RTEMS  5.1
lpc-lcd.h
1
9 /*
10  * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_SHARED_LPC_LCD_H
24 #define LIBBSP_ARM_SHARED_LPC_LCD_H
25
26 #include <bsp/utility.h>
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif
31
43 typedef struct {
44  uint8_t img [1024];
45  uint32_t ctrl;
46  uint32_t cfg;
47  uint32_t pal0;
48  uint32_t pal1;
49  uint32_t xy;
50  uint32_t clip;
51  uint32_t intmsk;
52  uint32_t intclr;
53  uint32_t intraw;
54  uint32_t intstat;
55 } lpc_cursor;
56
57 typedef struct {
58  uint32_t timh;
59  uint32_t timv;
60  uint32_t pol;
61  uint32_t le;
62  uint32_t upbase;
63  uint32_t lpbase;
64  uint32_t ctrl;
65  uint32_t intmsk;
66  uint32_t intraw;
67  uint32_t intstat;
68  uint32_t intclr;
69  uint32_t upcurr;
70  uint32_t lpcurr;
71  uint8_t reserved_0 [0x200 - 0x034];
72  uint16_t pal [256];
73  uint8_t reserved_1 [0x800 - 0x400];
74  lpc_cursor crsr;
75 } lpc_lcd;
76
83 #define LCD_CFG_CLKDIV(val) BSP_FLD32(val, 0, 4)
84 #define LCD_CFG_HCLK_ENABLE BSP_BIT32(5)
85 #define LCD_CFG_MODE_SELECT(val) BSP_FLD32(val, 6, 7)
86 #define LCD_CFG_DISPLAY_TYPE BSP_BIT32(8)
87
96 #define LCD_TIMH_PPL(val) BSP_FLD32(val, 2, 7)
97 #define LCD_TIMH_PPL_GET(reg) BSP_FLD32GET(reg, 2, 7)
98 #define LCD_TIMH_HSW(val) BSP_FLD32(val, 8, 15)
99 #define LCD_TIMH_HSW_GET(reg) BSP_FLD32GET(reg, 8, 15)
100 #define LCD_TIMH_HFP(val) BSP_FLD32(val, 16, 23)
101 #define LCD_TIMH_HFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
102 #define LCD_TIMH_HBP(val) BSP_FLD32(val, 24, 31)
103 #define LCD_TIMH_HBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
104
113 #define LCD_TIMV_LPP(val) BSP_FLD32(val, 0, 9)
114 #define LCD_TIMV_LPP_GET(reg) BSP_FLD32GET(reg, 0, 9)
115 #define LCD_TIMV_VSW(val) BSP_FLD32(val, 10, 15)
116 #define LCD_TIMV_VSW_GET(reg) BSP_FLD32GET(reg, 10, 15)
117 #define LCD_TIMV_VFP(val) BSP_FLD32(val, 16, 23)
118 #define LCD_TIMV_VFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
119 #define LCD_TIMV_VBP(val) BSP_FLD32(val, 24, 31)
120 #define LCD_TIMV_VBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
121
130 #define LCD_POL_PCD_LO(val) BSP_FLD32(val, 0, 4)
131 #define LCD_POL_PCD_LO_GET(reg) BSP_FLD32GET(reg, 0, 4)
132 #define LCD_POL_CLKSEL BSP_BIT32(5)
133 #define LCD_POL_ACB(val) BSP_FLD32(val, 6, 10)
134 #define LCD_POL_ACB_GET(reg) BSP_FLD32GET(reg, 6, 10)
135 #define LCD_POL_IVS BSP_BIT32(11)
136 #define LCD_POL_IHS BSP_BIT32(12)
137 #define LCD_POL_IPC BSP_BIT32(13)
138 #define LCD_POL_IOE BSP_BIT32(14)
139 #define LCD_POL_CPL(val) BSP_FLD32(val, 16, 25)
140 #define LCD_POL_CPL_GET(reg) BSP_FLD32GET(reg, 16, 25)
141 #define LCD_POL_BCD BSP_BIT32(26)
142 #define LCD_POL_PCD_HI(val) BSP_FLD32(val, 27, 31)
143 #define LCD_POL_PCD_HI_GET(reg) BSP_FLD32GET(reg, 27, 31)
144
153 #define LCD_LE_LED(val) BSP_FLD32(val, 0, 6)
154 #define LCD_LE_LEE BSP_BIT32(16)
155
164 #define LCD_CTRL_LCDEN BSP_BIT32(0)
165 #define LCD_CTRL_LCDBPP(val) BSP_FLD32(val, 1, 3)
166 #define LCD_CTRL_LCDBPP_GET(reg) BSP_FLD32GET(reg, 1, 3)
167 #define LCD_CTRL_LCDBW BSP_BIT32(4)
168 #define LCD_CTRL_LCDTFT BSP_BIT32(5)
169 #define LCD_CTRL_LCDMONO8 BSP_BIT32(6)
170 #define LCD_CTRL_LCDDUAL BSP_BIT32(7)
171 #define LCD_CTRL_BGR BSP_BIT32(8)
172 #define LCD_CTRL_BEBO BSP_BIT32(9)
173 #define LCD_CTRL_BEPO BSP_BIT32(10)
174 #define LCD_CTRL_LCDPWR BSP_BIT32(11)
175 #define LCD_CTRL_LCDVCOMP(val) BSP_FLD32(val, 12, 13)
176 #define LCD_CTRL_LCDVCOMP_GET(reg) BSP_FLD32GET(reg, 12, 13)
177 #define LCD_CTRL_WATERMARK BSP_BIT32(16)
178
187 #define LCD_INT_FUF BSP_BIT32(1)
188 #define LCD_INT_LNBU BSP_BIT32(2)
189 #define LCD_INT_VCOMP BSP_BIT32(3)
190 #define LCD_INT_BER BSP_BIT32(4)
191
200 #define LCD_PAL_R(val) BSP_FLD16(val, 0, 4)
201 #define LCD_PAL_G(val) BSP_FLD16(val, 5, 9)
202 #define LCD_PAL_B(val) BSP_FLD16(val, 10, 14)
203 #define LCD_PAL_I BSP_BIT16(15)
204
209 #ifdef __cplusplus
210 }
211 #endif /* __cplusplus */
212
213 #endif /* LIBBSP_ARM_SHARED_LPC_LCD_H */
Definition: lpc-lcd.h:57
Definition: lpc-lcd.h:43
Utility macros.
