RTEMS  5.1
m5op.h
1 /*
2  * Copyright (c) 2003-2006 The Regents of The University of Michigan
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions are
7  * met: redistributions of source code must retain the above copyright
8  * notice, this list of conditions and the following disclaimer;
9  * redistributions in binary form must reproduce the above copyright
10  * notice, this list of conditions and the following disclaimer in the
11  * documentation and/or other materials provided with the distribution;
12  * neither the name of the copyright holders nor the names of its
13  * contributors may be used to endorse or promote products derived from
14  * this software without specific prior written permission.
15  *
16  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
17  * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
18  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
19  * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
20  * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
21  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
22  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
26  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27  *
28  * Authors: Nathan Binkert
29  * Ali Saidi
30  */
31
32 #ifndef __M5OP_H__
33 #define __M5OP_H__
34
35 #ifdef __cplusplus
36 extern "C" {
37 #endif
38
39 #include <stdint.h>
40
41 void arm(uint64_t address);
42 void quiesce(void);
43 void quiesceNs(uint64_t ns);
44 void quiesceCycle(uint64_t cycles);
45 uint64_t quiesceTime(void);
46 uint64_t rpns(void);
47 void wakeCPU(uint64_t cpuid);
48
49 void m5_exit(uint64_t ns_delay);
50 void m5_fail(uint64_t ns_delay, uint64_t code);
51 uint64_t m5_initparam(void);
52 void m5_checkpoint(uint64_t ns_delay, uint64_t ns_period);
53 void m5_reset_stats(uint64_t ns_delay, uint64_t ns_period);
54 void m5_dump_stats(uint64_t ns_delay, uint64_t ns_period);
55 void m5_dumpreset_stats(uint64_t ns_delay, uint64_t ns_period);
56 uint64_t m5_readfile(void *buffer, uint64_t len, uint64_t offset);
57 uint64_t m5_writefile(void *buffer, uint64_t len, uint64_t offset, const char *filename);
58 void m5_debugbreak(void);
59 void m5_switchcpu(void);
60 void m5_addsymbol(uint64_t addr, char *symbol);
61 void m5_panic(void);
62 void m5_work_begin(uint64_t workid, uint64_t threadid);
63 void m5_work_end(uint64_t workid, uint64_t threadid);
64
65 // These operations are for critical path annotation
66 void m5a_bsm(char *sm, const void *id, int flags);
67 void m5a_esm(char *sm);
68 void m5a_begin(int flags, char *st);
69 void m5a_end(void);
70 void m5a_q(const void *id, char *q, int count);
71 void m5a_dq(const void *id, char *q, int count);
72 void m5a_wf(const void *id, char *q, char *sm, int count);
73 void m5a_we(const void *id, char *q, char *sm, int count);
74 void m5a_ws(const void *id, char *q, char *sm);
75 void m5a_sq(const void *id, char *q, int count, int flags);
76 void m5a_aq(const void *id, char *q, int count);
77 void m5a_pq(const void *id, char *q, int count);
78 void m5a_l(char *lsm, const void *id, char *sm);
79 void m5a_identify(uint64_t id);
80 uint64_t m5a_getid(void);
81
82 #define M5_AN_FL_NONE 0x0
83 #define M5_AN_FL_BAD 0x2
84 #define M5_AN_FL_LINK 0x10
85 #define M5_AN_FL_RESET 0x20
86
87 #ifdef __cplusplus
88 }
89 #endif
90 #endif // __M5OP_H__
Definition: inftrees.h:24
