RTEMS  5.1
lpc176x.h
1
9 /*
10  * Copyright (c) 2014 Taller Technologies.
11  *
12  * @author Boretto Martin (martin.boretto@tallertechnologies.com)
13  * @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
14  * @author Lenarduzzi Federico (federico.lenarduzzi@tallertechnologies.com)
15  * @author Daniel Chicco (daniel.chicco@tallertechnologies.com)
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef LIBBSP_ARM_LPC176X_H
23 #define LIBBSP_ARM_LPC176X_H
24
25 #include <bsp/lpc-i2s.h>
26
27 #define LPC176X_PLL_CON_PLLE BSP_BIT32( 0 )
28 #define LPC176X_PLL_CON_PLLC BSP_BIT32( 1 )
29 #define LPC176X_PLL_SEL_MSEL( val ) BSP_FLD32( val, 0, 14 )
30 #define LPC176X_PLL_SEL_MSEL_GET( reg ) BSP_FLD32GET( reg, 0, 14 )
31 #define LPC176X_PLL_SEL_MSEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 14 )
32 #define LPC176X_PLL_SEL_PSEL( val ) BSP_FLD32( val, 16, 23 )
33 #define LPC176X_PLL_SEL_PSEL_GET( reg ) BSP_FLD32GET( reg, 16, 23 )
34 #define LPC176X_PLL_SEL_PSEL_SET( reg, val ) BSP_FLD32SET( reg, val, 16, 23 )
35 #define LPC176X_PLL_STAT_PLLE BSP_BIT32( 24 )
36 #define LPC176X_PLL_STAT_PLLC BSP_BIT32( 25 )
37 #define LPC176X_PLL_STAT_PLOCK BSP_BIT32( 26 )
38
42 typedef struct {
46  uint32_t con;
50  uint32_t cfg;
54  uint32_t stat;
58  uint32_t feed;
59 } lpc176x_pll;
60
61 #define LPC176X_SCB_BASE_ADDR 0x400FC000U
62 #define LPC176X_SCB_FLASHCFG_FLASHTIM( val ) BSP_FLD32( val, 12, 15 )
63 #define LPC176X_SCB_FLASHCFG_FLASHTIM_GET( reg ) BSP_FLD32GET( reg, 12, 15 )
64 #define LPC176X_SCB_FLASHCFG_FLASHTIM_SET( reg, val ) BSP_FLD32SET( reg, val, \
65  12, 15 )
66 #define LPC176X_SCB_MEMMAP_MAP BSP_BIT32( 0 )
67 /* POWER MODE CONTROL REGISTER (PCON) */
68 /* Power mode control bit 0 */
69 #define LPC176X_SCB_PCON_PM0 BSP_BIT32( 0 )
70 /* Power mode control bit 1 */
71 #define LPC176X_SCB_PCON_PM1 BSP_BIT32( 1 )
72 /* Brown-Out Reduced ower Down */
73 #define LPC176X_SCB_PCON_BODRPM BSP_BIT32( 2 )
74 /* Brown-Out Global Disable */
75 #define LPC176X_SCB_PCON_BOGD BSP_BIT32( 3 )
76 /* Brown-Out Reset Disable */
77 #define LPC176X_SCB_PCON_BORD BSP_BIT32( 4 )
78 /* Sleep Mode entry flag */
79 #define LPC176X_SCB_PCON_SMFLAG BSP_BIT32( 8 )
80 /* Deep Sleep entry flag */
81 #define LPC176X_SCB_PCON_DSFLAG BSP_BIT32( 9 )
82 /* Power-Down entry flag */
83 #define LPC176X_SCB_PCON_PDFLAG BSP_BIT32( 10 )
84 /* Deep Power-Down entry flag */
85 #define LPC176X_SCB_PCON_DPDFLAG BSP_BIT32( 11 )
86 /* POWER CONTROL for PERIPHERALS REGISTER (PCONP) */
87 /* 0 - Reserved */
88 /* Timer/Counter 0 power/clock control bit */
89 #define LPC176X_SCB_PCONP_TIMER_0 BSP_BIT32( 1 )
90 /* Timer/Counter 1 power/clock control bit */
91 #define LPC176X_SCB_PCONP_TIMER_1 BSP_BIT32( 2 )
92 /* UART 0 power/clock control bit */
93 #define LPC176X_SCB_PCONP_UART_0 BSP_BIT32( 3 )
94 /* UART 1 power/clock control bit */
95 #define LPC176X_SCB_PCONP_UART_1 BSP_BIT32( 4 )
96 /* 5 - Reserved */
97 /* PWM 1 power/clock control bit */
98 #define LPC176X_SCB_PCONP_PWM_0 BSP_BIT32( 6 )
99 /* The I2C0 interface power/clock control bit */
100 #define LPC176X_SCB_PCONP_I2C_0 BSP_BIT32( 7 )
101 /* The SPI interface power/clock control bit */
102 #define LPC176X_SCB_PCONP_SPI BSP_BIT32( 8 )
103 /* The RTC power/clock control bit */
104 #define LPC176X_SCB_PCONP_RTC BSP_BIT32( 9 )
105 /* The SSP1 interface power/clock control bit */
106 #define LPC176X_SCB_PCONP_SSP_1 BSP_BIT32( 10 )
107 /* 11 - Reserved */
108 /* A/D converter (ADC) power/clock control bit */
109 #define LPC176X_SCB_PCONP_ADC BSP_BIT32( 12 )
110 /* CAN Controller 1 power/clock control bit */
111 #define LPC176X_SCB_PCONP_CAN_1 BSP_BIT32( 13 )
112 /* CAN Controller 2 power/clock control bit */
113 #define LPC176X_SCB_PCONP_CAN_2 BSP_BIT32( 14 )
114 /* Power/clock control bit for IOCON, GPIO, and GPIO interrupts*/
115 #define LPC176X_SCB_PCONP_GPIO BSP_BIT32( 15 )
116 /* Repetitive Interrupt Timer power/clock control bit */
117 #define LPC176X_SCB_PCONP_RIT BSP_BIT32( 16 )
118 /* Motor Control PWM */
119 #define LPC176X_SCB_PCONP_MCPWM BSP_BIT32( 17 )
120 /* Quadrate Encoder Interface power/clock control bit */
121 #define LPC176X_SCB_PCONP_QEI BSP_BIT32( 18 )
122 /* The IC21 interface power/clock control bit */
123 #define LPC176X_SCB_PCONP_I2C_1 BSP_BIT32( 19 )
124 /* 20 - Reserved */
125 /* The SSP0 interface power/clock control bit */
126 #define LPC176X_SCB_PCONP_SSP_0 BSP_BIT32( 21 )
127 /* Timer 2 power/clock control bit */
128 #define LPC176X_SCB_PCONP_TIMER_2 BSP_BIT32( 22 )
129 /* Timer 3 power/clock control bit */
130 #define LPC176X_SCB_PCONP_TIMER_3 BSP_BIT32( 23 )
131 /* UART 2 power/clock control bit */
132 #define LPC176X_SCB_PCONP_UART_2 BSP_BIT32( 24 )
133 /* UART 3 power/clock control bit */
134 #define LPC176X_SCB_PCONP_UART_3 BSP_BIT32( 25 )
135 /* I2C interface 2 power/clock control bit */
136 #define LPC176X_SCB_PCONP_I2C_2 BSP_BIT32( 26 )
137 /* I2S interface power/clock control bit */
138 #define LPC176X_SCB_PCONP_I2S BSP_BIT32( 27 )
139 /* 28 - Reserved */
140 /* GPDMA function power/clock control bit */
141 #define LPC176X_SCB_PCONP_GPDMA BSP_BIT32( 29 )
142 /* Ethernet block power/clock control bit */
143 #define LPC176X_SCB_PCONP_ENET BSP_BIT32( 30 )
144 /* USB interface power/clock control bit */
145 #define LPC176X_SCB_PCONP_USB BSP_BIT32( 31 )
146 #define LPC176X_SCB_CCLKSEL_CCLKDIV( val ) BSP_FLD32( val, 0, 7 )
147 #define LPC176X_SCB_CCLKSEL_CCLKDIV_GET( reg ) BSP_FLD32GET( reg, 0, 7 )
148 #define LPC176X_SCB_CCLKSEL_CCLKDIV_SET( reg, val ) BSP_FLD32SET( reg, \
149  val, \
150  0, \
151  7 )
152 #define LPC176X_SCB_CCLKSEL_CCLKSEL BSP_BIT32( 8 )
153 #define LPC176X_SCB_USBCLKSEL_USBDIV( val ) BSP_FLD32( val, 0, 4 )
154 #define LPC176X_SCB_USBCLKSEL_USBDIV_GET( reg ) BSP_FLD32GET( reg, 0, 4 )
155 #define LPC176X_SCB_USBCLKSEL_USBDIV_SET( reg, val ) BSP_FLD32SET( reg, \
156  val, \
157  0, \
158  4 )
159 #define LPC176X_SCB_USBCLKSEL_USBSEL( val ) BSP_FLD32( val, 8, 9 )
160 #define LPC176X_SCB_USBCLKSEL_USBSEL_GET( reg ) BSP_FLD32GET( reg, 8, 9 )
161 #define LPC176X_SCB_USBCLKSEL_USBSEL_SET( reg, val ) BSP_FLD32SET( reg, \
162  val, \
163  8, \
164  9 )
165 #define LPC176X_SCB_CLKSRCSEL_CLKSRC BSP_BIT32( 0 )
166 #define LPC176X_SCB_SCS_MCIPWR BSP_BIT32( 3 )
167 #define LPC176X_SCB_SCS_OSC_RANGE_SEL BSP_BIT32( 4 )
168 #define LPC176X_SCB_SCS_OSC_ENABLE BSP_BIT32( 5 )
169 #define LPC176X_SCB_SCS_OSC_STATUS BSP_BIT32( 6 )
170 #define LPC176X_SCB_PCLKSEL_PCLKDIV( val ) BSP_FLD32( val, 0, 4 )
171 #define LPC176X_SCB_PCLKSEL_PCLKDIV_GET( reg ) BSP_FLD32GET( reg, 0, 4 )
172 #define LPC176X_SCB_PCLKSEL_PCLKDIV_SET( reg, val ) BSP_FLD32SET( reg, \
173  val, \
174  0, \
175  4 )
176 #define LPC176X_SCB_PBOOST_BOOST BSP_BIT32( 0 )
177 #define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL( val ) BSP_FLD32( val, 3, 0 )
178 #define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_GET( reg ) BSP_FLD32GET( reg, 3, 0 )
179 #define LPC176X_SCB_CLKOUTCFG_CLKOUTSEL_SET( reg, val ) BSP_FLD32SET( reg, \
180  val, 3, 0 )
181 #define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV( val ) BSP_FLD32( val, 7, 4 )
182 #define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_GET( reg ) BSP_FLD32GET( reg, 7, 4 )
183 #define LPC176X_SCB_CLKOUTCFG_CLKOUTDIV_SET( reg, val ) BSP_FLD32SET( reg, \
184  val, 7, 4 )
185 #define LPC176X_SCB_CLKOUTCFG_CLKOUT_EN BSP_BIT32( 8 )
186 #define LPC176X_SCB_CLKOUTCFG_CLKOUT_ACT BSP_BIT32( 9 )
187
191 typedef struct {
195  uint32_t flashcfg;
196  uint32_t reserved_04[ 15 ];
200  uint32_t memmap;
201  uint32_t reserved_44[ 15 ];
206  uint32_t reserved_90[ 4 ];
211  uint32_t reserved_b0[ 4 ];
215  uint32_t pcon;
219  uint32_t pconp;
220  uint32_t reserved_c8[ 15 ];
225  uint32_t cclksel;
230  uint32_t usbclksel;
234  uint32_t clksrcsel;
235  uint32_t reserved_110[ 12 ];
239  uint32_t extint;
240  uint32_t reserved_144;
244  uint32_t extmode;
248  uint32_t extpolar;
249  uint32_t reserved_150[ 12 ];
253  uint32_t rsid;
254  uint32_t reserved_184[ 7 ];
258  uint32_t scs;
259  uint32_t reserved_1a4;
263  uint32_t pclksel[ 2 ];
267  uint32_t pboost;
268  uint32_t reserved_1b4[ 5 ];
272  uint32_t clkoutcfg;
276  uint32_t rstcon[ 2 ];
277  uint32_t reserved_1d4[ 4 ];
278 } lpc176x_scb;
279
280 #define LPC176X_BASE 0x00u
281 #define LPC176X_SCB ( *(volatile lpc176x_scb *) ( LPC176X_SCB_BASE_ADDR ) )
282
283 /* Fast I/O setup */
284 #define LPC176X_FIO_BASE_ADDR 0x2009C000U
285 #define LPC176X_FIO ( (volatile lpc176x_fio *) LPC176X_FIO_BASE_ADDR )
286
287 #define FIO0DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )
288 #define FIO0MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )
289 #define FIO0PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )
290 #define FIO0SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )
291 #define FIO0CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )
292
293 #define FIO1DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )
294 #define FIO1MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )
295 #define FIO1PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )
296 #define FIO1SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )
297 #define FIO1CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )
298
299 #define FIO2DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )
300 #define FIO2MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )
301 #define FIO2PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )
302 #define FIO2SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )
303 #define FIO2CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )
304
305 #define FIO3DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )
306 #define FIO3MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )
307 #define FIO3PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )
308 #define FIO3SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )
309 #define FIO3CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )
310
311 #define FIO4DIR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )
312 #define FIO4MASK ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )
313 #define FIO4PIN ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )
314 #define FIO4SET ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )
315 #define FIO4CLR ( *(volatile uint32_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )
316
317 /* FIOs can be accessed through WORD, HALF-WORD or BYTE. */
318 #define FIO0DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )
319 #define FIO1DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )
320 #define FIO2DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )
321 #define FIO3DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )
322 #define FIO4DIR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )
323
324 #define FIO0DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x01U ) )
325 #define FIO1DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) )
326 #define FIO2DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x41U ) )
327 #define FIO3DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x61U ) )
328 #define FIO4DIR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x81U ) )
329
330 #define FIO0DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) )
331 #define FIO1DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) )
332 #define FIO2DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) )
333 #define FIO3DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) )
334 #define FIO4DIR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) )
335
336 #define FIO0DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x03U ) )
337 #define FIO1DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x23U ) )
338 #define FIO2DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x43U ) )
339 #define FIO3DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x63U ) )
340 #define FIO4DIR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x83U ) )
341
342 #define FIO0DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x00U ) )
343 #define FIO1DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x20U ) )
344 #define FIO2DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x40U ) )
345 #define FIO3DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x60U ) )
346 #define FIO4DIRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x80U ) )
347
348 #define FIO0DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x02U ) )
349 #define FIO1DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x22U ) )
350 #define FIO2DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x42U ) )
351 #define FIO3DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x62U ) )
352 #define FIO4DIRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x82U ) )
353
354 #define FIO0MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )
355 #define FIO1MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )
356 #define FIO2MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )
357 #define FIO3MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )
358 #define FIO4MASK0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )
359
360 #define FIO0MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x11U ) )
361 #define FIO1MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x21U ) )
362 #define FIO2MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x51U ) )
363 #define FIO3MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x71U ) )
364 #define FIO4MASK1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x91U ) )
365
366 #define FIO0MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) )
367 #define FIO1MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) )
368 #define FIO2MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) )
369 #define FIO3MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) )
370 #define FIO4MASK2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) )
371
372 #define FIO0MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x13U ) )
373 #define FIO1MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x33U ) )
374 #define FIO2MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x53U ) )
375 #define FIO3MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x73U ) )
376 #define FIO4MASK3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x93U ) )
377
378 #define FIO0MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x10U ) )
379 #define FIO1MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x30U ) )
380 #define FIO2MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x50U ) )
381 #define FIO3MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x70U ) )
382 #define FIO4MASKL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x90U ) )
383
384 #define FIO0MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x12U ) )
385 #define FIO1MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x32U ) )
386 #define FIO2MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x52U ) )
387 #define FIO3MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x72U ) )
388 #define FIO4MASKU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x92U ) )
389
390 #define FIO0PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )
391 #define FIO1PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )
392 #define FIO2PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )
393 #define FIO3PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )
394 #define FIO4PIN0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )
395
396 #define FIO0PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x15U ) )
397 #define FIO1PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x25U ) )
398 #define FIO2PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x55U ) )
399 #define FIO3PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x75U ) )
400 #define FIO4PIN1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x95U ) )
401
402 #define FIO0PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) )
403 #define FIO1PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) )
404 #define FIO2PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) )
405 #define FIO3PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) )
406 #define FIO4PIN2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) )
407
408 #define FIO0PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x17U ) )
409 #define FIO1PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x37U ) )
410 #define FIO2PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x57U ) )
411 #define FIO3PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x77U ) )
412 #define FIO4PIN3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x97U ) )
413
414 #define FIO0PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x14U ) )
415 #define FIO1PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x34U ) )
416 #define FIO2PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x54U ) )
417 #define FIO3PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x74U ) )
418 #define FIO4PINL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x94U ) )
419
420 #define FIO0PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x16U ) )
421 #define FIO1PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x36U ) )
422 #define FIO2PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x56U ) )
423 #define FIO3PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x76U ) )
424 #define FIO4PINU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x96U ) )
425
426 #define FIO0SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )
427 #define FIO1SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )
428 #define FIO2SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )
429 #define FIO3SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )
430 #define FIO4SET0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )
431
432 #define FIO0SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x19U ) )
433 #define FIO1SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x29U ) )
434 #define FIO2SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x59U ) )
435 #define FIO3SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x79U ) )
436 #define FIO4SET1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x99U ) )
437
438 #define FIO0SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) )
439 #define FIO1SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) )
440 #define FIO2SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) )
441 #define FIO3SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) )
442 #define FIO4SET2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) )
443
444 #define FIO0SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1BU ) )
445 #define FIO1SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3BU ) )
446 #define FIO2SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5BU ) )
447 #define FIO3SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7BU ) )
448 #define FIO4SET3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9BU ) )
449
450 #define FIO0SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x18U ) )
451 #define FIO1SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x38U ) )
452 #define FIO2SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x58U ) )
453 #define FIO3SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x78U ) )
454 #define FIO4SETL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x98U ) )
455
456 #define FIO0SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1AU ) )
457 #define FIO1SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3AU ) )
458 #define FIO2SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5AU ) )
459 #define FIO3SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7AU ) )
460 #define FIO4SETU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9AU ) )
461
462 #define FIO0CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )
463 #define FIO1CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )
464 #define FIO2CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )
465 #define FIO3CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )
466 #define FIO4CLR0 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )
467
468 #define FIO0CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1DU ) )
469 #define FIO1CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x2DU ) )
470 #define FIO2CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5DU ) )
471 #define FIO3CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7DU ) )
472 #define FIO4CLR1 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9DU ) )
473
474 #define FIO0CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) )
475 #define FIO1CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) )
476 #define FIO2CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) )
477 #define FIO3CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) )
478 #define FIO4CLR2 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9EU ) )
479
480 #define FIO0CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x1FU ) )
481 #define FIO1CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x3FU ) )
482 #define FIO2CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x5FU ) )
483 #define FIO3CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x7FU ) )
484 #define FIO4CLR3 ( *(volatile uint8_t *) ( LPC176X_FIO_BASE_ADDR + 0x9FU ) )
485
486 #define FIO0CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1CU ) )
487 #define FIO1CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3CU ) )
488 #define FIO2CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5CU ) )
489 #define FIO3CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7CU ) )
490 #define FIO4CLRL ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x9CU ) )
491
492 #define FIO0CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x1EU ) )
493 #define FIO1CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x3EU ) )
494 #define FIO2CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x5EU ) )
495 #define FIO3CLRU ( *(volatile uint16_t *) ( LPC176X_FIO_BASE_ADDR + 0x7EU ) )
496 #define FIO4CLRU ( *(volatile uint16_t *) ( FIO_BASE_ADDR + 0x9EU ) )
497
498 #define LPC176X_USB_CLOCK 48000000U
499 #define LPC176X_MODULE_CLOCK_MASK 0x3U
500
501 /* Pin Connect Block */
502 #define PINSEL_BASE_ADDR 0x4002C000U
503
504 #define PINSEL0 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x00U ) )
505 #define PINSEL1 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x04U ) )
506 #define PINSEL2 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x08U ) )
507 #define PINSEL3 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x0CU ) )
508 #define PINSEL4 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x10U ) )
509 #define PINSEL5 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x14U ) )
510 #define PINSEL6 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x18U ) )
511 #define PINSEL7 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x1CU ) )
512 #define PINSEL8 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x20U ) )
513 #define PINSEL9 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x24U ) )
514 #define PINSEL10 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x28U ) )
515 #define PINSEL11 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x2CU ) )
516
517 #define PINMODE0 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x40U ) )
518 #define PINMODE1 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x44U ) )
519 #define PINMODE2 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x48U ) )
520 #define PINMODE3 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x4CU ) )
521 #define PINMODE4 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x50U ) )
522 #define PINMODE5 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x54U ) )
523 #define PINMODE6 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x58U ) )
524 #define PINMODE7 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x5CU ) )
525 #define PINMODE8 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x60U ) )
526 #define PINMODE9 ( *(volatile uint32_t *) ( PINSEL_BASE_ADDR + 0x64U ) )
527
528 /* Pulse Width Modulator (PWM) */
529 #define PWM0_BASE_ADDR 0x40014000
530
531 #define PWM0IR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x00 ) )
532 #define PWM0TCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x04 ) )
533 #define PWM0TC ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x08 ) )
534 #define PWM0PR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x0C ) )
535 #define PWM0PC ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x10 ) )
536 #define PWM0MCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x14 ) )
537 #define PWM0MR0 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x18 ) )
538 #define PWM0MR1 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x1C ) )
539 #define PWM0MR2 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x20 ) )
540 #define PWM0MR3 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x24 ) )
541 #define PWM0CCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x28 ) )
542 #define PWM0CR0 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x2C ) )
543 #define PWM0CR1 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x30 ) )
544 #define PWM0CR2 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x34 ) )
545 #define PWM0CR3 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x38 ) )
546 #define PWM0EMR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x3C ) )
547 #define PWM0MR4 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x40 ) )
548 #define PWM0MR5 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x44 ) )
549 #define PWM0MR6 ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x48 ) )
550 #define PWM0PCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x4C ) )
551 #define PWM0LER ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x50 ) )
552 #define PWM0CTCR ( *(volatile uint32_t *) ( PWM0_BASE_ADDR + 0x70 ) )
553
554 #define PWM1_BASE_ADDR 0x40018000
555
556 #define PWM1IR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x00 ) )
557 #define PWM1TCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x04 ) )
558 #define PWM1TC ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x08 ) )
559 #define PWM1PR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x0C ) )
560 #define PWM1PC ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x10 ) )
561 #define PWM1MCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x14 ) )
562 #define PWM1MR0 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x18 ) )
563 #define PWM1MR1 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x1C ) )
564 #define PWM1MR2 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x20 ) )
565 #define PWM1MR3 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x24 ) )
566 #define PWM1CCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x28 ) )
567 #define PWM1CR0 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x2C ) )
568 #define PWM1CR1 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x30 ) )
569 #define PWM1CR2 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x34 ) )
570 #define PWM1CR3 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x38 ) )
571 #define PWM1EMR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x3C ) )
572 #define PWM1MR4 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x40 ) )
573 #define PWM1MR5 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x44 ) )
574 #define PWM1MR6 ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x48 ) )
575 #define PWM1PCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x4C ) )
576 #define PWM1LER ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x50 ) )
577 #define PWM1CTCR ( *(volatile uint32_t *) ( PWM1_BASE_ADDR + 0x70 ) )
578
579 /* Universal Asynchronous Receiver Transmitter 0 (UART0) */
580 #define UART0_BASE_ADDR 0x4000C000
581
582 #define U0RBR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )
583 #define U0THR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )
584 #define U0DLL ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x00 ) )
585 #define U0DLM ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) )
586 #define U0IER ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x04 ) )
587 #define U0IIR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) )
588 #define U0FCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x08 ) )
589 #define U0LCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x0C ) )
590 #define U0LSR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x14 ) )
591 #define U0SCR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x1C ) )
592 #define U0ACR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x20 ) )
593 #define U0ICR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x24 ) )
594 #define U0FDR ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x28 ) )
595 #define U0TER ( *(volatile uint32_t *) ( UART0_BASE_ADDR + 0x30 ) )
596
597 /* Universal Asynchronous Receiver Transmitter 1 (UART1) */
598 #define UART1_BASE_ADDR 0x40010000
599
600 #define U1RBR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )
601 #define U1THR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )
602 #define U1DLL ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x00 ) )
603 #define U1DLM ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) )
604 #define U1IER ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x04 ) )
605 #define U1IIR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) )
606 #define U1FCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x08 ) )
607 #define U1LCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x0C ) )
608 #define U1MCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x10 ) )
609 #define U1LSR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x14 ) )
610 #define U1MSR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x18 ) )
611 #define U1SCR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x1C ) )
612 #define U1ACR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x20 ) )
613 #define U1FDR ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x28 ) )
614 #define U1TER ( *(volatile uint32_t *) ( UART1_BASE_ADDR + 0x30 ) )
615
616 /* Universal Asynchronous Receiver Transmitter 2 (UART2) */
617 #define UART2_BASE_ADDR 0x40098000
618
619 #define U2RBR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )
620 #define U2THR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )
621 #define U2DLL ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x00 ) )
622 #define U2DLM ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) )
623 #define U2IER ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x04 ) )
624 #define U2IIR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) )
625 #define U2FCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x08 ) )
626 #define U2LCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x0C ) )
627 #define U2LSR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x14 ) )
628 #define U2SCR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x1C ) )
629 #define U2ACR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x20 ) )
630 #define U2ICR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x24 ) )
631 #define U2FDR ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x28 ) )
632 #define U2TER ( *(volatile uint32_t *) ( UART2_BASE_ADDR + 0x30 ) )
633
634 /* Universal Asynchronous Receiver Transmitter 3 (UART3) */
635 #define UART3_BASE_ADDR 0x4009C000
636
637 #define U3RBR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )
638 #define U3THR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )
639 #define U3DLL ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x00 ) )
640 #define U3DLM ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) )
641 #define U3IER ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x04 ) )
642 #define U3IIR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) )
643 #define U3FCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x08 ) )
644 #define U3LCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x0C ) )
645 #define U3LSR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x14 ) )
646 #define U3SCR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x1C ) )
647 #define U3ACR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x20 ) )
648 #define U3ICR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x24 ) )
649 #define U3FDR ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x28 ) )
650 #define U3TER ( *(volatile uint32_t *) ( UART3_BASE_ADDR + 0x30 ) )
651
652 /* SPI0 (Serial Peripheral Interface 0) */
653 #define SPI0_BASE_ADDR 0xE0020000
654 #define S0SPCR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x00 ) )
655 #define S0SPSR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x04 ) )
656 #define S0SPDR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x08 ) )
657 #define S0SPCCR ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x0C ) )
658 #define S0SPINT ( *(volatile uint32_t *) ( SPI0_BASE_ADDR + 0x1C ) )
659
660 /* Real Time Clock */
661 #define RTC_BASE_ADDR 0x40024000
662
663 #define RTC_ILR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x00 ) )
664 #define RTC_CTC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x04 ) )
665 #define RTC_CCR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x08 ) )
666 #define RTC_CIIR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x0C ) )
667 #define RTC_AMR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x10 ) )
668 #define RTC_CTIME0 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x14 ) )
669 #define RTC_CTIME1 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x18 ) )
670 #define RTC_CTIME2 ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x1C ) )
671 #define RTC_SEC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x20 ) )
672 #define RTC_MIN ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x24 ) )
673 #define RTC_HOUR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x28 ) )
674 #define RTC_DOM ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x2C ) )
675 #define RTC_DOW ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x30 ) )
676 #define RTC_DOY ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x34 ) )
677 #define RTC_MONTH ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x38 ) )
678 #define RTC_YEAR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x3C ) )
679 #define RTC_CISS ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x40 ) )
680 #define RTC_ALSEC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x60 ) )
681 #define RTC_ALMIN ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x64 ) )
682 #define RTC_ALHOUR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x68 ) )
683 #define RTC_ALDOM ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x6C ) )
684 #define RTC_ALDOW ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x70 ) )
685 #define RTC_ALDOY ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x74 ) )
686 #define RTC_ALMON ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x78 ) )
687 #define RTC_ALYEAR ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x7C ) )
688 #define RTC_PREINT ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x80 ) )
689 #define RTC_PREFRAC ( *(volatile uint32_t *) ( RTC_BASE_ADDR + 0x84 ) )
690
691 /* A/D Converter 0 (AD0) */
692 #define AD0_BASE_ADDR 0x40034000
693
694 #define AD0CR ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x00 ) )
695 #define AD0GDR ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x04 ) )
696 #define AD0INTEN ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x0C ) )
697 #define AD0_DATA_START ( (volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) )
698 #define AD0DR0 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x10 ) )
699 #define AD0DR1 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x14 ) )
700 #define AD0DR2 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x18 ) )
701 #define AD0DR3 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x1C ) )
702 #define AD0DR4 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x20 ) )
703 #define AD0DR5 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x24 ) )
704 #define AD0DR6 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x28 ) )
705 #define AD0DR7 ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x2C ) )
706 #define AD0STAT ( *(volatile uint32_t *) ( AD0_BASE_ADDR + 0x30 ) )
707
708 /* D/A Converter */
709 #define DAC_BASE_ADDR 0x4008C000
710
711 #define DACR ( *(volatile uint32_t *) ( DAC_BASE_ADDR + 0x00 ) )
712
713 /* CAN CONTROLLERS AND ACCEPTANCE FILTER */
714 #define CAN_ACCEPT_BASE_ADDR 0x4003C000
715
716 #define CAN_AFMR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x00 ) )
717 #define CAN_SFF_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x04 ) )
718 #define CAN_SFF_GRP_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \
719  0x08 ) )
720 #define CAN_EFF_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x0C ) )
721 #define CAN_EFF_GRP_SA ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \
722  0x10 ) )
723 #define CAN_EOT ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x14 ) )
724 #define CAN_LUT_ERR_ADR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + \
725  0x18 ) )
726 #define CAN_LUT_ERR ( *(volatile uint32_t *) ( CAN_ACCEPT_BASE_ADDR + 0x1C ) )
727
728 #define CAN_CENTRAL_BASE_ADDR 0x40040000
729
730 #define CAN_TX_SR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x00 ) )
731 #define CAN_RX_SR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x04 ) )
732 #define CAN_MSR ( *(volatile uint32_t *) ( CAN_CENTRAL_BASE_ADDR + 0x08 ) )
733
734 #define CAN1_BASE_ADDR 0x40044000
735
736 #define CAN1MOD ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x00 ) )
737 #define CAN1CMR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x04 ) )
738 #define CAN1GSR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x08 ) )
739 #define CAN1ICR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x0C ) )
740 #define CAN1IER ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x10 ) )
741 #define CAN1BTR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x14 ) )
742 #define CAN1EWL ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x18 ) )
743 #define CAN1SR ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x1C ) )
744 #define CAN1RFS ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x20 ) )
745 #define CAN1RID ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x24 ) )
746 #define CAN1RDA ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x28 ) )
747 #define CAN1RDB ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x2C ) )
748
749 #define CAN1TFI1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x30 ) )
750 #define CAN1TID1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x34 ) )
751 #define CAN1TDA1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x38 ) )
752 #define CAN1TDB1 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x3C ) )
753 #define CAN1TFI2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x40 ) )
754 #define CAN1TID2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x44 ) )
755 #define CAN1TDA2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x48 ) )
756 #define CAN1TDB2 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x4C ) )
757 #define CAN1TFI3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x50 ) )
758 #define CAN1TID3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x54 ) )
759 #define CAN1TDA3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x58 ) )
760 #define CAN1TDB3 ( *(volatile uint32_t *) ( CAN1_BASE_ADDR + 0x5C ) )
761
762 #define CAN2_BASE_ADDR 0x40048000
763
764 #define CAN2MOD ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x00 ) )
765 #define CAN2CMR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x04 ) )
766 #define CAN2GSR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x08 ) )
767 #define CAN2ICR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x0C ) )
768 #define CAN2IER ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x10 ) )
769 #define CAN2BTR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x14 ) )
770 #define CAN2EWL ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x18 ) )
771 #define CAN2SR ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x1C ) )
772 #define CAN2RFS ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x20 ) )
773 #define CAN2RID ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x24 ) )
774 #define CAN2RDA ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x28 ) )
775 #define CAN2RDB ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x2C ) )
776
777 #define CAN2TFI1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x30 ) )
778 #define CAN2TID1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x34 ) )
779 #define CAN2TDA1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x38 ) )
780 #define CAN2TDB1 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x3C ) )
781 #define CAN2TFI2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x40 ) )
782 #define CAN2TID2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x44 ) )
783 #define CAN2TDA2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x48 ) )
784 #define CAN2TDB2 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x4C ) )
785 #define CAN2TFI3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x50 ) )
786 #define CAN2TID3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x54 ) )
787 #define CAN2TDA3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x58 ) )
788 #define CAN2TDB3 ( *(volatile uint32_t *) ( CAN2_BASE_ADDR + 0x5C ) )
789
790 /* MultiMedia Card Interface(MCI) Controller */
791 #define MCI_BASE_ADDR 0x400c0000
792
793 #define MCI_POWER ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x00 ) )
794 #define MCI_CLOCK ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x04 ) )
795 #define MCI_ARGUMENT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x08 ) )
796 #define MCI_COMMAND ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x0C ) )
797 #define MCI_RESP_CMD ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x10 ) )
798 #define MCI_RESP0 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x14 ) )
799 #define MCI_RESP1 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x18 ) )
800 #define MCI_RESP2 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x1C ) )
801 #define MCI_RESP3 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x20 ) )
802 #define MCI_DATA_TMR ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x24 ) )
803 #define MCI_DATA_LEN ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x28 ) )
804 #define MCI_DATA_CTRL ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x2C ) )
805 #define MCI_DATA_CNT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x30 ) )
806 #define MCI_STATUS ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x34 ) )
807 #define MCI_CLEAR ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x38 ) )
808 #define MCI_MASK0 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x3C ) )
809 #define MCI_MASK1 ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x40 ) )
810 #define MCI_FIFO_CNT ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x48 ) )
811 #define MCI_FIFO ( *(volatile uint32_t *) ( MCI_BASE_ADDR + 0x80 ) )
812
813 /* I2S Interface Controller (I2S) */
814 #define I2S_BASE_ADDR 0x400a8000
815
816 #define I2S_DAO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x00 ) )
817 #define I2S_DAI ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x04 ) )
818 #define I2S_TX_FIFO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x08 ) )
819 #define I2S_RX_FIFO ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x0C ) )
820 #define I2S_STATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x10 ) )
821 #define I2S_DMA1 ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x14 ) )
822 #define I2S_DMA2 ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x18 ) )
823 #define I2S_IRQ ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x1C ) )
824 #define I2S_TXRATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x20 ) )
825 #define I2S_RXRATE ( *(volatile uint32_t *) ( I2S_BASE_ADDR + 0x24 ) )
826
827 /* General-purpose DMA Controller */
828 #define DMA_BASE_ADDR 0x50004000
829
830 #define GPDMA_INT_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x000 ) )
831 #define GPDMA_INT_TCSTAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x004 ) )
832 #define GPDMA_INT_TCCLR ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x008 ) )
833 #define GPDMA_INT_ERR_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x00C ) )
834 #define GPDMA_INT_ERR_CLR ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x010 ) )
835 #define GPDMA_RAW_INT_TCSTAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + \
836  0x014 ) )
837 #define GPDMA_RAW_INT_ERR_STAT ( *(volatile uint32_t *) ( DMA_BASE_ADDR + \
838  0x018 ) )
839 #define GPDMA_ENABLED_CHNS ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x01C ) )
840 #define GPDMA_SOFT_BREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x020 ) )
841 #define GPDMA_SOFT_SREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x024 ) )
842 #define GPDMA_SOFT_LBREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x028 ) )
843 #define GPDMA_SOFT_LSREQ ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x02C ) )
844 #define GPDMA_CONFIG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x030 ) )
845 #define GPDMA_SYNC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x034 ) )
846
847 /* DMA channel 0 registers */
848 #define GPDMA_CH0_BASE_ADDR ( DMA_BASE_ADDR + 0x100 )
849 #define GPDMA_CH0_SRC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x100 ) )
850 #define GPDMA_CH0_DEST ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x104 ) )
851 #define GPDMA_CH0_LLI ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x108 ) )
852 #define GPDMA_CH0_CTRL ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x10C ) )
853 #define GPDMA_CH0_CFG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x110 ) )
854
855 /* DMA channel 1 registers */
856 #define GPDMA_CH1_BASE_ADDR ( DMA_BASE_ADDR + 0x120 )
857 #define GPDMA_CH1_SRC ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x120 ) )
858 #define GPDMA_CH1_DEST ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x124 ) )
859 #define GPDMA_CH1_LLI ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x128 ) )
860 #define GPDMA_CH1_CTRL ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x12C ) )
861 #define GPDMA_CH1_CFG ( *(volatile uint32_t *) ( DMA_BASE_ADDR + 0x130 ) )
862
863 /* USB Controller */
864 #define USB_INT_BASE_ADDR 0x400fc1c0
865 #define USB_BASE_ADDR 0x2008c200
866
867 #define USB_INT_STAT ( *(volatile uint32_t *) ( USB_INT_BASE_ADDR + 0x00 ) )
868
869 /* USB Device Interrupt Registers */
870 #define DEV_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x00 ) )
871 #define DEV_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x04 ) )
872 #define DEV_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x08 ) )
873 #define DEV_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x0C ) )
874 #define DEV_INT_PRIO ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x2C ) )
875
876 /* USB Device Endpoint Interrupt Registers */
877 #define EP_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x30 ) )
878 #define EP_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x34 ) )
879 #define EP_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x38 ) )
880 #define EP_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x3C ) )
881 #define EP_INT_PRIO ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x40 ) )
882
883 /* USB Device Endpoint Realization Registers */
884 #define REALIZE_EP ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x44 ) )
885 #define EP_INDEX ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x48 ) )
886 #define MAXPACKET_SIZE ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x4C ) )
887
888 /* USB Device Command Reagisters */
889 #define CMD_CODE ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x10 ) )
890 #define CMD_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x14 ) )
891
892 /* USB Device Data Transfer Registers */
893 #define RX_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x18 ) )
894 #define TX_DATA ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x1C ) )
895 #define RX_PLENGTH ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x20 ) )
896 #define TX_PLENGTH ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x24 ) )
897 #define USB_CTRL ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x28 ) )
898
899 /* USB Device DMA Registers */
900 #define DMA_REQ_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x50 ) )
901 #define DMA_REQ_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x54 ) )
902 #define DMA_REQ_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x58 ) )
903 #define UDCA_HEAD ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x80 ) )
904 #define EP_DMA_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x84 ) )
905 #define EP_DMA_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x88 ) )
906 #define EP_DMA_DIS ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x8C ) )
907 #define DMA_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x90 ) )
908 #define DMA_INT_EN ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0x94 ) )
909 #define EOT_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA0 ) )
910 #define EOT_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA4 ) )
911 #define EOT_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xA8 ) )
912 #define NDD_REQ_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xAC ) )
913 #define NDD_REQ_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB0 ) )
914 #define NDD_REQ_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB4 ) )
915 #define SYS_ERR_INT_STAT ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xB8 ) )
916 #define SYS_ERR_INT_CLR ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xBC ) )
917 #define SYS_ERR_INT_SET ( *(volatile uint32_t *) ( USB_BASE_ADDR + 0xC0 ) )
918
919 /* USB Host Controller */
920 #define USBHC_BASE_ADDR 0x2008c000
921
922 #define HC_REVISION ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x00 ) )
923 #define HC_CONTROL ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x04 ) )
924 #define HC_CMD_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x08 ) )
925 #define HC_INT_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x0C ) )
926 #define HC_INT_EN ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x10 ) )
927 #define HC_INT_DIS ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x14 ) )
928 #define HC_HCCA ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x18 ) )
929 #define HC_PERIOD_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x1C ) )
930 #define HC_CTRL_HEAD_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x20 ) )
931 #define HC_CTRL_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x24 ) )
932 #define HC_BULK_HEAD_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x28 ) )
933 #define HC_BULK_CUR_ED ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x2C ) )
934 #define HC_DONE_HEAD ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x30 ) )
935 #define HC_FM_INTERVAL ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x34 ) )
936 #define HC_FM_REMAINING ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x38 ) )
937 #define HC_FM_NUMBER ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x3C ) )
938 #define HC_PERIOD_START ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x40 ) )
939 #define HC_LS_THRHLD ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x44 ) )
940 #define HC_RH_DESCA ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x48 ) )
941 #define HC_RH_DESCB ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x4C ) )
942 #define HC_RH_STAT ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x50 ) )
943 #define HC_RH_PORT_STAT1 ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x54 ) )
944 #define HC_RH_PORT_STAT2 ( *(volatile uint32_t *) ( USBHC_BASE_ADDR + 0x58 ) )
945
946 /* USB OTG Controller */
947 #define USBOTG_BASE_ADDR 0x2008c100
948
949 #define OTG_INT_STAT ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x00 ) )
950 #define OTG_INT_EN ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x04 ) )
951 #define OTG_INT_SET ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x08 ) )
952 #define OTG_INT_CLR ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x0C ) )
953 #define OTG_STAT_CTRL ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x10 ) )
954 #define OTG_TIMER ( *(volatile uint32_t *) ( USBOTG_BASE_ADDR + 0x14 ) )
955
956 #define USBOTG_I2C_BASE_ADDR 0x2008c300
957
958 #define OTG_I2C_RX ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) )
959 #define OTG_I2C_TX ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x00 ) )
960 #define OTG_I2C_STS ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x04 ) )
961 #define OTG_I2C_CTL ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + 0x08 ) )
962 #define OTG_I2C_CLKHI ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + \
963  0x0C ) )
964 #define OTG_I2C_CLKLO ( *(volatile uint32_t *) ( USBOTG_I2C_BASE_ADDR + \
965  0x10 ) )
966
967 #define USBOTG_CLK_BASE_ADDR 0x2008CFF0U
968
969 #define OTG_CLK_CTRL ( *(volatile uint32_t *) ( USBOTG_CLK_BASE_ADDR + \
970  0x04U ) )
971 #define OTG_CLK_STAT ( *(volatile uint32_t *) ( USBOTG_CLK_BASE_ADDR + \
972  0x08U ) )
973
974 /* Register Fields */
975 #define GET_FIELD( val, mask, shift ) \
976  ( ( ( val ) & ( mask ) ) >> ( shift ) )
977
978 #define SET_FIELD( val, field, mask, shift ) \
979  ( ( ( val ) & ~( mask ) ) | ( ( ( field ) << ( shift ) ) & ( mask ) ) )
980
981 /* CLKSRCSEL */
982 #define CLKSRCSEL_CLKSRC_MASK 0x00000003U
983
984 #define GET_CLKSRCSEL_CLKSRC( reg ) \
985  GET_FIELD( reg, CLKSRCSEL_CLKSRC_MASK, 0 )
986
987 #define SET_CLKSRCSEL_CLKSRC( reg, val ) \
988  SET_FIELD( reg, val, CLKSRCSEL_CLKSRC_MASK, 0 )
989
990 /* PLLCON */
991 #define PLLCON_PLLE 0x00000001U
992
993 #define PLLCON_PLLC 0x00000002U
994
995 /* PLLCFG */
996 #define PLLCFG_MSEL_MASK 0x00007fffU
997
998 #define GET_PLLCFG_MSEL( reg ) \
999  GET_FIELD( reg, PLLCFG_MSEL_MASK, 0 )
1000
1001 #define SET_PLLCFG_MSEL( reg, val ) \
1002  SET_FIELD( reg, val, PLLCFG_MSEL_MASK, 0 )
1003
1004 #define PLLCFG_NSEL_MASK 0x00ff0000U
1005
1006 #define GET_PLLCFG_NSEL( reg ) \
1007  GET_FIELD( reg, PLLCFG_NSEL_MASK, 16 )
1008
1009 #define SET_PLLCFG_NSEL( reg, val ) \
1010  SET_FIELD( reg, val, PLLCFG_NSEL_MASK, 16 )
1011
1012 /* PLLSTAT */
1013 #define PLLSTAT_MSEL_MASK 0x00007fffU
1014
1015 #define GET_PLLSTAT_MSEL( reg ) \
1016  GET_FIELD( reg, PLLSTAT_MSEL_MASK, 0 )
1017
1018 #define SET_PLLSTAT_MSEL( reg, val ) \
1019  SET_FIELD( reg, val, PLLSTAT_MSEL_MASK, 0 )
1020
1021 #define PLLSTAT_NSEL_MASK 0x00ff0000U
1022
1023 #define GET_PLLSTAT_NSEL( reg ) \
1024  GET_FIELD( reg, PLLSTAT_NSEL_MASK, 16 )
1025
1026 #define SET_PLLSTAT_NSEL( reg, val ) \
1027  SET_FIELD( reg, val, PLLSTAT_NSEL_MASK, 16 )
1028
1029 #define PLLSTAT_PLLE 0x01000000U
1030
1031 #define PLLSTAT_PLLC 0x02000000U
1032
1033 #define PLLSTAT_PLOCK 0x04000000U
1034
1035 /* CCLKCFG */
1036 #define CCLKCFG_CCLKSEL_MASK 0x000000ffU
1037
1038 #define GET_CCLKCFG_CCLKSEL( reg ) \
1039  GET_FIELD( reg, CCLKCFG_CCLKSEL_MASK, 0 )
1040
1041 #define SET_CCLKCFG_CCLKSEL( reg, val ) \
1042  SET_FIELD( reg, val, CCLKCFG_CCLKSEL_MASK, 0 )
1043
1044 /* MEMMAP */
1045 #define MEMMAP_MAP_MASK 0x00000003U
1046
1047 #define GET_MEMMAP_MAP( reg ) \
1048  GET_FIELD( reg, MEMMAP_MAP_MASK, 0 )
1049
1050 #define SET_MEMMAP_MAP( reg, val ) \
1051  SET_FIELD( reg, val, MEMMAP_MAP_MASK, 0 )
1052
1053 /* TIR */
1054 #define TIR_MR0 0x00000001U
1055 #define TIR_MR1 0x00000002U
1056 #define TIR_MR2 0x00000004U
1057 #define TIR_MR3 0x00000008U
1058 #define TIR_CR0 0x00000010U
1059 #define TIR_CR1 0x00000020U
1060 #define TIR_CR2 0x00000040U
1061 #define TIR_CR3 0x00000080U
1062
1063 /* TCR */
1064 #define TCR_EN 0x00000001U
1065 #define TCR_RST 0x00000002U
1066
1067 /* TMCR */
1068 #define TMCR_MR0I 0x00000001U
1069 #define TMCR_MR0R 0x00000002U
1070 #define TMCR_MR0S 0x00000004U
1071 #define TMCR_MR1I 0x00000008U
1072 #define TMCR_MR1R 0x00000010U
1073 #define TMCR_MR1S 0x00000020U
1074 #define TMCR_MR2I 0x00000040U
1075 #define TMCR_MR2R 0x00000080U
1076 #define TMCR_MR2S 0x00000100U
1077 #define TMCR_MR3I 0x00000200U
1078 #define TMCR_MR3R 0x00000400U
1079 #define TMCR_MR3S 0x00000800U
1080
1081 /* PCLKSEL0 */
1082 #define PCLKSEL0_PCLK_WDT_MASK 0x00000003U
1083
1084 #define GET_PCLKSEL0_PCLK_WDT( reg ) \
1085  GET_FIELD( reg, PCLKSEL0_PCLK_WDT_MASK, 0 )
1086
1087 #define SET_PCLKSEL0_PCLK_WDT( reg, val ) \
1088  SET_FIELD( reg, val, PCLKSEL0_PCLK_WDT_MASK, 0 )
1089
1090 #define PCLKSEL0_PCLK_TIMER0_MASK 0x0000000cU
1091
1092 #define GET_PCLKSEL0_PCLK_TIMER0( reg ) \
1093  GET_FIELD( reg, PCLKSEL0_PCLK_TIMER0_MASK, 2 )
1094
1095 #define SET_PCLKSEL0_PCLK_TIMER0( reg, val ) \
1096  SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER0_MASK, 2 )
1097
1098 #define PCLKSEL0_PCLK_TIMER1_MASK 0x00000030U
1099
1100 #define GET_PCLKSEL0_PCLK_TIMER1( reg ) \
1101  GET_FIELD( reg, PCLKSEL0_PCLK_TIMER1_MASK, 4 )
1102
1103 #define SET_PCLKSEL0_PCLK_TIMER1( reg, val ) \
1104  SET_FIELD( reg, val, PCLKSEL0_PCLK_TIMER1_MASK, 4 )
1105
1106 #define PCLKSEL0_PCLK_UART0_MASK 0x000000c0U
1107
1108 #define GET_PCLKSEL0_PCLK_UART0( reg ) \
1109  GET_FIELD( reg, PCLKSEL0_PCLK_UART0_MASK, 6 )
1110
1111 #define SET_PCLKSEL0_PCLK_UART0( reg, val ) \
1112  SET_FIELD( reg, val, PCLKSEL0_PCLK_UART0_MASK, 6 )
1113
1114 #define PCLKSEL0_PCLK_UART1_MASK 0x00000300U
1115
1116 #define GET_PCLKSEL0_PCLK_UART1( reg ) \
1117  GET_FIELD( reg, PCLKSEL0_PCLK_UART1_MASK, 8 )
1118
1119 #define SET_PCLKSEL0_PCLK_UART1( reg, val ) \
1120  SET_FIELD( reg, val, PCLKSEL0_PCLK_UART1_MASK, 8 )
1121
1122 #define PCLKSEL0_PCLK_PWM0_MASK 0x00000c00U
1123
1124 #define GET_PCLKSEL0_PCLK_PWM0( reg ) \
1125  GET_FIELD( reg, PCLKSEL0_PCLK_PWM0_MASK, 10 )
1126
1127 #define SET_PCLKSEL0_PCLK_PWM0( reg, val ) \
1128  SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM0_MASK, 10 )
1129
1130 #define PCLKSEL0_PCLK_PWM1_MASK 0x00003000U
1131
1132 #define GET_PCLKSEL0_PCLK_PWM1( reg ) \
1133  GET_FIELD( reg, PCLKSEL0_PCLK_PWM1_MASK, 12 )
1134
1135 #define SET_PCLKSEL0_PCLK_PWM1( reg, val ) \
1136  SET_FIELD( reg, val, PCLKSEL0_PCLK_PWM1_MASK, 12 )
1137
1138 #define PCLKSEL0_PCLK_I2C0_MASK 0x0000c000U
1139
1140 #define GET_PCLKSEL0_PCLK_I2C0( reg ) \
1141  GET_FIELD( reg, PCLKSEL0_PCLK_I2C0_MASK, 14 )
1142
1143 #define SET_PCLKSEL0_PCLK_I2C0( reg, val ) \
1144  SET_FIELD( reg, val, PCLKSEL0_PCLK_I2C0_MASK, 14 )
1145
1146 #define PCLKSEL0_PCLK_SPI_MASK 0x00030000U
1147
1148 #define GET_PCLKSEL0_PCLK_SPI( reg ) \
1149  GET_FIELD( reg, PCLKSEL0_PCLK_SPI_MASK, 16 )
1150
1151 #define SET_PCLKSEL0_PCLK_SPI( reg, val ) \
1152  SET_FIELD( reg, val, PCLKSEL0_PCLK_SPI_MASK, 16 )
1153
1154 #define PCLKSEL0_PCLK_RTC_MASK 0x000c0000U
1155
1156 #define GET_PCLKSEL0_PCLK_RTC( reg ) \
1157  GET_FIELD( reg, PCLKSEL0_PCLK_RTC_MASK, 18 )
1158
1159 #define SET_PCLKSEL0_PCLK_RTC( reg, val ) \
1160  SET_FIELD( reg, val, PCLKSEL0_PCLK_RTC_MASK, 18 )
1161
1162 #define PCLKSEL0_PCLK_SSP1_MASK 0x00300000U
1163
1164 #define GET_PCLKSEL0_PCLK_SSP1( reg ) \
1165  GET_FIELD( reg, PCLKSEL0_PCLK_SSP1_MASK, 20 )
1166
1167 #define SET_PCLKSEL0_PCLK_SSP1( reg, val ) \
1168  SET_FIELD( reg, val, PCLKSEL0_PCLK_SSP1_MASK, 20 )
1169
1170 #define PCLKSEL0_PCLK_DAC_MASK 0x00c00000U
1171
1172 #define GET_PCLKSEL0_PCLK_DAC( reg ) \
1173  GET_FIELD( reg, PCLKSEL0_PCLK_DAC_MASK, 22 )
1174
1175 #define SET_PCLKSEL0_PCLK_DAC( reg, val ) \
1176  SET_FIELD( reg, val, PCLKSEL0_PCLK_DAC_MASK, 22 )
1177
1178 #define PCLKSEL0_PCLK_ADC_MASK 0x03000000U
1179
1180 #define GET_PCLKSEL0_PCLK_ADC( reg ) \
1181  GET_FIELD( reg, PCLKSEL0_PCLK_ADC_MASK, 24 )
1182
1183 #define SET_PCLKSEL0_PCLK_ADC( reg, val ) \
1184  SET_FIELD( reg, val, PCLKSEL0_PCLK_ADC_MASK, 24 )
1185
1186 #define PCLKSEL0_PCLK_CAN1_MASK 0x0c000000U
1187
1188 #define GET_PCLKSEL0_PCLK_CAN1( reg ) \
1189  GET_FIELD( reg, PCLKSEL0_PCLK_CAN1_MASK, 26 )
1190
1191 #define SET_PCLKSEL0_PCLK_CAN1( reg, val ) \
1192  SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN1_MASK, 26 )
1193
1194 #define PCLKSEL0_PCLK_CAN2_MASK 0x30000000U
1195
1196 #define GET_PCLKSEL0_PCLK_CAN2( reg ) \
1197  GET_FIELD( reg, PCLKSEL0_PCLK_CAN2_MASK, 28 )
1198
1199 #define SET_PCLKSEL0_PCLK_CAN2( reg, val ) \
1200  SET_FIELD( reg, val, PCLKSEL0_PCLK_CAN2_MASK, 28 )
1201
1202 /* PCLKSEL1 */
1203 #define PCLKSEL1_PCLK_BAT_RAM_MASK 0x00000003U
1204
1205 #define GET_PCLKSEL1_PCLK_BAT_RAM( reg ) \
1206  GET_FIELD( reg, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 )
1207
1208 #define SET_PCLKSEL1_PCLK_BAT_RAM( reg, val ) \
1209  SET_FIELD( reg, val, PCLKSEL1_PCLK_BAT_RAM_MASK, 0 )
1210
1211 #define PCLKSEL1_PCLK_GPIO_MASK 0x0000000cU
1212
1213 #define GET_PCLKSEL1_PCLK_GPIO( reg ) \
1214  GET_FIELD( reg, PCLKSEL1_PCLK_GPIO_MASK, 2 )
1215
1216 #define SET_PCLKSEL1_PCLK_GPIO( reg, val ) \
1217  SET_FIELD( reg, val, PCLKSEL1_PCLK_GPIO_MASK, 2 )
1218
1219 #define PCLKSEL1_PCLK_PCB_MASK 0x00000030U
1220
1221 #define GET_PCLKSEL1_PCLK_PCB( reg ) \
1222  GET_FIELD( reg, PCLKSEL1_PCLK_PCB_MASK, 4 )
1223
1224 #define SET_PCLKSEL1_PCLK_PCB( reg, val ) \
1225  SET_FIELD( reg, val, PCLKSEL1_PCLK_PCB_MASK, 4 )
1226
1227 #define PCLKSEL1_PCLK_I2C1_MASK 0x000000c0U
1228
1229 #define GET_PCLKSEL1_PCLK_I2C1( reg ) \
1230  GET_FIELD( reg, PCLKSEL1_PCLK_I2C1_MASK, 6 )
1231
1232 #define SET_PCLKSEL1_PCLK_I2C1( reg, val ) \
1233  SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C1_MASK, 6 )
1234
1235 #define PCLKSEL1_PCLK_SSP0_MASK 0x00000c00U
1236
1237 #define GET_PCLKSEL1_PCLK_SSP0( reg ) \
1238  GET_FIELD( reg, PCLKSEL1_PCLK_SSP0_MASK, 10 )
1239
1240 #define SET_PCLKSEL1_PCLK_SSP0( reg, val ) \
1241  SET_FIELD( reg, val, PCLKSEL1_PCLK_SSP0_MASK, 10 )
1242
1243 #define PCLKSEL1_PCLK_TIMER2_MASK 0x00003000U
1244
1245 #define GET_PCLKSEL1_PCLK_TIMER2( reg ) \
1246  GET_FIELD( reg, PCLKSEL1_PCLK_TIMER2_MASK, 12 )
1247
1248 #define SET_PCLKSEL1_PCLK_TIMER2( reg, val ) \
1249  SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER2_MASK, 12 )
1250
1251 #define PCLKSEL1_PCLK_TIMER3_MASK 0x0000c000U
1252
1253 #define GET_PCLKSEL1_PCLK_TIMER3( reg ) \
1254  GET_FIELD( reg, PCLKSEL1_PCLK_TIMER3_MASK, 14 )
1255
1256 #define SET_PCLKSEL1_PCLK_TIMER3( reg, val ) \
1257  SET_FIELD( reg, val, PCLKSEL1_PCLK_TIMER3_MASK, 14 )
1258
1259 #define PCLKSEL1_PCLK_UART2_MASK 0x00030000U
1260
1261 #define GET_PCLKSEL1_PCLK_UART2( reg ) \
1262  GET_FIELD( reg, PCLKSEL1_PCLK_UART2_MASK, 16 )
1263
1264 #define SET_PCLKSEL1_PCLK_UART2( reg, val ) \
1265  SET_FIELD( reg, val, PCLKSEL1_PCLK_UART2_MASK, 16 )
1266
1267 #define PCLKSEL1_PCLK_UART3_MASK 0x000c0000U
1268
1269 #define GET_PCLKSEL1_PCLK_UART3( reg ) \
1270  GET_FIELD( reg, PCLKSEL1_PCLK_UART3_MASK, 18 )
1271
1272 #define SET_PCLKSEL1_PCLK_UART3( reg, val ) \
1273  SET_FIELD( reg, val, PCLKSEL1_PCLK_UART3_MASK, 18 )
1274
1275 #define PCLKSEL1_PCLK_I2C2_MASK 0x00300000U
1276
1277 #define GET_PCLKSEL1_PCLK_I2C2( reg ) \
1278  GET_FIELD( reg, PCLKSEL1_PCLK_I2C2_MASK, 20 )
1279
1280 #define SET_PCLKSEL1_PCLK_I2C2( reg, val ) \
1281  SET_FIELD( reg, val, PCLKSEL1_PCLK_I2C2_MASK, 20 )
1282
1283 #define PCLKSEL1_PCLK_I2S_MASK 0x00c00000U
1284
1285 #define GET_PCLKSEL1_PCLK_I2S( reg ) \
1286  GET_FIELD( reg, PCLKSEL1_PCLK_I2S_MASK, 22 )
1287
1288 #define SET_PCLKSEL1_PCLK_I2S( reg, val ) \
1289  SET_FIELD( reg, val, PCLKSEL1_PCLK_I2S_MASK, 22 )
1290
1291 #define PCLKSEL1_PCLK_MCI_MASK 0x03000000U
1292
1293 #define GET_PCLKSEL1_PCLK_MCI( reg ) \
1294  GET_FIELD( reg, PCLKSEL1_PCLK_MCI_MASK, 24 )
1295
1296 #define SET_PCLKSEL1_PCLK_MCI( reg, val ) \
1297  SET_FIELD( reg, val, PCLKSEL1_PCLK_MCI_MASK, 24 )
1298
1299 #define PCLKSEL1_PCLK_SYSCON_MASK 0x30000000U
1300
1301 #define GET_PCLKSEL1_PCLK_SYSCON( reg ) \
1302  GET_FIELD( reg, PCLKSEL1_PCLK_SYSCON_MASK, 28 )
1303
1304 #define SET_PCLKSEL1_PCLK_SYSCON( reg, val ) \
1305  SET_FIELD( reg, val, PCLKSEL1_PCLK_SYSCON_MASK, 28 )
1306
1307 /* RTC_ILR */
1308 #define RTC_ILR_RTCCIF 0x00000001U
1309 #define RTC_ILR_RTCALF 0x00000002U
1310 #define RTC_ILR_RTSSF 0x00000004U
1311
1312 /* RTC_CCR */
1313 #define RTC_CCR_CLKEN 0x00000001U
1314 #define RTC_CCR_CTCRST 0x00000002U
1315 #define RTC_CCR_CLKSRC 0x00000010U
1316
1317 /* GPDMA */
1318 typedef struct {
1319  uint32_t src;
1320  uint32_t dest;
1321  uint32_t lli;
1322  uint32_t ctrl;
1324
1325 typedef struct {
1327  uint32_t cfg;
1329
1330 #define GPDMA_CH_NUMBER 2
1331 #define GPDMA_STATUS_CH_0 0x00000001U
1332 #define GPDMA_STATUS_CH_1 0x00000002U
1333 #define GPDMA_CH_BASE_ADDR( i ) \
1334  ( (volatile lpc176x_dma_channel *) \
1335  ( ( i ) ? GPDMA_CH1_BASE_ADDR : GPDMA_CH0_BASE_ADDR ) )
1336
1337 /* GPDMA_CONFIG */
1338 #define GPDMA_CONFIG_EN 0x00000001U
1339 #define GPDMA_CONFIG_MODE 0x00000002U
1340
1341 /* GPDMA_ENABLED_CHNS */
1342 #define GPDMA_ENABLED_CHNS_CH0 0x00000001U
1343 #define GPDMA_ENABLED_CHNS_CH1 0x00000002U
1344
1345 /* GPDMA_CH_CTRL */
1346 #define GPDMA_CH_CTRL_TSZ_MASK 0x00000fffU
1347
1348 #define GET_GPDMA_CH_CTRL_TSZ( reg ) \
1349  GET_FIELD( reg, GPDMA_CH_CTRL_TSZ_MASK, 0 )
1350
1351 #define SET_GPDMA_CH_CTRL_TSZ( reg, val ) \
1352  SET_FIELD( reg, val, GPDMA_CH_CTRL_TSZ_MASK, 0 )
1353
1354 #define GPDMA_CH_CTRL_TSZ_MAX 0x00000fffU
1355
1356 #define GPDMA_CH_CTRL_SBSZ_MASK 0x00007000U
1357
1358 #define GET_GPDMA_CH_CTRL_SBSZ( reg ) \
1359  GET_FIELD( reg, GPDMA_CH_CTRL_SBSZ_MASK, 12 )
1360
1361 #define SET_GPDMA_CH_CTRL_SBSZ( reg, val ) \
1362  SET_FIELD( reg, val, GPDMA_CH_CTRL_SBSZ_MASK, 12 )
1363
1364 #define GPDMA_CH_CTRL_DBSZ_MASK 0x00038000U
1365
1366 #define GET_GPDMA_CH_CTRL_DBSZ( reg ) \
1367  GET_FIELD( reg, GPDMA_CH_CTRL_DBSZ_MASK, 15 )
1368
1369 #define SET_GPDMA_CH_CTRL_DBSZ( reg, val ) \
1370  SET_FIELD( reg, val, GPDMA_CH_CTRL_DBSZ_MASK, 15 )
1371
1372 #define GPDMA_CH_CTRL_BSZ_1 0x00000000U
1373
1374 #define GPDMA_CH_CTRL_BSZ_4 0x00000001U
1375
1376 #define GPDMA_CH_CTRL_BSZ_8 0x00000002U
1377
1378 #define GPDMA_CH_CTRL_BSZ_16 0x00000003U
1379
1380 #define GPDMA_CH_CTRL_BSZ_32 0x00000004U
1381
1382 #define GPDMA_CH_CTRL_BSZ_64 0x00000005U
1383
1384 #define GPDMA_CH_CTRL_BSZ_128 0x00000006U
1385
1386 #define GPDMA_CH_CTRL_BSZ_256 0x00000007U
1387
1388 #define GPDMA_CH_CTRL_SW_MASK 0x001c0000U
1389
1390 #define GET_GPDMA_CH_CTRL_SW( reg ) \
1391  GET_FIELD( reg, GPDMA_CH_CTRL_SW_MASK, 18 )
1392
1393 #define SET_GPDMA_CH_CTRL_SW( reg, val ) \
1394  SET_FIELD( reg, val, GPDMA_CH_CTRL_SW_MASK, 18 )
1395
1396 #define GPDMA_CH_CTRL_DW_MASK 0x00e00000U
1397
1398 #define GET_GPDMA_CH_CTRL_DW( reg ) \
1399  GET_FIELD( reg, GPDMA_CH_CTRL_DW_MASK, 21 )
1400
1401 #define SET_GPDMA_CH_CTRL_DW( reg, val ) \
1402  SET_FIELD( reg, val, GPDMA_CH_CTRL_DW_MASK, 21 )
1403
1404 #define GPDMA_CH_CTRL_W_8 0x00000000U
1405
1406 #define GPDMA_CH_CTRL_W_16 0x00000001U
1407
1408 #define GPDMA_CH_CTRL_W_32 0x00000002U
1409
1410 #define GPDMA_CH_CTRL_SI 0x04000000U
1411
1412 #define GPDMA_CH_CTRL_DI 0x08000000U
1413
1414 #define GPDMA_CH_CTRL_PROT_MASK 0x70000000U
1415
1416 #define GET_GPDMA_CH_CTRL_PROT( reg ) \
1417  GET_FIELD( reg, GPDMA_CH_CTRL_PROT_MASK, 28 )
1418
1419 #define SET_GPDMA_CH_CTRL_PROT( reg, val ) \
1420  SET_FIELD( reg, val, GPDMA_CH_CTRL_PROT_MASK, 28 )
1421
1422 #define GPDMA_CH_CTRL_ITC 0x80000000U
1423
1424 /* GPDMA_CH_CFG */
1425 #define GPDMA_CH_CFG_EN 0x00000001U
1426
1427 #define GPDMA_CH_CFG_SRCPER_MASK 0x0000001eU
1428
1429 #define GET_GPDMA_CH_CFG_SRCPER( reg ) \
1430  GET_FIELD( reg, GPDMA_CH_CFG_SRCPER_MASK, 1 )
1431
1432 #define SET_GPDMA_CH_CFG_SRCPER( reg, val ) \
1433  SET_FIELD( reg, val, GPDMA_CH_CFG_SRCPER_MASK, 1 )
1434
1435 #define GPDMA_CH_CFG_DESTPER_MASK 0x000003c0U
1436
1437 #define GET_GPDMA_CH_CFG_DESTPER( reg ) \
1438  GET_FIELD( reg, GPDMA_CH_CFG_DESTPER_MASK, 6 )
1439
1440 #define SET_GPDMA_CH_CFG_DESTPER( reg, val ) \
1441  SET_FIELD( reg, val, GPDMA_CH_CFG_DESTPER_MASK, 6 )
1442
1443 #define GPDMA_CH_CFG_PER_SSP0_TX 0x00000000U
1444
1445 #define GPDMA_CH_CFG_PER_SSP0_RX 0x00000001U
1446
1447 #define GPDMA_CH_CFG_PER_SSP1_TX 0x00000002U
1448
1449 #define GPDMA_CH_CFG_PER_SSP1_RX 0x00000003U
1450
1451 #define GPDMA_CH_CFG_PER_SD_MMC 0x00000004U
1452
1453 #define GPDMA_CH_CFG_PER_I2S_CH0 0x00000005U
1454
1455 #define GPDMA_CH_CFG_PER_I2S_CH1 0x00000006U
1456
1457 #define GPDMA_CH_CFG_FLOW_MASK 0x00003800U
1458
1459 #define GET_GPDMA_CH_CFG_FLOW( reg ) \
1460  GET_FIELD( reg, GPDMA_CH_CFG_FLOW_MASK, 11 )
1461
1462 #define SET_GPDMA_CH_CFG_FLOW( reg, val ) \
1463  SET_FIELD( reg, val, GPDMA_CH_CFG_FLOW_MASK, 11 )
1464
1465 #define GPDMA_CH_CFG_FLOW_MEM_TO_MEM_DMA 0x00000000U
1466
1467 #define GPDMA_CH_CFG_FLOW_MEM_TO_PER_DMA 0x00000001U
1468
1469 #define GPDMA_CH_CFG_FLOW_PER_TO_MEM_DMA 0x00000002U
1470
1471 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_DMA 0x00000003U
1472
1473 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_DEST 0x00000004U
1474
1475 #define GPDMA_CH_CFG_FLOW_MEM_TO_PER_PER 0x00000005U
1476
1477 #define GPDMA_CH_CFG_FLOW_PER_TO_MEM_PER 0x00000006U
1478
1479 #define GPDMA_CH_CFG_FLOW_PER_TO_PER_SRC 0x00000007U
1480
1481 #define GPDMA_CH_CFG_IE 0x00004000U
1482
1483 #define GPDMA_CH_CFG_ITC 0x00008000U
1484
1485 #define GPDMA_CH_CFG_LOCK 0x00010000U
1486
1487 #define GPDMA_CH_CFG_ACTIVE 0x00020000U
1488
1489 #define GPDMA_CH_CFG_HALT 0x00040000U
1490
1491 /* AHBCFG */
1492 #define AHBCFG_SCHEDULER_UNIFORM 0x00000001U
1493
1494 #define AHBCFG_BREAK_BURST_MASK 0x00000006U
1495
1496 #define GET_AHBCFG_BREAK_BURST( reg ) \
1497  GET_FIELD( reg, AHBCFG_BREAK_BURST_MASK, 1 )
1498
1499 #define SET_AHBCFG_BREAK_BURST( reg, val ) \
1500  SET_FIELD( reg, val, AHBCFG_BREAK_BURST_MASK, 1 )
1501
1502 #define AHBCFG_QUANTUM_BUS_CYCLE 0x00000008U
1503
1504 #define AHBCFG_QUANTUM_SIZE_MASK 0x000000f0U
1505
1506 #define GET_AHBCFG_QUANTUM_SIZE( reg ) \
1507  GET_FIELD( reg, AHBCFG_QUANTUM_SIZE_MASK, 4 )
1508
1509 #define SET_AHBCFG_QUANTUM_SIZE( reg, val ) \
1510  SET_FIELD( reg, val, AHBCFG_QUANTUM_SIZE_MASK, 4 )
1511
1512 #define AHBCFG_DEFAULT_MASTER_MASK 0x00000700U
1513
1514 #define GET_AHBCFG_DEFAULT_MASTER( reg ) \
1515  GET_FIELD( reg, AHBCFG_DEFAULT_MASTER_MASK, 8 )
1516
1517 #define SET_AHBCFG_DEFAULT_MASTER( reg, val ) \
1518  SET_FIELD( reg, val, AHBCFG_DEFAULT_MASTER_MASK, 8 )
1519
1520 #define AHBCFG_EP1_MASK 0x00007000U
1521
1522 #define GET_AHBCFG_EP1( reg ) \
1523  GET_FIELD( reg, AHBCFG_EP1_MASK, 12 )
1524
1525 #define SET_AHBCFG_EP1( reg, val ) \
1526  SET_FIELD( reg, val, AHBCFG_EP1_MASK, 12 )
1527
1528 #define AHBCFG_EP2_MASK 0x00070000U
1529
1530 #define GET_AHBCFG_EP2( reg ) \
1531  GET_FIELD( reg, AHBCFG_EP2_MASK, 16 )
1532
1533 #define SET_AHBCFG_EP2( reg, val ) \
1534  SET_FIELD( reg, val, AHBCFG_EP2_MASK, 16 )
1535
1536 #define AHBCFG_EP3_MASK 0x00700000U
1537
1538 #define GET_AHBCFG_EP3( reg ) \
1539  GET_FIELD( reg, AHBCFG_EP3_MASK, 20 )
1540
1541 #define SET_AHBCFG_EP3( reg, val ) \
1542  SET_FIELD( reg, val, AHBCFG_EP3_MASK, 20 )
1543
1544 #define AHBCFG_EP4_MASK 0x07000000U
1545
1546 #define GET_AHBCFG_EP4( reg ) \
1547  GET_FIELD( reg, AHBCFG_EP4_MASK, 24 )
1548
1549 #define SET_AHBCFG_EP4( reg, val ) \
1550  SET_FIELD( reg, val, AHBCFG_EP4_MASK, 24 )
1551
1552 #define AHBCFG_EP5_MASK 0x70000000U
1553
1554 #define GET_AHBCFG_EP5( reg ) \
1555  GET_FIELD( reg, AHBCFG_EP5_MASK, 28 )
1556
1557 #define SET_AHBCFG_EP5( reg, val ) \
1558  SET_FIELD( reg, val, AHBCFG_EP5_MASK, 28 )
1559
1560 /* I2S */
1561 static volatile lpc_i2s * const lpc176x_i2s = (lpc_i2s *) I2S_BASE_ADDR;
1562
1563 /* ADC */
1564 #define ADC_CR_SEL( val ) BSP_FLD32( val, 0, 7 )
1565 #define ADC_CR_SEL_GET( val ) BSP_FLD32GET( val, 0, 7 )
1566 #define ADC_CR_SEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 7 )
1567 #define ADC_CR_CLKDIV( val ) BSP_FLD32( val, 8, 15 )
1568 #define ADC_CR_CLKDIV_GET( reg ) BSP_FLD32GET( reg, 8, 15 )
1569 #define ADC_CR_CLKDIV_SET( reg, val ) BSP_FLD32SET( reg, val, 8, 15 )
1570 #define ADC_CR_BURST BSP_BIT32( 16 )
1571 #define ADC_CR_CLKS( val ) BSP_FLD32( val, 17, 19 )
1572 #define ADC_CR_PDN BSP_BIT32( 21 )
1573 #define ADC_CR_START( val ) BSP_FLD32( val, 24, 26 )
1574 #define ADC_CR_EDGE BSP_BIT32( 27 )
1575
1576 #define ADC_DR_VALUE( reg ) BSP_FLD32GET( reg, 6, 15 )
1577 #define ADC_DR_OVERRUN BSP_BIT32( 30 )
1578 #define ADC_DR_DONE BSP_BIT32( 31 )
1579
1580 /* DAC */
1581 #define DAC_STEPS 1024
1582 #define DAC_VALUE( val ) BSP_FLD32( val, 6, 15 )
1583 #define DAC_BIAS BSP_BIT32( 16 )
1584
1585 #endif /* LIBBSP_ARM_LPC176X_H */
System Control Block representation.
Definition: lpc176x.h:191
Definition: lpc176x.h:1318
uint32_t extint
External Interrupt flag register.
Definition: lpc176x.h:239
uint32_t pboost
Peripheral boost.
Definition: lpc176x.h:267
uint32_t extmode
External Interrupt Mode register.
Definition: lpc176x.h:244
Phase-Locked Loop representation.
Definition: lpc176x.h:42
uint32_t rsid
Reset Source Identification Register.
Definition: lpc176x.h:253
I2S control block.
Definition: lpc-i2s.h:46
uint32_t cfg
PLL Configuration Register.
Definition: lpc176x.h:50
uint32_t con
PLL Control Register.
Definition: lpc176x.h:46
uint32_t stat
PLL Status Register.
Definition: lpc176x.h:54
uint32_t clkoutcfg
Clock Output Configuration Register.
Definition: lpc176x.h:272
uint32_t feed
PLL Feed Register.
Definition: lpc176x.h:58
lpc176x_pll pll_1
Phase-Locked Loop 1.
Definition: lpc176x.h:210
uint32_t cclksel
Selects the divide valuefor creating the CPU clock from the PPL0 output.
Definition: lpc176x.h:225
uint32_t extpolar
External Interrupt Polarity register.
Definition: lpc176x.h:248
Definition: lpc176x.h:1325
uint32_t flashcfg
Flash Accelerator Configuration Register.
Definition: lpc176x.h:195
I2S API.
lpc176x_pll pll_0
Phase-Locked Loop 0.
Definition: lpc176x.h:205
uint32_t pconp
Power Control for Peripherals register.
Definition: lpc176x.h:219
uint32_t memmap
Memopry Map Control.
Definition: lpc176x.h:200
uint32_t pcon
Power Mode Control register.
Definition: lpc176x.h:215
uint32_t scs
System Controls and Status Register.
Definition: lpc176x.h:258
uint32_t clksrcsel
Clock Source Select register.
Definition: lpc176x.h:234
uint32_t usbclksel
Selects the divide value for creating the USB clock from the PPL0 output.
Definition: lpc176x.h:230
