RTEMS  5.1
sci.h
1 /****************************************************************************
2 * File: sci.h
3 *
4 * Desc: This is the include file for the serial communications interface.
5 *
6 * Note: See bsp.h,confdefs.h,system.h for installing drivers into RTEMS.
7 *
8 ****************************************************************************/
9
10 #ifndef _sci_h_
11 #define _sci_h_
12
13 /*******************************************************************************
14  IOCTL commands for the sci driver.
15  I'm still working on these...
16 *******************************************************************************/
17
18 #define SCI_IOCTL_PARITY_NONE 0x00 /* no parity bit after the data bits */
19 #define SCI_IOCTL_PARITY_ODD 0x01 /* parity bit added after data bits */
20 #define SCI_IOCTL_PARITY_EVEN 0x02 /* parity bit added after data bits */
21 #define SCI_IOCTL_PARITY_MARK 0x03 /* parity bit is lo, -12 volts, logical 1 */
22 #define SCI_IOCTL_PARITY_SPACE 0x04 /* parity bit is hi, +12 volts, logical 0 */
23 #define SCI_IOCTL_PARITY_FORCED_ON 0x03 /* parity bit is forced hi or lo */
24 #define SCI_IOCTL_PARITY_FORCED_OFF 0x04 /* parity bit is forced hi or lo */
25
26 #define SCI_IOCTL_BAUD_RATE 0x20 /* set the baud rate, arg is baud */
27
28 #define SCI_IOCTL_DATA_BITS 0x30 /* set the data bits, arg is # bits */
29
30 #define SCI_IOCTL_STOP_BITS_1 0x40 /* 1 stop bit after char frame */
31 #define SCI_IOCTL_STOP_BITS_2 0x41 /* 2 stop bit after char frame */
32
33 #define SCI_IOCTL_MODE_NORMAL 0x50 /* normal operating mode */
34 #define SCI_IOCTL_MODE_LOOP 0x51 /* internal loopback mode */
35
36 #define SCI_IOCTL_FLOW_NONE 0x60 /* no flow control */
37 #define SCI_IOCTL_FLOW_RTS_CTS 0x61 /* hardware flow control */
38
39 #define SCI_IOCTL_SEND_BREAK 0x70 /* send an rs-232 break */
40
41 #define SCI_IOCTL_MODE_1200 0x80 /* 1200,n,8,1 download mode */
42 #define SCI_IOCTL_MODE_9600 0x81 /* 9600,n,8,1 download mode */
43 #define SCI_IOCTL_MODE_9_BIT 0x82 /* 9600,forced,8,1 command mode */
44
45
46 /*******************************************************************************
47  SCI Registers
48 *******************************************************************************/
49
50 /* SCI Control Register 0 (SCCR0) $FFFC08
51
52  8 4 2 1 - 8 4 2 1 - 8 4 2 1 - 8 4 2 1
53  ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^
54  | | | | | | | | | | | | | | | |
55  | | | | | | | | | | | | | | | +----- 0 baud rate divisor
56  | | | | | | | | | | | | | | +------- 1 baud rate divisor
57  | | | | | | | | | | | | | +--------- 2 baud rate divisor
58  | | | | | | | | | | | | +----------- 3 baud rate divisor
59  | | | | | | | | | | | |
60  | | | | | | | | | | | +--------------- 4 baud rate divisor
61  | | | | | | | | | | +----------------- 5 baud rate divisor
62  | | | | | | | | | +------------------- 6 baud rate divisor
63  | | | | | | | | +--------------------- 7 baud rate divisor
64  | | | | | | | |
65  | | | | | | | +------------------------- 8 baud rate divisor
66  | | | | | | +--------------------------- 9 baud rate divisor
67  | | | | | +----------------------------- 10 baud rate divisor
68  | | | | +------------------------------- 11 baud rate divisor
69  | | | |
70  | | | +----------------------------------- 12 baud rate divisor
71  | | +------------------------------------- 13 unused
72  | +--------------------------------------- 14 unused
73  +----------------------------------------- 15 unused
74
75  0 0 0 0 - 0 0 0 0 - 0 0 0 0 - 0 1 0 0 reset value - (64k baud?)
76  */
77
78 #define SCI_BAUD_57_6K 9
79 #define SCI_BAUD_38_4K 14
80 #define SCI_BAUD_19_2K 27
81 #define SCI_BAUD_9600 55
82 #define SCI_BAUD_4800 109
83 #define SCI_BAUD_2400 218
84 #define SCI_BAUD_1200 437
85
86
87 /* SCI Control Register 1 (SCCR1) $FFFC0A
88
89  8 4 2 1 - 8 4 2 1 - 8 4 2 1 - 8 4 2 1
90  ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^
91  | | | | | | | | | | | | | | | |
92  | | | | | | | | | | | | | | | +----- 0 send a break
93  | | | | | | | | | | | | | | +------- 1 rcvr wakeup mode
94  | | | | | | | | | | | | | +--------- 2 rcvr enable
95  | | | | | | | | | | | | +----------- 3 xmtr enable
96  | | | | | | | | | | | |
97  | | | | | | | | | | | +--------------- 4 idle line intr enable
98  | | | | | | | | | | +----------------- 5 rcvr intr enable
99  | | | | | | | | | +------------------- 6 xmit complete intr enable
100  | | | | | | | | +--------------------- 7 xmtr intr enable
101  | | | | | | | |
102  | | | | | | | +------------------------- 8 wakeup on address mark
103  | | | | | | +--------------------------- 9 mode 1=9 bits, 0=8 bits
104  | | | | | +----------------------------- 10 parity enable 1=on, 0=off
105  | | | | +------------------------------- 11 parity type 1=odd, 0=even
106  | | | |
107  | | | +----------------------------------- 12 idle line select
108  | | +------------------------------------- 13 wired-or mode
109  | +--------------------------------------- 14 loop mode
110  +----------------------------------------- 15 unused
111
112  0 0 0 0 - 0 0 0 0 - 0 0 0 0 - 0 0 0 0 reset value
113 */
114
115 #define SCI_SEND_BREAK 0x0001 /* 0000-0000-0000-0001 */
116 #define SCI_RCVR_WAKEUP 0x0002 /* 0000-0000-0000-0010 */
117 #define SCI_ENABLE_RCVR 0x0004 /* 0000-0000-0000-0100 */
118 #define SCI_ENABLE_XMTR 0x0008 /* 0000-0000-0000-1000 */
119
120 #define SCI_DISABLE_RCVR 0xFFFB /* 1111-1111-1111-1011 */
121 #define SCI_DISABLE_XMTR 0xFFF7 /* 1111-1111-1111-0111 */
122
123 #define SCI_ENABLE_INT_IDLE 0x0010 /* 0000-0000-0001-0000 */
124 #define SCI_ENABLE_INT_RX 0x0020 /* 0000-0000-0010-0000 */
125 #define SCI_ENABLE_INT_TX_DONE 0x0040 /* 0000-0000-0100-0000 */
126 #define SCI_ENABLE_INT_TX 0x0080 /* 0000-0000-1000-0000 */
127
128 #define SCI_DISABLE_INT_ALL 0xFF00 /* 1111-1111-0000-0000 ??? */
129
130 #define SCI_DISABLE_INT_RX 0xFFDF /* 1111-1111-1101-1111 */
131 #define SCI_CLEAR_RX_INT 0xFFBF /* 1111-1111-1011-1111 */
132 #define SCI_DISABLE_INT_TX 0xFF7F /* 1111-1111-0111-1111 */
133 #define SCI_CLEAR_TDRE 0xFEFF /* 1111-1110-1111-1111 */
134
135 #define SCI_RCVR_WAKE_ON_MARK 0x0100 /* 0000-0001-0000-0000 */
136 #define SCI_9_DATA_BITS 0x0200 /* 0000-0010-0000-0000 */
137 #define SCI_PARITY_ENABLE 0x0400 /* 0000-0100-0000-0000 */
138 #define SCI_PARITY_ODD 0x0800 /* 0000-1000-0000-0000 */
139
140 #define SCI_RCVR_WAKE_ON_IDLE 0xFEFF /* 1111-1110-1111-1111 */
141 #define SCI_8_DATA_BITS 0xFDFF /* 1111-1101-1111-1111 */
142 #define SCI_PARITY_DISABLE 0xFBFF /* 1111-1011-1111-1111 */
143 #define SCI_PARITY_EVEN 0xF7FF /* 1111-0111-1111-1111 */
144
145 #define SCI_PARITY_NONE 0xF3FF /* 1111-0011-1111-1111 */
146
147 #define SCI_IDLE_LINE_LONG 0x1000 /* 0001-0000-0000-0000 */
148 #define SCI_TXD_OPEN_DRAIN 0x2000 /* 0010-0000-0000-0000 */
149 #define SCI_LOOPBACK_MODE 0x4000 /* 0100-0000-0000-0000 */
150 #define SCI_SCCR1_UNUSED 0x8000 /* 1000-0000-0000-0000 */
151
152
153 /* SCI Status Register (SCSR) $FFFC0C
154
155  8 4 2 1 - 8 4 2 1 - 8 4 2 1 - 8 4 2 1
156  ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^
157  | | | | | | | | | | | | | | | |
158  | | | | | | | | | | | | | | | +----- 0 PF - parity error
159  | | | | | | | | | | | | | | +------- 1 FE - framing error
160  | | | | | | | | | | | | | +--------- 2 NF - noise flag
161  | | | | | | | | | | | | +----------- 3 OR - overrun flag
162  | | | | | | | | | | | |
163  | | | | | | | | | | | +--------------- 4 IDLE - idle line detected
164  | | | | | | | | | | +----------------- 5 RAF - rcvr active flag
165  | | | | | | | | | +------------------- 6 RDRF - rcv data reg full
166  | | | | | | | | +--------------------- 7 TC - xmt complete flag
167  | | | | | | | |
168  | | | | | | | +------------------------- 8 TDRE - xmt data reg empty
169  | | | | | | +--------------------------- 9 always zero
170  | | | | | +----------------------------- 10 always zero
171  | | | | +------------------------------- 11 always zero
172  | | | |
173  | | | +----------------------------------- 12 always zero
174  | | +------------------------------------- 13 always zero
175  | +--------------------------------------- 14 always zero
176  +----------------------------------------- 15 always zero
177
178  0 0 0 0 - 0 0 0 1 - 1 0 0 0 - 0 0 0 0 reset value
179 */
180
181 #define SCI_ERROR_PARITY 0x0001 /* 0000-0000-0000-0001 */
182 #define SCI_ERROR_FRAMING 0x0002 /* 0000-0000-0000-0010 */
183 #define SCI_ERROR_NOISE 0x0004 /* 0000-0000-0000-0100 */
184 #define SCI_ERROR_OVERRUN 0x0008 /* 0000-0000-0000-1000 */
185
186 #define SCI_IDLE_LINE 0x0010 /* 0000-0000-0001-0000 */
187 #define SCI_RCVR_ACTIVE 0x0020 /* 0000-0000-0010-0000 */
188 #define SCI_RCVR_READY 0x0040 /* 0000-0000-0100-0000 */
189 #define SCI_XMTR_IDLE 0x0080 /* 0000-0000-1000-0000 */
190
191 #define SCI_CLEAR_RX_INT 0xFFBF /* 1111-1111-1011-1111 */
192
193 #define SCI_XMTR_READY 0x0100 /* 0000-0001-0000-0000 */
194
195 #define SCI_CLEAR_TDRE 0xFEFF /* 1111-1110-1111-1111 */
196
197 #define SCI_XMTR_AVAILABLE 0x0180 /* 0000-0001-1000-0000 */
198
199
200
201 /*******************************************************************************
202  Function prototypes
203 *******************************************************************************/
204
205 #ifdef __cplusplus
206 extern "C" {
207 #endif
208
209 /* look at console_open to see how this is called */
210
211 const rtems_termios_callbacks * SciGetTermiosHandlers( int32_t polled );
212
213 /* SCI interrupt */
214
215 /*rtems_isr SciIsr( rtems_vector_number vector ); */
216
217 /*int32_t SciOpenPolled ( int32_t major, int32_t minor, void *arg ); */
218 /*int32_t SciOpenInterrupt ( int32_t major, int32_t minor, void *arg ); */
219
220 /*int32_t SciClose ( int32_t major, int32_t minor, void *arg ); */
221
222 /*int32_t SciWritePolled ( int32_t minor, const char *buf, int32_t len ); */
223 /*int32_t SciWriteInterrupt( int32_t minor, const char *buf, int32_t len ); */
224
225 /*int32_t SciReadPolled ( int32_t minor ); */
226
227 /*int32_t SciSetAttributes ( int32_t minor, const struct termios *t ); */
228
229 #ifdef __cplusplus
230 }
231 #endif
232
233 #endif /* _sci_h_ */
Definition: libio.h:1879
