RTEMS  5.1
lm3s69xx.h
1
9 /*
10  * Copyright � 2013 Eugeniy Meshcheryakov <eugen@debian.org>
11  *
12  * Copyright (c) 2011 Sebastian Huber. All rights reserved.
13  *
14  * embedded brains GmbH
15  * Obere Lagerstr. 30
16  * 82178 Puchheim
17  * Germany
18  * <rtems@embedded-brains.de>
19  *
20  * The license and distribution terms for this file may be
21  * found in the file LICENSE in this distribution or at
22  * http://www.rtems.org/license/LICENSE.
23  */
24
25 #ifndef LIBBSP_ARM_LM3S69XX_LM3S69XX_H
26 #define LIBBSP_ARM_LM3S69XX_LM3S69XX_H
27 #include <bspopts.h>
28 #include <bsp/utility.h>
29
38 #define LM3S69XX_SYSCON_BASE 0x400fe000
39
40 #define LM3S69XX_UART_0_BASE 0x4000c000
41 #define LM3S69XX_UART_1_BASE 0x4000d000
42 #define LM3S69XX_UART_2_BASE 0x4000e000
43
44 #ifdef LM3S69XX_USE_AHB_FOR_GPIO
45 #define LM3S69XX_GPIO_A_BASE 0x40058000
46 #define LM3S69XX_GPIO_B_BASE 0x40059000
47 #define LM3S69XX_GPIO_C_BASE 0x4005a000
48 #define LM3S69XX_GPIO_D_BASE 0x4005b000
49 #define LM3S69XX_GPIO_E_BASE 0x4005c000
50 #define LM3S69XX_GPIO_F_BASE 0x4005d000
51 #if LM3S69XX_NUM_GPIO_BLOCKS > 6
52 #define LM3S69XX_GPIO_G_BASE 0x4005e000
53 #if LM3S69XX_NUM_GPIO_BLOCKS > 7
54 #define LM3S69XX_GPIO_H_BASE 0x4005f000
55 #endif
56 #endif
57
58 #define LM3S69XX_GPIO(port) ((volatile lm3s69xx_gpio *)(LM3S69XX_GPIO_A_BASE + (port) * 0x1000))
59 #else /* LM3S69XX_USE_AHB_FOR_GPIO */
60 #define LM3S69XX_GPIO_A_BASE 0x40004000
61 #define LM3S69XX_GPIO_B_BASE 0x40005000
62 #define LM3S69XX_GPIO_C_BASE 0x40006000
63 #define LM3S69XX_GPIO_D_BASE 0x40007000
64 #define LM3S69XX_GPIO_E_BASE 0x40024000
65 #define LM3S69XX_GPIO_F_BASE 0x40025000
66 #if LM3S69XX_NUM_GPIO_BLOCKS > 6
67 #define LM3S69XX_GPIO_G_BASE 0x40026000
68 #if LM3S69XX_NUM_GPIO_BLOCKS > 7
69 #define LM3S69XX_GPIO_H_BASE 0x40027000
70 #endif
71 #endif
72
73 #define LM3S69XX_GPIO(port) ((volatile lm3s69xx_gpio *)(((port) < 4) ? \
74  (LM3S69XX_GPIO_A_BASE + (port) * 0x1000) : \
75  (LM3S69XX_GPIO_E_BASE + ((port) - 4) * 0x1000)))
76 #endif /* LM3S69XX_USE_AHB_FOR_GPIO */
77
78 #define LM3S69XX_SSI_0_BASE 0x40008000
79 #if LM3S69XX_NUM_SSI_BLOCKS > 1
80 #define LM3S69XX_SSI_1_BASE 0x40009000
81 #if LM3S69XX_NUM_SSI_BLOCKS > 2
82 #define LM3S69XX_SSI_2_BASE 0x4000A000
83 #if LM3S69XX_NUM_SSI_BLOCKS > 3
84 #define LM3S69XX_SSI_3_BASE 0x4000B000
85 #endif
86 #endif
87 #endif
88
89 #define LM3S69XX_SYSCON ((volatile lm3s69xx_syscon *)LM3S69XX_SYSCON_BASE)
90
91 #define LM3S69XX_PLL_FREQUENCY 400000000U
92
93 typedef struct {
94  uint32_t data[256]; /* Masked data registers are included here. */
95  uint32_t dir;
96  uint32_t is;
97  uint32_t ibe;
98  uint32_t iev;
99  uint32_t im;
100  uint32_t ris;
101  uint32_t mis;
102  uint32_t icr;
103  uint32_t afsel;
104
105  uint32_t reserved_0[55];
106
107  uint32_t dr2r;
108  uint32_t dr4r;
109  uint32_t dr8r;
110  uint32_t odr;
111  uint32_t pur;
112  uint32_t pdr;
113  uint32_t slr;
114  uint32_t den;
115  uint32_t lock;
116  uint32_t cr;
117  uint32_t amsel;
118 } lm3s69xx_gpio;
119
120 typedef struct {
121  uint32_t did0;
122  uint32_t did1;
123
124  uint32_t dc0;
125  uint32_t reserved_0;
126  uint32_t dc1;
127  uint32_t dc2;
128  uint32_t dc3;
129  uint32_t dc4;
130  uint32_t dc5;
131  uint32_t dc6;
132  uint32_t dc7;
133
134  uint32_t reserved_1;
135
136 #define SYSCONPBORCTL_BORIOR BSP_BIT32(1)
137  uint32_t pborctl;
138
139 #define SYSCONLDOPCTL_VADJ(val) BSP_FLD32(val, 0, 5)
140 #define SYSCONLDOPCTL_VADJ_MASK BSP_MSK32(0, 5)
141  uint32_t ldopctl;
142
143  uint32_t reserved_2[2];
144
145  uint32_t srcr0;
146  uint32_t srcr1;
147  uint32_t srcr2;
148
149  uint32_t reserved_3;
150
151 #define SYSCONRIS_MOSCPUPRIS BSP_BIT32(8)
152 #define SYSCONRIS_USBPLLRIS BSP_BIT32(7)
153 #define SYSCONRIS_PLLLRIS BSP_BIT32(6)
154 #define SYSCONRIS_BORRIS BSP_BIT32(1)
155  uint32_t ris;
156
157 #define SYSCONIMC_MOSCPUPIM BSP_BIT32(8)
158 #define SYSCONIMC_USBPLLLIM BSP_BIT32(7)
159 #define SYSCONIMC_PLLLIM BSP_BIT32(6)
160 #define SYSCONIMC_BORIM BSP_BIT32(1)
161  uint32_t imc;
162
163 #define SYSCONMISC_MOSCPUPMIS BSP_BIT32(8)
164 #define SYSCONMISC_USBPLLLMIS BSP_BIT32(7)
165 #define SYSCONMISC_PLLLMIS BSP_BIT32(6)
166 #define SYSCONMISC_BORMIS BSP_BIT32(1)
167  uint32_t misc;
168
169 #define SYSCONRESC_MOSCFAIL BSP_BIT32(16)
170 #define SYSCONRESC_SW BSP_BIT32(4)
171 #define SYSCONRESC_WDT BSP_BIT32(3)
172 #define SYSCONRESC_BOR BSP_BIT32(2)
173 #define SYSCONRESC_POR BSP_BIT32(1)
174 #define SYSCONRESC_EXT BSP_BIT32(0)
175  uint32_t resc;
176
177 #define SYSCONRCC_AGC BSP_BIT32(27)
178 #define SYSCONRCC_SYSDIV(val) BSP_FLD32(val, 23, 26)
179 #define SYSCONRCC_SYSDIV_MSK BSP_MSK32(23, 26)
180 #define SYSCONRCC_USESYSDIV BSP_BIT32(22)
181 #define SYSCONRCC_USEPWMDIV BSP_BIT32(20)
182 #define SYSCONRCC_PWMDIV(val) BSP_FLD32(val, 17, 19)
183 #define SYSCONRCC_PWMDIV_DIV2_VAL 0
184 #define SYSCONRCC_PWMDIV_DIV4_VAL 1
185 #define SYSCONRCC_PWMDIV_DIV8_VAL 2
186 #define SYSCONRCC_PWMDIV_DIV16_VAL 3
187 #define SYSCONRCC_PWMDIV_DIV32_VAL 4
188 #define SYSCONRCC_PWMDIV_DIV64_VAL 5
189 #define SYSCONRCC_PWMDIV_MSK BSP_MSK32(17, 19)
190 #define SYSCONRCC_PWRDN BSP_BIT32(13)
191 #define SYSCONRCC_BYPASS BSP_BIT32(11)
192 #define SYSCONRCC_XTAL(val) BSP_FLD32(val, 6, 10)
193 #define SYSCONRCC_XTAL_MSK BSP_MSK32(6, 10)
194 #define SYSCONRCC_OSCSRC(val) BSP_FLD32(val, 4, 5)
195 #define SYSCONRCC_OSCSRC_MOSC SYSCONRCC_OSCSRC(0x0)
196 #define SYSCONRCC_OSCSRC_IOSC SYSCONRCC_OSCSRC(0x1)
197 #define SYSCONRCC_OSCSRC_IOSC_DIV_4 SYSCONRCC_OSCSRC(0x2)
198 #define SYSCONRCC_OSCSRC_30KHZ SYSCONRCC_OSCSRC(0x3)
199 #define SYSCONRCC_OSCSRC_MSK BSP_MSK32(4, 5)
200 #define SYSCONRCC_IOSCDIS BSP_BIT32(1)
201 #define SYSCONRCC_MOSCDIS BSP_BIT32(0)
202  uint32_t rcc;
203
204 #define SYSCONPLLCFG_F(val) BSP_FLD32(val, 5, 13)
205 #define SYSCONPLLCFG_F_MSK BSP_MSK32(5, 13)
206 #define SYSCONPLLCFG_R(val) BSP_FLD32(val, 0, 4)
207 #define SYSCONPLLCFG_R_MSK BSP_MSK32(0, 4)
208  uint32_t pllcfg;
209
210  uint32_t reserved_4;
211
212 #define SYSCONGPIOHBCTL_PORTH BSP_BIT32(7)
213 #define SYSCONGPIOHBCTL_PORTG BSP_BIT32(6)
214 #define SYSCONGPIOHBCTL_PORTF BSP_BIT32(5)
215 #define SYSCONGPIOHBCTL_PORTE BSP_BIT32(4)
216 #define SYSCONGPIOHBCTL_PORTD BSP_BIT32(3)
217 #define SYSCONGPIOHBCTL_PORTC BSP_BIT32(2)
218 #define SYSCONGPIOHBCTL_PORTB BSP_BIT32(1)
219 #define SYSCONGPIOHBCTL_PORTA BSP_BIT32(0)
220  uint32_t gpiohbctl;
221
222 #define SYSCONRCC2_USERCC2 BSP_BIT32(31)
223 #define SYSCONRCC2_DIV400 BSP_BIT32(30)
224 #define SYSCONRCC2_SYSDIV2(val) BSP_FLD32(val, 23, 28)
225 #define SYSCONRCC2_SYSDIV2_MSK BSP_MSK32(23, 28)
226 #define SYSCONRCC2_SYSDIV2EXT(val) BSP_FLD32(val, 22, 28)
227 #define SYSCONRCC2_SYSDIV2EXT_MSK BSP_MSK32(22, 28)
228 #define SYSCONRCC2_USBPWRDN BSP_BIT32(14)
229 #define SYSCONRCC2_PWRDN2 BSP_BIT32(13)
230 #define SYSCONRCC2_BYPASS2 BSP_BIT32(11)
231 #define SYSCONRCC2_OSCSRC2(val) BSP_FLD32(val, 4, 6)
232 #define SYSCONRCC2_OSCSRC2_MSK BSP_MSK32(4, 6)
233  uint32_t rcc2;
234
235  uint32_t reserved_5[2];
236
237 #define SYSCONMOSCCTL_CVAL BSP_BIT32(0)
238  uint32_t moscctl;
239
240  uint32_t reserved_6[32];
241
242 #define SYSCONRCGC0_PWM BSP_BIT32(20)
243 #define SYSCONRCGC0_ADC BSP_BIT32(16)
244 #define SYSCONRCGC0_MAXADCSPD(val) BSP_FLD32(val, 8, 9)
245 #define SYSCONRCGC0_MAXADCSPD_MSK BSP_MSK32(8, 9)
246 #define SYSCONRCGC0_HIB BSP_BIT32(6)
247 #define SYSCONRCGC0_WDT BSP_BIT32(3)
248  uint32_t rcgc0;
249
250 #define SYSCONRCGC1_COMP1 BSP_BIT32(25)
251 #define SYSCONRCGC1_COMP0 BSP_BIT32(24)
252 #define SYSCONRCGC1_TIMER3 BSP_BIT32(19)
253 #define SYSCONRCGC1_TIMER2 BSP_BIT32(18)
254 #define SYSCONRCGC1_TIMER1 BSP_BIT32(17)
255 #define SYSCONRCGC1_TIMER0 BSP_BIT32(16)
256 #define SYSCONRCGC1_I2C1 BSP_BIT32(14)
257 #define SYSCONRCGC1_I2C0 BSP_BIT32(12)
258 #define SYSCONRCGC1_QEI0 BSP_BIT32(8)
259 #if LM3S69XX_NUM_SSI_BLOCKS > 1
260 #define SYSCONRCGC1_SSI1 BSP_BIT32(5)
261 #endif
262 #define SYSCONRCGC1_SSI0 BSP_BIT32(4)
263 #define SYSCONRCGC1_UART2 BSP_BIT32(2)
264 #define SYSCONRCGC1_UART1 BSP_BIT32(1)
265 #define SYSCONRCGC1_UART0 BSP_BIT32(0)
266  uint32_t rcgc1;
267
268 #define SYSCONRCGC2_USB0 BSP_BIT32(16)
269 #define SYSCONRCGC2_UDMA BSP_BIT32(13)
270 #if LM3S69XX_NUM_GPIO_BLOCKS > 7
271 #define SYSCONRCGC2_GPIOH BSP_BIT32(7)
272 #endif
273 #define SYSCONRCGC2_GPIOG BSP_BIT32(6)
274 #define SYSCONRCGC2_GPIOF BSP_BIT32(5)
275 #define SYSCONRCGC2_GPIOE BSP_BIT32(4)
276 #define SYSCONRCGC2_GPIOD BSP_BIT32(3)
277 #define SYSCONRCGC2_GPIOC BSP_BIT32(2)
278 #define SYSCONRCGC2_GPIOB BSP_BIT32(1)
279 #define SYSCONRCGC2_GPIOA BSP_BIT32(0)
280  uint32_t rcgc2;
281
282  uint32_t reserved_7;
283
284  uint32_t scgc0;
285  uint32_t scgc1;
286  uint32_t scgc2;
287
288  uint32_t reserved_8;
289
290  uint32_t dcgc0;
291  uint32_t dcgc1;
292  uint32_t dcgc2;
293
294  uint32_t reserved_9[6];
295
296 #define SYSCONDSLPCLKCFG_DSDIVORIDE(val) BSP_FLD32(val, 23, 28)
297 #define SYSCONDSLPCLKCFG_DSDIVORIDE_MSK BSP_MSK32(23, 28)
298 #define SYSCONDSLPCLKCFG_DSOSCSRC(val) BSP_FLD32(val, 4, 6)
299 #define SYSCONDSLPCLKCFG_DSOSCSRC_MSK BSP_MSK32(4, 6)
300  uint32_t dslpclkcfg;
302
303 typedef struct {
304 #define UARTDR_OE BSP_BIT32(11)
305 #define UARTDR_BE BSP_BIT32(10)
306 #define UARTDR_PE BSP_BIT32(9)
307 #define UARTDR_FE BSP_BIT32(8)
308 #define UARTDR_ERROR_MSK BSP_MSK32(8, 11)
309 #define UARTDR_DATA(val) BSP_FLD32(val, 0, 7)
310 #define UARTDR_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
311  uint32_t dr;
312
313  uint32_t rsr_ecr;
314  uint32_t reserved_0[4];
315
316 #define UARTFR_TXFE BSP_BIT32(7)
317 #define UARTFR_RXFF BSP_BIT32(6)
318 #define UARTFR_TXFF BSP_BIT32(5)
319 #define UARTFR_RXFE BSP_BIT32(4)
320 #define UARTFR_BUSY BSP_BIT32(3)
321  uint32_t fr;
322
323  uint32_t reserved_1;
324
325  uint32_t ilpr;
326  uint32_t ibrd;
327  uint32_t fbrd;
328
329 #define UARTLCRH_SPS BSP_BIT32(7)
330 #define UARTLCRH_WLEN(val) BSP_FLD32(val, 5, 6)
331 #define UARTLCRH_FEN BSP_BIT32(4)
332 #define UARTLCRH_STP2 BSP_BIT32(3)
333 #define UARTLCRH_EPS BSP_BIT32(2)
334 #define UARTLCRH_PEN BSP_BIT32(1)
335 #define UARTLCRH_BRK BSP_BIT32(0)
336  uint32_t lcrh;
337
338 #define UARTCTL_RXE BSP_BIT32(9)
339 #define UARTCTL_TXE BSP_BIT32(8)
340 #define UARTCTL_LBE BSP_BIT32(7)
341 #define UARTCTL_SIRLP BSP_BIT32(2)
342 #define UARTCTL_SIREN BSP_BIT32(1)
343 #define UARTCTL_UARTEN BSP_BIT32(0)
344  uint32_t ctl;
345
346 #define UARTIFLS_RXIFLSEL(val) BSP_FLD32(val, 3, 5)
347 #define UARTIFLS_TXIFLSEL(val) BSP_FLD32(val, 0, 2)
348  uint32_t ifls;
349
350 #define UARTI_OE BSP_BIT32(10)
351 #define UARTI_BE BSP_BIT32(9)
352 #define UARTI_PE BSP_BIT32(8)
353 #define UARTI_FE BSP_BIT32(7)
354 #define UARTI_RT BSP_BIT32(6)
355 #define UARTI_TX BSP_BIT32(5)
356 #define UARTI_RX BSP_BIT32(4)
357  uint32_t im;
358  uint32_t ris;
359  uint32_t mis;
360  uint32_t icr;
361 #if LM3S69XX_HAS_UDMA
362  uint32_t dmactl;
363 #endif
364 } lm3s69xx_uart;
365
366 typedef struct {
367 #define SSICR0_SCR(val) BSP_FLD32(val, 8, 15)
368 #define SSICR0_SPH BSP_BIT32(7)
369 #define SSICR0_SPO BSP_BIT32(6)
370 #define SSICR0_FRF(val) BSP_FLD32(val, 4, 5)
371 #define SSICR0_DSS(val) BSP_FLD32(val, 0, 3)
372  uint32_t cr0;
373
374 #define SSICR1_SOD BSP_BIT32(3)
375 #define SSICR1_MS BSP_BIT32(2)
376 #define SSICR1_SSE BSP_BIT32(1)
377 #define SSICR1_LBM BSP_BIT32(0)
378  uint32_t cr1;
379  uint32_t dr;
380
381 #define SSISR_BSY BSP_BIT32(4)
382 #define SSISR_RFF BSP_BIT32(3)
383 #define SSISR_RNE BSP_BIT32(2)
384 #define SSISR_TNF BSP_BIT32(1)
385 #define SSISR_TFE BSP_BIT32(0)
386  uint32_t sr;
387
388 #define SSI_CPSRDIV(val) BSP_FLD32(val, 0, 7)
389  uint32_t cpsr;
390
391 #define SSII_TX BSP_BIT32(3)
392 #define SSII_RX BSP_BIT32(2)
393 #define SSII_RT BSP_BIT32(1)
394 #define SSII_ROR BSP_BIT32(0)
395  uint32_t im;
396  uint32_t ris;
397  uint32_t mis;
398  uint32_t icr;
399
400 #if LM3S69XX_HAS_UDMA
401 #define SSIDMACTL_TXDMAE BSP_BIT32(1)
402 #define SSIDMACTL_RXDMAE BSP_BIT32(0)
403  uint32_t dmactl;
404 #endif /* LM3S69XX_HAS_UDMA */
405 } lm3s69xx_ssi;
406
407 #endif /* LIBBSP_ARM_LM3S69XX_LM3S69XX_H */
Utility macros.
Definition: lm3s69xx.h:93
Definition: lm3s69xx.h:120
Definition: lm3s69xx.h:303
Definition: lm3s69xx.h:366
