RTEMS  5.1
imx_ccmvar.h
1 /*-
2  * Copyright (c) 2014 Ian Lepore <ian@freebsd.org>
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  *
14  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24  * SUCH DAMAGE.
25  *
26  * $FreeBSD: head/sys/arm/freescale/imx/imx_ccmvar.h 292565 2015-12-21 20:17:24Z gonzo $
27  */
28
29 #ifndef IMX_CCMVAR_H
30 #define IMX_CCMVAR_H
31
32 /*
33  * We need a clock management system that works across unrelated SoCs and
34  * devices. For now, to keep imx development moving, define some barebones
35  * functionality that can be shared within the imx family by having each SoC
36  * implement functions with a common name.
37  *
38  * The usb enable functions are best-effort. They turn on the usb otg, host,
39  * and phy clocks in a SoC-specific manner, but it may take a lot more than that
40  * to make usb work on a given board. In particular, it can require specific
41  * pinmux setup of gpio pins connected to external phy parts, voltage regulators
42  * and overcurrent detectors, and so on. On such boards, u-boot or other early
43  * board setup code has to handle those things.
44  */
45
46 uint32_t imx_ccm_ipg_hz(void);
47 uint32_t imx_ccm_perclk_hz(void);
48 uint32_t imx_ccm_sdhci_hz(void);
49 uint32_t imx_ccm_uart_hz(void);
50 uint32_t imx_ccm_ahb_hz(void);
51 #ifdef __rtems__
52 uint32_t imx_ccm_ecspi_hz(void);
53 #endif /* __rtems__ */
54
55 #ifndef __rtems__
56 void imx_ccm_usb_enable(device_t _usbdev);
57 void imx_ccm_usbphy_enable(device_t _phydev);
58 void imx_ccm_ssi_configure(device_t _ssidev);
59 void imx_ccm_hdmi_enable(void);
60 void imx_ccm_ipu_enable(int ipu);
61
62 /* Routines to get and set the arm clock root divisor register. */
63 uint32_t imx_ccm_get_cacrr(void);
64 void imx_ccm_set_cacrr(uint32_t _divisor);
65 #endif /* __rtems__ */
66
67 #endif
Definition: rtemscompat1.h:15
