INTR_DMA_1 (15) /* DMA channel 1 interrupt */
162
163 #define MCF5206E_INTR_BIT(n) (1 << (n))
164
165 /* Interrupt Control Registers (ICR1 - ICR15) */
166 #define MCF5206E_ICR(mbar,n) MCF5206E_REG8(mbar,0x014 + (n) - 1)
167
168 #define MCF5206E_ICR_AVEC (0x80) /* Autovector Enable */
169 #define MCF5206E_ICR_IL (0x1c) /* Interrupt Level */
170 #define MCF5206E_ICR_IL_S (2)
171 #define MCF5206E_ICR_IP (0x03) /* Interrupt Priority */
172 #define MCF5206E_ICR_IP_S (0)
173
174 /* Interrupt Mask Register */
175 #define MCF5206E_IMR(mbar) MCF5206E_REG16(mbar,0x036)
176
177 /* Interrupt Pending Register */
178 #define MCF5206E_IPR(mbar) MCF5206E_REG16(mbar,0x03a)
179
180 /* Reset Status Register */
181 #define MCF5206E_RSR(mbar) MCF5206E_REG8(mbar,0x040)
182 #define MCF5206E_RSR_HRST (0x80) /* Hard Reset or System Reset */
183 #define MCF5206E_RSR_SWTR (0x20) /* Software Watchdog Timer Reset */
184
185 /* System Protection Control Register */
186 #define MCF5206E_SYPCR(mbar) MCF5206E_REG8(mbar,0x041)
187 #define MCF5206E_SYPCR_SWE (0x80) /* Software Watchdog Enable */
188 #define MCF5206E_SYPCR_SWRI (0x40) /* Software Watchdog Reset/Interrupt Sel.*/
189 #define MCF5206E_SYPCR_SWP (0x20) /* Software Watchdog Prescaler */
190 #define MCF5206E_SYPCR_SWT (0x18) /* Software Watchdog Timing: */
191 #define MCF5206E_SYPCR_SWT_S (3)
192 #define MCF5206E_SYPCR_SWT_9 (0x00) /* timeout = (1<<9)/sysfreq */
193 #define MCF5206E_SYPCR_SWT_11 (0x08) /* timeout = (1<<11)/sysfreq */
194 #define MCF5206E_SYPCR_SWT_13 (0x10) /* timeout = (1<<13)/sysfreq */
195 #define MCF5206E_SYPCR_SWT_15 (0x18) /* timeout = (1<<15)/sysfreq */
196 #define MCF5206E_SYPCR_SWT_18 (0x20) /* timeout = (1<<18)/sysfreq */
197 #define MCF5206E_SYPCR_SWT_20 (0x28) /* timeout = (1<<20)/sysfreq */
198 #define MCF5206E_SYPCR_SWT_22 (0x30) /* timeout = (1<<22)/sysfreq */
199 #define MCF5206E_SYPCR_SWT_24 (0x38) /* timeout = (1<<24)/sysfreq */
200 #define MCF5206E_SYPCR_BME (0x04) /* Bus Timeout Monitor Enable */
201 #define MCF5206E_SYPCR_BMT (0x03) /* Bus Monitor Timing: */
202 #define MCF5206E_SYPCR_BMT_1024 (0x00) /* timeout 1024 system clocks */
203 #define MCF5206E_SYPCR_BMT_512 (0x01) /* timeout 512 system clocks */
204 #define MCF5206E_SYPCR_BMT_256 (0x02) /* timeout 256 system clocks */
205 #define MCF5206E_SYPCR_BMT_128 (0x03) /* timeout 128 system clocks */
206
207 /* Software Watchdog Interrupt Vector Register */
208 #define MCF5206E_SWIVR(mbar) MCF5206E_REG8(mbar,0x042)
209
210 /* Software Watchdog Service Register */
211 #define MCF5206E_SWSR(mbar) MCF5206E_REG8(mbar,0x043)
212 #define MCF5206E_SWSR_KEY1 (0x55)
213 #define MCF5206E_SWSR_KEY2 (0xAA)
214
215 /* Pin Assignment Register */
216 #define MCF5206E_PAR(mbar) MCF5206E_REG16(mbar,0x0CA)
217 #define MCF5206E_PAR_PAR9 (0x200)
218 #define MCF5206E_PAR_PAR9_TOUT (0x000) /* Timer 0 output */
219 #define MCF5206E_PAR_PAR9_DREQ1 (0x200) /* DMA channel 1 request */
220 #define MCF5206E_PAR_PAR8 (0x100)
221 #define MCF5206E_PAR_PAR8_TIN0 (0x000) /* Timer 1 input */
222 #define MCF5206E_PAR_PAR8_DREQ0 (0x100) /* DMA channel 0 request */
223 #define MCF5206E_PAR_PAR7 (0x080)
224 #define MCF5206E_PAR_PAR7_RSTO (0x000) /* Reset output */
225 #define MCF5206E_PAR_PAR7_UART2 (0x080) /* UART 2 RTS output */
226 #define MCF5206E_PAR_PAR6 (0x040)
227 #define MCF5206E_PAR_PAR6_IRQ (0x000) /* IRQ7, IRQ4, IRQ1 */
228 #define MCF5206E_PAR_PAR6_IPL (0x040) /* IPL2, IPL1, IPL0 */
229 #define MCF5206E_PAR_PAR5 (0x020)
230 #define MCF5206E_PAR_PAR5_GPIO (0x000) /* General purpose I/O PP7-PP4 */
231 #define MCF5206E_PAR_PAR5_PST (0x020) /* BDM signals PST3-PST0 */
232 #define MCF5206E_PAR_PAR4 (0x010)
233 #define MCF5206E_PAR_PAR4_GPIO (0x000) /* General purpose I/O PP3-PP0 */
234 #define MCF5206E_PAR_PAR4_DDATA (0x010) /* BDM signals DDATA3-DDATA0 */
235 #define MCF5206E_PAR_PAR3 (0x008)
236 #define MCF5206E_PAR_PAR2 (0x004)
237 #define MCF5206E_PAR_PAR1 (0x002)
238 #define MCF5206E_PAR_PAR0 (0x001)
239 #define MCF5206E_PAR_WE0_WE1_WE2_WE3 (0x000)
240 #define MCF5206E_PAR_WE0_WE1_CS5_CS4 (0x001)
241 #define MCF5206E_PAR_WE0_WE1_CS5_A24 (0x002)
242 #define MCF5206E_PAR_WE0_WE1_A25_A24 (0x003)
243 #define MCF5206E_PAR_WE0_CS6_CS5_CS4 (0x004)
244 #define MCF5206E_PAR_WE0_CS6_CS5_A24 (0x005)
245 #define MCF5206E_PAR_WE0_CS6_A25_A24 (0x006)
246 #define MCF5206E_PAR_WE0_A26_A25_A24 (0x007)
247 #define MCF5206E_PAR_CS7_CS6_CS5_CS4 (0x008)
248 #define MCF5206E_PAR_CS7_CS6_CS4_A24 (0x009)
249 #define MCF5206E_PAR_CS7_CS6_A25_A24 (0x00A)
250 #define MCF5206E_PAR_CS7_A26_A25_A24 (0x00B)
251 #define MCF5206E_PAR_A27_A26_A25_A24 (0x00C)
252
253 /* Bus Master Arbitration Control */
254 #define MCF5206E_MARB(mbar) MCF5206E_REG8(mbar,0x007)
255 #define MCF5206E_MARB_NOARB (0x08) /* Arbiter operation disable */
256 #define MCF5206E_MARB_ARBCTRL (0x04) /* Arb. order: Internal DMA, Coldfire */
257
258 /*** Chip Select Module -- MCF5206e User's Manual, Chapter 9 ***/
259
260 /* Chip Select Address Register */
261 #define MCF5206E_CSAR(mbar,bank) MCF5206E_REG16(mbar,0x064 + ((bank) * 12))
262
263 /* Chip Select Mask Register */
264 #define MCF5206E_CSMR(mbar,bank) MCF5206E_REG32(mbar,0x068 + ((bank) * 12))
265 #define MCF5206E_CSMR_BAM (0xffff0000) /* Base Address Mask */
266 #define MCF5206E_CSMR_BAM_S (16)
267 #define MCF5206E_CSMR_MASK_256M (0x0FFF0000)
268 #define MCF5206E_CSMR_MASK_128M (0x07FF0000)
269 #define MCF5206E_CSMR_MASK_64M (0x03FF0000)
270 #define MCF5206E_CSMR_MASK_32M (0x01FF0000)
271 #define MCF5206E_CSMR_MASK_16M (0x00FF0000)
272 #define MCF5206E_CSMR_MASK_8M (0x007F0000)
273 #define MCF5206E_CSMR_MASK_4M (0x003F0000)
274 #define MCF5206E_CSMR_MASK_2M (0x001F0000)
275 #define MCF5206E_CSMR_MASK_1M (0x000F0000)
276 #define MCF5206E_CSMR_MASK_1024K (0x000F0000)
277 #define MCF5206E_CSMR_MASK_512K (0x00070000)
278 #define MCF5206E_CSMR_MASK_256K (0x00030000)
279 #define MCF5206E_CSMR_MASK_128K (0x00010000)
280 #define MCF5206E_CSMR_MASK_64K (0x00000000)
281 #define MCF5206E_CSMR_CI (0x00000020) /* CPU Space Mask (CSMR1 only) */
282 #define MCF5206E_CSMR_SC (0x00000010) /* Supervisor Code Space Mask */
283 #define MCF5206E_CSMR_SD (0x00000008) /* Supervisor Data Space Mask */
284 #define MCF5206E_CSMR_UC (0x00000004) /* User Code Space Mask */
285 #define MCF5206E_CSMR_UD (0x00000002) /* User Data Space Mask */
286
287 /* Chip Select Control Register */
288 #define MCF5206E_CSCR(mbar,bank) MCF5206E_REG16(mbar,0x6E + ((bank) * 12))
289 #define MCF5206E_CSCR_WS (0x3c00) /* Wait States */
290 #define MCF5206E_CSCR_WS_S (10)
291 #define MCF5206E_CSCR_WS0 (0x0000) /* 0 Wait States */
292 #define MCF5206E_CSCR_WS1 (0x0400) /* 1 Wait States */
293 #define MCF5206E_CSCR_WS2 (0x0800) /* 2 Wait States */
294 #define MCF5206E_CSCR_WS3 (0x0C00) /* 3 Wait States */
295 #define MCF5206E_CSCR_WS4 (0x1000) /* 4 Wait States */
296 #define MCF5206E_CSCR_WS5 (0x1400) /* 5 Wait States */
297 #define MCF5206E_CSCR_WS6 (0x1800) /* 6 Wait States */
298 #define MCF5206E_CSCR_WS7 (0x1C00) /* 7 Wait States */
299 #define MCF5206E_CSCR_WS8 (0x2000) /* 8 Wait States */
300 #define MCF5206E_CSCR_WS9 (0x2400) /* 9 Wait States */
301 #define MCF5206E_CSCR_WS10 (0x2800) /* 10 Wait States */
302 #define MCF5206E_CSCR_WS11 (0x2C00) /* 11 Wait States */
303 #define MCF5206E_CSCR_WS12 (0x3000) /* 12 Wait States */
304 #define MCF5206E_CSCR_WS13 (0x3400) /* 13 Wait States */
305 #define MCF5206E_CSCR_WS14 (0x3800) /* 14 Wait States */
306 #define MCF5206E_CSCR_WS15 (0x3C00) /* 15 Wait States */
307 #define MCF5206E_CSCR_BRST (0x0200) /* Burst Enable */
308 #define MCF5206E_CSCR_AA (0x0100) /* Coldfire Core Auto Acknowledge
309  Enable */
310 #define MCF5206E_CSCR_PS (0x00C0) /* Port Size */
311 #define MCF5206E_CSCR_PS_S (6)
312 #define MCF5206E_CSCR_PS_32 (0x0000) /* Port Size = 32 bits */
313 #define MCF5206E_CSCR_PS_8 (0x0040) /* Port Size = 8 bits */
314 #define MCF5206E_CSCR_PS_16 (0x0080) /* Port Size = 16 bits */
315 #define MCF5206E_CSCR_EMAA (0x0020) /* External Master Automatic Acknowledge
316  Enable */
317 #define MCF5206E_CSCR_ASET (0x0010) /* Address Setup Enable */
318 #define MCF5206E_CSCR_WRAH (0x0008) /* Write Address Hold Enable */
319 #define MCF5206E_CSCR_RDAH (0x0004) /* Read Address Hold Enable */
320 #define MCF5206E_CSCR_WR (0x0002) /* Write Enable */
321 #define MCF5206E_CSCR_RD (0x0001) /* Read Enable */
322
323 /* Default Memory Control Register */
324 #define MCF5206E_DMCR(mbar) MCF5206E_REG16(mbar, 0x0C6)
325
326 /*** Parallel Port (GPIO) Module -- MCF5206e User's Manual, Chapter 10 ***/
327
328 /* Port A Data Direction Register */
329 #define MCF5206E_PPDDR(mbar) MCF5206E_REG8(mbar,0x1C5)
330
331 /* Port A Data Register */
332 #define MCF5206E_PPDAT(mbar) MCF5206E_REG8(mbar,0x1C9)
333
334 #define MCF5206E_PP_DAT0 (0x01)
335 #define MCF5206E_PP_DAT1 (0x02)
336 #define MCF5206E_PP_DAT2 (0x04)
337 #define MCF5206E_PP_DAT3 (0x08)
338 #define MCF5206E_PP_DAT4 (0x10)
339 #define MCF5206E_PP_DAT5 (0x20)
340 #define MCF5206E_PP_DAT6 (0x40)
341 #define MCF5206E_PP_DAT7 (0x80)
342
343 /*** DRAM Controller -- MCF5206e User's Manual, Chapter 11 ***/
344
345 /* DRAM Controller Refresh Register */
346 #define MCF5206E_DCRR(mbar) MCF5206E_REG16(mbar,0x046)
347
348 /* DRAM Controller Timing Register */
349 #define MCF5206E_DCTR(mbar) MCF5206E_REG16(mbar,0x04A)
350 #define MCF5206E_DCTR_DAEM (0x8000) /* Drive Multiplexed Address During
351  External Master DRAM Transfers */
352 #define MCF5206E_DCTR_EDO (0x4000) /* Extended Data-Out Enable */
353 #define MCF5206E_DCTR_RCD (0x1000) /* RAS-to-CAS Delay Time */
354 #define MCF5206E_DCTR_RSH (0x0600) /* RAS Hold Time */
355 #define MCF5206E_DCTR_RSH_0 (0x0000) /* See User's Manual for details */
356 #define MCF5206E_DCTR_RSH_1 (0x0200)
357 #define MCF5206E_DCTR_RSH_2 (0x0400)
358 #define MCF5206E_DCTR_RP (0x0060) /* RAS Precharge Time */
359 #define MCF5206E_DCTR_RP_15 (0x0000) /* RAS Precharges for 1.5 system clks */
360 #define MCF5206E_DCTR_RP_25 (0x0020) /* RAS Precharges for 2.5 system clks */
361 #define MCF5206E_DCTR_RP_35 (0x0040) /* RAS Precharges for 3.5 system clks */
362 #define MCF5206E_DCTR_CAS (0x0008) /* Column Address Strobe Time */
363 #define MCF5206E_DCTR_CP (0x0002) /* CAS Precharge Time */
364 #define MCF5206E_DCTR_CSR (0x0001) /* CAS Setup Time for CAS before RAS
365  refresh */
366
367 /* DRAM Controller Address Registers */
368 #define MCF5206E_DCAR(mbar,bank) MCF5206E_REG16(mbar,0x4C + ((bank) * 12))
369
370 /* DRAM Controller Mask Registers */
371 #define MCF5206E_DCMR(mbar,bank) MCF5206E_REG32(mbar,0x50 + ((bank) * 12))
372 #define MCF5206E_DCMR_BAM (0xffff0000) /* Base Address Mask */
373 #define MCF5206E_DCMR_BAM_S (16)
374 #define MCF5206E_DCMR_MASK_256M (0x0FFE0000)
375 #define MCF5206E_DCMR_MASK_128M (0x07FE0000)
376 #define MCF5206E_DCMR_MASK_64M (0x03FE0000)
377 #define MCF5206E_DCMR_MASK_32M (0x01FE0000)
378 #define MCF5206E_DCMR_MASK_16M (0x00FE0000)
379 #define MCF5206E_DCMR_MASK_8M (0x007E0000)
380 #define MCF5206E_DCMR_MASK_4M (0x003E0000)
381 #define MCF5206E_DCMR_MASK_2M (0x001E0000)
382 #define MCF5206E_DCMR_MASK_1M (0x000E0000)
383 #define MCF5206E_DCMR_MASK_1024K (0x000E0000)
384 #define MCF5206E_DCMR_MASK_512K (0x00060000)
385 #define MCF5206E_DCMR_MASK_256K (0x00020000)
386 #define MCF5206E_DCMR_MASK_128K (0x00000000)
387 #define MCF5206E_DCMR_SC (0x00000010) /* Supervisor Code Space Mask */
388 #define MCF5206E_DCMR_SD (0x00000008) /* Supervisor Data Space Mask */
389 #define MCF5206E_DCMR_UC (0x00000004) /* User Code Space Mask */
390 #define MCF5206E_DCMR_UD (0x00000002) /* User Data Space Mask */
391
392 /* DRAM Controller Control Register */
393 #define MCF5206E_DCCR(mbar,bank) MCF5206E_REG8(mbar, 0x57 + ((bank) * 12))
394 #define MCF5206E_DCCR_PS (0xC0) /* Port Size */
395 #define MCF5206E_DCCR_PS_32 (0x00) /* 32 bit Port Size */
396 #define MCF5206E_DCCR_PS_8 (0x40) /* 8 bit Port Size */
397 #define MCF5206E_DCCR_PS_16 (0x80) /* 16 bit Port Size */
398 #define MCF5206E_DCCR_BPS (0x30) /* Bank Page Size */
399 #define MCF5206E_DCCR_BPS_512 (0x00) /* 512 Byte Page Size */
400 #define MCF5206E_DCCR_BPS_1K (0x10) /* 1 KByte Page Size */
401 #define MCF5206E_DCCR_BPS_2K (0x20) /* 2 KByte Page Size */
402 #define MCF5206E_DCCR_PM (0x0C) /* Page Mode Select */
403 #define MCF5206E_DCCR_PM_NORMAL (0x00) /* Normal Mode */
404 #define MCF5206E_DCCR_PM_BURSTP (0x04) /* Burst Page Mode */
405 #define MCF5206E_DCCR_PM_FASTP (0x0C) /* Fast Page Mode */
406 #define MCF5206E_DCCR_WR (0x02) /* Write Enable */
407 #define MCF5206E_DCCR_RD (0x01) /* Read Enable */
408
409 /*** UART Module -- MCF5206e User's Manual, Chapter 12 ***/
410
411 #define MCF5206E_UART_CHANNELS (2)
412 /* UART Mode Register */
413 #define MCF5206E_UMR(mbar,n) MCF5206E_REG8(mbar,0x140 + (((n)-1) * 0x40))
414 #define MCF5206E_UMR1_RXRTS (0x80) /* Receiver Request-to-Send
415  Control */
416 #define MCF5206E_UMR1_RXIRQ (0x40) /* Receiver Interrupt Select */
417 #define MCF5206E_UMR1_ERR (0x20) /* Error Mode */
418 #define MCF5206E_UMR1_PM (0x1C) /* Parity Mode, Parity Type */
419 #define MCF5206E_UMR1_PM_EVEN (0x00) /* Even Parity */
420 #define MCF5206E_UMR1_PM_ODD (0x04) /* Odd Parity */
421 #define MCF5206E_UMR1_PM_FORCE_LOW (0x08) /* Force parity low */
422 #define MCF5206E_UMR1_PM_FORCE_HIGH (0x0C) /* Force parity high */
423 #define MCF5206E_UMR1_PM_NO_PARITY (0x10) /* No Parity */
424 #define MCF5206E_UMR1_PM_MULTI_DATA (0x18) /* Multidrop mode - data char */
425 #define MCF5206E_UMR1_PM_MULTI_ADDR (0x1C) /* Multidrop mode - addr char */
426 #define MCF5206E_UMR1_BC (0x03) /* Bits per Character */
427 #define MCF5206E_UMR1_BC_5 (0x00) /* 5 bits per character */
428 #define MCF5206E_UMR1_BC_6 (0x01) /* 6 bits per character */
429 #define MCF5206E_UMR1_BC_7 (0x02) /* 7 bits per character */
430 #define MCF5206E_UMR1_BC_8 (0x03) /* 8 bits per character */
431
432 #define MCF5206E_UMR2_CM (0xC0) /* Channel Mode */
433 #define MCF5206E_UMR2_CM_NORMAL (0x00) /* Normal Mode */
434 #define MCF5206E_UMR2_CM_AUTO_ECHO (0x40) /* Automatic Echo Mode */
435 #define MCF5206E_UMR2_CM_LOCAL_LOOP (0x80) /* Local Loopback Mode */
436 #define MCF5206E_UMR2_CM_REMOTE_LOOP (0xC0) /* Remote Loopback Modde */
437 #define MCF5206E_UMR2_TXRTS (0x20) /* Transmitter Ready-to-Send op */
438 #define MCF5206E_UMR2_TXCTS (0x10) /* Transmitter Clear-to-Send op */
439 #define MCF5206E_UMR2_SB (0x0F) /* Stop Bit Length */
440 #define MCF5206E_UMR2_SB_1 (0x07) /* 1 Stop Bit for 6-8 bits char */
441 #define MCF5206E_UMR2_SB_15 (0x08) /* 1.5 Stop Bits for 6-8 bits chr*/
442 #define MCF5206E_UMR2_SB_2 (0x0F) /* 2 Stop Bits for 6-8 bits char */
443 #define MCF5206E_UMR2_SB5_1 (0x00) /* 1 Stop Bits for 5 bit char */
444 #define MCF5206E_UMR2_SB5_15 (0x07) /* 1.5 Stop Bits for 5 bit char */
445 #define MCF5206E_UMR2_SB5_2 (0x0F) /* 2 Stop Bits for 5 bit char */
446
447 /* UART Status Register (read only) */
448 #define MCF5206E_USR(mbar,n) MCF5206E_REG8(mbar,0x144 + (((n)-1) * 0x40))
449 #define MCF5206E_USR_RB (0x80) /* Received Break */
450 #define MCF5206E_USR_FE (0x40) /* Framing Error */
451 #define MCF5206E_USR_PE (0x20) /* Parity Error */
452 #define MCF5206E_USR_OE (0x10) /* Overrun Error */
453 #define MCF5206E_USR_TXEMP (0x08) /* Transmitter Empty */
454 #define MCF5206E_USR_TXRDY (0x04) /* Transmitter Ready */
455 #define MCF5206E_USR_FFULL (0x02) /* FIFO Full */
456 #define MCF5206E_USR_RXRDY (0x01) /* Receiver Ready */
457
458 /* UART Clock Select Register (write only) */
459 #define MCF5206E_UCSR(mbar,n) MCF5206E_REG8(mbar,0x144 + (((n)-1) * 0x40))
460 #define MCF5206E_UCSR_RCS (0xF0) /* Receiver Clock Select */
461 #define MCF5206E_UCSR_RCS_TIMER (0xD0) /* Timer */
462 #define MCF5206E_UCSR_RCS_EXT16 (0xE0) /* External clk x16 */
463 #define MCF5206E_UCSR_RCS_EXT (0xF0) /* External clk x1 */
464 #define MCF5206E_UCSR_TCS (0x0F) /* Transmitter Clock Select */
465 #define MCF5206E_UCSR_TCS_TIMER (0x0D) /* Timer */
466 #define MCF5206E_UCSR_TCS_EXT16 (0x0E) /* External clk x16 */
467 #define MCF5206E_UCSR_TCS_EXT (0x0F) /* External clk x1 */
468
469 /* UART Command Register (write only) */
470 #define MCF5206E_UCR(mbar,n) MCF5206E_REG8(mbar,0x148 + (((n)-1) * 0x40))
471 #define MCF5206E_UCR_MISC (0x70) /* Miscellaneous Commands: */
472 #define MCF5206E_UCR_MISC_NOP (0x00) /* No Command */
473 #define MCF5206E_UCR_MISC_RESET_MR (0x10) /* Reset Mode Register Ptr */
474 #define MCF5206E_UCR_MISC_RESET_RX (0x20) /* Reset Receiver */
475 #define MCF5206E_UCR_MISC_RESET_TX (0x30) /* Reset Transmitter */
476 #define MCF5206E_UCR_MISC_RESET_ERR (0x40) /* Reset Error Status */
477 #define MCF5206E_UCR_MISC_RESET_BRK (0x50) /* Reset Break-Change Interrupt */
478 #define MCF5206E_UCR_MISC_START_BRK (0x60) /* Start Break */
479 #define MCF5206E_UCR_MISC_STOP_BRK (0x70) /* Stop Break */
480 #define MCF5206E_UCR_TC (0x0C) /* Transmitter Commands: */
481 #define MCF5206E_UCR_TC_NOP (0x00) /* No Action Taken */
482 #define MCF5206E_UCR_TC_ENABLE (0x04) /* Transmitter Enable */
483 #define MCF5206E_UCR_TC_DISABLE (0x08) /* Transmitter Disable */
484 #define MCF5206E_UCR_RC (0x03) /* Receiver Commands: */
485 #define MCF5206E_UCR_RC_NOP (0x00) /* No Action Taken */
486 #define MCF5206E_UCR_RC_ENABLE (0x01) /* Receiver Enable */
487 #define MCF5206E_UCR_RC_DISABLE (0x02) /* Receiver Disable */
488
489 /* UART Receive Buffer (read only) */
490 #define MCF5206E_URB(mbar,n) MCF5206E_REG8(mbar,0x14C + (((n)-1) * 0x40))
491
492 /* UART Transmit Buffer (write only) */
493 #define MCF5206E_UTB(mbar,n) MCF5206E_REG8(mbar,0x14C + (((n)-1) * 0x40))
494
495 /* UART Input Port Change Register (read only) */
496 #define MCF5206E_UIPCR(mbar,n) MCF5206E_REG8(mbar,0x150 + (((n)-1) * 0x40))
497 #define MCF5206E_UIPCR_COS (0x10) /* Change of State at CTS input */
498 #define MCF5206E_UIPCR_CTS (0x01) /* Current State of CTS */
499
500 /* UART Auxiliary Control Register (write only) */
501 #define MCF5206E_UACR(mbar,n) MCF5206E_REG8(mbar,0x150 + (((n)-1) * 0x40))
502 #define MCF5206E_UACR_IEC (0x01) /* Input Enable Control - generate interrupt
503  on CTS change */
504
505 /* UART Interrupt Status Register (read only) */
506 #define MCF5206E_UISR(mbar,n) MCF5206E_REG8(mbar,0x154 + (((n)-1) * 0x40))
507 #define MCF5206E_UISR_COS (0x80) /* Change of State has occured at CTS */
508 #define MCF5206E_UISR_DB (0x04) /* Delta Break */
509 #define MCF5206E_UISR_RXRDY (0x02) /* Receiver Ready or FIFO Full */
510 #define MCF5206E_UISR_TXRDY (0x01) /* Transmitter Ready */
511
512 /* UART Interrupt Mask Register (write only) */
513 #define MCF5206E_UIMR(mbar,n) MCF5206E_REG8(mbar,0x154 + (((n)-1) * 0x40))
514 #define MCF5206E_UIMR_COS (0x80) /* Change of State interrupt enable */
515 #define MCF5206E_UIMR_DB (0x04) /* Delta Break interrupt enable */
516 #define MCF5206E_UIMR_FFULL (0x02) /* FIFO Full interrupt enable */
517 #define MCF5206E_UIMR_TXRDY (0x01) /* Transmitter Ready Interrupt enable */
518
519 /* UART Baud Rate Generator Prescale MSB Register */
520 #define MCF5206E_UBG1(mbar,n) MCF5206E_REG8(mbar,0x158 + (((n)-1) * 0x40))
521
522 /* UART Baud Rate Generator Prescale LSB Register */
523 #define MCF5206E_UBG2(mbar,n) MCF5206E_REG8(mbar,0x15C + (((n)-1) * 0x40))
524
525 /* UART Interrupt Vector Register */
526 #define MCF5206E_UIVR(mbar,n) MCF5206E_REG8(mbar,0x170 + (((n)-1) * 0x40))
527
528 /* UART Input Port Register (read only) */
529 #define MCF5206E_UIP(mbar,n) MCF5206E_REG8(mbar,0x174 + (((n)-1) * 0x40))
530 #define MCF5206E_UIP_CTS (0x01) /* Current state of CTS input */
531
532 /* UART Output Port Bit Set Command (address-triggered command, write) */
533 #define MCF5206E_UOP1(mbar,n) MCF5206E_REG8(mbar,0x178 + (((n)-1) * 0x40))
534
535 /* UART Output Port Bit Reset Command (address-triggered command, write */
536 #define MCF5206E_UOP0(mbar,n) MCF5206E_REG8(mbar,0x17C + (((n)-1) * 0x40))
537
538 /*** M-BUS (I2C) Module -- MCF5206e User's Manual, Chapter 13 ***/
539
540 /* M-Bus Address Register */
541 #define MCF5206E_MADR(mbar) MCF5206E_REG8(mbar, 0x1E0)
542
543 /* M-Bus Frequency Divider Register */
544 #define MCF5206E_MFDR(mbar) MCF5206E_REG8(mbar, 0x1E4)
545
546 /* M-Bus Control Register */
547 #define MCF5206E_MBCR(mbar) MCF5206E_REG8(mbar, 0x1E8)
548 #define MCF5206E_MBCR_MEN (0x80) /* M-Bus Enable */
549 #define MCF5206E_MBCR_MIEN (0x40) /* M-Bus Interrupt Enable */
550 #define MCF5206E_MBCR_MSTA (0x20) /* Master Mode Selection */
551 #define MCF5206E_MBCR_MTX (0x10) /* Transmit Mode Selection */
552 #define MCF5206E_MBCR_TXAK (0x08) /* Transmit Acknowledge Enable */
553 #define MCF5206E_MBCR_RSTA (0x04) /* Repeat Start */
554
555 /* M-Bus Status Register */
556 #define MCF5206E_MBSR(mbar) MCF5206E_REG8(mbar, 0x1EC)
557 #define MCF5206E_MBSR_MCF (0x80) /* Data Transferring Bit */
558 #define MCF5206E_MBSR_MAAS (0x40) /* Addressed as a Slave Bit */
559 #define MCF5206E_MBSR_MBB (0x20) /* Bus Busy Bit */
560 #define MCF5206E_MBSR_MAL (0x10) /* Arbitration Lost */
561 #define MCF5206E_MBSR_SRW (0x04) /* Slave Read/Write */
562 #define MCF5206E_MBSR_MIF (0x02) /* MBus Interrupt pending */
563 #define MCF5206E_MBSR_RXAK (0x01) /* Received Acknowledge */
564
565 /* M-Bus Data I/O Register */
566 #define MCF5206E_MBDR(mbar) MCF5206E_REG8(mbar, 0x1F0)
567
568 /*** Timer Module -- MCF5206e User's Manual, Chapter 14 ***/
569
570 /* Timer Mode Register */
571 #define MCF5206E_TMR(mbar,n) MCF5206E_REG16(mbar, 0x100 + (((n)-1)*0x20))
572 #define MCF5206E_TMR_PS (0xFF00) /* Prescaler Value */
573 #define MCF5206E_TMR_PS_S (8)
574 #define MCF5206E_TMR_CE (0x00C0) /* Capture Edge and Enable
575  Interrupt */
576 #define MCF5206E_TMR_CE_ANY (0x00C0) /* Capture on any edge */
577 #define MCF5206E_TMR_CE_FALL (0x0080) /* Capture on falling edge only */
578 #define MCF5206E_TMR_CE_RISE (0x0040) /* Capture on rising edge only */
579 #define MCF5206E_TMR_CE_NONE (0x0000) /* Disable Interrupt on capture
580  event */
581 #define MCF5206E_TMR_OM (0x0020) /* Output Mode - Toggle output */
582 #define MCF5206E_TMR_ORI (0x0010) /* Output Reference Interrupt
583  Enable */
584 #define MCF5206E_TMR_FRR (0x0008) /* Free Run/Restart */
585 #define MCF5206E_TMR_ICLK (0x0006) /* Input Clock Source */
586 #define MCF5206E_TMR_ICLK_TIN (0x0006) /* TIN pin (falling edge) */
587 #define MCF5206E_TMR_ICLK_DIV16 (0x0004) /* Master system clock divided
588  by 16 */
589 #define MCF5206E_TMR_ICLK_MSCLK (0x0002) /* Master System Clock */
590 #define MCF5206E_TMR_ICLK_STOP (0x0000) /* Stops counter */
591 #define MCF5206E_TMR_RST (0x0001) /* Reset/Enable Timer */
592
593 /* Timer Reference Register */
594 #define MCF5206E_TRR(mbar,n) MCF5206E_REG16(mbar, 0x104 + (((n)-1)*0x20))
595
596 /* Timer Capture Register */
597 #define MCF5206E_TCR(mbar,n) MCF5206E_REG16(mbar, 0x108 + (((n)-1)*0x20))
598
599 /* Timer Counter Register */
600 #define MCF5206E_TCN(mbar,n) MCF5206E_REG16(mbar, 0x10C + (((n)-1)*0x20))
601
602 /* Timer Event Register */
603 #define MCF5206E_TER(mbar,n) MCF5206E_REG8(mbar, 0x111 + (((n)-1)*0x20))
604 #define MCF5206E_TER_REF (0x02) /* Output Reference Event */
605 #define MCF5206E_TER_CAP (0x01) /* Capture Event */
606
607
608
609 #endif
