RTEMS  5.1
lpc17xx.h
1
9 /*
10  * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LPC17XX_REGS_H
24 #define LPC17XX_REGS_H
25
26 #include <bsp/utility.h>
27
28 #define LPC17XX_BASE 0x00
29
30 typedef struct {
31 #define LPC17XX_WWDT_MOD_WDEN BSP_BIT32(0)
32 #define LPC17XX_WWDT_MOD_WDRESET BSP_BIT32(1)
33 #define LPC17XX_WWDT_MOD_WDTOF BSP_BIT32(2)
34 #define LPC17XX_WWDT_MOD_WDINT BSP_BIT32(3)
35 #define LPC17XX_WWDT_MOD_WDPROTECT BSP_BIT32(4)
36  uint32_t mod;
37  uint32_t tc;
38  uint32_t feed;
39  uint32_t tv;
40  uint32_t reserved_10;
41  uint32_t warnint;
42  uint32_t window;
43  uint32_t reserved_1c;
44 } lpc17xx_wwdt;
45
46 #define LPC17XX_WWDT (*(volatile lpc17xx_wwdt *) (LPC17XX_BASE + 0x40000000))
47
48 typedef struct {
49 #define LPC17XX_PLL_CON_PLLE BSP_BIT32(0)
50 #define LPC17XX_PLL_SEL_MSEL(val) BSP_FLD32(val, 0, 4)
51 #define LPC17XX_PLL_SEL_MSEL_GET(reg) BSP_FLD32GET(reg, 0, 4)
52 #define LPC17XX_PLL_SEL_MSEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
53 #define LPC17XX_PLL_SEL_PSEL(val) BSP_FLD32(val, 5, 6)
54 #define LPC17XX_PLL_SEL_PSEL_GET(reg) BSP_FLD32GET(reg, 5, 6)
55 #define LPC17XX_PLL_SEL_PSEL_SET(reg, val) BSP_FLD32SET(reg, val, 5, 6)
56 #define LPC17XX_PLL_STAT_PLLE BSP_BIT32(8)
57 #define LPC17XX_PLL_STAT_PLOCK BSP_BIT32(10)
58  uint32_t con;
59  uint32_t cfg;
60  uint32_t stat;
61  uint32_t feed;
62 } lpc17xx_pll;
63
64 typedef struct {
65  uint32_t flashcfg;
66 #define LPC17XX_SCB_FLASHCFG_FLASHTIM(val) BSP_FLD32(val, 12, 15)
67 #define LPC17XX_SCB_FLASHCFG_FLASHTIM_GET(reg) BSP_FLD32GET(reg, 12, 15)
68 #define LPC17XX_SCB_FLASHCFG_FLASHTIM_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
69  uint32_t reserved_04 [15];
70  uint32_t memmap;
71 #define LPC17XX_SCB_MEMMAP_MAP BSP_BIT32(0)
72  uint32_t reserved_44 [15];
73  lpc17xx_pll pll_0;
74  uint32_t reserved_90 [4];
75  lpc17xx_pll pll_1;
76  uint32_t reserved_b0 [4];
77  uint32_t pcon;
78 #define LPC17XX_SCB_PCON_PM0 BSP_BIT32(0)
79 #define LPC17XX_SCB_PCON_PM1 BSP_BIT32(1)
80 #define LPC17XX_SCB_PCON_BODRPM BSP_BIT32(2)
81 #define LPC17XX_SCB_PCON_BOGD BSP_BIT32(3)
82 #define LPC17XX_SCB_PCON_BORD BSP_BIT32(4)
83 #define LPC17XX_SCB_PCON_SMFLAG BSP_BIT32(8)
84 #define LPC17XX_SCB_PCON_DSFLAG BSP_BIT32(9)
85 #define LPC17XX_SCB_PCON_PDFLAG BSP_BIT32(10)
86 #define LPC17XX_SCB_PCON_DPDFLAG BSP_BIT32(11)
87  uint32_t pconp;
88 #define LPC17XX_SCB_PCONP_LCD BSP_BIT32(0)
89 #define LPC17XX_SCB_PCONP_TIMER_0 BSP_BIT32(1)
90 #define LPC17XX_SCB_PCONP_TIMER_1 BSP_BIT32(2)
91 #define LPC17XX_SCB_PCONP_UART_0 BSP_BIT32(3)
92 #define LPC17XX_SCB_PCONP_UART_1 BSP_BIT32(4)
93 #define LPC17XX_SCB_PCONP_PWM_0 BSP_BIT32(5)
94 #define LPC17XX_SCB_PCONP_PWM_1 BSP_BIT32(6)
95 #define LPC17XX_SCB_PCONP_I2C_0 BSP_BIT32(7)
96 #define LPC17XX_SCB_PCONP_UART_4 BSP_BIT32(8)
97 #define LPC17XX_SCB_PCONP_RTC BSP_BIT32(9)
98 #define LPC17XX_SCB_PCONP_SSP_1 BSP_BIT32(10)
99 #define LPC17XX_SCB_PCONP_EMC BSP_BIT32(11)
100 #define LPC17XX_SCB_PCONP_ADC BSP_BIT32(12)
101 #define LPC17XX_SCB_PCONP_CAN_0 BSP_BIT32(13)
102 #define LPC17XX_SCB_PCONP_CAN_1 BSP_BIT32(14)
103 #define LPC17XX_SCB_PCONP_GPIO BSP_BIT32(15)
104 #define LPC17XX_SCB_PCONP_QEI BSP_BIT32(17)
105 #define LPC17XX_SCB_PCONP_I2C_1 BSP_BIT32(18)
106 #define LPC17XX_SCB_PCONP_SSP_2 BSP_BIT32(19)
107 #define LPC17XX_SCB_PCONP_SSP_0 BSP_BIT32(20)
108 #define LPC17XX_SCB_PCONP_TIMER_2 BSP_BIT32(21)
109 #define LPC17XX_SCB_PCONP_TIMER_3 BSP_BIT32(22)
110 #define LPC17XX_SCB_PCONP_UART_2 BSP_BIT32(23)
111 #define LPC17XX_SCB_PCONP_UART_3 BSP_BIT32(24)
112 #define LPC17XX_SCB_PCONP_I2C_2 BSP_BIT32(25)
113 #define LPC17XX_SCB_PCONP_I2S BSP_BIT32(26)
114 #define LPC17XX_SCB_PCONP_SDC BSP_BIT32(27)
115 #define LPC17XX_SCB_PCONP_GPDMA BSP_BIT32(28)
116 #define LPC17XX_SCB_PCONP_ENET BSP_BIT32(29)
117 #define LPC17XX_SCB_PCONP_USB BSP_BIT32(30)
118 #define LPC17XX_SCB_PCONP_MCPWM BSP_BIT32(31)
119  uint32_t reserved_c8 [14];
120  uint32_t emcclksel;
121 #define LPC17XX_SCB_EMCCLKSEL_EMCDIV BSP_BIT32(0)
122  uint32_t cclksel;
123 #define LPC17XX_SCB_CCLKSEL_CCLKDIV(val) BSP_FLD32(val, 0, 4)
124 #define LPC17XX_SCB_CCLKSEL_CCLKDIV_GET(reg) BSP_FLD32GET(reg, 0, 4)
125 #define LPC17XX_SCB_CCLKSEL_CCLKDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
126 #define LPC17XX_SCB_CCLKSEL_CCLKSEL BSP_BIT32(8)
127  uint32_t usbclksel;
128 #define LPC17XX_SCB_USBCLKSEL_USBDIV(val) BSP_FLD32(val, 0, 4)
129 #define LPC17XX_SCB_USBCLKSEL_USBDIV_GET(reg) BSP_FLD32GET(reg, 0, 4)
130 #define LPC17XX_SCB_USBCLKSEL_USBDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
131 #define LPC17XX_SCB_USBCLKSEL_USBSEL(val) BSP_FLD32(val, 8, 9)
132 #define LPC17XX_SCB_USBCLKSEL_USBSEL_GET(reg) BSP_FLD32GET(reg, 8, 9)
133 #define LPC17XX_SCB_USBCLKSEL_USBSEL_SET(reg, val) BSP_FLD32SET(reg, val, 8, 9)
134  uint32_t clksrcsel;
135 #define LPC17XX_SCB_CLKSRCSEL_CLKSRC BSP_BIT32(0)
136  uint32_t reserved_110 [12];
137  uint32_t extint;
138  uint32_t reserved_144;
139  uint32_t extmode;
140  uint32_t extpolar;
141  uint32_t reserved_150 [12];
142  uint32_t rsid;
143  uint32_t reserved_184 [1];
144  uint32_t matrixarb;
145  uint32_t reserved_18c [5];
146  uint32_t scs;
147 #define LPC17XX_SCB_SCS_EMC_SHIFT_CTL BSP_BIT32(0)
148 #define LPC17XX_SCB_SCS_EMC_RESET_DIS BSP_BIT32(1)
149 #define LPC17XX_SCB_SCS_EMC_BURST_CTL BSP_BIT32(2)
150 #define LPC17XX_SCB_SCS_MCIPWR BSP_BIT32(3)
151 #define LPC17XX_SCB_SCS_OSC_RANGE_SEL BSP_BIT32(4)
152 #define LPC17XX_SCB_SCS_OSC_ENABLE BSP_BIT32(5)
153 #define LPC17XX_SCB_SCS_OSC_STATUS BSP_BIT32(6)
154  uint32_t reserved_1a4;
155  uint32_t pclksel;
156 #define LPC17XX_SCB_PCLKSEL_PCLKDIV(val) BSP_FLD32(val, 0, 4)
157 #define LPC17XX_SCB_PCLKSEL_PCLKDIV_GET(reg) BSP_FLD32GET(reg, 0, 4)
158 #define LPC17XX_SCB_PCLKSEL_PCLKDIV_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
159  uint32_t reserved_1ac;
160  uint32_t pboost;
161 #define LPC17XX_SCB_PBOOST_BOOST BSP_BIT32(0)
162  uint32_t reserved_1b4 [5];
163  uint32_t clkoutcfg;
164 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTSEL(val) BSP_FLD32(val, 3, 0)
165 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTSEL_GET(reg) BSP_FLD32GET(reg, 3, 0)
166 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTSEL_SET(reg, val) BSP_FLD32SET(reg, val, 3, 0)
167 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTDIV(val) BSP_FLD32(val, 7, 4)
168 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTDIV_GET(reg) BSP_FLD32GET(reg, 7, 4)
169 #define LPC17XX_SCB_CLKOUTCFG_CLKOUTDIV_SET(reg, val) BSP_FLD32SET(reg, val, 7, 4)
170 #define LPC17XX_SCB_CLKOUTCFG_CLKOUT_EN BSP_BIT32(8)
171 #define LPC17XX_SCB_CLKOUTCFG_CLKOUT_ACT BSP_BIT32(9)
172  uint32_t rstcon0;
173  uint32_t rstcon1;
174  uint32_t reserved_1d4 [2];
175  uint32_t emcdlyctl;
176 #define LPC17XX_SCB_EMCDLYCTL_CMDDLY(val) BSP_FLD32(val, 0, 4)
177 #define LPC17XX_SCB_EMCDLYCTL_CMDDLY_GET(reg) BSP_FLD32GET(reg, 0, 4)
178 #define LPC17XX_SCB_EMCDLYCTL_CMDDLY_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
179 #define LPC17XX_SCB_EMCDLYCTL_FBCLKDLY(val) BSP_FLD32(val, 8, 12)
180 #define LPC17XX_SCB_EMCDLYCTL_FBCLKDLY_GET(reg) BSP_FLD32GET(reg, 8, 12)
181 #define LPC17XX_SCB_EMCDLYCTL_FBCLKDLY_SET(reg, val) BSP_FLD32SET(reg, val, 8, 12)
182 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT0DLY(val) BSP_FLD32(val, 16, 20)
183 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT0DLY_GET(reg) BSP_FLD32GET(reg, 16, 20)
184 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT0DLY_SET(reg, val) BSP_FLD32SET(reg, val, 16, 20)
185 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT1DLY(val) BSP_FLD32(val, 24, 28)
186 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT1DLY_GET(reg) BSP_FLD32GET(reg, 24, 28)
187 #define LPC17XX_SCB_EMCDLYCTL_CLKOUT1DLY_SET(reg, val) BSP_FLD32SET(reg, val, 24, 28)
188  uint32_t emccal;
189 #define LPC17XX_SCB_EMCCAL_CALVALUE(val) BSP_FLD32(val, 0, 7)
190 #define LPC17XX_SCB_EMCCAL_CALVALUE_GET(reg) BSP_FLD32GET(reg, 0, 7)
191 #define LPC17XX_SCB_EMCCAL_CALVALUE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
192 #define LPC17XX_SCB_EMCCAL_START BSP_BIT32(14)
193 #define LPC17XX_SCB_EMCCAL_DONE BSP_BIT32(15)
194 } lpc17xx_scb;
195
196 #define LPC17XX_SCB (*(volatile lpc17xx_scb *) (LPC17XX_BASE + 0x400fc000))
197
198 typedef struct {
199  uint32_t reserved_00 [268435456];
200  lpc17xx_wwdt wwdt;
201  uint32_t reserved_40000020 [258040];
202  lpc17xx_scb scb;
203 } lpc17xx;
204
205 #define LPC17XX (*(volatile lpc17xx *) (LPC17XX_BASE))
206
207 #endif /* LPC17XX_REGS_H */
Definition: lpc17xx.h:198
Utility macros.
Definition: lpc17xx.h:30
Definition: lpc17xx.h:64
Definition: lpc17xx.h:48
