RTEMS  5.1
gdb_if.h
1
9 /*
10  * THIS SOFTWARE IS NOT COPYRIGHTED
11  *
12  * The following software is offered for use in the public domain.
13  * There is no warranty with regard to this software or its performance
14  * and the user must accept the software "AS IS" with all faults.
15  *
16  * THE CONTRIBUTORS DISCLAIM ANY WARRANTIES, EXPRESS OR IMPLIED, WITH
17  * REGARD TO THIS SOFTWARE INCLUDING BUT NOT LIMITED TO THE WARRANTIES
18  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
19  */
20
21 #ifndef _GDB_IF_H
22 #define _GDB_IF_H
23
32 /* Max number of threads in qM response */
33 #define QM_MAX_THREADS (20)
34
36  char display[256];
37  char name[256];
38  char more_display[256];
39 };
40
41 /*
42  * Prototypes
43  */
44
45 int parse_zbreak(const char *in, int *type, unsigned char **addr, int *len);
46
47 char* mem2hstr(char *buf, const unsigned char *mem, int count);
48 int hstr2mem(unsigned char *mem, const char *buf, int count);
49 void set_mem_err(void);
50 unsigned char get_byte(const unsigned char *ptr);
51 void set_byte(unsigned char *ptr, int val);
52 char* thread2vhstr(char *buf, int thread);
53 char* thread2fhstr(char *buf, int thread);
54 const char* fhstr2thread(const char *buf, int *thread);
55 const char* vhstr2thread(const char *buf, int *thread);
56 char* int2fhstr(char *buf, int val);
57 char* int2vhstr(char *buf, int vali);
58 const char* fhstr2int(const char *buf, int *ival);
59 const char* vhstr2int(const char *buf, int *ival);
60 int hstr2byte(const char *buf, int *bval);
61 int hstr2nibble(const char *buf, int *nibble);
62
63 Thread_Control *rtems_gdb_index_to_stub_id(int);
64 int rtems_gdb_stub_thread_support_ok(void);
65 int rtems_gdb_stub_get_current_thread(void);
66 int rtems_gdb_stub_get_next_thread(int);
67 int rtems_gdb_stub_get_offsets(
68  unsigned char **text_addr,
69  unsigned char **data_addr,
70  unsigned char **bss_addr
71 );
72 int rtems_gdb_stub_get_thread_regs(
73  int thread,
74  unsigned int *registers
75 );
76 int rtems_gdb_stub_set_thread_regs(
77  int thread,
78  unsigned int *registers
79 );
80 void rtems_gdb_process_query(
81  char *inbuffer,
82  char *outbuffer,
83  int do_threads,
84  int thread
85 );
86
87 #if defined (__mc68000__)
88 /* there are 180 bytes of registers on a 68020 w/68881 */
89 /* many of the fpa registers are 12 byte (96 bit) registers */
90 #define NUMREGBYTES 180
91 enum regnames {D0,D1,D2,D3,D4,D5,D6,D7,
92  A0,A1,A2,A3,A4,A5,A6,A7,
93  PS,PC,
94  FP0,FP1,FP2,FP3,FP4,FP5,FP6,FP7,
95  FPCONTROL,FPSTATUS,FPIADDR
96  };
97 #elif defined (__mips__)
98 /*
99  * MIPS registers, numbered in the order in which gdb expects to see them.
100  */
101 #define ZERO 0
102 #define AT 1
103 #define V0 2
104 #define V1 3
105 #define A0 4
106 #define A1 5
107 #define A2 6
108 #define A3 7
109
110 #define T0 8
111 #define T1 9
112 #define T2 10
113 #define T3 11
114 #define T4 12
115 #define T5 13
116 #define T6 14
117 #define T7 15
118
119 #define S0 16
120 #define S1 17
121 #define S2 18
122 #define S3 19
123 #define S4 20
124 #define S5 21
125 #define S6 22
126 #define S7 23
127
128 #define T8 24
129 #define T9 25
130 #define K0 26
131 #define K1 27
132 #define GP 28
133 #define SP 29
134 #define S8 30
135 #define RA 31
136
137 #define SR 32
138 #define LO 33
139 #define HI 34
140 #define BAD_VA 35
141 #define CAUSE 36
142 #define PC 37
143
144 #define F0 38
145 #define F1 39
146 #define F2 40
147 #define F3 41
148 #define F4 42
149 #define F5 43
150 #define F6 44
151 #define F7 45
152
153 #define F8 46
154 #define F9 47
155 #define F10 48
156 #define F11 49
157 #define F12 50
158 #define F13 51
159 #define F14 52
160 #define F15 53
161
162 #define F16 54
163 #define F17 55
164 #define F18 56
165 #define F19 57
166 #define F20 58
167 #define F21 59
168 #define F22 60
169 #define F23 61
170
171 #define F24 62
172 #define F25 63
173 #define F26 64
174 #define F27 65
175 #define F28 66
176 #define F29 67
177 #define F30 68
178 #define F31 69
179
180 #define FCSR 70
181 #define FIRR 71
182
183 #define NUM_REGS 72
184
185 void mips_gdb_stub_install(int enableThreads) ;
186 #endif /* defined (__mips__) */
187
188 #define MEMOPT_READABLE 1
189 #define MEMOPT_WRITEABLE 2
190
191 #define NUM_MEMSEGS 10
192
193 int gdbstub_add_memsegment(unsigned,unsigned,int);
194
195 #endif /* _GDB_IF_H */
Definition: thread.h:732
Definition: gdb_if.h:34
