RTEMS  5.1
imx_ecspireg.h
1 /*
2  * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
3  *
4  * embedded brains GmbH
5  * Dornierstr. 4
6  * 82178 Puchheim
7  * Germany
8  * <info@embedded-brains.de>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef IMX_ECSPIREG_H
16 #define IMX_ECSPIREG_H
17
18 #include <bsp/utility.h>
19
20 typedef struct {
21  uint32_t rxdata;
22  uint32_t txdata;
23  uint32_t conreg;
24 #define IMX_ECSPI_CONREG_BURST_LENGTH(val) BSP_FLD32(val, 20, 31)
25 #define IMX_ECSPI_CONREG_BURST_LENGTH_GET(reg) BSP_FLD32GET(reg, 20, 31)
26 #define IMX_ECSPI_CONREG_BURST_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 20, 31)
27 #define IMX_ECSPI_CONREG_CHANNEL_SELECT(val) BSP_FLD32(val, 18, 19)
28 #define IMX_ECSPI_CONREG_CHANNEL_SELECT_GET(reg) BSP_FLD32GET(reg, 18, 19)
29 #define IMX_ECSPI_CONREG_CHANNEL_SELECT_SET(reg, val) BSP_FLD32SET(reg, val, 18, 19)
30 #define IMX_ECSPI_CONREG_DRCTL(val) BSP_FLD32(val, 16, 17)
31 #define IMX_ECSPI_CONREG_DRCTL_GET(reg) BSP_FLD32GET(reg, 16, 17)
32 #define IMX_ECSPI_CONREG_DRCTL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 17)
33 #define IMX_ECSPI_CONREG_PRE_DIVIDER(val) BSP_FLD32(val, 12, 15)
34 #define IMX_ECSPI_CONREG_PRE_DIVIDER_GET(reg) BSP_FLD32GET(reg, 12, 15)
35 #define IMX_ECSPI_CONREG_PRE_DIVIDER_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
36 #define IMX_ECSPI_CONREG_POST_DIVIDER(val) BSP_FLD32(val, 8, 11)
37 #define IMX_ECSPI_CONREG_POST_DIVIDER_GET(reg) BSP_FLD32GET(reg, 8, 11)
38 #define IMX_ECSPI_CONREG_POST_DIVIDER_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
39 #define IMX_ECSPI_CONREG_CHANNEL_MODE(val) BSP_FLD32(val, 4, 7)
40 #define IMX_ECSPI_CONREG_CHANNEL_MODE_GET(reg) BSP_FLD32GET(reg, 4, 7)
41 #define IMX_ECSPI_CONREG_CHANNEL_MODE_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
42 #define IMX_ECSPI_CONREG_SMC BSP_BIT32(3)
43 #define IMX_ECSPI_CONREG_XCH BSP_BIT32(2)
44 #define IMX_ECSPI_CONREG_HT BSP_BIT32(1)
45 #define IMX_ECSPI_CONREG_EN BSP_BIT32(0)
46  uint32_t configreg;
47 #define IMX_ECSPI_CONFIGREG_HT_LENGTH(val) BSP_FLD32(val, 24, 28)
48 #define IMX_ECSPI_CONFIGREG_HT_LENGTH_GET(reg) BSP_FLD32GET(reg, 24, 28)
49 #define IMX_ECSPI_CONFIGREG_HT_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 24, 28)
50 #define IMX_ECSPI_CONFIGREG_SCLK_CTL(val) BSP_FLD32(val, 20, 23)
51 #define IMX_ECSPI_CONFIGREG_SCLK_CTL_GET(reg) BSP_FLD32GET(reg, 20, 23)
52 #define IMX_ECSPI_CONFIGREG_SCLK_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 20, 23)
53 #define IMX_ECSPI_CONFIGREG_DATA_CTL(val) BSP_FLD32(val, 16, 19)
54 #define IMX_ECSPI_CONFIGREG_DATA_CTL_GET(reg) BSP_FLD32GET(reg, 16, 19)
55 #define IMX_ECSPI_CONFIGREG_DATA_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
56 #define IMX_ECSPI_CONFIGREG_SS_POL(val) BSP_FLD32(val, 12, 15)
57 #define IMX_ECSPI_CONFIGREG_SS_POL_GET(reg) BSP_FLD32GET(reg, 12, 15)
58 #define IMX_ECSPI_CONFIGREG_SS_POL_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
59 #define IMX_ECSPI_CONFIGREG_SS_CTL(val) BSP_FLD32(val, 8, 11)
60 #define IMX_ECSPI_CONFIGREG_SS_CTL_GET(reg) BSP_FLD32GET(reg, 8, 11)
61 #define IMX_ECSPI_CONFIGREG_SS_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
62 #define IMX_ECSPI_CONFIGREG_SCLK_POL(val) BSP_FLD32(val, 4, 7)
63 #define IMX_ECSPI_CONFIGREG_SCLK_POL_GET(reg) BSP_FLD32GET(reg, 4, 7)
64 #define IMX_ECSPI_CONFIGREG_SCLK_POL_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
65 #define IMX_ECSPI_CONFIGREG_SCLK_PHA(val) BSP_FLD32(val, 0, 3)
66 #define IMX_ECSPI_CONFIGREG_SCLK_PHA_GET(reg) BSP_FLD32GET(reg, 0, 3)
67 #define IMX_ECSPI_CONFIGREG_SCLK_PHA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
68 #define IMX_ECSPI_TC BSP_BIT32(7)
69 #define IMX_ECSPI_RO BSP_BIT32(6)
70 #define IMX_ECSPI_RF BSP_BIT32(5)
71 #define IMX_ECSPI_RDR BSP_BIT32(4)
72 #define IMX_ECSPI_RR BSP_BIT32(3)
73 #define IMX_ECSPI_TF BSP_BIT32(2)
74 #define IMX_ECSPI_TDR BSP_BIT32(1)
75 #define IMX_ECSPI_TE BSP_BIT32(0)
76  uint32_t intreg;
77  uint32_t dmareg;
78 #define IMX_ECSPI_DMAREG_RXTDEN BSP_BIT32(31)
79 #define IMX_ECSPI_DMAREG_RX_DMA_LENGTH(val) BSP_FLD32(val, 24, 29)
80 #define IMX_ECSPI_DMAREG_RX_DMA_LENGTH_GET(reg) BSP_FLD32GET(reg, 24, 29)
81 #define IMX_ECSPI_DMAREG_RX_DMA_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 24, 29)
82 #define IMX_ECSPI_DMAREG_RXDEN BSP_BIT32(23)
83 #define IMX_ECSPI_DMAREG_RX_THRESHOLD(val) BSP_FLD32(val, 16, 21)
84 #define IMX_ECSPI_DMAREG_RX_THRESHOLD_GET(reg) BSP_FLD32GET(reg, 16, 21)
85 #define IMX_ECSPI_DMAREG_RX_THRESHOLD_SET(reg, val) BSP_FLD32SET(reg, val, 16, 21)
86 #define IMX_ECSPI_DMAREG_TEDEN BSP_BIT32(7)
87 #define IMX_ECSPI_DMAREG_TX_THRESHOLD(val) BSP_FLD32(val, 0, 5)
88 #define IMX_ECSPI_DMAREG_TX_THRESHOLD_GET(reg) BSP_FLD32GET(reg, 0, 5)
89 #define IMX_ECSPI_DMAREG_TX_THRESHOLD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
90  uint32_t statreg;
91  uint32_t periodreg;
92 #define IMX_ECSPI_PERIODREG_CSD_CTL(val) BSP_FLD32(val, 16, 21)
93 #define IMX_ECSPI_PERIODREG_CSD_CTL_GET(reg) BSP_FLD32GET(reg, 16, 21)
94 #define IMX_ECSPI_PERIODREG_CSD_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 21)
95 #define IMX_ECSPI_PERIODREG_CSRC BSP_BIT32(15)
96 #define IMX_ECSPI_PERIODREG_SAMPLE_PERIOD(val) BSP_FLD32(val, 0, 14)
97 #define IMX_ECSPI_PERIODREG_SAMPLE_PERIOD_GET(reg) BSP_FLD32GET(reg, 0, 14)
98 #define IMX_ECSPI_PERIODREG_SAMPLE_PERIOD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 14)
99  uint32_t testreg;
100 #define IMX_ECSPI_TESTREG_LBC BSP_BIT32(31)
101 #define IMX_ECSPI_TESTREG_RXCNT(val) BSP_FLD32(val, 8, 14)
102 #define IMX_ECSPI_TESTREG_RXCNT_GET(reg) BSP_FLD32GET(reg, 8, 14)
103 #define IMX_ECSPI_TESTREG_RXCNT_SET(reg, val) BSP_FLD32SET(reg, val, 8, 14)
104 #define IMX_ECSPI_TESTREG_TXCNT(val) BSP_FLD32(val, 0, 6)
105 #define IMX_ECSPI_TESTREG_TXCNT_GET(reg) BSP_FLD32GET(reg, 0, 6)
106 #define IMX_ECSPI_TESTREG_TXCNT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
107  uint32_t reserved_24[7];
108  uint32_t msgdata;
109 } imx_ecspi;
110
111 #endif /* IMX_ECSPIREG_H */
Definition: imx_ecspireg.h:20
Utility macros.
