RTEMS  5.1
greth.h
1 /*
2  * Gaisler Research ethernet MAC driver
3  * adapted from Opencores driver by Marko Isomaki
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  */
9
10
11 #ifndef _GR_ETH_
12 #define _GR_ETH_
13
14
15 /* Configuration Information */
16
17 typedef struct {
18  void *base_address;
19  rtems_vector_number vector;
20  uint32_t txd_count;
21  uint32_t rxd_count;
23
24 /* Ethernet configuration registers */
25
26 typedef struct _greth_regs {
27  volatile uint32_t ctrl; /* Ctrl Register */
28  volatile uint32_t status; /* Status Register */
29  volatile uint32_t mac_addr_msb; /* Bit 47-32 of MAC address */
30  volatile uint32_t mac_addr_lsb; /* Bit 31-0 of MAC address */
31  volatile uint32_t mdio_ctrl; /* MDIO control and status */
32  volatile uint32_t txdesc; /* Transmit descriptor pointer */
33  volatile uint32_t rxdesc; /* Receive descriptor pointer */
34 } greth_regs;
35
36 #define GRETH_TOTAL_BD 128
37 #define GRETH_MAXBUF_LEN 1520
38
39 /* Tx BD */
40 #define GRETH_TXD_ENABLE 0x0800 /* Tx BD Enable */
41 #define GRETH_TXD_WRAP 0x1000 /* Tx BD Wrap (last BD) */
42 #define GRETH_TXD_IRQ 0x2000 /* Tx BD IRQ Enable */
43 #define GRETH_TXD_MORE 0x20000 /* Tx BD More (more descs for packet) */
44 #define GRETH_TXD_IPCS 0x40000 /* Tx BD insert ip chksum */
45 #define GRETH_TXD_TCPCS 0x80000 /* Tx BD insert tcp chksum */
46 #define GRETH_TXD_UDPCS 0x100000 /* Tx BD insert udp chksum */
47
48 #define GRETH_TXD_UNDERRUN 0x4000 /* Tx BD Underrun Status */
49 #define GRETH_TXD_RETLIM 0x8000 /* Tx BD Retransmission Limit Status */
50 #define GRETH_TXD_LATECOL 0x10000 /* Tx BD Late Collision */
51
52 #define GRETH_TXD_STATS (GRETH_TXD_UNDERRUN | \
53  GRETH_TXD_RETLIM | \
54  GRETH_TXD_LATECOL)
55
56 #define GRETH_TXD_CS (GRETH_TXD_IPCS | \
57  GRETH_TXD_TCPCS | \
58  GRETH_TXD_UDPCS)
59
60 /* Rx BD */
61 #define GRETH_RXD_ENABLE 0x0800 /* Rx BD Enable */
62 #define GRETH_RXD_WRAP 0x1000 /* Rx BD Wrap (last BD) */
63 #define GRETH_RXD_IRQ 0x2000 /* Rx BD IRQ Enable */
64
65 #define GRETH_RXD_DRIBBLE 0x4000 /* Rx BD Dribble Nibble Status */
66 #define GRETH_RXD_TOOLONG 0x8000 /* Rx BD Too Long Status */
67 #define GRETH_RXD_CRCERR 0x10000 /* Rx BD CRC Error Status */
68 #define GRETH_RXD_OVERRUN 0x20000 /* Rx BD Overrun Status */
69 #define GRETH_RXD_LENERR 0x40000 /* Rx BD Length Error */
70 #define GRETH_RXD_ID 0x40000 /* Rx BD IP Detected */
71 #define GRETH_RXD_IR 0x40000 /* Rx BD IP Chksum Error */
72 #define GRETH_RXD_UD 0x40000 /* Rx BD UDP Detected*/
73 #define GRETH_RXD_UR 0x40000 /* Rx BD UDP Chksum Error */
74 #define GRETH_RXD_TD 0x40000 /* Rx BD TCP Detected */
75 #define GRETH_RXD_TR 0x40000 /* Rx BD TCP Chksum Error */
76
77
78 #define GRETH_RXD_STATS (GRETH_RXD_OVERRUN | \
79  GRETH_RXD_DRIBBLE | \
80  GRETH_RXD_TOOLONG | \
81  GRETH_RXD_CRCERR)
82
83 /* CTRL Register */
84 #define GRETH_CTRL_TXEN 0x00000001 /* Transmit Enable */
85 #define GRETH_CTRL_RXEN 0x00000002 /* Receive Enable */
86 #define GRETH_CTRL_TXIRQ 0x00000004 /* Transmit Enable */
87 #define GRETH_CTRL_RXIRQ 0x00000008 /* Receive Enable */
88 #define GRETH_CTRL_FULLD 0x00000010 /* Full Duplex */
89 #define GRETH_CTRL_PRO 0x00000020 /* Promiscuous (receive all) */
90 #define GRETH_CTRL_RST 0x00000040 /* Reset MAC */
91
92 /* Status Register */
93 #define GRETH_STATUS_RXERR 0x00000001 /* Receive Error */
94 #define GRETH_STATUS_TXERR 0x00000002 /* Transmit Error IRQ */
95 #define GRETH_STATUS_RXIRQ 0x00000004 /* Receive Frame IRQ */
96 #define GRETH_STATUS_TXIRQ 0x00000008 /* Transmit Error IRQ */
97 #define GRETH_STATUS_RXAHBERR 0x00000010 /* Receiver AHB Error */
98 #define GRETH_STATUS_TXAHBERR 0x00000020 /* Transmitter AHB Error */
99
100 /* MDIO Control */
101 #define GRETH_MDIO_WRITE 0x00000001 /* MDIO Write */
102 #define GRETH_MDIO_READ 0x00000002 /* MDIO Read */
103 #define GRETH_MDIO_LINKFAIL 0x00000004 /* MDIO Link failed */
104 #define GRETH_MDIO_BUSY 0x00000008 /* MDIO Link Busy */
105 #define GRETH_MDIO_REGADR 0x000007C0 /* Register Address */
106 #define GRETH_MDIO_PHYADR 0x0000F800 /* PHY address */
107 #define GRETH_MDIO_DATA 0xFFFF0000 /* MDIO DATA */
108
109
110 /* MII registers */
111 #define GRETH_MII_EXTADV_1000FD 0x00000200
112 #define GRETH_MII_EXTADV_1000HD 0x00000100
113 #define GRETH_MII_EXTPRT_1000FD 0x00000800
114 #define GRETH_MII_EXTPRT_1000HD 0x00000400
115
116 #define GRETH_MII_100T4 0x00000200
117 #define GRETH_MII_100TXFD 0x00000100
118 #define GRETH_MII_100TXHD 0x00000080
119 #define GRETH_MII_10FD 0x00000040
120 #define GRETH_MII_10HD 0x00000020
121
122
123
124 /* Attach routine */
125
126 int rtems_greth_driver_attach (
127  struct rtems_bsdnet_ifconfig *config,
129 );
130
131 /* PHY data */
132 struct phy_device_info
133 {
134  int vendor;
135  int device;
136  int rev;
137
138  int adv;
139  int part;
140
141  int extadv;
142  int extpart;
143 };
144
145 /*
146 #ifdef CPU_U32_FIX
147 void ipalign(struct mbuf *m);
148 #endif
149
150 */
151 #endif
152
Definition: greth.h:17
Definition: deflate.c:115
Definition: greth.h:132
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: rtemscompat1.h:15
Definition: greth.h:19
