RTEMS  5.1
imx_gpcreg.h
1 /*
2  * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
3  *
4  * embedded brains GmbH
5  * Dornierstr. 4
6  * 82178 Puchheim
7  * Germany
8  * <info@embedded-brains.de>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef IMX_GPCREG_H
16 #define IMX_GPCREG_H
17
18 #include <bsp/utility.h>
19
20 typedef struct {
21  uint32_t lpcr_a7_bsc;
22  uint32_t lpcr_a7_ad;
23  uint32_t lpcr_m4;
24  uint32_t reserved_0c[2];
25  uint32_t slpcr;
26  uint32_t reserved_18[2];
27  uint32_t mlpcr;
28  uint32_t pgc_ack_sel_a7;
29  uint32_t pgc_ack_sel_m4;
30  uint32_t misc;
31  uint32_t imr1_core0_a7;
32  uint32_t imr2_core0_a7;
33  uint32_t imr3_core0_a7;
34  uint32_t imr4_core0_a7;
35  uint32_t imr1_core1_a7;
36  uint32_t imr2_core1_a7;
37  uint32_t imr3_core1_a7;
38  uint32_t imr4_core1_a7;
39  uint32_t imr1_m4;
40  uint32_t imr2_m4;
41  uint32_t imr3_m4;
42  uint32_t imr4_m4;
43  uint32_t reserved_60[4];
44  uint32_t isr1_a7;
45  uint32_t isr2_a7;
46  uint32_t isr3_a7;
47  uint32_t isr4_a7;
48  uint32_t isr1_m4;
49  uint32_t isr2_m4;
50  uint32_t isr3_m4;
51  uint32_t isr4_m4;
52  uint32_t reserved_90[8];
53  uint32_t slt0_cfg;
54  uint32_t slt1_cfg;
55  uint32_t slt2_cfg;
56  uint32_t slt3_cfg;
57  uint32_t slt4_cfg;
58  uint32_t slt5_cfg;
59  uint32_t slt6_cfg;
60  uint32_t slt7_cfg;
61  uint32_t slt8_cfg;
62  uint32_t slt9_cfg;
63  uint32_t reserved_d8[5];
64  uint32_t pgc_cpu_mapping;
65 #define IMX_GPC_CPU_PGC_SCU_A7 BSP_BIT32(2)
66 #define IMX_GPC_CPU_PGC_CORE1_A7 BSP_BIT32(1)
67 #define IMX_GPC_CPU_PGC_CORE0_A7 BSP_BIT32(0)
68 #define IMX_GPC_PU_PGC_USB_HSIC_PHY BSP_BIT32(4)
69 #define IMX_GPC_PU_PGC_USB_OTG2_PHY BSP_BIT32(3)
70 #define IMX_GPC_PU_PGC_USB_OTG1_PHY BSP_BIT32(2)
71 #define IMX_GPC_PU_PGC_PCIE_PHY BSP_BIT32(1)
72 #define IMX_GPC_PU_PGC_MIPI_PHY BSP_BIT32(0)
73  uint32_t cpu_pgc_sw_pup_req;
74  uint32_t reserved_f4;
75  uint32_t pu_pgc_sw_pup_req;
76  uint32_t cpu_pgc_sw_pdn_req;
77  uint32_t reserved_100;
78  uint32_t pu_pgc_sw_pdn_req;
79  uint32_t reserved_108[10];
80  uint32_t cpu_pgc_pup_status1;
81  uint32_t a7_mix_pgc_pup_status0;
82  uint32_t a7_mix_pgc_pup_status1;
83  uint32_t a7_mix_pgc_pup_status2;
84  uint32_t m4_mix_pgc_pup_status0;
85  uint32_t m4_mix_pgc_pup_status1;
86  uint32_t m4_mix_pgc_pup_status2;
87  uint32_t a7_pu_pgc_pup_status0;
88  uint32_t a7_pu_pgc_pup_status1;
89  uint32_t a7_pu_pgc_pup_status2;
90  uint32_t m4_pu_pgc_pup_status0;
91  uint32_t m4_pu_pgc_pup_status1;
92  uint32_t m4_pu_pgc_pup_status2;
93  uint32_t reserved_164[3];
94  uint32_t cpu_pgc_pdn_status1;
95  uint32_t reserved_174[6];
96  uint32_t a7_pu_pgc_pdn_status0;
97  uint32_t a7_pu_pgc_pdn_status1;
98  uint32_t a7_pu_pgc_pdn_status2;
99  uint32_t m4_pu_pgc_pdn_status0;
100  uint32_t m4_pu_pgc_pdn_status1;
101  uint32_t m4_pu_pgc_pdn_status2;
102  uint32_t reserved_1a4[3];
103  uint32_t a7_mix_pdn_flg;
104  uint32_t a7_pu_pdn_flg;
105  uint32_t m4_mix_pdn_flg;
106  uint32_t m4_pu_pdn_flg;
107 #define IMX_GPC_PGC_CTRL_MEMPWR_TCD1_TDR_TRM(val) BSP_FLD32(val, 24, 29)
108 #define IMX_GPC_PGC_CTRL_MEMPWR_TCD1_TDR_TRM_GET(reg) BSP_FLD32GET(reg, 24, 29)
109 #define IMX_GPC_PGC_CTRL_MEMPWR_TCD1_TDR_TRM_SET(reg, val) BSP_FLD32SET(reg, val, 24, 29)
110 #define IMX_GPC_PGC_CTRL_L2RETN_TCD1_TDR(val) BSP_FLD32(val, 16, 21)
111 #define IMX_GPC_PGC_CTRL_L2RETN_TCD1_TDR_GET(reg) BSP_FLD32GET(reg, 16, 21)
112 #define IMX_GPC_PGC_CTRL_L2RETN_TCD1_TDR_SET(reg, val) BSP_FLD32SET(reg, val, 16, 21)
113 #define IMX_GPC_PGC_CTRL_DFTRAM_TCD1(val) BSP_FLD32(val, 8, 13)
114 #define IMX_GPC_PGC_CTRL_DFTRAM_TCD1_GET(reg) BSP_FLD32GET(reg, 8, 13)
115 #define IMX_GPC_PGC_CTRL_DFTRAM_TCD1_SET(reg, val) BSP_FLD32SET(reg, val, 8, 13)
116 #define IMX_GPC_PGC_CTRL_L2RSTDIS(val) BSP_FLD32(val, 1, 6)
117 #define IMX_GPC_PGC_CTRL_L2RSTDIS_GET(reg) BSP_FLD32GET(reg, 1, 6)
118 #define IMX_GPC_PGC_CTRL_L2RSTDIS_SET(reg, val) BSP_FLD32SET(reg, val, 1, 6)
119 #define IMX_GPC_PGC_CTRL_PCR BSP_BIT32(0)
120  uint32_t reserved_1c0[400];
121  uint32_t pgc_a7core0_ctrl;
122  uint32_t pgc_a7core0_pupscr;
123  uint32_t pgc_a7core0_pdnscr;
124  uint32_t pgc_a7core0_sr;
125  uint32_t reserved_810[12];
126  uint32_t pgc_a7core1_ctrl;
127  uint32_t pgc_a7core1_pupscr;
128  uint32_t pgc_a7core1_pdnscr;
129  uint32_t pgc_a7core1_sr;
130  uint32_t reserved_850[12];
131  uint32_t pgc_a7scu_ctrl;
132  uint32_t pgc_a7scu_pupscr;
133  uint32_t pgc_a7scu_pdnscr;
134  uint32_t pgc_a7scu_sr;
135  uint32_t pgc_scu_auxsw;
136  uint32_t reserved_894[11];
137  uint32_t pgc_mix_ctrl;
138  uint32_t pgc_mix_pupscr;
139  uint32_t pgc_mix_pdnscr;
140  uint32_t pgc_mix_sr;
141  uint32_t reserved_8d0[12];
142  uint32_t pgc_mipi_ctrl;
143  uint32_t pgc_mipi_pupscr;
144  uint32_t pgc_mipi_pdnscr;
145  uint32_t pgc_mipi_sr;
146  uint32_t reserved_910[12];
147  uint32_t pgc_pcie_ctrl;
148  uint32_t pgc_pcie_pupscr;
149  uint32_t pgc_pcie_pdnscr;
150  uint32_t pgc_pcie_sr;
151  uint32_t reserved_950[176];
152  uint32_t pgc_mipi_auxsw;
153  uint32_t reserved_c14[15];
154  uint32_t pgc_pcie_auxsw;
155  uint32_t reserved_c54[43];
156  uint32_t pgc_hsic_ctrl;
157  uint32_t pgc_hsic_pupscr;
158  uint32_t pgc_hsic_pdnscr;
159  uint32_t pgc_hsic_sr;
160 } imx_gpc;
161
162 #endif /* IMX_GPCREG_H */
Definition: imx_gpcreg.h:20
Utility macros.
