RTEMS  5.1
l4stat.h
1 /*
2  * L4STAT APB-Register Driver.
3  *
4  * COPYRIGHT (c) 2017.
5  * Cobham Gaisler AB.
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef __L4STAT_H__
13 #define __L4STAT_H__
14
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19 #define L4STAT_ERR_OK 0
20 #define L4STAT_ERR_EINVAL -1
21 #define L4STAT_ERR_ERROR -2
22 #define L4STAT_ERR_TOOMANY -3
23 #define L4STAT_ERR_IMPLEMENTED -4
24
25 /* Register L4STAT driver to Driver Manager */
26 void l4stat_register_drv (void);
27
28 extern int l4stat_counter_print(unsigned int counter);
29
30 /*
31  * L4STAT CCTRL register fields
32  */
33 #define CCTRL_NCPU (0xf << CCTRL_NCPU_BIT)
34 #define CCTRL_NCNT_L3STAT (0x1ff << CCTRL_NCNT_BIT)
35 #define CCTRL_NCNT (0x1f << CCTRL_NCNT_BIT)
36 #define CCTRL_MC (0x1 << CCTRL_MC_BIT)
37 #define CCTRL_IA (0x1 << CCTRL_IA_BIT)
38 #define CCTRL_DS (0x1 << CCTRL_DS_BIT)
39 #define CCTRL_EE (0x1 << CCTRL_EE_BIT)
40 #define CCTRL_AE (0x1 << CCTRL_AE_BIT)
41 #define CCTRL_EL (0x1 << CCTRL_EL_BIT)
42 #define CCTRL_CD (0x1 << CCTRL_CD_BIT)
43 #define CCTRL_SU (0x3 << CCTRL_SU_BIT)
44 #define CCTRL_CL (0x1 << CCTRL_CL_BIT)
45 #define CCTRL_EN (0x1 << CCTRL_EN_BIT)
46 #define CCTRL_EVENTID (0xff << CCTRL_EVENTID_BIT)
47 #define CCTRL_CPUAHBM (0xf << CCTRL_CPUAHBM_BIT)
48
49 #define CCTRL_NCPU_BIT 28
50 #define CCTRL_NCNT_BIT 23
51 #define CCTRL_MC_BIT 22
52 #define CCTRL_IA_BIT 21
53 #define CCTRL_DS_BIT 20
54 #define CCTRL_EE_BIT 19
55 #define CCTRL_AE_BIT 18
56 #define CCTRL_EL_BIT 17
57 #define CCTRL_CD_BIT 16
58 #define CCTRL_SU_BIT 14
59 #define CCTRL_CL_BIT 13
60 #define CCTRL_EN_BIT 12
61 #define CCTRL_EVENTID_BIT 4
62 #define CCTRL_CPUAHBM_BIT 0
63
64 #define L4STAT_OPTIONS_EVENT_LEVEL_ENABLE CCTRL_EL
65 #define L4STAT_OPTIONS_EVENT_LEVEL_DISABLE 0
66 #define L4STAT_OPTIONS_MAXIMUM_DURATION CCTRL_CD
67 #define L4STAT_OPTIONS_SUPERVISOR_MODE_FILTER (0x1 << CCTRL_SU_BIT)
68 #define L4STAT_OPTIONS_USER_MODE_FILTER (0x2 << CCTRL_SU_BIT)
69 #define L4STAT_OPTIONS_NO_FILTER 0
70 #define L4STAT_OPTIONS_CLEAR_ON_READ CCTRL_CL
71
72 extern int l4stat_counter_enable(unsigned int counter, int event, int cpu, int options);
73 extern int l4stat_counter_disable(unsigned int counter);
74 extern int l4stat_counter_set(unsigned int counter, uint32_t val);
75 extern int l4stat_counter_get(unsigned int counter, uint32_t *val);
76
77 static inline int l4stat_counter_clear(unsigned int counter)
78 {
79  return l4stat_counter_set(counter, 0);
80 }
81
82 extern int l4stat_counter_max_set(unsigned int counter, uint32_t val);
83 extern int l4stat_counter_max_get(unsigned int counter, uint32_t *val);
84 extern int l4stat_tstamp_set(uint32_t val);
85 extern int l4stat_tstamp_get(uint32_t *val);
86
87 #ifdef __cplusplus
88 }
89 #endif
90
91 #endif
