RTEMS  5.1
imx_srcreg.h
1 /*
2  * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
3  *
4  * embedded brains GmbH
5  * Dornierstr. 4
6  * 82178 Puchheim
7  * Germany
8  * <info@embedded-brains.de>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef IMX_SRCREG_H
16 #define IMX_SRCREG_H
17
18 #include <bsp/utility.h>
19
20 typedef struct {
21  uint32_t scr;
22 #define IMX_SRC_SCR_DOM_EN BSP_BIT32(31)
23 #define IMX_SRC_SCR_LOCK BSP_BIT32(30)
24 #define IMX_SRC_SCR_DOMAIN3 BSP_BIT32(27)
25 #define IMX_SRC_SCR_DOMAIN2 BSP_BIT32(26)
26 #define IMX_SRC_SCR_DOMAIN1 BSP_BIT32(25)
27 #define IMX_SRC_SCR_DOMAIN0 BSP_BIT32(24)
28 #define IMX_SRC_SCR_MASK_TEMPSENSE_RESET(val) BSP_FLD32(val, 4, 7)
29 #define IMX_SRC_SCR_MASK_TEMPSENSE_RESET_GET(reg) BSP_FLD32GET(reg, 4, 7)
30 #define IMX_SRC_SCR_MASK_TEMPSENSE_RESET_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
31  uint32_t a7rcr0;
32 #define IMX_SRC_A7RCR0_DOM_EN BSP_BIT32(31)
33 #define IMX_SRC_A7RCR0_LOCK BSP_BIT32(30)
34 #define IMX_SRC_A7RCR0_DOMAIN3 BSP_BIT32(27)
35 #define IMX_SRC_A7RCR0_DOMAIN2 BSP_BIT32(26)
36 #define IMX_SRC_A7RCR0_DOMAIN1 BSP_BIT32(25)
37 #define IMX_SRC_A7RCR0_DOMAIN0 BSP_BIT32(24)
38 #define IMX_SRC_A7RCR0_A7_L2RESET BSP_BIT32(21)
39 #define IMX_SRC_A7RCR0_A7_SOC_DBG_RESET BSP_BIT32(20)
40 #define IMX_SRC_A7RCR0_MASK_WDOG1_RST(val) BSP_FLD32(val, 16, 19)
41 #define IMX_SRC_A7RCR0_MASK_WDOG1_RST_GET(reg) BSP_FLD32GET(reg, 16, 19)
42 #define IMX_SRC_A7RCR0_MASK_WDOG1_RST_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
43 #define IMX_SRC_A7RCR0_A7_ETM_RESET1 BSP_BIT32(13)
44 #define IMX_SRC_A7RCR0_A7_ETM_RESET0 BSP_BIT32(12)
45 #define IMX_SRC_A7RCR0_A7_DBG_RESET1 BSP_BIT32(9)
46 #define IMX_SRC_A7RCR0_A7_DBG_RESET0 BSP_BIT32(8)
47 #define IMX_SRC_A7RCR0_A7_CORE_RESET1 BSP_BIT32(5)
48 #define IMX_SRC_A7RCR0_A7_CORE_RESET0 BSP_BIT32(4)
49 #define IMX_SRC_A7RCR0_A7_CORE_POR_RESET1 BSP_BIT32(1)
50 #define IMX_SRC_A7RCR0_A7_CORE_POR_RESET0 BSP_BIT32(0)
51  uint32_t a7rcr1;
52 #define IMX_SRC_A7RCR1_DOM_EN BSP_BIT32(31)
53 #define IMX_SRC_A7RCR1_LOCK BSP_BIT32(30)
54 #define IMX_SRC_A7RCR1_DOMAIN3 BSP_BIT32(27)
55 #define IMX_SRC_A7RCR1_DOMAIN2 BSP_BIT32(26)
56 #define IMX_SRC_A7RCR1_DOMAIN1 BSP_BIT32(25)
57 #define IMX_SRC_A7RCR1_DOMAIN0 BSP_BIT32(24)
58 #define IMX_SRC_A7RCR1_A7_CORE1_ENABLE BSP_BIT32(1)
59  uint32_t m4rcr;
60 #define IMX_SRC_M4RCR_DOM_EN BSP_BIT32(31)
61 #define IMX_SRC_M4RCR_LOCK BSP_BIT32(30)
62 #define IMX_SRC_M4RCR_DOMAIN3 BSP_BIT32(27)
63 #define IMX_SRC_M4RCR_DOMAIN2 BSP_BIT32(26)
64 #define IMX_SRC_M4RCR_DOMAIN1 BSP_BIT32(25)
65 #define IMX_SRC_M4RCR_DOMAIN0 BSP_BIT32(24)
66 #define IMX_SRC_M4RCR_WDOG3_RST_OPTION BSP_BIT32(9)
67 #define IMX_SRC_M4RCR_WDOG3_RST_OPTION_M4 BSP_BIT32(8)
68 #define IMX_SRC_M4RCR_MASK_WDOG3_RST(val) BSP_FLD32(val, 4, 7)
69 #define IMX_SRC_M4RCR_MASK_WDOG3_RST_GET(reg) BSP_FLD32GET(reg, 4, 7)
70 #define IMX_SRC_M4RCR_MASK_WDOG3_RST_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
71 #define IMX_SRC_M4RCR_ENABLE_M4 BSP_BIT32(3)
72 #define IMX_SRC_M4RCR_SW_M4P_RST BSP_BIT32(2)
73 #define IMX_SRC_M4RCR_SW_M4C_RST BSP_BIT32(1)
74 #define IMX_SRC_M4RCR_SW_M4C_NON_SCLR_RST BSP_BIT32(0)
75  uint32_t reserved_10;
76  uint32_t ercr;
77  uint32_t reserved_18;
78  uint32_t hsicphy_rcr;
79  uint32_t usbophy1_rcr;
80  uint32_t usbophy2_rcr;
81  uint32_t mipiphy_rcr;
82  uint32_t pciephy_rcr;
83  uint32_t reserved_30[10];
84  uint32_t sbmr1;
85  uint32_t srsr;
86  uint32_t reserved_60[2];
87  uint32_t sisr;
88  uint32_t simr;
89  uint32_t sbmr2;
90  uint32_t gpr1;
91  uint32_t gpr2;
92  uint32_t gpr3;
93  uint32_t gpr4;
94  uint32_t gpr5;
95  uint32_t gpr6;
96  uint32_t gpr7;
97  uint32_t gpr8;
98  uint32_t gpr9;
99  uint32_t gpr10;
100  uint32_t reserved_9c[985];
101  uint32_t ddrc_rcr;
102 } imx_src;
103
104 #endif /* IMX_SRCREG_H */
Utility macros.
Definition: imx_srcreg.h:20
