RTEMS  5.1
ili9488_spi.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
37 #ifndef _ILI9488_SPI_H_
38 #define _ILI9488_SPI_H_
39
40 /*------------------------------------------------------------------------------
41  * Headers
42  *----------------------------------------------------------------------------*/
43
44 #include "board.h"
45
46 /*------------------------------------------------------------------------------
47  * Exported functions
48  *----------------------------------------------------------------------------*/
49 extern uint32_t ILI9488_SpiReadChipId (void);
50 extern uint32_t ILI9488_SpiInitialize(sXdmad *dmad);
51 extern void ILI9488_SpiSetPixelFormat(uint8_t format);
52 extern void ILI9488_SpiNop(void);
53 extern void ILI9488_SpiWriteMemory(const uint8_t *pBuf, uint32_t size);
54 extern void ILI9488_SpiReadMemory(const uint8_t *pBuf, uint32_t size);
55 extern void ILI9488_SpiSetCursor(uint16_t x, uint16_t y);
56 extern void ILI9488_SpiSetWindow(
57  uint16_t dwX,
58  uint16_t dwY,
59  uint16_t dwWidth,
60  uint16_t dwHeight);
61
62 extern void ILI9488_SpiSetFullWindow(void);
63 extern void ILI9488_SpiOn(void);
64 extern void ILI9488_SpiOff(void);
65 extern void ILI9488_SpiSetDisplayLandscape(
66  uint8_t dwRGB, uint8_t LandscaprMode);
67 extern void ILI9488_SetPixelColor(uint32_t x, uint32_t y, uint32_t color);
68
69 #endif /* #ifndef ILI9488_SPI */
Definition: mknod-pack_dev.c:254
unsigned size
Definition: tte.h:74
Definition: xdmad.h:127
