RTEMS  5.1
interrupts.h
1
9 /*
10  * COPYRIGHT (c) 1998 valette@crf.canon.fr
11  *
12  * The license and distribution terms for this file may be
13  * found in the file LICENSE in this distribution or at
14  * http://www.rtems.org/license/LICENSE.
15  *
16  * Applications must not include this file directly.
17  */
18
28 #ifndef _RTEMS_SCORE_INTERRUPTS_H
29 #define _RTEMS_SCORE_INTERRUPTS_H
30
31 #ifndef ASM
32
34
35 typedef void (*rtems_raw_irq_hdl) (void);
36 typedef void (*rtems_raw_irq_enable) (const struct __rtems_raw_irq_connect_data__*);
37 typedef void (*rtems_raw_irq_disable) (const struct __rtems_raw_irq_connect_data__*);
38 typedef int (*rtems_raw_irq_is_enabled) (const struct __rtems_raw_irq_connect_data__*);
39
45 #if !defined(I386_DISABLE_INLINE_ISR_DISABLE_ENABLE)
46 #define i386_disable_interrupts( _level ) \
47  { \
48  __asm__ volatile ( "pushf ; \
49  cli ; \
50  pop %0" \
51  : "=rm" ((_level)) \
52  ); \
53  }
54
55 #define i386_enable_interrupts( _level ) \
56  { \
57  __asm__ volatile ( "push %0 ; \
58  popf" \
59  : : "rm" ((_level)) : "cc" \
60  ); \
61  }
62
63 #define i386_flash_interrupts( _level ) \
64  { \
65  __asm__ volatile ( "push %0 ; \
66  popf ; \
67  cli" \
68  : : "rm" ((_level)) : "cc" \
69  ); \
70  }
71
72 #define i386_get_interrupt_level( _level ) \
73  do { \
74  uint32_t _eflags; \
75  \
76  __asm__ volatile ( "pushf ; \
77  pop %0" \
78  : "=rm" ((_eflags)) \
79  ); \
80  \
81  _level = (_eflags & EFLAGS_INTR_ENABLE) ? 0 : 1; \
82  } while (0)
83 #else
84 uint32_t i386_disable_interrupts( void );
85 void i386_enable_interrupts(uint32_t level);
86 void i386_flash_interrupts(uint32_t level);
87 void i386_set_interrupt_level(uint32_t new_level);
88 uint32_t i386_get_interrupt_level( void );
89 #endif /* PARAVIRT */
90
94 #endif
95 #endif
Definition: i386.h:361
