RTEMS  5.1
jffs2_fs_sb.h
1 /*
2  * JFFS2 -- Journalling Flash File System, Version 2.
3  *
4  * Copyright © 2001-2007 Red Hat, Inc.
5  * Copyright © 2004-2010 David Woodhouse <dwmw2@infradead.org>
6  *
7  * Created by David Woodhouse <dwmw2@infradead.org>
8  *
9  * For licensing information, see the file 'LICENCE' in this directory.
10  *
11  */
12
13 #ifndef _JFFS2_FS_SB
14 #define _JFFS2_FS_SB
15
16 #include <linux/types.h>
17 #include <linux/spinlock.h>
18 #include <linux/workqueue.h>
19 #include <linux/completion.h>
20 #include <linux/mutex.h>
21 #include <linux/timer.h>
22 #include <linux/wait.h>
23 #include <linux/list.h>
24 #include <linux/rwsem.h>
25
26 #define JFFS2_SB_FLAG_RO 1
27 #define JFFS2_SB_FLAG_SCANNING 2 /* Flash scanning is in progress */
28 #define JFFS2_SB_FLAG_BUILDING 4 /* File system building is in progress */
29
30 struct jffs2_inodirty;
31
33  bool override_compr;
34  unsigned int compr;
35
36  /* The size of the reserved pool. The reserved pool is the JFFS2 flash
37  * space which may only be used by root cannot be used by the other
38  * users. This is implemented simply by means of not allowing the
39  * latter users to write to the file system if the amount if the
40  * available space is less then 'rp_size'. */
41  unsigned int rp_size;
42 };
43
44 /* A struct for the overall file system control. Pointers to
45  jffs2_sb_info structs are named `c' in the source code.
46  Nee jffs_control
47 */
48 struct jffs2_sb_info {
49  struct mtd_info *mtd;
50
51  uint32_t highest_ino;
52  uint32_t check_ino; /* *NEXT* inode to be checked */
53
54  unsigned int flags;
55
56  struct task_struct *gc_task; /* GC task struct */
57  struct completion gc_thread_start; /* GC thread start completion */
58  struct completion gc_thread_exit; /* GC thread exit completion port */
59
60  struct mutex alloc_sem; /* Used to protect all the following
61  fields, and also to protect against
62  out-of-order writing of nodes. And GC. */
63  uint32_t cleanmarker_size; /* Size of an _inline_ CLEANMARKER
64  (i.e. zero for OOB CLEANMARKER */
65
66  uint32_t flash_size;
67  uint32_t used_size;
68  uint32_t dirty_size;
69  uint32_t wasted_size;
70  uint32_t free_size;
71  uint32_t erasing_size;
72  uint32_t bad_size;
73  uint32_t sector_size;
74  uint32_t unchecked_size;
75
76  uint32_t nr_free_blocks;
77  uint32_t nr_erasing_blocks;
78
79  /* Number of free blocks there must be before we... */
80  uint8_t resv_blocks_write; /* ... allow a normal filesystem write */
81  uint8_t resv_blocks_deletion; /* ... allow a normal filesystem deletion */
82  uint8_t resv_blocks_gctrigger; /* ... wake up the GC thread */
83  uint8_t resv_blocks_gcbad; /* ... pick a block from the bad_list to GC */
84  uint8_t resv_blocks_gcmerge; /* ... merge pages when garbage collecting */
85  /* Number of 'very dirty' blocks before we trigger immediate GC */
86  uint8_t vdirty_blocks_gctrigger;
87
88  uint32_t nospc_dirty_size;
89
90  uint32_t nr_blocks;
91  struct jffs2_eraseblock *blocks; /* The whole array of blocks. Used for getting blocks
92  * from the offset (blocks[ofs / sector_size]) */
93  struct jffs2_eraseblock *nextblock; /* The block we're currently filling */
94
95  struct jffs2_eraseblock *gcblock; /* The block we're currently garbage-collecting */
96
97  struct list_head clean_list; /* Blocks 100% full of clean data */
98  struct list_head very_dirty_list; /* Blocks with lots of dirty space */
99  struct list_head dirty_list; /* Blocks with some dirty space */
100  struct list_head erasable_list; /* Blocks which are completely dirty, and need erasing */
101  struct list_head erasable_pending_wbuf_list; /* Blocks which need erasing but only after the current wbuf is flushed */
102  struct list_head erasing_list; /* Blocks which are currently erasing */
103  struct list_head erase_checking_list; /* Blocks which are being checked and marked */
104  struct list_head erase_pending_list; /* Blocks which need erasing now */
105  struct list_head erase_complete_list; /* Blocks which are erased and need the clean marker written to them */
106  struct list_head free_list; /* Blocks which are free and ready to be used */
107  struct list_head bad_list; /* Bad blocks. */
108  struct list_head bad_used_list; /* Bad blocks with valid data in. */
109
110  spinlock_t erase_completion_lock; /* Protect free_list and erasing_list
111  against erase completion handler */
112  wait_queue_head_t erase_wait; /* For waiting for erases to complete */
113
114  wait_queue_head_t inocache_wq;
115  int inocache_hashsize;
116  struct jffs2_inode_cache **inocache_list;
117  spinlock_t inocache_lock;
118
119  /* Sem to allow jffs2_garbage_collect_deletion_dirent to
120  drop the erase_completion_lock while it's holding a pointer
121  to an obsoleted node. I don't like this. Alternatives welcomed. */
122  struct mutex erase_free_sem;
123
124  uint32_t wbuf_pagesize; /* 0 for NOR and other flashes with no wbuf */
125
126 #ifdef CONFIG_JFFS2_FS_WBUF_VERIFY
127  unsigned char *wbuf_verify; /* read-back buffer for verification */
128 #endif
129 #ifdef CONFIG_JFFS2_FS_WRITEBUFFER
130  unsigned char *wbuf; /* Write-behind buffer for NAND flash */
131  uint32_t wbuf_ofs;
132  uint32_t wbuf_len;
133  struct jffs2_inodirty *wbuf_inodes;
134  struct rw_semaphore wbuf_sem; /* Protects the write buffer */
135
136  struct delayed_work wbuf_dwork; /* write-buffer write-out work */
137
138  unsigned char *oobbuf;
139  int oobavail; /* How many bytes are available for JFFS2 in OOB */
140 #endif
141
142  struct jffs2_summary *summary; /* Summary information */
143  struct jffs2_mount_opts mount_opts;
144
145 #ifdef CONFIG_JFFS2_FS_XATTR
146 #define XATTRINDEX_HASHSIZE (57)
147  uint32_t highest_xid;
148  uint32_t highest_xseqno;
149  struct list_head xattrindex[XATTRINDEX_HASHSIZE];
150  struct list_head xattr_unchecked;
151  struct list_head xattr_dead_list;
152  struct jffs2_xattr_ref *xref_dead_list;
153  struct jffs2_xattr_ref *xref_temp;
154  struct rw_semaphore xattr_sem;
155  uint32_t xdatum_mem_usage;
156  uint32_t xdatum_mem_threshold;
157 #endif
158  /* OS-private pointer for getting back to master superblock info */
159  void *os_priv;
160 };
161
162 #endif /* _JFFS2_FS_SB */
Definition: nodelist.h:158
Definition: nodelist.h:277
Definition: intercom.c:58
Definition: wait.h:5
Definition: list.h:57
Definition: summary.h:151
Definition: jffs2_fs_sb.h:48
Definition: spinlock.h:5
Definition: jffs2_fs_sb.h:32
Definition: xattr.h:45
Definition: completion.h:4
Definition: mutex.h:4
