RTEMS  5.1
imx_iomuxvar.h
1 /*-
2  * Copyright (c) 2014 Ian Lepore <ian@freebsd.org>
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  *
14  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24  * SUCH DAMAGE.
25  *
26  * $FreeBSD: head/sys/arm/freescale/imx/imx_iomuxvar.h 321938 2017-08-02 18:28:06Z ian $
27  */
28
29 #ifndef IMX_IOMUXVAR_H
30 #define IMX_IOMUXVAR_H
31
32 /*
33  * IOMUX interface functions
34  */
35 void iomux_set_function(u_int pin, u_int fn);
36 void iomux_set_pad(u_int pin, u_int cfg);
37 u_int iomux_get_pad_config(u_int pin);
38
39 /*
40  * The IOMUX Controller device has a small set of "general purpose registers"
41  * which control various aspects of SoC operation that really have nothing to do
42  * with IO pin assignments or pad control. These functions let other soc level
43  * code manipulate these values.
44  */
45 uint32_t imx_iomux_gpr_get(u_int regaddr);
46 void imx_iomux_gpr_set(u_int regaddr, uint32_t val);
47 void imx_iomux_gpr_set_masked(u_int regaddr, uint32_t clrbits, uint32_t setbits);
48
49 #endif
