RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
shared
dev
serial
mc68681_p.h
1
2
3
* COPYRIGHT (c) 1989-1999.
4
* On-Line Applications Research Corporation (OAR).
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef _MC68681_P_H_
12
#define _MC68681_P_H_
13
14
#ifdef __cplusplus
15
extern
"C"
16
#endif
17
18
19
* Define MC68681_STATIC to nothing while debugging so the entry points
20
* will show up in the symbol table.
21
22
23
#define MC68681_STATIC
24
25
/* #define MC68681_STATIC static */
26
27
28
* mc68681 register offsets Read/Write Addresses
29
30
31
#define MC68681_MODE_REG_1A 0
/* MR1A-MR Prior to Read */
32
#define MC68681_MODE_REG_2A 0
/* MR2A-MR After Read */
33
34
#define MC68681_COUNT_MODE_CURRENT_MSB 6
/* CTU */
35
#define MC68681_COUNTER_TIMER_UPPER_REG 6
/* CTU */
36
#define MC68681_COUNT_MODE_CURRENT_LSB 7
/* CTL */
37
#define MC68681_COUNTER_TIMER_LOWER_REG 7
/* CTL */
38
#define MC68681_INTERRUPT_VECTOR_REG 12
/* IVR */
39
40
#define MC68681_MODE_REG_1B 8
/* MR1B-MR Prior to Read */
41
#define MC68681_MODE_REG_2B 8
/* MR2BA-MR After Read */
42
43
44
* mc68681 register offsets Read Only Addresses
45
46
47
#define MC68681_STATUS_REG_A 1
/* SRA */
48
#define MC68681_MASK_ISR_REG 2
/* MISR */
49
#define MC68681_RECEIVE_BUFFER_A 3
/* RHRA */
50
#define MC68681_INPUT_PORT_CHANGE_REG 4
/* IPCR */
51
#define MC68681_INTERRUPT_STATUS_REG 5
/* ISR */
52
#define MC68681_STATUS_REG_B 9
/* SRB */
53
#define MC68681_RECEIVE_BUFFER_B 11
/* RHRB */
54
#define MC68681_INPUT_PORT 13
/* IP */
55
#define MC68681_START_COUNT_CMD 14
/* SCC */
56
#define MC68681_STOP_COUNT_CMD 15
/* STC */
57
58
59
* mc68681 register offsets Write Only Addresses
60
61
62
#define MC68681_CLOCK_SELECT_REG_A 1
/* CSRA */
63
#define MC68681_COMMAND_REG_A 2
/* CRA */
64
#define MC68681_TRANSMIT_BUFFER_A 3
/* THRA */
65
#define MC68681_AUX_CTRL_REG 4
/* ACR */
66
#define MC68681_INTERRUPT_MASK_REG 5
/* IMR */
67
#define MC68681_CLOCK_SELECT_REG_B 9
/* CSRB */
68
#define MC68681_COMMAND_REG_B 10
/* CRB */
69
#define MC68681_TRANSMIT_BUFFER_B 11
/* THRB */
70
#define MC68681_OUTPUT_PORT_CONFIG_REG 13
/* OPCR */
71
#define MC68681_OUTPUT_PORT_SET_REG 14
/* SOPBC */
72
#define MC68681_OUTPUT_PORT_RESET_BITS 15
/* COPBC */
73
74
75
* DUART Command Register Definitions:
76
77
* MC68681_COMMAND_REG_A,MC68681_COMMAND_REG_B
78
79
80
#define MC68681_MODE_REG_ENABLE_RX 0x01
81
#define MC68681_MODE_REG_DISABLE_RX 0x02
82
#define MC68681_MODE_REG_ENABLE_TX 0x04
83
#define MC68681_MODE_REG_DISABLE_TX 0x08
84
#define MC68681_MODE_REG_RESET_MR_PTR 0x10
85
#define MC68681_MODE_REG_RESET_RX 0x20
86
#define MC68681_MODE_REG_RESET_TX 0x30
87
#define MC68681_MODE_REG_RESET_ERROR 0x40
88
#define MC68681_MODE_REG_RESET_BREAK 0x50
89
#define MC68681_MODE_REG_START_BREAK 0x60
90
#define MC68681_MODE_REG_STOP_BREAK 0x70
91
#define MC68681_MODE_REG_SET_RX_BRG 0x80
92
#define MC68681_MODE_REG_CLEAR_RX_BRG 0x90
93
#define MC68681_MODE_REG_SET_TX_BRG 0xa0
94
#define MC68681_MODE_REG_CLEAR_TX_BRG 0xb0
95
#define MC68681_MODE_REG_SET_STANDBY 0xc0
96
#define MC68681_MODE_REG_SET_ACTIVE 0xd0
97
98
99
* Mode Register Definitions
100
101
* MC68681_MODE_REG_1A
102
* MC68681_MODE_REG_1B
103
104
105
#define MC68681_5BIT_CHARS 0x00
106
#define MC68681_6BIT_CHARS 0x01
107
#define MC68681_7BIT_CHARS 0x02
108
#define MC68681_8BIT_CHARS 0x03
109
110
#define MC68681_ODD_PARITY 0x00
111
#define MC68681_EVEN_PARITY 0x04
112
113
#define MC68681_WITH_PARITY 0x00
114
#define MC68681_FORCE_PARITY 0x08
115
#define MC68681_NO_PARITY 0x10
116
#define MC68681_MULTI_DROP 0x18
117
118
#define MC68681_ERR_MODE_CHAR 0x00
119
#define MC68681_ERR_MODE_BLOCK 0x20
120
121
#define MC68681_RX_INTR_RX_READY 0x00
122
#define MC68681_RX_INTR_FFULL 0x40
123
124
#define MC68681_NO_RX_RTS_CTL 0x00
125
#define MC68681_RX_RTS_CTRL 0x80
126
127
128
129
130
* MC68681_MODE_REG_2A
131
* MC68681_MODE_REG_2B
132
133
134
#define MC68681_STOP_BIT_LENGTH__563 0x00
135
#define MC68681_STOP_BIT_LENGTH__625 0x01
136
#define MC68681_STOP_BIT_LENGTH__688 0x02
137
#define MC68681_STOP_BIT_LENGTH__75 0x03
138
#define MC68681_STOP_BIT_LENGTH__813 0x04
139
#define MC68681_STOP_BIT_LENGTH__875 0x05
140
#define MC68681_STOP_BIT_LENGTH__938 0x06
141
#define MC68681_STOP_BIT_LENGTH_1 0x07
142
#define MC68681_STOP_BIT_LENGTH_1_563 0x08
143
#define MC68681_STOP_BIT_LENGTH_1_625 0x09
144
#define MC68681_STOP_BIT_LENGTH_1_688 0x0a
145
#define MC68681_STOP_BIT_LENGTH_1_75 0x0b
146
#define MC68681_STOP_BIT_LENGTH_1_813 0x0c
147
#define MC68681_STOP_BIT_LENGTH_1_875 0x0d
148
#define MC68681_STOP_BIT_LENGTH_1_938 0x0e
149
#define MC68681_STOP_BIT_LENGTH_2 0x0f
150
151
#define MC68681_CTS_ENABLE_TX 0x10
152
#define MC68681_TX_RTS_CTRL 0x20
153
154
#define MC68681_CHANNEL_MODE_NORMAL 0x00
155
#define MC68681_CHANNEL_MODE_ECHO 0x40
156
#define MC68681_CHANNEL_MODE_LOCAL_LOOP 0x80
157
#define MC68681_CHANNEL_MODE_REMOTE_LOOP 0xc0
158
159
160
* Status Register Definitions
161
162
* MC68681_STATUS_REG_A, MC68681_STATUS_REG_B
163
164
165
#define MC68681_RX_READY 0x01
166
#define MC68681_FFULL 0x02
167
#define MC68681_TX_READY 0x04
168
#define MC68681_TX_EMPTY 0x08
169
#define MC68681_OVERRUN_ERROR 0x10
170
#define MC68681_PARITY_ERROR 0x20
171
#define MC68681_FRAMING_ERROR 0x40
172
#define MC68681_RECEIVED_BREAK 0x80
173
174
#define MC68681_RX_ERRORS \
175
(MC68681_OVERRUN_ERROR|MC68681_PARITY_ERROR| \
176
MC68681_FRAMING_ERROR|MC68681_RECEIVED_BREAK)
177
178
179
* Interupt Status Register Definitions.
180
181
* MC68681_INTERRUPT_STATUS_REG
182
183
184
185
* Interupt Mask Register Definitions
186
187
* MC68681_INTERRUPT_MASK_REG
188
189
190
/* These are passed to mc68681_build_imr */
191
#define MC68681_IR_TX_READY 0x01
192
#define MC68681_IR_RX_READY 0x02
193
#define MC68681_IR_BREAK 0x04
194
#define MC68681_IMR_ENABLE_ALL 0x07
195
#define MC68681_IMR_DISABLE_ALL 0x00
196
#define MC68681_IMR_ENABLE_ALL_EXCEPT_TX 0x06
197
198
#define MC68681_IR_TX_READY_A 0x01
199
#define MC68681_IR_RX_READY_A 0x02
200
#define MC68681_IR_BREAK_A 0x04
201
#define MC68681_IR_COUNTER_READY 0x08
202
#define MC68681_IR_TX_READY_B 0x10
203
#define MC68681_IR_RX_READY_B 0x20
204
#define MC68681_IR_BREAK_B 0x40
205
#define MC68681_IR_INPUT_PORT_CHANGE 0x80
206
207
208
* Status Register Definitions.
209
210
* MC68681_STATUS_REG_A,MC68681_STATUS_REG_B
211
212
213
#define MC68681_STATUS_RXRDY 0x01
214
#define MC68681_STATUS_FFULL 0x02
215
#define MC68681_STATUS_TXRDY 0x04
216
#define MC68681_STATUS_TXEMT 0x08
217
#define MC68681_STATUS_OVERRUN_ERROR 0x10
218
#define MC68681_STATUS_PARITY_ERROR 0x20
219
#define MC68681_STATUS_FRAMING_ERROR 0x40
220
#define MC68681_STATUS_RECEIVED_BREAK 0x80
221
222
223
* Definitions for the Interrupt Vector Register:
224
225
* MC68681_INTERRUPT_VECTOR_REG
226
227
228
#define MC68681_INTERRUPT_VECTOR_INIT 0x0f
229
230
231
* Definitions for the Auxiliary Control Register
232
233
* MC68681_AUX_CTRL_REG
234
235
236
#define MC68681_AUX_BRG_SET1 0x00
237
#define MC68681_AUX_BRG_SET2 0x80
238
239
240
* Per chip context control
241
242
243
typedef
struct
_mc68681_context
244
245
int
mate;
246
unsigned
char
imr;
247
mc68681_context
248
249
250
* Driver functions
251
252
MC68681_STATIC
void
mc68681_initialize_context(
253
int
minor,
254
mc68681_context
*pmc68681Context
255
256
257
MC68681_STATIC
bool
mc68681_probe(
int
minor);
258
259
MC68681_STATIC
int
mc68681_set_attributes(
260
int
minor,
261
const
struct
termios *t
262
263
264
MC68681_STATIC
void
mc68681_init(
int
minor);
265
266
MC68681_STATIC
int
mc68681_open(
267
int
major,
268
int
minor,
269
void
* arg
270
271
272
MC68681_STATIC
int
mc68681_close(
273
int
major,
274
int
minor,
275
void
* arg
276
277
278
MC68681_STATIC
void
mc68681_write_polled(
279
int
minor,
280
char
cChar
281
282
283
MC68681_STATIC
void
mc68681_initialize_interrupts(
int
minor);
284
285
MC68681_STATIC ssize_t mc68681_write_support_int(
286
int
minor,
287
const
char
*buf,
288
size_t
len
289
290
291
MC68681_STATIC ssize_t mc68681_write_support_polled(
292
int
minor,
293
const
char
*buf,
294
size_t
len
295
296
297
MC68681_STATIC
int
mc68681_inbyte_nonblocking_polled(
298
int
minor
299
300
301
MC68681_STATIC
unsigned
int
mc68681_build_imr(
302
int
minor,
303
int
enable_flag
304
305
306
MC68681_STATIC
void
mc68681_process(
307
int
minor
308
309
310
MC68681_STATIC
void
mc68681_enable_interrupts(
311
int
minor,
312
int
imr_mask
313
314
315
MC68681_STATIC
rtems_isr
mc68681_isr(
316
rtems_vector_number
vector
317
318
319
#ifdef __cplusplus
320
321
#endif
322
323
#endif
/* _MC68681_P_H_ */
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
rtems_isr
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition:
intr.h:52
_mc68681_context
Definition:
mc68681_p.h:243
