RTEMS  5.1
lpc-dma.h
1
9 /*
10  * Copyright (c) 2010-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_SHARED_LPC_DMA_H
24 #define LIBBSP_ARM_SHARED_LPC_DMA_H
25
26 #include <bspopts.h>
27 #include <bsp/utility.h>
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif
32
47 typedef struct {
48  uint32_t src;
49  uint32_t dest;
50  uint32_t lli;
51  uint32_t ctrl;
53
57 typedef struct {
58  lpc_dma_descriptor desc;
59  uint32_t cfg;
60  uint32_t reserved [3];
62
66 typedef struct {
67  uint32_t int_stat;
68  uint32_t int_tc_stat;
69  uint32_t int_tc_clear;
70  uint32_t int_err_stat;
71  uint32_t int_err_clear;
72  uint32_t raw_tc_stat;
73  uint32_t raw_err_stat;
74  uint32_t enabled_channels;
75  uint32_t soft_burst_req;
76  uint32_t soft_single_req;
77  uint32_t soft_last_burst_req;
78  uint32_t soft_last_single_req;
79  uint32_t cfg;
80  uint32_t sync;
81  uint32_t reserved [50];
82  lpc_dma_channel channels [LPC_DMA_CHANNEL_COUNT];
83 } lpc_dma;
84
91 #define DMA_CFG_E BSP_BIT32(0)
92 #define DMA_CFG_M_0 BSP_BIT32(1)
93 #define DMA_CFG_M_1 BSP_BIT32(2)
94
103 #define DMA_CH_CTRL_TSZ(val) BSP_FLD32(val, 0, 11)
104 #define DMA_CH_CTRL_TSZ_MAX DMA_CH_CTRL_TSZ(0xfff)
105
106 #define DMA_CH_CTRL_SB(val) BSP_FLD32(val, 12, 14)
107 #define DMA_CH_CTRL_SB_1 DMA_CH_CTRL_SB(0)
108 #define DMA_CH_CTRL_SB_4 DMA_CH_CTRL_SB(1)
109 #define DMA_CH_CTRL_SB_8 DMA_CH_CTRL_SB(2)
110 #define DMA_CH_CTRL_SB_16 DMA_CH_CTRL_SB(3)
111 #define DMA_CH_CTRL_SB_32 DMA_CH_CTRL_SB(4)
112 #define DMA_CH_CTRL_SB_64 DMA_CH_CTRL_SB(5)
113 #define DMA_CH_CTRL_SB_128 DMA_CH_CTRL_SB(6)
114 #define DMA_CH_CTRL_SB_256 DMA_CH_CTRL_SB(7)
115
116 #define DMA_CH_CTRL_DB(val) BSP_FLD32(val, 15, 17)
117 #define DMA_CH_CTRL_DB_1 DMA_CH_CTRL_DB(0)
118 #define DMA_CH_CTRL_DB_4 DMA_CH_CTRL_DB(1)
119 #define DMA_CH_CTRL_DB_8 DMA_CH_CTRL_DB(2)
120 #define DMA_CH_CTRL_DB_16 DMA_CH_CTRL_DB(3)
121 #define DMA_CH_CTRL_DB_32 DMA_CH_CTRL_DB(4)
122 #define DMA_CH_CTRL_DB_64 DMA_CH_CTRL_DB(5)
123 #define DMA_CH_CTRL_DB_128 DMA_CH_CTRL_DB(6)
124 #define DMA_CH_CTRL_DB_256 DMA_CH_CTRL_DB(7)
125
126 #define DMA_CH_CTRL_SW(val) BSP_FLD32(val, 18, 20)
127 #define DMA_CH_CTRL_SW_8 DMA_CH_CTRL_SW(0)
128 #define DMA_CH_CTRL_SW_16 DMA_CH_CTRL_SW(1)
129 #define DMA_CH_CTRL_SW_32 DMA_CH_CTRL_SW(2)
130
131 #define DMA_CH_CTRL_DW(val) BSP_FLD32(val, 21, 23)
132 #define DMA_CH_CTRL_DW_8 DMA_CH_CTRL_DW(0)
133 #define DMA_CH_CTRL_DW_16 DMA_CH_CTRL_DW(1)
134 #define DMA_CH_CTRL_DW_32 DMA_CH_CTRL_DW(2)
135
136 #define DMA_CH_CTRL_S BSP_BIT32(24)
137 #define DMA_CH_CTRL_D BSP_BIT32(25)
138 #define DMA_CH_CTRL_SI BSP_BIT32(26)
139 #define DMA_CH_CTRL_DI BSP_BIT32(27)
140 #define DMA_CH_CTRL_PROT(val) BSP_FLD32(val, 28, 30)
141 #define DMA_CH_CTRL_I BSP_BIT32(31)
142
151 #define DMA_CH_CFG_E BSP_BIT32(0)
152 #define DMA_CH_CFG_SPER(val) BSP_FLD32(val, 1, 5)
153 #define DMA_CH_CFG_DPER(val) BSP_FLD32(val, 6, 10)
154
155 #define DMA_CH_CFG_FLOW(val) BSP_FLD32(val, 11, 13)
156 #define DMA_CH_CFG_FLOW_MEM_TO_MEM_DMA DMA_CH_CFG_FLOW(0)
157 #define DMA_CH_CFG_FLOW_MEM_TO_PER_DMA DMA_CH_CFG_FLOW(1)
158 #define DMA_CH_CFG_FLOW_PER_TO_MEM_DMA DMA_CH_CFG_FLOW(2)
159 #define DMA_CH_CFG_FLOW_PER_TO_PER_DMA DMA_CH_CFG_FLOW(3)
160 #define DMA_CH_CFG_FLOW_PER_TO_PER_DEST DMA_CH_CFG_FLOW(4)
161 #define DMA_CH_CFG_FLOW_MEM_TO_PER_PER DMA_CH_CFG_FLOW(5)
162 #define DMA_CH_CFG_FLOW_PER_TO_MEM_PER DMA_CH_CFG_FLOW(6)
163 #define DMA_CH_CFG_FLOW_PER_TO_PER_SRC DMA_CH_CFG_FLOW(7)
164
165 #define DMA_CH_CFG_IE BSP_BIT32(14)
166 #define DMA_CH_CFG_ITC BSP_BIT32(15)
167 #define DMA_CH_CFG_L BSP_BIT32(16)
168 #define DMA_CH_CFG_A BSP_BIT32(17)
169 #define DMA_CH_CFG_H BSP_BIT32(18)
170
179 #define LPC24XX_DMA_PER_SSP_0_TX 0
180 #define LPC24XX_DMA_PER_SSP_0_RX 1
181 #define LPC24XX_DMA_PER_SSP_1_TX 2
182 #define LPC24XX_DMA_PER_SSP_1_RX 3
183 #define LPC24XX_DMA_PER_SD_MMC 4
184 #define LPC24XX_DMA_PER_I2S_CH_0 5
185 #define LPC24XX_DMA_PER_I2S_CH_1 6
186
195 #define LPC32XX_DMA_PER_I2S_0_CH_0 0
196 #define LPC32XX_DMA_PER_I2S_0_CH_1 13
197 #define LPC32XX_DMA_PER_I2S_1_CH_0 2
198 #define LPC32XX_DMA_PER_I2S_1_CH_1 10
199 #define LPC32XX_DMA_PER_NAND_0 1
200 #define LPC32XX_DMA_PER_NAND_1 12
201 #define LPC32XX_DMA_PER_SD_MMC 4
202 #define LPC32XX_DMA_PER_SSP_0_RX 14
203 #define LPC32XX_DMA_PER_SSP_0_TX 15
204 #define LPC32XX_DMA_PER_SSP_1_RX 3
205 #define LPC32XX_DMA_PER_SSP_1_TX 11
206 #define LPC32XX_DMA_PER_UART_1_RX 6
207 #define LPC32XX_DMA_PER_UART_1_TX 5
208 #define LPC32XX_DMA_PER_UART_2_RX 8
209 #define LPC32XX_DMA_PER_UART_2_TX 7
210 #define LPC32XX_DMA_PER_UART_7_RX 10
211 #define LPC32XX_DMA_PER_UART_7_TX 9
212
217 #ifdef __cplusplus
218 }
219 #endif /* __cplusplus */
220
221 #endif /* LIBBSP_ARM_SHARED_LPC_DMA_H */
void sync(void)
Definition: sync.c:85
DMA control block.
Definition: lpc-dma.h:66
Utility macros.
DMA channel block.
Definition: lpc-dma.h:57
DMA descriptor item.
Definition: lpc-dma.h:47
