RTEMS  5.1
l2c.h
1 /*
2  * GRLIB L2CACHE Driver
3  *
4  * COPYRIGHT (c) 2017
5  * Cobham Gaisler AB
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  *
11  * OVERVIEW
12  * ========
13  * This driver controls the L2CACHE device located
14  * at an on-chip AMBA.
15  */
16
17 #ifndef __L2CACHE_H__
18 #define __L2CACHE_H__
19
20 #include <stdint.h>
21 #include <stdio.h>
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif
26
27 extern void l2cache_register_drv(void);
28
29 #define L2CACHE_ERR_OK 0
30 #define L2CACHE_ERR_NOINIT -1
31 #define L2CACHE_ERR_EINVAL -2
32 #define L2CACHE_ERR_TOOMANY -3
33 #define L2CACHE_ERR_ERROR -4
34
35 /* L2C Flush options */
36 #define L2CACHE_OPTIONS_FLUSH_WAIT (0x1 << 2)
37 #define L2CACHE_OPTIONS_FLUSH_INVALIDATE (0x3 << 0)
38 #define L2CACHE_OPTIONS_FLUSH_WRITEBACK (0x2 << 0)
39 #define L2CACHE_OPTIONS_FLUSH_INV_WBACK (0x1 << 0)
40 #define L2CACHE_OPTIONS_FLUSH_NONE (0 << 0)
41
42 /* L2C Status */
43 #define L2CACHE_STATUS_ENABLED 1
44 #define L2CACHE_STATUS_SPLIT_ENABLED (0x1 << 1)
45 #define L2CACHE_STATUS_EDAC_ENABLED (0x1 << 2)
46 #define L2CACHE_STATUS_REPL (0x3 << L2CACHE_STATUS_REPL_BIT)
47 #define L2CACHE_STATUS_REPL_BIT 3
48 #define L2CACHE_STATUS_WRITETHROUGH (0x1 << 5)
49 #define L2CACHE_STATUS_LOCK (0xf << L2CACHE_STATUS_LOCK_BIT)
50 #define L2CACHE_STATUS_LOCK_BIT 6
51 #define L2CACHE_STATUS_SCRUB_ENABLED (0x1 << 10)
52 #define L2CACHE_STATUS_INT (0xf << L2CACHE_STATUS_INT_BIT)
53 #define L2CACHE_STATUS_INT_BIT 11
54 #define L2CACHE_STATUS_INT_BCKEND (0x1 << 11)
55 #define L2CACHE_STATUS_INT_WPHIT (0x1 << 12)
56 #define L2CACHE_STATUS_INT_UEE (0x1 << 13)
57 #define L2CACHE_STATUS_INT_CEE (0x1 << 14)
58 #define L2CACHE_STATUS_SCRUB_DELAY (0xffff << L2CACHE_STATUS_SCRUB_DELAY_BIT)
59 #define L2CACHE_STATUS_SCRUB_DELAY_BIT 15
60 #define L2CACHE_STATUS_SIGN_BIT 31
61
62 /* status helper macros */
63 #define L2CACHE_ENABLED(status) (status & L2CACHE_STATUS_ENABLED)
64 #define L2CACHE_DISABLED(status) (!(status & L2CACHE_STATUS_ENABLED))
65 #define L2CACHE_SPLIT_ENABLED(status) (status & L2CACHE_STATUS_SPLIT_ENABLED)
66 #define L2CACHE_SPLIT_DISABLED(status) \
67  (!(status & L2CACHE_STATUS_SPLIT_ENABLED))
68 #define L2CACHE_EDAC_ENABLED(status) (status & L2CACHE_STATUS_EDAC_ENABLED)
69 #define L2CACHE_EDAC_DISABLED(status) (!(status & L2CACHE_STATUS_EDAC_ENABLED))
70 #define L2CACHE_REPL(status) \
71  ((status & L2CACHE_STATUS_REPL) >> L2CACHE_STATUS_REPL_BIT)
72 #define L2CACHE_WRITETHROUGH(status) (status & L2CACHE_STATUS_WRITETHROUGH)
73 #define L2CACHE_WRITEBACK(status) (!(status & L2CACHE_STATUS_WRITETHROUGH))
74 #define L2CACHE_LOCKED_WAYS(status) \
75  ((status & L2CACHE_STATUS_LOCK) >> L2CACHE_STATUS_LOCK_BIT)
76 #define L2CACHE_SCRUB_ENABLED(status) (status & L2CACHE_STATUS_SCRUB_ENABLED)
77 #define L2CACHE_SCRUB_DISABLED(status) \
78  (!(status & L2CACHE_STATUS_SCRUB_ENABLED))
79 #define L2CACHE_SCRUB_DELAY(status) \
80  ((status & L2CACHE_STATUS_SCRUB_DELAY) >> L2CACHE_STATUS_SCRUB_DELAY_BIT)
81 #define L2CACHE_INT_ENABLED(status) (status & L2CACHE_STATUS_INT)
82 #define L2CACHE_INT_DISABLED(status) (!(status & L2CACHE_STATUS_INT))
83 extern int l2cache_status(void);
84
85 /* L2C Setup */
86 extern int l2cache_enable(int flush);
87 extern int l2cache_disable(int flush);
88
89 extern int l2cache_split_enable(void);
90 extern int l2cache_split_disable(void);
91
92 extern int l2cache_edac_enable(int flush);
93 extern int l2cache_edac_disable(int flush);
94
95 extern int l2cache_scrub_enable(int delay);
96 extern int l2cache_scrub_disable(void);
97 extern int l2cache_scrub_line(int way, int index);
98
99 extern int l2cache_writethrough(int flush);
100 extern int l2cache_writeback(int flush);
101
102 #define L2CACHE_OPTIONS_REPL_INDEX_WAY_BIT (2)
103 #define L2CACHE_OPTIONS_REPL_MASTERIDX_MOD (3 << 0)
104 #define L2CACHE_OPTIONS_REPL_MASTERIDX_IDX (2 << 0)
105 #define L2CACHE_OPTIONS_REPL_RANDOM (1 << 0)
106 #define L2CACHE_OPTIONS_REPL_LRU (0 << 0)
107 extern int l2cache_replacement(int options, int flush);
108
109 /* L2C Flush */
110 extern int l2cache_flush(int flush);
111 extern int l2cache_flush_address(uint32_t addr, int size, int flush);
112 extern int l2cache_flush_line(int way, int index, int flush);
113 extern int l2cache_flush_way(int way, int flush);
114
115 /* L2C Lock way */
116 #define L2CACHE_OPTIONS_DIRTY (0x1 << 2)
117 #define L2CACHE_OPTIONS_VALID (0x1 << 1)
118 #define L2CACHE_OPTIONS_FETCH (0x1 << 0)
119 #define L2CACHE_OPTIONS_DISABLE 2
120 #define L2CACHE_OPTIONS_ENABLE 1
121 #define L2CACHE_OPTIONS_NONE 0
122 extern int l2cache_lock_way(uint32_t tag, int options, int flush, int enable);
123 extern int l2cache_unlock(void);
124
125 /* L2C Fill a way */
126 extern int l2cache_fill_way(int way, uint32_t tag, int options, int flush);
127
128 /* L2C MTRR */
129 #define L2CACHE_OPTIONS_MTRR_ACCESS_WRITETHROUGH (0x1 << 2)
130 #define L2CACHE_OPTIONS_MTRR_ACCESS_UNCACHED (0x0 << 2)
131 #define L2CACHE_OPTIONS_MTRR_WRITEPROT_ENABLE (0x1 << 1)
132 #define L2CACHE_OPTIONS_MTRR_WRITEPROT_DISABLE (0x0 << 1)
133 extern int l2cache_mtrr_enable(int id, uint32_t addr, uint32_t mask,
134  int options, int flush);
135 extern int l2cache_mtrr_disable(int id);
136
137 /* L2C Debug print */
138 extern int l2cache_print(void);
139
140 /* L2C Interrupts */
141 /* Function Interrupt-Code ISR callback prototype.
142  * arg - Custom arg provided by user
143  * addr - Cacheline addr that generated the error
144  * status - Error status register of the L2CACHE core
145  */
146 typedef void (*l2cache_isr_t)(void *arg, uint32_t addr, uint32_t status);
147 #define L2CACHE_INTERRUPT_ALL (0xf << 0)
148 #define L2CACHE_INTERRUPT_BACKENDERROR (0x1 << 3)
149 #define L2CACHE_INTERRUPT_WPROTHIT (0x1 << 2)
150 #define L2CACHE_INTERRUPT_UNCORRERROR (0x1 << 1)
151 #define L2CACHE_INTERRUPT_CORRERROR (0x1 << 0)
152 extern int l2cache_isr_register( l2cache_isr_t isr, void * arg, int options);
153 extern int l2cache_isr_unregister(void);
154 extern int l2cache_interrupt_mask(int options);
155 extern int l2cache_interrupt_unmask(int options);
156
157 /* L2C error interface */
158 #define L2CACHE_STATUS_MULTIPLEERRORS 2
159 #define L2CACHE_STATUS_NEWERROR 1
160 #define L2CACHE_STATUS_NOERROR 0
161 extern int l2cache_error_status(uint32_t * addr, uint32_t * status);
162
163 /*#define TEST_L2CACHE*/
164 #ifdef TEST_L2CACHE
165 /* Used for internal testing */
166 /*
167  * L2CACHE Tag private data struture
168  */
169 struct l2cache_tag {
170  uint32_t tag;
171  int valid;
172  int dirty;
173  int lru;
174 };
175
176 /*
177  * L2CACHE Line private data struture
178  */
179 struct l2cache_dataline {
180  uint32_t data[16];
181  int words;
182 };
183 extern int l2cache_get_index( uint32_t addr);
184 extern uint32_t l2cache_get_tag( uint32_t addr);
185
186 extern int l2cache_diag_tag( int way, int index, struct l2cache_tag * tag);
187 extern int l2cache_diag_line( int way, int index,
188  struct l2cache_dataline * dataline);
189
190 #define L2CACHE_HIT 1
191 #define L2CACHE_MISS 0
192 extern int l2cache_lookup(uint32_t addr, int * way);
193
194 extern int l2cache_error_inject_address( uint32_t addr, uint32_t mask);
195 #endif /* TEST_L2CACHE */
196
197 #ifdef __cplusplus
198 }
199 #endif
200
201 #endif /* __L2CACHE_H__ */
unsigned size
Definition: tte.h:74
